path: root/arch/x86/include/asm/processor.h
2012-03-30x86: Remove the ancient and deprecated disable_hlt() and enable_hlt() facilityLen Brown
The X86_32-only disable_hlt/enable_hlt mechanism was used by the 32-bit floppy driver. Its effect was to replace the use of the HLT instruction inside default_idle() with cpu_relax() - essentially it turned off the use of HLT. This workaround was commented in the code as: "disable hlt during certain critical i/o operations" "This halt magic was a workaround for ancient floppy DMA wreckage. It should be safe to remove." H. Peter Anvin additionally adds: "To the best of my knowledge, no-hlt only existed because of flaky power distributions on 386/486 systems which were sold to run DOS. Since DOS did no power management of any kind, including HLT, the power draw was fairly uniform; when exposed to the much hhigher noise levels you got when Linux used HLT caused some of these systems to fail. They were by far in the minority even back then." Alan Cox further says: "Also for the Cyrix 5510 which tended to go castors up if a HLT occurred during a DMA cycle and on a few other boxes HLT during DMA tended to go astray. Do we care ? I doubt it. The 5510 was pretty obscure, the 5520 fixed it, the 5530 is probably the oldest still in any kind of use." So, let's finally drop this. Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Stephen Hemminger <shemminger@vyatta.com Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: <stable@kernel.org> Link: http://lkml.kernel.org/n/tip-3rhk9bzf0x9rljkv488tloib@git.kernel.org [ If anyone cares then alternative instruction patching could be used to replace HLT with a one-byte NOP instruction. Much simpler. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-03-29Merge branch 'x86-cleanups-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 cleanups from Peter Anvin: "The biggest textual change is the cleanup to use symbolic constants for x86 trap values. The only *functional* change and the reason for the x86/x32 dependency is the move of is_ia32_task() into <asm/thread_info.h> so that it can be used in other code that needs to understand if a system call comes from the compat entry point (and therefore uses i386 system call numbers) or not. One intended user for that is the BPF system call filter. Moving it out of <asm/compat.h> means we can define it unconditionally, returning always true on i386." * 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Move is_ia32_task to asm/thread_info.h from asm/compat.h x86: Rename trap_no to trap_nr in thread_struct x86: Use enum instead of literals for trap values
2012-03-29Merge branch 'x86-x32-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x32 support for x86-64 from Ingo Molnar: "This tree introduces the X32 binary format and execution mode for x86: 32-bit data space binaries using 64-bit instructions and 64-bit kernel syscalls. This allows applications whose working set fits into a 32 bits address space to make use of 64-bit instructions while using a 32-bit address space with shorter pointers, more compressed data structures, etc." Fix up trivial context conflicts in arch/x86/{Kconfig,vdso/vma.c} * 'x86-x32-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (71 commits) x32: Fix alignment fail in struct compat_siginfo x32: Fix stupid ia32/x32 inversion in the siginfo format x32: Add ptrace for x32 x32: Switch to a 64-bit clock_t x32: Provide separate is_ia32_task() and is_x32_task() predicates x86, mtrr: Use explicit sizing and padding for the 64-bit ioctls x86/x32: Fix the binutils auto-detect x32: Warn and disable rather than error if binutils too old x32: Only clear TIF_X32 flag once x32: Make sure TS_COMPAT is cleared for x32 tasks fs: Remove missed ->fds_bits from cessation use of fd_set structs internally fs: Fix close_on_exec pointer in alloc_fdtable x32: Drop non-__vdso weak symbols from the x32 VDSO x32: Fix coding style violations in the x32 VDSO code x32: Add x32 VDSO support x32: Allow x32 to be configured x32: If configured, add x32 system calls to system call tables x32: Handle process creation x32: Signal-related system calls x86: Add #ifdef CONFIG_COMPAT to <asm/sys_ia32.h> ...
