commit cd01544a268ad8ee5b1dfe42c4393f1095f86879 upstream.
Commit
379d98ddf413 ("x86: vdso: Use $LD instead of $CC to link")
accidentally broke unwinding from userspace, because ld would strip the
.eh_frame sections when linking.
Originally, the compiler would implicitly add --eh-frame-hdr when
invoking the linker, but when this Makefile was converted from invoking
ld via the compiler, to invoking it directly (like vmlinux does),
the flag was missed. (The EH_FRAME section is important for the VDSO
shared libraries, but not for vmlinux.)
Fix the problem by explicitly specifying --eh-frame-hdr, which restores
parity with the old method.
See relevant bug reports for additional info:
https://bugzilla.kernel.org/show_bug.cgi?id=201741
https://bugzilla.redhat.com/show_bug.cgi?id=1659295
Fixes: 379d98ddf413 ("x86: vdso: Use $LD instead of $CC to link")
Reported-by: Florian Weimer <fweimer@redhat.com>
Reported-by: Carlos O'Donell <carlos@redhat.com>
Reported-by: "H. J. Lu" <hjl.tools@gmail.com>
Signed-off-by: Alistair Strachan <astrachan@google.com>
Tested-by: Laura Abbott <labbott@redhat.com>
Cc: Carlos O'Donell <carlos@redhat.com>
Cc: Joel Fernandes <joel@joelfernandes.org>
Cc: kernel-team@android.com
Cc: Laura Abbott <labbott@redhat.com>
Cc: stable <stable@vger.kernel.org>
Cc: X86 ML <x86@kernel.org>
Link: https://lkml.kernel.org/r/20181214223637.35954-1-astrachan@google.com
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro1.iwamatsu@toshiba.co.jp>
commit ac3e233d29f7f77f28243af0132057d378d3ea58 upstream.
GNU linker's -z common-page-size's default value is based on the target
architecture. arch/x86/entry/vdso/Makefile sets it to the architecture
default, which is implicit and redundant. Drop it.
Fixes: 2aae950b21e4 ("x86_64: Add vDSO for x86-64 with gettimeofday/clock_gettime/getcpu")
Reported-by: Dmitry Golovin <dima@golovin.in>
Reported-by: Bill Wendling <morbo@google.com>
Suggested-by: Dmitry Golovin <dima@golovin.in>
Suggested-by: Rui Ueyama <ruiu@google.com>
Signed-off-by: Nick Desaulniers <ndesaulniers@google.com>
Acked-by: Andy Lutomirski <luto@kernel.org>
Cc: Fangrui Song <maskray@google.com>
Cc: x86-ml <x86@kernel.org>
Link: https://lkml.kernel.org/r/20181206191231.192355-1-ndesaulniers@google.com
Link: https://bugs.llvm.org/show_bug.cgi?id=38774
Link: https://github.com/ClangBuiltLinux/linux/issues/31
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
commit 379d98ddf41344273d9718556f761420f4dc80b3 upstream.
The vdso{32,64}.so can fail to link with CC=clang when clang tries to find
a suitable GCC toolchain to link these libraries with.
/usr/bin/ld: arch/x86/entry/vdso/vclock_gettime.o:
access beyond end of merged section (782)
This happens because the host environment leaked into the cross compiler
environment due to the way clang searches for suitable GCC toolchains.
Clang is a retargetable compiler, and each invocation of it must provide
--target=<something> --gcc-toolchain=<something> to allow it to find the
correct binutils for cross compilation. These flags had been added to
KBUILD_CFLAGS, but the vdso code uses CC and not KBUILD_CFLAGS (for various
reasons) which breaks clang's ability to find the correct linker when cross
compiling.
Most of the time this goes unnoticed because the host linker is new enough
to work anyway, or is incompatible and skipped, but this cannot be reliably
assumed.
This change alters the vdso makefile to just use LD directly, which
bypasses clang and thus the searching problem. The makefile will just use
${CROSS_COMPILE}ld instead, which is always what we want. This matches the
method used to link vmlinux.
This drops references to DISABLE_LTO; this option doesn't seem to be set
anywhere, and not knowing what its possible values are, it's not clear how
to convert it from CC to LD flag.
Cc: joel@joelfernandes.org
Cc: Andi Kleen <andi.kleen@intel.com>
Link: https://lkml.kernel.org/r/20180803173931.117515-1-astrachan@google.com
This reverts commit 94c0c4f033eee2304a98cf30a141f9dae35d3a62.
The commit message in the 4.9 stable tree did not have a reference to
the upstream commit id.
This reverts commit 408d67a0fecf4cfe7869f518211ae278ee44376e.
compiling.
assumed.
