path: root/arch/um
2010-01-18untangle the do_mremap() messAl Viro
This backports the following upstream commits all as one patch: 54f5de709984bae0d31d823ff03de755f9dcac54 ecc1a8993751de4e82eb18640d631dae1f626bd6 1a0ef85f84feb13f07b604fcf5b90ef7c2b5c82f f106af4e90eadd76cfc0b5325f659619e08fb762 097eed103862f9c6a97f2e415e21d1134017b135 935874141df839c706cd6cdc438e85eb69d1525e 0ec62d290912bb4b989be7563851bc364ec73b56 c4caa778157dbbf04116f0ac2111e389b5cd7a29 2ea1d13f64efdf49319e86c87d9ba38c30902782 570dcf2c15463842e384eb597a87c1e39bead99b 564b3bffc619dcbdd160de597b0547a7017ea010 0067bd8a55862ac9dd212bd1c4f6f5bff1ca1301 f8b7256096a20436f6d0926747e3ac3d64c81d24 8c7b49b3ecd48923eb64ff57e07a1cdb74782970 9206de95b1ea68357996ec02be5db0638a0de2c1 2c6a10161d0b5fc047b5bd81b03693b9af99fab5 05d72faa6d13c9d857478a5d35c85db9adada685 bb52d6694002b9d632bb355f64daa045c6293a4e e77414e0aad6a1b063ba5e5750c582c75327ea6a aa65607373a4daf2010e8c3867b6317619f3c1a3 Backport done by Greg Kroah-Hartman. Only minor tweaks were needed. Cc: David S. Miller <davem@davemloft.net> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-09-24um: Clean up linker script using standard macros.Tim Abbott
Signed-off-by: Tim Abbott <tabbott@ksplice.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: user-mode-linux-devel@lists.sourceforge.net Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (39 commits) cpumask: Move deprecated functions to end of header. cpumask: remove unused deprecated functions, avoid accusations of insanity cpumask: use new-style cpumask ops in mm/quicklist. cpumask: use mm_cpumask() wrapper: x86 cpumask: use mm_cpumask() wrapper: um cpumask: use mm_cpumask() wrapper: mips cpumask: use mm_cpumask() wrapper: mn10300 cpumask: use mm_cpumask() wrapper: m32r cpumask: use mm_cpumask() wrapper: arm cpumask: Use accessors for cpu_*_mask: um cpumask: Use accessors for cpu_*_mask: powerpc cpumask: Use accessors for cpu_*_mask: mips cpumask: Use accessors for cpu_*_mask: m32r cpumask: remove arch_send_call_function_ipi cpumask: arch_send_call_function_ipi_mask: s390 cpumask: arch_send_call_function_ipi_mask: powerpc cpumask: arch_send_call_function_ipi_mask: mips cpumask: arch_send_call_function_ipi_mask: m32r cpumask: arch_send_call_function_ipi_mask: alpha cpumask: remove obsolete topology_core_siblings and topology_thread_siblings: ia64 ...
2009-09-24cpumask: use mm_cpumask() wrapper: umRusty Russell
Makes code futureproof against the impending change to mm->cpu_vm_mask. It's also a chance to use the new cpumask_ ops which take a pointer (the older ones are deprecated, but there's no hurry for arch code). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-24cpumask: Use accessors for cpu_*_mask: umRusty Russell
Use the accessors rather than frobbing bits directly (the new versions are const). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com>
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (30 commits) Use macros for .data.page_aligned section. Use macros for .bss.page_aligned section. Use new __init_task_data macro in arch init_task.c files. kbuild: Don't define ALIGN and ENTRY when preprocessing linker scripts. arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0 kbuild: add static to prototypes kbuild: fail build if recordmcount.pl fails kbuild: set -fconserve-stack option for gcc 4.5 kbuild: echo the record_mcount command gconfig: disable "typeahead find" search in treeviews kbuild: fix cc1 options check to ensure we do not use -fPIC when compiling checkincludes.pl: add option to remove duplicates in place markup_oops: use modinfo to avoid confusion with underscored module names checkincludes.pl: provide usage helper checkincludes.pl: close file as soon as we're done with it ctags: usability fix kernel hacking: move STRIP_ASM_SYMS from General gitignore usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma kbuild: Check if linker supports the -X option kbuild: introduce ld-option ... Fix trivial conflict in scripts/basic/fixdep.c
2009-09-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) trivial: fix typo in aic7xxx comment trivial: fix comment typo in drivers/ata/pata_hpt37x.c trivial: typo in kernel-parameters.txt trivial: fix typo in tracing documentation trivial: add __init/__exit macros in drivers/gpio/bt8xxgpio.c trivial: add __init macro/ fix of __exit macro location in ipmi_poweroff.c trivial: remove unnecessary semicolons trivial: Fix duplicated word "options" in comment trivial: kbuild: remove extraneous blank line after declaration of usage() trivial: improve help text for mm debug config options trivial: doc: hpfall: accept disk device to unload as argument trivial: doc: hpfall: reduce risk that hpfall can do harm trivial: SubmittingPatches: Fix reference to renumbered step trivial: fix typos "man[ae]g?ment" -> "management" trivial: media/video/cx88: add __init/__exit macros to cx88 drivers trivial: fix typo in CONFIG_DEBUG_FS in gcov doc trivial: fix missing printk space in amd_k7_smp_check trivial: fix typo s/ketymap/keymap/ in comment trivial: fix typo "to to" in multiple files trivial: fix typos in comments s/DGBU/DBGU/ ...
