path: root/arch/x86/Kconfig.cpu
2015-10-21x86/Kconfig/cpus: Fix/complete CPU type help textsBorislav Petkov
Move the generic help text explaining each CPU type and what to select under the "Processor Family" prompt and not under the M486 option. Also, amend it with the missing options. Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1445244077-25120-1-git-send-email-bp@alien8.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-04-02Merge branch 'x86-nuke-platforms-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 old platform removal from Peter Anvin: "This patchset removes support for several completely obsolete platforms, where the maintainers either have completely vanished or acked the removal. For some of them it is questionable if there even exists functional specimens of the hardware" Geert Uytterhoeven apparently thought this was a April Fool's pull request ;) * 'x86-nuke-platforms-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, platforms: Remove NUMAQ x86, platforms: Remove SGI Visual Workstation x86, apic: Remove support for IBM Summit/EXA chipset x86, apic: Remove support for ia32-based Unisys ES7000
2014-03-11x86: Remove CONFIG_X86_OOSTOREDave Jones
This was an optimization that made memcpy type benchmarks a little faster on ancient (Circa 1998) IDT Winchip CPUs. In real-life workloads, it wasn't even noticable, and I doubt anyone is running benchmarks on 16 year old silicon any more. Given this code has likely seen very little use over the last decade, let's just remove it. Signed-off-by: Dave Jones <davej@fedoraproject.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-27x86, platforms: Remove NUMAQH. Peter Anvin
The NUMAQ support seems to be unmaintained, remove it. Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: David Rientjes <rientjes@google.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/r/n/530CFD6C.7040705@zytor.com
2012-11-29x86, 386 removal: Document Nx586 as a 386 and thus unsupportedH. Peter Anvin
Per Alan Cox, Nx586 did not support WP in supervisor mode, making it a 386 by Linux kernel standards. As such, it is too unsupported now. Reported-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Link: http://lkml.kernel.org/r/20121128205203.05868eab@pyramind.ukuu.org.uk Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2012-11-29x86, 386 removal: Remove CONFIG_X86_POPAD_OKH. Peter Anvin
The check_popad() routine tested for a 386-specific bug, and never actually did anything useful with it anyway other than print a message. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/r/1354132230-21854-8-git-send-email-hpa@linux.intel.com
2012-11-29x86, 386 removal: Remove CONFIG_X86_WP_WORKS_OKH. Peter Anvin
All 486+ CPUs support WP in supervisor mode, so remove the fallback 386 support code. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/r/1354132230-21854-7-git-send-email-hpa@linux.intel.com
2012-11-29x86, 386 removal: Remove CONFIG_INVLPGH. Peter Anvin
All 486+ CPUs support INVLPG, so remove the fallback 386 support code. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/r/1354132230-21854-6-git-send-email-hpa@linux.intel.com
2012-11-29x86, 386 removal: Remove CONFIG_BSWAPH. Peter Anvin
All 486+ CPUs support BSWAP, so remove the fallback 386 support code. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/r/1354132230-21854-5-git-send-email-hpa@linux.intel.com
2012-11-29x86, 386 removal: Remove CONFIG_XADDH. Peter Anvin
All 486+ CPUs support XADD, so remove the fallback 386 support code. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/r/1354132230-21854-4-git-send-email-hpa@linux.intel.com
2012-11-29x86, 386 removal: Remove CONFIG_CMPXCHGH. Peter Anvin
All 486+ CPUs support CMPXCHG, so remove the fallback 386 support code. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/r/1354132230-21854-3-git-send-email-hpa@linux.intel.com
2012-11-29x86, 386 removal: Remove CONFIG_M386 from KconfigH. Peter Anvin
Remove the CONFIG_M386 symbol from Kconfig so that it cannot be selected. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/r/1354132230-21854-2-git-send-email-hpa@linux.intel.com
2012-09-13x86/Kconfig: Clean up Kconfig defaultsJan Beulich
The main goal here is to have the resulting .config no carry any options that aren't enabled and can't be (i.e such where the default is "no" and can't be changed), so that if any such option later gets a user visible prompt, the user will actually be prompted on a "make ...oldconfig" rather than keeping the previously invisible option disabled. There's a little bit of other trivial cleanup mixed in here. Signed-off-by: Jan Beulich <jbeulich@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/504DEE19020000780009A285@nat28.tlf.novell.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-03-08x86: Tighten dependencies of CPU_SUP_*_32Jan Beulich