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild updates from Michal Marek:
- GCC plugin support by Emese Revfy from grsecurity, with a fixup from
Kees Cook. The plugins are meant to be used for static analysis of
the kernel code. Two plugins are provided already.
- reduction of the gcc commandline by Arnd Bergmann.
- IS_ENABLED / IS_REACHABLE macro enhancements by Masahiro Yamada
- bin2c fix by Michael Tautschnig
- setlocalversion fix by Wolfram Sang
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
gcc-plugins: disable under COMPILE_TEST
kbuild: Abort build on bad stack protector flag
scripts: Fix size mismatch of kexec_purgatory_size
kbuild: make samples depend on headers_install
Kbuild: don't add obj tree in additional includes
Kbuild: arch: look for generated headers in obtree
Kbuild: always prefix objtree in LINUXINCLUDE
Kbuild: avoid duplicate include path
Kbuild: don't add ../../ to include path
vmlinux.lds.h: replace config_enabled() with IS_ENABLED()
kconfig.h: allow to use IS_{ENABLE,REACHABLE} in macro expansion
kconfig.h: use already defined macros for IS_REACHABLE() define
export.h: use __is_defined() to check if __KSYM_* is defined
kconfig.h: use __is_defined() to check if MODULE is defined
kbuild: setlocalversion: print error to STDERR
Add sancov plugin
Add Cyclomatic complexity GCC plugin
GCC plugin infrastructure
Shared library support
Pull perf fixes from Ingo Molnar:
"This tree contains tooling fixes plus some additions:
- fixes to the vdso2c build environment that Stephen Rothwell is
using for the linux-next build (Arnaldo Carvalho de Melo)
- AVX-512 instruction mappings (Adrian Hunter)
- misc fixes"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
Revert "perf tools: event.h needs asm/perf_regs.h"
x86: Make the vdso2c compiler use the host architecture headers
tools build: Fix objtool build with ARCH=x86_64
objtool: Always use host headers
objtool: Use tools/scripts/Makefile.arch to get ARCH and HOSTARCH
tools build: Add HOSTARCH Makefile variable
perf tests kmod-path: Fix build on ubuntu:16.04-x-armhf
perf tools: Add AVX-512 instructions to the new instructions test
perf tools: Add AVX-512 support to the instruction decoder used by Intel PT
x86/insn: Add AVX-512 support to the instruction decoder
x86/insn: perf tools: Fix vcvtph2ps instruction decoding
To be clear: this is a ppc64le hosted, x86_64 target cross build.
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Link: http://lkml.kernel.org/r/20160723150845.3af8e452@canb.auug.org.au
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
sigreturn.S was historically included by the various
__kernel_vsyscall implementations due to assumptions about all the
32-bit vDSO images having the sigreturn symbols at the same address.
Those assumptions were removed in v3.16, and as of v4.4, there is only
a single 32-bit vDSO left.
Simplify the build process by assembling sigreturn.S into a normal
object file.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Link: http://lkml.kernel.org/r/d7b6dfde3c7397aa26977320da90448363b5a7e9.1465505753.git.luto@kernel.org
This patch allows to build the whole kernel with GCC plugins. It was ported from
grsecurity/PaX. The infrastructure supports building out-of-tree modules and
building in a separate directory. Cross-compilation is supported too.
Currently the x86, arm, arm64 and uml architectures enable plugins.
The directory of the gcc plugins is scripts/gcc-plugins. You can use a file or a directory
there. The plugins compile with these options:
* -fno-rtti: gcc is compiled with this option so the plugins must use it too
* -fno-exceptions: this is inherited from gcc too
* -fasynchronous-unwind-tables: this is inherited from gcc too
* -ggdb: it is useful for debugging a plugin (better backtrace on internal
errors)
* -Wno-narrowing: to suppress warnings from gcc headers (ipa-utils.h)
* -Wno-unused-variable: to suppress warnings from gcc headers (gcc_version
variable, plugin-version.h)
The infrastructure introduces a new Makefile target called gcc-plugins. It
supports all gcc versions from 4.5 to 6.0. The scripts/gcc-plugin.sh script
chooses the proper host compiler (gcc-4.7 can be built by either gcc or g++).
This script also checks the availability of the included headers in
scripts/gcc-plugins/gcc-common.h.
The gcc-common.h header contains frequently included headers for GCC plugins
and it has a compatibility layer for the supported gcc versions.
The gcc-generate-*-pass.h headers automatically generate the registration
structures for GIMPLE, SIMPLE_IPA, IPA and RTL passes.
Note that 'make clean' keeps the *.so files (only the distclean or mrproper
targets clean all) because they are needed for out-of-tree modules.
Based on work created by the PaX Team.