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Disintegrate asm/system.h for X86David Howells
Disintegrate asm/system.h for X86. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: H. Peter Anvin <hpa@zytor.com> cc: x86@kernel.org
2012-03-24Merge tag 'bug-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull <linux/bug.h> cleanup from Paul Gortmaker: "The changes shown here are to unify linux's BUG support under the one <linux/bug.h> file. Due to historical reasons, we have some BUG code in bug.h and some in kernel.h -- i.e. the support for BUILD_BUG in linux/kernel.h predates the addition of linux/bug.h, but old code in kernel.h wasn't moved to bug.h at that time. As a band-aid, kernel.h was including <asm/bug.h> to pseudo link them. This has caused confusion[1] and general yuck/WTF[2] reactions. Here is an example that violates the principle of least surprise: CC lib/string.o lib/string.c: In function 'strlcat': lib/string.c:225:2: error: implicit declaration of function 'BUILD_BUG_ON' make[2]: *** [lib/string.o] Error 1 $ $ grep linux/bug.h lib/string.c #include <linux/bug.h> $ We've included <linux/bug.h> for the BUG infrastructure and yet we still get a compile fail! [We've not kernel.h for BUILD_BUG_ON.] Ugh - very confusing for someone who is new to kernel development. With the above in mind, the goals of this changeset are: 1) find and fix any include/*.h files that were relying on the implicit presence of BUG code. 2) find and fix any C files that were consuming kernel.h and hence relying on implicitly getting some/all BUG code. 3) Move the BUG related code living in kernel.h to <linux/bug.h> 4) remove the asm/bug.h from kernel.h to finally break the chain. During development, the order was more like 3-4, build-test, 1-2. But to ensure that git history for bisect doesn't get needless build failures introduced, the commits have been reorderd to fix the problem areas in advance. [1] https://lkml.org/lkml/2012/1/3/90 [2] https://lkml.org/lkml/2012/1/17/414" Fix up conflicts (new radeon file, reiserfs header cleanups) as per Paul and linux-next. * tag 'bug-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: kernel.h: doesn't explicitly use bug.h, so don't include it. bug: consolidate BUILD_BUG_ON with other bug code BUG: headers with BUG/BUG_ON etc. need linux/bug.h bug.h: add include of it to various implicit C users lib: fix implicit users of kernel.h for TAINT_WARN spinlock: macroize assert_spin_locked to avoid bug.h dependency x86: relocate get/set debugreg fcns to include/asm/debugreg.
2012-03-22Merge branch 'x86-debug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86/debug changes from Ingo Molnar. * 'x86-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Fix section warnings x86-64: Fix CFI data for common_interrupt() x86: Properly _init-annotate NMI selftest code x86/debug: Fix/improve the show_msr=<cpus> debug print out
2012-03-13x86: Rename trap_no to trap_nr in thread_structSrikar Dronamraju
There are precedences of trap number being referred to as trap_nr. However thread struct refers trap number as trap_no. Change it to trap_nr. Also use enum instead of left-over literals for trap values. This is pure cleanup, no functional change intended. Suggested-by: Ingo Molnar <mingo@eltu.hu> Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jim Keniston <jkenisto@linux.vnet.ibm.com> Cc: Linux-mm <linux-mm@kvack.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20120312092555.5379.942.sendpatchset@srdronam.in.ibm.com [ Fixed the math-emu build ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-13Merge branch 'x86/x32' into x86/cleanupsIngo Molnar
Merge reason: We are going to merge a dependent patch. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-02-28x86: relocate get/set debugreg fcns to include/asm/debugreg.Paul Gortmaker
Since we already have a debugreg.h header file, move the assoc. get/set functions to it. In addition to it being the logical home for them, it has a secondary advantage. The functions that are moved use BUG(). So we really need to have linux/bug.h in scope. But asm/processor.h is used about 600 times, vs. only about 15 for debugreg.h -- so adding bug.h to the latter reduces the amount of time we'll be processing it during a compile. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Ingo Molnar <mingo@elte.hu> CC: Thomas Gleixner <tglx@linutronix.de> CC: "H. Peter Anvin" <hpa@zytor.com>
2012-02-20x86-64: Add prototype for old_rsp to a header fileH. J. Lu
So far this has only been used in process_64.c, but the x32 code will need it in additional code. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2012-02-20x86: Factor out TIF_IA32 from 32-bit address spaceH. Peter Anvin