2009-09-22uml: fix order of pud and pmd_free()Roel Kluin
If pmd_alloc() fails we should only free the prior allocated pud, if pte_alloc_map() fails, we should free pmd as well. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22um: convert to asm-generic/hardirq.hChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22arches: drop superfluous casts in nr_free_pages() callersGeert Uytterhoeven
Commit 96177299416dbccb73b54e6b344260154a445375 ("Drop free_pages()") modified nr_free_pages() to return 'unsigned long' instead of 'unsigned int'. This made the casts to 'unsigned long' in most callers superfluous, so remove them. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Mikael Starvik <starvik@axis.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Chris Zankel <zankel@tensilica.com> Cc: Michal Simek <monstr@monstr.eu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22const: make block_device_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21trivial: remove unnecessary semicolonsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-21trivial: fix typo "to to" in multiple filesAnand Gadiyar
Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-21Use new __init_task_data macro in arch init_task.c files.Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tim Abbott <tabbott@ksplice.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-20includecheck fix: um, helper.cJaswinder Singh Rajput
fix the following 'make includecheck' warning: arch/um/os-Linux/helper.c: linux/limits.h is included more than once. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Cc: jdike@addtoit.com Cc: Sam Ravnborg <sam@ravnborg.org> LKML-Reference: <1247064950.4382.45.camel@ht.satnam> Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
2009-09-20arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0Sam Ravnborg
Albin Tonnerre <albin.tonnerre@free-electrons.com> reported: Bash 4 filters out variables which contain a dot in them. This happends to be the case of CPPFLAGS_vmlinux.lds. This is rather unfortunate, as it now causes build failures when using SHELL=/bin/bash to compile, or when bash happens to be used by make (eg when it's /bin/sh) Remove the common definition of CPPFLAGS_vmlinux.lds by pushing relevant stuff to either Makefile.build or the arch specific kernel/Makefile where we build the linker script. This is also nice cleanup as we move the information out where it is used. Notes for the different architectures touched: arm - we use an already exported symbol cris - we use a config symbol aleady available [Not build tested] mips - the jiffies complexity has moved to vmlinux.lds.S where we need it. Added a few variables to CPPFLAGS - they are only used by the linker script. [Not build tested] powerpc - removed assignment that is not needed [not build tested] sparc - simplified it using $(BITS) um - introduced a few new exported variables to deal with this xtensa - added options to CPP invocation [not build tested] Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-16Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (75 commits) PCI hotplug: clean up acpi_run_hpp() PCI hotplug: acpiphp: use generic pci_configure_slot() PCI hotplug: shpchp: use generic pci_configure_slot() PCI hotplug: pciehp: use generic pci_configure_slot() PCI hotplug: add pci_configure_slot() PCI hotplug: clean up acpi_get_hp_params_from_firmware() interface PCI hotplug: acpiphp: don't cache hotplug_params in acpiphp_bridge PCI hotplug: acpiphp: remove superfluous _HPP/_HPX evaluation PCI: Clear saved_state after the state has been restored PCI PM: Return error codes from pci_pm_resume() PCI: use dev_printk in quirk messages PCI / PCIe portdrv: Fix pcie_portdrv_slot_reset() PCI Hotplug: convert acpi_pci_detect_ejectable() to take an acpi_handle PCI Hotplug: acpiphp: find bridges the easy way PCI: pcie portdrv: remove unused variable PCI / ACPI PM: Propagate wake-up enable for devices w/o ACPI support ACPI PM: Replace wakeup.prepared with reference counter PCI PM: Introduce device flag wakeup_prepared PCI / ACPI PM: Rework some debug messages PCI PM: Simplify PCI wake-up code ... Fixed up conflict in arch/powerpc/kernel/pci_64.c due to OF device tree scanning having been moved and merged for the 32- and 64-bit cases. The 'needs_freset' initialization added in 6e19314cc ("PCI/powerpc: support PCIe fundamental reset") is now in arch/powerpc/kernel/pci_of_scan.c.
