commit eab6870fee877258122a042bfd99ee7908c40280 upstream.
Mark Rutland noticed that GCC optimization passes have the potential to elide
necessary invocations of the array_index_mask_nospec() instruction sequence,
so mark the asm() volatile.
Mark explains:
"The volatile will inhibit *some* cases where the compiler could lift the
array_index_nospec() call out of a branch, e.g. where there are multiple
invocations of array_index_nospec() with the same arguments:
if (idx < foo) {
idx1 = array_idx_nospec(idx, foo)
do_something(idx1);
< some other code >
if (idx < foo) {
idx2 = array_idx_nospec(idx, foo);
do_something_else(idx2);
... since the compiler can determine that the two invocations yield the same
result, and reuse the first result (likely the same register as idx was in
originally) for the second branch, effectively re-writing the above as:
if (idx < foo) {
idx = array_idx_nospec(idx, foo);
do_something(idx);
< some other code >
if (idx < foo) {
do_something_else(idx);
... if we don't take the first branch, then speculatively take the second, we
lose the nospec protection.
There's more info on volatile asm in the GCC docs:
https://gcc.gnu.org/onlinedocs/gcc/Extended-Asm.html#Volatile
Reported-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: <stable@vger.kernel.org>
Fixes: babdde2698d4 ("x86: Implement array_index_mask_nospec")
Link: https://lkml.kernel.org/lkml/152838798950.14521.4893346294059739135.stgit@dwillia2-desk3.amr.corp.intel.com
commit be3233fbfcb8f5acb6e3bcd0895c3ef9e100d470 upstream.
Allow the compiler to handle @size as an immediate value or memory
directly rather than allocating a register.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Link: http://lkml.kernel.org/r/151797010204.1289.1510000292250184993.stgit@dwillia2-desk3.amr.corp.intel.com
commit b3d7ad85b80bbc404635dca80f5b129f6242bc7a
Rename the open coded form of this instruction sequence from
rdtsc_ordered() into a generic barrier primitive, barrier_nospec().
One of the mitigations for Spectre variant1 vulnerabilities is to fence
speculative execution after successfully validating a bounds check. I.e.
force the result of a bounds check to resolve in the instruction pipeline
to ensure speculative execution honors that result before potentially
operating on out-of-bounds data.
No functional changes.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Suggested-by: Andi Kleen <ak@linux.intel.com>
Suggested-by: Ingo Molnar <mingo@redhat.com>
Cc: Tom Lendacky <thomas.lendacky@amd.com>
Cc: kernel-hardening@lists.openwall.com
Cc: gregkh@linuxfoundation.org
Cc: alan@linux.intel.com
Link: https://lkml.kernel.org/r/151727415361.33451.9049453007262764675.stgit@dwillia2-desk3.amr.corp.intel.com
commit babdde2698d482b6c0de1eab4f697cf5856c5859
array_index_nospec() uses a mask to sanitize user controllable array
indexes, i.e. generate a 0 mask if 'index' >= 'size', and a ~0 mask
otherwise. While the default array_index_mask_nospec() handles the
carry-bit from the (index - size) result in software.
The x86 array_index_mask_nospec() does the same, but the carry-bit is
handled in the processor CF flag without conditional instructions in the
control flow.
Link: https://lkml.kernel.org/r/151727414808.33451.1873237130672785331.stgit@dwillia2-desk3.amr.corp.intel.com
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
On x86, we *do* still use the non-NOP rmb()/wmb() for IO barriers,
but even that is generally questionable.
Leave them around as historial unless somebody can point to a
case where they care about the performance, but tweak the
comment so people don't think they are strictly required in all
cases.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: Andrey Konovalov <andreyknvl@google.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Davidlohr Bueso <dave@stgolabs.net>
Cc: Davidlohr Bueso <dbueso@suse.de>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: virtualization <virtualization@lists.linux-foundation.org>
Link: http://lkml.kernel.org/r/1453921746-16178-4-git-send-email-mst@redhat.com
The comment about wmb being non-NOP to deal with non-Intel CPUs
is a left over from before the following commit:
09df7c4c8097 ("x86: Remove CONFIG_X86_OOSTORE")
It makes no sense now: in particular, wmb() is not a NOP even for
regular Intel CPUs because of weird use-cases e.g. dealing with
WC memory.
