Historically a lot of these existed because we did not have
a distinction between what was modular code and what was providing
support to modules via EXPORT_SYMBOL and friends. That changed
when we forked out support for the latter into the export.h file.
This means we should be able to reduce the usage of module.h
in code that is obj-y Makefile or bool Kconfig. In the case of
some of these which are modular, we can extend that to also include
files that are building basic support functionality but not related
to loading or registering the final module; such files also have
no need whatsoever for module.h
The advantage in removing such instances is that module.h itself
sources about 15 other headers; adding significantly to what we feed
cpp, and it can obscure what headers we are effectively using.
Since module.h was the source for init.h (for __init) and for
export.h (for EXPORT_SYMBOL) we consider each instance for the
presence of either and replace as needed.
In the case of crypto/glue_helper.c we delete a redundant instance
of MODULE_LICENSE in order to delete module.h -- the license info
is already present at the top of the file.
The uncore change warrants a mention too; it is uncore.c that uses
module.h and not uncore.h; hence the relocation done there.
Link: http://lkml.kernel.org/r/20160714001901.31603-9-paul.gortmaker@windriver.com
Reuse module loader code to write relocations, thereby eliminating the need
for architecture specific relocation code in livepatch. Specifically, reuse
the apply_relocate_add() function in the module loader to write relocations
instead of duplicating functionality in livepatch's arch-dependent
klp_write_module_reloc() function.
In order to accomplish this, livepatch modules manage their own relocation
sections (marked with the SHF_RELA_LIVEPATCH section flag) and
livepatch-specific symbols (marked with SHN_LIVEPATCH symbol section
index). To apply livepatch relocation sections, livepatch symbols
referenced by relocs are resolved and then apply_relocate_add() is called
to apply those relocations.
In addition, remove x86 livepatch relocation code and the s390
klp_write_module_reloc() function stub. They are no longer needed since
relocation work has been offloaded to module loader.
Lastly, mark the module as a livepatch module so that the module loader
canappropriately identify and initialize it.
Signed-off-by: Jessica Yu <jeyu@redhat.com>
Reviewed-by: Miroslav Benes <mbenes@suse.cz>
Acked-by: Josh Poimboeuf <jpoimboe@redhat.com>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # for s390 changes
There is no need for livepatch.h (generic and arch-specific) to depend
on CONFIG_LIVEPATCH. Remove that superfluous dependency.
Reported-by: Josh Poimboeuf <jpoimboe@redhat.com>
There is an #error in asm/livepatch.h for both x86 and s390 in
!CONFIG_LIVEPATCH cases. It does not make much sense as pointed out by
Michael Ellerman. One can happily include asm/livepatch.h with
CONFIG_LIVEPATCH. Remove it as useless.
Suggested-by: Michael Ellerman <mpe@ellerman.id.au>
Signed-off-by: Miroslav Benes <mbenes@suse.cz>
If anyone includes asm/livepatch.h when CONFIG_LIVEPATCH=n the build
fails with the existing error message. Change it to something saner.
[jkosina@suse.cz: fixed changelog typo spotted by Josh]
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
We give up old_addr hint from the coming patch module in cases when kernel load
base has been randomized (as in such case, the coming module has no idea about
the exact randomization offset).
We are currently too pessimistic, and give up immediately as soon as
CONFIG_RANDOMIZE_BASE is set; this doesn't however directly imply that the
load base has actually been randomized. There are config options that
disable kASLR (such as hibernation), user could have disabled kaslr on
kernel command-line, etc.
The loader propagates the information whether kernel has been randomized
through bootparams. This allows us to have the condition more accurate.
On top of that, it seems unnecessary to give up old_addr hints even if
randomization is active. The relocation offset can be computed using
kaslr_ofsset(), and therefore old_addr can be adjusted accordingly.
Storage-class specifier 'extern' is redundant in front of the function
declaration. According to the C specification it has the same meaning as
if not present at all. So remove it.
Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Rename CONFIG_LIVE_PATCHING to CONFIG_LIVEPATCH to make the naming of
the config and the code more consistent.
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Reviewed-by: Jingoo Han <jg1.han@samsung.com>
We are aborting a build in case when gcc doesn't support fentry on x86_64
(regs->ip modification can't really reliably work with mcount).
This however breaks allmodconfig for people with older gccs that don't
support -mfentry.
Turn the build-time failure into runtime failure, resulting in the whole
infrastructure not being initialized if CC_USING_FENTRY is unset.
Reported-by: Andrew Morton <akpm@linux-foundation.org>
The execution flow redirection related implemention in the livepatch
ftrace handler is depended on the specific architecture. This patch
introduces klp_arch_set_pc(like kgdb_arch_set_pc) interface to change
the pt_regs.
Signed-off-by: Li Bin <huawei.libin@huawei.com>
This commit introduces code for the live patching core. It implements
an ftrace-based mechanism and kernel interface for doing live patching
of kernel and kernel module functions.
It represents the greatest common functionality set between kpatch and
kgraft and can accept patches built using either method.
This first version does not implement any consistency mechanism that
ensures that old and new code do not run together. In practice, ~90% of
CVEs are safe to apply in this way, since they simply add a conditional
check. However, any function change that can not execute safely with
the old version of the function can _not_ be safely applied in this
version.
[ jkosina@suse.cz: due to the number of contributions that got folded into
this original patch from Seth Jennings, add SUSE's copyright as well, as
discussed via e-mail ]
Signed-off-by: Seth Jennings <sjenning@redhat.com>
Reviewed-by: Petr Mladek <pmladek@suse.cz>
Signed-off-by: Petr Mladek <pmladek@suse.cz>
