Opaque KVM structs are useful for prototypes in asm/kvm_host.h, to avoid
"'struct foo' declared inside parameter list" warnings (and consequent
breakage due to conflicting types).
Move them from individual files to a generic place in linux/kvm_types.h.
sched_in preempt notifier is available for x86, allow its use in
specific virtualization technlogies as well.
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
The only user of the fpu_activate hook was dropped in commit
2d04a05bd7e9 (KVM: x86 emulator: emulate CLTS internally, 2011-04-20).
vmx_fpu_activate and svm_fpu_activate are still called on #NM (and for
Intel CLTS), but never from common code; hence, there's no need for
a hook.
Reviewed-by: Yang Zhang <yang.z.zhang@intel.com>
Signed-off-by: Wanpeng Li <wanpeng.li@linux.intel.com>
This reverts commit 682367c494869008eb89ef733f196e99415ae862,
which causes 32-bit SMP Windows 7 guests to panic.
SeaBIOS has a limit on the number of MTRRs that it can handle,
and this patch exceeded the limit. Better revert it.
Thanks to Nadav Amit for debugging the cause.
Cc: stable@nongnu.org
Reported-by: Wanpeng Li <wanpeng.li@linux.intel.com>
Pull KVM changes from Paolo Bonzini:
"These are the x86, MIPS and s390 changes; PPC and ARM will come in a
few days.
MIPS and s390 have little going on this release; just bugfixes, some
small, some larger.
The highlights for x86 are nested VMX improvements (Jan Kiszka),
optimizations for old processor (up to Nehalem, by me and Bandan Das),
and a lot of x86 emulator bugfixes (Nadav Amit).
Stephen Rothwell reported a trivial conflict with the tracing branch"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (104 commits)
x86/kvm: Resolve shadow warnings in macro expansion
KVM: s390: rework broken SIGP STOP interrupt handling
KVM: x86: always exit on EOIs for interrupts listed in the IOAPIC redir table
KVM: vmx: remove duplicate vmx_mpx_supported() prototype
KVM: s390: Fix memory leak on busy SIGP stop
x86/kvm: Resolve shadow warning from min macro
kvm: Resolve missing-field-initializers warnings
Replace NR_VMX_MSR with its definition
KVM: x86: Assertions to check no overrun in MSR lists
KVM: x86: set rflags.rf during fault injection
KVM: x86: Setting rflags.rf during rep-string emulation
KVM: x86: DR6/7.RTM cannot be written
KVM: nVMX: clean up nested_release_vmcs12 and code around it
KVM: nVMX: fix lifetime issues for vmcs02
KVM: x86: Defining missing x86 vectors
KVM: x86: emulator injects #DB when RFLAGS.RF is set
KVM: x86: Cleanup of rflags.rf cleaning
KVM: x86: Clear rflags.rf on emulated instructions
KVM: x86: popf emulation should not change RF
KVM: x86: Clearing rflags.rf upon skipped emulated instruction
Haswell and newer Intel CPUs have support for RTM, and in that case DR6.RTM is
not fixed to 1 and DR7.RTM is not fixed to zero. That is not the case in the
current KVM implementation. This bug is apparent only if the MOV-DR instruction
is emulated or the host also debugs the guest.
This patch is a partial fix which enables DR6.RTM and DR7.RTM to be cleared and
set respectively. It also sets DR6.RTM upon every debug exception. Obviously,
it is not a complete fix, as debugging of RTM is still unsupported.
Signed-off-by: Nadav Amit <namit@cs.technion.ac.il>
For the next patch we will need to know the full state of the
interrupt shadow; we will then set KVM_REQ_EVENT when one bit
is cleared.
However, right now get_interrupt_shadow only returns the one
corresponding to the emulated instruction, or an unconditional
0 if the emulated instruction does not have an interrupt shadow.
This is confusing and does not allow us to check for cleared
bits as mentioned above.
Clean the callback up, and modify toggle_interruptibility to
match the comment above the call. As a small result, the
call to set_interrupt_shadow will be skipped in the common
case where int_shadow == 0 && mask == 0.
I've observed kvmclock being marked as unstable on a modern
single-socket system with a stable TSC and qemu-1.6.2 or qemu-2.0.0.
The culprit was failure in TSC matching because of overflow of
kvm_arch::nr_vcpus_matched_tsc in case there were multiple TSC writes
in a single synchronization cycle.
