path: root/arch/unicore32
2018-02-22kmemcheck: stop using GFP_NOTRACK and SLAB_NOTRACKLevin, Alexander (Sasha Levin)
commit 75f296d93bcebcfe375884ddac79e30263a31766 upstream. Convert all allocations that used a NOTRACK flag to stop using it. Link: http://lkml.kernel.org/r/20171007030159.22241-3-alexander.levin@verizon.com Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Cc: Alexander Potapenko <glider@google.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Tim Hansen <devtimhansen@gmail.com> Cc: Vegard Nossum <vegardno@ifi.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-13kernel/exit.c: export abort() to modulesAndrew Morton
commit dc8635b78cd8669c37e230058d18c33af7451ab1 upstream. gcc -fisolate-erroneous-paths-dereference can generate calls to abort() from modular code too. [arnd@arndb.de: drop duplicate exports of abort()] Link: http://lkml.kernel.org/r/20180102103311.706364-1-arnd@arndb.de Reported-by: Vineet Gupta <Vineet.Gupta1@synopsys.com> Cc: Sudip Mukherjee <sudipm.mukherjee@gmail.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Alexey Brodkin <Alexey.Brodkin@synopsys.com> Cc: Russell King <rmk+kernel@armlinux.org.uk> Cc: Jose Abreu <Jose.Abreu@synopsys.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Evgeniy Didin <Evgeniy.Didin@synopsys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-29arch, mm: Allow arch_dup_mmap() to failThomas Gleixner
commit c10e83f598d08046dd1ebc8360d4bb12d802d51b upstream. In order to sanitize the LDT initialization on x86 arch_dup_mmap() must be allowed to fail. Fix up all instances. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Andy Lutomirsky <luto@kernel.org> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Borislav Petkov <bpetkov@suse.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: David Laight <David.Laight@aculab.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Eduardo Valentin <eduval@amazon.com> Cc: Greg KH <gregkh@linuxfoundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Juergen Gross <jgross@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Will Deacon <will.deacon@arm.com> Cc: aliguori@amazon.com Cc: dan.j.williams@intel.com Cc: hughd@google.com Cc: keescook@google.com Cc: kirill.shutemov@linux.intel.com Cc: linux-mm@kvack.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-02License cleanup: add SPDX license identifier to uapi header files with a licenseGreg Kroah-Hartman
Many user space API headers have licensing information, which is either incomplete, badly formatted or just a shorthand for referring to the license under which the file is supposed to be. This makes it hard for compliance tools to determine the correct license. Update these files with an SPDX license identifier. The identifier was chosen based on the license information in the file. GPL/LGPL licensed headers get the matching GPL/LGPL SPDX license identifier with the added 'WITH Linux-syscall-note' exception, which is the officially assigned exception identifier for the kernel syscall exception: NOTE! This copyright does *not* cover user programs that use kernel services by normal system calls - this is merely considered normal use of the kernel, and does *not* fall under the heading of "derived work". This exception makes it possible to include GPL headers into non GPL code, without confusing license compliance tools. Headers which have either explicit dual licensing or are just licensed under a non GPL license are updated with the corresponding SPDX identifier and the GPLv2 with syscall exception identifier. The format is: ((GPL-2.0 WITH Linux-syscall-note) OR SPDX-ID-OF-OTHER-LICENSE) SPDX license identifiers are a legally binding shorthand, which can be used instead of the full boiler plate text. The update does not remove existing license information as this has to be done on a case by case basis and the copyright holders might have to be consulted. This will happen in a separate step. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. See the previous patch in this series for the methodology of how this patch was researched. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-03unicore32/PCI: Replace pci_fixup_irqs() call with host bridge IRQ mapping hooksLorenzo Pieralisi
The pci_fixup_irqs() function allocates IRQs for all PCI devices present in a system; those PCI devices possibly belong to different PCI bus trees (and possibly rooted at different host bridges) and may well be enabled (ie probed and bound to a driver) by the time pci_fixup_irqs() is called when probing a given host bridge driver. Furthermore, current kernel code relying on pci_fixup_irqs() to assign legacy PCI IRQs to devices does not work at all for hotplugged devices in that the code carrying out the IRQ fixup is called at host bridge driver probe time, which just cannot take into account devices hotplugged after the system has booted. The introduction of map/swizzle function hooks in struct pci_host_bridge allows us to define per-bridge map/swizzle functions that can be used at device probe time in PCI core code to allocate IRQs for a given device (through pci_assign_irq()). Convert PCI host bridge initialization code to the pci_scan_root_bus_bridge() API (that allows to pass a struct pci_host_bridge with initialized map/swizzle pointers) and remove the pci_fixup_irqs() call from arch code. Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