Building in support for either of these CPUs is pointless when e.g. M686 was selected (since such a kernel would use cmov instructions, which aren't available on these older CPUs). Signed-off-by: Jan Beulich <jbeulich@suse.com> Link: http://lkml.kernel.org/r/4F58875A02000078000770E0@nat28.tlf.novell.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-05x86/numa: Improve internode cache alignmentAlex Shi
Currently cache alignment among nodes in the kernel is still 128 bytes on x86 NUMA machines - we got that X86_INTERNODE_CACHE_SHIFT default from old P4 processors. But now most modern x86 CPUs use the same size: 64 bytes from L1 to last level L3. so let's remove the incorrect setting, and directly use the L1 cache size to do SMP cache line alignment. This patch saves some memory space on kernel data, and it also improves the cache locality of kernel data. The System.map is quite different with/without this change: before patch after patch ... 000000000000b000 d tlb_vector_| 000000000000b000 d tlb_vector 000000000000b080 d cpu_loops_p| 000000000000b040 d cpu_loops_ ... Signed-off-by: Alex Shi <alex.shi@intel.com> Cc: asit.k.mallick@intel.com Link: http://lkml.kernel.org/r/1330774047-18597-1-git-send-email-alex.shi@intel.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-01-12mm,x86,um: move CMPXCHG_DOUBLE config optionHeiko Carstens
Move CMPXCHG_DOUBLE and rename it to HAVE_CMPXCHG_DOUBLE so architectures can simply select the option if it is supported. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm,x86,um: move CMPXCHG_LOCAL config optionHeiko Carstens
Move CMPXCHG_LOCAL and rename it to HAVE_CMPXCHG_LOCAL so architectures can simply select the option if it is supported. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-25x86: Add support for cmpxchg_doubleChristoph Lameter
A simple implementation that only supports the word size and does not have a fallback mode (would require a spinlock). Add 32 and 64 bit support for cmpxchg_double. cmpxchg double uses the cmpxchg8b or cmpxchg16b instruction on x86 processors to compare and swap 2 machine words. This allows lockless algorithms to move more context information through critical sections. Set a flag CONFIG_CMPXCHG_DOUBLE to signal that support for double word cmpxchg detection has been build into the kernel. Note that each subsystem using cmpxchg_double has to implement a fall back mechanism as long as we offer support for processors that do not implement cmpxchg_double. Reviewed-by: H. Peter Anvin <hpa@zytor.com> Cc: Tejun Heo <tj@kernel.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Christoph Lameter <cl@linux.com> Link: http://lkml.kernel.org/r/20110601172614.173427964@linux.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2011-04-08x86, cpu: Move AMD Elan Kconfig under "Processor family"Ian Campbell
Currently the option resides under X86_EXTENDED_PLATFORM due to historical nonstandard A20M# handling. However that is no longer the case and so Elan can be treated as part of the standard processor choice Kconfig option. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Link: http://lkml.kernel.org/r/1302245177.31620.47.camel@localhost.localdomain Cc: H. Peter Anvin <hpa@zytor.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-03-18x86: Fix common misspellingsLucas De Marchi
They were generated by 'codespell' and then manually reviewed. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Cc: trivial@kernel.org LKML-Reference: <1300389856-1099-3-git-send-email-lucas.demarchi@profusion.mobi> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-18Merge branch 'linus' into x86/urgentIngo Molnar
Merge reason: Merge upstream commits to avoid conflicts in upcoming patches. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-17x86: Use PentiumPro-optimized partial_csum() on VIA C7Jon Nettleton
Testing on the OLPC XO-1.5 (VIA C7-M 1000MHz CPU) shows a partial_csum() speed increase by a factor of 1.5 when we switch to the Pentium-optimized version. Signed-off-by: Daniel Drake <dsd@laptop.org> Cc: dilinger@queued.net Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-09x86: Remove dead config option X86_CPUJan Beulich
This isn't being referenced anywhere, and the selects done from it can be easily done together with all the other X86 ones. v2: Also adjust UML's Kconfig.x86. Signed-off-by: Jan Beulich <jbeulich@novell.com> LKML-Reference: <4D7603DA02000078000351C1@vpn.id2.novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-18x86: this_cpu_cmpxchg and this_cpu_xchg operationsChristoph Lameter