Turns out that qemu does multiple TSC writes during init, below is the
evidence of that (qemu-2.0.0):
The first one:
0xffffffffa08ff2b4 : vmx_write_tsc_offset+0xa4/0xb0 [kvm_intel]
0xffffffffa04c9c05 : kvm_write_tsc+0x1a5/0x360 [kvm]
0xffffffffa04cfd6b : kvm_arch_vcpu_postcreate+0x4b/0x80 [kvm]
0xffffffffa04b8188 : kvm_vm_ioctl+0x418/0x750 [kvm]
The second one:
0xffffffffa090610d : vmx_set_msr+0x29d/0x350 [kvm_intel]
0xffffffffa04be83b : do_set_msr+0x3b/0x60 [kvm]
0xffffffffa04c10a8 : msr_io+0xc8/0x160 [kvm]
0xffffffffa04caeb6 : kvm_arch_vcpu_ioctl+0xc86/0x1060 [kvm]
0xffffffffa04b6797 : kvm_vcpu_ioctl+0xc7/0x5a0 [kvm]
#0 kvm_vcpu_ioctl at /build/buildd/qemu-2.0.0+dfsg/kvm-all.c:1780
#1 kvm_put_msrs at /build/buildd/qemu-2.0.0+dfsg/target-i386/kvm.c:1270
#2 kvm_arch_put_registers at /build/buildd/qemu-2.0.0+dfsg/target-i386/kvm.c:1909
#3 kvm_cpu_synchronize_post_init at /build/buildd/qemu-2.0.0+dfsg/kvm-all.c:1641
#4 cpu_synchronize_post_init at /build/buildd/qemu-2.0.0+dfsg/include/sysemu/kvm.h:330
#5 cpu_synchronize_all_post_init () at /build/buildd/qemu-2.0.0+dfsg/cpus.c:521
#6 main at /build/buildd/qemu-2.0.0+dfsg/vl.c:4390
The third one:
#3 kvm_cpu_synchronize_post_reset at /build/buildd/qemu-2.0.0+dfsg/kvm-all.c:1635
#4 cpu_synchronize_post_reset at /build/buildd/qemu-2.0.0+dfsg/include/sysemu/kvm.h:323
#5 cpu_synchronize_all_post_reset () at /build/buildd/qemu-2.0.0+dfsg/cpus.c:512
#6 main at /build/buildd/qemu-2.0.0+dfsg/vl.c:4482
The fix is to count each vCPU only once when matched, so that
nr_vcpus_matched_tsc holds the size of the matched set. This is
achieved by reusing generation counters. Every vCPU with
this_tsc_generation == cur_tsc_generation is in the matched set. The
match set is cleared by setting cur_tsc_generation to a value which no
other vCPU is set to (by incrementing it).
I needed to bump up the counter size form u8 to u64 to ensure it never
overflows. Otherwise in cases TSC is not written the same number of
times on each vCPU the counter could overflow and incorrectly indicate
some vCPUs as being in the matched set. This scenario seems unlikely
but I'm not sure if it can be disregarded.
Signed-off-by: Tomasz Grabiec <tgrabiec@cloudius-systems.com>
KVM does not really do much with the PAT, so this went unnoticed for a
long time. It is exposed however if you try to do rdmsr on the PAT
register.
Reported-by: Valentine Sinitsyn <valentine.sinitsyn@gmail.com>
Cc: stable@vger.kernel.org
Recent Intel CPUs have 10 variable range MTRRs. Since operating systems
sometime make assumptions on CPUs while they ignore capability MSRs, it is
better for KVM to be consistent with recent CPUs. Reporting more MTRRs than
actually supported has no functional implications.
The rdpmc emulation checks that the counter (ECX) is not higher than 2, without
taking into considerations bits 30:31 role (e.g., bit 30 marks whether the
counter is fixed). The fix uses the pmu information for checking the validity
of the pmu counter.
CS.RPL is not equal to the CPL in the few instructions between
setting CR0.PE and reloading CS. And CS.DPL is also not equal
to the CPL for conforming code segments.
However, SS.DPL *is* always equal to the CPL except for the weird
case of SYSRET on AMD processors, which sets SS.DPL=SS.RPL from the
value in the STAR MSR, but force CPL=3 (Intel instead forces
SS.DPL=SS.RPL=CPL=3).
So this patch:
- modifies SVM to update the CPL from SS.DPL rather than CS.RPL;
the above case with SYSRET is not broken further, and the way
to fix it would be to pass the CPL to userspace and back
- modifies VMX to always return the CPL from SS.DPL (except
forcing it to 0 if we are emulating real mode via vm86 mode;
in vm86 mode all DPLs have to be 3, but real mode does allow
privileged instructions). It also removes the CPL cache,
which becomes a duplicate of the SS access rights cache.
