[ Upstream commit 0f4cd769c410e2285a4e9873a684d90423f03090 ]
When counting dispatched micro-ops with cnt_ctl=1, in order to prevent
sample bias, IBS hardware preloads the least significant 7 bits of
current count (IbsOpCurCnt) with random values, such that, after the
interrupt is handled and counting resumes, the next sample taken
will be slightly perturbed.
The current count bitfield is in the IBS execution control h/w register,
alongside the maximum count field.
Currently, the IBS driver writes that register with the maximum count,
leaving zeroes to fill the current count field, thereby overwriting
the random bits the hardware preloaded for itself.
Fix the driver to actually retain and carry those random bits from the
read of the IBS control register, through to its write, instead of
overwriting the lower current count bits with zeroes.
Tested with:
perf record -c 100001 -e ibs_op/cnt_ctl=1/pp -a -C 0 taskset -c 0 <workload>
'perf annotate' output before:
15.70 65: addsd %xmm0,%xmm1
17.30 add $0x1,%rax
15.88 cmp %rdx,%rax
je 82
17.32 72: test $0x1,%al
jne 7c
7.52 movapd %xmm1,%xmm0
5.90 jmp 65
8.23 7c: sqrtsd %xmm1,%xmm0
12.15 jmp 65
'perf annotate' output after:
16.63 65: addsd %xmm0,%xmm1
16.82 add $0x1,%rax
16.81 cmp %rdx,%rax
je 82
16.69 72: test $0x1,%al
jne 7c
8.30 movapd %xmm1,%xmm0
8.13 jmp 65
8.24 7c: sqrtsd %xmm1,%xmm0
8.39 jmp 65
Tested on Family 15h and 17h machines.
Machines prior to family 10h Rev. C don't have the RDWROPCNT capability,
and have the IbsOpCurCnt bitfield reserved, so this patch shouldn't
affect their operation.
It is unknown why commit db98c5faf8cb ("perf/x86: Implement 64-bit
counter support for IBS") ignored the lower 4 bits of the IbsOpCurCnt
field; the number of preloaded random bits has always been 7, AFAICT.
Signed-off-by: Kim Phillips <kim.phillips@amd.com>
Cc: "Arnaldo Carvalho de Melo" <acme@kernel.org>
Cc: <x86@kernel.org>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: "Borislav Petkov" <bp@alien8.de>
Cc: Stephane Eranian <eranian@google.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: "Namhyung Kim" <namhyung@kernel.org>
Link: https://lkml.kernel.org/r/20190826195730.30614-1-kim.phillips@amd.com
Some versions of Intel PT do not support tracing across VMXON, more
specifically, VMXON will clear TraceEn control bit and any attempt to
set it before VMXOFF will throw a #GP, which in the current state of
things will crash the kernel. Namely:
$ perf record -e intel_pt// kvm -nographic
on such a machine will kill it.
To avoid this, notify the intel_pt driver before VMXON and after
VMXOFF so that it knows when not to enable itself.
Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@infradead.org>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Gleb Natapov <gleb@kernel.org>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Cc: hpa@zytor.com
Link: http://lkml.kernel.org/r/87oa9dwrfk.fsf@ashishki-desk.ger.corp.intel.com
This patch adds a definition for GLOBAL_OVFL_STATUS bit 55
which is used with the Processor Trace (PT) feature.
Signed-off-by: Stephane Eranian <eranian@google.com>
Cc: <stable@vger.kernel.org>
Cc: adrian.hunter@intel.com
Cc: kan.liang@intel.com
Cc: namhyung@kernel.org
Link: http://lkml.kernel.org/r/1457034642-21837-2-git-send-email-eranian@google.com
Add new MSRs (LBR_INFO) and some new MSR bits used by the Intel Skylake
PMU driver.
Cc: eranian@google.com
Link: http://lkml.kernel.org/r/1431285767-27027-4-git-send-email-andi@firstfloor.org
New Fam15h models carry extra feature bits and extend
the MSR register space for IBS ops. Adding them here.