2017-07-11unicore32: move generic-y of exported headers to uapi/asm/KbuildMasahiro Yamada
Since commit fcc8487d477a ("uapi: export all headers under uapi directories"), all (and only) headers under uapi directories are exported, but asm-generic wrappers are still exceptions. To complete de-coupling the uapi from kernel headers, move generic-y of exported headers to uapi/asm/Kbuild. With this change, "make headers_install" will just need to parse uapi/asm/Kbuild to build up exported headers. Also, move "generic-y += kprobes.h" up in order to keep the entries sorted. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-06-04signal: Remove non-uapi <asm/siginfo.h>Christoph Hellwig
By moving the kernel side __SI_* defintions right next to the userspace ones we can kill the non-uapi versions of <asm/siginfo.h> include include/asm-generic/siginfo.h and untangle the unholy mess of includes. [ tglx: Removed uapi/asm/siginfo.h from m32r, microblaze, mn10300 and score ] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Tony Luck <tony.luck@intel.com> Cc: linux-ia64@vger.kernel.org Cc: Arnd Bergmann <arnd@arndb.de> Cc: sparclinux@vger.kernel.org Cc: "David S. Miller" <davem@davemloft.net> Link: http://lkml.kernel.org/r/20170603190102.28866-6-hch@lst.de
2017-05-10Merge tag 'kbuild-uapi-v4.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild Pull Kbuild UAPI updates from Masahiro Yamada: "Improvement of headers_install by Nicolas Dichtel. It has been long since the introduction of uapi directories, but the de-coupling of exported headers has not been completed. Headers listed in header-y are exported whether they exist in uapi directories or not. His work fixes this inconsistency. All (and only) headers under uapi directories are now exported. The asm-generic wrappers are still exceptions, but this is a big step forward" * tag 'kbuild-uapi-v4.12' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: arch/include: remove empty Kbuild files uapi: export all arch specifics directories uapi: export all headers under uapi directories smc_diag.h: fix include from userland btrfs_tree.h: fix include from userland uapi: includes linux/types.h before exporting files Makefile.headersinst: remove destination-y option Makefile.headersinst: cleanup input files x86: stop exporting msr-index.h to userland nios2: put setup.h in uapi h8300: put bitsperlong.h in uapi
2017-05-10Merge tag 'kbuild-misc-v4.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild Pull misc Kbuild updates from Masahiro Yamada: - clean up builddeb script - use full path for KBUILD_IMAGE to fix rpm-pkg build - fix objdiff tool to ignore debug info * tag 'kbuild-misc-v4.12' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: builddeb: fix typo builddeb: Update a few outdated and hardcoded strings deb-pkg: Remove the KBUILD_IMAGE workaround unicore32: Use full path in KBUILD_IMAGE definition sh: Use full path in KBUILD_IMAGE definition arc: Use full path in KBUILD_IMAGE definition arm: Use full path in KBUILD_IMAGE definition arm64: Use full path in KBUILD_IMAGE definition scripts: objdiff: Ignore debug info when comparing
2017-05-11uapi: export all headers under uapi directoriesNicolas Dichtel
Regularly, when a new header is created in include/uapi/, the developer forgets to add it in the corresponding Kbuild file. This error is usually detected after the release is out. In fact, all headers under uapi directories should be exported, thus it's useless to have an exhaustive list. After this patch, the following files, which were not exported, are now exported (with make headers_install_all): asm-arc/kvm_para.h asm-arc/ucontext.h asm-blackfin/shmparam.h asm-blackfin/ucontext.h asm-c6x/shmparam.h asm-c6x/ucontext.h asm-cris/kvm_para.h asm-h8300/shmparam.h asm-h8300/ucontext.h asm-hexagon/shmparam.h asm-m32r/kvm_para.h asm-m68k/kvm_para.h asm-m68k/shmparam.h asm-metag/kvm_para.h asm-metag/shmparam.h asm-metag/ucontext.h asm-mips/hwcap.h asm-mips/reg.h asm-mips/ucontext.h asm-nios2/kvm_para.h asm-nios2/ucontext.h asm-openrisc/shmparam.h asm-parisc/kvm_para.h asm-powerpc/perf_regs.h asm-sh/kvm_para.h asm-sh/ucontext.h asm-tile/shmparam.h asm-unicore32/shmparam.h asm-unicore32/ucontext.h asm-x86/hwcap2.h asm-xtensa/kvm_para.h drm/armada_drm.h drm/etnaviv_drm.h drm/vgem_drm.h linux/aspeed-lpc-ctrl.h linux/auto_dev-ioctl.h linux/bcache.h linux/btrfs_tree.h linux/can/vxcan.h linux/cifs/cifs_mount.h linux/coresight-stm.h linux/cryptouser.h linux/fsmap.h linux/genwqe/genwqe_card.h linux/hash_info.h linux/kcm.h linux/kcov.h linux/kfd_ioctl.h linux/lightnvm.h linux/module.h linux/nbd-netlink.h linux/nilfs2_api.h linux/nilfs2_ondisk.h linux/nsfs.h linux/pr.h linux/qrtr.h linux/rpmsg.h linux/sched/types.h linux/sed-opal.h linux/smc.h linux/smc_diag.h linux/stm.h linux/switchtec_ioctl.h linux/vfio_ccw.h linux/wil6210_uapi.h rdma/bnxt_re-abi.h Note that I have removed from this list the files which are generated in every exported directories (like .install or .install.cmd). Thanks to Julien Floret <julien.floret@6wind.com> for the tip to get all subdirs with a pure makefile command. For the record, note that exported files for asm directories are a mix of files listed by: - include/uapi/asm-generic/Kbuild.asm; - arch/<arch>/include/uapi/asm/Kbuild; - arch/<arch>/include/asm/Kbuild. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> Acked-by: Russell King <rmk+kernel@armlinux.org.uk> Acked-by: Mark Salter <msalter@redhat.com> Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-05-08Merge tag 'pci-v4.12-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: - add framework for supporting PCIe devices in Endpoint mode (Kishon Vijay Abraham I) - use non-postable PCI config space mappings when possible (Lorenzo Pieralisi) - clean up and unify mmap of PCI BARs (David Woodhouse) - export and unify Function Level Reset support (Christoph Hellwig) - avoid FLR for Intel 82579 NICs (Sasha Neftin) - add pci_request_irq() and pci_free_irq() helpers (Christoph Hellwig) - short-circuit config access failures for disconnected devices (Keith Busch) - remove D3 sleep delay when possible (Adrian Hunter) - freeze PME scan before suspending devices (Lukas Wunner) - stop disabling MSI/MSI-X in pci_device_shutdown() (Prarit Bhargava) - disable boot interrupt quirk for ASUS M2N-LR (Stefan Assmann) - add arch-specific alignment control to improve device passthrough by avoiding multiple BARs in a page (Yongji Xie) - add sysfs sriov_drivers_autoprobe to control VF driver binding (Bodong Wang) - allow slots below PCI-to-PCIe "reverse bridges" (Bjorn Helgaas) - fix crashes when unbinding host controllers that don't support removal (Brian Norris) - add driver for MicroSemi Switchtec management interface (Logan Gunthorpe) - add driver for Faraday Technology FTPCI100 host bridge (Linus Walleij) - add i.MX7D support (Andrey Smirnov) - use generic MSI support for Aardvark (Thomas Petazzoni) - make Rockchip driver modular (Brian Norris) - advertise 128-byte Read Completion Boundary support for Rockchip (Shawn Lin) - advertise PCI_EXP_LNKSTA_SLC for Rockchip root port (Shawn Lin) - convert atomic_t to refcount_t in HV driver (Elena Reshetova) - add CPU IRQ affinity in HV driver (K. Y. Srinivasan) - fix PCI bus removal in HV driver (Long Li) - add support for ThunderX2 DMA alias topology (Jayachandran C) - add ThunderX pass2.x 2nd node MCFG quirk (Tomasz Nowicki) - add ITE 8893 bridge DMA alias quirk (Jarod Wilson) - restrict Cavium ACS quirk only to CN81xx/CN83xx/CN88xx devices (Manish Jaggi) * tag 'pci-v4.12-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (146 commits) PCI: Don't allow unbinding host controllers that aren't prepared ARM: DRA7: clockdomain: Change the CLKTRCTRL of CM_PCIE_CLKSTCTRL to SW_WKUP MAINTAINERS: Add PCI Endpoint maintainer Documentation: PCI: Add userguide for PCI endpoint test function tools: PCI: Add sample test script to invoke pcitest tools: PCI: Add a userspace tool to test PCI endpoint Documentation: misc-devices: Add Documentation for pci-endpoint-test driver misc: Add host side PCI driver for PCI test function device PCI: Add device IDs for DRA74x and DRA72x dt-bindings: PCI: dra7xx: Add DT bindings to enable unaligned access PCI: dwc: dra7xx: Workaround for errata id i870 dt-bindings: PCI: dra7xx: Add DT bindings for PCI dra7xx EP mode PCI: dwc: dra7xx: Add EP mode support PCI: dwc: dra7xx: Facilitate wrapper and MSI interrupts to be enabled independently dt-bindings: PCI: Add DT bindings for PCI designware EP mode PCI: dwc: designware: Add EP mode support Documentation: PCI: Add binding documentation for pci-test endpoint function ixgbe: Use pcie_flr() instead of duplicating it IB/hfi1: Use pcie_flr() instead of duplicating it PCI: imx6: Fix spelling mistake: "contol" -> "control" ...
2017-05-01Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 mm updates from Ingo Molnar: "The main x86 MM changes in this cycle were: - continued native kernel PCID support preparation patches to the TLB flushing code (Andy Lutomirski) - various fixes related to 32-bit compat syscall returning address over 4Gb in applications, launched from 64-bit binaries - motivated by C/R frameworks such as Virtuozzo. (Dmitry Safonov) - continued Intel 5-level paging enablement: in particular the conversion of x86 GUP to the generic GUP code. (Kirill A. Shutemov) - x86/mpx ABI corner case fixes/enhancements (Joerg Roedel) - ... plus misc updates, fixes and cleanups" * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (62 commits) mm, zone_device: Replace {get, put}_zone_device_page() with a single reference to fix pmem crash x86/mm: Fix flush_tlb_page() on Xen x86/mm: Make flush_tlb_mm_range() more predictable x86/mm: Remove flush_tlb() and flush_tlb_current_task() x86/vm86/32: Switch to flush_tlb_mm_range() in mark_screen_rdonly() x86/mm/64: Fix crash in remove_pagetable() Revert "x86/mm/gup: Switch GUP to the generic get_user_page_fast() implementation" x86/boot/e820: Remove a redundant self assignment x86/mm: Fix dump pagetables for 4 levels of page tables x86/mpx, selftests: Only check bounds-vs-shadow when we keep shadow x86/mpx: Correctly report do_mpx_bt_fault() failures to user-space Revert "x86/mm/numa: Remove numa_nodemask_from_meminfo()" x86/espfix: Add support for 5-level paging x86/kasan: Extend KASAN to support 5-level paging x86/mm: Add basic defines/helpers for CONFIG_X86_5LEVEL=y x86/paravirt: Add 5-level support to the paravirt code x86/mm: Define virtual memory map for 5-level paging x86/asm: Remove __VIRTUAL_MASK_SHIFT==47 assert x86/boot: Detect 5-level paging support x86/mm/numa: Remove numa_nodemask_from_meminfo() ...