Provide support as far as the hardware capabilities of the x86 cpus allow. Define CONFIG_CMPXCHG_LOCAL in Kconfig.cpu to allow core code to test for fast cpuops implementations. V1->V2: - Take out the definition for this_cpu_cmpxchg_8 and move it into a separate patch. tj: - Reordered ops to better follow this_cpu_* organization. - Renamed macro temp variables similar to their existing neighbours. Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-05-18Merge branch 'x86-fpu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, fpu: Use static_cpu_has() to implement use_xsave() x86: Add new static_cpu_has() function using alternatives x86, fpu: Use the proper asm constraint in use_xsave() x86, fpu: Unbreak FPU emulation x86: Introduce 'struct fpu' and related API x86: Eliminate TS_XSAVE x86-32: Don't set ignore_fpu_irq in simd exception x86: Merge kernel_math_error() into math_error() x86: Merge simd_math_error() into math_error() x86-32: Rework cache flush denied handler Fix trivial conflict in arch/x86/kernel/process.c
2010-05-03x86-32: Rework cache flush denied handlerBrian Gerst
The cache flush denied error is an erratum on some AMD 486 clones. If an invd instruction is executed in userspace, the processor calls exception 19 (13 hex) instead of #GP (13 decimal). On cpus where XMM is not supported, redirect exception 19 to do_general_protection(). Also, remove die_if_kernel(), since this was the last user. Signed-off-by: Brian Gerst <brgerst@gmail.com> LKML-Reference: <1269176446-2489-2-git-send-email-brgerst@gmail.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-03-26x86, perf, bts, mm: Delete the never used BTS-ptrace codePeter Zijlstra
Support for the PMU's BTS features has been upstreamed in v2.6.32, but we still have the old and disabled ptrace-BTS, as Linus noticed it not so long ago. It's buggy: TIF_DEBUGCTLMSR is trampling all over that MSR without regard for other uses (perf) and doesn't provide the flexibility needed for perf either. Its users are ptrace-block-step and ptrace-bts, since ptrace-bts was never used and ptrace-block-step can be implemented using a much simpler approach. So axe all 3000 lines of it. That includes the *locked_memory*() APIs in mm/mlock.c as well. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Markus Metzger <markus.t.metzger@intel.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <20100325135413.938004390@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-28Merge branch 'x86-rwsem-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-rwsem-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86-64, rwsem: Avoid store forwarding hazard in __downgrade_write x86-64, rwsem: 64-bit xadd rwsem implementation x86: Fix breakage of UML from the changes in the rwsem system x86-64: support native xadd rwsem implementation x86: clean up rwsem type system
2010-01-13x86-64: support native xadd rwsem implementationLinus Torvalds
This one is much faster than the spinlock based fallback rwsem code, with certain artifical benchmarks having shown 300%+ improvement on threaded page faults etc. Again, note the 32767-thread limit here. So this really does need that whole "make rwsem_count_t be 64-bit and fix the BIAS values to match" extension on top of it, but that is conceptually a totally independent issue. NOT TESTED! The original patch that this all was based on were tested by KAMEZAWA Hiroyuki, but maybe I screwed up something when I created the cleaned-up series, so caveat emptor.. Also note that it _may_ be a good idea to mark some more registers clobbered on x86-64 in the inline asms instead of saving/restoring them. They are inline functions, but they are only used in places where there are not a lot of live registers _anyway_, so doing for example the clobbers of %r8-%r11 in the asm wouldn't make the fast-path code any worse, and would make the slow-path code smaller. (Not that the slow-path really matters to that degree. Saving a few unnecessary registers is the _least_ of our problems when we hit the slow path. The instruction/cycle counting really only matters in the fast path). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <alpine.LFD.2.00.1001121810410.17145@localhost.localdomain> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-01-05Revert "x86: Side-step lguest problem by only building cmpxchg8b_emu for ↵Rusty Russell