Factor out IA32 (compatibility instruction set) from 32-bit address space in the thread_info flags; this is a precondition patch for x32 support. Originally-by: H. J. Lu <hjl.tools@gmail.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Link: http://lkml.kernel.org/n/tip-4pr1xnnksprt7t0h3w5fw4rv@git.kernel.org
2012-02-20i387: support lazy restore of FPU stateLinus Torvalds
This makes us recognize when we try to restore FPU state that matches what we already have in the FPU on this CPU, and avoids the restore entirely if so. To do this, we add two new data fields: - a percpu 'fpu_owner_task' variable that gets written any time we update the "has_fpu" field, and thus acts as a kind of back-pointer to the task that owns the CPU. The exception is when we save the FPU state as part of a context switch - if the save can keep the FPU state around, we leave the 'fpu_owner_task' variable pointing at the task whose FP state still remains on the CPU. - a per-thread 'last_cpu' field, that indicates which CPU that thread used its FPU on last. We update this on every context switch (writing an invalid CPU number if the last context switch didn't leave the FPU in a lazily usable state), so we know that *that* thread has done nothing else with the FPU since. These two fields together can be used when next switching back to the task to see if the CPU still matches: if 'fpu_owner_task' matches the task we are switching to, we know that no other task (or kernel FPU usage) touched the FPU on this CPU in the meantime, and if the current CPU number matches the 'last_cpu' field, we know that this thread did no other FP work on any other CPU, so the FPU state on the CPU must match what was saved on last context switch. In that case, we can avoid the 'f[x]rstor' entirely, and just clear the CR0.TS bit. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-18i387: move TS_USEDFPU flag from thread_info to task_structLinus Torvalds
This moves the bit that indicates whether a thread has ownership of the FPU from the TS_USEDFPU bit in thread_info->status to a word of its own (called 'has_fpu') in task_struct->thread.has_fpu. This fixes two independent bugs at the same time: - changing 'thread_info->status' from the scheduler causes nasty problems for the other users of that variable, since it is defined to be thread-synchronous (that's what the "TS_" part of the naming was supposed to indicate). So perfectly valid code could (and did) do ti->status |= TS_RESTORE_SIGMASK; and the compiler was free to do that as separate load, or and store instructions. Which can cause problems with preemption, since a task switch could happen in between, and change the TS_USEDFPU bit. The change to TS_USEDFPU would be overwritten by the final store. In practice, this seldom happened, though, because the 'status' field was seldom used more than once, so gcc would generally tend to generate code that used a read-modify-write instruction and thus happened to avoid this problem - RMW instructions are naturally low fat and preemption-safe. - On x86-32, the current_thread_info() pointer would, during interrupts and softirqs, point to a *copy* of the real thread_info, because x86-32 uses %esp to calculate the thread_info address, and thus the separate irq (and softirq) stacks would cause these kinds of odd thread_info copy aliases. This is normally not a problem, since interrupts aren't supposed to look at thread information anyway (what thread is running at interrupt time really isn't very well-defined), but it confused the heck out of irq_fpu_usable() and the code that tried to squirrel away the FPU state. (It also caused untold confusion for us poor kernel developers). It also turns out that using 'task_struct' is actually much more natural for most of the call sites that care about the FPU state, since they tend to work with the task struct for other reasons anyway (ie scheduling). And the FPU data that we are going to save/restore is found there too. Thanks to Arjan Van De Ven <arjan@linux.intel.com> for pointing us to the %esp issue. Cc: Arjan van de Ven <arjan@linux.intel.com> Reported-and-tested-by: Raphael Prevost <raphael@buro.asia> Acked-and-tested-by: Suresh Siddha <suresh.b.siddha@intel.com> Tested-by: Peter Anvin <hpa@zytor.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-12x86/debug: Fix/improve the show_msr=<cpus> debug print outYinghai Lu
Found out that show_msr=<cpus> is broken, when I asked a user to use it to capture debug info about broken MTRR's whose MTRR settings are probably different between CPUs. Only the first CPUs MSRs are printed, but that is not enough to track down the suspected bug. For years we called print_cpu_msr from print_cpu_info(), but this commit: | commit 2eaad1fddd7450a48ad464229775f97fbfe8af36 | Author: Mike Travis <travis@sgi.com> | Date: Thu Dec 10 17:19:36 2009 -0800 | | x86: Limit the number of processor bootup messages removed the print_cpu_info() call from all APs. Put it back - it will only print MSRs when the user specifically requests them via show_msr=<cpus>. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Mike Travis <travis@sgi.com> Link: http://lkml.kernel.org/r/1329069237-11483-1-git-send-email-yinghai@kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-21x86: Simplify code by removing a !SMP #ifdefs from 'struct cpuinfo_x86'Kevin Winchester