2009-09-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (46 commits) powerpc64: convert to dynamic percpu allocator sparc64: use embedding percpu first chunk allocator percpu: kill lpage first chunk allocator x86,percpu: use embedding for 64bit NUMA and page for 32bit NUMA percpu: update embedding first chunk allocator to handle sparse units percpu: use group information to allocate vmap areas sparsely vmalloc: implement pcpu_get_vm_areas() vmalloc: separate out insert_vmalloc_vm() percpu: add chunk->base_addr percpu: add pcpu_unit_offsets[] percpu: introduce pcpu_alloc_info and pcpu_group_info percpu: move pcpu_lpage_build_unit_map() and pcpul_lpage_dump_cfg() upward percpu: add @align to pcpu_fc_alloc_fn_t percpu: make @dyn_size mandatory for pcpu_setup_first_chunk() percpu: drop @static_size from first chunk allocators percpu: generalize first chunk allocator selection percpu: build first chunk allocators selectively percpu: rename 4k first chunk allocator to page percpu: improve boot messages percpu: fix pcpu_reclaim() locking ... Fix trivial conflict as by Tejun Heo in kernel/sched.c
2009-09-09PCI: remove pcibios_scan_all_fns()Alex Chiang
This was #define'd as 0 on all platforms, so let's get rid of it. This change makes pci_scan_slot() slightly easier to read. Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Tony Luck <tony.luck@intel.com> Cc: David Howells <dhowells@redhat.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Russell King <linux@arm.linux.org.uk> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-02netdev: drivers should make ethtool_ops constStephen Hemminger
No need to put ethtool_ops in data, they should be const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-14Merge branch 'percpu-for-linus' into percpu-for-nextTejun Heo
Conflicts: arch/sparc/kernel/smp_64.c arch/x86/kernel/cpu/perf_counter.c arch/x86/kernel/setup_percpu.c drivers/cpufreq/cpufreq_ondemand.c mm/percpu.c Conflicts in core and arch percpu codes are mostly from commit ed78e1e078dd44249f88b1dd8c76dafb39567161 which substituted many num_possible_cpus() with nr_cpu_ids. As for-next branch has moved all the first chunk allocators into mm/percpu.c, the changes are moved from arch code to mm/percpu.c. Signed-off-by: Tejun Heo <tj@kernel.org>
2009-08-12Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: arch/microblaze/include/asm/socket.h
2009-07-27mm: Pass virtual address to [__]p{te,ud,md}_free_tlb()Benjamin Herrenschmidt
mm: Pass virtual address to [__]p{te,ud,md}_free_tlb() Upcoming paches to support the new 64-bit "BookE" powerpc architecture will need to have the virtual address corresponding to PTE page when freeing it, due to the way the HW table walker works. Basically, the TLB can be loaded with "large" pages that cover the whole virtual space (well, sort-of, half of it actually) represented by a PTE page, and which contain an "indirect" bit indicating that this TLB entry RPN points to an array of PTEs from which the TLB can then create direct entries. Thus, in order to invalidate those when PTE pages are deleted, we need the virtual address to pass to tlbilx or tlbivax instructions. The old trick of sticking it somewhere in the PTE page struct page sucks too much, the address is almost readily available in all call sites and almost everybody implemets these as macros, so we may as well add the argument everywhere. I added it to the pmd and pud variants for consistency. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: David Howells <dhowells@redhat.com> [MN10300 & FRV] Acked-by: Nick Piggin <npiggin@suse.de> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-10sched: INIT_PREEMPT_COUNTPeter Zijlstra
Pull the initial preempt_count value into a single definition site. Maintainers for: alpha, ia64 and m68k, please have a look, your arch code is funny. The header magic is a bit odd, but similar to the KERNEL_DS one, CPP waits with expanding these macros until the INIT_THREAD_INFO macro itself is expanded, which is in arch/*/kernel/init_task.c where we've already included sched.h so we're good. Cc: tony.luck@intel.com Cc: rth@twiddle.net Cc: geert@linux-m68k.org Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-09linker script: unify usage of discard definitionTejun Heo
