[ Upstream commit 9b8bd476e78e89c9ea26c3b435ad0201c3d7dbf5 ]
Identical to __put_user(); the __get_user() argument evalution will too
leak UBSAN crud into the __uaccess_begin() / __uaccess_end() region.
While uncommon this was observed to happen for:
drivers/xen/gntdev.c: if (__get_user(old_status, batch->status[i]))
where UBSAN added array bound checking.
This complements commit:
6ae865615fc4 ("x86/uaccess: Dont leak the AC flag into __put_user() argument evaluation")
Tested-by Sedat Dilek <sedat.dilek@gmail.com>
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: broonie@kernel.org
Cc: sfr@canb.auug.org.au
Cc: akpm@linux-foundation.org
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: mhocko@suse.cz
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Link: https://lkml.kernel.org/r/20190829082445.GM2369@hirez.programming.kicks-ass.net
commit 2a418cf3f5f1caf911af288e978d61c9844b0695 upstream.
When calling __put_user(foo(), ptr), the __put_user() macro would call
foo() in between __uaccess_begin() and __uaccess_end(). If that code
were buggy, then those bugs would be run without SMAP protection.
Fortunately, there seem to be few instances of the problem in the
kernel. Nevertheless, __put_user() should be fixed to avoid doing this.
Therefore, evaluate __put_user()'s argument before setting AC.
This issue was noticed when an objtool hack by Peter Zijlstra complained
about genregs_get() and I compared the assembly output to the C source.
[ bp: Massage commit message and fixed up whitespace. ]
Fixes: 11f1a4b9755f ("x86: reorganize SMAP handling in user space accesses")
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: stable@vger.kernel.org
Link: http://lkml.kernel.org/r/20190225125231.845656645@infradead.org
commit 304ec1b050310548db33063e567123fae8fd0301
Quoting Linus:
I do think that it would be a good idea to very expressly document
the fact that it's not that the user access itself is unsafe. I do
agree that things like "get_user()" want to be protected, but not
because of any direct bugs or problems with get_user() and friends,
but simply because get_user() is an excellent source of a pointer
that is obviously controlled from a potentially attacking user
space. So it's a prime candidate for then finding _subsequent_
accesses that can then be used to perturb the cache.
__uaccess_begin_nospec() covers __get_user() and copy_from_iter() where the
limit check is far away from the user pointer de-reference. In those cases
a barrier_nospec() prevents speculation with a potential pointer to
privileged memory. uaccess_try_nospec covers get_user_try.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Suggested-by: Andi Kleen <ak@linux.intel.com>
Cc: kernel-hardening@lists.openwall.com
Cc: gregkh@linuxfoundation.org
Cc: alan@linux.intel.com
Link: https://lkml.kernel.org/r/151727416953.33451.10508284228526170604.stgit@dwillia2-desk3.amr.corp.intel.com
commit b3bbfb3fb5d25776b8e3f361d2eedaabb0b496cd
For __get_user() paths, do not allow the kernel to speculate on the value
of a user controlled pointer. In addition to the 'stac' instruction for
Supervisor Mode Access Protection (SMAP), a barrier_nospec() causes the
access_ok() result to resolve in the pipeline before the CPU might take any
speculative action on the pointer value. Given the cost of 'stac' the
speculation barrier is placed after 'stac' to hopefully overlap the cost of
disabling SMAP with the cost of flushing the instruction pipeline.
Since __get_user is a major kernel interface that deals with user
controlled pointers, the __uaccess_begin_nospec() mechanism will prevent
speculative execution past an access_ok() permission check. While
speculative execution past access_ok() is not enough to lead to a kernel
memory leak, it is a necessary precondition.
To be clear, __uaccess_begin_nospec() is addressing a class of potential
problems near __get_user() usages.
Note, that while the barrier_nospec() in __uaccess_begin_nospec() is used
to protect __get_user(), pointer masking similar to array_index_nospec()
will be used for get_user() since it incorporates a bounds check near the
usage.
uaccess_try_nospec provides the same mechanism for get_user_try.
No functional changes.
Suggested-by: Ingo Molnar <mingo@redhat.com>
Cc: Tom Lendacky <thomas.lendacky@amd.com>
Link: https://lkml.kernel.org/r/151727415922.33451.5796614273104346583.stgit@dwillia2-desk3.amr.corp.intel.com
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Don't cast away the __user in __get_user_asm_u64() on x86-32.
