path: root/arch/x86/include/asm/iommu_table.h
2015-04-09x86/iommu: Fix header comments regarding standard and _FINISH macrosAravind Gopalakrishnan
The comment line regarding IOMMU_INIT and IOMMU_INIT_FINISH macros is incorrect: "The standard vs the _FINISH differs in that the _FINISH variant will continue detecting other IOMMUs in the call list..." It should be "..the *standard* variant will continue detecting..." Fix that. Also, make it readable while at it. Signed-off-by: Aravind Gopalakrishnan <Aravind.Gopalakrishnan@amd.com> Signed-off-by: Borislav Petkov <bp@suse.de> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: konrad.wilk@oracle.com Fixes: 6e9636693373 ("x86, iommu: Update header comments with appropriate naming") Link: http://lkml.kernel.org/r/1428508017-5316-1-git-send-email-Aravind.Gopalakrishnan@amd.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-09-05x86/iommu: Use NULL instead of plain 0 for __IOMMU_INITMathias Krause
IOMMU_INIT_POST and IOMMU_INIT_POST_FINISH pass the plain value 0 instead of NULL to __IOMMU_INIT. Fix this and make sparse happy by doing so. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Joerg Roedel <joerg.roedel@amd.com> Link: http://lkml.kernel.org/r/1346621506-30857-8-git-send-email-minipli@googlemail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-09-05x86/iommu: Drop duplicate const in __IOMMU_INITMathias Krause
It's redundant and makes sparse complain about it. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Joerg Roedel <joerg.roedel@amd.com> Link: http://lkml.kernel.org/r/1346621506-30857-7-git-send-email-minipli@googlemail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2010-10-08x86, iommu: Update header comments with appropriate namingKonrad Rzeszutek Wilk
The header comments diverged a bit from the implementation. Lets re-sync them. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> LKML-Reference: <1286564028-2352-3-git-send-email-konrad.wilk@oracle.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-08-26x86, swiotlb: Simplify SWIOTLB pci_swiotlb_detect routine.Konrad Rzeszutek Wilk
In 'pci_swiotlb_detect' we used to do two different things: a). If user provided 'iommu=soft' or 'swiotlb=force' we would set swiotlb=1 and return 1 (and forcing pci-dma.c to call pci_swiotlb_init() immediately). b). If 4GB or more would be detected and if user did not specify iommu=off, we would set 'swiotlb=1' and return whatever 'a)' figured out. We simplify this by splitting a) and b) in two different routines. CC: Fujita Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> LKML-Reference: <1282845485-8991-5-git-send-email-konrad.wilk@oracle.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-08-26x86, iommu: Add proper dependency sort routine (and sanity check).Konrad Rzeszutek Wilk
We are using a very simple sort routine which sorts the .iommu_table array in the order of dependencies. Specifically each structure of iommu_table_entry has a field 'depend' which contains the function pointer to the IOMMU that MUST be run before us. We sort the array of structures so that the struct iommu_table_entry with no 'depend' field are first, and then the subsequent ones are the ones for which the 'depend' function has been already invoked (in other words, precede us). Using the kernel's version 'sort', which is a mergeheap is feasible, but would require making the comparison operator scan recursivly the array to satisfy the "heapify" process: setting the levels properly. The end result would much more complex than it should be an it is just much simpler to utilize this simple sort routine. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> LKML-Reference: <1282845485-8991-4-git-send-email-konrad.wilk@oracle.com> CC: H. Peter Anvin <hpa@zytor.com> CC: Fujita Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-08-26x86, iommu: Add IOMMU_INIT macros, .iommu_table section, and ↵Konrad Rzeszutek Wilk
iommu_table_entry structure This patch set adds a mechanism to "modularize" the IOMMUs we have on X86. Currently the count of IOMMUs is up to six and they have a complex relationship that requires careful execution order. 'pci_iommu_alloc' does that today, but most folks are unhappy with how it does it. This patch set addresses this and also paves a mechanism to jettison unused IOMMUs during run-time. For details that sparked this, please refer to: http://lkml.org/lkml/2010/8/2/282 The first solution that comes to mind is to convert wholesale the IOMMU detection routines to be called during initcall time frame. Unfortunately that misses the dependency relationship that some of the IOMMUs have (for example: for AMD-Vi IOMMU to work, GART detection MUST run first, and before all of that SWIOTLB MUST run). The second solution would be to introduce a registration call wherein the IOMMU would provide its detection/init routines and as well on what MUST run before it. That would work, except that the 'pci_iommu_alloc' which would run through this list, is called during mem_init. This means we don't have any memory allocator, and it is so early that we haven't yet started running through the initcall_t list. This solution borrows concepts from the 2nd idea and from how MODULE_INIT works. A macro is provided that each IOMMU uses to define it's detect function and early_init (before the memory allocate is active), and as well what other IOMMU MUST run before us. Since most IOMMUs depend on having SWIOTLB run first ("pci_swiotlb_detect") a convenience macro to depends on that is also provided. This macro is similar in design to MODULE_PARAM macro wherein we setup a .iommu_table section in which we populate it with the values that match a struct iommu_table_entry. During bootup we will sort through the array so that the IOMMUs that MUST run before us are first elements in the array. And then we just iterate through them calling the detection routine and if appropiate, the init routines. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> LKML-Reference: <1282845485-8991-2-git-send-email-konrad.wilk@oracle.com> CC: H. Peter Anvin <hpa@zytor.com> CC: Fujita Tomonori <fujita.tomonori@lab.ntt.co.jp> CC: Thomas Gleixner <tglx@linutronix.de> CC: Ingo Molnar <mingo@redhat.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
