path: root/arch/x86/include/asm/uv/bios.h
2010-02-28Merge branch 'x86-uv-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-uv-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, uv: Remove recursion in uv_heartbeat_enable() x86, uv: uv_global_gru_mmr_address() macro fix x86, uv: Add serial number parameter to uv_bios_get_sn_info()
2010-02-05x86, uv: Update UV arch to target Legacy VGA I/O correctly.Mike Travis
Add function to direct Legacy VGA I/O traffic to correct I/O Hub. Signed-off-by: Mike Travis <travis@sgi.com> LKML-Reference: <201002022238.o12McEbi018727@imap1.linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Robin Holt <holt@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: David Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-12-17x86, uv: Add serial number parameter to uv_bios_get_sn_info()Russ Anderson
Add system_serial_number to the information returned by uv_bios_get_sn_info() UV BIOS call. Signed-off-by: Russ Anderson <rja@sgi.com> LKML-Reference: <20091217165323.GA30774@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-12-16x86: uv: update XPC to handle updated BIOS interfaceRobin Holt
The UV BIOS has moved the location of some of their pointers to the "partition reserved page" from memory into a uv hub MMR. The GRU does not support bcopy operations from MMR space so we need to special case the MMR addresses using VLOAD operations. Additionally, the BIOS call for registering a message queue watchlist has removed the 'blade' value and eliminated the structure that was being passed in. This is also reflected in this patch. Signed-off-by: Robin Holt <holt@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-16sgi-xp: xpc needs to pass the physical address, not virtualRuss Anderson
Impact: fix crash xpc needs to pass the physical address, not virtual. Testing uncovered this problem. The virtual address happens to work most of the time due to the way bios was masking off the node bits. Passing the physical address makes it work all of the time. Signed-off-by: Russ Anderson <rja@sgi.com> Acked-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-05x86: uv: Add UV reserved page bios callRuss Anderson
Add UV bios call to get the address of the reserved page. Signed-off-by: Russ Anderson <rja@sgi.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-11-05x86: uv: Add UV memory protection bios callRuss Anderson
Add UV bios call to change memory protections. Signed-off-by: Russ Anderson <rja@sgi.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-11-05x86: uv: Add UV watchlist bios callRuss Anderson
Add UV bios calls to allocate and free watchlists. Signed-off-by: Russ Anderson <rja@sgi.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-10-27Merge commit 'v2.6.28-rc2' into x86/uvIngo Molnar
2008-10-23x86: drop double underscores from header guardsH. Peter Anvin
Drop double underscores from header guards in arch/x86/include. They are used inconsistently, and are not necessary. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-10-22x86: Fix ASM_X86__ header guardsH. Peter Anvin
Change header guards named "ASM_X86__*" to "_ASM_X86_*" since: a. the double underscore is ugly and pointless. b. no leading underscore violates namespace constraints. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-10-22x86, um: ... and asm-x86 moveAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
