Calculate TASK_SIZE at run-time by figuring out the host's VMSPLIT - this is
needed on i386 if UML is to run on hosts with varying VMSPLITs without
recompilation.
TASK_SIZE is now defined in terms of a variable, task_size. This gets rid of
an include of pgtable.h from processor.h, which can cause include loops.
On i386, task_size is calculated early in boot by probing the address space in
a binary search to figure out where the boundary between usable and non-usable
memory is. This tries to make sure that a page that is considered to be in
userspace is, or can be made, read-write. I'm concerned about a system-global
VDSO page in kernel memory being hit and considered to be a userspace page.
On x86_64, task_size is just the old value of CONFIG_TOP_ADDR.
A bunch of config variable are gone now. CONFIG_TOP_ADDR is directly replaced
by TASK_SIZE. NEST_LEVEL is gone since the relocation of the stubs makes it
irrelevant. All the HOST_VMSPLIT stuff is gone. All references to these in
arch/um/Makefile are also gone.
I noticed and fixed a missing extern in os.h when adding os_get_task_size.
Note: This has been revised to fix the 32-bit UML on 64-bit host bug that
Miklos ran into.
Signed-off-by: Jeff Dike <jdike@linux.intel.com>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Formatting changes in the files which have been changed in the
tt-removal patchset so far. These include:
copyright updates
header file trimming
style fixes
adding severity to printks
indenting Kconfig help according to the predominant kernel style
These changes should be entirely non-functional.
This patchset throws out tt mode, which has been non-functional for a while.
This is done in phases, interspersed with code cleanups on the affected files.
The removal is done as follows:
remove all code, config options, and files which depend on
CONFIG_MODE_TT
get rid of the CHOOSE_MODE macro, which decided whether to
call tt-mode or skas-mode code, and replace invocations with their
skas portions
replace all now-trivial procedures with their skas equivalents
There are now a bunch of now-redundant pieces of data structures, including
mode-specific pieces of the thread structure, pt_regs, and mm_context. These
are all replaced with their skas-specific contents.
As part of the ongoing style compliance project, I made a style pass over all
files that were changed. There are three such patches, one for each phase,
covering the files affected by that phase but no later ones.
I noticed that we weren't freeing the LDT state associated with a process when
it exited, so that's fixed in one of the later patches.
The last patch is a tidying patch which I've had for a while, but which caused
inexplicable crashes under tt mode. Since that is no longer a problem, this
can now go in.
This patch:
Start getting rid of tt mode support.
This patch throws out CONFIG_MODE_TT and all config options, code, and files
which depend on it.
CONFIG_MODE_SKAS is gone and everything that depends on it is included
unconditionally.
The few changed lines are in re-written Kconfig help, lines which needed
something skas-related removed from them, and a few more which weren't
strictly deletions.
Have most signals go through an arch-provided handler which recovers the
sigcontext and then calls a generic handler. This replaces the
ARCH_GET_SIGCONTEXT macro, which was somewhat fragile. On x86_64, recovering
%rdx (which holds the sigcontext pointer) must be the first thing that
happens. sig_handler duly invokes that first, but there is no guarantee that
I can see that instructions won't be reordered such that %rdx is used before
that. Having the arch provide the handler seems much more robust.
Some signals in some parts of UML require their own handlers - these places
don't call set_handler any more. They call sigaction or signal themselves.
Signed-off-by: Jeff Dike <jdike@addtoit.com>
If running on a host not supporting TLS (for instance 2.4) we should report
that cleanly to the user, instead of printing not comprehensible "error 5" for
that.
Additionally, i386 and x86_64 support different ranges for
user_desc->entry_number, and we must account for that; we couldn't pass
ourselves -1 because we need to override previously existing TLS descriptors
which glibc has possibly set, so test at startup the range to use.
x86 and x86_64 existing ranges are hardcoded.
Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Acked-by: Jeff Dike <jdike@addtoit.com>
infrastructure for it.
Let it rip!
