path: root/arch/um/sys-i386/ptrace.c
2010-10-27ptrace: change signature of arch_ptrace()Namhyung Kim
Fix up the arguments to arch_ptrace() to take account of the fact that @addr and @data are now unsigned long rather than long as of a preceding patch in this series. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: <linux-arch@vger.kernel.org> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13uml: tidy ptrace interfaceJeff Dike
Tidy the ptrace interface code. Removed a bunch of unused macros. Started converting register sets from arrays of longs to structures. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: remove unused variables in the context switcherKarol Swietlicki
This patch removes a variable which was not used in two functions. Yet another code cleanup, nothing really significant. Please note that I could not test this on x86_64. I don't have the hardware for it. [ jdike - Bits of tidying around the affected code. Also, it's fine on x86_64 ] Signed-off-by: Karol Swietlicki <magotari@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-29misc uml annotation and section fixesAl Viro
2007-10-16uml: coredumping floating point fixesJeff Dike
Fix core dumping of floating point state. ELF_CORE_COPY_FPREGS gets a definitions, and as a result, dump_fpu no longer needs to exist. Also, elf_fpregset_t needed a real definition. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: ptrace floating point fixesJeff Dike
Handle floating point state better in ptrace. The code now correctly distinguishes between PTRACE_[GS]ETFPREGS and PTRACE_[GS]ETFPXREGS. The FPX requests get handed off to arch-specific code because that's not generic. get_fpregs, set_fpregs, set_fpregs, and set_fpxregs needed real implementations. Something here exposed a missing include in asm/page.h, which needed linux/types.h in order to get gfp_t, so that's fixed here. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: floating point signal delivery fixesJeff Dike
Handle floating point state in across signals correctly. UML/i386 needs to know whether the host does PTRACE_[GS]ETFPXREGS, so an arch_init_registers hook is added, which on x86_64 does nothing. UML doesn't save and restore floating point registers on kernel entry and exit, so they need to be copied between the host process and the sigcontext. save_fpx_registers and restore_fpx_registers are added for this purpose. save_fp_registers and restore_fp_registers already exist. There was a bunch of floating point state conversion code in arch/um/sys-i386/ptrace.c which isn't needed there, but is needed in signal.c, so it is moved over. The i386 code now distinguishes between fp and fpx state and handles them correctly. The x86_64 code just needs to copy state as-is between the host process and the stack. There are also some fixes there to pass the correct address of the floating point state around. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: style fixes pass 3Jeff Dike
Formatting changes in the files which have been changed in the course of folding foo_skas functions into their callers. These include: copyright updates header file trimming style fixes adding severity to printks These changes should be entirely non-functional. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: remove code made redundant by CHOOSE_MODE removalJeff Dike
This patch makes a number of simplifications enabled by the removal of CHOOSE_MODE. There were lots of functions that looked like int foo(args){ foo_skas(args); } The bodies of foo_skas are now folded into foo, and their declarations (and sometimes entire header files) are deleted. In addition, the union uml_pt_regs, which was a union between the tt and skas register formats, is now a struct, with the tt-mode arm of the union being removed. It turns out that usr2_handler was unused, so it is gone. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: throw out CHOOSE_MODEJeff Dike
The next stage after removing code which depends on CONFIG_MODE_TT is removing the CHOOSE_MODE abstraction, which provided both compile-time and run-time branching to either tt-mode or skas-mode code. This patch removes choose-mode.h and all inclusions of it, and replaces all CHOOSE_MODE invocations with the skas branch. This leaves a number of trivial functions which will be dealt with in a later patch. There are some changes in the uaccess and tls support which go somewhat beyond this and eliminate some of the now-redundant functions. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: throw out CONFIG_MODE_TTJeff Dike
