path: root/arch/x86/Kconfig
2019-11-24x86/olpc: Fix build error with CONFIG_MFD_CS5535=mBorislav Petkov
[ Upstream commit fa112cf1e8bc693d5a666b1c479a2859c8b6e0f1 ] When building a 32-bit config which has the above MFD item as module but OLPC_XO1_PM is enabled =y - which is bool, btw - the kernel fails building with: ld: arch/x86/platform/olpc/olpc-xo1-pm.o: in function `xo1_pm_remove': /home/boris/kernel/linux/arch/x86/platform/olpc/olpc-xo1-pm.c:159: undefined reference to `mfd_cell_disable' ld: arch/x86/platform/olpc/olpc-xo1-pm.o: in function `xo1_pm_probe': /home/boris/kernel/linux/arch/x86/platform/olpc/olpc-xo1-pm.c:133: undefined reference to `mfd_cell_enable' make: *** [Makefile:1030: vmlinux] Error 1 Force MFD_CS5535 to y if OLPC_XO1_PM is enabled. Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Lubomir Rintel <lkundrak@v3.sk> Cc: x86@kernel.org Link: http://lkml.kernel.org/r/20181005131750.GA5366@zn.tnic Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-11-12x86/tsx: Add config options to set tsx=on|off|autoMichal Hocko
commit db616173d787395787ecc93eef075fa975227b10 upstream. There is a general consensus that TSX usage is not largely spread while the history shows there is a non trivial space for side channel attacks possible. Therefore the tsx is disabled by default even on platforms that might have a safe implementation of TSX according to the current knowledge. This is a fair trade off to make. There are, however, workloads that really do benefit from using TSX and updating to a newer kernel with TSX disabled might introduce a noticeable regressions. This would be especially a problem for Linux distributions which will provide TAA mitigations. Introduce config options X86_INTEL_TSX_MODE_OFF, X86_INTEL_TSX_MODE_ON and X86_INTEL_TSX_MODE_AUTO to control the TSX feature. The config setting can be overridden by the tsx cmdline options. [ bp: Text cleanups from Josh. ] Suggested-by: Borislav Petkov <bpetkov@suse.de> Signed-off-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Pawan Gupta <pawan.kumar.gupta@linux.intel.com> Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-03x86/smp: Enforce CONFIG_HOTPLUG_CPU when SMP=yThomas Gleixner
commit bebd024e4815b1a170fcd21ead9c2222b23ce9e6 upstream. The SMT disable 'nosmt' command line argument is not working properly when CONFIG_HOTPLUG_CPU is disabled. The teardown of the sibling CPUs which are required to be brought up due to the MCE issues, cannot work. The CPUs are then kept in a half dead state. As the 'nosmt' functionality has become popular due to the speculative hardware vulnerabilities, the half torn down state is not a proper solution to the problem. Enforce CONFIG_HOTPLUG_CPU=y when SMP is enabled so the full operation is possible. Reported-by: Tianyu Lan <Tianyu.Lan@microsoft.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Konrad Wilk <konrad.wilk@oracle.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Mukesh Ojha <mojha@codeaurora.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Rik van Riel <riel@surriel.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Micheal Kelley <michael.h.kelley@microsoft.com> Cc: "K. Y. Srinivasan" <kys@microsoft.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Borislav Petkov <bp@alien8.de> Cc: K. Y. Srinivasan <kys@microsoft.com> Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/20190326163811.598166056@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-12-05x86/Kconfig: Select SCHED_SMT if SMP enabledThomas Gleixner
commit dbe733642e01dd108f71436aaea7b328cb28fd87 upstream CONFIG_SCHED_SMT is enabled by all distros, so there is not a real point to have it configurable. The runtime overhead in the core scheduler code is minimal because the actual SMT scheduling parts are conditional on a static key. This allows to expose the scheduler's SMT state static key to the speculation control code. Alternatively the scheduler's static key could be made always available when CONFIG_SMP is enabled, but that's just adding an unused static key to every other architecture for nothing. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Tom Lendacky <thomas.lendacky@amd.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: David Woodhouse <dwmw@amazon.co.uk> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Casey Schaufler <casey.schaufler@intel.com> Cc: Asit Mallick <asit.k.mallick@intel.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Jon Masters <jcm@redhat.com> Cc: Waiman Long <longman9394@gmail.com> Cc: Greg KH <gregkh@linuxfoundation.org> Cc: Dave Stewart <david.c.stewart@intel.com> Cc: Kees Cook <keescook@chromium.org> Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/20181125185004.337452245@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-12-05x86/retpoline: Make CONFIG_RETPOLINE depend on compiler supportZhenzhong Duan
commit 4cd24de3a0980bf3100c9dcb08ef65ca7c31af48 upstream Since retpoline capable compilers are widely available, make CONFIG_RETPOLINE hard depend on the compiler capability. Break the build when CONFIG_RETPOLINE is enabled and the compiler does not support it. Emit an error message in that case: "arch/x86/Makefile:226: *** You are building kernel with non-retpoline compiler, please update your compiler.. Stop." [dwmw: Fail the build with non-retpoline compiler] Suggested-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Zhenzhong Duan <zhenzhong.duan@oracle.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: David Woodhouse <dwmw@amazon.co.uk> Cc: Borislav Petkov <bp@suse.de> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Michal Marek <michal.lkml@markovi.net> Cc: <srinivas.eeda@oracle.com> Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/cca0cb20-f9e2-4094-840b-fb0f8810cd34@default Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05mm/tlb, x86/mm: Support invalidating TLB caches for RCU_TABLE_FREEPeter Zijlstra
commit d86564a2f085b79ec046a5cba90188e612352806 upstream. Jann reported that x86 was missing required TLB invalidates when he hit the !*batch slow path in tlb_remove_table(). This is indeed the case; RCU_TABLE_FREE does not provide TLB (cache) invalidates, the PowerPC-hash where this code originated and the Sparc-hash where this was subsequently used did not need that. ARM which later used this put an explicit TLB invalidate in their __p*_free_tlb() functions, and PowerPC-radix followed that example. But when we hooked up x86 we failed to consider this. Fix this by (optionally) hooking tlb_remove_table() into the TLB invalidate code. NOTE: s390 was also needing something like this and might now be able to use the generic code again. [ Modified to be on top of Nick's cleanups, which simplified this patch now that tlb_flush_mmu_tlbonly() really only flushes the TLB - Linus ] Fixes: 9e52fc2b50de ("x86/mm: Enable RCU based page table freeing (CONFIG_HAVE_RCU_TABLE_FREE=y)") Reported-by: Jann Horn <jannh@google.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Rik van Riel <riel@surriel.com> Cc: Nicholas Piggin <npiggin@gmail.com> Cc: David Miller <davem@davemloft.net> Cc: Will Deacon <will.deacon@arm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15cpu/hotplug: Provide knobs to control SMTThomas Gleixner
commit 05736e4ac13c08a4a9b1ef2de26dd31a32cbee57 upstream Provide a command line and a sysfs knob to control SMT. The command line options are: 'nosmt': Enumerate secondary threads, but do not online them 'nosmt=force': Ignore secondary threads completely during enumeration via MP table and ACPI/MADT. The sysfs control file has the following states (read/write): 'on': SMT is enabled. Secondary threads can be freely onlined 'off': SMT is disabled. Secondary threads, even if enumerated cannot be onlined 'forceoff': SMT is permanentely disabled. Writes to the control file are rejected. 'notsupported': SMT is not supported by the CPU The command line option 'nosmt' sets the sysfs control to 'off'. This can be changed to 'on' to reenable SMT during runtime. The command line option 'nosmt=force' sets the sysfs control to 'forceoff'. This cannot be changed during runtime. When SMT is 'on' and the control file is changed to 'off' then all online secondary threads are offlined and attempts to online a secondary thread later on are rejected. When SMT is 'off' and the control file is changed to 'on' then secondary threads can be onlined again. The 'off' -> 'on' transition does not automatically online the secondary threads. When the control file is set to 'forceoff', the behaviour is the same as setting it to 'off', but the operation is irreversible and later writes to the control file are rejected. When the control status is 'notsupported' then writes to the control file are rejected. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-15objtool, retpolines: Integrate objtool with retpoline support more closelyPeter Zijlstra
commit d5028ba8ee5a18c9d0bb926d883c28b370f89009 upstream. Disable retpoline validation in objtool if your compiler sucks, and otherwise select the validation stuff for CONFIG_RETPOLINE=y (most builds would already have it set due to ORC). Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andy Lutomirski <luto@kernel.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-22kmemcheck: rip it outLevin, Alexander (Sasha Levin)
