Pull x86/apic updates from Thomas Gleixner:
"This is a major overhaul to the x86 apic subsystem consisting of the
following parts:
- Remove obsolete APIC driver abstractions (David Rientjes)
- Use the irqdomain facilities to dynamically allocate IRQs for
IOAPICs. This is a prerequisite to enable IOAPIC hotplug support,
and it also frees up wasted vectors (Jiang Liu)
- Misc fixlets.
Despite the hickup in Ingos previous pull request - caused by the
missing fixup for the suspend/resume issue reported by Borislav - I
strongly recommend that this update finds its way into 3.17. Some
history for you:
This is preparatory work for physical IOAPIC hotplug. The first
attempt to support this was done by Yinghai and I shot it down because
it just added another layer of obscurity and complexity to the already
existing mess without tackling the underlying shortcomings of the
current implementation.
After quite some on- and offlist discussions, I requested that the
design of this functionality must use generic infrastructure, i.e.
irq domains, which provide all the mechanisms to dynamically map linux
interrupt numbers to physical interrupts.
Jiang picked up the idea and did a great job of consolidating the
existing interfaces to manage the x86 (IOAPIC) interrupt system by
utilizing irq domains.
The testing in tip, Linux-next and inside of Intel on various machines
did not unearth any oddities until Borislav exposed it to one of his
oddball machines. The issue was resolved quickly, but unfortunately
the fix fell through the cracks and did not hit the tip tree before
Ingo sent the pull request. Not entirely Ingos fault, I also assumed
that the fix was already merged when Ingo asked me whether he could
send it.
Nevertheless this work has a proper design, has undergone several
rounds of review and the final fallout after applying it to tip and
integrating it into Linux-next has been more than moderate. It's the
ground work not only for IOAPIC hotplug, it will also allow us to move
the lowlevel vector allocation into the irqdomain hierarchy, which
will benefit other architectures as well. Patches are posted already,
but they are on hold for two weeks, see below.
I really appreciate the competence and responsiveness Jiang has shown
in course of this endavour. So I'm sure that any fallout of this will
be addressed in a timely manner.
FYI, I'm vanishing for 2 weeks into my annual kids summer camp kitchen
duty^Wvacation, while you folks are drooling at KS/LinuxCon :) But HPA
will have a look at the hopefully zero fallout until I'm back"
* 'x86-apic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (53 commits)
x86, irq, PCI: Keep IRQ assignment for PCI devices during suspend/hibernation
x86/apic/vsmp: Make is_vsmp_box() static
x86, apic: Remove enable_apic_mode callback
x86, apic: Remove setup_portio_remap callback
x86, apic: Remove multi_timer_check callback
x86, apic: Replace noop_check_apicid_used
x86, apic: Remove check_apicid_present callback
x86, apic: Remove mps_oem_check callback
x86, apic: Remove smp_callin_clear_local_apic callback
x86, apic: Replace trampoline physical addresses with defaults
x86, apic: Remove x86_32_numa_cpu_node callback
x86: intel-mid: Use the new io_apic interfaces
x86, vsmp: Remove is_vsmp_box() from apic_is_clustered_box()
x86, irq: Clean up irqdomain transition code
x86, irq, devicetree: Release IOAPIC pin when PCI device is disabled
x86, irq, SFI: Release IOAPIC pin when PCI device is disabled
x86, irq, mpparse: Release IOAPIC pin when PCI device is disabled
x86, irq, ACPI: Release IOAPIC pin when PCI device is disabled
x86, irq: Introduce helper functions to release IOAPIC pin
x86, irq: Simplify the way to handle ISA IRQ
Both the 32-bit and 64-bit cmpxchg.h header define __HAVE_ARCH_CMPXCHG
and there's ifdeffery which checks it. But since both bitness define it,
we can just as well move it up to the main cmpxchg header and simpify a
bit of code in doing that.
Link: http://lkml.kernel.org/r/20140711104338.GB17083@pd.tnic
Release IOAPIC pin associated with PCI device when the PCI device
is disabled.
Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Joerg Roedel <joro@8bytes.org>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Grant Likely <grant.likely@linaro.org>
Cc: Rafael J. Wysocki <rjw@rjwysocki.net>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Len Brown <len.brown@intel.com>
Cc: Pavel Machek <pavel@ucw.cz>
Link: http://lkml.kernel.org/r/1402380987-32577-1-git-send-email-jiang.liu@linux.intel.com
On startup, setup_IO_APIC_irqs() will program all IOAPIC pins for ISA
IRQs. Later when mp_map_pin_to_irq() is called, it just returns ISA IRQ
number without programming corresponding IOAPIC pin.
This patch consolidates the way to program IOAPIC pins for both ISA and
non-ISA IRQs into mp_map_pin_to_irq() as below:
1) For ISA IRQs, mp_irqs array is used to map IOAPIC pin to IRQ and
mp_irqdomain_map() is used to actually program the pin.
2) For non-ISA IRQs, irqdomain is used to map IOAPIC pin to IRQ, and
mp_irqdomain_map() is also used to actually program the pin.
Link: http://lkml.kernel.org/r/1402302011-23642-36-git-send-email-jiang.liu@linux.intel.com
Refine ACPI to use common irqdomain map interface to program IOAPIC pins,
so we can unify the callsite to progam IOAPIC pins.