Drop this comment.
Link: http://lkml.kernel.org/r/1453921746-16178-3-git-send-email-mst@redhat.com
ADDL clobbers flags (such as CF) but barrier.h didn't tell this
to GCC. Historically, GCC doesn't need one on x86, and always
considers flags clobbered. We are probably missing the cc
clobber in a *lot* of places for this reason.
But even if not necessary, it's probably a good thing to add for
documentation, and in case GCC semantcs ever change.
Reported-by: Borislav Petkov <bp@alien8.de>
Link: http://lkml.kernel.org/r/1453921746-16178-2-git-send-email-mst@redhat.com
This defines __smp_xxx barriers for x86,
for use by virtualization.
smp_xxx barriers are removed as they are
defined correctly by asm-generic/barriers.h
As on most architectures, on x86 read_barrier_depends and
smp_read_barrier_depends are empty. Drop the local definitions and pull
the generic ones from asm-generic/barrier.h instead: they are identical.
This is in preparation to refactoring this code area.
Upcoming changes to static keys is interacting/conflicting with the following
pending TSC commits in tip:x86/asm:
4ea1636b04db x86/asm/tsc: Rename native_read_tsc() to rdtsc()
So merge it into the locking tree to have a smoother resolution.
smp_store_release()/smp_load_acquire()
Replace ACCESS_ONCE() macro in smp_store_release() and smp_load_acquire()
with WRITE_ONCE() and READ_ONCE() on x86, arm, arm64, ia64, metag, mips,
powerpc, s390, sparc and asm-generic since ACCESS_ONCE() does not work
reliably on non-scalar types.
WRITE_ONCE() and READ_ONCE() were introduced in the following commits:
230fa253df63 ("kernel: Provide READ_ONCE and ASSIGN_ONCE")
43239cbe79fc ("kernel: Change ASSIGN_ONCE(val, x) to WRITE_ONCE(x, val)")
Signed-off-by: Andrey Konovalov <andreyknvl@google.com>
Acked-by: Davidlohr Bueso <dbueso@suse.de>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Cc: Alexander Duyck <alexander.h.duyck@redhat.com>
Cc: Andre Przywara <andre.przywara@arm.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: James Hogan <james.hogan@imgtec.com>
Link: http://lkml.kernel.org/r/1438528264-714-1-git-send-email-andreyknvl@google.com
All callers have been converted to rdtsc_ordered().
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Huang Rui <ray.huang@amd.com>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Len Brown <lenb@kernel.org>
Cc: Richard Weinberger <richard@nod.at>
Cc: kvm ML <kvm@vger.kernel.org>
Link: http://lkml.kernel.org/r/9baa4ae9a1e7c7c282f9cb2f15bb6bf5c2004032.1434501121.git.luto@kernel.org
Since set_mb() is really about an smp_mb() -- not a IO/DMA barrier
like mb() rename it to match the recent smp_load_acquire() and
smp_store_release().
Since we assume set_mb() to result in a single store followed by a
full memory barrier, employ WRITE_ONCE().
... now that we have it.
Acked-by: Andy Lutomirski <luto@amacapital.net>
There are a number of situations where the mandatory barriers rmb() and
wmb() are used to order memory/memory operations in the device drivers
and those barriers are much heavier than they actually need to be. For
example in the case of PowerPC wmb() calls the heavy-weight sync
instruction when for coherent memory operations all that is really needed
is an lsync or eieio instruction.
