path: root/arch/um/sys-i386
2011-09-14um: clean arch_ptrace() up a bitAl Viro
1) take subarch-specific stuff to subarch_ptrace() 2) PTRACE_{PEEK,POKE}{TEXT,DATA} is handled by ptrace_request() just fine... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-14um: PTRACE_[GS]ETFPXREGS had been wired on the wrong subarchAl Viro
It's 32bit-only, not 64bit-only... And while we are at it, it's set_fpxregs(), not set_fpregs()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-14um: Save FPU registers between task switchesIngo van Lil
Some time ago Jeff prepared 42daba316557 ("uml: stop saving process FP state") for UML to stop saving the process FP state between task switches. The assumption was that since with SKAS0 every guest process runs inside a host process context the host OS will take care of keeping the proper FP state. Unfortunately this is not true for multi-threaded applications, where all guest threads share a single host process context yet all may use the FPU on their own. Although I haven't verified it I suspect things to be even worse in SKAS3 mode where all guest processes run inside a single host process. The patch reintroduces the saving and restoring of the FP context between task switches. [richard@nod.at: Ingo posted this patch in 2009, sadly it was never applied and got lost. Now in 2011 the problem was reported by Gunnar.] Signed-off-by: Ingo van Lil <inguin@gmx.de> Signed-off-by: Richard Weinberger <richard@nod.at> Reported-by: <gunnarlindroth@hotmail.com> Tested-by: <gunnarlindroth@hotmail.com> Cc: Stanislav Meduna <stano@meduna.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge 'akpm' patch seriesLinus Torvalds
* Merge akpm patch series: (122 commits) drivers/connector/cn_proc.c: remove unused local Documentation/SubmitChecklist: add RCU debug config options reiserfs: use hweight_long() reiserfs: use proper little-endian bitops pnpacpi: register disabled resources drivers/rtc/rtc-tegra.c: properly initialize spinlock drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in twl_rtc_set_time() drivers/rtc: add support for Qualcomm PMIC8xxx RTC drivers/rtc/rtc-s3c.c: support clock gating drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200 init: skip calibration delay if previously done misc/eeprom: add eeprom access driver for digsy_mtc board misc/eeprom: add driver for microwire 93xx46 EEPROMs checkpatch.pl: update $logFunctions checkpatch: make utf-8 test --strict checkpatch.pl: add ability to ignore various messages checkpatch: add a "prefer __aligned" check checkpatch: validate signature styles and To: and Cc: lines checkpatch: add __rcu as a sparse modifier checkpatch: suggest using min_t or max_t ... Did this as a merge because of (trivial) conflicts in - Documentation/feature-removal-schedule.txt - arch/xtensa/include/asm/uaccess.h that were just easier to fix up in the merge than in the patch series.
