commit a24864a1d52a97e345a6bd4862a057f98364d098
uml: definitively kill subprocesses on panic
In a stock 2.6.22.6 kernel, poweroff a user mode linux guest (2.6.22.6 running
in skas0 mode) will halt the host linux. I think the reason is the kernel
thread abort because of a bug. Then the sys_reboot in process of user mode
linux guest is not trapped by the user mode linux kernel and is executed by
host. I think it is better to make sure all of our children process to quit
when user mode linux kernel abort.
[ jdike - the kernel process needs to ignore SIGTERM, plus the waitpid/kill
loop is needed to make sure that all of our children are dead before the
kernel exits ]
Signed-off-by: Lepton Wu <ytht.net@gmail.com>
Signed-off-by: Jeff Dike <jdike@linux.intel.com>
commit 189872f968def833727b6bfef83ebd7440c538e6 in mainline.
uml: don't use glibc asm/user.h
Stop including asm/user.h from libc - it seems to be disappearing from
distros. It's replaced with sys/user.h which defines user_fpregs_struct and
user_fpxregs_struct instead of user_i387_struct and struct user_fxsr_struct on
i386.
As a bonus, on x86_64, I get to dump some stupid typedefs which were needed in
order to get asm/user.h to compile.
commit 818f6ef407b448cef63294b9d0f6f8a2af9cb817 in mainline.
uml: fix an IPV6 libc vs kernel symbol clash
On some systems, with IPV6 configured, there is a clash between the kernel's
in6addr_any and the one in libc.
This is handled in the usual (gross) way of defining the kernel symbol out of
the way on the gcc command line.
commit 71f926f2ea61994470a53c9e11d3ef993197cada in mainline.
uml: stop using libc asm/page.h
Remove includes of asm/page.h from libc code. This header seems to be
disappearing, and UML doesn't make much use of it anyway.
The one use, PAGE_SHIFT in stub.h, is handled by copying the constant from the
kernel side of the house in common_offsets.h.
[ jdike - added arch/um/kernel/skas/clone.c for -stable ]
This patch fixes a crash caused by an interrupt coming in when an IRQ stack
is being torn down. When this happens, handle_signal will loop, setting up
the IRQ stack again because the tearing down had finished, and handling
whatever signals had come in.
However, to_irq_stack returns a mask of pending signals to be handled, plus
bit zero is set if the IRQ stack was already active, and thus shouldn't be
torn down. This causes a problem because when handle_signal goes around
the loop, sig will be zero, and to_irq_stack will duly set bit zero in the
returned mask, faking handle_signal into believing that it shouldn't tear
down the IRQ stack and return thread_info pointers back to their original
values.
This will eventually cause a crash, as the IRQ stack thread_info will
continue pointing to the original task_struct and an interrupt will look
into it after it has been freed.
The fix is to stop passing a signal number into to_irq_stack. Rather, the
pending signals mask is initialized beforehand with the bit for sig already
set. References to sig in to_irq_stack can be replaced with references to
the mask.
[akpm@linux-foundation.org: use UL]
I found a type mismatch in UML that makes host block devices unusable as ubd
devices on x86_64 and other 64 bits systems (segfault of the mm subsystem):
In block/ioctl.c, the following lines show that the BLKGETSIZE ioctl expects
a pointer to a long:
case BLKGETSIZE:
if ((bdev->bd_inode->i_size >> 9) > ~0UL)
return -EFBIG;
return put_ulong(arg, bdev->bd_inode->i_size >> 9);
In arch/um/os-Linux/file.c, os_file_size calls it with an int.
The ioctl_list man page should be fixed as well.
Cc: Jeff Dike <jdike@addtoit.com>
Stop UML crashing when trying to dump a process core on x86_64. This is the
minimal fix to stop the crash - more things are broken here, and patches are
forthcoming.
The immediate thing to do is define ELF_CORE_COPY_REGS and
ELF_CORE_COPY_FPREGS. Defining ELF_CORE_COPY_FPREGS allows dump_fpu to go
away. It is defined in terms of save_fp_registers, so that needs to be added.
Fix a class of bugs in the UML linker scripts which caused section boundary
variables to sometimes not line up with their sections.
The previous patch which limited the number of sectors in a single request
to a COWed device was correct in concept, but the limit was implemented in
the wrong place.
By putting it in ubd_add, it covered the cases where the COWing was
specified on the command line. However, when the command line only has the
COW file specified, the fact that it's a COW file isn't known until it's
opened, so the limit is missed in these cases.
