ksyms.c is down to the stuff defined in various USER_OBJS
Signed-off-by: Richard Weinberger <richard@nod.at>
This patch makes os_get_task_size locate the bottom of the address space,
as well as the top. This is for systems which put a lower limit on mmap
addresses. It works by manually scanning pages from zero onwards until a
valid page is found.
Because the bottom of the address space may not be zero, it's not
sufficient to assume the top of the address space is the size of the
address space. The size is the difference between the top address and
bottom address.
[jdike@addtoit.com: changed the name to reflect that this function is
supposed to return the top of the process address space, not its size and
changed the return value to reflect that. Also some minor formatting
changes]
Signed-off-by: Tom Spink <tspink@gmail.com>
Signed-off-by: Jeff Dike <jdike@linux.intel.com>
The top of physical memory should be below the initial process stack, not the
top of the address space, at least for as long as the stack isn't known to the
kernel VM system and appropriately reserved.
Cc: "Christopher S. Aker" <caker@theshore.net>
Cc: WANG Cong <xiyou.wangcong@gmail.com>
A few random style fixes.
Make some small improvements for arch/um/kernel/um_arch.c.
Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com>
Acked-by: Jeff Dike <jdike@addtoit.com>
Calculate TASK_SIZE at run-time by figuring out the host's VMSPLIT - this is
needed on i386 if UML is to run on hosts with varying VMSPLITs without
recompilation.
TASK_SIZE is now defined in terms of a variable, task_size. This gets rid of
an include of pgtable.h from processor.h, which can cause include loops.
On i386, task_size is calculated early in boot by probing the address space in
a binary search to figure out where the boundary between usable and non-usable
memory is. This tries to make sure that a page that is considered to be in
userspace is, or can be made, read-write. I'm concerned about a system-global
VDSO page in kernel memory being hit and considered to be a userspace page.
On x86_64, task_size is just the old value of CONFIG_TOP_ADDR.
A bunch of config variable are gone now. CONFIG_TOP_ADDR is directly replaced
by TASK_SIZE. NEST_LEVEL is gone since the relocation of the stubs makes it
irrelevant. All the HOST_VMSPLIT stuff is gone. All references to these in
arch/um/Makefile are also gone.
I noticed and fixed a missing extern in os.h when adding os_get_task_size.
Note: This has been revised to fix the 32-bit UML on 64-bit host bug that
Miklos ran into.
Cc: Miklos Szeredi <miklos@szeredi.hu>
Joe Perches noticed some printks in smp.c that needed fixing.
While I was in there, I did the usual tidying in arch/um/kernel, which
should be fairly style-clean at this point:
copyright updates
emacs formatting comments removal
include tidying
style fixes
Cc: Joe Perches <joe@perches.com>
It turns out that if there's a panic early enough, UML will just sit there in
the LED-blinking loop because the panic notifier hadn't been installed yet.
This patch installs it earlier.
It also fixes the problem which exposed the hang, namely that if you give UML
a zero-sized initrd, it will ask alloc_bootmem for zero bytes, and that will
cause the panic.
While I was in initrd.c, I gave it a style makeover.
Prompted by checkpatch, I moved a couple extern declarations of uml_exitcode
to kern_util.h.
Clean up the calculation and use of the usable address space size on the host.
task_size is gone, replaced with TASK_SIZE, which is calculated from
CONFIG_TOP_ADDR. get_kmem_end and set_task_sizes_skas are also gone.
host_task_size, which refers to the entire address space usable by the UML
kernel and which may be larger than the address space usable by a UML process,
since that has to end on a pgdir boundary, is replaced by CONFIG_TOP_ADDR.
STACK_TOP is now TASK_SIZE minus the two stub pages.
This patch changes a few functions into returning void. The return values
were not used anyway, so I think it should not be a problem. Also removed a
little leftover bit from TT mode.
Signed-off-by: Karol Swietlicki <magotari@gmail.com>
Tidy kern_util.h. It turns out that most of the function declarations
aren't used, so they can go away. os.h no longer includes
kern_util.h, so files which got it through os.h now need to include it
directly. A number of other files never needed it, so these includes
are deleted.