commit 4675ff05de2d76d167336b368bd07f3fef6ed5a6 upstream. Fix up makefiles, remove references, and git rm kmemcheck. Link: http://lkml.kernel.org/r/20171007030159.22241-4-alexander.levin@verizon.com Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Vegard Nossum <vegardno@ifi.uio.no> Cc: Pekka Enberg <penberg@kernel.org> Cc: Michal Hocko <mhocko@kernel.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Alexander Potapenko <glider@google.com> Cc: Tim Hansen <devtimhansen@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/retpoline: Add initial retpoline supportDavid Woodhouse
commit 76b043848fd22dbf7f8bf3a1452f8c70d557b860 upstream. Enable the use of -mindirect-branch=thunk-extern in newer GCC, and provide the corresponding thunks. Provide assembler macros for invoking the thunks in the same way that GCC does, from native and inline assembler. This adds X86_FEATURE_RETPOLINE and sets it by default on all CPUs. In some circumstances, IBRS microcode features may be used instead, and the retpoline can be disabled. On AMD CPUs if lfence is serialising, the retpoline can be dramatically simplified to a simple "lfence; jmp *\reg". A future patch, after it has been verified that lfence really is serialising in all circumstances, can enable this by setting the X86_FEATURE_RETPOLINE_AMD feature bit in addition to X86_FEATURE_RETPOLINE. Do not align the retpoline in the altinstr section, because there is no guarantee that it stays aligned when it's copied over the oldinstr during alternative patching. [ Andi Kleen: Rename the macros, add CONFIG_RETPOLINE option, export thunks] [ tglx: Put actual function CALL/JMP in front of the macros, convert to symbolic labels ] [ dwmw2: Convert back to numeric labels, merge objtool fixes ] Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: gnomes@lxorguk.ukuu.org.uk Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: thomas.lendacky@amd.com Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Kosina <jikos@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Link: https://lkml.kernel.org/r/1515707194-20531-4-git-send-email-dwmw@amazon.co.uk Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/cpu: Implement CPU vulnerabilites sysfs functionsThomas Gleixner
commit 61dc0f555b5c761cdafb0ba5bd41ecf22d68a4c4 upstream. Implement the CPU vulnerabilty show functions for meltdown, spectre_v1 and spectre_v2. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Will Deacon <will.deacon@arm.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Linus Torvalds <torvalds@linuxfoundation.org> Cc: Borislav Petkov <bp@alien8.de> Cc: David Woodhouse <dwmw@amazon.co.uk> Link: https://lkml.kernel.org/r/20180107214913.177414879@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-29x86/Kconfig: Limit NR_CPUS on 32-bit to a sane amountThomas Gleixner
commit 7bbcbd3d1cdcbacd0f9f8dc4c98d550972f1ca30 upstream. The recent cpu_entry_area changes fail to compile on 32-bit when BIGSMP=y and NR_CPUS=512, because the fixmap area becomes too big. Limit the number of CPUs with BIGSMP to 64, which is already way to big for 32-bit, but it's at least a working limitation. We performed a quick survey of 32-bit-only machines that might be affected by this change negatively, but found none. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Juergen Gross <jgross@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25x86/mm/kasan: Don't use vmemmap_populate() to initialize shadowAndrey Ryabinin
commit 2aeb07365bcd489620f71390a7d2031cd4dfb83e upstream. [ Note, this is a Git cherry-pick of the following commit: d17a1d97dc20: ("x86/mm/kasan: don't use vmemmap_populate() to initialize shadow") ... for easier x86 PTI code testing and back-porting. ] The KASAN shadow is currently mapped using vmemmap_populate() since that provides a semi-convenient way to map pages into init_top_pgt. However, since that no longer zeroes the mapped pages, it is not suitable for KASAN, which requires zeroed shadow memory. Add kasan_populate_shadow() interface and use it instead of vmemmap_populate(). Besides, this allows us to take advantage of gigantic pages and use them to populate the shadow, which should save us some memory wasted on page tables and reduce TLB pressure. Link: http://lkml.kernel.org/r/20171103185147.2688-2-pasha.tatashin@oracle.com Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Steven Sistare <steven.sistare@oracle.com> Cc: Daniel Jordan <daniel.m.jordan@oracle.com> Cc: Bob Picco <bob.picco@oracle.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Alexander Potapenko <glider@google.com> Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: David S. Miller <davem@davemloft.net> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Michal Hocko <mhocko@kernel.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Will Deacon <will.deacon@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25x86/kasan: Use the same shadow offset for 4- and 5-level pagingAndrey Ryabinin
commit 12a8cc7fcf54a8575f094be1e99032ec38aa045c upstream. We are going to support boot-time switching between 4- and 5-level paging. For KASAN it means we cannot have different KASAN_SHADOW_OFFSET for different paging modes: the constant is passed to gcc to generate code and cannot be changed at runtime. This patch changes KASAN code to use 0xdffffc0000000000 as shadow offset for both 4- and 5-level paging. For 5-level paging it means that shadow memory region is not aligned to PGD boundary anymore and we have to handle unaligned parts of the region properly. In addition, we have to exclude paravirt code from KASAN instrumentation as we now use set_pgd() before KASAN is fully ready. [kirill.shutemov@linux.intel.com: clenaup, changelog message] Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@suse.de> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/20170929140821.37654-4-kirill.shutemov@linux.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25x86/unwind: Rename unwinder config options to 'CONFIG_UNWINDER_*'Josh Poimboeuf
commit 11af847446ed0d131cf24d16a7ef3d5ea7a49554 upstream. Rename the unwinder config options from: CONFIG_ORC_UNWINDER CONFIG_FRAME_POINTER_UNWINDER CONFIG_GUESS_UNWINDER to: CONFIG_UNWINDER_ORC CONFIG_UNWINDER_FRAME_POINTER CONFIG_UNWINDER_GUESS ... in order to give them a more logical config namespace. Suggested-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/73972fc7e2762e91912c6b9584582703d6f1b8cc.1507924831.git.jpoimboe@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-10locking/refcounts, x86/asm: Enable CONFIG_ARCH_HAS_REFCOUNTKees Cook
[ Upstream commit 39208aa7ecb7d9c4e86df782b5693270313cbab1 ] With the section inlining bug fixed for the x86 refcount protection, we can turn the config back on. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: Elena <elena.reshetova@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch <linux-arch@vger.kernel.org> Link: http://lkml.kernel.org/r/1504382986-49301-3-git-send-email-keescook@chromium.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-11Merge tag 'libnvdimm-for-4.14' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm Pull libnvdimm from Dan Williams: "A rework of media error handling in the BTT driver and other updates. It has appeared in a few -next releases and collected some late- breaking build-error and warning fixups as a result. Summary: - Media error handling support in the Block Translation Table (BTT) driver is reworked to address sleeping-while-atomic locking and memory-allocation-context conflicts. - The dax_device lookup overhead for xfs and ext4 is moved out of the iomap hot-path to a mount-time lookup. - A new 'ecc_unit_size' sysfs attribute is added to advertise the read-modify-write boundary property of a persistent memory range. - Preparatory fix-ups for arm and powerpc pmem support are included along with other miscellaneous fixes" * tag 'libnvdimm-for-4.14' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (26 commits) libnvdimm, btt: fix format string warnings libnvdimm, btt: clean up warning and error messages ext4: fix null pointer dereference on sbi libnvdimm, nfit: move the check on nd_reserved2 to the endpoint dax: fix FS_DAX=n BLOCK=y compilation libnvdimm: fix integer overflow static analysis warning libnvdimm, nd_blk: remove mmio_flush_range() libnvdimm, btt: rework error clearing libnvdimm: fix potential deadlock while clearing errors libnvdimm, btt: cache sector_size in arena_info libnvdimm, btt: ensure that flags were also unchanged during a map_read libnvdimm, btt: refactor map entry operations with macros libnvdimm, btt: fix a missed NVDIMM_IO_ATOMIC case in the write path libnvdimm, nfit: export an 'ecc_unit_size' sysfs attribute ext4: perform dax_device lookup at mount ext2: perform dax_device lookup at mount xfs: perform dax_device lookup at mount dax: introduce a fs_dax_get_by_bdev() helper libnvdimm, btt: check memory allocation failure libnvdimm, label: fix index block size calculation ...