Link: http://lkml.kernel.org/r/1402302011-23642-31-git-send-email-jiang.liu@linux.intel.com
Enhance ACPI driver to provide basic irqdomain support for IOAPIC.
We will build identity mapping for IOAPICs hosting legacy IRQs,
otherwise dynamically allocate IRQ numbers for IOAPIC pins on demand.
Link: http://lkml.kernel.org/r/1402302011-23642-26-git-send-email-jiang.liu@linux.intel.com
Enhance function mp_register_ioapic() to support irqdomain.
When registering IOAPIC, caller may provide callbacks and parameters
for creating irqdomain. The IOAPIC core will create irqdomain later
if caller has passed in corresponding parameters.
Cc: sfi-devel@simplefirmware.org
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Tony Lindgren <tony@atomide.com>
Link: http://lkml.kernel.org/r/1402302011-23642-25-git-send-email-jiang.liu@linux.intel.com
Currently x86 support identity mapping between GSI(IOAPIC pin) and IRQ
number, so continous IRQs at low end are statically allocated to IOAPICs
at boot time. This design causes trouble to support IOAPIC hotplug.
This patch implements basic mechanism to dynamically allocate IRQ on
demand for IOAPIC pins by using irqdomain framework.
It first adds several fields into struct ioapic to support irqdomain.
Then it implements an algorithm to dynamically allocate IRQ number
Currently it supports three types of irqdomain:
1) LEGACY: used to support IOAPIC hosting legacy IRQs and building
identity mapping for legacy IRQs. A speical case, we dynamically
allocate IRQ number for IOAPIC pin which has GSI number below
nr_legacy_irqs() but isn't legacy IRQ. This is for backward
compatibility and avoid regression.
2) STRICT: build identity mapping between GSI and IRQ nubmer.
3) DYNAMIC: dynamically allocate IRQ number for IOAPIC pin on demand.
Legacy(ISA) IRQs is not managed by irqdomain because there may be
multiple pins sharing the same IRQ number and current irqdomain only
supports 1:1 mapping between pins and IRQ.
Link: http://lkml.kernel.org/r/1402302011-23642-24-git-send-email-jiang.liu@linux.intel.com
Currently __acpi_register_gsi is defined to return GSI number and
may be set to acpi_register_gsi_pic(), acpi_register_gsi_ioapic(),
acpi_register_gsi_xen_hvm() and acpi_register_gsi_xen().
Among which, acpi_register_gsi_ioapic() returns GSI number, but
acpi_register_gsi_xen_hvm() and acpi_register_gsi_xen() actually
returns IRQ number instead of GSI. And for acpi_register_gsi_pic(),
GSI number equals to IRQ number.
So change acpi_register_gsi_ioapic() to return IRQ number, it also
simplifies the code.
Link: http://lkml.kernel.org/r/1402380887-32512-1-git-send-email-jiang.liu@linux.intel.com
Currently ACPI and ioapic both implement algorithms to map (ioapic, pin)
to IRQ number. So consolidate the common part into one place, which is
also preparing for irqdomain support.
It introduces mp_map_gsi_to_irq(), which will be used to allocate IRQ
number IOAPIC pins when irqdomain is enabled.
Also rename gsi_to_irq() to map_gsi_to_irq(), later we will introduce
unmap_gsi_to_irq() when enabling IOAPIC hotplug.
Link: http://lkml.kernel.org/r/1402380812-32446-1-git-send-email-jiang.liu@linux.intel.com
NR_IRQS_LEGACY
Some platforms, such as Intel MID and mshypv, do not support legacy
interrupt controllers. So count legacy IRQs by legacy_pic->nr_legacy_irqs
instead of hard-coded NR_IRQS_LEGACY.
Cc: xen-devel@lists.xenproject.org
Acked-by: David Vrabel <david.vrabel@citrix.com>
Link: http://lkml.kernel.org/r/1402302011-23642-20-git-send-email-jiang.liu@linux.intel.com
A default identity mapping between GSI and IRQ is built for legacy IRQs.
So when overriding the default identity mapping for legacy IRQs,
we should also invalidate isa_irq_to_gsi[gsi] when setting
isa_irq_to_gsi[irq] = gsi. Otherwise there may be two entries with the
same GSI in the isa_irq_to_gsi array, and acpi_isa_irq_to_gsi() may give
wrong result.
Link: http://lkml.kernel.org/r/1402302011-23642-10-git-send-email-jiang.liu@linux.intel.com
Function mp_register_gsi() may return error code when failed to look up
or program corresponding IOAPIC pin for GSI, so enhance acpi_register_gsi()
to handle possible error cases.
Link: http://lkml.kernel.org/r/1402380683-32345-1-git-send-email-jiang.liu@linux.intel.com
1) Remove out-of-date comment
2) Kill unused function acpi_set_irq_model_pic()
3) Use NR_IRQS_LEGACY instead of hard-coded 16
4) Trivial syntax improvements
Cc: Jiri Kosina <trivial@kernel.org>
Link: http://lkml.kernel.org/r/1402302011-23642-8-git-send-email-jiang.liu@linux.intel.com
Static function irq_to_gsi() is only called by acpi_isa_irq_to_gsi(),
so kill function irq_to_gsi() and simplify acpi_isa_irq_to_gsi().