This patch moves the sector limit from ubd_add to ubd_open_dev.
Cc: <stable@kernel.org>
The previous DEBUG_SHIRQ patch missed one case. The console doesn't
set its host descriptors non-blocking.
Remove fs.h from mm.h. For this,
1) Uninline vma_wants_writenotify(). It's pretty huge anyway.
2) Add back fs.h or less bloated headers (err.h) to files that need it.
As result, on x86_64 allyesconfig, fs.h dependencies cut down from 3929 files
rebuilt down to 3444 (-12.3%).
Cross-compile tested without regressions on my two usual configs and (sigh):
alpha arm-mx1ads mips-bigsur powerpc-ebony
alpha-allnoconfig arm-neponset mips-capcella powerpc-g5
alpha-defconfig arm-netwinder mips-cobalt powerpc-holly
alpha-up arm-netx mips-db1000 powerpc-iseries
arm arm-ns9xxx mips-db1100 powerpc-linkstation
arm-assabet arm-omap_h2_1610 mips-db1200 powerpc-lite5200
arm-at91rm9200dk arm-onearm mips-db1500 powerpc-maple
arm-at91rm9200ek arm-picotux200 mips-db1550 powerpc-mpc7448_hpc2
arm-at91sam9260ek arm-pleb mips-ddb5477 powerpc-mpc8272_ads
arm-at91sam9261ek arm-pnx4008 mips-decstation powerpc-mpc8313_rdb
arm-at91sam9263ek arm-pxa255-idp mips-e55 powerpc-mpc832x_mds
arm-at91sam9rlek arm-realview mips-emma2rh powerpc-mpc832x_rdb
arm-ateb9200 arm-realview-smp mips-excite powerpc-mpc834x_itx
arm-badge4 arm-rpc mips-fulong powerpc-mpc834x_itxgp
arm-carmeva arm-s3c2410 mips-ip22 powerpc-mpc834x_mds
arm-cerfcube arm-shannon mips-ip27 powerpc-mpc836x_mds
arm-clps7500 arm-shark mips-ip32 powerpc-mpc8540_ads
arm-collie arm-simpad mips-jazz powerpc-mpc8544_ds
arm-corgi arm-spitz mips-jmr3927 powerpc-mpc8560_ads
arm-csb337 arm-trizeps4 mips-malta powerpc-mpc8568mds
arm-csb637 arm-versatile mips-mipssim powerpc-mpc85xx_cds
arm-ebsa110 i386 mips-mpc30x powerpc-mpc8641_hpcn
arm-edb7211 i386-allnoconfig mips-msp71xx powerpc-mpc866_ads
arm-em_x270 i386-defconfig mips-ocelot powerpc-mpc885_ads
arm-ep93xx i386-up mips-pb1100 powerpc-pasemi
arm-footbridge ia64 mips-pb1500 powerpc-pmac32
arm-fortunet ia64-allnoconfig mips-pb1550 powerpc-ppc64
arm-h3600 ia64-bigsur mips-pnx8550-jbs powerpc-prpmc2800
arm-h7201 ia64-defconfig mips-pnx8550-stb810 powerpc-ps3
arm-h7202 ia64-gensparse mips-qemu powerpc-pseries
arm-hackkit ia64-sim mips-rbhma4200 powerpc-up
arm-integrator ia64-sn2 mips-rbhma4500 s390
arm-iop13xx ia64-tiger mips-rm200 s390-allnoconfig
arm-iop32x ia64-up mips-sb1250-swarm s390-defconfig
arm-iop33x ia64-zx1 mips-sead s390-up
arm-ixp2000 m68k mips-tb0219 sparc
arm-ixp23xx m68k-amiga mips-tb0226 sparc-allnoconfig
arm-ixp4xx m68k-apollo mips-tb0287 sparc-defconfig
arm-jornada720 m68k-atari mips-workpad sparc-up
arm-kafa m68k-bvme6000 mips-wrppmc sparc64
arm-kb9202 m68k-hp300 mips-yosemite sparc64-allnoconfig
arm-ks8695 m68k-mac parisc sparc64-defconfig
arm-lart m68k-mvme147 parisc-allnoconfig sparc64-up
arm-lpd270 m68k-mvme16x parisc-defconfig um-x86_64
arm-lpd7a400 m68k-q40 parisc-up x86_64
arm-lpd7a404 m68k-sun3 powerpc x86_64-allnoconfig
arm-lubbock m68k-sun3x powerpc-cell x86_64-defconfig
arm-lusl7200 mips powerpc-celleb x86_64-up
arm-mainstone mips-atlas powerpc-chrp32
* 'request-queue-t' of git://git.kernel.dk/linux-2.6-block:
[BLOCK] Add request_queue_t and mark it deprecated
[BLOCK] Get rid of request_queue_t typedef
2.6.23-rc1 turned up another batch of references from non-__init code to
__init code. In most cases, these were missing __init annotations. In one
case (os_drop_memory), the annotation was present but wrong.