2017-05-01Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer updates from Thomas Gleixner: "The timer departement delivers: - more year 2038 rework - a massive rework of the arm achitected timer - preparatory patches to allow NTP correction of clock event devices to avoid early expiry - the usual pile of fixes and enhancements all over the place" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (91 commits) timer/sysclt: Restrict timer migration sysctl values to 0 and 1 arm64/arch_timer: Mark errata handlers as __maybe_unused Clocksource/mips-gic: Remove redundant non devicetree init MIPS/Malta: Probe gic-timer via devicetree clocksource: Use GENMASK_ULL in definition of CLOCKSOURCE_MASK acpi/arm64: Add SBSA Generic Watchdog support in GTDT driver clocksource: arm_arch_timer: add GTDT support for memory-mapped timer acpi/arm64: Add memory-mapped timer support in GTDT driver clocksource: arm_arch_timer: simplify ACPI support code. acpi/arm64: Add GTDT table parse driver clocksource: arm_arch_timer: split MMIO timer probing. clocksource: arm_arch_timer: add structs to describe MMIO timer clocksource: arm_arch_timer: move arch_timer_needs_of_probing into DT init call clocksource: arm_arch_timer: refactor arch_timer_needs_probing clocksource: arm_arch_timer: split dt-only rate handling x86/uv/time: Set ->min_delta_ticks and ->max_delta_ticks unicore32/time: Set ->min_delta_ticks and ->max_delta_ticks um/time: Set ->min_delta_ticks and ->max_delta_ticks tile/time: Set ->min_delta_ticks and ->max_delta_ticks score/time: Set ->min_delta_ticks and ->max_delta_ticks ...
2017-04-26CONFIG_ARCH_HAS_RAW_COPY_USER is unconditional nowAl Viro
all architectures converted Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-04-26Merge branches 'uaccess.alpha', 'uaccess.arc', 'uaccess.arm', ↵Al Viro
'uaccess.arm64', 'uaccess.avr32', 'uaccess.bfin', 'uaccess.c6x', 'uaccess.cris', 'uaccess.frv', 'uaccess.h8300', 'uaccess.hexagon', 'uaccess.ia64', 'uaccess.m32r', 'uaccess.m68k', 'uaccess.metag', 'uaccess.microblaze', 'uaccess.mips', 'uaccess.mn10300', 'uaccess.nios2', 'uaccess.openrisc', 'uaccess.parisc', 'uaccess.powerpc', 'uaccess.s390', 'uaccess.score', 'uaccess.sh', 'uaccess.sparc', 'uaccess.tile', 'uaccess.um', 'uaccess.unicore32', 'uaccess.x86' and 'uaccess.xtensa' into work.uaccess
2017-04-20unicore32/PCI: Use generic pci_mmap_resource_range()David Woodhouse
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2017-04-20PCI: Add BAR index argument to pci_mmap_page_range()David Woodhouse
In all cases we know which BAR it is. Passing it in means that arch code (or generic code; watch this space) won't have to go looking for it again. Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2017-04-18PCI: Move multiple declarations of pci_mmap_page_range() to <linux/pci.h>David Woodhouse
We can declare it <linux/pci.h> even on platforms where it isn't going to be defined. There's no need to have it littered through the various <asm/pci.h> files. Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2017-04-14unicore32/time: Set ->min_delta_ticks and ->max_delta_ticksNicolai Stange
In preparation for making the clockevents core NTP correction aware, all clockevent device drivers must set ->min_delta_ticks and ->max_delta_ticks rather than ->min_delta_ns and ->max_delta_ns: a clockevent device's rate is going to change dynamically and thus, the ratio of ns to ticks ceases to stay invariant. Make the unicore32 arch's clockevent driver initialize these fields properly. This patch alone doesn't introduce any change in functionality as the clockevents core still looks exclusively at the (untouched) ->min_delta_ns and ->max_delta_ns. As soon as this has changed, a followup patch will purge the initialization of ->min_delta_ns and ->max_delta_ns from this driver. Cc: Ingo Molnar <mingo@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Stephen Boyd <sboyd@codeaurora.org> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Signed-off-by: Nicolai Stange <nicstange@gmail.com> Signed-off-by: John Stultz <john.stultz@linaro.org>
2017-04-02Merge branch 'parisc-4.11-3' of ↵Al Viro
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux into uaccess.parisc
2017-03-28unicore32: get rid of zeroing and switch to RAW_COPY_USERAl Viro
2017-03-28asm-generic/uaccess.h: don't mess with __copy_{to,from}_userAl Viro
only h8300 actually used those; might as well define them there. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-03-28new helper: uaccess_kernel()Al Viro
2017-03-27add asm-generic/extable.hAl Viro
... and make the users of generic uaccess.h use that. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-03-20unicore32: Use full path in KBUILD_IMAGE definitionMichal Marek
The KBUILD_IMAGE variable is used by the rpm and deb-pkg targets, which expect it to point to the image file in the build directory. The builddeb script has a workaround for architectures which only provide the basename, but let's provide a clean interface for packaging tools. Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Signed-off-by: Michal Marek <mmarek@suse.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-03-18mm/gup: Drop the arch_pte_access_permitted() MMU callbackKirill A. Shutemov