Signed-off-by: Emese Revfy <re.emese@gmail.com>
Signed-off-by: Michal Marek <mmarek@suse.com>
These targets are marked as PHONY. No need to add FORCE to their
dependency.
kcov provides code coverage collection for coverage-guided fuzzing
(randomized testing). Coverage-guided fuzzing is a testing technique
that uses coverage feedback to determine new interesting inputs to a
system. A notable user-space example is AFL
(http://lcamtuf.coredump.cx/afl/). However, this technique is not
widely used for kernel testing due to missing compiler and kernel
support.
kcov does not aim to collect as much coverage as possible. It aims to
collect more or less stable coverage that is function of syscall inputs.
To achieve this goal it does not collect coverage in soft/hard
interrupts and instrumentation of some inherently non-deterministic or
non-interesting parts of kernel is disbled (e.g. scheduler, locking).
Currently there is a single coverage collection mode (tracing), but the
API anticipates additional collection modes. Initially I also
implemented a second mode which exposes coverage in a fixed-size hash
table of counters (what Quentin used in his original patch). I've
dropped the second mode for simplicity.
This patch adds the necessary support on kernel side. The complimentary
compiler support was added in gcc revision 231296.
We've used this support to build syzkaller system call fuzzer, which has
found 90 kernel bugs in just 2 months:
https://github.com/google/syzkaller/wiki/Found-Bugs
We've also found 30+ bugs in our internal systems with syzkaller.
Another (yet unexplored) direction where kcov coverage would greatly
help is more traditional "blob mutation". For example, mounting a
random blob as a filesystem, or receiving a random blob over wire.
Why not gcov. Typical fuzzing loop looks as follows: (1) reset
coverage, (2) execute a bit of code, (3) collect coverage, repeat. A
typical coverage can be just a dozen of basic blocks (e.g. an invalid
input). In such context gcov becomes prohibitively expensive as
reset/collect coverage steps depend on total number of basic
blocks/edges in program (in case of kernel it is about 2M). Cost of
kcov depends only on number of executed basic blocks/edges. On top of
that, kernel requires per-thread coverage because there are always
background threads and unrelated processes that also produce coverage.
With inlined gcov instrumentation per-thread coverage is not possible.
kcov exposes kernel PCs and control flow to user-space which is
insecure. But debugfs should not be mapped as user accessible.
Based on a patch by Quentin Casasnovas.
[akpm@linux-foundation.org: make task_struct.kcov_mode have type `enum kcov_mode']
[akpm@linux-foundation.org: unbreak allmodconfig]
[akpm@linux-foundation.org: follow x86 Makefile layout standards]
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
Cc: syzkaller <syzkaller@googlegroups.com>
Cc: Vegard Nossum <vegard.nossum@oracle.com>
Cc: Tavis Ormandy <taviso@google.com>
Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Cc: Kostya Serebryany <kcc@google.com>
Cc: Eric Dumazet <edumazet@google.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Kees Cook <keescook@google.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: David Drysdale <drysdale@google.com>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com>
Cc: Kirill A. Shutemov <kirill@shutemov.name>
Cc: Jiri Slaby <jslaby@suse.cz>
Code which runs outside the kernel's normal mode of operation often does
unusual things which can cause a static analysis tool like objtool to
emit false positive warnings:
- boot image
- vdso image
- relocation
- realmode
- efi
- head
- purgatory
- modpost
Set OBJECT_FILES_NON_STANDARD for their related files and directories,
which will tell objtool to skip checking them. It's ok to skip them
because they don't affect runtime stack traces.
Also skip the following code which does the right thing with respect to
frame pointers, but is too "special" to be validated by a tool:
- entry
- mcount
Also skip the test_nx module because it modifies its exception handling
table at runtime, which objtool can't understand. Fortunately it's
just a test module so it doesn't matter much.
Currently objtool is the only user of OBJECT_FILES_NON_STANDARD, but it
might eventually be useful for other tools.
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Bernd Petrovitsch <bernd@petrovitsch.priv.at>
Cc: Chris J Arges <chris.j.arges@canonical.com>
Cc: Michal Marek <mmarek@suse.cz>
Cc: Namhyung Kim <namhyung@gmail.com>
Cc: Pedro Alves <palves@redhat.com>
Cc: live-patching@vger.kernel.org
Link: http://lkml.kernel.org/r/366c080e3844e8a5b6a0327dc7e8c2b90ca3baeb.1456719558.git.jpoimboe@redhat.com
UBSAN uses compile-time instrumentation to catch undefined behavior
(UB). Compiler inserts code that perform certain kinds of checks before
operations that could cause UB. If check fails (i.e. UB detected)
__ubsan_handle_* function called to print error message.
So the most of the work is done by compiler. This patch just implements
ubsan handlers printing errors.
GCC has this capability since 4.9.x [1] (see -fsanitize=undefined
option and its suboptions).
