[ Upstream commit 7ff1e34bbdc15acab823b1ee4240e94623d50ee8 ]
Fixes:
arch/um/os-Linux/skas/process.c:613:1: warning: control reaches end of
non-void function [-Wreturn-type]
longjmp() never returns but gcc still warns that the end of the function
can be reached.
Add a return code and debug aid to detect this impossible case.
Signed-off-by: Richard Weinberger <richard@nod.at>
Hard code max size. Taken from
https://sourceware.org/git/?p=binutils-gdb.git;a=blob;f=gdb/common/x86-xstate.h
Signed-off-by: Thomas Meyer <thomas@m3y3r.de>
Also use correct function name spelling (stub_segv_handler) for better grepping
When ptrace fails to set GP/FP regs for the target process,
log the error before crashing the UML kernel.
We need linux/threads.h for that variable.
Fixes: 8bba077066d6d0 ("um: Set number of CPUs")
Define NR_CPUS required by the timer subsystem.
Fixes this make warning:
scripts/kconfig/conf --oldconfig arch/x86/um/Kconfig
kernel/time/Kconfig:155:warning: range is invalid
Signed-off-by: Nikola Kotur <kotnick@gmail.com>
This fix two related bugs:
* PTRACE_GETREGS doesn't get the right orig_ax (syscall) value
* PTRACE_SETREGS can't set the orig_ax value (erased by initial value)
Get rid of the now useless and error-prone get_syscall().
Fix inconsistent behavior in the ptrace implementation for i386 when
updating orig_eax automatically update the syscall number as well. This
is now updated in handle_syscall().
Signed-off-by: Mickaël Salaün <mic@digikod.net>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Will Drewry <wad@chromium.org>
Cc: Thomas Meyer <thomas@m3y3r.de>
Cc: Nicolas Iooss <nicolas.iooss_linux@m4x.org>
Cc: Anton Ivanov <aivanov@brocade.com>
Cc: Meredydd Luff <meredydd@senatehouse.org>
Cc: David Drysdale <drysdale@google.com>
UML is using an obsolete itimer call for
all timers and "polls" for kernel space timer firing
in its userspace portion resulting in a long list
of bugs and incorrect behaviour(s). It also uses
ITIMER_VIRTUAL for its timer which results in the
timer being dependent on it running and the cpu
load.
This patch fixes this by moving to posix high resolution
timers firing off CLOCK_MONOTONIC and relaying the timer
correctly to the UML userspace.
Fixes:
- crashes when hosts suspends/resumes
- broken userspace timers - effecive ~40Hz instead
of what they should be. Note - this modifies skas behavior
by no longer setting an itimer per clone(). Timer events
are relayed instead.
- kernel network packet scheduling disciplines
- tcp behaviour especially under load
- various timer related corner cases
Finally, overall responsiveness of userspace is better.
Signed-off-by: Anton Ivanov <aivanov@brocade.com>
[rw: massaged commit message]
To support changing syscall numbers we have to store
it after syscall_trace_enter().
When declaring __syscall_stub_start, use the same type in UML userspace
code as in arch/um/include/asm/sections.h.
While at it, also declare batch_syscall_stub as char[].
Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org>
atomic_notifier_chain_register() and uml_postsetup() do call kernel code
that rely on the "current" kernel macro and a valid task_struct resp.
thread_info struct. Give those functions a valid stack by moving
uml_postsetup() in the init_thread stack. This moves enables a panic()
call in this early code to generate a valid stacktrace, instead of
crashing.
E.g. when an UML kernel is started with an initrd but too few physical
memory the panic() call get's actually processed.
Before we had SKAS0 UML had two modes of operation
TT (tracing thread) and SKAS3/4 (separated kernel address space).
TT was known to be insecure and got removed a long time ago.
SKAS3/4 required a few (3 or 4) patches on the host side which never went
mainline. The last host patch is 10 years old.
With SKAS0 mode (separated kernel address space using 0 host patches),
default since 2005, SKAS3/4 is obsolete and can be removed.
This reverts commit 0974a9cadc7886f7baaa458bb0c89f5c5f9d458e.
The real for for that issue is to release current->mm->mmap_sem in
fix_range_common().
Currently we use both struct siginfo and siginfo_t.