While at it, add functionality to read IbsBrTarget and
OpData4 depending on their availability if user wants a
PERF_SAMPLE_RAW.
Signed-off-by: Aravind Gopalakrishnan <Aravind.Gopalakrishnan@amd.com>
Acked-by: Borislav Petkov <bp@suse.de>
Cc: Jan Kiszka <jan.kiszka@siemens.com>
Cc: Len Brown <len.brown@intel.com>
Cc: <paulus@samba.org>
Cc: <acme@kernel.org>
Link: http://lkml.kernel.org/r/1415651066-13523-1-git-send-email-Aravind.Gopalakrishnan@amd.com
The basic idea is that it does not make sense to list all PEBS
events individually. The list is very long, sometimes outdated
and the hardware doesn't need it. If an event does not support
PEBS it will just not count, there is no security issue.
We need to only list events that something special, like
supporting load or store addresses.
This vastly simplifies the PEBS event selection. It also
speeds up the scheduling because the scheduler doesn't
have to walk as many constraints.
Bugs fixed:
- We do not allow setting forbidden flags with PEBS anymore
(SDM 18.9.4), except for the special cycle event.
This is done using a new constraint macro that also
matches on the event flags.
- Correct DataLA and load/store/na flags reporting on Haswell
[Requires a followon patch]
- We did not allow all PEBS events on Haswell:
We were missing some valid subevents in d1-d2 (MEM_LOAD_UOPS_RETIRED.*,
MEM_LOAD_UOPS_RETIRED_L3_HIT_RETIRED.*)
This includes the changes proposed by Stephane earlier and obsoletes
his patchkit (except for some changes on pre Sandy Bridge/Silvermont
CPUs)
I only did Sandy Bridge and Silvermont and later so far, mostly because these
are the parts I could directly confirm the hardware behavior with hardware
architects. Also I do not believe the older CPUs have any
missing events in their PEBS list, so there's no pressing
need to change them.
I did not implement the flag proposed by Peter to allow
setting forbidden flags. If really needed this could
be implemented on to of this patch.
v2: Fix broken store events on SNB/IVB (Stephane Eranian)
v3: More fixes. Rename some arguments (Stephane Eranian)
v4: List most Haswell events individually again to report
memory operation type correctly.
Add new flags to describe load/store/na for datala.
Update description.
Reviewed-by: Stephane Eranian <eranian@google.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/1407785233-32193-2-git-send-email-eranian@google.com
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Kan Liang <kan.liang@intel.com>
Cc: Maria Dimakopoulou <maria.n.dimakopoulou@gmail.com>
Cc: Mark Davies <junk@eslaf.co.uk>
Cc: Yan, Zheng <zheng.z.yan@intel.com>
Similar to SandyBridge, but has a few new events and two
new counter bits.
There are some new counter flags that need to be prevented
from being set on fixed counters, and allowed to be set
for generic counters.
Also we add support for the counter 2 constraint to handle
all raw events.
(Contains fixes from Stephane Eranian.)
Cc: Andi Kleen <ak@linux.jf.intel.com>
Link: http://lkml.kernel.org/r/1371515812-9646-3-git-send-email-andi@firstfloor.org
On AMD family 15h processors, there are 4 new performance
counters (in addition to 6 core performance counters) that can
be used for counting northbridge events (i.e. DRAM accesses).
Their bit fields are almost identical to the core performance
counters. However, unlike the core performance counters, these
MSRs are shared between multiple cores (that share the same
northbridge).
We will reuse the same code path as existing family 10h
northbridge event constraints handler logic to enforce
this sharing.
Signed-off-by: Jacob Shin <jacob.shin@amd.com>
Acked-by: Stephane Eranian <eranian@google.com>
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Cc: Jacob Shin <jacob.shin@amd.com>
Link: http://lkml.kernel.org/r/1360171589-6381-7-git-send-email-jacob.shin@amd.com
Update these AMD bit field names to be consistent with naming
convention followed by the rest of the file.
