commit 8376efd31d3d7c44bd05be337adde023cc531fa1 upstream.
Commit 11e63f6d920d added cache flushing for unaligned writes from an
iovec, covering the first and last cache line of a >= 8 byte write and
the first cache line of a < 8 byte write. But an unaligned write of
2-7 bytes can still cover two cache lines, so make sure we flush both
in that case.
Fixes: 11e63f6d920d ("x86, pmem: fix broken __copy_user_nocache ...")
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 11e63f6d920d6f2dfd3cd421e939a4aec9a58dcd upstream.
Before we rework the "pmem api" to stop abusing __copy_user_nocache()
for memcpy_to_pmem() we need to fix cases where we may strand dirty data
in the cpu cache. The problem occurs when copy_from_iter_pmem() is used
for arbitrary data transfers from userspace. There is no guarantee that
these transfers, performed by dax_iomap_actor(), will have aligned
destinations or aligned transfer lengths. Backstop the usage
__copy_user_nocache() with explicit cache management in these unaligned
cases.
Yes, copy_from_iter_pmem() is now too big for an inline, but addressing
that is saved for a later patch that moves the entirety of the "pmem
api" into the pmem driver directly.
Fixes: 5de490daec8b ("pmem: add copy_from_iter_pmem() and clear_pmem()")
Cc: <x86@kernel.org>
Cc: Jan Kara <jack@suse.cz>
Cc: Jeff Moyer <jmoyer@redhat.com>
Cc: Matthew Wilcox <mawilcox@microsoft.com>
Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Use the mcsafe_key defined in the previous patch to make decisions on which
copy function to use. We can't use the FEATURE bit any more because PCI
quirks run too late to affect the patching of code. So we use a static key.
Turn memcpy_mcsafe() into an inline function to make life easier for
callers. The assembly code that actually does the copy is now named
memcpy_mcsafe_unrolled()
Signed-off-by: Tony Luck <tony.luck@intel.com>
Acked-by: Borislav Petkov <bp@suse.de>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Boris Petkov <bp@suse.de>
Link: http://lkml.kernel.org/r/bfde2fc774e94f53d91b70a4321c85a0d33e7118.1472754712.git.tony.luck@intel.com
The __pmem address space was meant to annotate codepaths that touch
persistent memory and need to coordinate a call to wmb_pmem(). Now that
wmb_pmem() is gone, there is little need to keep this annotation.
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
All users have been replaced with flushing in the pmem driver.
Update the definition of memcpy_from_pmem() to return 0 or a negative
error code. Implement x86/arch_memcpy_from_pmem() with memcpy_mcsafe().
Acked-by: Ingo Molnar <mingo@kernel.org>
If a write is directed at a known bad block perform the following:
1/ write the data
2/ send a clear poison command
3/ invalidate the poison out of the cache hierarchy
Reviewed-by: Vishal Verma <vishal.l.verma@intel.com>
__arch_wb_cache_pmem() was already an internal implementation detail of
the x86 PMEM API, but this functionality needs to be exported as part of
the general PMEM API to handle the fsync/msync case for DAX mmaps.
One thing worth noting is that we really do want this to be part of the
PMEM API as opposed to a stand-alone function like clflush_cache_range()
because of ordering restrictions. By having wb_cache_pmem() as part of
the PMEM API we can leave it unordered, call it multiple times to write
back large amounts of memory, and then order the multiple calls with a
single wmb_pmem().
Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
Cc: Jan Kara <jack@suse.com>
Cc: Jeff Layton <jlayton@poochiereds.net>
Cc: Matthew Wilcox <willy@linux.intel.com>
Cc: Matthew Wilcox <matthew.r.wilcox@intel.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
To date, we have implemented two I/O usage models for persistent memory,
PMEM (a persistent "ram disk") and DAX (mmap persistent memory into
userspace). This series adds a third, DAX-GUP, that allows DAX mappings
to be the target of direct-i/o. It allows userspace to coordinate
DMA/RDMA from/to persistent memory.
The implementation leverages the ZONE_DEVICE mm-zone that went into
4.3-rc1 (also discussed at kernel summit) to flag pages that are owned
and dynamically mapped by a device driver. The pmem driver, after
mapping a persistent memory range into the system memmap via
devm_memremap_pages(), arranges for DAX to distinguish pfn-only versus
page-backed pmem-pfns via flags in the new pfn_t type.
The DAX code, upon seeing a PFN_DEV+PFN_MAP flagged pfn, flags the
resulting pte(s) inserted into the process page tables with a new
_PAGE_DEVMAP flag. Later, when get_user_pages() is walking ptes it keys
off _PAGE_DEVMAP to pin the device hosting the page range active.
Finally, get_page() and put_page() are modified to take references
against the device driver established page mapping.
Finally, this need for "struct page" for persistent memory requires
memory capacity to store the memmap array. Given the memmap array for a
large pool of persistent may exhaust available DRAM introduce a
mechanism to allocate the memmap from persistent memory. The new
"struct vmem_altmap *" parameter to devm_memremap_pages() enables
arch_add_memory() to use reserved pmem capacity rather than the page
allocator.
This patch (of 25):
Both __dax_pmd_fault, and clear_pmem() were taking special steps to
clear memory a page at a time to take advantage of non-temporal
clear_page() implementations. However, x86_64 does not use non-temporal
instructions for clear_page(), and arch_clear_pmem() was always
incurring the cost of __arch_wb_cache_pmem().