The only arch that defines it to something meaningful is x86. But x86 doesn't use the generic GUP_fast() implementation -- the only place where the callback is called. Let's drop it. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Aneesh Kumar K . V <aneesh.kumar@linux.vnet.ibm.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Dann Frazier <dann.frazier@canonical.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Steve Capper <steve.capper@linaro.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/20170316152655.37789-2-kirill.shutemov@linux.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-03-09arch, mm: convert all architectures to use 5level-fixup.hKirill A. Shutemov
If an architecture uses 4level-fixup.h we don't need to do anything as it includes 5level-fixup.h. If an architecture uses pgtable-nop*d.h, define __ARCH_USE_5LEVEL_HACK before inclusion of the header. It makes asm-generic code to use 5level-fixup.h. If an architecture has 4-level paging or folds levels on its own, include 5level-fixup.h directly. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-03-05uaccess: drop duplicate includes from asm/uaccess.hAl Viro
2017-03-02sched/headers: Prepare for new header dependencies before moving code to ↵Ingo Molnar
<linux/sched/task_stack.h> We are going to split <linux/sched/task_stack.h> out of <linux/sched.h>, which will have to be picked up from other headers and a couple of .c files. Create a trivial placeholder <linux/sched/task_stack.h> file that just maps to <linux/sched.h> to make this patch obviously correct and bisectable. Include the new header in the files that are going to need it. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
<linux/sched/task.h> We are going to split <linux/sched/task.h> out of <linux/sched.h>, which will have to be picked up from other headers and a couple of .c files. Create a trivial placeholder <linux/sched/task.h> file that just maps to <linux/sched.h> to make this patch obviously correct and bisectable. Include the new header in the files that are going to need it. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
<linux/sched/debug.h> We are going to split <linux/sched/debug.h> out of <linux/sched.h>, which will have to be picked up from other headers and a couple of .c files. Create a trivial placeholder <linux/sched/debug.h> file that just maps to <linux/sched.h> to make this patch obviously correct and bisectable. Include the new header in the files that are going to need it. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
<linux/sched/signal.h> We are going to split <linux/sched/signal.h> out of <linux/sched.h>, which will have to be picked up from other headers and a couple of .c files. Create a trivial placeholder <linux/sched/signal.h> file that just maps to <linux/sched.h> to make this patch obviously correct and bisectable. Include the new header in the files that are going to need it. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-02-27kprobes: move kprobe declarations to asm-generic/kprobes.hLuis R. Rodriguez
Often all is needed is these small helpers, instead of compiler.h or a full kprobes.h. This is important for asm helpers, in fact even some asm/kprobes.h make use of these helpers... instead just keep a generic asm file with helpers useful for asm code with the least amount of clutter as possible. Likewise we need now to also address what to do about this file for both when architectures have CONFIG_HAVE_KPROBES, and when they do not. Then for when architectures have CONFIG_HAVE_KPROBES but have disabled CONFIG_KPROBES. Right now most asm/kprobes.h do not have guards against CONFIG_KPROBES, this means most architecture code cannot include asm/kprobes.h safely. Correct this and add guards for architectures missing them. Additionally provide architectures that not have kprobes support with the default asm-generic solution. This lets us force asm/kprobes.h on the header include/linux/kprobes.h always, but most importantly we can now safely include just asm/kprobes.h on architecture code without bringing the full kitchen sink of header files. Two architectures already provided a guard against CONFIG_KPROBES on its kprobes.h: sh, arch. The rest of the architectures needed gaurds added. We avoid including any not-needed headers on asm/kprobes.h unless kprobes have been enabled. In a subsequent atomic change we can try now to remove compiler.h from include/linux/kprobes.h. During this sweep I've also identified a few architectures defining a common macro needed for both kprobes and ftrace, that of the definition of the breakput instruction up. Some refer to this as BREAKPOINT_INSTRUCTION. This must be kept outside of the #ifdef CONFIG_KPROBES guard. [mcgrof@kernel.org: fix arm64 build] Link: http://lkml.kernel.org/r/CAB=NE6X1WMByuARS4mZ1g9+W=LuVBnMDnh_5zyN0CLADaVh=Jw@mail.gmail.com [sfr@canb.auug.org.au: fixup for kprobes declarations moving] Link: http://lkml.kernel.org/r/20170214165933.13ebd4f4@canb.auug.org.au Link: http://lkml.kernel.org/r/20170203233139.32682-1-mcgrof@kernel.org Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Masami Hiramatsu <mhiramat@kernel.org> Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-25Merge tag 'for-next-dma_ops' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull rdma DMA mapping updates from Doug Ledford: "Drop IB DMA mapping code and use core DMA code instead. Bart Van Assche noted that the ib DMA mapping code was significantly similar enough to the core DMA mapping code that with a few changes it was possible to remove the IB DMA mapping code entirely and switch the RDMA stack to use the core DMA mapping code. This resulted in a nice set of cleanups, but touched the entire tree and has been kept separate for that reason." * tag 'for-next-dma_ops' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (37 commits) IB/rxe, IB/rdmavt: Use dma_virt_ops instead of duplicating it IB/core: Remove ib_device.dma_device nvme-rdma: Switch from dma_device to dev.parent RDS: net: Switch from dma_device to dev.parent IB/srpt: Modify a debug statement IB/srp: Switch from dma_device to dev.parent IB/iser: Switch from dma_device to dev.parent IB/IPoIB: Switch from dma_device to dev.parent IB/rxe: Switch from dma_device to dev.parent IB/vmw_pvrdma: Switch from dma_device to dev.parent IB/usnic: Switch from dma_device to dev.parent IB/qib: Switch from dma_device to dev.parent IB/qedr: Switch from dma_device to dev.parent IB/ocrdma: Switch from dma_device to dev.parent IB/nes: Remove a superfluous assignment statement IB/mthca: Switch from dma_device to dev.parent IB/mlx5: Switch from dma_device to dev.parent IB/mlx4: Switch from dma_device to dev.parent IB/i40iw: Remove a superfluous assignment statement IB/hns: Switch from dma_device to dev.parent ...
2017-02-22arch, mm: remove arch specific show_memMichal Hocko
We have a generic implementation for quite some time already. If there is any arch specific information to be printed then we should add a callback called from the generic code rather than duplicate the whole show_mem. The current code has resulted in the code duplication and the output divergence which is both confusing and adds maintainance costs. Let's just get rid of this mess. Link: http://lkml.kernel.org/r/20170117091543.25850-4-mhocko@kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> [UniCore32] Acked-by: Helge Deller <deller@gmx.de> [for parisc] Acked-by: Chris Metcalf <cmetcalf@mellanox.com> [for tile] Acked-by: Mel Gorman <mgorman@suse.de> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-21Merge tag 'extable-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull exception table module split from Paul Gortmaker: "Final extable.h related changes. This completes the separation of exception table content from the module.h header file. This is achieved with the final commit that removes the one line back compatible change that sourced extable.h into the module.h file. The commits are unchanged since January, with the exception of a couple Acks that came in for the last two commits a bit later. The changes have been in linux-next for quite some time[1] and have got widespread arch coverage via toolchains I have and also from additional ones the kbuild bot has. Maintaners of the various arch were Cc'd during the postings to lkml[2] and informed that the intention was to take the remaining arch specific changes and lump them together with the final two non-arch specific changes and submit for this merge window. The ia64 diffstat stands out and probably warrants a mention. In an earlier review, Al Viro made a valid comment that the original header separation of content left something to be desired, and that it get fixed as a part of this change, hence the larger diffstat" * tag 'extable-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (21 commits) module.h: remove extable.h include now users have migrated core: migrate exception table users off module.h and onto extable.h cris: migrate exception table users off module.h and onto extable.h hexagon: migrate exception table users off module.h and onto extable.h microblaze: migrate exception table users off module.h and onto extable.h unicore32: migrate exception table users off module.h and onto extable.h score: migrate exception table users off module.h and onto extable.h metag: migrate exception table users off module.h and onto extable.h arc: migrate exception table users off module.h and onto extable.h nios2: migrate exception table users off module.h and onto extable.h sparc: migrate exception table users onto extable.h openrisc: migrate exception table users off module.h and onto extable.h frv: migrate exception table users off module.h and onto extable.h sh: migrate exception table users off module.h and onto extable.h xtensa: migrate exception table users off module.h and onto extable.h mn10300: migrate exception table users off module.h and onto extable.h alpha: migrate exception table users off module.h and onto extable.h arm: migrate exception table users off module.h and onto extable.h m32r: migrate exception table users off module.h and onto extable.h ia64: ensure exception table search users include extable.h ...