Several fields in struct cpuinfo_x86 were not defined for the !SMP case, likely to save space. However, those fields still have some meaning for UP, and keeping them allows some #ifdef removal from other files. The additional size of the UP kernel from this change is not significant enough to worry about keeping up the distinction: text data bss dec hex filename 4737168 506459 972040 6215667 5ed7f3 vmlinux.o.before 4737444 506459 972040 6215943 5ed907 vmlinux.o.after for a difference of 276 bytes for an example UP config. If someone wants those 276 bytes back badly then it should be implemented in a cleaner way. Signed-off-by: Kevin Winchester <kjwinchester@gmail.com> Cc: Steffen Persvold <sp@numascale.com> Link: http://lkml.kernel.org/r/1324428742-12498-1-git-send-email-kjwinchester@gmail.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-10-14x86, intel: Output microcode revision in /proc/cpuinfoAndi Kleen
I got a request to make it easier to determine the microcode update level on Intel CPUs. This patch adds a new "microcode" field to /proc/cpuinfo. The microcode level is also outputed on fatal machine checks together with the other CPUID model information. I removed the respective code from the microcode update driver, it just reads the field from cpu_data. Also when the microcode is updated it fills in the new values too. I had to add a memory barrier to native_cpuid to prevent it being optimized away when the result is not used. This turns out to clean up further code which already got this information manually. This is done in followon patches. Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Link: http://lkml.kernel.org/r/1318466795-7393-1-git-send-email-andi@firstfloor.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-03x86 idle: move mwait_idle_with_hints() to where it is usedLen Brown
...and make it static no functional change cc: x86@kernel.org Acked-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-29Merge branch 'idle-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6 * 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6: x86 idle: deprecate mwait_idle() and "idle=mwait" cmdline param x86 idle: deprecate "no-hlt" cmdline param x86 idle APM: deprecate CONFIG_APM_CPU_IDLE x86 idle floppy: deprecate disable_hlt() x86 idle: EXPORT_SYMBOL(default_idle, pm_idle) only when APM demands it x86 idle: clarify AMD erratum 400 workaround idle governor: Avoid lock acquisition to read pm_qos before entering idle cpuidle: menu: fixed wrapping timers at 4.294 seconds
2011-05-29x86 idle: clarify AMD erratum 400 workaroundLen Brown
The workaround for AMD erratum 400 uses the term "c1e" falsely suggesting: 1. Intel C1E is somehow involved 2. All AMD processors with C1E are involved Use the string "amd_c1e" instead of simply "c1e" to clarify that this workaround is specific to AMD's version of C1E. Use the string "e400" to clarify that the workaround is specific to AMD processors with Erratum 400. This patch is text-substitution only, with no functional change. cc: x86@kernel.org Acked-by: Borislav Petkov <borislav.petkov@amd.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-26x86: Move llc_shared_map out of cpu_infoYinghai Lu
cpu_info is already with per_cpu, We can take llc_shared_map out of cpu_info, and declare it as per_cpu variable directly. So later referencing could be simple and directly instead of diving to find cpu_info at first. Also could make smp_store_cpu_info() much simple to avoid to do save and restore trick. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Hans Rosenfeld <hans.rosenfeld@amd.com> Cc: Alok N Kataria <akataria@vmware.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Hans J. Koch <hjk@linutronix.de> Cc: Tejun Heo <tj@kernel.org> Cc: Borislav Petkov <borislav.petkov@amd.com> Cc: Andreas Herrmann <andreas.herrmann3@amd.com> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <4D3A16E8.5020608@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-13Merge branch 'idle-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6 * 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6: cpuidle/x86/perf: fix power:cpu_idle double end events and throw cpu_idle events from the cpuidle layer intel_idle: open broadcast clock event cpuidle: CPUIDLE_FLAG_CHECK_BM is omap3_idle specific cpuidle: CPUIDLE_FLAG_TLB_FLUSHED is specific to intel_idle cpuidle: delete unused CPUIDLE_FLAG_SHALLOW, BALANCED, DEEP definitions SH, cpuidle: delete use of NOP CPUIDLE_FLAGS_SHALLOW cpuidle: delete NOP CPUIDLE_FLAG_POLL ACPI: processor_idle: delete use of NOP CPUIDLE_FLAGs cpuidle: Rename X86 specific idle poll state[0] from C0 to POLL ACPI, intel_idle: Cleanup idle= internal variables cpuidle: Make cpuidle_enable_device() call poll_idle_init() intel_idle: update Sandy Bridge core C-state residency targets