Link: http://lkml.kernel.org/r/1402302011-23642-7-git-send-email-jiang.liu@linux.intel.com
Reorganize code to avoid forward declaration in boot.c, no function
changes.
Link: http://lkml.kernel.org/r/1402302011-23642-5-git-send-email-jiang.liu@linux.intel.com
Simplify arch/x86/include/asm/mpspec.h by
1) Change max_physical_apicid to static as it's only used in apic.c.
2) Kill declaration of mpc_default_type, it's never defined.
3) Delete default_acpi_madt_oem_check(), it has already been declared
in apic.h.
4) Make default_acpi_madt_oem_check() depends on CONFIG_X86_LOCAL_APIC
instead of CONFIG_X86_64 to support i386.
5) Change mp_override_legacy_irq(), mp_config_acpi_legacy_irqs() and
mp_register_gsi() as static because they are only used in acpi/boot.c.
Acked-by: David Rientjes <rientjes@google.com>
Cc: H. Peter Anvin <hpa@linux.intel.com>
Cc: Seiji Aguchi <seiji.aguchi@hds.com>
Cc: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com>
Cc: Richard Weinberger <richard@nod.at>
Link: http://lkml.kernel.org/r/1402302011-23642-4-git-send-email-jiang.liu@linux.intel.com
Pull x86 old platform removal from Peter Anvin:
"This patchset removes support for several completely obsolete
platforms, where the maintainers either have completely vanished or
acked the removal. For some of them it is questionable if there even
exists functional specimens of the hardware"
Geert Uytterhoeven apparently thought this was a April Fool's pull request ;)
* 'x86-nuke-platforms-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, platforms: Remove NUMAQ
x86, platforms: Remove SGI Visual Workstation
x86, apic: Remove support for IBM Summit/EXA chipset
x86, apic: Remove support for ia32-based Unisys ES7000
Pull ACPI and power management updates from Rafael Wysocki:
"The majority of this material spent some time in linux-next, some of
it even several weeks. There are a few relatively fresh commits in
it, but they are mostly fixes and simple cleanups.
ACPI took the lead this time, both in terms of the number of commits
and the number of modified lines of code, cpufreq follows and there
are a few changes in the PM core and in cpuidle too.
A new feature that already got some LWN.net's attention is the device
PM QoS extension allowing latency tolerance requirements to be
propagated from leaf devices to their ancestors with hardware
interfaces for specifying latency tolerance. That should help systems
with hardware-driven power management to avoid going too far with it
in cases when there are latency tolerance constraints.
There also are some significant changes in the ACPI core related to
the way in which hotplug notifications are handled. They affect PCI
hotplug (ACPIPHP) and the ACPI dock station code too. The bottom line
is that all those notification now go through the root notify handler
and are propagated to the interested subsystems by means of callbacks
instead of having to install a notify handler for each device object
that we can potentially get hotplug notifications for.
In addition to that ACPICA will now advertise "Windows 2013"
compatibility for _OSI, because some systems out there don't work
correctly if that is not done (some of them don't even boot).
On the system suspend side of things, all of the device suspend and
resume callbacks, except for ->prepare() and ->complete(), are now
going to be executed asynchronously as that turns out to speed up
system suspend and resume on some platforms quite significantly and we
have a few more optimizations in that area.
Apart from that, there are some new device IDs and fixes and cleanups
all over. In particular, the system suspend and resume handling by
cpufreq should be improved and the cpuidle menu governor should be a
bit more robust now.
Specifics:
- Device PM QoS support for latency tolerance constraints on systems
with hardware interfaces allowing such constraints to be specified.
That is necessary to prevent hardware-driven power management from
becoming overly aggressive on some systems and to prevent power
management features leading to excessive latencies from being used
in some cases.
- Consolidation of the handling of ACPI hotplug notifications for
device objects. This causes all device hotplug notifications to go
through the root notify handler (that was executed for all of them
anyway before) that propagates them to individual subsystems, if
necessary, by executing callbacks provided by those subsystems
(those callbacks are associated with struct acpi_device objects
during device enumeration). As a result, the code in question
becomes both smaller in size and more straightforward and all of
those changes should not affect users.
- ACPICA update, including fixes related to the handling of _PRT in
cases when it is broken and the addition of "Windows 2013" to the
list of supported "features" for _OSI (which is necessary to
support systems that work incorrectly or don't even boot without
it). Changes from Bob Moore and Lv Zheng.
- Consolidation of ACPI _OST handling from Jiang Liu.
- ACPI battery and AC fixes allowing unusual system configurations to
be handled by that code from Alexander Mezin.
- New device IDs for the ACPI LPSS driver from Chiau Ee Chew.
- ACPI fan and thermal optimizations related to system suspend and
resume from Aaron Lu.
- Cleanups related to ACPI video from Jean Delvare.
- Assorted ACPI fixes and cleanups from Al Stone, Hanjun Guo, Lan
Tianyu, Paul Bolle, Tomasz Nowicki.
- Intel RAPL (Running Average Power Limits) driver cleanups from
Jacob Pan.