pre-Pentium" This reverts commit ae1b22f6e46c03cede7cea234d0bf2253b4261cf. As Linus said in 982d007a6ee: "There was something really messy about cmpxchg8b and clone CPU's, so if you enable it on other CPUs later, do it carefully." This breaks lguest for those configs, but we can fix that by emulating if we have to. Fixes: http://bugzilla.kernel.org/show_bug.cgi?id=14884 Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-08Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (36 commits) x86, mm: Correct the implementation of is_untracked_pat_range() x86/pat: Trivial: don't create debugfs for memtype if pat is disabled x86, mtrr: Fix sorting of mtrr after subtracting x86: Move find_smp_config() earlier and avoid bootmem usage x86, platform: Change is_untracked_pat_range() to bool; cleanup init x86: Change is_ISA_range() into an inline function x86, mm: is_untracked_pat_range() takes a normal semiclosed range x86, mm: Call is_untracked_pat_range() rather than is_ISA_range() x86: UV SGI: Don't track GRU space in PAT x86: SGI UV: Fix BAU initialization x86, numa: Use near(er) online node instead of roundrobin for NUMA x86, numa, bootmem: Only free bootmem on NUMA failure path x86: Change crash kernel to reserve via reserve_early() x86: Eliminate redundant/contradicting cache line size config options x86: When cleaning MTRRs, do not fold WP into UC x86: remove "extern" from function prototypes in <asm/proto.h> x86, mm: Report state of NX protections during boot x86, mm: Clean up and simplify NX enablement x86, pageattr: Make set_memory_(x|nx) aware of NX support x86, sleep: Always save the value of EFER ... Fix up conflicts (added both iommu_shutdown and is_untracked_pat_range) to 'struct x86_platform_ops') in arch/x86/include/asm/x86_init.h arch/x86/kernel/x86_init.c
2009-12-05Merge branch 'x86-cpu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, msr, cpumask: Use struct cpumask rather than the deprecated cpumask_t x86, cpuid: Simplify the code in cpuid_open x86, cpuid: Remove the bkl from cpuid_open() x86, msr: Remove the bkl from msr_open() x86: AMD Geode LX optimizations x86, msr: Unify rdmsr_on_cpus/wrmsr_on_cpus
2009-11-19x86: Eliminate redundant/contradicting cache line size config optionsJan Beulich
Rather than having X86_L1_CACHE_BYTES and X86_L1_CACHE_SHIFT (with inconsistent defaults), just having the latter suffices as the former can be easily calculated from it. To be consistent, also change X86_INTERNODE_CACHE_BYTES to X86_INTERNODE_CACHE_SHIFT, and set it to 7 (128 bytes) for NUMA to account for last level cache line size (which here matters more than L1 cache line size). Finally, make sure the default value for X86_L1_CACHE_SHIFT, when X86_GENERIC is selected, is being seen before that for the individual CPU model options (other than on x86-64, where GENERIC_CPU is part of the choice construct, X86_GENERIC is a separate option on ix86). Signed-off-by: Jan Beulich <jbeulich@novell.com> Acked-by: Ravikiran Thirumalai <kiran@scalex86.org> Acked-by: Nick Piggin <npiggin@suse.de> LKML-Reference: <4AFD5710020000780001F8F0@vpn.id2.novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-26x86: Side-step lguest problem by only building cmpxchg8b_emu for pre-PentiumRusty Russell
Commit 79e1dd05d1a22 "x86: Provide an alternative() based cmpxchg64()" broke lguest, even on systems which have cmpxchg8b support. The emulation code gets used until alternatives get run, but it contains native instructions, not their paravirt alternatives. The simplest fix is to turn this code off except for 386 and 486 builds. Reported-by: Johannes Stezenbach <js@sig21.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: H. Peter Anvin <hpa@zytor.com> Cc: lguest@ozlabs.org Cc: Arjan van de Ven <arjan@infradead.org> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <200910261426.05769.rusty@rustcorp.com.au> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-02x86: AMD Geode LX optimizationsMatteo Croce
Add CPU optimizations for AMD Geode LX. Signed-off-by: Matteo Croce <technoboy85@gmail.com> LKML-Reference: <40101cc30910010811v5d15ff4cx9dd57c9cc9b4b045@mail.gmail.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-10-01x86: Optimize cmpxchg64() at build-time some moreLinus Torvalds
Try to avoid the 'alternates()' code when we can statically determine that cmpxchg8b is fine. We already have that CONFIG_x86_CMPXCHG64 (enabled by PAE support), and we could easily also enable it for some of the CPU cases. Note, this patch only adds CMPXCHG8B for the obvious Intel CPU's, not for others. (There was something really messy about cmpxchg8b and clone CPU's, so if you enable it on other CPUs later, do it carefully.) If we avoid that asm-alternative thing when we can assume the instruction exists, we'll generate less support crud, and we'll avoid the whole issue with that extra 'nop' for padding instruction sizes etc. LKML-Reference: <alpine.LFD.2.01.0909301743150.6996@localhost.localdomain> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-23x86: add specific support for Intel Atom architectureTobias Doerffel