2017-09-08mm/memory_hotplug: introduce add_pagesMichal Hocko
There are new users of memory hotplug emerging. Some of them require different subset of arch_add_memory. There are some which only require allocation of struct pages without mapping those pages to the kernel address space. We currently have __add_pages for that purpose. But this is rather lowlevel and not very suitable for the code outside of the memory hotplug. E.g. x86_64 wants to update max_pfn which should be done by the caller. Introduce add_pages() which should care about those details if they are needed. Each architecture should define its implementation and select CONFIG_ARCH_HAS_ADD_PAGES. All others use the currently existing __add_pages. Link: http://lkml.kernel.org/r/20170817000548.32038-7-jglisse@redhat.com Signed-off-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Jérôme Glisse <jglisse@redhat.com> Acked-by: Balbir Singh <bsingharora@gmail.com> Cc: Aneesh Kumar <aneesh.kumar@linux.vnet.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dan Williams <dan.j.williams@intel.com> Cc: David Nellans <dnellans@nvidia.com> Cc: Evgeny Baskakov <ebaskakov@nvidia.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: John Hubbard <jhubbard@nvidia.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Mark Hairgrove <mhairgrove@nvidia.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Sherry Cheung <SCheung@nvidia.com> Cc: Subhash Gutti <sgutti@nvidia.com> Cc: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: Bob Liu <liubo95@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-09-08mm: thp: introduce CONFIG_ARCH_ENABLE_THP_MIGRATIONNaoya Horiguchi
Introduce CONFIG_ARCH_ENABLE_THP_MIGRATION to limit thp migration functionality to x86_64, which should be safer at the first step. Link: http://lkml.kernel.org/r/20170717193955.20207-5-zi.yan@sent.com Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Zi Yan <zi.yan@cs.rutgers.edu> Reviewed-by: Anshuman Khandual <khandual@linux.vnet.ibm.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: David Nellans <dnellans@nvidia.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Minchan Kim <minchan@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Michal Hocko <mhocko@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-09-06x86,mpx: make mpx depend on x86-64 to free up VMA flagRik van Riel
Patch series "mm,fork,security: introduce MADV_WIPEONFORK", v4. If a child process accesses memory that was MADV_WIPEONFORK, it will get zeroes. The address ranges are still valid, they are just empty. If a child process accesses memory that was MADV_DONTFORK, it will get a segmentation fault, since those address ranges are no longer valid in the child after fork. Since MADV_DONTFORK also seems to be used to allow very large programs to fork in systems with strict memory overcommit restrictions, changing the semantics of MADV_DONTFORK might break existing programs. The use case is libraries that store or cache information, and want to know that they need to regenerate it in the child process after fork. Examples of this would be: - systemd/pulseaudio API checks (fail after fork) (replacing a getpid check, which is too slow without a PID cache) - PKCS#11 API reinitialization check (mandated by specification) - glibc's upcoming PRNG (reseed after fork) - OpenSSL PRNG (reseed after fork) The security benefits of a forking server having a re-inialized PRNG in every child process are pretty obvious. However, due to libraries having all kinds of internal state, and programs getting compiled with many different versions of each library, it is unreasonable to expect calling programs to re-initialize everything manually after fork. A further complication is the proliferation of clone flags, programs bypassing glibc's functions to call clone directly, and programs calling unshare, causing the glibc pthread_atfork hook to not get called. It would be better to have the kernel take care of this automatically. The patchset also adds MADV_KEEPONFORK, to undo the effects of a prior MADV_WIPEONFORK. This is similar to the OpenBSD minherit syscall with MAP_INHERIT_ZERO: https://man.openbsd.org/minherit.2 This patch (of 2): MPX only seems to be available on 64 bit CPUs, starting with Skylake and Goldmont. Move VM_MPX into the 64 bit only portion of vma->vm_flags, in order to free up a VMA flag. Link: http://lkml.kernel.org/r/20170811212829.29186-2-riel@redhat.com Signed-off-by: Rik van Riel <riel@redhat.com> Acked-by: Dave Hansen <dave.hansen@intel.com> Cc: Mike Kravetz <mike.kravetz@oracle.com> Cc: Florian Weimer <fweimer@redhat.com> Cc: Kees Cook <keescook@chromium.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Will Drewry <wad@chromium.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Matthew Wilcox <willy@infradead.org> Cc: Colm MacCártaigh <colm@allcosts.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-09-04Merge branch 'x86-cache-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 cache quality monitoring update from Thomas Gleixner: "This update provides a complete rewrite of the Cache Quality Monitoring (CQM) facility. The existing CQM support was duct taped into perf with a lot of issues and the attempts to fix those turned out to be incomplete and horrible. After lengthy discussions it was decided to integrate the CQM support into the Resource Director Technology (RDT) facility, which is the obvious choise as in hardware CQM is part of RDT. This allowed to add Memory Bandwidth Monitoring support on top. As a result the mechanisms for allocating cache/memory bandwidth and the corresponding monitoring mechanisms are integrated into a single management facility with a consistent user interface" * 'x86-cache-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (37 commits) x86/intel_rdt: Turn off most RDT features on Skylake x86/intel_rdt: Add command line options for resource director technology x86/intel_rdt: Move special case code for Haswell to a quirk function x86/intel_rdt: Remove redundant ternary operator on return x86/intel_rdt/cqm: Improve limbo list processing x86/intel_rdt/mbm: Fix MBM overflow handler during CPU hotplug x86/intel_rdt: Modify the intel_pqr_state for better performance x86/intel_rdt/cqm: Clear the default RMID during hotcpu x86/intel_rdt: Show bitmask of shareable resource with other executing units x86/intel_rdt/mbm: Handle counter overflow x86/intel_rdt/mbm: Add mbm counter initialization x86/intel_rdt/mbm: Basic counting of MBM events (total and local) x86/intel_rdt/cqm: Add CPU hotplug support x86/intel_rdt/cqm: Add sched_in support x86/intel_rdt: Introduce rdt_enable_key for scheduling x86/intel_rdt/cqm: Add mount,umount support x86/intel_rdt/cqm: Add rmdir support x86/intel_rdt: Separate the ctrl bits from rmdir x86/intel_rdt/cqm: Add mon_data x86/intel_rdt: Prepare for RDT monitor data support ...
2017-09-04Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 mm changes from Ingo Molnar: "PCID support, 5-level paging support, Secure Memory Encryption support The main changes in this cycle are support for three new, complex hardware features of x86 CPUs: - Add 5-level paging support, which is a new hardware feature on upcoming Intel CPUs allowing up to 128 PB of virtual address space and 4 PB of physical RAM space - a 512-fold increase over the old limits. (Supercomputers of the future forecasting hurricanes on an ever warming planet can certainly make good use of more RAM.) Many of the necessary changes went upstream in previous cycles, v4.14 is the first kernel that can enable 5-level paging. This feature is activated via CONFIG_X86_5LEVEL=y - disabled by default. (By Kirill A. Shutemov) - Add 'encrypted memory' support, which is a new hardware feature on upcoming AMD CPUs ('Secure Memory Encryption', SME) allowing system RAM to be encrypted and decrypted (mostly) transparently by the CPU, with a little help from the kernel to transition to/from encrypted RAM. Such RAM should be more secure against various attacks like RAM access via the memory bus and should make the radio signature of memory bus traffic harder to intercept (and decrypt) as well. This feature is activated via CONFIG_AMD_MEM_ENCRYPT=y - disabled by default. (By Tom Lendacky) - Enable PCID optimized TLB flushing on newer Intel CPUs: PCID is a hardware feature that attaches an address space tag to TLB entries and thus allows to skip TLB flushing in many cases, even if we switch mm's. (By Andy Lutomirski) All three of these features were in the works for a long time, and it's coincidence of the three independent development paths that they are all enabled in v4.14 at once" * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (65 commits) x86/mm: Enable RCU based page table freeing (CONFIG_HAVE_RCU_TABLE_FREE=y) x86/mm: Use pr_cont() in dump_pagetable() x86/mm: Fix SME encryption stack ptr handling kvm/x86: Avoid clearing the C-bit in rsvd_bits() x86/CPU: Align CR3 defines x86/mm, mm/hwpoison: Clear PRESENT bit for kernel 1:1 mappings of poison pages acpi, x86/mm: Remove encryption mask from ACPI page protection type x86/mm, kexec: Fix memory corruption with SME on successive kexecs x86/mm/pkeys: Fix typo in Documentation/x86/protection-keys.txt x86/mm/dump_pagetables: Speed up page tables dump for CONFIG_KASAN=y x86/mm: Implement PCID based optimization: try to preserve old TLB entries using PCID x86: Enable 5-level paging support via CONFIG_X86_5LEVEL=y x86/mm: Allow userspace have mappings above 47-bit x86/mm: Prepare to expose larger address space to userspace x86/mpx: Do not allow MPX if we have mappings above 47-bit x86/mm: Rename tasksize_32bit/64bit to task_size_32bit/64bit() x86/xen: Redefine XEN_ELFNOTE_INIT_P2M using PUD_SIZE * PTRS_PER_PUD x86/mm/dump_pagetables: Fix printout of p4d level x86/mm/dump_pagetables: Generalize address normalization x86/boot: Fix memremap() related build failure ...