- intel_pstate fixes and cleanups from Dirk Brandewie.
- cpufreq fixes related to system suspend/resume handling from Viresh
Kumar.
- cpufreq core fixes and cleanups from Viresh Kumar, Stratos
Karafotis, Saravana Kannan, Rashika Kheria, Joe Perches.
- cpufreq drivers updates from Viresh Kumar, Zhuoyu Zhang, Rob
Herring.
- cpuidle fixes related to the menu governor from Tuukka Tikkanen.
- cpuidle fix related to coupled CPUs handling from Paul Burton.
- Asynchronous execution of all device suspend and resume callbacks,
except for ->prepare and ->complete, during system suspend and
resume from Chuansheng Liu.
- Delayed resuming of runtime-suspended devices during system suspend
for the PCI bus type and ACPI PM domain.
- New set of PM helper routines to allow device runtime PM callbacks
to be used during system suspend and resume more easily from Ulf
Hansson.
- Assorted fixes and cleanups in the PM core from Geert Uytterhoeven,
Prabhakar Lad, Philipp Zabel, Rashika Kheria, Sebastian Capella.
- devfreq fix from Saravana Kannan"
* tag 'pm+acpi-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (162 commits)
PM / devfreq: Rewrite devfreq_update_status() to fix multiple bugs
PM / sleep: Correct whitespace errors in <linux/pm.h>
intel_pstate: Set core to min P state during core offline
cpufreq: Add stop CPU callback to cpufreq_driver interface
cpufreq: Remove unnecessary braces
cpufreq: Fix checkpatch errors and warnings
cpufreq: powerpc: add cpufreq transition latency for FSL e500mc SoCs
MAINTAINERS: Reorder maintainer addresses for PM and ACPI
PM / Runtime: Update runtime_idle() documentation for return value meaning
video / output: Drop display output class support
fujitsu-laptop: Drop unneeded include
acer-wmi: Stop selecting VIDEO_OUTPUT_CONTROL
ACPI / gpu / drm: Stop selecting VIDEO_OUTPUT_CONTROL
ACPI / video: fix ACPI_VIDEO dependencies
cpufreq: remove unused notifier: CPUFREQ_{SUSPENDCHANGE|RESUMECHANGE}
cpufreq: Do not allow ->setpolicy drivers to provide ->target
cpufreq: arm_big_little: set 'physical_cluster' for each CPU
cpufreq: arm_big_little: make vexpress driver depend on bL core driver
ACPI / button: Add ACPI Button event via netlink routine
ACPI: Remove duplicate definitions of PREFIX
Current ACPI cpu hotplug driver fails to associate hot-added CPUs with
corresponding NUMA node when doing socket online. The code path to
associate CPU with NUMA node is as below:
acpi_processor_add()
->acpi_processor_get_info()
->acpi_processor_hotadd_init()
->acpi_map_lsapic()
->_acpi_map_lsapic()
->acpi_map_cpu2node()
cpu_subsys_online()
->try_online_node()
->node_set_online()
When doing socket online, a new NUMA node is introduced in addition to
hot-added CPU and memory device. And the new NUMA node is marked as
online when onlining hot-added CPUs through sysfs interface
/sys/devices/system/cpu/cpuxx/online.
On the other hand, acpi_map_cpu2node() will only build the CPU to node
map if corresponding NUMA node is already online, so it always fails
to associate hot-added CPUs with corresponding NUMA node because the
NUMA node is still in offline state.
For the fix, we could safely remove the "node_online(node)" check in
function acpi_map_cpu2node() because it's only called for hot-added CPUs
by acpi_processor_hotadd_init().
Link: http://lkml.kernel.org/r/1390185115-26850-1-git-send-email-jiang.liu@linux.intel.com
Acked-by: Rafael J. Wysocki <rjw@rjwysocki.net>
BAD_MADT_ENTRY() is arch independent and will be used for all
architectures which parse MADT, so move it to linux/acpi.h to
reduce code duplication.
Signed-off-by: Hanjun Guo <hanjun.guo@linaro.org>
There should no longer be any ia32-based Unisys ES7000 systems out in
the wild, so remove support for it.
We've done our due diligence in reaching out to any contact information
listed for this system and no indication was given that it should be
kept around.
Signed-off-by: David Rientjes <rientjes@google.com>
"As far as the number of commits goes, the top spot belongs to ACPI
this time with cpufreq in the second position and a handful of PM
core, PNP and cpuidle updates. They are fixes and cleanups mostly, as
usual, with a couple of new features in the mix.
The most visible change is probably that we will create struct
acpi_device objects (visible in sysfs) for all devices represented in
the ACPI tables regardless of their status and there will be a new
sysfs attribute under those objects allowing user space to check that
status via _STA.
Consequently, ACPI device eject or generally hot-removal will not
delete those objects, unless the table containing the corresponding
namespace nodes is unloaded, which is extremely rare. Also ACPI
container hotplug will be handled quite a bit differently and cpufreq
will support CPU boost ("turbo") generically and not only in the
acpi-cpufreq driver.
Specifics:
- ACPI core changes to make it create a struct acpi_device object for
every device represented in the ACPI tables during all namespace
scans regardless of the current status of that device. In
accordance with this, ACPI hotplug operations will not delete those
objects, unless the underlying ACPI tables go away.