2011-07-25um: Set __HAVE_ARCH_GATE_AREA for i386Richard Weinberger
When UML is unable to reuse the host's vDSO FIXADDR_USER_START is zero. To handle this special case correclty we have to implement custom gate area helper methods. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um: clean up delay functionsRichard Weinberger
Both sys-i386 and sys-x86_64 support now ndelay(). The delay functions are based on arch/x86/lib/delay.c. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-22um: Make rwsem.S depend on CONFIG_RWSEM_XCHGADD_ALGORITHMRichard Weinberger
rwsem.S can only be used with CONFIG_RWSEM_XCHGADD_ALGORITHM. This unbreaks the UML build on i386. Reported-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Richard Weinberger <richard@nod.at> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: user-mode-linux-devel@lists.sourceforge.net Cc: JBeulich@novell.com Link: http://lkml.kernel.org/r/201107222055.35341.richard@nod.at Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-21treewide: fix potentially dangerous trailing ';' in #defined values/expressionsPhil Carmody
All these are instances of #define NAME value; or #define NAME(params_opt) value; These of course fail to build when used in contexts like if(foo $OP NAME) while(bar $OP NAME) and may silently generate the wrong code in contexts such as foo = NAME + 1; /* foo = value; + 1; */ bar = NAME - 1; /* bar = value; - 1; */ baz = NAME & quux; /* baz = value; & quux; */ Reported on comp.lang.c, Message-ID: <ab0d55fe-25e5-482b-811e-c475aa6065c3@c29g2000yqd.googlegroups.com> Initial analysis of the dangers provided by Keith Thompson in that thread. There are many more instances of more complicated macros having unnecessary trailing semicolons, but this pile seems to be all of the cases of simple values suffering from the problem. (Thus things that are likely to be found in one of the contexts above, more complicated ones aren't.) Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-07-21x86: Unify rwsem assembly implementationJan Beulich
Rather than having two functionally identical implementations for 32- and 64-bit configurations, use the previously extended assembly abstractions to fold the rwsem two implementations into a shared one. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/4E258DF3020000780004E3ED@nat28.tlf.novell.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-04-28um: mdd support for 64 bit atomic operationsRichard Weinberger
This adds support for 64 bit atomic operations on 32 bit UML systems. XFS needs them since 2.6.38. $ make ARCH=um SUBARCH=i386 ... LD .tmp_vmlinux1 fs/built-in.o: In function `xlog_regrant_reserve_log_space': xfs_log.c:(.text+0xd8584): undefined reference to `atomic64_read_386' xfs_log.c:(.text+0xd85ac): undefined reference to `cmpxchg8b_emu' ... Addresses https://bugzilla.kernel.org/show_bug.cgi?id=32812 Reported-by: Martin Walch <walch.martin@web.de> Tested-by: Martin Walch <walch.martin@web.de> Cc: Martin Walch <walch.martin@web.de> Cc: <stable@kernel.org> [2.6.38.x 084189a: um: disable CONFIG_CMPXCHG_LOCAL] Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22uml: kernels on {i386,x86_64} produce bad coredumpsPaul Pluzhnikov
One of our users reported that when a user-level program SIGSEGVs under UML kernel, the resulting core dump is not very usable. I have reproduced that with the latest kernel: make ARCH=um defconfig; make ARCH=um Run the resulting kernel, then "inside" run this program: #include <pthread.h> void *fn(void *p) { abort(); } int main() { pthread_t tid; pthread_create(&tid, 0, fn, 0); pthread_join(tid, 0); return 0; } Analyze the coredump with GDB. Here is what you'll see: sudo gdb -q -ex 'set solib-absolute-prefix ../root_fs' -ex 'file ../root_fs/var/tmp/mt-abort' -ex 'core ../root_fs/var/tmp/core.762' Reading symbols from /usr/local/google/root_fs/var/tmp/mt-abort...done. [New Thread 763] [New Thread 762] Core was generated by `./mt-abort'. Program terminated with signal 6, Aborted. #0 0x0000000040255250 in raise () from ../root_fs/lib64/libc.so.6 (gdb) info thread 2 Thread 762 0x0000000000000000 in ?? () * 1 Thread 763 0x0000000040255250 in raise () from ../root_fs/lib64/libc.so.6 Note that thread#2 looks funny. (gdb) thread 2 [Switching to thread 2 (Thread 762)]#0 0x0000000000000000 in ?? () (gdb) info reg rax 0x0 0 rbx 0x0 0 rcx 0x0 0 rdx 0x0 0 rsi 0x0 0 rdi 0x0 0 rbp 0x0 0x0 rsp 0x0 0x0 r8 0x0 0 r9 0x0 0 r10 0x0 0 r11 0x0 0 r12 0x0 0 r13 0x0 0 r14 0x0 0 r15 0x0 0 rip 0x0 0 eflags 0x0 [ ] cs 0x0 0 ss 0x0 0 ds 0x0 0 es 0x0 0 fs 0x0 0 gs 0x0 0 Examining the core shows that NT_PRSTATUS notes for all threads other than the one that crashed are zeroed out. I believe this is happening because neither ELF_CORE_COPY_TASK_REGS nor task_pt_regs are defined under ARCH=um, and so elf_core_copy_task_regs() becomes a no-op. Attached patch fixes this for SUBARCH={x86_64,i386}. Signed-off-by: Paul Pluzhnikov <ppluzhnikov@google.com> Cc: Jeff Dike <jdike@addtoit.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ptrace: change signature of arch_ptrace()Namhyung Kim