Prevents sparse getting upset.
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
Link: http://lkml.kernel.org/r/20170912164000.13745-1-ville.syrjala@linux.intel.com
For inline asm statements which have a CALL instruction, we list the
stack pointer as a constraint to convince GCC to ensure the frame
pointer is set up first:
static inline void foo()
register void *__sp asm(_ASM_SP);
asm("call bar" : "+r" (__sp))
Unfortunately, that pattern causes Clang to corrupt the stack pointer.
The fix is easy: convert the stack pointer register variable to a global
variable.
It should be noted that the end result is different based on the GCC
version. With GCC 6.4, this patch has exactly the same result as
before:
defconfig defconfig-nofp distro distro-nofp
before 9820389 9491555 8816046 8516940
after 9820389 9491555 8816046 8516940
With GCC 7.2, however, GCC's behavior has changed. It now changes its
behavior based on the conversion of the register variable to a global.
That somehow convinces it to *always* set up the frame pointer before
inserting *any* inline asm. (Therefore, listing the variable as an
output constraint is a no-op and is no longer necessary.) It's a bit
overkill, but the performance impact should be negligible. And in fact,
there's a nice improvement with frame pointers disabled:
before 9796316 9468236 9076191 8790305
after 9796957 9464267 9076381 8785949
So in summary, while listing the stack pointer as an output constraint
is no longer necessary for newer versions of GCC, it's still needed for
older versions.
Suggested-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Reported-by: Matthias Kaehlcke <mka@chromium.org>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Dmitriy Vyukov <dvyukov@google.com>
Cc: Miguel Bernal Marin <miguel.bernal.marin@linux.intel.com>
Link: http://lkml.kernel.org/r/3db862e970c432ae823cf515c52b54fec8270e0e.1505942196.git.jpoimboe@redhat.com
Pull syscall updates from Ingo Molnar:
"Improve the security of set_fs(): we now check the address limit on a
number of key platforms (x86, arm, arm64) before returning to
user-space - without adding overhead to the typical system call fast
path"
* 'x86-syscall-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
arm64/syscalls: Check address limit on user-mode return
arm/syscalls: Check address limit on user-mode return
x86/syscalls: Check address limit on user-mode return
Pull uacess-unaligned removal from Al Viro:
"That stuff had just one user, and an exotic one, at that - binfmt_flat
on arm and m68k"
* 'work.uaccess-unaligned' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
kill {__,}{get,put}_user_unaligned()
binfmt_flat: flat_{get,put}_addr_from_rp() should be able to fail
Ensure the address limit is a user-mode segment before returning to
user-mode. Otherwise a process can corrupt kernel-mode memory and elevate
privileges [1].
The set_fs function sets the TIF_SETFS flag to force a slow path on
return. In the slow path, the address limit is checked to be USER_DS if
needed.
The addr_limit_user_check function is added as a cross-architecture
function to check the address limit.
[1] https://bugs.chromium.org/p/project-zero/issues/detail?id=990
Signed-off-by: Thomas Garnier <thgarnie@google.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Miroslav Benes <mbenes@suse.cz>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Cc: Pratyush Anand <panand@redhat.com>
Cc: Russell King <linux@armlinux.org.uk>
Cc: Petr Mladek <pmladek@suse.com>
Cc: Will Drewry <wad@chromium.org>
Cc: linux-api@vger.kernel.org
Link: http://lkml.kernel.org/r/20170615011203.144108-1-thgarnie@google.com
Pull user access str* updates from Al Viro:
"uaccess str...() dead code removal"
* 'uaccess.strlen' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
s390 keyboard.c: don't open-code strndup_user()
mips: get rid of unused __strnlen_user()
get rid of unused __strncpy_from_user() instances
kill strlen_user()
no users left
The code to fetch a 64-bit value from user space was entirely buggered,
and has been since the code was merged in early 2016 in commit
b2f680380ddf ("x86/mm/32: Add support for 64-bit __get_user() on 32-bit
kernels").
Happily the buggered routine is almost certainly entirely unused, since
the normal way to access user space memory is just with the non-inlined
"get_user()", and the inlined version didn't even historically exist.