2017-02-01sched/cputime: Remove generic asm headersFrederic Weisbecker
cputime_t is now only used by two architectures: * powerpc (when CONFIG_VIRT_CPU_ACCOUNTING_NATIVE=y) * s390 And since the core doesn't use it anymore, we don't need any arch support from the others. So we can remove their stub implementations. A final cleanup would be to provide an efficient pure arch implementation of cputime_to_nsec() for s390 and powerpc and finally remove include/linux/cputime.h . Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Stanislaw Gruszka <sgruszka@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Wanpeng Li <wanpeng.li@hotmail.com> Link: http://lkml.kernel.org/r/1485832191-26889-36-git-send-email-fweisbec@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-01-26unicore32: migrate exception table users off module.h and onto extable.hPaul Gortmaker
This file was only including module.h for exception table related functions. We've now separated that content out into its own file "extable.h" so now move over to that and avoid all the extra header content in module.h that we don't really need to compile this file. Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2017-01-24treewide: Consolidate get_dma_ops() implementationsBart Van Assche
Introduce a new architecture-specific get_arch_dma_ops() function that takes a struct bus_type * argument. Add get_dma_ops() in <linux/dma-mapping.h>. Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Juergen Gross <jgross@suse.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: linux-arch@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: Russell King <linux@armlinux.org.uk> Cc: x86@kernel.org Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-01-24treewide: Constify most dma_map_ops structuresBart Van Assche
Most dma_map_ops structures are never modified. Constify these structures such that these can be write-protected. This patch has been generated as follows: git grep -l 'struct dma_map_ops' | xargs -d\\n sed -i \ -e 's/struct dma_map_ops/const struct dma_map_ops/g' \ -e 's/const struct dma_map_ops {/struct dma_map_ops {/g' \ -e 's/^const struct dma_map_ops;$/struct dma_map_ops;/' \ -e 's/const const struct dma_map_ops /const struct dma_map_ops /g'; sed -i -e 's/const \(struct dma_map_ops intel_dma_ops\)/\1/' \ $(git grep -l 'struct dma_map_ops intel_dma_ops'); sed -i -e 's/const \(struct dma_map_ops dma_iommu_ops\)/\1/' \ $(git grep -l 'struct dma_map_ops' | grep ^arch/powerpc); sed -i -e '/^struct vmd_dev {$/,/^};$/ s/const \(struct dma_map_ops[[:blank:]]dma_ops;\)/\1/' \ -e '/^static void vmd_setup_dma_ops/,/^}$/ s/const \(struct dma_map_ops \*dest\)/\1/' \ -e 's/const \(struct dma_map_ops \*dest = \&vmd->dma_ops\)/\1/' \ drivers/pci/host/*.c sed -i -e '/^void __init pci_iommu_alloc(void)$/,/^}$/ s/dma_ops->/intel_dma_ops./' arch/ia64/kernel/pci-dma.c sed -i -e 's/static const struct dma_map_ops sn_dma_ops/static struct dma_map_ops sn_dma_ops/' arch/ia64/sn/pci/pci_dma.c sed -i -e 's/(const struct dma_map_ops \*)//' drivers/misc/mic/bus/vop_bus.c Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Juergen Gross <jgross@suse.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: linux-arch@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: Russell King <linux@armlinux.org.uk> Cc: x86@kernel.org Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-12-25clocksource: Use a plain u64 instead of cycle_tThomas Gleixner
There is no point in having an extra type for extra confusion. u64 is unambiguous. Conversion was done with the following coccinelle script: @rem@ @@ -typedef u64 cycle_t; @fix@ typedef cycle_t; @@ -cycle_t +u64 Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: John Stultz <john.stultz@linaro.org>
2016-11-17locking/core: Provide common cpu_relax_yield() definitionChristian Borntraeger
No need to duplicate the same define everywhere. Since the only user is stop-machine and the only provider is s390, we can use a default implementation of cpu_relax_yield() in sched.h. Suggested-by: Russell King <rmk+kernel@armlinux.org.uk> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Reviewed-by: David Hildenbrand <david@redhat.com> Acked-by: Russell King <rmk+kernel@armlinux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Nicholas Piggin <npiggin@gmail.com> Cc: Noam Camus <noamc@ezchip.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Will Deacon <will.deacon@arm.com> Cc: kvm@vger.kernel.org Cc: linux-arch@vger.kernel.org Cc: linux-s390 <linux-s390@vger.kernel.org> Cc: linuxppc-dev@lists.ozlabs.org Cc: sparclinux@vger.kernel.org Cc: virtualization@lists.linux-foundation.org Cc: xen-devel@lists.xenproject.org Link: http://lkml.kernel.org/r/1479298985-191589-1-git-send-email-borntraeger@de.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-11-16locking/core, arch: Remove cpu_relax_lowlatency()Christian Borntraeger
As there are no users left, we can remove cpu_relax_lowlatency() implementations from every architecture. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Nicholas Piggin <npiggin@gmail.com> Cc: Noam Camus <noamc@ezchip.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Will Deacon <will.deacon@arm.com> Cc: linuxppc-dev@lists.ozlabs.org Cc: virtualization@lists.linux-foundation.org Cc: xen-devel@lists.xenproject.org Cc: <linux-arch@vger.kernel.org> Link: http://lkml.kernel.org/r/1477386195-32736-6-git-send-email-borntraeger@de.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-11-16locking/core: Introduce cpu_relax_yield()Christian Borntraeger