Let's use struct siginfo internally to avoid ongoing
compiler warning. We are allowed to do so because
struct siginfo and siginfo_t are equivalent.
If we die within a stub handler we only way to reliable
kill the (obviously) dying uml guest process is killing
it's host twin on the host side.
UML guest processes now get correct siginfo_t for SIGTRAP, SIGFPE,
SIGILL and SIGBUS. Specifically, si_addr and si_code are now correct
where previously they were si_addr = NULL and si_code = 128.
Signed-off-by: Martin Pärtel <martin.partel@gmail.com>
For one thing, we always block the same signals (IRQ ones - IO, WINCH, VTALRM),
so there's no need to pass sa_mask elements in arguments. For another, the
flags depend only on whether it's an IRQ signal or not (we add SA_RESTART
for them).
We used to generate those, but we hadn't done that for a long
time. No need to bother blocking them for signal handlers.
there
Some time ago Jeff prepared 42daba316557 ("uml: stop saving process FP
state") for UML to stop saving the process FP state between task
switches. The assumption was that since with SKAS0 every guest process
runs inside a host process context the host OS will take care of keeping
the proper FP state.
Unfortunately this is not true for multi-threaded applications, where
all guest threads share a single host process context yet all may use
the FPU on their own. Although I haven't verified it I suspect things
to be even worse in SKAS3 mode where all guest processes run inside a
single host process.
The patch reintroduces the saving and restoring of the FP context
between task switches.
[richard@nod.at: Ingo posted this patch in 2009, sadly it was never applied
and got lost. Now in 2011 the problem was reported by Gunnar.]
Signed-off-by: Ingo van Lil <inguin@gmx.de>
Reported-by: <gunnarlindroth@hotmail.com>
Tested-by: <gunnarlindroth@hotmail.com>
Cc: Stanislav Meduna <stano@meduna.org>
- Make some variables and functions static, since they don't need to be
global.
- Remove an unused function - arch/um/kernel/time.c::sched_clock().
- Clean the style a bit as complained by checkpatch.pl.
Signed-off-by: WANG Cong <wangcong@zeuux.org>
We lost the marking of SIGWINCH as being OK to receive during stub
execution, causing a panic should that happen.
Cc: Benedict Verheyen <benedict.verheyen@gmail.com>
Signed-off-by: Jeff Dike <jdike@linux.intel.com>
A few random style fixes.
Cc: WANG Cong <xiyou.wangcong@gmail.com>
Commit ee3d9bd4de1ed93d2a7ee41c331ed30a1c7b8acd ("uml: simplify SIGSEGV
handling"), while greatly simplifying the kernel SIGSEGV handler that
runs in the process address space, introduced a bug which corrupts FP
state in the process.
Previously, the SIGSEGV handler called the sigreturn system call by hand - it
couldn't return through the restorer provided to it because that could try to
call the libc restorer which likely wouldn't exist in the process address
space. So, it blocked off some signals, including SIGUSR1, on entry to the
SIGSEGV handler, queued a SIGUSR1 to itself, and invoked sigreturn. The
SIGUSR1 was delivered, and was visible to the UML kernel after sigreturn
finished.
The commit eliminated the signal masking and the call to sigreturn. The
handler simply hits itself with a SIGTRAP to let the UML kernel know that it
is finished. UML then restores the process registers, which effectively
longjmps the process out of the signal handler, skipping sigreturn's restoring
of register state and the signal mask.
The bug is that the host apparently sets used_fp to 0 when it saves the
process FP state in the sigcontext on the process signal stack. Thus, when
the process is longjmped out of the handler, its FP state is corrupt because
it wasn't saved on the context switch to the UML kernel.
This manifested itself as sleep hanging. For some reason, sleep uses floating
point in order to calculate the sleep interval. When a page fault corrupts
its FP state, it is faked into essentially sleeping forever.
This patch saves the FP state before entering the SIGSEGV handler and restores
it afterwards.
Style changes under arch/um/os-Linux:
include trimming
CodingStyle fixes
some printks needed severity indicators
make_tempfile turns out not to be used outside of mem.c, so it is now static.
Its declaration in tempfile.h is no longer needed, and tempfile.h itself is no
longer needed.
create_tmp_file was also made static.
checkpatch moans about an EXPORT_SYMBOL in user_syms.c which is part of a
macro definition - this is copying a bit of kernel infrastructure into the
libc side of UML because the kernel headers can't be included there.