Discarded sections in different archs share some commonality but have considerable differences. This led to linker script for each arch implementing its own /DISCARD/ definition, which makes maintaining tedious and adding new entries error-prone. This patch makes all linker scripts to move discard definitions to the end of the linker script and use the common DISCARDS macro. As ld uses the first matching section definition, archs can include default discarded sections by including them earlier in the linker script. ia64 is notable because it first throws away some ia64 specific subsections and then include the rest of the sections into the final image, so those sections must be discarded before the inclusion. defconfig compile tested for x86, x86-64, powerpc, powerpc64, ia64, alpha, sparc, sparc64 and s390. Michal Simek tested microblaze. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Tested-by: Michal Simek <monstr@monstr.eu> Cc: linux-arch@vger.kernel.org Cc: Michal Simek <monstr@monstr.eu> Cc: microblaze-uclinux@itee.uq.edu.au Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Tony Luck <tony.luck@intel.com>
2009-07-08Remove multiple KERN_ prefixes from printk formatsJoe Perches
Commit 5fd29d6ccbc98884569d6f3105aeca70858b3e0f ("printk: clean up handling of log-levels and newlines") changed printk semantics. printk lines with multiple KERN_<level> prefixes are no longer emitted as before the patch. <level> is now included in the output on each additional use. Remove all uses of multiple KERN_<level>s in formats. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-04Merge branch 'master' into for-nextTejun Heo
Pull linus#master to merge PER_CPU_DEF_ATTRIBUTES and alpha build fix changes. As alpha in percpu tree uses 'weak' attribute instead of inline assembly, there's no need for __used attribute. Conflicts: arch/alpha/include/asm/percpu.h arch/mn10300/kernel/vmlinux.lds.S include/linux/percpu-defs.h
2009-06-25UML: Fix some apparent bitrotPaul Menage
UML: Fix some apparent bitrot - migration of net_device methods into net_device_ops - dma_sync_single() changes Signed-off-by: Paul Menage <menage@google.com> Acked-by: Amerigo Wang <xiyou.wangcong@gmail.com> -- This version is split from my earlier patch, including just the portions that ar required for Linus' tree. Fixes the following compile errors: include/linux/dma-mapping.h:113: error: redefinition of 'dma_sync_single' arch/um/include/asm/dma-mapping.h:84: error: previous definition of 'dma_sync_single' was here include/linux/dma-mapping.h: In function 'dma_sync_single': include/linux/dma-mapping.h:117: error: implicit declaration of function 'dma_sync_single_for_cpu' include/linux/dma-mapping.h: At top level: include/linux/dma-mapping.h:120: error: redefinition of 'dma_sync_sg' arch/um/include/asm/dma-mapping.h:91: error: previous definition of 'dma_sync_sg' was here include/linux/dma-mapping.h: In function 'dma_sync_sg': include/linux/dma-mapping.h:124: error: implicit declaration of function 'dma_sync_sg_for_cpu' arch/um/drivers/slirp_kern.c: In function 'slirp_init': arch/um/drivers/slirp_kern.c:35: error: 'struct net_device' has no member named 'init' Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-24linker script: throw away .discard sectionTejun Heo
x86 throws away .discard section but no other archs do. Also, .discard is not thrown away while linking modules. Make every arch and module linking throw it away. This will be used to define dummy variables for percpu declarations and definitions. This patch is based on Ivan Kokshaysky's alpha percpu patch. [ Impact: always throw away everything in .discard ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Russell King <linux@arm.linux.org.uk> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Bryan Wu <cooloney@kernel.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Chris Zankel <chris@zankel.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@elte.hu>
2009-06-21Move FAULT_FLAG_xyz into handle_mm_fault() callersLinus Torvalds
This allows the callers to now pass down the full set of FAULT_FLAG_xyz flags to handle_mm_fault(). All callers have been (mechanically) converted to the new calling convention, there's almost certainly room for architectures to clean up their code and then add FAULT_FLAG_RETRY when that support is added. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16Merge branch 'akpm'Linus Torvalds
* akpm: (182 commits) fbdev: bf54x-lq043fb: use kzalloc over kmalloc/memset fbdev: *bfin*: fix __dev{init,exit} markings fbdev: *bfin*: drop unnecessary calls to memset fbdev: bfin-t350mcqb-fb: drop unused local variables fbdev: blackfin has __raw I/O accessors, so use them in fb.h fbdev: s1d13xxxfb: add accelerated bitblt functions tcx: use standard fields for framebuffer physical address and length fbdev: add support for handoff from firmware to hw framebuffers intelfb: fix a bug when changing video timing fbdev: use framebuffer_release() for freeing fb_info structures radeon: P2G2CLK_ALWAYS_ONb tested twice, should 2nd be P2G2CLK_DAC_ALWAYS_ONb? s3c-fb: CPUFREQ frequency scaling support s3c-fb: fix resource releasing on error during probing carminefb: fix possible access beyond end of carmine_modedb[] acornfb: remove fb_mmap function mb862xxfb: use CONFIG_OF instead of CONFIG_PPC_OF mb862xxfb: restrict compliation of platform driver to PPC Samsung SoC Framebuffer driver: add Alpha Channel support atmel-lcdc: fix pixclock upper bound detection offb: use framebuffer_alloc() to allocate fb_info struct ... Manually fix up conflicts due to kmemcheck in mm/slab.c