Link: http://lkml.kernel.org/r/1360171589-6381-4-git-send-email-jacob.shin@amd.com
Adding a generic way to use __output_copy function with specific copy
function via DEFINE_PERF_OUTPUT_COPY macro.
Using this to add new __output_copy_user function, that provides output
copy from user pointers. For x86 the copy_from_user_nmi function is used
and __copy_from_user_inatomic for the rest of the architectures.
This new function will be used in user stack dump on sample, coming in
next patches.
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Cc: "Frank Ch. Eigler" <fche@redhat.com>
Cc: Arun Sharma <asharma@fb.com>
Cc: Benjamin Redelings <benjamin.redelings@nescent.org>
Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Frank Ch. Eigler <fche@redhat.com>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Robert Richter <robert.richter@amd.com>
Cc: Tom Zanussi <tzanussi@gmail.com>
Cc: Ulrich Drepper <drepper@gmail.com>
Link: http://lkml.kernel.org/r/1344345647-11536-4-git-send-email-jolsa@redhat.com
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Some PMUs don't provide a full register set for their sample,
specifically 'advanced' PMUs like AMD IBS and Intel PEBS which provide
'better' than regular interrupt accuracy.
In this case we use the interrupt regs as basis and over-write some
fields (typically IP) with different information.
The perf core however uses user_mode() to distinguish user/kernel
samples, user_mode() relies on regs->cs. If the interrupt skid pushed
us over a boundary the new IP might not be in the same domain as the
interrupt.
Commit ce5c1fe9a9e ("perf/x86: Fix USER/KERNEL tagging of samples")
tried to fix this by making the perf core use kernel_ip(). This
however is wrong (TM), as pointed out by Linus, since it doesn't allow
for VM86 and non-zero based segments in IA32 mode.
Therefore, provide a new helper to set the regs->ip field,
set_linear_ip(), which massages the regs into a suitable state
assuming the provided IP is in fact a linear address.
Also modify perf_instruction_pointer() and perf_callchain_user() to
deal with segments base offsets.
Link: http://lkml.kernel.org/r/1341910954.3462.102.camel@twins
When CONFIG_PERF_EVENTS disabled, there will have a compiliation
error, because missing struct before structure name.
Signed-off-by: Jovi Zhang <bookjovi@gmail.com>
Cc: Jiri Kosina <trivial@kernel.org>
Link: http://lkml.kernel.org/r/CACV3sbKF%3DCX%2B2jWEWesfCA6rBoQ3wDM4-5ac9MuBtVbCtMRHdQ@mail.gmail.com
Recent Intel microcode resolved the SNB-PEBS issues, so conditionally
enable PEBS on SNB hardware depending on the microcode revision.
Thanks to Stephane for figuring out the various microcode revisions.
Suggested-by: Stephane Eranian <eranian@google.com>
Acked-by: Borislav Petkov <borislav.petkov@amd.com>
Link: http://lkml.kernel.org/n/tip-v3672ziwh9damwqwh1uz3krm@git.kernel.org
There is no need for keeping separate pmu structs. We can enable
amd_{get,put}_event_constraints() functions also for family 15h event.
The advantage is that there is only a single pmu struct for all AMD
cpus. This patch introduces functions to setup the pmu to enabe core
performance counters or counter constraints.
Also, cpuid checks are used instead of family checks where
possible. Thus, it enables the code independently of cpu families if
the feature flag is set.
Signed-off-by: Robert Richter <robert.richter@amd.com>
Link: http://lkml.kernel.org/r/1340217996-2254-4-git-send-email-robert.richter@amd.com
There are macros that are Intel specific and not x86 generic. Rename
them into INTEL_*.