2017-09-04Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking updates from Ingo Molnar: - Add 'cross-release' support to lockdep, which allows APIs like completions, where it's not the 'owner' who releases the lock, to be tracked. It's all activated automatically under CONFIG_PROVE_LOCKING=y. - Clean up (restructure) the x86 atomics op implementation to be more readable, in preparation of KASAN annotations. (Dmitry Vyukov) - Fix static keys (Paolo Bonzini) - Add killable versions of down_read() et al (Kirill Tkhai) - Rework and fix jump_label locking (Marc Zyngier, Paolo Bonzini) - Rework (and fix) tlb_flush_pending() barriers (Peter Zijlstra) - Remove smp_mb__before_spinlock() and convert its usages, introduce smp_mb__after_spinlock() (Peter Zijlstra) * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (56 commits) locking/lockdep/selftests: Fix mixed read-write ABBA tests sched/completion: Avoid unnecessary stack allocation for COMPLETION_INITIALIZER_ONSTACK() acpi/nfit: Fix COMPLETION_INITIALIZER_ONSTACK() abuse locking/pvqspinlock: Relax cmpxchg's to improve performance on some architectures smp: Avoid using two cache lines for struct call_single_data locking/lockdep: Untangle xhlock history save/restore from task independence locking/refcounts, x86/asm: Disable CONFIG_ARCH_HAS_REFCOUNT for the time being futex: Remove duplicated code and fix undefined behaviour Documentation/locking/atomic: Finish the document... locking/lockdep: Fix workqueue crossrelease annotation workqueue/lockdep: 'Fix' flush_work() annotation locking/lockdep/selftests: Add mixed read-write ABBA tests mm, locking/barriers: Clarify tlb_flush_pending() barriers locking/lockdep: Make CONFIG_LOCKDEP_CROSSRELEASE and CONFIG_LOCKDEP_COMPLETIONS truly non-interactive locking/lockdep: Explicitly initialize wq_barrier::done::map locking/lockdep: Rename CONFIG_LOCKDEP_COMPLETE to CONFIG_LOCKDEP_COMPLETIONS locking/lockdep: Reword title of LOCKDEP_CROSSRELEASE config locking/lockdep: Make CONFIG_LOCKDEP_CROSSRELEASE part of CONFIG_PROVE_LOCKING locking/refcounts, x86/asm: Implement fast refcount overflow protection locking/lockdep: Fix the rollback and overwrite detection logic in crossrelease ...
2017-09-04Merge branch 'x86-asm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 asm updates from Ingo Molnar: - Introduce the ORC unwinder, which can be enabled via CONFIG_ORC_UNWINDER=y. The ORC unwinder is a lightweight, Linux kernel specific debuginfo implementation, which aims to be DWARF done right for unwinding. Objtool is used to generate the ORC unwinder tables during build, so the data format is flexible and kernel internal: there's no dependency on debuginfo created by an external toolchain. The ORC unwinder is almost two orders of magnitude faster than the (out of tree) DWARF unwinder - which is important for perf call graph profiling. It is also significantly simpler and is coded defensively: there has not been a single ORC related kernel crash so far, even with early versions. (knock on wood!) But the main advantage is that enabling the ORC unwinder allows CONFIG_FRAME_POINTERS to be turned off - which speeds up the kernel measurably: With frame pointers disabled, GCC does not have to add frame pointer instrumentation code to every function in the kernel. The kernel's .text size decreases by about 3.2%, resulting in better cache utilization and fewer instructions executed, resulting in a broad kernel-wide speedup. Average speedup of system calls should be roughly in the 1-3% range - measurements by Mel Gorman [1] have shown a speedup of 5-10% for some function execution intense workloads. The main cost of the unwinder is that the unwinder data has to be stored in RAM: the memory cost is 2-4MB of RAM, depending on kernel config - which is a modest cost on modern x86 systems. Given how young the ORC unwinder code is it's not enabled by default - but given the performance advantages the plan is to eventually make it the default unwinder on x86. See Documentation/x86/orc-unwinder.txt for more details. - Remove lguest support: its intended role was that of a temporary proof of concept for virtualization, plus its removal will enable the reduction (removal) of the paravirt API as well, so Rusty agreed to its removal. (Juergen Gross) - Clean up and fix FSGS related functionality (Andy Lutomirski) - Clean up IO access APIs (Andy Shevchenko) - Enhance the symbol namespace (Jiri Slaby) * 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (47 commits) objtool: Handle GCC stack pointer adjustment bug x86/entry/64: Use ENTRY() instead of ALIGN+GLOBAL for stub32_clone() x86/fpu/math-emu: Add ENDPROC to functions x86/boot/64: Extract efi_pe_entry() from startup_64() x86/boot/32: Extract efi_pe_entry() from startup_32() x86/lguest: Remove lguest support x86/paravirt/xen: Remove xen_patch() objtool: Fix objtool fallthrough detection with function padding x86/xen/64: Fix the reported SS and CS in SYSCALL objtool: Track DRAP separately from callee-saved registers objtool: Fix validate_branch() return codes x86: Clarify/fix no-op barriers for text_poke_bp() x86/switch_to/64: Rewrite FS/GS switching yet again to fix AMD CPUs selftests/x86/fsgsbase: Test selectors 1, 2, and 3 x86/fsgsbase/64: Report FSBASE and GSBASE correctly in core dumps x86/fsgsbase/64: Fully initialize FS and GS state in start_thread_common x86/asm: Fix UNWIND_HINT_REGS macro for older binutils x86/asm/32: Fix regs_get_register() on segment registers x86/xen/64: Rearrange the SYSCALL entries x86/asm/32: Remove a bunch of '& 0xffff' from pt_regs segment reads ...