2009-06-16fbdev: move logo externs to header fileGeert Uytterhoeven
Now we have __initconst, we can finally move the external declarations for the various Linux logo structures to <linux/linux_logo.h>. James' ack dates back to the previous submission (way to long ago), when the logos were still __initdata, which caused failures on some platforms with some toolchain versions. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: James Simmons <jsimmons@infradead.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16uml: bad macro expansion, parameter is memberRoel Kluin
`ELF_CORE_COPY_REGS(x, y)' will make expansions like: `(y)[0] = (x)->x.gp[0]' but correct is `(y)[0] = (x)->regs.gp[0]' Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: WANG Cong <amwang@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16uml: fix a section warningAmerigo Wang
When compiling uml on x86_64: MODPOST vmlinux.o WARNING: vmlinux.o (.__syscall_stub.2): unexpected non-allocatable section. Did you forget to use "ax"/"aw" in a .S file? Note that for example <linux/init.h> contains section definitions for use in .S files. Because modpost checks for missing SHF_ALLOC section flag. So just add it. Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16um: remove obsolete hw_interrupt_typeThomas Gleixner
The defines and typedefs (hw_interrupt_type, no_irq_type, irq_desc_t) have been kept around for migration reasons. After more than two years it's time to remove them finally. This patch cleans up one of the remaining users. When all such patches hit mainline we can remove the defines and typedefs finally. Impact: cleanup Convert the last remaining users to struct irq_chip and remove the define. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16uml: UML net driver does not allow for vlansAlan Cox
See ancient discussion at http://marc.info/?l=user-mode-linux-devel&m=101990155831279&w=2 Addresses http://bugzilla.kernel.org/show_bug.cgi?id=7854 Signed-off-by: Alan Cox <alan@linux.intel.com> Reported-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Cc: Roland Kletzing <devzero@web.de> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: consolidate init_mm definitionAlexey Dobriyan
* create mm/init-mm.c, move init_mm there * remove INIT_MM, initialize init_mm with C99 initializer * unexport init_mm on all arches: init_mm is already unexported on x86. One strange place is some OMAP driver (drivers/video/omap/) which won't build modular, but it's already wants get_vm_area() export. Somebody should look there. [akpm@linux-foundation.org: add missing #includes] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Americo Wang <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-15uml: remove driver_data direct access of struct deviceGreg Kroah-Hartman
In the near future, the driver core is going to not allow direct access to the driver_data pointer in struct device. Instead, the functions dev_get_drvdata() and dev_set_drvdata() should be used. These functions have been around since the beginning, so are backwards compatible with all older kernel versions. Cc: user-mode-linux-devel@lists.sourceforge.net Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: add generic lib/checksum.c asm-generic: add a generic uaccess.h asm-generic: add generic NOMMU versions of some headers asm-generic: add generic atomic.h and io.h asm-generic: add legacy I/O header files asm-generic: add generic versions of common headers asm-generic: make bitops.h usable asm-generic: make pci.h usable directly asm-generic: make get_rtc_time overridable asm-generic: rename page.h and uaccess.h asm-generic: rename atomic.h to atomic-long.h asm-generic: add a generic unistd.h asm-generic: add generic ABI headers asm-generic: add generic sysv ipc headers asm-generic: introduce asm/bitsperlong.h asm-generic: rename termios.h, signal.h and mman.h
2009-06-12PM: Remove unused asm/suspend.hMagnus Damm
This patch removes unused asm/suspend.h files for the following architectures: alpha, arm, ia64, m68k, mips, s390, um Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-06-12module: merge module_alloc() finallyAmerigo Wang