This patch removes X86_PMC_IDX_GENERIC and does:
$ sed -i -e 's/X86_PMC_MAX_/INTEL_PMC_MAX_/g' \
arch/x86/include/asm/kvm_host.h \
arch/x86/include/asm/perf_event.h \
arch/x86/kernel/cpu/perf_event.c \
arch/x86/kernel/cpu/perf_event_p4.c \
arch/x86/kvm/pmu.c
$ sed -i -e 's/X86_PMC_IDX_FIXED/INTEL_PMC_IDX_FIXED/g' \
arch/x86/kernel/cpu/perf_event_intel.c \
arch/x86/kernel/cpu/perf_event_intel_ds.c \
arch/x86/kvm/pmu.c
$ sed -i -e 's/X86_PMC_MSK_/INTEL_PMC_MSK_/g' \
Link: http://lkml.kernel.org/r/1340217996-2254-2-git-send-email-robert.richter@amd.com
Fixing i386 allnoconfig built errors:
arch/x86/built-in.o: In function `amd_pmu_hw_config':
perf_event_amd.c:(.text+0xc3e1): undefined reference to `get_ibs_caps'
Reported-by: Andrew Morton <akpm@linux-foundation.org>
Each IBS sample contains a linear address of the instruction that
caused the sample to trigger. This address is more precise than the
rip that was taken from the interrupt handler's stack. Update the rip
with that address. We use this in the next patch to implement
precise-event sampling on AMD systems using IBS.
Link: http://lkml.kernel.org/r/1333390758-10893-6-git-send-email-robert.richter@amd.com
Pull kvm updates from Avi Kivity:
"Changes include timekeeping improvements, support for assigning host
PCI devices that share interrupt lines, s390 user-controlled guests, a
large ppc update, and random fixes."
This is with the sign-off's fixed, hopefully next merge window we won't
have rebased commits.
* 'kvm-updates/3.4' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (130 commits)
KVM: Convert intx_mask_lock to spin lock
KVM: x86: fix kvm_write_tsc() TSC matching thinko
x86: kvmclock: abstract save/restore sched_clock_state
KVM: nVMX: Fix erroneous exception bitmap check
KVM: Ignore the writes to MSR_K7_HWCR(3)
KVM: MMU: make use of ->root_level in reset_rsvds_bits_mask
KVM: PMU: add proper support for fixed counter 2
KVM: PMU: Fix raw event check
KVM: PMU: warn when pin control is set in eventsel msr
KVM: VMX: Fix delayed load of shared MSRs
KVM: use correct tlbs dirty type in cmpxchg
KVM: Allow host IRQ sharing for assigned PCI 2.3 devices
KVM: Ensure all vcpus are consistent with in-kernel irqchip settings
KVM: x86 emulator: Allow PM/VM86 switch during task switch
KVM: SVM: Fix CPL updates
KVM: x86 emulator: VM86 segments must have DPL 3
KVM: x86 emulator: Fix task switch privilege checks
arch/powerpc/kvm/book3s_hv.c: included linux/sched.h twice
KVM: x86 emulator: correctly mask pmc index bits in RDPMC instruction emulation
KVM: mmu_notifier: Flush TLBs before releasing mmu_lock
Print warning once if pin control bit is set in eventsel msr since
emulation does not support it yet.
Signed-off-by: Gleb Natapov <gleb@redhat.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
This patch implements 64 bit counter support for IBS. The
sampling period is no longer limited to the hw counter width.
The functions perf_event_set_period() and
perf_event_try_update() can be used as generic functions. They
can replace similar code that is duplicate across architectures.
Acked-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/1323968199-9326-5-git-send-email-robert.richter@amd.com
tools/perf/builtin-record.c
tools/perf/builtin-top.c
tools/perf/perf.h
tools/perf/util/top.h
Merge reason: resolve these cherry-picking conflicts.
It turned out that a performance counter on AMD does not
count at all when the GO or HO bit is set in the control
register and SVM is disabled in EFER.
This patch works around this issue by masking out the HO bit
in the performance counter control register when SVM is not
enabled.