The structure which was used to pass signal handlers from the kernel
side to the userspace side is gone. Instead, the handlers are
declared here, and used directly from libc code. This allows
arch/um/os-Linux/trap.c to be deleted, with its remnants being moved
to arch/um/os-Linux/skas/trap.c.
arch/um/os-Linux/tty.c had its inclusions changed, and it needed some
style attention, so it got tidied.
The calculation of CONFIG_STUB_CODE and CONFIG_STUB_DATA didn't take into
account anything but 3G/1G and 2G/2G, leaving the other vmsplits out in the
cold.
I'd rather not duplicate the four known host vmsplit cases for each of these
symbols. I'd also like to calculate them based on the highest userspace
address.
The Kconfig language seems not to allow calculation of hex constants, so I
moved this to as-layout.h. CONFIG_STUB_CODE, CONFIG_STUB_DATA, and
CONFIG_STUB_START are now gone. In their place are STUB_CODE, STUB_DATA, and
STUB_START in as-layout.h.
i386 and x86_64 seem to differ as to whether an unadorned constant is an int
or a long, so I cast them to unsigned long so they can be printed
consistently. However, they are also used in stub.S, where C types don't work
so well. So, there are ASM_ versions of these constants for use in stub.S. I
also ifdef-ed the non-asm-friendly portion of as-layout.h.
With this in place, most of the rest of this patch is changing CONFIG_STUB_*
to STUB_*, except in stub.S, where they are changed to ASM_STUB_*.
defconfig has the old symbols deleted.
I also print these addresses out in case there is any problem mapping them on
the host.
The two stub.S files had some trailing whitespace, so that is cleaned up here.
Formatting changes in the files which have been changed in the course
of folding foo_skas functions into their callers. These include:
copyright updates
header file trimming
style fixes
adding severity to printks
These changes should be entirely non-functional.
This patch makes a number of simplifications enabled by the removal of
CHOOSE_MODE. There were lots of functions that looked like
int foo(args){
foo_skas(args);
The bodies of foo_skas are now folded into foo, and their declarations (and
sometimes entire header files) are deleted.
In addition, the union uml_pt_regs, which was a union between the tt and skas
register formats, is now a struct, with the tt-mode arm of the union being
removed.
It turns out that usr2_handler was unused, so it is gone.
The next stage after removing code which depends on CONFIG_MODE_TT is removing
the CHOOSE_MODE abstraction, which provided both compile-time and run-time
branching to either tt-mode or skas-mode code.
This patch removes choose-mode.h and all inclusions of it, and replaces all
CHOOSE_MODE invocations with the skas branch. This leaves a number of trivial
functions which will be dealt with in a later patch.
There are some changes in the uaccess and tls support which go somewhat beyond
this and eliminate some of the now-redundant functions.
This patchset throws out tt mode, which has been non-functional for a while.
This is done in phases, interspersed with code cleanups on the affected files.
The removal is done as follows:
remove all code, config options, and files which depend on
CONFIG_MODE_TT
get rid of the CHOOSE_MODE macro, which decided whether to
call tt-mode or skas-mode code, and replace invocations with their
skas portions
replace all now-trivial procedures with their skas equivalents
There are now a bunch of now-redundant pieces of data structures, including
mode-specific pieces of the thread structure, pt_regs, and mm_context. These
are all replaced with their skas-specific contents.
As part of the ongoing style compliance project, I made a style pass over all
files that were changed. There are three such patches, one for each phase,
covering the files affected by that phase but no later ones.
I noticed that we weren't freeing the LDT state associated with a process when
it exited, so that's fixed in one of the later patches.
The last patch is a tidying patch which I've had for a while, but which caused
inexplicable crashes under tt mode. Since that is no longer a problem, this
can now go in.
This patch:
Start getting rid of tt mode support.
This patch throws out CONFIG_MODE_TT and all config options, code, and files
which depend on it.
CONFIG_MODE_SKAS is gone and everything that depends on it is included
unconditionally.
