[mingo@elte.hu: split from "x86_64: get boot_cpu_id as early for k8_scan_nodes]
memset and NULL check after alloc_bootmem() are unnecessary.
Because it returns zeroed memory and it never return NULL.
Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de>
Add kernel support for new ACPI "sapic" tables that contain 16-bit APICIDs.
This patch simply adds parsing of an optional SAPIC table if present.
Otherwise, the traditional local APIC table is used.
Note: the SAPIC table is not a new ACPI table - it exists on other architectures
but is not currently recognized by x86_64.
Signed-off-by: Jack Steiner <steiner@sgi.com>
Add functions that can be used to determine if an x86_64
system is a SGI "UV" system. UV systems come in 3 types and
are identified by the OEM ID in the MADT.
After the inclusion, a lot of files needs fixing for conflicts,
some of them in the headers themselves, to accomodate for both
i386 and x86_64 versions.
[ mingo@elte.hu: build fix ]
Signed-off-by: Glauber Costa <gcosta@redhat.com>
When acpi=off and pci=nomsi, don't load acpiphp.
Fixes this:
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
ACPI Exception (utmutex-0263): AE_BAD_PARAMETER, Thread
FFFF81103CC54000 could not acquire Mutex [1] [20070126]
[akpm@linux-foundation.org: export acpi_pci_disabled for acpiphp.ko]
[akpm@linux-foundation.org: fix return statement]
Signed-off-by: Yinghai Lu <yinghai.lu@sun.com>
Cc: Kristen Carlson Accardi <kristen.c.accardi@intel.com>
drivers/acpi/scan.c
include/linux/acpi.h
Signed-off-by: Len Brown <len.brown@intel.com>
This patch contains the following possible cleanups:
- make the following needlessly global code static:
- drivers/acpi/bay.c:dev_attr_eject
- drivers/acpi/bay.c:dev_attr_present
- drivers/acpi/dock.c:dev_attr_docked
- drivers/acpi/dock.c:dev_attr_flags
- drivers/acpi/dock.c:dev_attr_uid
- drivers/acpi/dock.c:dev_attr_undock
- drivers/acpi/pci_bind.c:acpi_pci_unbind()
- drivers/acpi/pci_link.c:acpi_link_lock
- drivers/acpi/sbs.c:acpi_sbs_callback()
- drivers/acpi/sbshc.c:acpi_smbus_transaction()
- drivers/acpi/sleep/main.c:acpi_sleep_prepare()
- #if 0 the following unused global functions:
- drivers/acpi/numa.c:acpi_unmap_pxm_to_node()
- remove the following unused EXPORT_SYMBOL's:
- acpi_register_gsi
- acpi_unregister_gsi
- acpi_strict
- acpi_bus_receive_event
- register_acpi_bus_type
- unregister_acpi_bus_type
- acpi_os_printf
- acpi_os_sleep
- acpi_os_stall
- acpi_os_read_pci_configuration
- acpi_os_create_semaphore
- acpi_os_delete_semaphore
- acpi_os_wait_semaphore
- acpi_os_signal_semaphore
- acpi_os_signal
- acpi_pci_irq_enable
- acpi_get_pxm
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Acked-by: Alexey Starikovskiy <astarikovskiy@suse.de>
'bugzilla-7186', 'bugzilla-8269', 'bugzilla-8570', 'bugzilla-9139', 'bugzilla-9277', 'bugzilla-9341', 'bugzilla-9444', 'bugzilla-9614', 'bugzilla-9643' and 'bugzilla-9644' into release
Fix following warning:
WARNING: o-x86_64/arch/x86/kernel/built-in.o(.text+0x13d15): Section mismatch in reference from the function acpi_map_lsapic() to the function .cpuinit.text:mp_register_lapic()
The function acpi_map_lsapic() is exported and thus not annotated.
But the sole user is acpi/processor_core.c in a __cpuinit path.
So create a small wrapper and put back the annotation thus
avoiding the warning.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
ACPI tables follow a tree structure in memory.
The root of the tree is the RSDP (Root System Description Pointer).
To find the RSDP, the OS searches for the signature "RSD PTR "
in well known physical memory locations. Then the OS computes
a table checksum to verify that the signature is really part
of a valid table header.
Some systems have a proper signature but an invalid checksum;
followed elsewhere by a proper signature with valid checksum.
http://bugzilla.kernel.org/show_bug.cgi?id=9444
The Linux RSDP scanning code bailed out on those systems
and as a result they booted with ACPI disabled.
Fix this by deleting the Linux RSDP scanning code and
plugging in the ACPICA RSDP scanning code.
.. as it it used only during early boot.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
arch/ia64/kernel/acpi.c | 2 +-
arch/x86/kernel/acpi/boot.c | 4 ++--
drivers/acpi/osl.c | 3 ++-
3 files changed, 5 insertions(+), 4 deletions(-)
Some BIOSes advertise HPET at 0x0. We really do no want to
allocate a resource there. Check for it and leave early.
Other BIOSes tell us the HPET is at 0xfed0000000000000
instead of 0xfed00000. Add a check and fix it up with a warning
on user request.
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (74 commits)
fix do_sys_open() prototype
sysfs: trivial: fix sysfs_create_file kerneldoc spelling mistake
Documentation: Fix typo in SubmitChecklist.
Typo: depricated -> deprecated
Add missing profile=kvm option to Documentation/kernel-parameters.txt
fix typo about TBI in e1000 comment
proc.txt: Add /proc/stat field
small documentation fixes
Fix compiler warning in smount example program from sharedsubtree.txt
docs/sysfs: add missing word to sysfs attribute explanation
documentation/ext3: grammar fixes
Documentation/java.txt: typo and grammar fixes
Documentation/filesystems/vfs.txt: typo fix
include/asm-*/system.h: remove unused set_rmb(), set_wmb() macros
trivial copy_data_pages() tidy up
Fix typo in arch/x86/kernel/tsc_32.c
file link fix for Pegasus USB net driver help
remove unused return within void return function
Typo fixes retrun -> return
x86 hpet.h: remove broken links
Spelling fixes in arch/i386/.
Signed-off-by: Simon Arlott <simon@fire.lp0.eu>
This patch converts the x86_cpu_to_apicid array to be a per cpu
variable. This saves sizeof(apicid) * NR unused cpus. Access is mostly
from startup and CPU HOTPLUG functions.
MP_processor_info() is one of the functions that require access to the
x86_cpu_to_apicid array before the per_cpu data area is setup. For this
case, a pointer to the __initdata array is initialized in setup_arch()
and removed in smp_prepare_cpus() after the per_cpu data area is
initialized.
A second change is included to change the initial array value of ARCH
i386 from 0xff to BAD_APICID to be consistent with ARCH x86_64.
Signed-off-by: Mike Travis <travis@sgi.com>
Cc: Andi Kleen <ak@suse.de>
Cc: Christoph Lameter <clameter@sgi.com>
Cc: "Siddha, Suresh B" <suresh.b.siddha@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/misc-2.6
* 'dmi-const' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/misc-2.6:
drivers/firmware: const-ify DMI API and internals