The normal "get_user()" case is handled by external hand-written asm in
arch/x86/lib/getuser.S that doesn't have either of these issues.
There were two independent bugs in __get_user_asm_u64():
- it still did the STAC/CLAC user space access marking, even though
that is now done by the wrapper macros, see commit 11f1a4b9755f
("x86: reorganize SMAP handling in user space accesses").
This didn't result in a semantic error, it just means that the
inlined optimized version was hugely less efficient than the
allegedly slower standard version, since the CLAC/STAC overhead is
quite high on modern Intel CPU's.
- the double register %eax/%edx was marked as an output, but the %eax
part of it was touched early in the asm, and could thus clobber other
inputs to the asm that gcc didn't expect it to touch.
In particular, that meant that the generated code could look like
this:
mov (%eax),%eax
mov 0x4(%eax),%edx
where the load of %edx obviously was _supposed_ to be from the 32-bit
word that followed the source of %eax, but because %eax was
overwritten by the first instruction, the source of %edx was
basically random garbage.
The fixes are trivial: remove the extraneous STAC/CLAC entries, and mark
the 64-bit output as early-clobber to let gcc know that no inputs should
alias with the output register.
Cc: stable@kernel.org # v4.8+
Al noticed that unsafe_put_user() had type problems, and fixed them in
commit a7cc722fff0b ("fix unsafe_put_user()"), which made me look more
at those functions.
It turns out that unsafe_get_user() had a type issue too: it limited the
largest size of the type it could handle to "unsigned long". Which is
fine with the current users, but doesn't match our existing normal
get_user() semantics, which can also handle "u64" even when that does
not fit in a long.
While at it, also clean up the type cast in unsafe_put_user(). We
actually want to just make it an assignment to the expected type of the
pointer, because we actually do want warnings from types that don't
convert silently. And it makes the code more readable by not having
that one very long and complex line.
[ This patch might become stable material if we ever end up back-porting
any new users of the unsafe uaccess code, but as things stand now this
doesn't matter for any current existing uses. ]
__put_user_size() relies upon its first argument having the same type as what
the second one points to; the only other user makes sure of that and
unsafe_put_user() should do the same.
no callers, no consistent semantics, no sane way to use it...
I recently encountered wreckage because access_ok() was used where it
should not be, add an explicit WARN when access_ok() is used wrongly.
drivers/platform/x86/dell-smo8800.c is touched due to the following obscenity:
drivers/platform/x86/dell-smo8800.c ->
linux/interrupt.h ->
linux/hardirq.h ->
asm/hardirq.h ->
linux/irq.h ->
asm/hw_irq.h ->
asm/sections.h ->
asm/uaccess.h
is the only chain of includes pulling asm/uaccess.h there.
get_user_ex(x, ptr) should zero x on failure. It's not a lot of a leak
(at most we are leaking uninitialized 64bit value off the kernel stack,
and in a fairly constrained situation, at that), but the fix is trivial,
so...
[ This sat in different branch from the uaccess fixes since mid-August ]
As already done with __copy_*_user(), mark copy_*_user() as __always_inline.
Without this, the checks for things like __builtin_const_p() won't work
consistently in either hardened usercopy nor the recent adjustments for
detecting usercopy overflows at compile time.
The change in kernel text size is detectable, but very small:
12118735 5768608 14229504 32116847 1ea106f vmlinux.before
12120207 5768608 14229504 32118319 1ea162f vmlinux.after
There are three usercopy warnings which are currently being silenced for
gcc 4.6 and newer:
1) "copy_from_user() buffer size is too small" compile warning/error
This is a static warning which happens when object size and copy size
are both const, and copy size > object size. I didn't see any false
positives for this one. So the function warning attribute seems to
be working fine here.
Note this scenario is always a bug and so I think it should be
changed to *always* be an error, regardless of
CONFIG_DEBUG_STRICT_USER_COPY_CHECKS.
2) "copy_from_user() buffer size is not provably correct" compile warning
This is another static warning which happens when I enable
__compiletime_object_size() for new compilers (and
CONFIG_DEBUG_STRICT_USER_COPY_CHECKS). It happens when object size
is const, but copy size is *not*. In this case there's no way to
compare the two at build time, so it gives the warning. (Note the
warning is a byproduct of the fact that gcc has no way of knowing
whether the overflow function will be called, so the call isn't dead
code and the warning attribute is activated.)
