commit 201f99f170df14ba52ea4c52847779042b7a623b upstream.
We don't cap the size of buffer from the user so we could write past the
end of the array here. Only root can write to this file.
Reported-by: Nico Golde <nico@ngolde.de>
Reported-by: Fabian Yamaguchi <fabs@goesec.de>
commit f15b9000eb1d09bbaa4b0a6b2089d7e1f64e84b3 upstream.
UML uses the _PAGE_NEWPAGE flag to mark pages which are not jet
installed on the host side using mmap().
pte_same() has to ignore this flag, otherwise unuse_pte_range()
is unable to unuse the page because two identical
page tables entries with different _PAGE_NEWPAGE flags would not
match and swapoff() would never return.
Analyzed-by: Hugh Dickins <hughd@google.com>
Signed-off-by: Richard Weinberger <richard@nod.at>
commit 2b76ebaa728f8a3967c52aa189261c72fe56a6f1 upstream.
The current __swp_type() function uses a too small bitshift.
Using more than one swap files causes bad pages because
the type bits clash with other page flags.
Fix the following gcc complain
arch/um/kernel/skas/mmu.c: In function 'uml_setup_stubs':
arch/um/kernel/skas/mmu.c:106:16: warning: unused variable 'pages' [-Wunused-variable]
Signed-Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
Reported-by: Toralf Förster <toralf.foerster@gmx.de>
CC: dhowells@redhat.com
... rather than open-coding the 64bit versions. endian.h has those guys.
while we can't just use -U$(SUBARCH), we still need to kill idiotic define
(implicit -Di386=1), both for SUBARCH=i386 and SUBARCH=x86/CONFIG_64BIT=n
builds.
This has been obsolescent for a while; time for the final push.
In adjacent context, replaced old cpus_* with cpumask_*.
Acked-by: David S. Miller <davem@davemloft.net> (arch/sparc)
Acked-by: Chris Metcalf <cmetcalf@tilera.com> (arch/tile)
Cc: user-mode-linux-devel@lists.sourceforge.net
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: linux-hexagon@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Helge Deller <deller@gmx.de>
Cc: sparclinux@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system
Pull "Disintegrate and delete asm/system.h" from David Howells:
"Here are a bunch of patches to disintegrate asm/system.h into a set of
separate bits to relieve the problem of circular inclusion
dependencies.
I've built all the working defconfigs from all the arches that I can
and made sure that they don't break.
The reason for these patches is that I recently encountered a circular
dependency problem that came about when I produced some patches to
optimise get_order() by rewriting it to use ilog2().
This uses bitops - and on the SH arch asm/bitops.h drags in
asm-generic/get_order.h by a circuituous route involving asm/system.h.
The main difficulty seems to be asm/system.h. It holds a number of
low level bits with no/few dependencies that are commonly used (eg.
memory barriers) and a number of bits with more dependencies that
aren't used in many places (eg. switch_to()).
These patches break asm/system.h up into the following core pieces:
(1) asm/barrier.h
Move memory barriers here. This already done for MIPS and Alpha.
(2) asm/switch_to.h
Move switch_to() and related stuff here.
(3) asm/exec.h
Move arch_align_stack() here. Other process execution related bits
could perhaps go here from asm/processor.h.
(4) asm/cmpxchg.h
Move xchg() and cmpxchg() here as they're full word atomic ops and
frequently used by atomic_xchg() and atomic_cmpxchg().
(5) asm/bug.h
Move die() and related bits.
(6) asm/auxvec.h
Move AT_VECTOR_SIZE_ARCH here.
Other arch headers are created as needed on a per-arch basis."
Fixed up some conflicts from other header file cleanups and moving code
around that has happened in the meantime, so David's testing is somewhat
weakened by that. We'll find out anything that got broken and fix it..
* tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits)
Delete all instances of asm/system.h
Remove all #inclusions of asm/system.h
Add #includes needed to permit the removal of asm/system.h
Move all declarations of free_initmem() to linux/mm.h
Disintegrate asm/system.h for OpenRISC
Split arch_align_stack() out from asm-generic/system.h
Split the switch_to() wrapper out of asm-generic/system.h
Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h
Create asm-generic/barrier.h
Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h
Disintegrate asm/system.h for Xtensa
Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt]
Disintegrate asm/system.h for Tile
Disintegrate asm/system.h for Sparc
Disintegrate asm/system.h for SH
Disintegrate asm/system.h for Score
Disintegrate asm/system.h for S390
Disintegrate asm/system.h for PowerPC
Disintegrate asm/system.h for PA-RISC
Disintegrate asm/system.h for MN10300
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
git://git.kernel.org/pub/scm/linux/kernel/git/rw/uml
Pull UML changes from Richard Weinberger:
"Mostly bug fixes and cleanups"
* 'for-linus-3.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/uml: (35 commits)
um: Update defconfig
um: Switch to large mcmodel on x86_64
MTD: Relax dependencies
um: Wire CONFIG_GENERIC_IO up
um: Serve io_remap_pfn_range()
Introduce CONFIG_GENERIC_IO
um: allow SUBARCH=x86
um: most of the SUBARCH uses can be killed
um: deadlock in line_write_interrupt()
um: don't bother trying to rebuild CHECKFLAGS for USER_OBJS
um: use the right ifdef around exports in user_syms.c
um: a bunch of headers can be killed by using generic-y
um: ptrace-generic.h doesn't need user.h
um: kill HOST_TASK_PID
um: remove pointless include of asm/fixmap.h from asm/pgtable.h
um: asm-offsets.h might as well come from underlying arch...
um: merge processor_{32,64}.h a bit...
um: switch close_chan() to struct line
um: race fix: initialize delayed_work *before* registering IRQ
um: line->have_irq is never checked...
Enable ext4, cgroups and devtmpfs.
x86_64 UML is unable to load modules if more than 504MiB
of memory are used.
This happens because on x86_64 the UML process has a quite high
start address (typically around 0x6000000).
If UML's memory is larger than 504MiB VMALLOC_START happens to be after
0x8000000. This is no problem unless one loads a module which was built
with R_X86_64_32S relocations.
Symbols with a location > 0x8000000 cannot be used with R_X86_64_32S
To deal with this x86_64 UML has to be compiled with -mcmodel=large
such that no R_X86_64_32S relocations are used.
Reported-by: 전하늘 <allskyee@gmail.com>
UML has no io memory but implements everything defined in
generic-asm/io.h.
At some places io_remap_pfn_range() is needed.
UML has to serve it like all other archs do.
[richard@nod.at: Re-export SUBARCH in arch/um/Makefile]
... just strip NOSTDINC_FLAGS out of it for those
... the same one that controls whether elf_aux.o is included into the
build, bringing the vsyscall_e... into it.
just provide get_current_pid() to the userland side of things
instead of get_current() + manual poking in its results
... and switch chan_interrupt() to directly calling close_one_chan(),
so we can lose delay_free_irq argument of close_chan() as well.
... since chan_interrupt() might schedule it if there's too much
incoming data. Kill task argument of chan_interrupt(), while
we are at it - it's always &line->task.
looks like a half-arsed duplicate of line->enabled
put references to in and out chans associated with line into
explicit struct chan * fields in it.
now we can do that...
move config-independent parts of initialization into
register_lines(), call setup_one_line() after it instead
of abusing ->init_str.
Current code doesn't update the symlinks in /sys/dev/char when we add/remove
tty lines. Fixing that allows to stop messing with ->valid before the driver
registration, which is a Good Thing(tm) - we shouldn't have it set before we
really have the things set up and ready for line_open().
We need tty_driver available to call tty_{un,}register_device(), so we just
stash a reference to it into struct line_driver.
Pull parse_chan_pair() call into setup_one_line(), under the mutex.
We really don't want open() to succeed before parse_chan_pair() had
been done (or after it has failed, BTW). We also want "remove con<n>"
to free irqs, etc., same as "config con<n>=none".
If two processes are opening the same line, the second to get
into line_open() will decide that it doesn't need to do anything
(correctly) or wait for anything. The latter, unfortunately,
is incorrect - the first opener might not be through yet. We
need to have exclusion covering the entire line_init(), including
the blocking parts. Moreover, the next patch will need to
widen the exclusion on mconsole side of things, also including
the blocking bits, so let's just convert that sucker to mutex...
make line_setup() act on a separate array of conf strings + default conf,
have lines array initialized explicitly by that data, bury LINE_INIT()
macro from hell.