Fix up the arguments to arch_ptrace() to take account of the fact that @addr and @data are now unsigned long rather than long as of a preceding patch in this series. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: <linux-arch@vger.kernel.org> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-23Merge branch 'master' into for-nextJiri Kosina
2010-04-21UML: Fix compiler warning due to missing task_struct declarationJan Kiszka
We can't pull in linux/sched.h due to circular dependency, so just forward-declare the struct. This fixes the following warning: CC arch/um/sys-i386/elfcore.o In file included from /data/linux-2.6/include/linux/elf.h:8, from /data/linux-2.6/arch/um/sys-i386/elfcore.c:2: arch/um/sys-i386/asm/elf.h:78: warning: ‘struct task_struct’ declared inside parameter list arch/um/sys-i386/asm/elf.h:78: warning: its scope is only this definition or declaration, which is probably not what you want I guess not many people build against i386 hosts anymore, so this remained widely unnoticed. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-12Add generic sys_ipc wrapperChristoph Hellwig
Add a generic implementation of the ipc demultiplexer syscall. Except for s390 and sparc64 all implementations of the sys_ipc are nearly identical. There are slight differences in the types of the parameters, where mips and powerpc as the only 64-bit architectures with sys_ipc use unsigned long for the "third" argument as it gets casted to a pointer later, while it traditionally is an "int" like most other paramters. frv goes even further and uses unsigned long for all parameters execept for "ptr" which is a pointer type everywhere. The change from int to unsigned long for "third" and back to "int" for the others on frv should be fine due to the in-register calling conventions for syscalls (we already had a similar issue with the generic sys_ptrace), but I'd prefer to have the arch maintainers looks over this in details. Except for that h8300, m68k and m68knommu lack an impplementation of the semtimedop sub call which this patch adds, and various architectures have gets used - at least on i386 it seems superflous as the compat code on x86-64 and ia64 doesn't even bother to implement it. [akpm@linux-foundation.org: add sys_ipc to sys_ni.c] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12Add generic sys_old_mmap()Christoph Hellwig
Add a generic implementation of the old mmap() syscall, which expects its argument in a memory block and switch all architectures over to use it. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12Add generic sys_old_select()Christoph Hellwig
Add a generic implementation of the old select() syscall, which expects its argument in a memory block and switch all architectures over to use it. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Acked-by: Andreas Schwab <schwab@linux-m68k.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: David Howells <dhowells@redhat.com> Cc: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06elf coredump: add extended numbering supportDaisuke HATAYAMA
The current ELF dumper implementation can produce broken corefiles if program headers exceed 65535. This number is determined by the number of vmas which the process have. In particular, some extreme programs may use more than 65535 vmas. (If you google max_map_count, you can find some users facing this problem.) This kind of program never be able to generate correct coredumps. This patch implements ``extended numbering'' that uses sh_info field of the first section header instead of e_phnum field in order to represent upto 4294967295 vmas. This is supported by AMD64-ABI(http://www.x86-64.org/documentation.html) and Solaris(http://docs.sun.com/app/docs/doc/817-1984/). Of course, we are preparing patches for gdb and binutils. Signed-off-by: Daisuke HATAYAMA <d.hatayama@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: David Howells <dhowells@redhat.com> Cc: Greg Ungerer <gerg@snapgear.com> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Andi Kleen <andi@firstfloor.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06elf coredump: replace ELF_CORE_EXTRA_* macros by functionsDaisuke HATAYAMA