Add another option when selecting CPU family so the kernel can be optimized for Intel Atom CPUs. If GCC supports tuning options for Intel Atom they will be used. Signed-off-by: Tobias Doerffel <tobias.doerffel@gmail.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com> LKML-Reference: <1251018457-19157-1-git-send-email-tobias.doerffel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-15x86: disable X86_PTRACE_BTS for nowIngo Molnar
Oleg Nesterov found a couple of races in the ptrace-bts code and fixes are queued up for it but they did not get ready in time for the merge window. We'll merge them in v2.6.31 - until then mark the feature as CONFIG_BROKEN. There's no user-space yet making use of this so it's not a big issue. Cc: <stable@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-14x86/centaur: merge 32 & 64 bit versionSebastian Andrzej Siewior
there should be no difference, except: * the 64bit variant now also initializes the padlock unit. * ->c_early_init() is executed again from ->c_init() * the 64bit fixups made into 32bit path. Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Cc: herbert@gondor.apana.org.au LKML-Reference: <1237029843-28076-2-git-send-email-sebastian@breakpoint.cc> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-05x86: clean up arch/x86/Kconfig*Ingo Molnar
- Consistent alignment of help text - Use the ---help--- keyword everywhere consistently as a visual separator - fix whitespace mismatches Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-05Merge branch 'x86/urgent' into x86/apicIngo Molnar
Conflicts: arch/x86/mach-default/setup.c Semantic merge: arch/x86/kernel/irqinit_32.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-04x86/Kconfig.cpu: make Kconfig help readable in the consoleBorislav Petkov
Impact: cleanup Some lines exceed the 80 char width making them unreadable. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-21x86: make x86_32 use tlb_64.c, build fix, clean up X86_L1_CACHE_BYTESIngo Molnar
Fix: arch/x86/mm/tlb.c:47: error: ‘CONFIG_X86_INTERNODE_CACHE_BYTES’ undeclared here (not in a function) The CONFIG_X86_INTERNODE_CACHE_BYTES symbol is only defined on 64-bit, because vsmp support is 64-bit only. Define it on 32-bit too - where it will always be equal to X86_L1_CACHE_BYTES. Also move the default of X86_L1_CACHE_BYTES (which is separate from the more commonly used L1_CACHE_SHIFT kconfig symbol) from 128 bytes to 64 bytes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-14x86: change the default cache size to 64 bytesIngo Molnar
Right now the generic cacheline size is 128 bytes - that is wasteful when structures are aligned, as all modern x86 CPUs have an (effective) cacheline sizes of 64 bytes. It was set to 128 bytes due to some cacheline aliasing problems on older P4 systems, but those are many years old and we dont optimize for them anymore. (They'll still get the 128 bytes cacheline size if the kernel is specifically built for Pentium 4) Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Arjan van de Ven <arjan@linux.intel.com>
2009-01-05X86_DEBUGCTLMSR won't work on umlAl Viro
2008-11-25x86, bts, ftrace: a BTS ftrace plug-in prototypeMarkus Metzger
Impact: add new ftrace plugin A prototype for a BTS ftrace plug-in. The tracer collects branch trace in a cyclic buffer for each cpu. The tracer is not configurable and the trace for each snapshot is appended when doing cat /debug/tracing/trace. This is a proof of concept that will be extended with future patches to become a (hopefully) useful tool. Signed-off-by: Markus Metzger <markus.t.metzger@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-28x86, bts: improve help text for BTS configMarkus Metzger
Improve the help text of the X86_PTRACE_BTS config. Make X86_DS invisible and depend on X86_PTRACE_BTS. Reported-by: Roland Dreier <rdreier@cisco.com> Signed-off-by: Markus Metzger <markus.t.metzger@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13x86: adjust dependencies for CONFIG_X86_CMOVJan Beulich
Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13x86: merge winchip-2 and winchip-2a cpu choicesKrzysztof Helt
The Winchip-2 and Winchip-2A cpu choices select the same options for kernel and compiler. Merge them to save few bytes and reduce confusion. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
