path: root/arch/x86/Makefile
2008-04-17x86: add subarch support (for headers) to x86_64Glauber de Oliveira Costa
this patch allows x86_64 to use subarch mach_ headers in practice, since x86_64 does not have any subarch, it will use mach_default. But it will allow for substantially less code duplication Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: introduce kernel/head32.cEric W. Biederman
Copy x86_64 and add a head32.c so we can start moving early architecture initialization out of assembly. [ Sam Ravnborg <sam@ravnborg.org>: updated it to x86 ] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-19x86: fix vdso_install breaks user "make install"Sam Ravnborg
I suggest to make the vdso_install step independent as in following patch. This solves the issue at ahnd and still gives us the posibility to install the files should they be needed. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-09x86 PM: move 64-bit hibernation files to arch/x86/powerRafael J. Wysocki
Move arch/x86/kernel/suspend_64.c to arch/x86/power . Move arch/x86/kernel/suspend_asm_64.S to arch/x86/power as hibernate_asm_64.S . Update purpose and copyright information in arch/x86/power/suspend_64.c and arch/x86/power/hibernate_asm_64.S . Update the Makefiles in arch/x86, arch/x86/kernel and arch/x86/power to reflect the above changes. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-04x86: define OBJCOPYFLAGS explicitly for each target.Ian Campbell
Do this rather than defining a global version and overriding it in almost all cases in order to make subsequent patches simpler. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-01fix directory entry in arch-x86-MakefileSteven Rostedt
Doing a make randconfig I came across this error in the Makefile. This patch makes a directory out of arch/x86/mach-default for CONFIG_X86_RDC321X Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-30KVM: Move arch dependent files to new directory arch/x86/kvm/Avi Kivity
This paves the way for multiple architecture support. Note that while ioapic.c could potentially be shared with ia64, it is also moved. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30x86: add support for the RDC R-321x SoCFlorian Fainelli
This patch adds support for the RDC R-321x system-on-chip, also known as R-861x-(G). It uses the generic GPIO API and has support for the on-chip hardware watchdog. Build-fix from: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Florian Fainelli <florian.fainelli@telecomint.eu> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: document fdimage/isoimage completely in make helpAndi Kleen
Add missing targets and missing options in x86 make help [ mingo@elte.hu: more whitespace cleanups ] Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: biarch support for 32 bit builds beautifiedSam Ravnborg
There were no reason to mess around with CC, AS and LD. Fixing this up avoided duplicated option for ld. A small fixlet were needed in boot/Makefile which assumed that CC were modified. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: share more options between 32 and 64 bit buildSam Ravnborg
On recommendation from Andi Kleen share a few more options between 32 and 64 bit builds. A defconfig build for i386 did not show any difference in size of text and data. The additional shared options are: -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: unification of arch/x86/MakefilesSam Ravnborg
Unify the 32 and 64 bit specific Makefiles. The unification was simplest to do in one step although the readability of the patch suffers a bit from this. Noteworthy remarks on the unification: - The 64 bit cpu stuff should be moved to Makefile_32.cpu but I did not feel confident doing it due to subtle differences - The use of cflags-y were abandoned since we have seen one bug where we did wrong due to missing assignment to KBUILD_CFLAGS. The cc-option marcro uses KBUILD_CFLAGS. - The "No need to remake" line are deleted. It caused "make -B" to fail - For 64 bit the sub architecture stuff is not used. - The way head64.o is specified could be nicer - but it awaits the introduction of head32.o (which seems like a win to introduce for readability) - Patch is checkpatch clean Patch is tested by doing a defconfig build for i386 and x86_64 and in both cases monitoring that only relevant files were recompiled when applying the patch. [ mingo@elte.hu: build fix ] Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-11-26x86: correctly set UTS_MACHINE for "make ARCH=x86"Andreas Herrmann
For a kernel built with "make ARCH=x86" the following system information is displayed when running the new kernel $ uname -m x86 On some i386 systems (e.g. K7) we even have the following information $ uname -m x66 This is weird. The usual information for "uname -m" should be "x86_64" on 64-bit and "i386" or "i686" on 32-bit. This patch fixes the issue by setting UTS_MACHINE to "i386" for 32-bit kernel builds and to "x86_64" for 64-bit kernel builds. I.e., "x86" won't be used for UTS_MACHINE anymore. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andreas Herrmann <aherrman@arcor.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-12x86: do not use $(ARCH) when not neededSam Ravnborg
For x86 ARCH may say i386 or x86_64 and soon x86. Rely on CONFIG_X64_32 to select between 32/64 or just hardcode the value as appropriate. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com>
2007-10-25x86: move defconfig files for i386 and x86_64 to x86Sam Ravnborg
With some small changes to kconfig makefile we can now locate the defconfig files for i386 and x86_64 in the configs/ subdirectory under x86. make ARCH=i386 defconfig and make defconfig works as expected also after this change. But arch maintainers shall now update a defconfig file in the configs/ directory. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-25x86: move i386 and x86_64 Makefiles to arch/x86Sam Ravnborg
Moving the ARCH specific Makefiles for i386 and x86_64 required a litle bit tweaking in the top-lvel Makefile. SRCARCH is now set in the top-level Makefile because we need this info to include the correct arch Makefile. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