So this warning seems to only indicate "this is an unusual pattern,
maybe you should check it out" rather than "this is a bug".
I get 102(!) of these warnings with allyesconfig and the
__compiletime_object_size() gcc check removed. I don't know if there
are any real bugs hiding in there, but from looking at a small
sample, I didn't see any. According to Kees, it does sometimes find
real bugs. But the false positive rate seems high.
3) "Buffer overflow detected" runtime warning
This is a runtime warning where object size is const, and copy size >
object size.
All three warnings (both static and runtime) were completely disabled
for gcc 4.6 with the following commit:
2fb0815c9ee6 ("gcc4: disable __compiletime_object_size for GCC 4.6+")
That commit mistakenly assumed that the false positives were caused by a
gcc bug in __compiletime_object_size(). But in fact,
__compiletime_object_size() seems to be working fine. The false
positives were instead triggered by #2 above. (Though I don't have an
explanation for why the warnings supposedly only started showing up in
gcc 4.6.)
So remove warning #2 to get rid of all the false positives, and re-enable
warnings #1 and #3 by reverting the above commit.
Furthermore, since #1 is a real bug which is detected at compile time,
upgrade it to always be an error.
Having done all that, CONFIG_DEBUG_STRICT_USER_COPY_CHECKS is no longer
needed.
Cc: "H . Peter Anvin" <hpa@zytor.com>
Cc: Byungchul Park <byungchul.park@lge.com>
Cc: Nilay Vaish <nilayvaish@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull usercopy protection from Kees Cook:
"Tbhis implements HARDENED_USERCOPY verification of copy_to_user and
copy_from_user bounds checking for most architectures on SLAB and
SLUB"
* tag 'usercopy-v4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
mm: SLUB hardened usercopy support
mm: SLAB hardened usercopy support
s390/uaccess: Enable hardened usercopy
sparc/uaccess: Enable hardened usercopy
powerpc/uaccess: Enable hardened usercopy
ia64/uaccess: Enable hardened usercopy
arm64/uaccess: Enable hardened usercopy
ARM: uaccess: Enable hardened usercopy
x86/uaccess: Enable hardened usercopy
mm: Hardened usercopy
mm: Implement stack frame object validation
mm: Add is_migrate_cma_page
When I initially added the unsafe_[get|put]_user() helpers in commit
5b24a7a2aa20 ("Add 'unsafe' user access functions for batched
accesses"), I made the mistake of modeling the interface on our
traditional __[get|put]_user() functions, which return zero on success,
or -EFAULT on failure.
That interface is fairly easy to use, but it's actually fairly nasty for
good code generation, since it essentially forces the caller to check
the error value for each access.
In particular, since the error handling is already internally
implemented with an exception handler, and we already use "asm goto" for
various other things, we could fairly easily make the error cases just
jump directly to an error label instead, and avoid the need for explicit
checking after each operation.
So switch the interface to pass in an error label, rather than checking
the error value in the caller. Best do it now before we start growing
more users (the signal handling code in particular would be a good place
to use the new interface).
So rather than
if (unsafe_get_user(x, ptr))
... handle error ..
the interface is now
unsafe_get_user(x, ptr, label);
where an error during the user mode fetch will now just cause a jump to
'label' in the caller.
Right now the actual _implementation_ of this all still ends up being a
"if (err) goto label", and does not take advantage of any exception
label tricks, but for "unsafe_put_user()" in particular it should be
fairly straightforward to convert to using the exception table model.
Note that "unsafe_get_user()" is much harder to convert to a clever
exception table model, because current versions of gcc do not allow the
use of "asm goto" (for the exception) with output values (for the actual
value to be fetched). But that is hopefully not a limitation in the
long term.
[ Also note that it might be a good idea to switch unsafe_get_user() to
actually _return_ the value it fetches from user space, but this
commit only changes the error handling semantics ]
Enables CONFIG_HARDENED_USERCOPY checks on x86. This is done both in
copy_*_user() and __copy_*_user() because copy_*_user() actually calls
down to _copy_*_user() and not __copy_*_user().