- On top of the above, new sysfs attribute for ACPI device objects
allowing user space to check device status by triggering the
execution of _STA for its ACPI object. From Srinivas Pandruvada.
- ACPI core hotplug changes reducing code duplication, integrating
the PCI root hotplug with the core and reworking container hotplug.
- ACPI core simplifications making it use ACPI_COMPANION() in the
code "glueing" ACPI device objects to "physical" devices.
- ACPICA update to upstream version 20131218. This adds support for
the DBG2 and PCCT tables to ACPICA, fixes some bugs and improves
debug facilities. From Bob Moore, Lv Zheng and Betty Dall.
- Init code change to carry out the early ACPI initialization
earlier. That should allow us to use ACPI during the timekeeping
initialization and possibly to simplify the EFI initialization too.
From Chun-Yi Lee.
- Clenups of the inclusions of ACPI headers in many places all over
from Lv Zheng and Rashika Kheria (work in progress).
- New helper for ACPI _DSM execution and rework of the code in
drivers that uses _DSM to execute it via the new helper. From
Jiang Liu.
- New Win8 OSI blacklist entries from Takashi Iwai.
- Assorted ACPI fixes and cleanups from Al Stone, Emil Goode, Hanjun
Guo, Lan Tianyu, Masanari Iida, Oliver Neukum, Prarit Bhargava,
Rashika Kheria, Tang Chen, Zhang Rui.
- intel_pstate driver updates, including proper Baytrail support,
from Dirk Brandewie and intel_pstate documentation from Ramkumar
Ramachandra.
- Generic CPU boost ("turbo") support for cpufreq from Lukasz
Majewski.
- powernow-k6 cpufreq driver fixes from Mikulas Patocka.
- cpufreq core fixes and cleanups from Viresh Kumar, Jane Li, Mark
Brown.
- Assorted cpufreq drivers fixes and cleanups from Anson Huang, John
Tobias, Paul Bolle, Paul Walmsley, Sachin Kamat, Shawn Guo, Viresh
Kumar.
- cpuidle cleanups from Bartlomiej Zolnierkiewicz.
- Support for hibernation APM events from Bin Shi.
- Hibernation fix to avoid bringing up nonboot CPUs with ACPI EC
disabled during thaw transitions from Bjørn Mork.
- PM core fixes and cleanups from Ben Dooks, Leonardo Potenza, Ulf
Hansson.
- PNP subsystem fixes and cleanups from Dmitry Torokhov, Levente
Kurusa, Rashika Kheria.
- New tool for profiling system suspend from Todd E Brandt and a
cpupower tool cleanup from One Thousand Gnomes"
* tag 'pm+acpi-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (153 commits)
thermal: exynos: boost: Automatic enable/disable of BOOST feature (at Exynos4412)
cpufreq: exynos4x12: Change L0 driver data to CPUFREQ_BOOST_FREQ
Documentation: cpufreq / boost: Update BOOST documentation
cpufreq: exynos: Extend Exynos cpufreq driver to support boost
cpufreq / boost: Kconfig: Support for software-managed BOOST
acpi-cpufreq: Adjust the code to use the common boost attribute
cpufreq: Add boost frequency support in core
intel_pstate: Add trace point to report internal state.
cpufreq: introduce cpufreq_generic_get() routine
ARM: SA1100: Create dummy clk_get_rate() to avoid build failures
cpufreq: stats: create sysfs entries when cpufreq_stats is a module
cpufreq: stats: free table and remove sysfs entry in a single routine
cpufreq: stats: remove hotplug notifiers
cpufreq: stats: handle cpufreq_unregister_driver() and suspend/resume properly
cpufreq: speedstep: remove unused speedstep_get_state
platform: introduce OF style 'modalias' support for platform bus
PM / tools: new tool for suspend/resume performance optimization
ACPI: fix module autoloading for ACPI enumerated devices
ACPI: add module autoloading support for ACPI enumerated devices
ACPI: fix create_modalias() return value handling
This change adds a runtime option that will force ACPICA to use the
RSDT instead of the XSDT. Although the ACPI spec requires that an XSDT
be used instead of the RSDT, the XSDT has been found to be corrupt or
ill-formed on some machines.
This option is already in the Linux kernel. When it is back ported to
ACPICA, code is re-written to follow ACPICA coding style. This patch
is the generation of the integration.
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
Signed-off-by: Bob Moore <robert.moore@intel.com>
Use dev_is_pci() instead of checking bus type directly.
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
* acpi-assorted:
ACPI: Add Toshiba NB100 to Vista _OSI blacklist
ACPI / osl: remove an unneeded NULL check
ACPI / platform: add ACPI ID for a Broadcom GPS chip
ACPI: improve acpi_extract_package() utility
ACPI / LPSS: fix UART Auto Flow Control
ACPI / platform: Add ACPI IDs for Intel SST audio device
x86 / ACPI: fix incorrect placement of __initdata tag
ACPI / thermal: convert printk(LEVEL...) to pr_<lvl>
ACPI / sysfs: make GPE sysfs attributes only accept correct values
ACPI / EC: Convert all printk() calls to dynamic debug function
ACPI / button: Using input_set_capability() to mark device's event capability
ACPI / osl: implement acpi_os_sleep() with msleep()
__initdata tag should not be placed between "struct" and "resource"
because it prevents the variable from being placed in the intended
.init.data section. Fix it.
