path: root/arch/um/kernel/ptrace.c
2007-10-20spelling fixes: arch/um/Simon Arlott
Spelling fixes in arch/um/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-16uml: style fixes in FP codeJeff Dike
Tidy the code affected by the floating point fixes. A bunch of unused stuff is gone, including two sigcontext.c files, which turned out to be entirely unneeded. There are the usual fixes - whitespace and style cleanups copyright updates emacs formatting comments gone include cleanups adding severities to printks Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: ptrace floating point fixesJeff Dike
Handle floating point state better in ptrace. The code now correctly distinguishes between PTRACE_[GS]ETFPREGS and PTRACE_[GS]ETFPXREGS. The FPX requests get handed off to arch-specific code because that's not generic. get_fpregs, set_fpregs, set_fpregs, and set_fpxregs needed real implementations. Something here exposed a missing include in asm/page.h, which needed linux/types.h in order to get gfp_t, so that's fixed here. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: style fixes pass 3Jeff Dike
Formatting changes in the files which have been changed in the course of folding foo_skas functions into their callers. These include: copyright updates header file trimming style fixes adding severity to printks These changes should be entirely non-functional. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: remove code made redundant by CHOOSE_MODE removalJeff Dike
This patch makes a number of simplifications enabled by the removal of CHOOSE_MODE. There were lots of functions that looked like int foo(args){ foo_skas(args); } The bodies of foo_skas are now folded into foo, and their declarations (and sometimes entire header files) are deleted. In addition, the union uml_pt_regs, which was a union between the tt and skas register formats, is now a struct, with the tt-mode arm of the union being removed. It turns out that usr2_handler was unused, so it is gone. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Consolidate PTRACE_DETACHAlexey Dobriyan
Identical handlers of PTRACE_DETACH go into ptrace_request(). Not touching compat code. Not touching archs that don't call ptrace_request. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17PTRACE_POKEDATA consolidationAlexey Dobriyan
Identical implementations of PTRACE_POKEDATA go into generic_ptrace_pokedata() function. AFAICS, fix bug on xtensa where successful PTRACE_POKEDATA will nevertheless return EPERM. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17PTRACE_PEEKDATA consolidationAlexey Dobriyan
Identical implementations of PTRACE_PEEKDATA go into generic_ptrace_peekdata() function. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: x86_64 ptrace fixesJeff Dike
This patch fixes some missing ptrace bits on x86_64. PTRACE_ARCH_PRCTL is hooked up and implemented. This required generalizing arch_prctl_skas slightly to take a task_struct to modify. Previously, it always operated on current. Reading and writing the debug registers is also enabled by un-ifdefing the code that implements that. It turns out that x86_64 is identical to i386, so the same code can be used. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-05-01[PATCH] drop task argument of audit_syscall_{entry,exit}Al Viro
... it's always current, and that's a good thing - allows simpler locking. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-03-31[PATCH] uml: implement {get,set}_thread_area for i386Paolo 'Blaisorblade' Giarrusso
Implement sys_[gs]et_thread_area and the corresponding ptrace operations for UML. This is the main chunk, additional parts follow. This implementation is now well tested and has run reliably for some time, and we've understood all the previously existing problems. Their implementation saves the new GDT content and then forwards the call to the host when appropriate, i.e. immediately when the target process is running or on context switch otherwise (i.e. on fork and on ptrace() calls). In SKAS mode, we must switch registers on each context switch (because SKAS does not switches tls_array together with current->mm). Also, added get_cpu() locking; this has been done for SKAS mode, since TT does not need it (it does not use smp_processor_id()). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] uml: sparse cleanupsAl Viro
misc sparse annotations Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] consolidate sys_ptrace()Christoph Hellwig
The sys_ptrace boilerplate code (everything outside the big switch statement for the arch-specific requests) is shared by most architectures. This patch moves it to kernel/ptrace.c and leaves the arch-specific code as arch_ptrace. Some architectures have a too different ptrace so we have to exclude them. They continue to keep their implementations. For sh64 I had to add a sh64_ptrace wrapper because it does some initialization on the first call. For um I removed an ifdefed SUBARCH_PTRACE_SPECIAL block, but SUBARCH_PTRACE_SPECIAL isn't defined anywhere in the tree. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-By: David Howells <dhowells@redhat.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-28[PATCH] uml: fix a couple of warningsJeff Dike
