path: root/arch/x86/include/asm/atomic_64.h
2009-07-03x86: atomic64: Code atomic(64)_read and atomic(64)_set in C not CPPPaul Mackerras
Occasionally we get bugs where atomic_read or atomic_set are used on atomic64_t variables or vice versa. These bugs don't generate warnings on x86 because atomic_read and atomic_set are coded as macros rather than C functions, so we don't get any type-checking on their arguments; similarly for atomic64_read and atomic64_set in 64-bit kernels. This converts them to C functions so that the arguments are type-checked and bugs like this will get caught more easily. It also converts atomic_cmpxchg and atomic_xchg, and atomic64_cmpxchg and atomic64_xchg on 64-bit, so we get type-checking on their arguments too. Compiling a typical 64-bit x86 config, this generates no new warnings, and the vmlinux text is 86 bytes smaller. Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Arnd Bergmann <arnd@arndb.de> LKML-Reference: <alpine.LFD.2.01.0907021653030.3210@localhost.localdomain> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-11asm-generic: rename atomic.h to atomic-long.hArnd Bergmann
The existing asm-generic/atomic.h only defines the atomic_long type. This renames it to atomic-long.h so we have a place to add a truly generic atomic.h that can be used on all non-SMP systems. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-01-06atomic_t: unify all arch definitionsMatthew Wilcox
The atomic_t type cannot currently be used in some header files because it would create an include loop with asm/atomic.h. Move the type definition to linux/types.h to break the loop. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Huang Ying <ying.huang@intel.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-22x86: Fix ASM_X86__ header guardsH. Peter Anvin
Change header guards named "ASM_X86__*" to "_ASM_X86_*" since: a. the double underscore is ugly and pointless. b. no leading underscore violates namespace constraints. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-10-22x86, um: ... and asm-x86 moveAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