init_maps is __init, but for some reason was being very careful about the
mechanism by which it allocated memory, checking whether it was OK to use
kmalloc (at this point in the boot, it definitely isn't) and using either
alloc_bootmem_low_pages or kmalloc/vmalloc. So, the kmalloc/vmalloc code is
removed.
Restructure do_aio thanks to commments from Ulrich and Al.
Uli started this by seeing that UML's initialization of a struct iocb
initialized fields that it shouldn't.
Al followed up by adding the following cleanups:
eliminating a variable by just using an anonymous structure in
its place.
hoisting a duplicated line out of the switch.
simplifying the error checking at the end.
I added a severity to the printk.
Cc: Ulrich Drepper <drepper@redhat.com>
In 2.6.23-rc1, i386 fiddled its string support such that UML started getting
undefined references from modules. The UML asm/string.h was including the
i386 string.h, which defined __HAVE_ARCH_STR*, but the corresponding
implementations weren't being pulled in.
This is fixed by adding arch/i386/lib/string.h to the list of host
architecture files to be pulled in to UML.
A complication is that the libc exports file assumed that the generic strlen
and strstr weren't in use (i.e. __HAVE_ARCH_STR is defined), then they aren't
exported. This is untrue for strlen, which is exported in either case, so
this logic is not needed.
Some of the code has been gradually transitioned to using the proper
struct request_queue, but there's lots left. So do a full sweet of
the kernel and get rid of this typedef and replace its uses with
the proper type.
Change in 'kbuild: do section mismatch check on full vmlinux'
should've been replicated in arch/um/Makefile.
Currently, CONFIG_X86_CMPXCHG64 both enables boot-time checking of
the cmpxchg64b feature and enables compilation of the set_64bit() family.
Since the option is dependent on PAE, and since KVM depends on set_64bit(),
this effectively disables KVM on i386 nopae.
Simplify by removing the config option altogether: the boot check is made
dependent on CONFIG_X86_PAE directly, and the set_64bit() family is exposed
without constraints. It is up to users to check for the feature flag (KVM
does not as virtualiation extensions imply its existence).
Signed-off-by: Avi Kivity <avi@qumranet.com>
This patch completes Linus's wish that the fault return codes be made into
bit flags, which I agree makes everything nicer. This requires requires
all handle_mm_fault callers to be modified (possibly the modifications
should go further and do things like fault accounting in handle_mm_fault --
however that would be for another patch).
[akpm@linux-foundation.org: fix alpha build]
[akpm@linux-foundation.org: fix s390 build]
[akpm@linux-foundation.org: fix sparc build]
[akpm@linux-foundation.org: fix sparc64 build]
[akpm@linux-foundation.org: fix ia64 build]
Signed-off-by: Nick Piggin <npiggin@suse.de>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Ian Molton <spyro@f2s.com>
Cc: Bryan Wu <bryan.wu@analog.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Greg Ungerer <gerg@uclinux.org>
Cc: Matthew Wilcox <willy@debian.org>
Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp>
Cc: Richard Curnow <rc@rc0.org.uk>
Cc: William Lee Irwin III <wli@holomorphy.com>
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp>
Cc: Chris Zankel <chris@zankel.net>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Andi Kleen <ak@muc.de>
[ Still apparently needs some ARM and PPC loving - Linus ]
Acked-by: Jeff Dike <jdike@addtoit.com>
Identical implementations of PTRACE_POKEDATA go into generic_ptrace_pokedata()
function.
AFAICS, fix bug on xtensa where successful PTRACE_POKEDATA will nevertheless
return EPERM.
Cc: <linux-arch@vger.kernel.org>
Identical implementations of PTRACE_PEEKDATA go into generic_ptrace_peekdata()
function.
I forgot this file was here. It hasn't been used since UML has been in
mainline.
Thanks to Jesper for finding something that needed doing to it, thus reminding
me of its existence.
COWed devices can't handle more than 32 (64 on x86_64) sectors in one request
due to the size of the bitmap being carried around in the io_thread_req.