Based on code from PaX and grsecurity.
Tested-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
struct thread_info is a legacy mess. To prepare for its partial removal,
move thread_info::addr_limit out.
As an added benefit, this way is simpler.
Link: http://lkml.kernel.org/r/15bee834d09402b47ac86f2feccdf6529f9bc5b0.1468527351.git.luto@kernel.org
thread_info::sig_on_uaccess_err to thread_struct
move the uaccess control fields out -- they're straightforward.
Link: http://lkml.kernel.org/r/d0ac4d01c8e4d4d756264604e47445d5acc7900e.1468527351.git.luto@kernel.org
Exchange between user and kernel memory is coded in assembly language.
Which means that such accesses won't be spotted by KASAN as a compiler
instruments only C code.
Add explicit KASAN checks to user memory access API to ensure that
userspace writes to (or reads from) a valid kernel memory.
Note: Unlike others strncpy_from_user() is written mostly in C and KASAN
sees memory accesses in it. However, it makes sense to add explicit
check for all @count bytes that *potentially* could be written to the
kernel.
[aryabinin@virtuozzo.com: move kasan check under the condition]
Link: http://lkml.kernel.org/r/1462869209-21096-1-git-send-email-aryabinin@virtuozzo.com
Link: http://lkml.kernel.org/r/1462538722-1574-4-git-send-email-aryabinin@virtuozzo.com
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Pull x86 asm updates from Ingo Molnar:
"The main changes in this cycle were:
- MSR access API fixes and enhancements (Andy Lutomirski)
- early exception handling improvements (Andy Lutomirski)
- user-space FS/GS prctl usage fixes and improvements (Andy
Lutomirski)
- Remove the cpu_has_*() APIs and replace them with equivalents
(Borislav Petkov)
- task switch micro-optimization (Brian Gerst)
- 32-bit entry code simplification (Denys Vlasenko)
- enhance PAT handling in enumated CPUs (Toshi Kani)
... and lots of other cleanups/fixlets"
* 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (70 commits)
x86/arch_prctl/64: Restore accidentally removed put_cpu() in ARCH_SET_GS
x86/entry/32: Remove asmlinkage_protect()
x86/entry/32: Remove GET_THREAD_INFO() from entry code
x86/entry, sched/x86: Don't save/restore EFLAGS on task switch
x86/asm/entry/32: Simplify pushes of zeroed pt_regs->REGs
selftests/x86/ldt_gdt: Test set_thread_area() deletion of an active segment
x86/tls: Synchronize segment registers in set_thread_area()
x86/asm/64: Rename thread_struct's fs and gs to fsbase and gsbase
x86/arch_prctl/64: Remove FSBASE/GSBASE < 4G optimization
x86/segments/64: When load_gs_index fails, clear the base
x86/segments/64: When loadsegment(fs, ...) fails, clear the base
x86/asm: Make asm/alternative.h safe from assembly
x86/asm: Stop depending on ptrace.h in alternative.h
x86/entry: Rename is_{ia32,x32}_task() to in_{ia32,x32}_syscall()
x86/asm: Make sure verify_cpu() has a good stack
x86/extable: Add a comment about early exception handlers
x86/msr: Set the return value to zero when native_rdmsr_safe() fails
x86/paravirt: Make "unsafe" MSR accesses unsafe even if PARAVIRT=y
x86/paravirt: Add paravirt_{read,write}_msr()
x86/msr: Carry on after a non-"safe" MSR access fails
The x86 exception table sorting was changed in commit 29934b0fb8ff
("x86/extable: use generic search and sort routines") to use the arch
independent code in lib/extable.c. However, the patch was mangled
somehow on its way into the kernel from the last version posted at [1].
The committed version kind of attempted to incorporate the changes of
commit 548acf19234d ("x86/mm: Expand the exception table logic to allow
new handling options") as in _completely_ _ignoring_ the x86 specific
'handler' member of struct exception_table_entry. This effectively
broke the sorting as entries will only partly be swapped now.
Fortunately, the x86 Kconfig selects BUILDTIME_EXTABLE_SORT, so the
exception table doesn't need to be sorted at runtime. However, in case
that ever changes, we better not break the exception table sorting just
because of that.