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
In acpi_register_lapic(), it will generates a new logical cpu
number and maps to the local APIC id, this logical cpu number
can be returned to simplify _acpi_map_lsapic() implementation.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Since APIC id is saved in processor struct, just use it and
remove the duplicated _MAT evaluation.
Pull x86 RAS changes from Ingo Molnar:
"[ The reason for drivers/ updates is that Boris asked for the
drivers/edac/ changes to go via x86/ras in this cycle ]
Main changes:
- AMD CPUs:
. Add ECC event decoding support for new F15h models
. Various erratum fixes
. Fix single-channel on dual-channel-controllers bug.
- Intel CPUs:
. UC uncorrectable memory error parsing fix
. Add support for CMC (Corrected Machine Check) 'FF' (Firmware
First) flag in the APEI HEST
- Various cleanups and fixes"
* 'x86-ras-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
amd64_edac: Fix incorrect wraparounds
amd64_edac: Correct erratum 505 range
cpc925_edac: Use proper array termination
x86/mce, acpi/apei: Only disable banks listed in HEST if mce is configured
amd64_edac: Get rid of boot_cpu_data accesses
amd64_edac: Add ECC decoding support for newer F15h models
x86, amd_nb: Clarify F15h, model 30h GART and L3 support
pci_ids: Add PCI device ID functions 3 and 4 for newer F15h models.
x38_edac: Make a local function static
i3200_edac: Make a local function static
x86/mce: Pay no attention to 'F' bit in MCACOD when parsing 'UC' errors
APEI/ERST: Fix error message formatting
amd64_edac: Fix single-channel setups
EDAC: Replace strict_strtol() with kstrtol()
mce: acpi/apei: Soft-offline a page on firmware GHES notification
mce: acpi/apei: Add a boot option to disable ff mode for corrected errors
mce: acpi/apei: Honour Firmware First for MCA banks listed in APEI HEST CMC
Pull x86 platform documentation fix from Ingo Molnar.
* 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/acpi: Correct out-of-date comment of __acpi_map_table()
than once
When programming ioapic pinX more than once, current code
does not check whether the later attr (trigger & polarity) is the
same as the former or not.
This causes broken semantics which can be observed in a qemu q35
machine, where ioapic's ioredtbl[x] can never be set as low-active,
even if the hpet driver registered it.
And hpet driver may share a high-level active IRQ line with other
devices. So in qemu, when hpet-dev asserts low-level as kernel
expects, the kernel has no response.
With this patch, we can observe an ioredtbl[x] set as low-active
for hpet.
Fix it by reporting -EBUSY to the caller, when attr is different.
Signed-off-by: Liu Ping Fan <pingfank@linux.vnet.ibm.com>
Cc: Kevin Hao <haokexin@gmail.com>
Link: http://lkml.kernel.org/r/1377248327-19633-1-git-send-email-pingfank@linux.vnet.ibm.com
[ Made small readability edits to both the changelog and the code. ]
Pursue a single RAS/MCE topic branch on x86.
The implementation of function __acpi_map_table() has been
changed long time ago, and now it directly invokes
early_ioremap() to setup the temporarily acpi table mappings.
So correct its out-of-date comment.
Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Cc: len.brown@intel.com
Cc: pavel@ucw.cz
Cc: rjw@sisk.pl
Link: http://lkml.kernel.org/r/51EE7F1C.9020506@gmail.com
We wanted to check if the APIC ID is out of range. It should be:
if (id >= MAX_LOCAL_APIC)
There's no known bad effect of this bug.
Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com>
Reviewed-by: Len Brown <len.brown@intel.com>
Cc: pavel@ucw.cz
Cc: rjw@sisk.pl
Link: http://lkml.kernel.org/r/1374566419-21120-1-git-send-email-tangchen@cn.fujitsu.com
The __cpuinit type of throwaway sections might have made sense
some time ago when RAM was more constrained, but now the savings
do not offset the cost and complications. For example, the fix in
commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time")
is a good example of the nasty type of bugs that can be created
with improper use of the various __init prefixes.
After a discussion on LKML[1] it was decided that cpuinit should go
the way of devinit and be phased out. Once all the users are gone,
we can then finally remove the macros themselves from linux/init.h.
Note that some harmless section mismatch warnings may result, since
notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c)
are flagged as __cpuinit -- so if we remove the __cpuinit from
arch specific callers, we will also get section mismatch warnings.
As an intermediate step, we intend to turn the linux/init.h cpuinit
content into no-ops as early as possible, since that will get rid
of these warnings. In any case, they are temporary and harmless.
This removes all the arch/x86 uses of the __cpuinit macros from
all C files. x86 only had the one __CPUINIT used in assembly files,
and it wasn't paired off with a .previous or a __FINIT, so we can
delete it directly w/o any corresponding additional change there.