The few changed lines are in re-written Kconfig help, lines which needed
something skas-related removed from them, and a few more which weren't
strictly deletions.
Replaced task_protections with stack_protections since they do the same
thing, and task_protections was misnamed anyway.
This needs THREAD_SIZE, so that's imported via common-offsets.h
Also tidied up the code in the vicinity.
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Dump core after a panic. This will provide better debugging information than
is currently available.
Commentary about missing locking.
Also got rid of uml_start because it was pointless.
user_util.h isn't needed any more, so delete it and remove all includes of it.
This patch moves all the the symbols defined in um_arch.c, which are mostly
boundaries between different parts of the UML kernel address space, to a new
header, as-layout.h. There are also a few things here which aren't really
related to address space layout, but which don't really have a better place to
go.
This patch moves the declarations of the architecture hooks from user_util.h
to a new header, arch.c, and adds the necessary includes to files which need
those declarations.
Move the host_info string from util.c to um_arch.c, where it is
actually initialized and used. Also document its lack of locking.
Signed-off-by: Jeff Dike <jdike@addtoit.com>
Formatting fixes -
style violations
whitespace breakage
emacs formatting comment removal
Remove in-source externs, linux/init.h is included in all cases.
This is a fixups for "Dynamic kernel command-line" patch.
It also includes some uml __init fixups so that we can __initdata also its
command_line.
Signed-off-by: Alon Bar-Lev <alon.barlev@gmail.com>
Cc: Jeff Dike <jdike@addtoit.com>
1. Rename saved_command_line into boot_command_line.
2. Set command_line as __initdata.
Add an error message when two umids are put on the command line.
umid.h is kind of pointless since it only declares one thing, and that
is already declared in os.h.
Commented the lack of locking of some data in os-Linux/umid.h.
kbuild explicitly includes this at build time.
Signed-off-by: Dave Jones <davej@redhat.com>
In some places, particularly drivers and __init code, the init utsns is the
appropriate one to use. This patch replaces those with a the init_utsname
helper.
Changes: Removed several uses of init_utsname(). Hope I picked all the
right ones in net/ipv4/ipconfig.c. These are now changed to
utsname() (the per-process namespace utsname) in the previous
patch (2/7)
[akpm@osdl.org: CIFS fix]
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
Cc: Kirill Korotaev <dev@openvz.org>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Herbert Poetzl <herbert@13thfloor.at>
Cc: Andrey Savochkin <saw@sw.ru>
Cc: Serge Hallyn <serue@us.ibm.com>
Make lots of structures const in order to make it obvious that they need no
locking.
When UML is built as a static binary, it segfaults when run. The reason is
that a memory hole that is present in dynamic binaries isn't there in static
binaries, and it contains essential stuff.
This fix removes the code which maps some anonymous memory into that hole and
cleans up some related code.
I was looking at the code of the UML and more precisely at the functions
set_task_sizes_tt and set_task_sizes_skas. I noticed that these 2 functions
take a paramater (arg) which is not used : the function is always called with
the value 0.
I suppose that this value might change in the future (or even can be
configured), so I added a constant in mem_user.h file.
Also, I rounded CONFIG_HOST_TASk_SIZE to a 4M.
Signed-off-by: Tyler <tyler@agat.net>
This is needed to fix UML compilation given that alternatives_smp_module_add
and alternatives_smp_module_del are null inline functions if !CONFIG_SMP.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
The kernel's implementation of notifier chains is unsafe. There is no
protection against entries being added to or removed from a chain while the
chain is in use. The issues were discussed in this thread:
http://marc.theaimsgroup.com/?l=linux-kernel&m=113018709002036&w=2
We noticed that notifier chains in the kernel fall into two basic usage
classes:
"Blocking" chains are always called from a process context
and the callout routines are allowed to sleep;
"Atomic" chains can be called from an atomic context and
the callout routines are not allowed to sleep.
We decided to codify this distinction and make it part of the API. Therefore
this set of patches introduces three new, parallel APIs: one for blocking
notifiers, one for atomic notifiers, and one for "raw" notifiers (which is
really just the old API under a new name). New kinds of data structures are
used for the heads of the chains, and new routines are defined for
registration, unregistration, and calling a chain. The three APIs are
explained in include/linux/notifier.h and their implementation is in
kernel/sys.c.
