path: root/arch/x86/include/asm/mshyperv.h
2010-05-07x86: Clean up the hypervisor layerH. Peter Anvin
Clean up the hypervisor layer and the hypervisor drivers, using an ops structure instead of an enumeration with if statements. The identity of the hypervisor, if needed, can be tested by testing the pointer value in x86_hyper. The MS-HyperV private state is moved into a normal global variable (it's per-system state, not per-CPU state). Being a normal bss variable, it will be left at all zero on non-HyperV platforms, and so can generally be tested for HyperV-specific features without additional qualification. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Acked-by: Greg KH <greg@kroah.com> Cc: Hank Janssen <hjanssen@microsoft.com> Cc: Alok Kataria <akataria@vmware.com> Cc: Ky Srinivasan <ksrinivasan@novell.com> LKML-Reference: <4BE49778.6060800@zytor.com>
2010-05-06x86: Detect running on a Microsoft HyperV systemKy Srinivasan
This patch integrates HyperV detection within the framework currently used by VmWare. With this patch, we can avoid having to replicate the HyperV detection code in each of the Microsoft HyperV drivers. Reworked and tweaked by Greg K-H to build properly. Signed-off-by: K. Y. Srinivasan <ksrinivasan@novell.com> LKML-Reference: <20100506190841.GA1605@kroah.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Vadim Rozenfeld <vrozenfe@redhat.com> Cc: Avi Kivity <avi@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "K.Prasad" <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Alan Cox <alan@linux.intel.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Cc: Hank Janssen <hjanssen@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