[1] https://lkml.org/lkml/2013/5/20/589
Cc: x86@kernel.org
Acked-by: Ingo Molnar <mingo@kernel.org>
Acked-by: H. Peter Anvin <hpa@linux.intel.com>
Add a boot option to disable firmware first mode for corrected errors.
Signed-off-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Acked-by: Borislav Petkov <bp@suse.de>
Signed-off-by: Tony Luck <tony.luck@intel.com>
Which by default will be x86_acpi_suspend_lowlevel.
This registration allows us to register another callback
if there is a need to use another platform specific callback.
Signed-off-by: Liang Tang <liang.tang@oracle.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Tested-by: Ben Guthro <benjamin.guthro@citrix.com>
Acked-by: "H. Peter Anvin" <hpa@linux.intel.com>
When a cpu is hotpluged, we call acpi_map_cpu2node() in
_acpi_map_lsapic() to store the cpu's node and apicid's node. But we
don't clear the cpu's node in acpi_unmap_lsapic() when this cpu is
hotremoved. If the node is also hotremoved, we will get the following
kernel BUG at include/linux/gfp.h:329!
invalid opcode: 0000 [#1] SMP
Modules linked in: ebtable_nat ebtables ipt_MASQUERADE iptable_nat nf_nat xt_CHECKSUM iptable_mangle bridge stp llc sunrpc ipt_REJECT nf_conntrack_ipv4 nf_defrag_ipv4 iptable_filter ip_tables ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables binfmt_misc dm_mirror dm_region_hash dm_log dm_mod vhost_net macvtap macvlan tun uinput iTCO_wdt iTCO_vendor_support coretemp kvm_intel kvm crc32c_intel microcode pcspkr i2c_i801 i2c_core lpc_ich mfd_core ioatdma e1000e i7core_edac edac_core sg acpi_memhotplug igb dca sd_mod crc_t10dif megaraid_sas mptsas mptscsih mptbase scsi_transport_sas scsi_mod
Pid: 3126, comm: init Not tainted 3.6.0-rc3-tangchen-hostbridge+ #13 FUJITSU-SV PRIMEQUEST 1800E/SB
RIP: 0010:[<ffffffff811bc3fd>] [<ffffffff811bc3fd>] allocate_slab+0x28d/0x300
RSP: 0018:ffff88078a049cf8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: 0000000000000001 RCX: 0000000000000000
RDX: 0000000000000001 RSI: 0000000000000001 RDI: 0000000000000246
RBP: ffff88078a049d38 R08: 00000000000040d0 R09: 0000000000000001
R10: 0000000000000000 R11: 0000000000000b5f R12: 00000000000052d0
R13: ffff8807c1417300 R14: 0000000000030038 R15: 0000000000000003
FS: 00007fa9b1b44700(0000) GS:ffff8807c3800000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00007fa9b09acca0 CR3: 000000078b855000 CR4: 00000000000007e0
Process init (pid: 3126, threadinfo ffff88078a048000, task ffff8807bb6f2650)
Call Trace:
new_slab+0x30/0x1b0
__slab_alloc+0x358/0x4c0
kmem_cache_alloc_node_trace+0xb4/0x1e0
alloc_fair_sched_group+0xd0/0x1b0
sched_create_group+0x3e/0x110
sched_autogroup_create_attach+0x4d/0x180
sys_setsid+0xd4/0xf0
system_call_fastpath+0x16/0x1b
Code: 89 c4 e9 73 fe ff ff 31 c0 89 de 48 c7 c7 45 de 9e 81 44 89 45 c8 e8 22 05 4b 00 85 db 44 8b 45 c8 0f 89 4f ff ff ff 0f 0b eb fe <0f> 0b 90 eb fd 0f 0b eb fe 89 de 48 c7 c7 45 de 9e 81 31 c0 44
RIP [<ffffffff811bc3fd>] allocate_slab+0x28d/0x300
RSP <ffff88078a049cf8>
---[ end trace adf84c90f3fea3e5 ]---
The reason is that the cpu's node is not NUMA_NO_NODE, we will call
alloc_pages_exact_node() to alloc memory on the node, but the node is
offlined.
If the node is onlined, we still need cpu's node. For example: a task
on the cpu is sleeped when the cpu is hotremoved. We will choose
another cpu to run this task when it is waked up. If we know the cpu's
node, we will choose the cpu on the same node first. So we should clear
cpu-to-node mapping when the node is offlined.
This patch only clears apicid-to-node mapping when the cpu is
hotremoved.
[akpm@linux-foundation.org: fix section error]
Signed-off-by: Wen Congyang <wency@cn.fujitsu.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Jiang Liu <liuj97@gmail.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
Coming patches to x86/mm2 require the changes and advanced baseline in
x86/boot.
Resolved Conflicts:
arch/x86/kernel/setup.c
mm/nobootmem.c
Pull x86 ACPI update from Peter Anvin:
"This is a patchset which didn't make the last merge window. It adds a
debugging capability to feed ACPI tables via the initramfs.
On a grander scope, it formalizes using the initramfs protocol for
feeding arbitrary blobs which need to be accessed early to the kernel:
they are fed first in the initramfs blob (lots of bootloaders can
concatenate this at boot time, others can use a single file) in an
uncompressed cpio archive using filenames starting with "kernel/".
