path: root/arch/um/sys-x86_64/ksyms.c
2008-06-06uml: memcpy export needs to follow host declarationJeff Dike
x86_64 defines either memcpy or __memcpy depending on the gcc version, and it looks like UML needs to follow that in its exporting. Cc: Gabriel C <nix.or.die@googlemail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-21missing export of csum_partial() on uml/amd64Al Viro
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2006-10-11[PATCH] uml: remove duplicate exportPaolo 'Blaisorblade' Giarrusso
The export is together with the definition, in arch/x86_64/lib/csum-partial.c, which is compiled in by arch/um/sys-x86_64/Makefile. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-20[PATCH] uml: small fixes left over from rc4Jeff Dike
Some changes that I sent in didn't make 2.6.12-rc4 for some reason. This adds them back. We have an x86_64 definition of TOP_ADDR a reimplementation of the x86_64 csum_partial_copy_from_user some syntax fixes in arch/um/kernel/ptrace.c removal of a CFLAGS definition in the x86_64 Makefile some include changes in the x86_64 ptrace.c and user-offsets.h a syntax fix in elf-x86_64.h Also moved an include in the i386 and x86_64 Makefiles to make the symlinks work, and some small fixes from Al Viro. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] x86_64: make string func definition work as intendedPaolo 'Blaisorblade' Giarrusso
In include/asm-x86_64/string.h there are such comments: /* Use C out of line version for memcmp */ #define memcmp __builtin_memcmp int memcmp(const void * cs,const void * ct,size_t count); This would mean that if the compiler does not decide to use __builtin_memcmp, it emits a call to memcmp to be satisfied by the C out-of-line version in lib/string.c. What happens is that after preprocessing, in lib/string.i you may find the definition of "__builtin_strcmp". Actually, by accident, in the object you will find the definition of strcmp and such (maybe a trick intended to redirect calls to __builtin_memcmp to the default memcmp when the definition is not expanded); however, this particular case is not a documented feature as far as I can see. Also, the EXPORT_SYMBOL does not work, so it's duplicated in the arch. I simply added some #undef to lib/string.c and removed the (now duplicated) exports in x86-64 and UML/x86_64 subarchs (the second ones are introduced by another patch I just posted for -mm). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> CC: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] uml: kludgy compilation fixes for x86-64 subarch modules supportPaolo 'Blaisorblade' Giarrusso
These are some trivial fixes for the x86-64 subarch module support. The only potential problem is that I have to modify arch/x86_64/kernel/module.c, to avoid copying the whole of it. I can't use it verbatim because it depends on a special vmalloc-like area for modules, which for now (maybe that's to fix, I guess not) UML/x86-64 has not. I went the easy way and reused the i386 vmalloc()-based allocator. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
