path: root/arch/x86/include/asm/amd_iommu.h
2011-06-21iommu/amd: Move missing parts to drivers/iommuJoerg Roedel
A few parts of the driver were missing in drivers/iommu. Move them there to have the complete driver in that directory. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2010-10-21Merge branch 'x86-iommu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, iommu: Update header comments with appropriate naming ia64, iommu: Add a dummy iommu_table.h file in IA64. x86, iommu: Fix IOMMU_INIT alignment rules x86, doc: Adding comments about .iommu_table and its neighbors. x86, iommu: Utilize the IOMMU_INIT macros functionality. x86, VT-d: Make Intel VT-d IOMMU use IOMMU_INIT_* macros. x86, GART/AMD-VI: Make AMD GART and IOMMU use IOMMU_INIT_* macros. x86, calgary: Make Calgary IOMMU use IOMMU_INIT_* macros. x86, xen-swiotlb: Make Xen-SWIOTLB use IOMMU_INIT_* macros. x86, swiotlb: Make SWIOTLB use IOMMU_INIT_* macros. x86, swiotlb: Simplify SWIOTLB pci_swiotlb_detect routine. x86, iommu: Add proper dependency sort routine (and sanity check). x86, iommu: Make all IOMMU's detection routines return a value. x86, iommu: Add IOMMU_INIT macros, .iommu_table section, and iommu_table_entry structure
2010-10-13x86/amd-iommu: Update copyright headersJoerg Roedel
This patch updates the copyright headers in all source files of the AMD IOMMU driver. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2010-08-26x86, iommu: Make all IOMMU's detection routines return a value.Konrad Rzeszutek Wilk
We return 1 if the IOMMU has been detected. Zero or an error number if we failed to find it. This is in preperation of using the IOMMU_INIT so that we can detect whether an IOMMU is present. I have not tested this for regression on Calgary, nor on AMD Vi chipsets as I don't have that hardware. CC: Muli Ben-Yehuda <muli@il.ibm.com> CC: "Jon D. Mason" <jdmason@kudzu.us> CC: "Darrick J. Wong" <djwong@us.ibm.com> CC: Jesse Barnes <jbarnes@virtuousgeek.org> CC: David Woodhouse <David.Woodhouse@intel.com> CC: Chris Wright <chrisw@sous-sol.org> CC: Yinghai Lu <yinghai@kernel.org> CC: Joerg Roedel <joerg.roedel@amd.com> CC: H. Peter Anvin <hpa@zytor.com> CC: Fujita Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> LKML-Reference: <1282845485-8991-3-git-send-email-konrad.wilk@oracle.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2009-11-27x86/amd-iommu: Update copyright headersJoerg Roedel
This patch updates the copyright headers in the relevant AMD IOMMU driver files to match the date of the latest changes. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-11-27x86/amd-iommu: Separate internal interface definitionsJoerg Roedel
This patch moves all function declarations which are only used inside the driver code to a seperate header file. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-11-10x86: amd_iommu: Convert amd_iommu_detect() to use iommu_init hookFUJITA Tomonori
This changes amd_iommu_detect() to set amd_iommu_init to iommu_init hook if amd_iommu_detect() finds the AMD IOMMU. We can kill the code to check if we found the IOMMU in amd_iommu_init() since amd_iommu_detect() sets amd_iommu_init() only when it found the IOMMU. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: chrisw@sous-sol.org Cc: dwmw2@infradead.org Cc: joerg.roedel@amd.com Cc: muli@il.ibm.com LKML-Reference: <1257849980-22640-5-git-send-email-fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-08x86: Use x86_platform for iommu_shutdownFUJITA Tomonori
This patch cleans up pci_iommu_shutdown() a bit to use x86_platform (similar to how IA64 initializes an IOMMU driver). This adds iommu_shutdown() to x86_platform to avoid calling every IOMMUs' shutdown functions in pci_iommu_shutdown() in order. The IOMMU shutdown functions are platform specific (we don't have multiple different IOMMU hardware) so the current way is pointless. An IOMMU driver sets x86_platform.iommu_shutdown to the shutdown function if necessary. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: joerg.roedel@amd.com LKML-Reference: <20091027163358F.fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-03Merge branches 'amd-iommu/fixes' and 'dma-debug/fixes' into iommu/fixesJoerg Roedel
2009-10-09x86/amd-iommu: Workaround for erratum 63Joerg Roedel
There is an erratum for IOMMU hardware which documents undefined behavior when forwarding SMI requests from peripherals and the DTE of that peripheral has a sysmgt value of 01b. This problem caused weird IO_PAGE_FAULTS in my case. This patch implements the suggested workaround for that erratum into the AMD IOMMU driver. The erratum is documented with number 63. Cc: stable@kernel.org Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-09-03x86/amd-iommu: Add passthrough mode initialization functionsJoerg Roedel
When iommu=pt is passed on kernel command line the devices should run untranslated. This requires the allocation of a special domain for that purpose. This patch implements the allocation and initialization path for iommu=pt. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-06-15amd-iommu: disable IOMMU hardware on shutdownJoerg Roedel
When the IOMMU stays enabled the BIOS may not be able to finish the machine shutdown properly. So disable the hardware on shutdown. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-05-28amd-iommu: add function to flush tlb for all devicesJoerg Roedel
This function is required for suspend/resume support with AMD IOMMU enabled. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-05-28amd-iommu: add function to flush tlb for all domainsJoerg Roedel
2008-10-22x86: Fix ASM_X86__ header guardsH. Peter Anvin
Change header guards named "ASM_X86__*" to "_ASM_X86_*" since: a. the double underscore is ugly and pointless. b. no leading underscore violates namespace constraints. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-10-22x86, um: ... and asm-x86 moveAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