The GO bit is not touched because it is only set when the
user wants to count in guest-mode only. So when SVM is
disabled the counter should not run at all and the
not-counting is the intended behaviour.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
Cc: Avi Kivity <avi@redhat.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Gleb Natapov <gleb@redhat.com>
Cc: stable@vger.kernel.org # v3.2
Link: http://lkml.kernel.org/r/1330523852-19566-1-git-send-email-joerg.roedel@amd.com
Put the logic to compute the event index into a per pmu method. This
is required because the x86 rules are weird and wonderful and don't
match the capabilities of the current scheme.
AFAIK only powerpc actually has a usable userspace read of the PMCs
but I'm not at all sure anybody actually used that.
ARM is restored to the default since it currently does not support
userspace access at all. And all software events are provided with a
method that reports their index as 0 (disabled).
Cc: Michael Cree <mcree@orcon.net.nz>
Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com>
Cc: Eric B Munson <emunson@mgebm.net>
Cc: Richard Kuo <rkuo@codeaurora.org>
Link: http://lkml.kernel.org/n/tip-dfydxodki16lylkt3gl2j7cw@git.kernel.org
This patch adds the encoding and definitions necessary for the
unhalted_reference_cycles event avaialble since Intel Core 2 processors.
Link: http://lkml.kernel.org/r/1323559734-3488-2-git-send-email-eranian@google.com
KVM needs to know perf capability to decide which PMU it can expose to a
guest.
Link: http://lkml.kernel.org/r/1320929850-10480-8-git-send-email-gleb@redhat.com
Intel CPUs report non-available architectural events in cpuid leaf
0AH.EBX. Use it to disable events that are not available according
to CPU.
Link: http://lkml.kernel.org/r/1320929850-10480-7-git-send-email-gleb@redhat.com
This patch implements IBS feature detection and initialzation. The
code is shared between perf and oprofile. If IBS is available on the
system for perf, a pmu is setup.
Link: http://lkml.kernel.org/r/1316597423-25723-3-git-send-email-robert.richter@amd.com
Moving IBS macros from oprofile to <asm/perf_event.h> to make it
available to perf. No additional changes.
Link: http://lkml.kernel.org/r/1316597423-25723-2-git-send-email-robert.richter@amd.com
Intel does not have guest/host-only bit in perf counters like AMD
does. To support GO/HO bits KVM needs to switch EVENTSELn values
(or PERF_GLOBAL_CTRL if available) at a guest entry. If a counter is
configured to count only in a guest mode it stays disabled in a host,
but VMX is configured to switch it to enabled value during guest entry.
This patch adds GO/HO tracking to Intel perf code and provides interface
for KVM to get a list of MSRs that need to be switched on a guest entry.
Only cpus with architectural PMU (v1 or later) are supported with this
patch. To my knowledge there is not p6 models with VMX but without
architectural PMU and p4 with VMX are rare and the interface is general
enough to support them if need arise.
Link: http://lkml.kernel.org/r/1317816084-18026-7-git-send-email-gleb@redhat.com
The AMD perf-counters support counting in guest or host-mode
only. Make use of that feature when user-space specified
guest/host-mode only counting.
Link: http://lkml.kernel.org/r/1317816084-18026-3-git-send-email-gleb@redhat.com
In order to prepare for fetching the stack pointer from the
regs when possible in dump_trace() instead of taking the
local one, save the current stack pointer in perf live regs saving.
The perf hardware pmu got initialized at various points in the boot,
some before early_initcall() some after (notably arch_initcall).
The problem is that the NMI lockup detector is ran from early_initcall()
and expects the hardware pmu to be present.
Sanitize this by moving all architecture hardware pmu implementations to
initialize at early_initcall() and move the lockup detector to an explicit
initcall right after that.
Cc: paulus <paulus@samba.org>
Cc: davem <davem@davemloft.net>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Will Deacon <will.deacon@arm.com>
LKML-Reference: <1290707759.2145.119.camel@laptop>
The count value for IBS op sampling has been extended by 7 bits. The
feature is reflected in bit 6 (OpCntExt) of the IBS capability
register (CPUID Fn8000_001B_EAX).
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing into perf/core
Drop this argument now that we always want to rewind only to the
state of the first caller.