This patchset throws out tt mode, which has been non-functional for a while. This is done in phases, interspersed with code cleanups on the affected files. The removal is done as follows: remove all code, config options, and files which depend on CONFIG_MODE_TT get rid of the CHOOSE_MODE macro, which decided whether to call tt-mode or skas-mode code, and replace invocations with their skas portions replace all now-trivial procedures with their skas equivalents There are now a bunch of now-redundant pieces of data structures, including mode-specific pieces of the thread structure, pt_regs, and mm_context. These are all replaced with their skas-specific contents. As part of the ongoing style compliance project, I made a style pass over all files that were changed. There are three such patches, one for each phase, covering the files affected by that phase but no later ones. I noticed that we weren't freeing the LDT state associated with a process when it exited, so that's fixed in one of the later patches. The last patch is a tidying patch which I've had for a while, but which caused inexplicable crashes under tt mode. Since that is no longer a problem, this can now go in. This patch: Start getting rid of tt mode support. This patch throws out CONFIG_MODE_TT and all config options, code, and files which depend on it. CONFIG_MODE_SKAS is gone and everything that depends on it is included unconditionally. The few changed lines are in re-written Kconfig help, lines which needed something skas-related removed from them, and a few more which weren't strictly deletions. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-03-31[PATCH] uml: add arch_switch_to for newly forked threadPaolo 'Blaisorblade' Giarrusso
Newly forked threads have no arch_switch_to_skas() called before their first run, because when schedule() switches to them they're resumed in the body of thread_wait() inside fork_handler() rather than in switch_threads() in switch_to_skas(). Compensate this missing call. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] uml: implement {get,set}_thread_area for i386Paolo 'Blaisorblade' Giarrusso
Implement sys_[gs]et_thread_area and the corresponding ptrace operations for UML. This is the main chunk, additional parts follow. This implementation is now well tested and has run reliably for some time, and we've understood all the previously existing problems. Their implementation saves the new GDT content and then forwards the call to the host when appropriate, i.e. immediately when the target process is running or on context switch otherwise (i.e. on fork and on ptrace() calls). In SKAS mode, we must switch registers on each context switch (because SKAS does not switches tls_array together with current->mm). Also, added get_cpu() locking; this has been done for SKAS mode, since TT does not need it (it does not use smp_processor_id()). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] uml: clean arch_switch usagePaolo 'Blaisorblade' Giarrusso
Call arch_switch also in switch_to_skas, even if it's, for now, a no-op for that case (and mark this in the comment); this will change soon. Also, arch_switch for TT mode is actually useless when the PT proxy (a complicate debugging instrumentation for TT mode) is not enabled. In fact, it only calls update_debugregs, which checks debugregs_seq against seq (to check if the registers are up-to-date - seq here means a "version number" of the registers). If the ptrace proxy is not enabled, debugregs_seq always stays 0 and update_debugregs will be a no-op. So, optimize this out (the compiler can't do it). Also, I've been disappointed by the fact that it would make a lot of sense if, after calling a successful update_debugregs(current->thread.arch.debugregs_seq), current->thread.arch.debugregs_seq were updated with the new debugregs_seq. But this is not done. Is this a bug or a feature? For all purposes, it seems a bug (otherwise the whole mechanism does not make sense, which is also a possibility to check), which causes some performance only problems (not correctness), since we write_debugregs when not needed. Also, as suggested by Jeff, remove a redundant enabling of SIGVTALRM, comprised in the subsequent local_irq_enable(). I'm just a bit dubious if ordering matters there... Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] uml: sparse cleanupsAl Viro
misc sparse annotations Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] uml: more carefully test whether we are in a system callBodo Stroesser
For security reasons, UML in is_syscall() needs to have access to code in vsyscall-page. The current implementation grants this access by explicitly allowing access to vsyscall in access_ok_skas(). With this change, copy_from_user() may be used to read the code. Ptrace access to vsyscall-page for debugging already was implemented in get_user_pages() by mainline. In i386, copy_from_user can't access vsyscall-page, but returns EFAULT. To make UML behave as i386 does, I changed is_syscall to use access_process_vm(current) to read the code from vsyscall-page. This doesn't hurt security, but simplifies the code and prepares implementation of stub-vmas. Signed-off-by: Bodo Stroesser <bstroesser@fujitsu-siemens.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-06[PATCH] uml: S390 preparation, peekusr/pokeusr defined by subarchBodo Stroesser
s390 needs to change some parts of arch/um/kernel/ptrace.c. Thus, the code regarding PEEKUSER and POKEUSER are shifted to arch/um/sys-<subarch>/ptrace.c. Also s390 debug registers need to be updated, when singlestepping is switched on / off. Thus, setting/resetting of singlestepping is centralized in the new function set_singlestep(), which also inserts the macro SUBARCH_SET_SINGLESTEP(mode), if defined. Finally, s390 has the "ieee_instruction_pointer" in its registers, which also is allowed to be read via ptrace( PTRACE_PEEKUSER, getpid(), PT_IEEE_IP, 0); To implement this feature, sys_ptrace inserts the macro SUBARCH_PTRACE_SPECIAL, if defined. Signed-off-by: Bodo Stroesser <bstroesser@fujitsu-siemens.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