[ Ard Biesheuvel points out that BUILDTIME_EXTABLE_SORT applies to the
core image only, but we still rely on the sorting routines for modules
in that case - Linus ]
Fix this by providing a swap_ex_entry_fixup() macro that takes care of
the 'handler' member.
[1] https://lkml.org/lkml/2016/1/27/232
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Fixes: 29934b0fb8f ("x86/extable: use generic search and sort routines")
Reviewed-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Borislav Petkov <bp@suse.de>
Cc: H. Peter Anvin <hpa@linux.intel.com>
The x86 exception table sorting was changed in this recent commit:
29934b0fb8ff ("x86/extable: use generic search and sort routines")
... to use the arch independent code in lib/extable.c. However, the
patch was mangled somehow on its way into the kernel from the last
version posted at:
contemporary commit done in the x86 tree:
548acf19234d ("x86/mm: Expand the exception table logic to allow new handling options")
... as in _completely_ _ignoring_ the x86 specific 'handler' member of
struct exception_table_entry. This effectively broke the sorting as
entries will only be partly swapped now.
because of that.
Link: http://lkml.kernel.org/r/1462914422-2911-1-git-send-email-minipli@googlemail.com
The existing __get_user() implementation does not support fetching
64-bit values on 32-bit x86. Implement this in a way that does not
generate any incorrect warnings as cautioned by Russell King.
Test code available at:
http://www.kvack.org/~bcrl/x86_32-get_user.tar .
Signed-off-by: Benjamin LaHaise <bcrl@kvack.org>
This removes a bunch of assembly and adds some C code instead. It
changes the actual printouts on both 32-bit and 64-bit kernels, but
they still seem okay.
Tested-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: KVM list <kvm@vger.kernel.org>
Cc: xen-devel <Xen-devel@lists.xen.org>
Link: http://lkml.kernel.org/r/4085070316fc3ab29538d3fcfe282648d1d4ee2e.1459605520.git.luto@kernel.org
early_fixup_exception() is limited by the fact that it doesn't have a
real struct pt_regs. Change both the 32-bit and 64-bit asm and the
C code to pass and accept a real pt_regs.
Link: http://lkml.kernel.org/r/e3fb680fcfd5e23e38237e8328b64a25cc121d37.1459605520.git.luto@kernel.org
Replace the arch specific versions of search_extable() and
sort_extable() with calls to the generic ones, which now support
relative exception tables as well.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Acked-by: H. Peter Anvin <hpa@linux.intel.com>
table format
Numerous 'call without frame pointer save/setup' warnings are introduced
by stacktool because of functions using the get_user() macro. Bad stack
traces could occur due to lack of or misplacement of stack frame setup
code.
This patch forces a stack frame to be created before the inline asm code
if CONFIG_FRAME_POINTER is enabled by listing the stack pointer as an
output operand for the get_user() inline assembly statement.
Signed-off-by: Chris J Arges <chris.j.arges@canonical.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Bernd Petrovitsch <bernd@petrovitsch.priv.at>
Cc: Jiri Slaby <jslaby@suse.cz>
Cc: Michal Marek <mmarek@suse.cz>
Cc: Namhyung Kim <namhyung@gmail.com>
Cc: Pedro Alves <palves@redhat.com>
Cc: live-patching@vger.kernel.org
Link: http://lkml.kernel.org/r/bc85501f221ee512670797c7f110022e64b12c81.1453405861.git.jpoimboe@redhat.com
Huge amounts of help from Andy Lutomirski and Borislav Petkov to
produce this. Andy provided the inspiration to add classes to the
exception table with a clever bit-squeezing trick, Boris pointed
out how much cleaner it would all be if we just had a new field.
Linus Torvalds blessed the expansion with:
' I'd rather not be clever in order to save just a tiny amount of space
in the exception table, which isn't really criticial for anybody. '
The third field is another relative function pointer, this one to a
handler that executes the actions.
We start out with three handlers:
1: Legacy - just jumps the to fixup IP
2: Fault - provide the trap number in %ax to the fixup code
3: Cleaned up legacy for the uaccess error hack
Signed-off-by: Tony Luck <tony.luck@intel.com>
Link: http://lkml.kernel.org/r/f6af78fcbd348cf4939875cfda9c19689b5e50b8.1455732970.git.tony.luck@intel.com
Expose an interface to allow users to mark several accesses together as
being user space accesses, allowing batching of the surrounding user
space access markers (SMAP on x86, PAN on arm64, domain register
switching on arm).