2017-08-31Merge branch 'for-4.14/fs' into libnvdimm-for-nextDan Williams
2017-08-31libnvdimm, nd_blk: remove mmio_flush_range()Robin Murphy
mmio_flush_range() suffers from a lack of clearly-defined semantics, and is somewhat ambiguous to port to other architectures where the scope of the writeback implied by "flush" and ordering might matter, but MMIO would tend to imply non-cacheable anyway. Per the rationale in 67a3e8fe9015 ("nd_blk: change aperture mapping from WC to WB"), the only existing use is actually to invalidate clean cache lines for ARCH_MEMREMAP_PMEM type mappings *without* writeback. Since the recent cleanup of the pmem API, that also now happens to be the exact purpose of arch_invalidate_pmem(), which would be a far more well-defined tool for the job. Rather than risk potentially inconsistent implementations of mmio_flush_range() for the sake of one callsite, streamline things by removing it entirely and instead move the ARCH_MEMREMAP_PMEM related definitions up to the libnvdimm level, so they can be shared by NFIT as well. This allows NFIT to be enabled for arm64. Signed-off-by: Robin Murphy <robin.murphy@arm.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2017-08-31x86/mm: Enable RCU based page table freeing (CONFIG_HAVE_RCU_TABLE_FREE=y)Vitaly Kuznetsov
There's a subtle bug in how some of the paravirt guest code handles page table freeing on x86: On x86 software page table walkers depend on the fact that remote TLB flush does an IPI: walk is performed lockless but with interrupts disabled and in case the page table is freed the freeing CPU will get blocked as remote TLB flush is required. On other architectures which don't require an IPI to do remote TLB flush we have an RCU-based mechanism (see include/asm-generic/tlb.h for more details). In virtualized environments we may want to override the ->flush_tlb_others callback in pv_mmu_ops and use a hypercall asking the hypervisor to do a remote TLB flush for us. This breaks the assumption about IPIs. Xen PV has been doing this for years and the upcoming remote TLB flush for Hyper-V will do it too. This is not safe, as software page table walkers may step on an already freed page. Fix the bug by enabling the RCU-based page table freeing mechanism, CONFIG_HAVE_RCU_TABLE_FREE=y. Testing with kernbench and mmap/munmap microbenchmarks, and neither showed any noticeable performance impact. Suggested-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Juergen Gross <jgross@suse.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Andrew Cooper <andrew.cooper3@citrix.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: Jork Loeser <Jork.Loeser@microsoft.com> Cc: KY Srinivasan <kys@microsoft.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Stephen Hemminger <sthemmin@microsoft.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: xen-devel@lists.xenproject.org Link: http://lkml.kernel.org/r/20170828082251.5562-1-vkuznets@redhat.com [ Rewrote/fixed/clarified the changelog. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-08-29locking/refcounts, x86/asm: Disable CONFIG_ARCH_HAS_REFCOUNT for the time beingIngo Molnar
Mike Galbraith bisected a boot crash back to the following commit: 7a46ec0e2f48 ("locking/refcounts, x86/asm: Implement fast refcount overflow protection") The crash/hang pattern is: > Symptom is a few splats as below, with box finally hanging. Network > comes up, but neither ssh nor console login is possible. > > ------------[ cut here ]------------ > WARNING: CPU: 4 PID: 0 at net/netlink/af_netlink.c:374 netlink_sock_destruct+0x82/0xa0 > ... > __sk_destruct() > rcu_process_callbacks() > __do_softirq() > irq_exit() > smp_apic_timer_interrupt() > apic_timer_interrupt() We are at -rc7 already, and the code has grown some dependencies, so instead of a plain revert disable the config temporarily, in the hope of getting real fixes. Reported-by: Mike Galbraith <efault@gmx.de> Tested-by: Mike Galbraith <efault@gmx.de> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Elena Reshetova <elena.reshetova@intel.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Kees Cook <keescook@chromium.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/tip-7a46ec0e2f4850407de5e1d19a44edee6efa58ec@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-08-26Merge branch 'linus' into x86/mm to pick up fixes and to fix conflictsIngo Molnar
Conflicts: arch/x86/kernel/head64.c arch/x86/mm/mmap.c Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-08-25Merge branch 'linus' into locking/core, to pick up fixesIngo Molnar
2017-08-24x86/lguest: Remove lguest supportJuergen Gross
Lguest seems to be rather unused these days. It has seen only patches ensuring it still builds the last two years and its official state is "Odd Fixes". Remove it in order to be able to clean up the paravirt code. Signed-off-by: Juergen Gross <jgross@suse.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: boris.ostrovsky@oracle.com Cc: lguest@lists.ozlabs.org Cc: rusty@rustcorp.com.au Cc: xen-devel@lists.xenproject.org Link: http://lkml.kernel.org/r/20170816173157.8633-3-jgross@suse.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-08-20Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull watchdog fix from Thomas Gleixner: "A fix for the hardlockup watchdog to prevent false positives with extreme Turbo-Modes which make the perf/NMI watchdog fire faster than the hrtimer which is used to verify. Slightly larger than the minimal fix, which just would increase the hrtimer frequency, but comes with extra overhead of more watchdog timer interrupts and thread wakeups for all users. With this change we restrict the overhead to the extreme Turbo-Mode systems" * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: kernel/watchdog: Prevent false positives with turbo modes
2017-08-18kernel/watchdog: fix Kconfig constraints for perf hardlockup watchdogNicholas Piggin
Commit 05a4a9527931 ("kernel/watchdog: split up config options") lost the perf-based hardlockup detector's dependency on PERF_EVENTS, which can result in broken builds with some powerpc configurations. Restore the dependency. Add it in for x86 too, despite x86 always selecting PERF_EVENTS it seems reasonable to make the dependency explicit. Link: http://lkml.kernel.org/r/20170810114452.6673-1-npiggin@gmail.com Fixes: 05a4a9527931 ("kernel/watchdog: split up config options") Signed-off-by: Nicholas Piggin <npiggin@gmail.com> Acked-by: Don Zickus <dzickus@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-08-18kernel/watchdog: Prevent false positives with turbo modesThomas Gleixner
The hardlockup detector on x86 uses a performance counter based on unhalted CPU cycles and a periodic hrtimer. The hrtimer period is about 2/5 of the performance counter period, so the hrtimer should fire 2-3 times before the performance counter NMI fires. The NMI code checks whether the hrtimer fired since the last invocation. If not, it assumess a hard lockup. The calculation of those periods is based on the nominal CPU frequency. Turbo modes increase the CPU clock frequency and therefore shorten the period of the perf/NMI watchdog. With extreme Turbo-modes (3x nominal frequency) the perf/NMI period is shorter than the hrtimer period which leads to false positives. A simple fix would be to shorten the hrtimer period, but that comes with the side effect of more frequent hrtimer and softlockup thread wakeups, which is not desired. Implement a low pass filter, which checks the perf/NMI period against kernel time. If the perf/NMI fires before 4/5 of the watchdog period has elapsed then the event is ignored and postponed to the next perf/NMI. That solves the problem and avoids the overhead of shorter hrtimer periods and more frequent softlockup thread wakeups. Fixes: 58687acba592 ("lockup_detector: Combine nmi_watchdog and softlockup detector") Reported-and-tested-by: Kan Liang <Kan.liang@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: dzickus@redhat.com Cc: prarit@redhat.com Cc: ak@linux.intel.com Cc: babu.moger@oracle.com Cc: peterz@infradead.org Cc: eranian@google.com Cc: acme@redhat.com Cc: stable@vger.kernel.org Cc: atomlin@redhat.com Cc: akpm@linux-foundation.org Cc: torvalds@linux-foundation.org Link: http://lkml.kernel.org/r/alpine.DEB.2.20.1708150931310.1886@nanos
2017-08-17locking/refcounts, x86/asm: Implement fast refcount overflow protectionKees Cook
