path: root/arch/x86/include/asm/ia32.h
2009-03-27generic compat_sys_ustatChristoph Hellwig
Due to a different size of ino_t ustat needs a compat handler, but currently only x86 and mips provide one. Add a generic compat_sys_ustat and switch all architectures over to it. Instead of doing various user copy hacks compat_sys_ustat just reimplements sys_ustat as it's trivial. This was suggested by Arnd Bergmann. Found by Eric Sandeen when running xfstests/017 on ppc64, which causes stack smashing warnings on RHEL/Fedora due to the too large amount of data writen by the syscall. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-18x86: ia32.h: remove unused struct sigfram32 and rt_sigframe32Hiroshi Shimamoto
Impact: cleanup Remove struct sigfram32 and rt_sigframe32 because there is no user. Signed-off-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-10-22x86: Fix ASM_X86__ header guardsH. Peter Anvin
Change header guards named "ASM_X86__*" to "_ASM_X86_*" since: a. the double underscore is ugly and pointless. b. no leading underscore violates namespace constraints. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-10-22x86, um: ... and asm-x86 moveAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