Clean up the assumption that doing clear_pmem() a page at a time is more
performant.
Reported-by: Dave Hansen <dave.hansen@linux.intel.com>
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
Cc: Christoffer Dall <christoffer.dall@linaro.org>
Cc: David Airlie <airlied@linux.ie>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Jens Axboe <axboe@fb.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Logan Gunthorpe <logang@deltatee.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Toshi Kani <toshi.kani@hpe.com>
Given that a write-back (WB) mapping plus non-temporal stores is
expected to be the most efficient way to access PMEM, update the
definition of ARCH_HAS_PMEM_API to imply arch support for
WB-mapped-PMEM. This is needed as a pre-requisite for adding PMEM to
the direct map and mapping it with struct page.
The above clarification for X86_64 means that memcpy_to_pmem() is
permitted to use the non-temporal arch_memcpy_to_pmem() rather than
needlessly fall back to default_memcpy_to_pmem() when the pcommit
instruction is not available. When arch_memcpy_to_pmem() is not
guaranteed to flush writes out of cache, i.e. on older X86_32
implementations where non-temporal stores may just dirty cache,
ARCH_HAS_PMEM_API is simply disabled.
The default fall back for persistent memory handling remains. Namely,
map it with the WT (write-through) cache-type and hope for the best.
arch_has_pmem_api() is updated to only indicate whether the arch
provides the proper helpers to meet the minimum "writes are visible
outside the cache hierarchy after memcpy_to_pmem() + wmb_pmem()". Code
that cares whether wmb_pmem() actually flushes writes to pmem must now
call arch_has_wmb_pmem() directly.
[hch: set ARCH_HAS_PMEM_API=n on x86_32]
[toshi: x86_32 compile fixes]
Signed-off-by: Toshi Kani <toshi.kani@hp.com>
This should result in a pretty sizeable performance gain for reads. For
rough comparison I did some simple read testing using PMEM to compare
reads of write combining (WC) mappings vs write-back (WB). This was
done on a random lab machine.
PMEM reads from a write combining mapping:
# dd of=/dev/null if=/dev/pmem0 bs=4096 count=100000
100000+0 records in
100000+0 records out
409600000 bytes (410 MB) copied, 9.2855 s, 44.1 MB/s
PMEM reads from a write-back mapping:
# dd of=/dev/null if=/dev/pmem0 bs=4096 count=1000000
1000000+0 records in
1000000+0 records out
4096000000 bytes (4.1 GB) copied, 3.44034 s, 1.2 GB/s
To be able to safely support a write-back aperture I needed to add
support for the "read flush" _DSM flag, as outlined in the DSM spec:
http://pmem.io/documents/NVDIMM_DSM_Interface_Example.pdf
This flag tells the ND BLK driver that it needs to flush the cache lines
associated with the aperture after the aperture is moved but before any
new data is read. This ensures that any stale cache lines from the
previous contents of the aperture will be discarded from the processor
cache, and the new data will be read properly from the DIMM. We know
that the cache lines are clean and will be discarded without any
writeback because either a) the previous aperture operation was a read,
and we never modified the contents of the aperture, or b) the previous
aperture operation was a write and we must have written back the dirtied
contents of the aperture to the DIMM before the I/O was completed.
In order to add support for the "read flush" flag I needed to add a
generic routine to invalidate cache lines, mmio_flush_range(). This is
protected by the ARCH_HAS_MMIO_FLUSH Kconfig variable, and is currently
only supported on x86.
Add support for two new PMEM APIs, copy_from_iter_pmem() and
clear_pmem(). copy_from_iter_pmem() is used to copy data from an
iterator into a PMEM buffer. clear_pmem() zeros a PMEM memory range.
Both of these new APIs must be explicitly ordered using a wmb_pmem()
function call and are implemented in such a way that the wmb_pmem()
will make the stores to PMEM durable. Because both APIs are unordered
they can be called as needed without introducing any unwanted memory
barriers.
Prior to this change x86_64 used the pmem defines in
arch/x86/include/asm/pmem.h, and UM used the default ones at the
top of include/linux/pmem.h. The inclusion or exclusion in linux/pmem.h
was controlled by CONFIG_ARCH_HAS_PMEM_API, but the ones in asm/pmem.h
were controlled by ARCH_HAS_NOCACHE_UACCESS.
Instead, control them both with CONFIG_ARCH_HAS_PMEM_API so that it's
clear that they are related and we don't run into the possibility where
they are both included or excluded. Also remove a bunch of stale
function prototypes meant for UM in asm/pmem.h - these just conflicted
with the inline defaults in linux/pmem.h and gave compile errors.
Prior to this change arch_has_wmb_pmem() was only called by
arch_has_pmem_api(). Both arch_has_wmb_pmem() and arch_has_pmem_api()
checked to make sure that CONFIG_ARCH_HAS_PMEM_API was enabled.
Instead, remove the old arch_has_wmb_pmem() wrapper to be rid of one
extra layer of indirection and the redundant CONFIG_ARCH_HAS_PMEM_API
check. Rename __arch_has_wmb_pmem() to arch_has_wmb_pmem() since we no
longer have a wrapper, and just have arch_has_pmem_api() call the
architecture specific arch_has_wmb_pmem() directly.
Move the x86 PMEM API implementation out of asm/cacheflush.h and into
its own header asm/pmem.h. This will allow members of the PMEM API to
be more easily identified on this and other architectures.
Suggested-by: Christoph Hellwig <hch@lst.de>
