path: root/arch/um/kernel/sysrq.c
2008-02-05uml: style fixes in arch/um/kernelJeff Dike
Joe Perches noticed some printks in smp.c that needed fixing. While I was in there, I did the usual tidying in arch/um/kernel, which should be fairly style-clean at this point: copyright updates emacs formatting comments removal include tidying style fixes Cc: Joe Perches <joe@perches.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: remove user_util.hJeff Dike
user_util.h isn't needed any more, so delete it and remove all includes of it. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: const a variableJeff Dike
kstack_depth_to_print can be made const. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-04Remove all inclusions of <linux/config.h>Dave Jones
kbuild explicitly includes this at build time. Signed-off-by: Dave Jones <davej@redhat.com>
2005-10-04[PATCH] uml: Fix sysrq-r support for skas modeAllan Graves
The old code had the IP and SP coming from the registers in the thread struct, which are completely wrong since those are the userspace registers. This fixes that by pulling the correct values from the jmp_buf in which the kernel state of each thread is stored. Signed-off-by: Allan Graves <allan.graves@oracle.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-28[PATCH] uml: stack dump fixPaolo 'Blaisorblade' Giarrusso
Copy (and adapt) to UML the stack code dumper used in i386 when CONFIG_FRAME_POINTER is enabled. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