With atomic and blocking chains, the implementation guarantees that the chain
links will not be corrupted and that chain callers will not get messed up by
entries being added or removed. For raw chains the implementation provides no
guarantees at all; users of this API must provide their own protections. (The
idea was that situations may come up where the assumptions of the atomic and
blocking APIs are not appropriate, so it should be possible for users to
handle these things in their own way.)
There are some limitations, which should not be too hard to live with. For
atomic/blocking chains, registration and unregistration must always be done in
a process context since the chain is protected by a mutex/rwsem. Also, a
callout routine for a non-raw chain must not try to register or unregister
entries on its own chain. (This did happen in a couple of places and the code
had to be changed to avoid it.)
Since atomic chains may be called from within an NMI handler, they cannot use
spinlocks for synchronization. Instead we use RCU. The overhead falls almost
entirely in the unregister routine, which is okay since unregistration is much
less frequent that calling a chain.
Here is the list of chains that we adjusted and their classifications. None
of them use the raw API, so for the moment it is only a placeholder.
ATOMIC CHAINS
arch/i386/kernel/traps.c: i386die_chain
arch/ia64/kernel/traps.c: ia64die_chain
arch/powerpc/kernel/traps.c: powerpc_die_chain
arch/sparc64/kernel/traps.c: sparc64die_chain
arch/x86_64/kernel/traps.c: die_chain
drivers/char/ipmi/ipmi_si_intf.c: xaction_notifier_list
kernel/panic.c: panic_notifier_list
kernel/profile.c: task_free_notifier
net/bluetooth/hci_core.c: hci_notifier
net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_chain
net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_expect_chain
net/ipv6/addrconf.c: inet6addr_chain
net/netfilter/nf_conntrack_core.c: nf_conntrack_chain
net/netfilter/nf_conntrack_core.c: nf_conntrack_expect_chain
net/netlink/af_netlink.c: netlink_chain
BLOCKING CHAINS
arch/powerpc/platforms/pseries/reconfig.c: pSeries_reconfig_chain
arch/s390/kernel/process.c: idle_chain
arch/x86_64/kernel/process.c idle_notifier
drivers/base/memory.c: memory_chain
drivers/cpufreq/cpufreq.c cpufreq_policy_notifier_list
drivers/cpufreq/cpufreq.c cpufreq_transition_notifier_list
drivers/macintosh/adb.c: adb_client_list
drivers/macintosh/via-pmu.c sleep_notifier_list
drivers/macintosh/via-pmu68k.c sleep_notifier_list
drivers/macintosh/windfarm_core.c wf_client_list
drivers/usb/core/notify.c usb_notifier_list
drivers/video/fbmem.c fb_notifier_list
kernel/cpu.c cpu_chain
kernel/module.c module_notify_list
kernel/profile.c munmap_notifier
kernel/profile.c task_exit_notifier
kernel/sys.c reboot_notifier_list
net/core/dev.c netdev_chain
net/decnet/dn_dev.c: dnaddr_chain
net/ipv4/devinet.c: inetaddr_chain
It's possible that some of these classifications are wrong. If they are,
please let us know or submit a patch to fix them. Note that any chain that
gets called very frequently should be atomic, because the rwsem read-locking
used for blocking chains is very likely to incur cache misses on SMP systems.
(However, if the chain's callout routines may sleep then the chain cannot be
atomic.)
The patch set was written by Alan Stern and Chandra Seetharaman, incorporating
material written by Keith Owens and suggestions from Paul McKenney and Andrew
Morton.
[jes@sgi.com: restructure the notifier chain initialization macros]
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com>
Signed-off-by: Jes Sorensen <jes@sgi.com>
The serial UML OS-abstraction layer patch (um/kernel dir).
This moves all startup code from sigio_user.c file under os-Linux dir
Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com>
Some printf formats are incorrect for large memory sizes.