Enforce that by telling the block layer not to put too many sectors in
requests to COWed devices.
Add some exports for hostfs that are required after Alberto Bertogli's fixes
for accessing unlinked host files.
Also did some style cleanups while I was here.
UML had two wrapper procedures for kmalloc, um_kmalloc and um_kmalloc_atomic
because the flag constants weren't available in userspace code.
kern_constants.h had made kernel constants available for a long time, so there
is no need for these wrappers any more. Rather, userspace code calls kmalloc
directly with the userspace versions of the gfp flags.
kmalloc isn't a real procedure, so I had to essentially copy the inline
wrapper around __kmalloc.
vmalloc also had its own wrapper for no good reason. This is now gone.
run_helper and run_helper_thread had arguments which were the same in all
callers. run_helper's stack_out was always NULL and run_helper_thread's
stack_order was always 0. These are now gone, and the constants folded
into the code.
Also fixed leaks of the helper stack in the AIO and SIGIO code.
Cleanup of the SIGWINCH support.
Some code and comment reformatting.
The stack used for SIGWINCH threads was leaked. This is now fixed by storing
it with the pid and other information, and freeing it when the thread is
killed.
If something goes wrong with a WIGWINCH thread, and this is discovered in the
interrupt handler, the winch record would leak. It is now freed, except that
the IRQ isn't freed. This is hard to do from interrupt context. This has the
side-effect that the IRQ system maintains a reference to the freed structure,
but that shouldn't cause a problem since the descriptor is disabled.
register_winch_irq is now much better about cleaning up after an
initialization failure.
If the host side of a console can't be opened, this will now produce visible
error messages.
enable_chan now returns a status and this is passed up to con_open and
ssl_open, which will complain if anything went wrong.
The default host device for the serial line driver is now a pts device rather
than a pty device since lots of hosts have LEGACY_PTYS disabled. This had
always been failing on such hosts, but silently.
Cleanup, mostly style violations.
Tidied the includes.
getmaster returns a real errno, which pty_open returns if there's a
problem.
The printks now have severity.
Changed os_* calls to call libc directly.
Major tidying of the xterm console driver:
got rid of the tt-mode gdb support
tidied up the includes
fixed lots of style violations
replaced os_* calls with glibc calls in xterm.c
all printk calls now have a severity indicator
the error paths of xterm_open are closer to being right
DEBUG_SHIRQ generates spurious interrupts, triggering handlers such as
mconsole_interrupt() or line_interrupt(). They expect data to be available to
be read from their sockets/pipes, but in the case of spurious interrupts, the
host didn't actually send anything, so UML hangs in read() and friends.
Setting those fd's as O_NONBLOCK makes DEBUG_SHIRQ-enabled UML kernels boot
and run correctly.
Signed-off-by: Eduard-Gabriel Munteanu <maxdamage@aladin.ro>
Add generic exit-time stack-depth checking to CONFIG_DEBUG_STACK_USAGE.
This also adds UML support.
Tested on UML and i386.
[akpm@linux-foundation.org: cleanups, speedups, tweaks]
Cc: Oleg Nesterov <oleg@tv-sign.ru>
It is theoretically possible for a request to finish and be freed between
writing it to the I/O thread and updating the sector count. In this case, the
update will dereference a freed pointer.
To avoid this, I delay the update until processing the next sg segment, when
the request pointer is known to be good.
Distros seem to be removing PAGE_SIZE from asm/page.h. So, the libc side of
UML should stop using it.
I replace it with UM_KERN_PAGE_SIZE, which is defined to be the same as
PAGE_SIZE on the kernel side of the house. I could also use getpagesize(),
but it's more important that UML have the same value of PAGE_SIZE everywhere.
It's conceivable that it could be built with a larger PAGE_SIZE, and use of
getpagesize() would break that badly.
PAGE_MASK got the same treatment, as it is closely tied to PAGE_SIZE.
Include linux/kernel.h wherever simple_strtoul is used. This kills a
compile warning in stderr_console.c and potential ones in the other files.
This also fixes a bunch of style violations in exitcode.c.
Force KERNEL_STACK_ORDER to be at least 1 on UML/x86_64, to avoid overflows.
Make the PTRACE_SYSEMU checking more robust. It will make sure that system
call numbers are reported correctly. If there is a problem, it will disable
PTRACE_SYSEMU use and use PTRACE_SYSCALL instead.
Thanks to Balaji G for helping reproduce this problem.