It means frame pointers are not necessary anymore to reliably get
the source of an event. But this also means we need this helper
to be a macro now, as an inline function is not an option since
we need to know when to provide a default implentation.
Fixes to 'cpuid10_edx' to comply with Intel documentation.
According to the Intel Manual, Volume 2A, Table 3-12, the cpuid for
architecture performance monitoring returns, in EDX, two pieces of
information:
1) Number of fixed-function counters (5 bits, not 4)
2) Width of fixed-function counters (8 bits)
Signed-off-by: Livio Soares <livio@eecg.toronto.edu>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: Arjan van de Ven <arjan@linux.intel.com>
LKML-Reference: <new-submission>
Below patch introduces perf_guest_info_callbacks and related
register/unregister functions. Add more PERF_RECORD_MISC_XXX bits
meaning guest kernel and guest user space.
Signed-off-by: Zhang Yanmin <yanmin_zhang@linux.intel.com>
ARCH_PERFMON_EVENTSEL bit masks are often used in the kernel. This
patch adds macros for the bit masks and removes local defines. The
function intel_pmu_raw_event() becomes x86_pmu_raw_event() which is
generic for x86 models and same also for p6. Duplicate code is
removed.
LKML-Reference: <20100330092821.GH11907@erda.amd.com>
The big rename:
cdd6c48 perf: Do the big rename: Performance Counters -> Performance Events
accidentally renamed some members of stucts that were named after
registers in the spec. To avoid confusion this patch reverts some
changes. The related specs are MSR descriptions in AMD's BKDGs and the
ARCHITECTURAL PERFORMANCE MONITORING section in the Intel 64 and IA-32
Architectures Software Developer's Manuals.
This patch does:
$ sed -i -e 's:num_events:num_counters:g' \
arch/x86/kernel/cpu/perf_event_amd.c \
arch/x86/kernel/cpu/perf_event_p6.c \
arch/x86/oprofile/op_model_ppro.c
$ sed -i -e 's:event_bits:cntval_bits:g' -e 's:event_mask:cntval_mask:g' \
LKML-Reference: <1269880612-25800-2-git-send-email-robert.richter@amd.com>
The netburst PMU is way different from the "architectural
perfomance monitoring" specification that current CPUs use.
P4 uses a tuple of ESCR+CCCR+COUNTER MSR registers to handle
perfomance monitoring events.
A few implementational details:
1) We need a separate x86_pmu::hw_config helper in struct
x86_pmu since register bit-fields are quite different from P6,
Core and later cpu series.
2) For the same reason is a x86_pmu::schedule_events helper
introduced.
3) hw_perf_event::config consists of packed ESCR+CCCR values.
It's allowed since in reality both registers only use a half
of their size. Of course before making a real write into a
particular MSR we need to unpack the value and extend it to
a proper size.
4) The tuple of packed ESCR+CCCR in hw_perf_event::config
doesn't describe the memory address of ESCR MSR register
so that we need to keep a mapping between these tuples
used and available ESCR (various P4 events may use same
ESCRs but not simultaneously), for this sake every active
event has a per-cpu map of hw_perf_event::idx <--> ESCR
addresses.
5) Since hw_perf_event::idx is an offset to counter/control register
we need to lift X86_PMC_MAX_GENERIC up, otherwise kernel
strips it down to 8 registers and event armed may never be turned
off (ie the bit in active_mask is set but the loop never reaches
this index to check), thanks to Peter Zijlstra
Restrictions:
- No cascaded counters support (do we ever need them?)