Some printks were missing newlines.
Kill a process that tries to branch into a stub and execute a system
call. There are no security implications here - a system call in a
stub is treated the same as a system call anywhere else. But if a
process is trying to branch into a stub, either it is trying something
nasty or it has gone haywire, so it's a good idea to get rid of it in
either case.
UML was panicing in the case of failures of libc calls which shouldn't happen.
This is an overreaction since a failure from libc doesn't normally mean that
kernel data structures are in an unknown state. Instead, the current process
should just be killed if there is no way to recover.
The case that prompted this was a failure of PTRACE_SETREGS restoring the same
state that was read by PTRACE_GETREGS. It appears that when a process tries
to load a bogus value into a segment register, it segfaults (as expected) and
the value is actually loaded and is seen by PTRACE_GETREGS (not expected).
This case is fixed by forcing a fatal SIGSEGV on the process so that it
immediately dies. fatal_sigsegv was added for this purpose. It was declared
as noreturn, so in order to pursuade gcc that it actually does not return, I
added a call to os_dump_core (and declared it noreturn) so that I get a core
file if somehow the process survives.
All other calls in arch/um/os-Linux/skas/process.c got the same treatment,
with failures causing the process to die instead of a kernel panic, with some
exceptions.
userspace_tramp exits with status 1 if anything goes wrong there. That will
cause start_userspace to return an error. copy_context_skas0 and
map_stub_pages also now return errors instead of panicing. Callers of thes
functions were changed to check for errors and do something appropriate.
Usually that's to return an error to their callers.
check_skas3_ptrace_faultinfo just exits since that's too early to do anything
else.
save_registers, restore_registers, and init_registers now return status
instead of panicing on failure, with their callers doing something
appropriate.
There were also duplicate declarations of save_registers and restore_registers
in os.h - these are gone.
I noticed and fixed up some whitespace damage.
Some register accessor cleanups -
userspace() was calling restore_registers and save_registers for no
reason, since userspace() is on the libc side of the house, and these
add no value over calling ptrace directly
init_thread_registers and get_safe_registers were the same thing,
so init_thread_registers is gone
Simplify the page fault stub by not masking signals while it is running. This
allows it to signal that it is done by executing an instruction which will
generate a SIGTRAP (int3 on x86) rather than running sigreturn by hand after
queueing a blocked SIGUSR1.
userspace_tramp now no longer puts anything in the SIGSEGV sa_mask, but it
does add SA_NODEFER to sa_flags so that SIGSEGV is still enabled after the
signal handler fails to run sigreturn.
SIGWINCH is just blocked so that we don't have to deal with it and the signal
masks used by wait_stub_done are updated to reflect the smaller number of
signals that it has to worry about.
Tidy kern_util.h. It turns out that most of the function declarations
aren't used, so they can go away. os.h no longer includes
kern_util.h, so files which got it through os.h now need to include it
directly. A number of other files never needed it, so these includes
are deleted.
The structure which was used to pass signal handlers from the kernel
side to the userspace side is gone. Instead, the handlers are
declared here, and used directly from libc code. This allows
arch/um/os-Linux/trap.c to be deleted, with its remnants being moved
to arch/um/os-Linux/skas/trap.c.
arch/um/os-Linux/tty.c had its inclusions changed, and it needed some
style attention, so it got tidied.
Sometimes when UML is debugged gdb miss breakpoints.
When process traced by gdb do fork, debugger remove breakpoints from
child address space. There is possibility to trace more than one fork,
but this not work with UML, I guess (only guess) there is a deadlock -
gdb waits for UML and UML waits for gdb.
When clone() is called with SIGCHLD and CLONE_VM flags, gdb see this
as PTRACE_EVENT_FORK not as PTRACE_EVENT_CLONE and remove breakpoints
from child and at the same time from traced process, because either
have the same address space.
Maybe it is possible to do fix in gdb, but I'm not sure if there is
easy way to find out if traced and child processes share memory. So I
do fix for UML, it simply do not call clone() with both SIGCHLD and
CLONE_VM flags together. Additionally __WALL flag is used for
waitpid() to assure not miss clone and normal process events.