This commit adds a coherent only version of the mandatory memory barriers
rmb() and wmb(). In most cases this should result in the barrier being the
same as the SMP barriers for the SMP case, however in some cases we use a
barrier that is somewhere in between rmb() and smp_rmb(). For example on
ARM the rmb barriers break down as follows:
Barrier Call Explanation
rmb() dsb() Data synchronization barrier - system
dma_rmb() dmb(osh) data memory barrier - outer sharable
smp_rmb() dmb(ish) data memory barrier - inner sharable
These new barriers are not as safe as the standard rmb() and wmb().
Specifically they do not guarantee ordering between coherent and incoherent
memories. The primary use case for these would be to enforce ordering of
reads and writes when accessing coherent memory that is shared between the
CPU and a device.
It may also be noted that there is no dma_mb(). Most architectures don't
provide a good mechanism for performing a coherent only full barrier without
resorting to the same mechanism used in mb(). As such there isn't much to
be gained in trying to define such a function.
Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: Michael Ellerman <michael@ellerman.id.au>
Cc: Michael Neuling <mikey@neuling.org>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Alexander Duyck <alexander.h.duyck@redhat.com>
This patch is meant to cleanup the handling of read_barrier_depends and
smp_read_barrier_depends. In multiple spots in the kernel headers
read_barrier_depends is defined as "do {} while (0)", however we then go
into the SMP vs non-SMP sections and have the SMP version reference
read_barrier_depends, and the non-SMP define it as yet another empty
do/while.
With this commit I went through and cleaned out the duplicate definitions
and reduced the number of definitions down to 2 per header. In addition I
moved the 50 line comments for the macro from the x86 and mips headers that
defined it as an empty do/while to those that were actually defining the
macro, alpha and blackfin.
Paul reported that X86_OOSTORE is dead, yay! Update a comment and
remove a newly added reference.
Reported-by: Paul Bolle <pebolle@tiscali.nl>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: Dave Jones <davej@redhat.com>
Cc: Waiman Long <Waiman.Long@hp.com>
Link: http://lkml.kernel.org/r/20140611090509.GC3588@twins.programming.kicks-ass.net
x86 is strongly ordered and all its atomic ops imply a full barrier.
Implement the two new primitives as the old ones were.
Link: http://lkml.kernel.org/n/tip-knswsr5mldkr0w1lrdxvc81w@git.kernel.org
Cc: Jesse Brandeburg <jesse.brandeburg@intel.com>
Cc: Michel Lespinasse <walken@google.com>
This was an optimization that made memcpy type benchmarks a little
faster on ancient (Circa 1998) IDT Winchip CPUs. In real-life
workloads, it wasn't even noticable, and I doubt anyone is running
benchmarks on 16 year old silicon any more.
Given this code has likely seen very little use over the last decade,
let's just remove it.
Signed-off-by: Dave Jones <davej@fedoraproject.org>
A number of situations currently require the heavyweight smp_mb(),
even though there is no need to order prior stores against later
loads. Many architectures have much cheaper ways to handle these
situations, but the Linux kernel currently has no portable way
to make use of them.
This commit therefore supplies smp_load_acquire() and
smp_store_release() to remedy this situation. The new
smp_load_acquire() primitive orders the specified load against
any subsequent reads or writes, while the new smp_store_release()
primitive orders the specifed store against any prior reads or
writes. These primitives allow array-based circular FIFOs to be
implemented without an smp_mb(), and also allow a theoretical
hole in rcu_assign_pointer() to be closed at no additional
expense on most architectures.
In addition, the RCU experience transitioning from explicit
smp_read_barrier_depends() and smp_wmb() to rcu_dereference()
and rcu_assign_pointer(), respectively resulted in substantial
improvements in readability. It therefore seems likely that
replacing other explicit barriers with smp_load_acquire() and
smp_store_release() will provide similar benefits. It appears
that roughly half of the explicit barriers in core kernel code
might be so replaced.
[Changelog by PaulMck]
Reviewed-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Victor Kaplansky <VICTORK@il.ibm.com>
Link: http://lkml.kernel.org/r/20131213150640.908486364@infradead.org
Disintegrate asm/system.h for X86.
Acked-by: H. Peter Anvin <hpa@zytor.com>
cc: x86@kernel.org