The ACPI maintainers requested that this patchset be fed via the x86
tree rather than the ACPI tree as the footprint in the general x86
code is much bigger than in the ACPI code proper."
* 'x86-acpi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
X86 ACPI: Use #ifdef not #if for CONFIG_X86 check
ACPI: Fix build when disabled
ACPI: Document ACPI table overriding via initrd
ACPI: Create acpi_table_taint() function to avoid code duplication
ACPI: Implement physical address table override
ACPI: Store valid ACPI tables passed via early initrd in reserved memblock areas
x86, acpi: Introduce x86 arch specific arch_reserve_mem_area() for e820 handling
lib: Add early cpio decoder
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Link: http://lkml.kernel.org/r/1353123563-3103-44-git-send-email-yinghai@kernel.org
These functions might be called from modules as well so make sure
they are exported.
In addition, implement empty version of acpi_unregister_gsi() and
remove the one from pci_irq.c.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Acked-by: Tony Luck <tony.luck@intel.com>
This is needed for ACPI table overriding via initrd. Beside reserving
memblocks, X86 also requires to flag the memory area to E820_RESERVED or
E820_ACPI in the e820 mappings to be able to io(re)map it later.
Signed-off-by: Thomas Renninger <trenn@suse.de>
Link: http://lkml.kernel.org/r/1349043837-22659-3-git-send-email-trenn@suse.de
Cc: Len Brown <lenb@kernel.org>
Cc: Robert Moore <robert.moore@intel.com>
Cc: Eric Piel <eric.piel@tremplin-utc.net>
Commit 31d2092eb0c23636b73d2c24c0c11b66470cef58 ("x86: move
mp_register_lapic_address to boot.c") renamed mp_register_lapic
to acpi_register_lapic. But mp_register_lapic remains in a
comment. So the patch rename it.
Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Link: http://lkml.kernel.org/r/50625239.3050403@jp.fujitsu.com
This is the 2nd part of fix for kernel bugzilla 40002:
"IRQ 0 assigned to VGA"
https://bugzilla.kernel.org/show_bug.cgi?id=40002
The root cause is the buggy FW, whose ACPI tables assign the GSI 16
to 2 irqs 0 and 16(VGA), and the VGA is the right owner of GSI 16.
So add a quirk to ignore the irq0 overriding GSI 16 for the
FUJITSU SIEMENS AMILO PRO V2030 platform will solve this issue.
Reported-and-tested-by: Szymon Kowalczyk <fazerxlo@o2.pl>
Signed-off-by: Feng Tang <feng.tang@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
Current WARN msg is only for the ati_ixp4x0 board, while this function
is used by mulitple platforms. So this one board specific warning
is not appropriate any more.
Currently when acpi_skip_timer_override is set, it only cover the
(source_irq == 0 && global_irq == 2) cases. While there is also
platform which need use this option and its global_irq is not 2.
This patch will extend acpi_skip_timer_override to cover all
timer overriding cases as long as the source irq is 0.
This is the first part of a fix to kernel bug bugzilla 40002:
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull the MCA deletion branch from Paul Gortmaker:
"It was good that we could support MCA machines back in the day, but
realistically, nobody is using them anymore. They were mostly limited
to 386-sx 16MHz CPU and some 486 class machines and never more than
64MB of RAM. Even the enthusiast hobbyist community seems to have
dried up close to ten years ago, based on what you can find searching
various websites dedicated to the relatively short lived hardware.
So lets remove the support relating to CONFIG_MCA. There is no point
carrying this forward, wasting cycles doing routine maintenance on it;
wasting allyesconfig build time on validating it, wasting I/O on git
grep'ping over it, and so on."
Let's see if anybody screams. It generally has compiled, and James
Bottomley pointed out that there was a MCA extension from NCR that
allowed for up to 4GB of memory and PPro-class machines. So in *theory*
there may be users out there.
But even James (technically listed as a maintainer) doesn't actually
have a system, and while Alan Cox claims to have a machine in his cellar
that he offered to anybody who wants to take it off his hands, he didn't
argue for keeping MCA support either.
So we could bring it back. But somebody had better speak up and talk
about how they have actually been using said MCA hardware with modern
kernels for us to do that. And David already took the patch to delete
all the networking driver code (commit a5e371f61ad3: "drivers/net:
delete all code/drivers depending on CONFIG_MCA").
* 'delete-mca' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
MCA: delete all remaining traces of microchannel bus support.
scsi: delete the MCA specific drivers and driver code
serial: delete the MCA specific 8250 support.
arm: remove ability to select CONFIG_MCA
Hardware with MCA bus is limited to 386 and 486 class machines
that are now 20+ years old and typically with less than 32MB
of memory. A quick search on the internet, and you see that
even the MCA hobbyist/enthusiast community has lost interest
in the early 2000 era and never really even moved ahead from
the 2.4 kernels to the 2.6 series.
This deletes anything remaining related to CONFIG_MCA from core
kernel code and from the x86 architecture. There is no point in
carrying this any further into the future.
One complication to watch for is inadvertently scooping up
stuff relating to machine check, since there is overlap in
the TLA name space (e.g. arch/x86/boot/mca.c).
Cc: James Bottomley <JBottomley@Parallels.com>
Cc: x86@kernel.org