This fixes doing KVM_IOCTL_SET_SREGS exactly after setting
CR0.PE=1 but before CS has been reloaded.
According to Intel specifications, PAE and non-PAE does not have any reserved
bits. In long-mode, regardless to PCIDE, only the high bits (above the
physical address) are reserved.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
This patch removes SMAP bit from CR4_RESERVED_BITS.
Signed-off-by: Feng Wu <feng.wu@intel.com>
When not running in guest-debug mode, the guest controls the debug
registers and having to take an exit for each DR access is a waste
of time. If the guest gets into a state where each context switch
causes DR to be saved and restored, this can take away as much as 40%
of the execution time from the guest.
After this patch, VMX- and SVM-specific code can set a flag in
switch_db_regs, telling vcpu_enter_guest that on the next exit the debug
registers might be dirty and need to be reloaded (syncing will be taken
care of by a new callback in kvm_x86_ops). This flag can be set on the
first access to a debug registers, so that multiple accesses to the
debug registers only cause one vmexit.
Note that since the guest will be able to read debug registers and
enable breakpoints in DR7, we need to ensure that they are synchronized
on entry to the guest---including DR6 that was not synced before.
The next patch will add another bit that we can test with the
same "if".
It's no longer possible to enter enable_irq_window in guest mode when
L1 intercepts external interrupts and we are entering L2. This is now
caught in vcpu_enter_guest. So we can remove the check from the VMX
version of enable_irq_window, thus the need to return an error code from
both enable_irq_window and enable_nmi_window.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Move the check for leaving L2 on pending and intercepted IRQs or NMIs
from the *_allowed handler into a dedicated callback. Invoke this
callback at the relevant points before KVM checks if IRQs/NMIs can be
injected. The callback has the task to switch from L2 to L1 if needed
and inject the proper vmexit events.
The rework fixes L2 wakeups from HLT and provides the foundation for
preemption timer emulation.
commit 0061d53daf26f introduced a mechanism to execute a global clock
update for a vm. We can apply this periodically in order to propagate
host NTP corrections. Also, if all vcpus of a vm are pinned, then
without an additional trigger, no guest NTP corrections can propagate
either, as the current trigger is only vcpu cpu migration.
Signed-off-by: Andrew Jones <drjones@redhat.com>
When we update a vcpu's local clock it may pick up an NTP correction.
We can't wait an indeterminate amount of time for other vcpus to pick
up that correction, so commit 0061d53daf26f introduced a global clock
update. However, we can't request a global clock update on every vcpu
load either (which is what happens if the tsc is marked as unstable).
The solution is to rate-limit the global clock updates. Marcelo
calculated that we should delay the global clock updates no more
than 0.1s as follows:
Assume an NTP correction c is applied to one vcpu, but not the other,
then in n seconds the delta of the vcpu system_timestamps will be
c * n. If we assume a correction of 500ppm (worst-case), then the two
vcpus will diverge 50us in 0.1s, which is a considerable amount.
From caddc009a6d2019034af8f2346b2fd37a81608d0 Mon Sep 17 00:00:00 2001
Date: Mon, 24 Feb 2014 18:11:11 +0800
Subject: [PATCH v5 1/3] KVM: x86: Intel MPX vmx and msr handle
This patch handle vmx and msr of Intel MPX feature.
Signed-off-by: Xudong Hao <xudong.hao@intel.com>
Signed-off-by: Liu Jinsong <jinsong.liu@intel.com>
Remove unused last_kernel_ns variable.
In contrast to VMX, SVM dose not automatically transfer DR6 into the
VCPU's arch.dr6. So if we face a DR6 read, we must consult a new vendor
hook to obtain the current value. And as SVM now picks the DR6 state
from its VMCB, we also need a set callback in order to write updates of
DR6 back.
Fixes a regression of 020df0794f.
Signed-off: Peter Lieven <pl@kamp.de>
Signed-off: Gleb Natapov
Signed-off: Vadim Rozenfeld <vrozenfe@redhat.com>
After some consideration I decided to submit only Hyper-V reference
counters support this time. I will submit iTSC support as a separate
patch as soon as it is ready.
v1 -> v2
1. mark TSC page dirty as suggested by
Eric Northup <digitaleric@google.com> and Gleb
2. disable local irq when calling get_kernel_ns,
as it was done by Peter Lieven <pl@amp.de>
3. move check for TSC page enable from second patch
to this one.
v3 -> v4
Get rid of ref counter offset.
v4 -> v5
replace __copy_to_user with kvm_write_guest
when updateing iTSC page.