- No dependent events support (so PERF_COUNT_HW_INSTRUCTIONS
doesn't work for now)
- There are events with same counters which can't work simultaneously
(need to use intersected ones due to broken counter 1)
- No PERF_COUNT_HW_CACHE_ events yet
Todo:
- Implement dependent events
- Need proper hashing for event opcodes (no linear search, good for
debugging stage but not in real loads)
- Some events counted during a clock cycle -- need to set threshold
for them and count every clock cycle just to get summary statistics
(ie to behave the same way as other PMUs do)
- Need to swicth to use event_constraints
- To support RAW events we need to encode a global list of P4 events
into p4_templates
- Cache events need to be added
Event support status matrix:
Event status
cycles works
cache-references works
cache-misses works
branch-misses works
bus-cycles partially (does not work on 64bit cpu with HT enabled)
instruction doesnt work (needs dependent event [mop tagging])
branches doesnt work
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
LKML-Reference: <20100311165439.GB5129@lenovo>
Use the LBR to fix up the PEBS IP+1 issue.
As said, PEBS reports the next instruction, here we use the LBR to find
the last branch and from that construct the actual IP. If the IP matches
the LBR-TO, we use LBR-FROM, otherwise we use the LBR-TO address as the
beginning of the last basic block and decode forward.
Once we find a match to the current IP, we use the previous location.
This patch introduces a new ABI element: PERF_RECORD_MISC_EXACT, which
conveys that the reported IP (PERF_SAMPLE_IP) is the exact instruction
that caused the event (barring CPU errata).
The fixup can fail due to various reasons:
1) LBR contains invalid data (quite possible)
2) part of the basic block got paged out
3) the reported IP isn't part of the basic block (see 1)
Cc: Masami Hiramatsu <mhiramat@redhat.com>
Cc: "Zhang, Yanmin" <yanmin_zhang@linux.intel.com>
Cc: paulus@samba.org
Cc: robert.richter@amd.com
Cc: fweisbec@gmail.com
LKML-Reference: <20100304140100.619375431@chello.nl>
Patch 1da53e0230 ("perf_events, x86: Improve x86 event scheduling")
lost us one of the fixed purpose counters and then ed8777fc13
("perf_events, x86: Fix event constraint masks") broke it even
further.
Widen the fixed event mask to event+umask and specify the full config
for each of the 3 fixed purpose counters. Then let the init code fill
out the placement for the GP regs based on the cpuid info.
For consistency reasons this patch renames
ARCH_PERFMON_EVENTSEL0_ENABLE to ARCH_PERFMON_EVENTSEL_ENABLE.
The following is performed:
$ sed -i -e s/ARCH_PERFMON_EVENTSEL0_ENABLE/ARCH_PERFMON_EVENTSEL_ENABLE/g \
arch/x86/include/asm/perf_event.h arch/x86/kernel/cpu/perf_event.c \
arch/x86/kernel/cpu/perfctr-watchdog.c \
arch/x86/oprofile/op_model_amd.c arch/x86/oprofile/op_model_ppro.c
This patch moves code from oprofile to perf_event.h to make it also
available for usage by perf.
Merge reason: We want to queue up a dependent patch. Also update to
later -rc's.
Since constraints are specified on the event number, not number
and unit mask shorten the constraint masks so that we'll
actually match something.
LKML-Reference: <20100127221121.967610372@chello.nl>
This patch improves event scheduling by maximizing the use of PMU
registers regardless of the order in which events are created in a group.
The algorithm takes into account the list of counter constraints for each
event. It assigns events to counters from the most constrained, i.e.,
works on only one counter, to the least constrained, i.e., works on any
counter.
Intel Fixed counter events and the BTS special event are also handled via
this algorithm which is designed to be fairly generic.
The patch also updates the validation of an event to use the scheduling
algorithm. This will cause early failure in perf_event_open().
The 2nd version of this patch follows the model used by PPC, by running
the scheduling algorithm and the actual assignment separately. Actual
assignment takes place in hw_perf_enable() whereas scheduling is
implemented in hw_perf_group_sched_in() and x86_pmu_enable().
[ fixup whitespace and style nits as well as adding is_x86_event() ]
LKML-Reference: <4b5430c6.0f975e0a.1bf9.ffff85fe@mx.google.com>
Propagate the ANY bit into the fixed counter config for v3 and higher.
[a.p.zijlstra@chello.nl: split from larger patch]