Implement SMP alternatives, i.e. switching at runtime between different
code versions for UP and SMP. The code can patch both SMP->UP and UP->SMP.
The UP->SMP case is useful for CPU hotplug.
With CONFIG_CPU_HOTPLUG enabled the code switches to UP at boot time and
when the number of CPUs goes down to 1, and switches to SMP when the number
of CPUs goes up to 2.
Without CONFIG_CPU_HOTPLUG or on non-SMP-capable systems the code is
patched once at boot time (if needed) and the tables are released
afterwards.
The changes in detail:
* The current alternatives bits are moved to a separate file,
the SMP alternatives code is added there.
* The patch adds some new elf sections to the kernel:
.smp_altinstructions
like .altinstructions, also contains a list
of alt_instr structs.
.smp_altinstr_replacement
like .altinstr_replacement, but also has some space to
save original instruction before replaving it.
.smp_locks
list of pointers to lock prefixes which can be nop'ed
out on UP.
The first two are used to replace more complex instruction
sequences such as spinlocks and semaphores. It would be possible
to deal with the lock prefixes with that as well, but by handling
them as special case the table sizes become much smaller.
* The sections are page-aligned and padded up to page size, so they
can be free if they are not needed.
* Splitted the code to release init pages to a separate function and
use it to release the elf sections if they are unused.
Signed-off-by: Gerd Hoffmann <kraxel@suse.de>
Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com>
It doesn't do anything but emit a warning, but there's a user population
that's used to adding 'debug' to the UML command line in order to gdb it.
With skas0 mode, that's not necessary, but these users need some indication
that 'debug' doesn't do what they want.
Undo the previous no-modes patch since Adrian Bunk sent in a kbuild way of
doing the same thing.
This moves all systemcalls from trap_user.c file under os-Linux dir
This patch cleans up the umid code:
- The only_if_set argument to get_umid is gone.
- get_umid returns an empty string rather than NULL if there is no umid.
- umid_is_random is gone since its users went away.
- Some printfs were turned into printks because the code runs late enough
that printk is working.
- Error paths were cleaned up.
- Some functions now return an error and let the caller print the error
message rather than printing it themselves. This eliminates the practice of
passing a pointer to printf or printk in, depending on where in the boot
process we are.
- Major tidying of not_dead_yet - mostly error path cleanup, plus a comment
explaining why it doesn't react to errors the way you might expect.
- Calls to os_* interfaces that were moved under os are changed back to
their native libc forms.
- snprintf, strlcpy, and their bounds-checking friends are used more often,
replacing by-hand bounds checking in some places.
A number of fixes to improve behavior when large physical memory sizes
are specified:
- libc files need -D_FILE_OFFSET_BITS=64 because there are unavoidable uses
of non-64 interfaces in libc
- some %d need to be %u
Cc: Paolo Giarrusso <blaisorblade@yahoo.it>
SEGV_MAYBE_FIXABLE tests ptrace_faultinfo, and depends on it being 1 only in
SKAS3 mode, while currently when running with mode=tt it will be 1 anyway.
Fix this, and do the same for proc_mm.
Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
This moves all system calls from mem_user.c and tempfile.c files under
os-Linux dir.
This moves all systemcalls from process.c file under os-Linux dir and join
process.c and process_kern.c files.
Signed-off-by: Gennady Sharapov <gennady.v.sharapov@intel.com>
Apparently, GDB gets confused when we do an execvp() on ourselves.
Since it's simply done to allocate further space for command line arguments
(which we'll use to allow gathering the startup command line for guest
processes through the host), allow the user to disable that to get a
debuggable UML binary.
This adds the "skas0" parameter to force skas0 operation on SKAS3 host and
shows which operating mode has been selected.
A few files include the same header twice.
This var is currently useless, as it's apparent from reading the code. Until
2.6.11 it was used in some code related to jail mode, in the same proc.:
if(jail){
while(!reading) sched_yield();
jail mode has been dropped, together with that use, so let's finish dropping
this.
Also, remove some other useless definitions I met.
Command line handling cleanups - a couple of things made static and an
unused declaration removed from header.