The prototype for kvm_check_iopl appeared in commit
f850e2e603bf5a05b0aee7901857cf85715aa694 ("KVM: x86 emulator: Check IOPL
level during io instruction emulation"), but the function never actually
existed. Remove the prototype.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
Signed-off-by: Gleb Natapov <gleb@redhat.com>
complete_pio ceased to exist in commit
7972995b0c346de76fe260ce0fd6bcc8ffab724a ("KVM: x86 emulator: Move
string pio emulation into emulator.c"), but the prototype remained.
Remove its prototype.
We currently use some ad-hoc arch variables tied to legacy KVM device
assignment to manage emulation of instructions that depend on whether
non-coherent DMA is present. Create an interface for this, adapting
legacy KVM device assignment and adding VFIO via the KVM-VFIO device.
For now we assume that non-coherent DMA is possible any time we have a
VFIO group. Eventually an interface can be developed as part of the
VFIO external user interface to query the coherency of a group.
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Default to operating in coherent mode. This simplifies the logic when
we switch to a model of registering and unregistering noncoherent I/O
with KVM.
The gfn_to_index function relies on huge page defines which either may
not make sense on systems that don't support huge pages or are defined
in an unconvenient way for other architectures. Since this is
x86-specific, move the function to arch/x86/include/asm/kvm_host.h.
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
kvm_mmu initialization is mostly filling in function pointers, there is
no way for it to fail. Clean up unused return values.
The new_cr3 MMU callback has been a wrapper for mmu_free_roots since commit
e676505 (KVM: MMU: Force cr3 reload with two dimensional paging on mov
cr3 emulation, 2012-07-08).
The commit message mentioned that "mmu_free_roots() is somewhat of an overkill,
but fixing that is more complicated and will be done after this minimal fix".
One year has passed, and no one really felt the need to do a different fix.
Wrap the call with a kvm_mmu_new_cr3 function for clarity, but remove the
callback.
The free MMU callback has been a wrapper for mmu_free_roots since mmu_free_roots
itself was introduced (commit 17ac10a, [PATCH] KVM: MU: Special treatment
for shadow pae root pages, 2007-01-05), and has always been the same for all
MMU cases. Remove the indirection as it is useless.
This makes the interface more deterministic for userspace, which can expect
(after configuring only the features it supports) to get exactly the same
state from the kernel, independent of the host CPU and kernel version.
Suggested-by: Gleb Natapov <gleb@redhat.com>
A guest can still attempt to save and restore XSAVE states even if they
have been masked in CPUID leaf 0Dh. This usually is not visible to
the guest, but is still wrong: "Any attempt to set a reserved bit (as
determined by the contents of EAX and EDX after executing CPUID with
EAX=0DH, ECX= 0H) in XCR0 for a given processor will result in a #GP
exception".
The patch also performs the same checks as __kvm_set_xcr in KVM_SET_XSAVE.
This catches migration from newer to older kernel/processor before the
guest starts running.
kvm_hc_kick_cpu allows the calling vcpu to kick another vcpu out of halt state.
the presence of these hypercalls is indicated to guest via
kvm_feature_pv_unhalt.
Fold pv_unhalt flag into GET_MP_STATE ioctl to aid migration
During migration, any vcpu that got kicked but did not become runnable
(still in halted state) should be runnable after migration.
Signed-off-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com>
Signed-off-by: Suzuki Poulose <suzuki@in.ibm.com>
[Raghu: Apic related changes, folding pvunhalted into vcpu_runnable
Added flags for future use (suggested by Gleb)]
[ Raghu: fold pv_unhalt flag as suggested by Eric Northup]
Signed-off-by: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com>
Acked-by: Gleb Natapov <gleb@redhat.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
Inject nEPT fault to L1 guest. This patch is original from Xinhao.
Reviewed-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Signed-off-by: Jun Nakajima <jun.nakajima@intel.com>
Signed-off-by: Xinhao Xu <xinhao.xu@intel.com>
Signed-off-by: Yang Zhang <yang.z.zhang@Intel.com>
The next patch will reuse it for other userspace exits than MMIO,
namely debug events.
[KVM maintainers:
The underlying support for this is in perf/core now. So please merge
this patch into the KVM tree.]
