path: root/arch/um/sys-ppc
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-02-05uml: remove TOPDIRWANG Cong
TOPDIR is obsolete, use srctree instead. This patch removes TOPDIR from all UML Makefiles. Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-15kbuild: enable 'make AFLAGS=...' to add additional options to ASSam Ravnborg
The variable AFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. On top of that several people over time has asked for a way to pass in additional flags to gcc. This patch replace use of AFLAGS with KBUILD_AFLAGS all over the tree. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k, s390 Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-07uml: remove user_util.hJeff Dike
user_util.h isn't needed any more, so delete it and remove all includes of it. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-06-15[POWERPC] Remove stale 64bit on 32bit kernel codeAnton Blanchard
Remove some stale POWER3/POWER4/970 on 32bit kernel support. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-05-28[PATCH] uml: stack dump fixPaolo 'Blaisorblade' Giarrusso
Copy (and adapt) to UML the stack code dumper used in i386 when CONFIG_FRAME_POINTER is enabled. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-06[PATCH] uml: S390 preparation, peekusr/pokeusr defined by subarchBodo Stroesser
s390 needs to change some parts of arch/um/kernel/ptrace.c. Thus, the code regarding PEEKUSER and POKEUSER are shifted to arch/um/sys-<subarch>/ptrace.c. Also s390 debug registers need to be updated, when singlestepping is switched on / off. Thus, setting/resetting of singlestepping is centralized in the new function set_singlestep(), which also inserts the macro SUBARCH_SET_SINGLESTEP(mode), if defined. Finally, s390 has the "ieee_instruction_pointer" in its registers, which also is allowed to be read via ptrace( PTRACE_PEEKUSER, getpid(), PT_IEEE_IP, 0); To implement this feature, sys_ptrace inserts the macro SUBARCH_PTRACE_SPECIAL, if defined. Signed-off-by: Bodo Stroesser <bstroesser@fujitsu-siemens.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