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-12Merge branch 'linus' into idle-testLen Brown
2011-01-12ACPI, intel_idle: Cleanup idle= internal variablesThomas Renninger
Having four variables for the same thing: idle_halt, idle_nomwait, force_mwait and boot_option_idle_overrides is rather confusing and unnecessary complex. if idle= boot param is passed, only set up one variable: boot_option_idle_overrides Introduces following functional changes/fixes: - intel_idle driver does not register if any idle=xy boot param is passed. - processor_idle.c will also not register a cpuidle driver and get active if idle=halt is passed. Before a cpuidle driver with one (C1, halt) state got registered Now the default_idle function will be used which finally uses the same idle call to enter sleep state (safe_halt()), but without registering a whole cpuidle driver. That means idle= param will always avoid cpuidle drivers to register with one exception (same behavior as before): idle=nomwait may still register acpi_idle cpuidle driver, but C1 will not use mwait, but hlt. This can be a workaround for IO based deeper sleep states where C1 mwait causes problems. Signed-off-by: Thomas Renninger <trenn@suse.de> cc: x86@kernel.org Signed-off-by: Len Brown <len.brown@intel.com>
2010-12-30x86: Replace uses of current_cpu_data with this_cpu opsTejun Heo
Replace all uses of current_cpu_data with this_cpu operations on the per cpu structure cpu_info. The scala accesses are replaced with the matching this_cpu ops which results in smaller and more efficient code. In the long run, it might be a good idea to remove cpu_data() macro too and use per_cpu macro directly. tj: updated description Cc: Yinghai Lu <yinghai@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: H. Peter Anvin <hpa@zytor.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-21Merge branch 'x86-idle-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-idle-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, hotplug: In the MWAIT case of play_dead, CLFLUSH the cache line x86, hotplug: Move WBINVD back outside the play_dead loop x86, hotplug: Use mwait to offline a processor, fix the legacy case x86, mwait: Move mwait constants to a common header file
2010-10-21Merge branch 'x86-fpu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, fpu: Merge fpu_save_init() x86-32, fpu: Rewrite fpu_save_init() x86, fpu: Remove PSHUFB_XMM5_* macros x86, fpu: Remove unnecessary ifdefs from i387 code. x86-32, fpu: Remove math_emulate stub x86-64, fpu: Simplify constraints for fxsave/fxtstor x86-64, fpu: Fix %cs value in convert_from_fxsr() x86-64, fpu: Disable preemption when using TS_USEDFPU x86, fpu: Merge __save_init_fpu() x86, fpu: Merge tolerant_fwait() x86, fpu: Merge fpu_init() x86: Use correct type for %cr4 x86, xsave: Disable xsave in i387 emulation mode Fixed up fxsaveq-induced conflict in arch/x86/include/asm/i387.h
2010-10-01x86, amd: Extract compute unit information for AMD CPUsAndreas Herrmann
Get compute unit information from CPUID Fn8000_001E_EBX. (See AMD CPUID Specification - publication # 25481, revision 2.34, September 2010.) Note that each core on a compute unit still has a core_id of its own. Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> LKML-Reference: <20100930123857.GE20545@loge.amd.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-09-17x86, hotplug: Use mwait to offline a processor, fix the legacy caseH. Peter Anvin
The code in native_play_dead() has a number of problems: 1. We should use MWAIT when available, to put ourselves into a deeper sleep state. 2. We use the existence of CLFLUSH to determine if WBINVD is safe, but that is totally bogus -- WBINVD is 486+, whereas CLFLUSH is a much later addition. 3. We should do WBINVD inside the loop, just in case of something like setting an A bit on page tables. Pointed out by Arjan van de Ven. This code is based in part of a previous patch by Venki Pallipadi, but unlike that patch this one keeps all the detection code local instead of pre-caching a bunch of information. We're shutting down the CPU; there is absolutely no hurry. This patch moves all the code to C and deletes the global wbinvd_halt() which is broken anyway. Originally-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Len Brown <lenb@kernel.org> Cc: Venkatesh Pallipadi <venki@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.hl> LKML-Reference: <20090522232230.162239000@intel.com>