elf_core_dump() and elf_fdpic_core_dump() use #ifdef and the corresponding macro for hiding _multiline_ logics in functions. This patch removes #ifdef and replaces ELF_CORE_EXTRA_* by corresponding functions. For architectures not implemeonting ELF_CORE_EXTRA_*, we use weak functions in order to reduce a range of modification. This cleanup is for my next patches, but I think this cleanup itself is worth doing regardless of my firnal purpose. Signed-off-by: Daisuke HATAYAMA <d.hatayama@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: David Howells <dhowells@redhat.com> Cc: Greg Ungerer <gerg@snapgear.com> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Andi Kleen <andi@firstfloor.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16elf: kill USE_ELF_CORE_DUMPChristoph Hellwig
Currently all architectures but microblaze unconditionally define USE_ELF_CORE_DUMP. The microblaze omission seems like an error to me, so let's kill this ifdef and make sure we are the same everywhere. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: <linux-arch@vger.kernel.org> Cc: Michal Simek <michal.simek@petalogix.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-11Unify sys_mmap*Al Viro
New helper - sys_mmap_pgoff(); switch syscalls to using it. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-16uml: fix a section warningAmerigo Wang
When compiling uml on x86_64: MODPOST vmlinux.o WARNING: vmlinux.o (.__syscall_stub.2): unexpected non-allocatable section. Did you forget to use "ax"/"aw" in a .S file? Note that for example <linux/init.h> contains section definitions for use in .S files. Because modpost checks for missing SHF_ALLOC section flag. So just add it. Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-12uml module: fix uml build process due to this mergeAmerigo Wang
Due to the previous merge, uml needs to be fixed. Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-04-02uml: fix link error from prefixing of i386 syscalls with ptregs_Miklos Szeredi
Fix the following link error: arch/um/sys-i386/built-in.o: In function `sys_call_table': (.rodata+0x11c): undefined reference to `ptregs_fork' arch/um/sys-i386/built-in.o: In function `sys_call_table': (.rodata+0x140): undefined reference to `ptregs_execve' arch/um/sys-i386/built-in.o: In function `sys_call_table': (.rodata+0x2cc): undefined reference to `ptregs_iopl' arch/um/sys-i386/built-in.o: In function `sys_call_table': (.rodata+0x2d8): undefined reference to `ptregs_vm86old' arch/um/sys-i386/built-in.o: In function `sys_call_table': (.rodata+0x2f0): undefined reference to `ptregs_sigreturn' arch/um/sys-i386/built-in.o: In function `sys_call_table': (.rodata+0x2f4): undefined reference to `ptregs_clone' arch/um/sys-i386/built-in.o: In function `sys_call_table': (.rodata+0x3ac): undefined reference to `ptregs_vm86' arch/um/sys-i386/built-in.o: In function `sys_call_table': (.rodata+0x3c8): undefined reference to `ptregs_rt_sigreturn' arch/um/sys-i386/built-in.o: In function `sys_call_table': (.rodata+0x3fc): undefined reference to `ptregs_sigaltstack' arch/um/sys-i386/built-in.o: In function `sys_call_table': (.rodata+0x40c): undefined reference to `ptregs_vfork' This was introduced by commit 253f29a4, "x86: pass in pt_regs pointer for syscalls that need it" Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Brian Gerst <brgerst@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jeff Dike <jdike@addtoit.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01uml: remove useless commentsWANG Cong
These comments are useless now, remove them. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-22x86, um: get rid of excessive includes of uml-config.hAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-10-22x86, um: get rid of header symlinksAl Viro
2008-10-22x86, um: get rid of sysdep symlinkAl Viro
2008-10-22x86, um: get rid of uml unistd.hAl Viro
2008-10-20uml: fix a compile errorWANG Cong
Fix arch/um/sys-i386/signal.c: In function 'copy_sc_from_user': arch/um/sys-i386/signal.c:182: warning: dereferencing 'void *' pointer arch/um/sys-i386/signal.c:182: error: request for member '_fxsr_env' in something not a structure or union Signed-off-by: WANG Cong <wangcong@zeuux.org> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24UML: make several more things staticWANG Cong