This is not arch perfmon, but older CPUs will just ignore it. This makes
it possible to do at least some TSX measurements from a KVM guest
v2: Various fixes to address review feedback
v3: Ignore the bits when no CPUID. No #GP. Force raw events with TSX bits.
v4: Use reserved bits for #GP
v5: Remove obsolete argument
Pull KVM fixes from Paolo Bonzini:
"On the x86 side, there are some optimizations and documentation
updates. The big ARM/KVM change for 3.11, support for AArch64, will
come through Catalin Marinas's tree. s390 and PPC have misc cleanups
and bugfixes"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (87 commits)
KVM: PPC: Ignore PIR writes
KVM: PPC: Book3S PR: Invalidate SLB entries properly
KVM: PPC: Book3S PR: Allow guest to use 1TB segments
KVM: PPC: Book3S PR: Don't keep scanning HPTEG after we find a match
KVM: PPC: Book3S PR: Fix invalidation of SLB entry 0 on guest entry
KVM: PPC: Book3S PR: Fix proto-VSID calculations
KVM: PPC: Guard doorbell exception with CONFIG_PPC_DOORBELL
KVM: Fix RTC interrupt coalescing tracking
kvm: Add a tracepoint write_tsc_offset
KVM: MMU: Inform users of mmio generation wraparound
KVM: MMU: document fast invalidate all mmio sptes
KVM: MMU: document fast invalidate all pages
KVM: MMU: document fast page fault
KVM: MMU: document mmio page fault
KVM: MMU: document write_flooding_count
KVM: MMU: document clear_spte_count
KVM: MMU: drop kvm_mmu_zap_mmio_sptes
KVM: MMU: init kvm generation close to mmio wrap-around value
KVM: MMU: add tracepoint for check_mmio_spte
KVM: MMU: fast invalidate all mmio sptes
Document it to Documentation/virtual/kvm/mmu.txt
Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Document write_flooding_count to Documentation/virtual/kvm/mmu.txt
Drop kvm_mmu_zap_mmio_sptes and use kvm_mmu_invalidate_zap_all_pages
instead to handle mmio generation number overflow
Reviewed-by: Gleb Natapov <gleb@redhat.com>
Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com>
This patch tries to introduce a very simple and scale way to invalidate
all mmio sptes - it need not walk any shadow pages and hold mmu-lock
KVM maintains a global mmio valid generation-number which is stored in
kvm->memslots.generation and every mmio spte stores the current global
generation-number into his available bits when it is created
When KVM need zap all mmio sptes, it just simply increase the global
generation-number. When guests do mmio access, KVM intercepts a MMIO #PF
then it walks the shadow page table and get the mmio spte. If the
generation-number on the spte does not equal the global generation-number,
it will go to the normal #PF handler to update the mmio spte
Since 19 bits are used to store generation-number on mmio spte, we zap all
mmio sptes when the number is round
Rename X86_CR4_RDWRGSFS to X86_CR4_FSGSBASE to match the SDM.
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
Link: http://lkml.kernel.org/n/tip-buq1evi5dpykxx7ak6amaam0@git.kernel.org
As Marcelo pointed out that
| "(retention of large number of pages while zapping)
| can be fatal, it can lead to OOM and host crash"
We introduce a list, kvm->arch.zapped_obsolete_pages, to link all
the pages which are deleted from the mmu cache but not actually
freed. When page reclaiming is needed, we always zap this kind of
pages first.
The current kvm_mmu_zap_all is really slow - it is holding mmu-lock to
walk and zap all shadow pages one by one, also it need to zap all guest
page's rmap and all shadow page's parent spte list. Particularly, things
become worse if guest uses more memory or vcpus. It is not good for
scalability
In this patch, we introduce a faster way to invalidate all shadow pages.
KVM maintains a global mmu invalid generation-number which is stored in
kvm->arch.mmu_valid_gen and every shadow page stores the current global
generation-number into sp->mmu_valid_gen when it is created
When KVM need zap all shadow pages sptes, it just simply increase the
global generation-number then reload root shadow pages on all vcpus.
Vcpu will create a new shadow page table according to current kvm's
generation-number. It ensures the old pages are not used any more.
Then the obsolete pages (sp->mmu_valid_gen != kvm->arch.mmu_valid_gen)
are zapped by using lock-break technique
With VMX, enable_irq_window can now return -EBUSY, in which case an
immediate exit shall be requested before entering the guest. Account for
this also in enable_nmi_window which uses enable_irq_window in absence
of vnmi support, e.g.
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
KVM guests today use 8bit APIC ids allowing for 256 ID's. Reserving one
ID for Broadcast interrupts should leave 255 ID's. In case of KVM there
is no need for reserving another ID for IO-APIC so the hard max limit for
VCPUS can be increased from 254 to 255. (This was confirmed by Gleb Natapov
http://article.gmane.org/gmane.comp.emulators.kvm.devel/99713 )
Signed-off-by: Chegu Vinod <chegu_vinod@hp.com>