2010-09-09x86: Use correct type for %cr4Brian Gerst
%cr4 is 64-bit in 64-bit mode (although the upper 32-bits are currently reserved). Use unsigned long for the temporary variable to get the right size. Signed-off-by: Brian Gerst <brgerst@gmail.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <1283563039-3466-2-git-send-email-brgerst@gmail.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-08-02x86: Fix keeping track of AMD C1EMichal Schmidt
Accomodate the original C1E-aware idle routine to the different times during boot when the BIOS enables C1E. While at it, remove the synthetic CPUID flag in favor of a single global setting which denotes C1E status on the system. [ hpa: changed c1e_enabled to be a bool; clarified cpu bit 3:21 comment ] Signed-off-by: Michal Schmidt <mschmidt@redhat.com> LKML-Reference: <20100727165335.GA11630@aftab> Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Acked-by: Thomas Gleixner <tglx@linutronix.de>
2010-07-28x86, cpu: Use AMD errata checking framework for erratum 383Hans Rosenfeld
Use the AMD errata checking framework instead of open-coding the test. Signed-off-by: Hans Rosenfeld <hans.rosenfeld@amd.com> LKML-Reference: <1280336972-865982-3-git-send-email-hans.rosenfeld@amd.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-07-28x86, cpu: Clean up AMD erratum 400 workaroundHans Rosenfeld
Remove check_c1e_idle() and use the new AMD errata checking framework instead. Signed-off-by: Hans Rosenfeld <hans.rosenfeld@amd.com> LKML-Reference: <1280336972-865982-2-git-send-email-hans.rosenfeld@amd.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-07-28x86, cpu: AMD errata checking frameworkHans Rosenfeld
Errata are defined using the AMD_LEGACY_ERRATUM() or AMD_OSVW_ERRATUM() macros. The latter is intended for newer errata that have an OSVW id assigned, which it takes as first argument. Both take a variable number of family-specific model-stepping ranges created by AMD_MODEL_RANGE(). Iff an erratum has an OSVW id, OSVW is available on the CPU, and the OSVW id is known to the hardware, it is used to determine whether an erratum is present. Otherwise, the model-stepping ranges are matched against the current CPU to find out whether the erratum applies. For certain special errata, the code using this framework might have to conduct further checks to make sure an erratum is really (not) present. Signed-off-by: Hans Rosenfeld <hans.rosenfeld@amd.com> LKML-Reference: <1280336972-865982-1-git-send-email-hans.rosenfeld@amd.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-05-20x86, kgdb: early trap init for early debugJan Kiszka
Allow the x86 arch to have early exception processing for the purpose of debugging via the kgdb. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-05-18Merge branch 'x86-fpu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, fpu: Use static_cpu_has() to implement use_xsave() x86: Add new static_cpu_has() function using alternatives x86, fpu: Use the proper asm constraint in use_xsave() x86, fpu: Unbreak FPU emulation x86: Introduce 'struct fpu' and related API x86: Eliminate TS_XSAVE x86-32: Don't set ignore_fpu_irq in simd exception x86: Merge kernel_math_error() into math_error() x86: Merge simd_math_error() into math_error() x86-32: Rework cache flush denied handler Fix trivial conflict in arch/x86/kernel/process.c
2010-05-18Merge branch 'x86-cpu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, hypervisor: add missing <linux/module.h> Modify the VMware balloon driver for the new x86_hyper API x86, hypervisor: Export the x86_hyper* symbols x86: Clean up the hypervisor layer x86, HyperV: fix up the license to mshyperv.c x86: Detect running on a Microsoft HyperV system x86, cpu: Make APERF/MPERF a normal table-driven flag x86, k8: Fix build error when K8_NB is disabled x86, cacheinfo: Disable index in all four subcaches x86, cacheinfo: Make L3 cache info per node x86, cacheinfo: Reorganize AMD L3 cache structure x86, cacheinfo: Turn off L3 cache index disable feature in virtualized environments x86, cacheinfo: Unify AMD L3 cache index disable checking cpufreq: Unify sysfs attribute definition macros powernow-k8: Fix frequency reporting x86, cpufreq: Add APERF/MPERF support for AMD processors x86: Unify APERF/MPERF support powernow-k8: Add core performance boost support x86, cpu: Add AMD core boosting feature flag to /proc/cpuinfo Fix up trivial conflicts in arch/x86/kernel/cpu/intel_cacheinfo.c and drivers/cpufreq/cpufreq_ondemand.c
2010-05-10x86: Introduce 'struct fpu' and related APIAvi Kivity