- Make some variables and functions static, since they don't need to be global. - Remove an unused function - arch/um/kernel/time.c::sched_clock(). - Clean the style a bit as complained by checkpatch.pl. Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: WANG Cong <wangcong@zeuux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13uml: tidy ptrace interfaceJeff Dike
Tidy the ptrace interface code. Removed a bunch of unused macros. Started converting register sets from arrays of longs to structures. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-26x86, UML: remove x86-specific implementations of find_first_bitAlexander van Heukelum
x86 has been switched to the generic versions of find_first_bit and find_first_zero_bit, but the original versions were retained. This patch just removes the now unused x86-specific versions. also update UML. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-02-23uml: remove unused sigcontext accessorsJeff Dike
The macros which extract registers from a struct sigcontext are no longer needed and can be removed. They are starting not to build anyway, given the removal of the 'e' and 'r' from register names during the x86 merge. Cc: Jiri Olsa <olsajiri@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: redo the calculation of NR_syscallsJeff Dike
Redo the calculation of NR_syscalls since that disappeared from i386 and use a similar mechanism on x86_64. We now figure out the size of the system call table in arch code and stick that in syscall_table_size. arch/um/kernel/skas/syscall.c defines NR_syscalls in terms of that since its the only thing that needs to know how many system calls there are. The old mechananism that was used on x86_64 is gone. arch/um/include/sysdep-i386/syscalls.h got some formatting since I was looking at it. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: LDT mutex conversionDaniel Walker
The ldt.semaphore conforms to the new struct mutex requirments, so I converted it to use the new API and changed the name. Signed-off-by: Daniel Walker <dwalker@mvista.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: style fixes in arch/um/sys-x86_64Jeff Dike
Style fixes in arch/um/sys-x86_64: updated copyrights CodingStyle fixes added severities to printks which needed them A bunch of functions in sys-*/ptrace_user.c turn out to be unused, so they and their declarations are gone. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: simplify SIGSEGV handlingJeff Dike
Simplify the page fault stub by not masking signals while it is running. This allows it to signal that it is done by executing an instruction which will generate a SIGTRAP (int3 on x86) rather than running sigreturn by hand after queueing a blocked SIGUSR1. userspace_tramp now no longer puts anything in the SIGSEGV sa_mask, but it does add SA_NODEFER to sa_flags so that SIGSEGV is still enabled after the signal handler fails to run sigreturn. SIGWINCH is just blocked so that we don't have to deal with it and the signal masks used by wait_stub_done are updated to reflect the smaller number of signals that it has to worry about. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: current.h cleanupJeff Dike
Tidy current-related stuff. There was a comment in current.h saying that current_thread was obsolete, so this patch turns all instances of current_thread into current_thread_info(). There's some simplifying of the result in arch/um/sys-i386/signal.c. current.h and thread_info also get style cleanups. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: header untanglingJeff Dike
Untangle UML headers somewhat and add some includes where they were needed explicitly, but gotten accidentally via some other header. arch/um/include/um_uaccess.h loses asm/fixmap.h because it uses no fixmap stuff and gains elf.h, because it needs FIXADDR_USER_*, and archsetjmp.h, because it needs jmp_buf. pmd_alloc_one is uninlined because it needs mm_struct, and that's inconvenient to provide in asm-um/pgtable-3level.h. elf_core_copy_fpregs is also uninlined from elf-i386.h and elf-x86_64.h, which duplicated the code anyway, to arch/um/kernel/process.c, so that the reference to current_thread doesn't pull sched.h or anything related into asm/elf.h. arch/um/sys-i386/ldt.c, arch/um/kernel/tlb.c and arch/um/kernel/skas/uaccess.c got sched.h because they dereference task_structs. Its