path: root/arch/um/sys-i386/bugs.c
2008-02-05uml: tidy kern_util.hJeff Dike
Tidy kern_util.h. It turns out that most of the function declarations aren't used, so they can go away. os.h no longer includes kern_util.h, so files which got it through os.h now need to include it directly. A number of other files never needed it, so these includes are deleted. The structure which was used to pass signal handlers from the kernel side to the userspace side is gone. Instead, the handlers are declared here, and used directly from libc code. This allows arch/um/os-Linux/trap.c to be deleted, with its remnants being moved to arch/um/os-Linux/skas/trap.c. arch/um/os-Linux/tty.c had its inclusions changed, and it needed some style attention, so it got tidied. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: further bugs.c tidyingJeff Dike
bugs.c, for both i386 and x86_64, can undergo further cleaning - The i386 arch_check_bugs only does one thing, so we might as well inline the cmov checking. The i386 includes can be trimmed down a bit. arch_init_thread wasn't used, so it is deleted. The panics in arch_handle_signal are turned into printks because the process is about to get segfaulted anyway, so something is dying no matter what happens here. Also, the return value was always the same, so it contained no information, so it can be void instead. The name is changed to arch_examine_signal because it doesn't handle anything. The caller of arch_handle_signal, relay_signal, does things in a different order. The kernel-mode signal check is now first, which puts everything else together, making things a bit clearer conceptually. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: remove now unused codeKarol Swietlicki
This patch finishes what the previous one started. The code was not used after my first patch, and now can be removed with ease. [ jdike - also deleted the #if 0 lcall stuff ] Signed-off-by: Karol Swietlicki <magotari@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: improve detection of host cmovKarol Swietlicki
This patch introduces a new way of checking for the cmov instruction. I use signal handling instead of reading /proc/cpuinfo. [ jdike - Fiddled the asm to make it obvious that it didn't mess with any in-use registers and made test_for_host_cmov void ] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Karol Swietlicki <magotari@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: remove xmm checking on x86Karol Swietlicki
This patch removes some code which ran at every boot, but does not seem to do anything anymore. Please test. It works for me but mistakes can happen. Signed-off-by: Karol Swietlicki <magotari@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: style fixes pass 3Jeff Dike
Formatting changes in the files which have been changed in the course of folding foo_skas functions into their callers. These include: copyright updates header file trimming style fixes adding severity to printks These changes should be entirely non-functional. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: remove code made redundant by CHOOSE_MODE removalJeff Dike
This patch makes a number of simplifications enabled by the removal of CHOOSE_MODE. There were lots of functions that looked like int foo(args){ foo_skas(args); } The bodies of foo_skas are now folded into foo, and their declarations (and sometimes entire header files) are deleted. In addition, the union uml_pt_regs, which was a union between the tt and skas register formats, is now a struct, with the tt-mode arm of the union being removed. It turns out that usr2_handler was unused, so it is gone. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: rename os_{read_write}_file_k back to os_{read_write}_fileJeff Dike
Rename os_{read_write}_file_k back to os_{read_write}_file, delete the originals and their bogus infrastructure, and fix all the callers. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: change remaining callers of os_{read_write}_fileJeff Dike
Convert all remaining os_{read_write}_file users to use the simple {read,write} wrappers, os_{read_write}_file_k. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: start fixing os_read_file and os_write_fileJeff Dike
This patch starts the removal of a very old, very broken piece of code. This stems from the problem of passing a userspace buffer into read() or write() on the host. If that buffer had not yet been faulted in, read and write will return -EFAULT. To avoid this problem, the solution was to fault the buffer in before the system call by touching the pages that hold the buffer by doing a copy-user of a byte to each page. This is obviously bogus, but it does usually work, in tt mode, since the kernel and process are in the same address space and userspace addresses can be accessed directly in the kernel. In skas mode, where the kernel and process are in separate address spaces, it is completely bogus because the userspace address, which is invalid in the kernel, is passed into the system call instead of the corresponding physical address, which would be valid. Here, it appears that this code, on every host read() or write(), tries to fault in a random process page. This doesn't seem to cause any correctness problems, but there is a performance impact. This patch, and the ones following, result in a 10-15% performance gain on a kernel build. This code can't be immediately tossed out because when it is, you can't log in. Apparently, there is some code in the console driver which depends on this somehow. However, we can start removing it by switching the code which does I/O using kernel addresses to using plain read() and write(). This patch introduces os_read_file_k and os_write_file_k for use with kernel buffers and converts all call locations which use obvious kernel buffers to use them. These include I/O using buffers which are local variables which are on the stack or kmalloc-ed. Later patches will handle the less obvious cases, followed by a mass conversion back to the original interface. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: remove user_util.hJeff Dike
user_util.h isn't needed any more, so delete it and remove all includes of it. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: formatting fixesJeff Dike
Formatting fixes - style violations whitespace breakage emacs formatting comment removal Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: delete unused codeJeff Dike
Get rid of a bunch of unused stuff - cpu_feature had no users linux_prog is little-used, so its declaration is moved to the user for easy deletion when the whole file goes away a long-unused debugging aid in helper.c is gone Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-26[PATCH] uml: Use ARRAY_SIZE more assiduouslyJeff Dike
There were a bunch of missed ARRAY_SIZE opportunities. Also, some formatting fixes in the affected areas of code. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