Currently all fpu state access is through tsk->thread.xstate. Since we wish to generalize fpu access to non-task contexts, wrap the state in a new 'struct fpu' and convert existing access to use an fpu API. Signal frame handlers are not converted to the API since they will remain task context only things. Signed-off-by: Avi Kivity <avi@redhat.com> Acked-by: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <1273135546-29690-3-git-send-email-avi@redhat.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-05-07x86: Clean up the hypervisor layerH. Peter Anvin
Clean up the hypervisor layer and the hypervisor drivers, using an ops structure instead of an enumeration with if statements. The identity of the hypervisor, if needed, can be tested by testing the pointer value in x86_hyper. The MS-HyperV private state is moved into a normal global variable (it's per-system state, not per-CPU state). Being a normal bss variable, it will be left at all zero on non-HyperV platforms, and so can generally be tested for HyperV-specific features without additional qualification. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Acked-by: Greg KH <greg@kroah.com> Cc: Hank Janssen <hjanssen@microsoft.com> Cc: Alok Kataria <akataria@vmware.com> Cc: Ky Srinivasan <ksrinivasan@novell.com> LKML-Reference: <4BE49778.6060800@zytor.com>
2010-05-06x86: Detect running on a Microsoft HyperV systemKy Srinivasan
This patch integrates HyperV detection within the framework currently used by VmWare. With this patch, we can avoid having to replicate the HyperV detection code in each of the Microsoft HyperV drivers. Reworked and tweaked by Greg K-H to build properly. Signed-off-by: K. Y. Srinivasan <ksrinivasan@novell.com> LKML-Reference: <20100506190841.GA1605@kroah.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Vadim Rozenfeld <vrozenfe@redhat.com> Cc: Avi Kivity <avi@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "K.Prasad" <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Alan Cox <alan@linux.intel.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Cc: Hank Janssen <hjanssen@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-03-26x86, ptrace: Fix block-stepPeter Zijlstra
Implement ptrace-block-step using TIF_BLOCKSTEP which will set DEBUGCTLMSR_BTF when set for a task while preserving any other DEBUGCTLMSR bits. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20100325135414.017536066@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-26x86, perf, bts, mm: Delete the never used BTS-ptrace codePeter Zijlstra
Support for the PMU's BTS features has been upstreamed in v2.6.32, but we still have the old and disabled ptrace-BTS, as Linus noticed it not so long ago. It's buggy: TIF_DEBUGCTLMSR is trampling all over that MSR without regard for other uses (perf) and doesn't provide the flexibility needed for perf either. Its users are ptrace-block-step and ptrace-bts, since ptrace-bts was never used and ptrace-block-step can be implemented using a much simpler approach. So axe all 3000 lines of it. That includes the *locked_memory*() APIs in mm/mlock.c as well. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Markus Metzger <markus.t.metzger@intel.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <20100325135413.938004390@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-19hw-breakpoint: Keep track of dr7 local enable bitsFrederic Weisbecker
When the user enables breakpoints through dr7, he can choose between "local" or "global" enable bits but given how linux is implemented, both have the same effect. That said we don't keep track how the user enabled the breakpoints so when the user requests the dr7 value, we only translate the "enabled" status using the global enabled bits. It means that if the user enabled a breakpoint using the local enabled bit, reading back dr7 will set the global bit and clear the local one. Apps like Wine expect a full dr7 POKEUSER/PEEKUSER match for emulated softwares that implement old reverse engineering protection schemes. We fix that by keeping track of the whole dr7 value given by the user in the thread structure to drop this bug. We'll think about something more proper later. This fixes a 2.6.32 - 2.6.33-x ptrace regression. Reported-and-tested-by: Michael Stefaniuc <mstefani@redhat.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Maneesh Soni <maneesh@linux.vnet.ibm.com> Cc: Alexandre Julliard <julliard@winehq.org> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: Maciej Rutecki <maciej.rutecki@gmail.com>
2009-12-16x86, cpuid: Add "volatile" to asm in native_cpuid()Suresh Siddha