includes of linux and asm headers got turned from "" to <>. arch/um/sys-i386/bug.c gets asm/errno.h because it needs errno constants. asm/elf-i386 gets asm/user.h because it needs user_regs_struct. asm/fixmap.h gets page.h because it needs PAGE_SIZE and PAGE_MASK and system.h for BUG_ON. asm/pgtable doesn't need sched.h. asm/processor-generic.h defined mm_segment_t, but didn't use it. So, that definition is moved to uaccess.h, which defines a bunch of mm_segment_t-related stuff. thread_info.h uses mm_segment_t, and includes uaccess.h, which causes a recursion. So, the definition is placed above the include of thread_info. in uaccess.h. thread_info.h also gets page.h because it needs PAGE_SIZE. ObCheckpatchViolationJustification - I'm not adding a typedef; I'm moving mm_segment_t from one place to another. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: host TLS diagnosticsJeff Dike
Add some diagnostics when TLS operations on the host fail. Also spit out more information about the TLS environment on the host at boot time. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: remove unused variables in the context switcherKarol Swietlicki
This patch removes a variable which was not used in two functions. Yet another code cleanup, nothing really significant. Please note that I could not test this on x86_64. I don't have the hardware for it. [ jdike - Bits of tidying around the affected code. Also, it's fine on x86_64 ] Signed-off-by: Karol Swietlicki <magotari@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: tidy kern_util.hJeff Dike
Tidy kern_util.h. It turns out that most of the function declarations aren't used, so they can go away. os.h no longer includes kern_util.h, so files which got it through os.h now need to include it directly. A number of other files never needed it, so these includes are deleted. The structure which was used to pass signal handlers from the kernel side to the userspace side is gone. Instead, the handlers are declared here, and used directly from libc code. This allows arch/um/os-Linux/trap.c to be deleted, with its remnants being moved to arch/um/os-Linux/skas/trap.c. arch/um/os-Linux/tty.c had its inclusions changed, and it needed some style attention, so it got tidied. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: borrow const.h techniquesJeff Dike
Suggested by Geert Uytterhoeven - use const.h to get constants that are usable in both C and assembly. I can't include it directly since this code can't include kernel headers. const.h is also for numeric constants that can be typed by tacking a "UL" or similar on the end. The constants here have to be typed by casting them. So, the relevant parts of const.h are copied here and modified in order to allow the constants to be uncasted in assembly and casted in C. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: further bugs.c tidyingJeff Dike
bugs.c, for both i386 and x86_64, can undergo further cleaning - The i386 arch_check_bugs only does one thing, so we might as well inline the cmov checking. The i386 includes can be trimmed down a bit. arch_init_thread wasn't used, so it is deleted. The panics in arch_handle_signal are turned into printks because the process is about to get segfaulted anyway, so something is dying no matter what happens here. Also, the return value was always the same, so it contained no information, so it can be void instead. The name is changed to arch_examine_signal because it doesn't handle anything. The caller of arch_handle_signal, relay_signal, does things in a different order. The kernel-mode signal check is now first, which puts everything else together, making things a bit clearer conceptually. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: remove now unused codeKarol Swietlicki
This patch finishes what the previous one started. The code was not used after my first patch, and now can be removed with ease. [ jdike - also deleted the #if 0 lcall stuff ] Signed-off-by: Karol Swietlicki <magotari@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: improve detection of host cmovKarol Swietlicki
This patch introduces a new way of checking for the cmov instruction. I use signal handling instead of reading /proc/cpuinfo. [ jdike - Fiddled the asm to make it obvious that it didn't mess with any in-use registers and made test_for_host_cmov void ] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Karol Swietlicki <magotari@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