Eliminate an unused variable warning in ptrace.c and a size mismatch warning by adding a cast to __pa. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-20[PATCH] uml: small fixes left over from rc4Jeff Dike
Some changes that I sent in didn't make 2.6.12-rc4 for some reason. This adds them back. We have an x86_64 definition of TOP_ADDR a reimplementation of the x86_64 csum_partial_copy_from_user some syntax fixes in arch/um/kernel/ptrace.c removal of a CFLAGS definition in the x86_64 Makefile some include changes in the x86_64 ptrace.c and user-offsets.h a syntax fix in elf-x86_64.h Also moved an include in the i386 and x86_64 Makefiles to make the symlinks work, and some small fixes from Al Viro. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-06[PATCH] uml: S390 preparation, peekusr/pokeusr defined by subarchBodo Stroesser
s390 needs to change some parts of arch/um/kernel/ptrace.c. Thus, the code regarding PEEKUSER and POKEUSER are shifted to arch/um/sys-<subarch>/ptrace.c. Also s390 debug registers need to be updated, when singlestepping is switched on / off. Thus, setting/resetting of singlestepping is centralized in the new function set_singlestep(), which also inserts the macro SUBARCH_SET_SINGLESTEP(mode), if defined. Finally, s390 has the "ieee_instruction_pointer" in its registers, which also is allowed to be read via ptrace( PTRACE_PEEKUSER, getpid(), PT_IEEE_IP, 0); To implement this feature, sys_ptrace inserts the macro SUBARCH_PTRACE_SPECIAL, if defined. Signed-off-by: Bodo Stroesser <bstroesser@fujitsu-siemens.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] uml: header and code cleanupBodo Stroesser
Remove some definitions and declarations from arch/um/include/skas_ptrace.h, as they have moved to arch/um/include/sysdep/skas_ptrace.h Also, remove PTRACE_SIGPENDING support in UML at all. Signed-off-by: Bodo Stroesser <bstroesser@fujitsu-siemens.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] uml: S390 preparation, abstract host page fault dataBodo Stroesser
This patch removes the arch-specific fault/trap-infos from thread and skas-regs. It adds a new struct faultinfo, that is arch-specific defined in sysdep/faultinfo.h. The structure is inserted in thread.arch and thread.regs.skas and thread.regs.tt Now, segv and other trap-handlers can copy the contents from regs.X.faultinfo to thread.arch.faultinfo with one simple assignment. Also, the number of macros necessary is reduced to FAULT_ADDRESS(struct faultinfo) extracts the faulting address from faultinfo FAULT_WRITE(struct faultinfo) extracts the "is_write" flag SEGV_IS_FIXABLE(struct faultinfo) is true for the fixable segvs, i.e. (TRAP == 14) on i386 UPT_FAULTINFO(regs) result is (struct faultinfo *) to the faultinfo in regs->skas.faultinfo GET_FAULTINFO_FROM_SC(struct faultinfo, struct sigcontext *) copies the relevant parts of the sigcontext to struct faultinfo. On SIGSEGV, call user_signal() instead of handle_segv(), if the architecture provides the information needed in PTRACE_FAULTINFO, or if PTRACE_FAULTINFO is missing, because segv-stub will provide the info. The benefit of the change is, that in case of a non-fixable SIGSEGV, we can give user processes a SIGSEGV, instead of possibly looping on pagefault handling. Since handle_segv() sikked arch_fixup() implicitly by passing ip==0 to segv(), I changed segv() to call arch_fixup() only, if !is_user. Signed-off-by: Bodo Stroesser <bstroesser@fujitsu-siemens.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] uml: obvious compile fixes for x86-64 Subarch and x86 regression fixesPaolo 'Blaisorblade' Giarrusso
This patch does some totally trivial compilation fixes. It also restores the debugregs manipulation, which was commented out simply because it doesn't compile on x86_64 (we haven't yet implemented there debugregs handling). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-03Merge with master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6.gitDavid Woodhouse
2005-05-03[AUDIT] Update UML audit-syscall-{entry,exit} calls to new prototypesJeff Dike
This patch is for -mm only. It should probably be included in git-audit, and should be forwarded to Linus iff git-audit is. It updates the audit-syscall-{entry,exit} calls to current -mm. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-05-01[PATCH] convert that currently tests _NSIG directly to use valid_signal()Jesper Juhl
Convert most of the current code that uses _NSIG directly to instead use valid_signal(). This avoids gcc -W warnings and off-by-one errors. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
