path: root/arch/x86/include/asm/a.out-core.h
2009-02-10x86: add %gs accessors for x86_32Tejun Heo
Impact: cleanup On x86_32, %gs is handled lazily. It's not saved and restored on kernel entry/exit but only when necessary which usually is during task switch but there are few other places. Currently, it's done by calling savesegment() and loadsegment() explicitly. Define get_user_gs(), set_user_gs() and task_user_gs() and use them instead. While at it, clean up register access macros in signal.c. This cleans up code a bit and will help future changes. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-09x86: include correct %gs in a.out core dumpTejun Heo
Impact: dump the correct %gs into a.out core dump aout_dump_thread() read %gs but didn't include it in core dump. Fix it. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-22x86: Fix ASM_X86__ header guardsH. Peter Anvin
Change header guards named "ASM_X86__*" to "_ASM_X86_*" since: a. the double underscore is ugly and pointless. b. no leading underscore violates namespace constraints. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-10-22x86, um: ... and asm-x86 moveAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