As Christoph Hellwig suggested, module_alloc() actually can be unified for i386 and x86_64 (of course, also UML). Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: 'Ingo Molnar' <mingo@elte.hu> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-06-12uml module: fix uml build process due to this mergeAmerigo Wang
Due to the previous merge, uml needs to be fixed. Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-06-12asm-generic: merge branch 'master' of torvalds/linux-2.6Arnd Bergmann
Fixes a merge conflict against the x86 tree caused by a fix to atomic.h which I renamed to atomic_long.h. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-11asm-generic: rename page.h and uaccess.hArnd Bergmann
The current asm-generic/page.h only contains the get_order function, and asm-generic/uaccess.h only implements unaligned accesses. This renames the file to getorder.h and uaccess-unaligned.h to make room for new page.h and uaccess.h file that will be usable by all simple (e.g. nommu) architectures. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-05-11block: implement and enforce request peek/start/fetchTejun Heo
Till now block layer allowed two separate modes of request execution. A request is always acquired from the request queue via elv_next_request(). After that, drivers are free to either dequeue it or process it without dequeueing. Dequeue allows elv_next_request() to return the next request so that multiple requests can be in flight. Executing requests without dequeueing has its merits mostly in allowing drivers for simpler devices which can't do sg to deal with segments only without considering request boundary. However, the benefit this brings is dubious and declining while the cost of the API ambiguity is increasing. Segment based drivers are usually for very old or limited devices and as converting to dequeueing model isn't difficult, it doesn't justify the API overhead it puts on block layer and its more modern users. Previous patches converted all block low level drivers to dequeueing model. This patch completes the API transition by... * renaming elv_next_request() to blk_peek_request() * renaming blkdev_dequeue_request() to blk_start_request() * adding blk_fetch_request() which is combination of peek and start * disallowing completion of queued (not started) requests * applying new API to all LLDs Renamings are for consistency and to break out of tree code so that it's apparent that out of tree drivers need updating. [ Impact: block request issue API cleanup, no functional change ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Mike Miller <mike.miller@hp.com> Cc: unsik Kim <donari75@gmail.com> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Tim Waugh <tim@cyberelk.net> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: David S. Miller <davem@davemloft.net> Cc: Laurent Vivier <Laurent@lvivier.info> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Adrian McMenamin <adrian@mcmen.demon.co.uk> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: Pierre Ossman <drzeus@drzeus.cx> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Stefan Weinhuber <wein@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: convert to pos and nr_sectors accessorsTejun Heo
With recent cleanups, there is no place where low level driver directly manipulates request fields. This means that the 'hard' request fields always equal the !hard fields. Convert all rq->sectors, nr_sectors and current_nr_sectors references to accessors. While at it, drop superflous blk_rq_pos() < 0 test in swim.c. [ Impact: use pos and nr_sectors accessors ] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Tested-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Mike Miller <mike.miller@hp.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Tim Waugh <tim@cyberelk.net> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Dario Ballabio <ballabio_dario@emc.com> Cc: David S. Miller <davem@davemloft.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: unsik Kim <donari75@gmail.com> Cc: Laurent Vivier <Laurent@lvivier.info> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28ubd: drop unnecessary rq->sector manipulationTejun Heo
ubd curiously updates rq->sector while issuing the request in multiple pieces. Don't do it and simply use local copy of sector. [ Impact: cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28ubd: cleanup completion pathTejun Heo
ubd had its own block request partial completion mechanism, which is unnecessary as block layer already does it. Kill ubd_end_request() and ubd_finish() and replace them with direct call to blk_end_request(). [ Impact: cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