With this consolidation we can now modify the .data
section definition in one spot for all archs.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Move definition of .text section to asm-generic.
__NR_syscall_max is done in x86_64 asm-offsets; do an equivalent in
uml kern_constants.h
Make kernel stacks be 1 page on i386 and 2 pages on x86_64. These match the
host values.
Add a separate IRQ stack. This differs from i386 in having the entire
interrupt run on a separate stack rather than starting on the normal kernel
stack and switching over once some preparation has been done. The underlying
mechanism, is of course, sigaltstack.
Another difference is that interrupts that happen in userspace are handled on
the normal kernel stack. These cause a wait wakeup instead of a signal
delivery so there is no point in trying to switch stacks for these. There's
no other stuff on the stack, so there is no extra stack consumption.
This quirk makes it possible to have the entire interrupt run on a separate
stack - process preemption (and calls to schedule()) happens on a normal
kernel stack. If we enable CONFIG_PREEMPT, this will need to be rethought.
The IRQ stack for CPU 0 is declared in the same way as the initial kernel
stack. IRQ stacks for other CPUs will be allocated dynamically.
An extra field was added to the thread_info structure. When the active
thread_info is copied to the IRQ stack, the real_thread field points back to
the original stack. This makes it easy to tell where to copy the thread_info
struct back to when the interrupt is finished. It also serves as a marker of
a nested interrupt. It is NULL for the first interrupt on the stack, and
non-NULL for any nested interrupts.
Care is taken to behave correctly if a second interrupt comes in when the
thread_info structure is being set up or taken down. I could just disable
interrupts here, but I don't feel like giving up any of the performance gained
by not flipping signals on and off.
If an interrupt comes in during these critical periods, the handler can't run
because it has no idea what shape the stack is in. So, it sets a bit for its
signal in a global mask and returns. The outer handler will deal with this
signal itself.
Atomicity is had with xchg. A nested interrupt that needs to bail out will
xchg its signal mask into pending_mask and repeat in case yet another
interrupt hit at the same time, until the mask stabilizes.
The outermost interrupt will set up the thread_info and xchg a zero into
pending_mask when it is done. At this point, nested interrupts will look at
->real_thread and see that no setup needs to be done. They can just continue
normally.
Similar care needs to be taken when exiting the outer handler. If another
interrupt comes in while it is copying the thread_info, it will drop a bit
into pending_mask. The outer handler will check this and if it is non-zero,
will loop, set up the stack again, and handle the interrupt.
Some tidying of the irq code before introducing irq stacks. Mostly
style fixes, but the timer handler calls the timer code directly
rather than going through the generic sig_handler_common_skas.
Now that we have UM_THREAD_SIZE, we can replace the calculations in
user-space code (an earlier patch took care of the kernel side of the
house).
Replaced task_protections with stack_protections since they do the same
thing, and task_protections was misnamed anyway.
This needs THREAD_SIZE, so that's imported via common-offsets.h
Also tidied up the code in the vicinity.
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (25 commits)
sound: convert "sound" subdirectory to UTF-8
MAINTAINERS: Add cxacru website/mailing list
include files: convert "include" subdirectory to UTF-8
general: convert "kernel" subdirectory to UTF-8
documentation: convert the Documentation directory to UTF-8
Convert the toplevel files CREDITS and MAINTAINERS to UTF-8.
remove broken URLs from net drivers' output
Magic number prefix consistency change to Documentation/magic-number.txt
trivial: s/i_sem /i_mutex/
fix file specification in comments
drivers/base/platform.c: fix small typo in doc
misc doc and kconfig typos
Remove obsolete fat_cvf help text
Fix occurrences of "the the "
Fix minor typoes in kernel/module.c
Kconfig: Remove reference to external mqueue library
Kconfig: A couple of grammatical fixes in arch/i386/Kconfig
Correct comments in genrtc.c to refer to correct /proc file.
Fix more "deprecated" spellos.
Fix "deprecated" typoes.
Fix trivial comment conflict in kernel/relay.c.
These haven't been fixed for ages. Just make comments out of them.
arch/um/kernel/skas/process.c:181:2: warning: #warning Need to look up
+userspace_pid by cpu
arch/um/kernel/skas/process.c:187:2: warning: #warning Need to look up
arch/um/kernel/skas/process.c:194:2: warning: #warning need to loop over
+userspace_pids in kill_off_processes_skas
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Mark another function as tt-mode only.
Enable (i)SCSI on UML, dunno why SCSI was deemed broken, it works like a
charm.