[ jdike - checkpatch fixes ]
Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl>
In a stock 2.6.22.6 kernel, poweroff a user mode linux guest (2.6.22.6 running
in skas0 mode) will halt the host linux. I think the reason is the kernel
thread abort because of a bug. Then the sys_reboot in process of user mode
linux guest is not trapped by the user mode linux kernel and is executed by
host. I think it is better to make sure all of our children process to quit
when user mode linux kernel abort.
[ jdike - the kernel process needs to ignore SIGTERM, plus the waitpid/kill
loop is needed to make sure that all of our children are dead before the
kernel exits ]
Signed-off-by: Lepton Wu <ytht.net@gmail.com>
The calculation of CONFIG_STUB_CODE and CONFIG_STUB_DATA didn't take into
account anything but 3G/1G and 2G/2G, leaving the other vmsplits out in the
cold.
I'd rather not duplicate the four known host vmsplit cases for each of these
symbols. I'd also like to calculate them based on the highest userspace
address.
The Kconfig language seems not to allow calculation of hex constants, so I
moved this to as-layout.h. CONFIG_STUB_CODE, CONFIG_STUB_DATA, and
CONFIG_STUB_START are now gone. In their place are STUB_CODE, STUB_DATA, and
STUB_START in as-layout.h.
i386 and x86_64 seem to differ as to whether an unadorned constant is an int
or a long, so I cast them to unsigned long so they can be printed
consistently. However, they are also used in stub.S, where C types don't work
so well. So, there are ASM_ versions of these constants for use in stub.S. I
also ifdef-ed the non-asm-friendly portion of as-layout.h.
With this in place, most of the rest of this patch is changing CONFIG_STUB_*
to STUB_*, except in stub.S, where they are changed to ASM_STUB_*.
defconfig has the old symbols deleted.
I also print these addresses out in case there is any problem mapping them on
the host.
The two stub.S files had some trailing whitespace, so that is cleaned up here.
There are various uses of powers of 1000, plus the odd BILLION constant in the
time code. However, there are perfectly good definitions of *SEC_PER_*SEC in
linux/time.h which can be used instaed.
These are replaced directly in kernel code. Userspace code imports those
constants as UM_*SEC_PER_*SEC and uses these.
Now that ITIMER_REAL is no longer used, there is no need for any use of
SIGALRM whatsoever. This patch removes all mention of it.
In addition, real_alarm_handler took a signal argument which is now always
SIGVTALRM. So, that is gone.
Enable tickless support.
CONFIG_TICK_ONESHOT and CONFIG_NO_HZ are enabled.
itimer_clockevent gets CLOCK_EVT_FEAT_ONESHOT and an implementation of
.set_next_event.
CONFIG_UML_REAL_TIME_CLOCK goes away because it only makes sense when there is
a clock ticking away all the time. timer_handler now just calls do_IRQ once
without trying to figure out how many ticks to emulate.
The idle loop now needs to turn ticking on and off.
Userspace ticks keep happening as usual. However, the userspace loop keep
track of when the next wakeup should happen and suppresses process ticks until
that happens.
set_interval took a timer type as an argument, but it always specified a
virtual timer. So, it is not needed, and it is gone, and set_interval is
simplified appropriately.
Eliminate hz() since its only purpose was to provide a kernel-space constant
to userspace code. This can be done instead by providing the constant
directly through kernel_constants.h.
A number of files that were changed in the recent removal of tt mode
are userspace files which call the os_* wrappers instead of calling
libc directly. A few other files were affected by this, through
This patch makes these call glibc directly.
There are also style fixes in the affected areas.
os_print_error has no remaining callers, so it is deleted.
There is a interface change to os_set_exec_close, eliminating a
parameter which was always the same. The callers are fixed as well.
os_process_pc got its error path cleaned up.
Before the removal of tt mode, access to a register on the skas-mode side of a
pt_regs struct looked like pt_regs.regs.skas.regs.regs[FOO]. This was bad
enough, but it became pt_regs.regs.regs.regs[FOO] with the removal of the
union from the middle. To get rid of the run of three "regs", the last field
is renamed to "gp".
Eliminate some uses of __u64 in the physical memory support. It's hard to get
a definition of __u64 in both kernel and userspace code on x86_64, so this
changes them to unsigned long long.
There are also a copyright update and formatting comment removal from the
affected header.