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled],
We run all interrupt handlers with interrupts disabled
and we even check and yell when an interrupt handler
returns with interrupts enabled (see commit [b738a50a:
genirq: Warn when handler enables interrupts]).
So now this flag is a NOOP and can be removed.
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
As described in commit e6fa16ab9c1e ("signal: sigprocmask() should do
retarget_shared_pending()") the modification of current->blocked is
incorrect as we need to check whether the signal we're about to block is
pending in the shared queue.
Also, use the new helper function introduced in commit 5e6292c0f28f
("signal: add block_sigmask() for adding sigmask to current->blocked")
which centralises the code for updating current->blocked after
successfully delivering a signal and reduces the amount of duplicate
code across architectures. In the past some architectures got this code
wrong, so using this helper function should stop that from happening
again.
Acked-by: Oleg Nesterov <oleg@redhat.com>
Cc: Richard Weinberger <richard@nod.at>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
If we fail to setup the signal stack frame then we don't need to restore
current->blocked because it is not modified by setup_signal_stack_*.
Acked-by: Richard Weinberger <richard@nod.at>
Tested-by: Richard Weinberger <richard@nod.at>
Pull vfs pile 1 from Al Viro:
"This is _not_ all; in particular, Miklos' and Jan's stuff is not there
yet."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (64 commits)
ext4: initialization of ext4_li_mtx needs to be done earlier
debugfs-related mode_t whack-a-mole
hfsplus: add an ioctl to bless files
hfsplus: change finder_info to u32
hfsplus: initialise userflags
qnx4: new helper - try_extent()
qnx4: get rid of qnx4_bread/qnx4_getblk
take removal of PF_FORKNOEXEC to flush_old_exec()
trim includes in inode.c
um: uml_dup_mmap() relies on ->mmap_sem being held, but activate_mm() doesn't hold it
um: embed ->stub_pages[] into mmu_context
gadgetfs: list_for_each_safe() misuse
ocfs2: fix leaks on failure exits in module_init
ecryptfs: make register_filesystem() the last potential failure exit
ntfs: forgets to unregister sysctls on register_filesystem() failure
logfs: missing cleanup on register_filesystem() failure
jfs: mising cleanup on register_filesystem() failure
make configfs_pin_fs() return root dentry on success
configfs: configfs_create_dir() has parent dentry in dentry->d_parent
configfs: sanitize configfs_create()
Pull kmap_atomic cleanup from Cong Wang.
It's been in -next for a long time, and it gets rid of the (no longer
used) second argument to k[un]map_atomic().
Fix up a few trivial conflicts in various drivers, and do an "evil
merge" to catch some new uses that have come in since Cong's tree.
* 'kmap_atomic' of git://github.com/congwang/linux: (59 commits)
feature-removal-schedule.txt: schedule the deprecated form of kmap_atomic() for removal
highmem: kill all __kmap_atomic() [swarren@nvidia.com: highmem: Fix ARM build break due to __kmap_atomic rename]
drbd: remove the second argument of k[un]map_atomic()
zcache: remove the second argument of k[un]map_atomic()
gma500: remove the second argument of k[un]map_atomic()
dm: remove the second argument of k[un]map_atomic()
tomoyo: remove the second argument of k[un]map_atomic()
sunrpc: remove the second argument of k[un]map_atomic()
rds: remove the second argument of k[un]map_atomic()
net: remove the second argument of k[un]map_atomic()
mm: remove the second argument of k[un]map_atomic()
lib: remove the second argument of k[un]map_atomic()
power: remove the second argument of k[un]map_atomic()
kdb: remove the second argument of k[un]map_atomic()
udf: remove the second argument of k[un]map_atomic()
ubifs: remove the second argument of k[un]map_atomic()
squashfs: remove the second argument of k[un]map_atomic()
reiserfs: remove the second argument of k[un]map_atomic()
ocfs2: remove the second argument of k[un]map_atomic()
ntfs: remove the second argument of k[un]map_atomic()
doesn't hold it
... while calling uml_dup_mmap()
seriously, kmalloc() for two-element array of pointers?
Signed-off-by: Cong Wang <amwang@redhat.com>
Set addr_assign_type correctly to NET_ADDR_RANDOM in case
a random MAC address was generated and assigned to the netdevice.
Return state from setup_etheraddr() about returning a random
MAC address or not and check this state in eth_configure().
Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de>