This implements refcount_t overflow protection on x86 without a noticeable performance impact, though without the fuller checking of REFCOUNT_FULL. This is done by duplicating the existing atomic_t refcount implementation but with normally a single instruction added to detect if the refcount has gone negative (e.g. wrapped past INT_MAX or below zero). When detected, the handler saturates the refcount_t to INT_MIN / 2. With this overflow protection, the erroneous reference release that would follow a wrap back to zero is blocked from happening, avoiding the class of refcount-overflow use-after-free vulnerabilities entirely. Only the overflow case of refcounting can be perfectly protected, since it can be detected and stopped before the reference is freed and left to be abused by an attacker. There isn't a way to block early decrements, and while REFCOUNT_FULL stops increment-from-zero cases (which would be the state _after_ an early decrement and stops potential double-free conditions), this fast implementation does not, since it would require the more expensive cmpxchg loops. Since the overflow case is much more common (e.g. missing a "put" during an error path), this protection provides real-world protection. For example, the two public refcount overflow use-after-free exploits published in 2016 would have been rendered unexploitable: http://perception-point.io/2016/01/14/analysis-and-exploitation-of-a-linux-kernel-vulnerability-cve-2016-0728/ http://cyseclabs.com/page?n=02012016 This implementation does, however, notice an unchecked decrement to zero (i.e. caller used refcount_dec() instead of refcount_dec_and_test() and it resulted in a zero). Decrements under zero are noticed (since they will have resulted in a negative value), though this only indicates that a use-after-free may have already happened. Such notifications are likely avoidable by an attacker that has already exploited a use-after-free vulnerability, but it's better to have them reported than allow such conditions to remain universally silent. On first overflow detection, the refcount value is reset to INT_MIN / 2 (which serves as a saturation value) and a report and stack trace are produced. When operations detect only negative value results (such as changing an already saturated value), saturation still happens but no notification is performed (since the value was already saturated). On the matter of races, since the entire range beyond INT_MAX but before 0 is negative, every operation at INT_MIN / 2 will trap, leaving no overflow-only race condition. As for performance, this implementation adds a single "js" instruction to the regular execution flow of a copy of the standard atomic_t refcount operations. (The non-"and_test" refcount_dec() function, which is uncommon in regular refcount design patterns, has an additional "jz" instruction to detect reaching exactly zero.) Since this is a forward jump, it is by default the non-predicted path, which will be reinforced by dynamic branch prediction. The result is this protection having virtually no measurable change in performance over standard atomic_t operations. The error path, located in .text.unlikely, saves the refcount location and then uses UD0 to fire a refcount exception handler, which resets the refcount, handles reporting, and returns to regular execution. This keeps the changes to .text size minimal, avoiding return jumps and open-coded calls to the error reporting routine. Example assembly comparison: refcount_inc() before: .text: ffffffff81546149: f0 ff 45 f4 lock incl -0xc(%rbp) refcount_inc() after: .text: ffffffff81546149: f0 ff 45 f4 lock incl -0xc(%rbp) ffffffff8154614d: 0f 88 80 d5 17 00 js ffffffff816c36d3 ... .text.unlikely: ffffffff816c36d3: 48 8d 4d f4 lea -0xc(%rbp),%rcx ffffffff816c36d7: 0f ff (bad) These are the cycle counts comparing a loop of refcount_inc() from 1 to INT_MAX and back down to 0 (via refcount_dec_and_test()), between unprotected refcount_t (atomic_t), fully protected REFCOUNT_FULL (refcount_t-full), and this overflow-protected refcount (refcount_t-fast): 2147483646 refcount_inc()s and 2147483647 refcount_dec_and_test()s: cycles protections atomic_t 82249267387 none refcount_t-fast 82211446892 overflow, untested dec-to-zero refcount_t-full 144814735193 overflow, untested dec-to-zero, inc-from-zero This code is a modified version of the x86 PAX_REFCOUNT atomic_t overflow defense from the last public patch of PaX/grsecurity, based on my understanding of the code. Changes or omissions from the original code are mine and don't reflect the original grsecurity/PaX code. Thanks to PaX Team for various suggestions for improvement for repurposing this code to be a refcount-only protection. Signed-off-by: Kees Cook <keescook@chromium.org> Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Christoph Hellwig <hch@infradead.org> Cc: David S. Miller <davem@davemloft.net> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Elena Reshetova <elena.reshetova@intel.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Greg KH <gregkh@linuxfoundation.org> Cc: Hans Liljestrand <ishkamiel@gmail.com> Cc: James Bottomley <James.Bottomley@hansenpartnership.com> Cc: Jann Horn <jannh@google.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Serge E. Hallyn <serge@hallyn.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: arozansk@redhat.com Cc: axboe@kernel.dk Cc: kernel-hardening@lists.openwall.com Cc: linux-arch <linux-arch@vger.kernel.org> Link: http://lkml.kernel.org/r/20170815161924.GA133115@beast Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-08-01x86/intel_rdt: Introduce a common compile option for RDTVikas Shivappa
We currently have a CONFIG_RDT_A which is for RDT(Resource directory technology) allocation based resctrl filesystem interface. As a preparation to add support for RDT monitoring as well into the same resctrl filesystem, change the config option to be CONFIG_RDT which would include both RDT allocation and monitoring code. No functional change. Signed-off-by: Vikas Shivappa <vikas.shivappa@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: ravi.v.shankar@intel.com Cc: tony.luck@intel.com Cc: fenghua.yu@intel.com Cc: peterz@infradead.org Cc: eranian@google.com Cc: vikas.shivappa@intel.com Cc: ak@linux.intel.com Cc: davidcc@google.com Cc: reinette.chatre@intel.com Link: http://lkml.kernel.org/r/1501017287-28083-4-git-send-email-vikas.shivappa@linux.intel.com
2017-07-26x86/kconfig: Consolidate unwinders into multiple choice selectionJosh Poimboeuf
There are three mutually exclusive unwinders. Make that more obvious by combining them into a multiple-choice selection: CONFIG_FRAME_POINTER_UNWINDER CONFIG_ORC_UNWINDER CONFIG_GUESS_UNWINDER (if CONFIG_EXPERT=y) Frame pointers are still the default (for now). The old CONFIG_FRAME_POINTER option is still used in some arch-independent places, so keep it around, but make it invisible to the user on x86 - it's now selected by CONFIG_FRAME_POINTER_UNWINDER=y. Suggested-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: live-patching@vger.kernel.org Link: http://lkml.kernel.org/r/20170725135424.zukjmgpz3plf5pmt@treble Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-07-26x86/unwind: Add the ORC unwinderJosh Poimboeuf
Add the new ORC unwinder which is enabled by CONFIG_ORC_UNWINDER=y. It plugs into the existing x86 unwinder framework. It relies on objtool to generate the needed .orc_unwind and .orc_unwind_ip sections. For more details on why ORC is used instead of DWARF, see Documentation/x86/orc-unwinder.txt - but the short version is that it's a simplified, fundamentally more robust debugninfo data structure, which also allows up to two orders of magnitude faster lookups than the DWARF unwinder - which matters to profiling workloads like perf. Thanks to Andy Lutomirski for the performance improvement ideas: splitting the ORC unwind table into two parallel arrays and creating a fast lookup table to search a subset of the unwind table. Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: live-patching@vger.kernel.org Link: http://lkml.kernel.org/r/0a6cbfb40f8da99b7a45a1a8302dc6aef16ec812.1500938583.git.jpoimboe@redhat.com [ Extended the changelog. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-07-21x86: Enable 5-level paging support via CONFIG_X86_5LEVEL=yKirill A. Shutemov
Most of things are in place and we can enable support for 5-level paging. The patch makes XEN_PV and XEN_PVH dependent on !X86_5LEVEL. Both are not ready to work with 5-level paging. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reviewed-by: Juergen Gross <jgross@suse.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/20170716225954.74185-9-kirill.shutemov@linux.intel.com [ Minor readability edits. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-07-18x86/mm: Extend early_memremap() support with additional attrsTom Lendacky
Add early_memremap() support to be able to specify encrypted and decrypted mappings with and without write-protection. The use of write-protection is necessary when encrypting data "in place". The write-protect attribute is considered cacheable for loads, but not stores. This implies that the hardware will never give the core a dirty line with this memtype. Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Borislav Petkov <bp@suse.de> Cc: Alexander Potapenko <glider@google.com> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Borislav Petkov <bp@alien8.de> Cc: Brijesh Singh <brijesh.singh@amd.com> Cc: Dave Young <dyoung@redhat.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Matt Fleming <matt@codeblueprint.co.uk> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Radim Krčmář <rkrcmar@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Toshimitsu Kani <toshi.kani@hpe.com> Cc: kasan-dev@googlegroups.com Cc: kvm@vger.kernel.org Cc: linux-arch@vger.kernel.org Cc: linux-doc@vger.kernel.org Cc: linux-efi@vger.kernel.org Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/479b5832c30fae3efa7932e48f81794e86397229.1500319216.git.thomas.lendacky@amd.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-07-18x86/mm: Add Secure Memory Encryption (SME) supportTom Lendacky
Add support for Secure Memory Encryption (SME). This initial support provides a Kconfig entry to build the SME support into the kernel and defines the memory encryption mask that will be used in subsequent patches to mark pages as encrypted. Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Borislav Petkov <bp@suse.de> Cc: Alexander Potapenko <glider@google.com> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Borislav Petkov <bp@alien8.de> Cc: Brijesh Singh <brijesh.singh@amd.com> Cc: Dave Young <dyoung@redhat.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Matt Fleming <matt@codeblueprint.co.uk> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Radim Krčmář <rkrcmar@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Toshimitsu Kani <toshi.kani@hpe.com> Cc: kasan-dev@googlegroups.com Cc: kvm@vger.kernel.org Cc: linux-arch@vger.kernel.org Cc: linux-doc@vger.kernel.org Cc: linux-efi@vger.kernel.org Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/a6c34d16caaed3bc3e2d6f0987554275bd291554.1500319216.git.thomas.lendacky@amd.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-07-12include/linux/string.h: add the option of fortified string.h functionsDaniel Micay