xsave_cntxt_init() does something like: cpuid(0xd, ..); // find out what features FP/SSE/.. etc are supported xsetbv(); // enable the features known to OS cpuid(0xd, ..); // find out the size of the context for features enabled Depending on what features get enabled in xsetbv(), value of the cpuid.eax=0xd.ecx=0.ebx changes correspondingly (representing the size of the context that is enabled). As we don't have volatile keyword for native_cpuid(), gcc 4.1.2 optimizes away the second cpuid and the kernel continues to use the cpuid information obtained before xsetbv(), ultimately leading to kernel crash on processors supporting more state than the legacy FP/SSE. Add "volatile" for native_cpuid(). Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <1261009542.2745.55.camel@sbs-t61.sc.intel.com> Cc: stable@kernel.org Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-11-21Merge branch 'tracing/hw-breakpoints' into perf/coreIngo Molnar
Conflicts: arch/x86/kernel/kprobes.c kernel/trace/Makefile Merge reason: hw-breakpoints perf integration is looking good in testing and in reviews, plus conflicts are mounting up - so merge & resolve. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-08hw-breakpoints: Rewrite the hw-breakpoints layer on top of perf eventsFrederic Weisbecker
This patch rebase the implementation of the breakpoints API on top of perf events instances. Each breakpoints are now perf events that handle the register scheduling, thread/cpu attachment, etc.. The new layering is now made as follows: ptrace kgdb ftrace perf syscall \ | / / \ | / / / Core breakpoint API / / | / | / Breakpoints perf events | | Breakpoints PMU ---- Debug Register constraints handling (Part of core breakpoint API) | | Hardware debug registers Reasons of this rewrite: - Use the centralized/optimized pmu registers scheduling, implying an easier arch integration - More powerful register handling: perf attributes (pinned/flexible events, exclusive/non-exclusive, tunable period, etc...) Impact: - New perf ABI: the hardware breakpoints counters - Ptrace breakpoints setting remains tricky and still needs some per thread breakpoints references. Todo (in the order): - Support breakpoints perf counter events for perf tools (ie: implement perf_bpcounter_event()) - Support from perf tools Changes in v2: - Follow the perf "event " rename - The ptrace regression have been fixed (ptrace breakpoint perf events weren't released when a task ended) - Drop the struct hw_breakpoint and store generic fields in perf_event_attr. - Separate core and arch specific headers, drop asm-generic/hw_breakpoint.h and create linux/hw_breakpoint.h - Use new generic len/type for breakpoint - Handle off case: when breakpoints api is not supported by an arch Changes in v3: - Fix broken CONFIG_KVM, we need to propagate the breakpoint api changes to kvm when we exit the guest and restore the bp registers to the host. Changes in v4: - Drop the hw_breakpoint_restore() stub as it is only used by KVM - EXPORT_SYMBOL_GPL hw_breakpoint_restore() as KVM can be built as a module - Restore the breakpoints unconditionally on kvm guest exit: TIF_DEBUG_THREAD doesn't anymore cover every cases of running breakpoints and vcpu->arch.switch_db_regs might not always be set when the guest used debug registers. (Waiting for a reliable optimization) Changes in v5: - Split-up the asm-generic/hw-breakpoint.h moving to linux/hw_breakpoint.h into a separate patch - Optimize the breakpoints restoring while switching from kvm guest to host. We only want to restore the state if we have active breakpoints to the host, otherwise we don't care about messed-up address registers. - Add asm/hw_breakpoint.h to Kbuild - Fix bad breakpoint type in trace_selftest.c Changes in v6: - Fix wrong header inclusion in trace.h (triggered a build error with CONFIG_FTRACE_SELFTEST Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Prasad <prasad@linux.vnet.ibm.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jan Kiszka <jan.kiszka@web.de> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Avi Kivity <avi@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org>
2009-11-04x86, fs: Fix x86 procfs stack information for threads on 64-bitStefani Seibold
This patch fixes two issues in the procfs stack information on x86-64 linux. The 32 bit loader compat_do_execve did not store stack start. (this was figured out by Alexey Dobriyan). The stack information on a x64_64 kernel always shows 0 kbyte stack usage, because of a missing implementation of the KSTK_ESP macro which always returned -1. The new implementation now returns the right value. Signed-off-by: Stefani Seibold <stefani@seibold.net> Cc: Americo Wang <xiyou.wangcong@gmail.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <1257240160.4889.24.camel@wall-e> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-18Merge commit 'perf/core' into perf/hw-breakpointFrederic Weisbecker
Conflicts: kernel/Makefile kernel/trace/Makefile kernel/trace/trace.h samples/Makefile Merge reason: We need to be uptodate with the perf events development branch because we plan to rewrite the breakpoints API on top of perf events.