This is currently only used for the user string lenth and copying
functions, where the SMAP overhead on x86 drowned the actual user
accesses (only noticeable on newer microarchitectures that support SMAP
in the first place, of course).
* user access batching branch:
Use the new batched user accesses in generic user string handling
Add 'unsafe' user access functions for batched accesses
The naming is meant to discourage random use: the helper functions are
not really any more "unsafe" than the traditional double-underscore
functions (which need the address range checking), but they do need even
more infrastructure around them, and should not be used willy-nilly.
In addition to checking the access range, these user access functions
require that you wrap the user access with a "user_acess_{begin,end}()"
around it.
That allows architectures that implement kernel user access control
(x86: SMAP, arm64: PAN) to do the user access control in the wrapping
user_access_begin/end part, and then batch up the actual user space
accesses using the new interfaces.
The main (and hopefully only) use for these are for core generic access
helpers, initially just the generic user string functions
(strnlen_user() and strncpy_from_user()).
This reorganizes how we do the stac/clac instructions in the user access
code. Instead of adding the instructions directly to the same inline
asm that does the actual user level access and exception handling, add
them at a higher level.
This is mainly preparation for the next step, where we will expose an
interface to allow users to mark several accesses together as being user
space accesses, but it does already clean up some code:
- the inlined trivial cases of copy_in_user() now do stac/clac just
once over the accesses: they used to do one pair around the user
space read, and another pair around the write-back.
- the {get,put}_user_ex() macros that are used with the catch/try
handling don't do any stac/clac at all, because that happens in the
try/catch surrounding them.
Other than those two cleanups that happened naturally from the
re-organization, this should not make any difference. Yet.
Add a inlined __ variant of copy_from_user_nmi. The inlined variant allows
the user to:
- batch the access_ok() check for multiple accesses
- avoid having a pagefault_disable/enable() on every access if the
caller already ensures disabled page faults due to its context.
- get all the optimizations in copy_*_user() for small constant sized
transfers
It is just a define to __copy_from_user_inatomic().
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/1445551641-13379-1-git-send-email-andi@firstfloor.org
This should improve code quality a bit. It also shrinks the kernel text:
Before:
text data bss dec filename
21828379 5194760 1277952 28301091 vmlinux
After:
21827997 5194760 1277952 28300709 vmlinux
... by 382 bytes.
Link: http://lkml.kernel.org/r/f427b8002d932e5deab9055e0074bb4e7e80ee39.1444091584.git.luto@kernel.org
GCC doesn't realize that get_user(), put_user(), and their __
variants are unlikely to fail. Tell it.
I noticed this while playing with the C entry code.
Before:
21828763 5194760 1277952 28301475 vmlinux.baseline
After:
21828379 5194760 1277952 28301091 vmlinux.new
The generated code shrunk by 384 bytes.
Link: http://lkml.kernel.org/r/dc37bed7024319c3004d950d57151fca6aeacf97.1444091584.git.luto@kernel.org
enabled
In general, non-atomic variants of user access functions must not sleep
if pagefaults are disabled.
Let's update all relevant comments in uaccess code. This also reflects
the might_sleep() checks in might_fault().
Reviewed-and-tested-by: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
Cc: David.Laight@ACULAB.COM
Cc: airlied@linux.ie
Cc: benh@kernel.crashing.org
Cc: bigeasy@linutronix.de
Cc: borntraeger@de.ibm.com
Cc: daniel.vetter@intel.com
Cc: heiko.carstens@de.ibm.com
Cc: herbert@gondor.apana.org.au
Cc: hocko@suse.cz
Cc: hughd@google.com
Cc: mst@redhat.com
Cc: paulus@samba.org
Cc: ralf@linux-mips.org
Cc: schwidefsky@de.ibm.com
Cc: yang.shi@windriver.com
Link: http://lkml.kernel.org/r/1431359540-32227-4-git-send-email-dahi@linux.vnet.ibm.com
virtio wants to read bitwise types from userspace using get_user. At the
moment this triggers sparse errors, since the value is passed through an
integer.
Fix that up using __force.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