However GCC 5.x has more checkers implemented [2].
Article [3] has a bit more details about UBSAN in the GCC.
[1] - https://gcc.gnu.org/onlinedocs/gcc-4.9.0/gcc/Debugging-Options.html
[2] - https://gcc.gnu.org/onlinedocs/gcc/Debugging-Options.html
[3] - http://developerblog.redhat.com/2014/10/16/gcc-undefined-behavior-sanitizer-ubsan/
Issues which UBSAN has found thus far are:
Found bugs:
* out-of-bounds access - 97840cb67ff5 ("netfilter: nfnetlink: fix
insufficient validation in nfnetlink_bind")
undefined shifts:
* d48458d4a768 ("jbd2: use a better hash function for the revoke
table")
* 10632008b9e1 ("clockevents: Prevent shift out of bounds")
* 'x << -1' shift in ext4 -
http://lkml.kernel.org/r/<5444EF21.8020501@samsung.com>
* undefined rol32(0) -
http://lkml.kernel.org/r/<1449198241-20654-1-git-send-email-sasha.levin@oracle.com>
* undefined dirty_ratelimit calculation -
http://lkml.kernel.org/r/<566594E2.3050306@odin.com>
* undefined roundown_pow_of_two(0) -
http://lkml.kernel.org/r/<1449156616-11474-1-git-send-email-sasha.levin@oracle.com>
* [WONTFIX] undefined shift in __bpf_prog_run -
http://lkml.kernel.org/r/<CACT4Y+ZxoR3UjLgcNdUm4fECLMx2VdtfrENMtRRCdgHB2n0bJA@mail.gmail.com>
WONTFIX here because it should be fixed in bpf program, not in kernel.
signed overflows:
* 32a8df4e0b33f ("sched: Fix odd values in effective_load()
calculations")
* mul overflow in ntp -
http://lkml.kernel.org/r/<1449175608-1146-1-git-send-email-sasha.levin@oracle.com>
* incorrect conversion into rtc_time in rtc_time64_to_tm() -
http://lkml.kernel.org/r/<1449187944-11730-1-git-send-email-sasha.levin@oracle.com>
* unvalidated timespec in io_getevents() -
http://lkml.kernel.org/r/<CACT4Y+bBxVYLQ6LtOKrKtnLthqLHcw-BMp3aqP3mjdAvr9FULQ@mail.gmail.com>
* [NOTABUG] signed overflow in ktime_add_safe() -
http://lkml.kernel.org/r/<CACT4Y+aJ4muRnWxsUe1CMnA6P8nooO33kwG-c8YZg=0Xc8rJqw@mail.gmail.com>
[akpm@linux-foundation.org: fix unused local warning]
[akpm@linux-foundation.org: fix __int128 build woes]
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Yury Gribov <y.gribov@samsung.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Johannes Berg <johannes@sipsolutions.net>
For the vDSO, user code wants runtime unwind info. Make sure
that, if we use .cfi directives, we generate it.
Link: http://lkml.kernel.org/r/16e29ad8855e6508197000d8c41f56adb00d7580.1444091584.git.luto@kernel.org
32-bit userspace will now always see the same vDSO, which is
exactly what used to be the int80 vDSO. Subsequent patches will
clean it up and make it support SYSENTER and SYSCALL using
alternatives.
Link: http://lkml.kernel.org/r/e7e6b3526fa442502e6125fe69486aab50813c32.1444091584.git.luto@kernel.org
Some dynamic loaders may be slightly faster if a GNU hash is
available. Strangely, this seems to have no effect at all on
the vdso size.
This is unlikely to have any measurable effect on the time it
takes to resolve vdso symbols (since there are so few of them).
In some contexts, it can be a win for a different reason: if
every DSO has a GNU hash section, then libc can avoid
calculating SysV hashes at all. Both musl and glibc appear to
have this optimization.
It's plausible that this breaks some ancient glibc version. If
so, then, depending on what glibc versions break, we could
either require COMPAT_VDSO for them or consider reverting.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Cc: Isaac Dunham <ibid.ag@gmail.com>
Cc: Nathan Lynch <nathan_lynch@mentor.com>
Cc: Rich Felker <dalias@libc.org>
Cc: musl@lists.openwall.com <musl@lists.openwall.com>
Link: http://lkml.kernel.org/r/fd56cc057a2d62ab31c56a48d04fccb435b3fd4f.1438897382.git.luto@kernel.org
Build the 32-bit vdso only for native 32-bit or 32-bit compat is
enabled. x32 should not force it to build.
Signed-off-by: Brian Gerst <brgerst@gmail.com>
Link: http://lkml.kernel.org/r/1434974121-32575-7-git-send-email-brgerst@gmail.com