This adds support for compiling with a rough equivalent to the glibc _FORTIFY_SOURCE=1 feature, providing compile-time and runtime buffer overflow checks for string.h functions when the compiler determines the size of the source or destination buffer at compile-time. Unlike glibc, it covers buffer reads in addition to writes. GNU C __builtin_*_chk intrinsics are avoided because they would force a much more complex implementation. They aren't designed to detect read overflows and offer no real benefit when using an implementation based on inline checks. Inline checks don't add up to much code size and allow full use of the regular string intrinsics while avoiding the need for a bunch of _chk functions and per-arch assembly to avoid wrapper overhead. This detects various overflows at compile-time in various drivers and some non-x86 core kernel code. There will likely be issues caught in regular use at runtime too. Future improvements left out of initial implementation for simplicity, as it's all quite optional and can be done incrementally: * Some of the fortified string functions (strncpy, strcat), don't yet place a limit on reads from the source based on __builtin_object_size of the source buffer. * Extending coverage to more string functions like strlcat. * It should be possible to optionally use __builtin_object_size(x, 1) for some functions (C strings) to detect intra-object overflows (like glibc's _FORTIFY_SOURCE=2), but for now this takes the conservative approach to avoid likely compatibility issues. * The compile-time checks should be made available via a separate config option which can be enabled by default (or always enabled) once enough time has passed to get the issues it catches fixed. Kees said: "This is great to have. While it was out-of-tree code, it would have blocked at least CVE-2016-3858 from being exploitable (improper size argument to strlcpy()). I've sent a number of fixes for out-of-bounds-reads that this detected upstream already" [arnd@arndb.de: x86: fix fortified memcpy] Link: http://lkml.kernel.org/r/20170627150047.660360-1-arnd@arndb.de [keescook@chromium.org: avoid panic() in favor of BUG()] Link: http://lkml.kernel.org/r/20170626235122.GA25261@beast [keescook@chromium.org: move from -mm, add ARCH_HAS_FORTIFY_SOURCE, tweak Kconfig help] Link: http://lkml.kernel.org/r/20170526095404.20439-1-danielmicay@gmail.com Link: http://lkml.kernel.org/r/1497903987-21002-8-git-send-email-keescook@chromium.org Signed-off-by: Daniel Micay <danielmicay@gmail.com> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Kees Cook <keescook@chromium.org> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Daniel Axtens <dja@axtens.net> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-07-12kernel/watchdog: split up config optionsNicholas Piggin
Split SOFTLOCKUP_DETECTOR from LOCKUP_DETECTOR, and split HARDLOCKUP_DETECTOR_PERF from HARDLOCKUP_DETECTOR. LOCKUP_DETECTOR implies the general boot, sysctl, and programming interfaces for the lockup detectors. An architecture that wants to use a hard lockup detector must define HAVE_HARDLOCKUP_DETECTOR_PERF or HAVE_HARDLOCKUP_DETECTOR_ARCH. Alternatively an arch can define HAVE_NMI_WATCHDOG, which provides the minimum arch_touch_nmi_watchdog, and it otherwise does its own thing and does not implement the LOCKUP_DETECTOR interfaces. sparc is unusual in that it has started to implement some of the interfaces, but not fully yet. It should probably be converted to a full HAVE_HARDLOCKUP_DETECTOR_ARCH. [npiggin@gmail.com: fix] Link: http://lkml.kernel.org/r/20170617223522.66c0ad88@roar.ozlabs.ibm.com Link: http://lkml.kernel.org/r/20170616065715.18390-4-npiggin@gmail.com Signed-off-by: Nicholas Piggin <npiggin@gmail.com> Reviewed-by: Don Zickus <dzickus@redhat.com> Reviewed-by: Babu Moger <babu.moger@oracle.com> Tested-by: Babu Moger <babu.moger@oracle.com> [sparc] Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-07-07Merge tag 'powerpc-4.13-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc updates from Michael Ellerman: "Highlights include: - Support for STRICT_KERNEL_RWX on 64-bit server CPUs. - Platform support for FSP2 (476fpe) board - Enable ZONE_DEVICE on 64-bit server CPUs. - Generic & powerpc spin loop primitives to optimise busy waiting - Convert VDSO update function to use new update_vsyscall() interface - Optimisations to hypercall/syscall/context-switch paths - Improvements to the CPU idle code on Power8 and Power9. As well as many other fixes and improvements. Thanks to: Akshay Adiga, Andrew Donnellan, Andrew Jeffery, Anshuman Khandual, Anton Blanchard, Balbir Singh, Benjamin Herrenschmidt, Christophe Leroy, Christophe Lombard, Colin Ian King, Dan Carpenter, Gautham R. Shenoy, Hari Bathini, Ian Munsie, Ivan Mikhaylov, Javier Martinez Canillas, Madhavan Srinivasan, Masahiro Yamada, Matt Brown, Michael Neuling, Michal Suchanek, Murilo Opsfelder Araujo, Naveen N. Rao, Nicholas Piggin, Oliver O'Halloran, Paul Mackerras, Pavel Machek, Russell Currey, Santosh Sivaraj, Stephen Rothwell, Thiago Jung Bauermann, Yang Li" * tag 'powerpc-4.13-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (158 commits) powerpc/Kconfig: Enable STRICT_KERNEL_RWX for some configs powerpc/mm/radix: Implement STRICT_RWX/mark_rodata_ro() for Radix powerpc/mm/hash: Implement mark_rodata_ro() for hash powerpc/vmlinux.lds: Align __init_begin to 16M powerpc/lib/code-patching: Use alternate map for patch_instruction() powerpc/xmon: Add patch_instruction() support for xmon powerpc/kprobes/optprobes: Use patch_instruction() powerpc/kprobes: Move kprobes over to patch_instruction() powerpc/mm/radix: Fix execute permissions for interrupt_vectors powerpc/pseries: Fix passing of pp0 in updatepp() and updateboltedpp() powerpc/64s: Blacklist rtas entry/exit from kprobes powerpc/64s: Blacklist functions invoked on a trap powerpc/64s: Un-blacklist system_call() from kprobes powerpc/64s: Move system_call() symbol to just after setting MSR_EE powerpc/64s: Blacklist system_call() and system_call_common() from kprobes powerpc/64s: Convert .L__replay_interrupt_return to a local label powerpc64/elfv1: Only dereference function descriptor for non-text symbols cxl: Export library to support IBM XSL powerpc/dts: Use #include "..." to include local DT powerpc/perf/hv-24x7: Aggregate result elements on POWER9 SMT8 ...
2017-07-07Merge tag 'libnvdimm-for-4.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm Pull libnvdimm updates from Dan Williams: "libnvdimm updates for the latest ACPI and UEFI specifications. This pull request also includes new 'struct dax_operations' enabling to undo the abuse of copy_user_nocache() for copy operations to pmem. The dax work originally missed 4.12 to address concerns raised by Al. Summary: - Introduce the _flushcache() family of memory copy helpers and use them for persistent memory write operations on x86. The _flushcache() semantic indicates that the cache is either bypassed for the copy operation (movnt) or any lines dirtied by the copy operation are written back (clwb, clflushopt, or clflush). - Extend dax_operations with ->copy_from_iter() and ->flush() operations. These operations and other infrastructure updates allow all persistent memory specific dax functionality to be pushed into libnvdimm and the pmem driver directly. It also allows dax-specific sysfs attributes to be linked to a host device, for example: /sys/block/pmem0/dax/write_cache - Add support for the new NVDIMM platform/firmware mechanisms introduced in ACPI 6.2 and UEFI 2.7. This support includes the v1.2 namespace label format, extensions to the address-range-scrub command set, new error injection commands, and a new BTT (block-translation-table) layout. These updates support inter-OS and pre-OS compatibility. - Fix a longstanding memory corruption bug in nfit_test. - Make the pmem and nvdimm-region 'badblocks' sysfs files poll(2) capable. - Miscellaneous fixes and small updates across libnvdimm and the nfit driver. Acknowledgements that came after the branch was pushed: commit 6aa734a2f38e ("libnvdimm, region, pmem: fix 'badblocks' sysfs_get_dirent() reference lifetime") was reviewed by Toshi Kani <toshi.kani@hpe.com>" * tag 'libnvdimm-for-4.13' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (42 commits) libnvdimm, namespace: record 'lbasize' for pmem namespaces acpi/nfit: Issue Start ARS to retrieve existing records libnvdimm: New ACPI 6.2 DSM functions acpi, nfit: Show bus_dsm_mask in sysfs libnvdimm, acpi, nfit: Add bus level dsm mask for pass thru. acpi, nfit: Enable DSM pass thru for root functions. libnvdimm: passthru functions clear to send libnvdimm, btt: convert some info messages to warn/err libnvdimm, region, pmem: fix 'badblocks' sysfs_get_dirent() reference lifetime libnvdimm: fix the clear-error check in nsio_rw_bytes libnvdimm, btt: fix btt_rw_page not returning errors acpi, nfit: quiet invalid block-aperture-region warnings libnvdimm, btt: BTT updates for UEFI 2.7 format acpi, nfit: constify *_attribute_group libnvdimm, pmem: disable dax flushing when pmem is fronting a volatile region libnvdimm, pmem, dax: export a cache control attribute dax: convert to bitmask for flags dax: remove default copy_from_iter fallback libnvdimm, nfit: enable support for volatile ranges libnvdimm, pmem: fix persistence warning ...