For spinning loops people do often use barrier() or cpu_relax(). For most architectures cpu_relax and barrier are the same, but on some architectures cpu_relax can add some latency. For example on power,sparc64 and arc, cpu_relax can shift the CPU towards other hardware threads in an SMT environment. On s390 cpu_relax does even more, it uses an hypercall to the hypervisor to give up the timeslice. In contrast to the SMT yielding this can result in larger latencies. In some places this latency is unwanted, so another variant "cpu_relax_lowlatency" was introduced. Before this is used in more and more places, lets revert the logic and provide a cpu_relax_yield that can be called in places where yielding is more important than latency. By default this is the same as cpu_relax on all architectures. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Nicholas Piggin <npiggin@gmail.com> Cc: Noam Camus <noamc@ezchip.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Will Deacon <will.deacon@arm.com> Cc: linuxppc-dev@lists.ozlabs.org Cc: virtualization@lists.linux-foundation.org Cc: xen-devel@lists.xenproject.org Link: http://lkml.kernel.org/r/1477386195-32736-2-git-send-email-borntraeger@de.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-25locking/mutex: Kill arch specific codePeter Zijlstra
Its all generic atomic_long_t stuff now. Tested-by: Jason Low <jason.low2@hpe.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-11unicore32: use simpler API for random address requestsJason Cooper
Currently, all callers to randomize_range() set the length to 0 and calculate end by adding a constant to the start address. We can simplify the API to remove a bunch of needless checks and variables. Use the new randomize_addr(start, range) call to set the requested address. Link: http://lkml.kernel.org/r/20160803233913.32511-7-jason@lakedaemon.net Signed-off-by: Jason Cooper <jason@lakedaemon.net> Acked-by: Kees Cook <keescook@chromium.org> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-07nmi_backtrace: generate one-line reports for idle cpusChris Metcalf
When doing an nmi backtrace of many cores, most of which are idle, the output is a little overwhelming and very uninformative. Suppress messages for cpus that are idling when they are interrupted and just emit one line, "NMI backtrace for N skipped: idling at pc 0xNNN". We do this by grouping all the cpuidle code together into a new .cpuidle.text section, and then checking the address of the interrupted PC to see if it lies within that section. This commit suitably tags x86 and tile idle routines, and only adds in the minimal framework for other architectures. Link: http://lkml.kernel.org/r/1472487169-14923-5-git-send-email-cmetcalf@mellanox.com Signed-off-by: Chris Metcalf <cmetcalf@mellanox.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Tested-by: Peter Zijlstra (Intel) <peterz@infradead.org> Tested-by: Daniel Thompson <daniel.thompson@linaro.org> [arm] Tested-by: Petr Mladek <pmladek@suse.com> Cc: Aaron Tomlin <atomlin@redhat.com> Cc: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Cc: Russell King <linux@arm.linux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-13unicore32: mm: Add missing parameter to arch_vma_access_permittedGuenter Roeck
unicore32 fails to compile with the following errors. mm/memory.c: In function ‘__handle_mm_fault’: mm/memory.c:3381: error: too many arguments to function ‘arch_vma_access_permitted’ mm/gup.c: In function ‘check_vma_flags’: mm/gup.c:456: error: too many arguments to function ‘arch_vma_access_permitted’ mm/gup.c: In function ‘vma_permits_fault’: mm/gup.c:640: error: too many arguments to function ‘arch_vma_access_permitted’ Fixes: d61172b4b695b ("mm/core, x86/mm/pkeys: Differentiate instruction fetches") Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
2016-08-04dma-mapping: use unsigned long for dma_attrsKrzysztof Kozlowski
The dma-mapping core and the implementations do not change the DMA attributes passed by pointer. Thus the pointer can point to const data. However the attributes do not have to be a bitfield. Instead unsigned long will do fine: 1. This is just simpler. Both in terms of reading the code and setting attributes. Instead of initializing local attributes on the stack and passing pointer to it to dma_set_attr(), just set the bits. 2. It brings safeness and checking for const correctness because the attributes are passed by value. Semantic patches for this change (at least most of them): virtual patch virtual context @r@ identifier f, attrs; @@ f(..., - struct dma_attrs *attrs + unsigned long attrs , ...) { ... } @@ identifier r.f; @@ f(..., - NULL + 0 ) and // Options: --all-includes virtual patch virtual context @r@ identifier f, attrs; type t; @@ t f(..., struct dma_attrs *attrs); @@ identifier r.f; @@ f(..., - NULL + 0 ) Link: http://lkml.kernel.org/r/1468399300-5399-2-git-send-email-k.kozlowski@samsung.com Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Robin Murphy <robin.murphy@arm.com> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> Acked-by: Mark Salter <msalter@redhat.com> [c6x] Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> [cris] Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> [drm] Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Acked-by: Joerg Roedel <jroedel@suse.de> [iommu] Acked-by: Fabien Dessenne <fabien.dessenne@st.com> [bdisp] Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> [vb2-core] Acked-by: David Vrabel <david.vrabel@citrix.com> [xen] Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [xen swiotlb] Acked-by: Joerg Roedel <jroedel@suse.de> [iommu] Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon] Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k] Acked-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> [s390] Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> [avr32] Acked-by: Vineet Gupta <vgupta@synopsys.com> [arc] Acked-by: Robin Murphy <robin.murphy@arm.com> [arm64 and dma-iommu] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
