This patch implements interrupts and gpio handling.
UniCore32 has 9 gpio interrupt sources.
And gpio device operations are also here.
Signed-off-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
This patch implements timer and time.
RTC and PWM device drivers are also here.
This patch implements consistent device DMA handling of memory management.
DMA device operations are also here.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
This patch implements fault handling of memory management.
This patch includes generic codes for memory management.
This patch implements process/thread related codes. Backtrace and stacktrace are here.
This patch implements low level entry and setup codes.
This patch includes processor and system headers. System call interface is here.
We used the syscall interface the same as asm-generic version.
This patch includes some generic stuff including elf and ksyms.
Because all one-line asm-generic headers are auto-generated by ASM_GENERIC_HEADERS
in arch/unicore32/Makefile, so the rest seems very little.
ELF handling functions and module handling functions are also here.
This patch implements build infrastructure.