2017-07-06mm/hugetlb: clean up ARCH_HAS_GIGANTIC_PAGEAneesh Kumar K.V
This moves the #ifdef in C code to a Kconfig dependency. Also we move the gigantic_page_supported() function to be arch specific. This allows architectures to conditionally enable runtime allocation of gigantic huge page. Architectures like ppc64 supports different gigantic huge page size (16G and 1G) based on the translation mode selected. This provides an opportunity for ppc64 to enable runtime allocation only w.r.t 1G hugepage. No functional change in this patch. Link: http://lkml.kernel.org/r/1494995292-4443-1-git-send-email-aneesh.kumar@linux.vnet.ibm.com Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-07-06mm, THP, swap: delay splitting THP during swap outHuang Ying
Patch series "THP swap: Delay splitting THP during swapping out", v11. This patchset is to optimize the performance of Transparent Huge Page (THP) swap. Recently, the performance of the storage devices improved so fast that we cannot saturate the disk bandwidth with single logical CPU when do page swap out even on a high-end server machine. Because the performance of the storage device improved faster than that of single logical CPU. And it seems that the trend will not change in the near future. On the other hand, the THP becomes more and more popular because of increased memory size. So it becomes necessary to optimize THP swap performance. The advantages of the THP swap support include: - Batch the swap operations for the THP to reduce lock acquiring/releasing, including allocating/freeing the swap space, adding/deleting to/from the swap cache, and writing/reading the swap space, etc. This will help improve the performance of the THP swap. - The THP swap space read/write will be 2M sequential IO. It is particularly helpful for the swap read, which are usually 4k random IO. This will improve the performance of the THP swap too. - It will help the memory fragmentation, especially when the THP is heavily used by the applications. The 2M continuous pages will be free up after THP swapping out. - It will improve the THP utilization on the system with the swap turned on. Because the speed for khugepaged to collapse the normal pages into the THP is quite slow. After the THP is split during the swapping out, it will take quite long time for the normal pages to collapse back into the THP after being swapped in. The high THP utilization helps the efficiency of the page based memory management too. There are some concerns regarding THP swap in, mainly because possible enlarged read/write IO size (for swap in/out) may put more overhead on the storage device. To deal with that, the THP swap in should be turned on only when necessary. For example, it can be selected via "always/never/madvise" logic, to be turned on globally, turned off globally, or turned on only for VMA with MADV_HUGEPAGE, etc. This patchset is the first step for the THP swap support. The plan is to delay splitting THP step by step, finally avoid splitting THP during the THP swapping out and swap out/in the THP as a whole. As the first step, in this patchset, the splitting huge page is delayed from almost the first step of swapping out to after allocating the swap space for the THP and adding the THP into the swap cache. This will reduce lock acquiring/releasing for the locks used for the swap cache management. With the patchset, the swap out throughput improves 15.5% (from about 3.73GB/s to about 4.31GB/s) in the vm-scalability swap-w-seq test case with 8 processes. The test is done on a Xeon E5 v3 system. The swap device used is a RAM simulated PMEM (persistent memory) device. To test the sequential swapping out, the test case creates 8 processes, which sequentially allocate and write to the anonymous pages until the RAM and part of the swap device is used up. This patch (of 5): In this patch, splitting huge page is delayed from almost the first step of swapping out to after allocating the swap space for the THP (Transparent Huge Page) and adding the THP into the swap cache. This will batch the corresponding operation, thus improve THP swap out throughput. This is the first step for the THP swap optimization. The plan is to delay splitting the THP step by step and avoid splitting the THP finally. In this patch, one swap cluster is used to hold the contents of each THP swapped out. So, the size of the swap cluster is changed to that of the THP (Transparent Huge Page) on x86_64 architecture (512). For other architectures which want such THP swap optimization, ARCH_USES_THP_SWAP_CLUSTER needs to be selected in the Kconfig file for the architecture. In effect, this will enlarge swap cluster size by 2 times on x86_64. Which may make it harder to find a free cluster when the swap space becomes fragmented. So that, this may reduce the continuous swap space allocation and sequential write in theory. The performance test in 0day shows no regressions caused by this. In the future of THP swap optimization, some information of the swapped out THP (such as compound map count) will be recorded in the swap_cluster_info data structure. The mem cgroup swap accounting functions are enhanced to support charge or uncharge a swap cluster backing a THP as a whole. The swap cluster allocate/free functions are added to allocate/free a swap cluster for a THP. A fair simple algorithm is used for swap cluster allocation, that is, only the first swap device in priority list will be tried to allocate the swap cluster. The function will fail if the trying is not successful, and the caller will fallback to allocate a single swap slot instead. This works good enough for normal cases. If the difference of the number of the free swap clusters among multiple swap devices is significant, it is possible that some THPs are split earlier than necessary. For example, this could be caused by big size difference among multiple swap devices. The swap cache functions is enhanced to support add/delete THP to/from the swap cache as a set of (HPAGE_PMD_NR) sub-pages. This may be enhanced in the future with multi-order radix tree. But because we will split the THP soon during swapping out, that optimization doesn't make much sense for this first step. The THP splitting functions are enhanced to support to split THP in swap cache during swapping out. The page lock will be held during allocating the swap cluster, adding the THP into the swap cache and splitting the THP. So in the code path other than swapping out, if the THP need to be split, the PageSwapCache(THP) will be always false. The swap cluster is only available for SSD, so the THP swap optimization in this patchset has no effect for HDD. [ying.huang@intel.com: fix two issues in THP optimize patch] Link: http://lkml.kernel.org/r/87k25ed8zo.fsf@yhuang-dev.intel.com [hannes@cmpxchg.org: extensive cleanups and simplifications, reduce code size] Link: http://lkml.kernel.org/r/20170515112522.32457-2-ying.huang@intel.com Signed-off-by: "Huang, Ying" <ying.huang@intel.com> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Suggested-by: Andrew Morton <akpm@linux-foundation.org> [for config option] Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> [for changes in huge_memory.c and huge_mm.h] Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Ebru Akagunduz <ebru.akagunduz@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@kernel.org> Cc: Tejun Heo <tj@kernel.org> Cc: Hugh Dickins <hughd@google.com> Cc: Shaohua Li <shli@kernel.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-07-03Merge branch 'ras-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RAS updates from Thomas Gleixner: "The RAS updates for the 4.13 merge window: - Cleanup of the MCE injection facility (Borsilav Petkov) - Rework of the AMD/SMCA handling (Yazen Ghannam) - Enhancements for ACPI/APEI to handle new notitication types (Shiju Jose) - atomic_t to refcount_t conversion (Elena Reshetova) - A few fixes and enhancements all over the place" * 'ras-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: RAS/CEC: Check the correct variable in the debugfs error handling x86/mce: Always save severity in machine_check_poll() x86/MCE, xen/mcelog: Make /dev/mcelog registration messages more precise x86/mce: Update bootlog description to reflect behavior on AMD x86/mce: Don't disable MCA banks when offlining a CPU on AMD x86/mce/mce-inject: Preset the MCE injection struct x86/mce: Clean up include files x86/mce: Get rid of register_mce_write_callback() x86/mce: Merge mce_amd_inj into mce-inject x86/mce/AMD: Use saved threshold block info in interrupt handler x86/mce/AMD: Use msr_stat when clearing MCA_STATUS x86/mce/AMD: Carve out SMCA bank configuration x86/mce/AMD: Redo error logging from APIC LVT interrupt handlers x86/mce: Convert threshold_bank.cpus from atomic_t to refcount_t RAS: Make local function parse_ras_param() static ACPI/APEI: Handle GSIV and GPIO notification types
2017-07-03Merge branch 'x86-platform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 PCI updates from Thomas Gleixner: "This update provides the seperation of x86 PCI accessors from the global PCI lock in the generic PCI config space accessors. The reasons for this are: - x86 has it's own PCI config lock for various reasons, so the accessors have to lock two locks nested. - The ECAM (mmconfig) access to the extended configuration space does not require locking. The existing generic locking causes a massive lock contention when accessing the extended config space of the Uncore facility for performance monitoring. The commit which switched the access to the primary config space over to ECAM mode has been removed from the branch, so the primary config space is still accessed with type1 accessors properly serialized by the x86 internal locking. Bjorn agreed on merging this through the x86 tree" * 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/PCI: Select CONFIG_PCI_LOCKLESS_CONFIG PCI: Provide Kconfig option for lockless config space accessors x86/PCI/ce4100: Properly lock accessor functions x86/PCI: Abort if legacy init fails x86/PCI: Remove duplicate defines
