Older binutils breaks if ASSERT() is used without a sink
for the output.
For example 2.14.90.0.6 is known to be broken, the link
fails with:
LD .tmp_vmlinux1
ld:arch/x86/kernel/vmlinux.lds:678: parse error
Document this quirk in all three files that use it.
See: http://marc.info/?l=linux-kbuild&m=124930110427870&w=2
See[2]: d2ba8b2 ("x86: Fix assert syntax in vmlinux.lds.S")
Cc: Roland McGrath <roland@redhat.com>
LKML-Reference: <4AD6523D.5030909@zytor.com>
This reverts commit e9a63a4e559fbdc522072281d05e6b13c1022f4b.
This breaks older binutils, where sink-less asserts are broken.
See this commit for further details:
d2ba8b2: x86: Fix assert syntax in vmlinux.lds.S
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
The linker scripts grew some use of weirdly wrong linker script syntax.
It happens to work, but it's not what the syntax is documented to be.
Clean it up to use the official syntax.
Signed-off-by: Roland McGrath <roland@redhat.com>
CC: Ian Lance Taylor <iant@google.com>
To allow linker to catch sections overlapping we have to declare
them in appropriate order.
Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com>
Acked-by: Pavel Machek <pavel@suse.cz>
Move wakeup code to .c, so that video mode setting code can be shared
between boot and wakeup. Remove nasty assembly code in 64-bit case by
re-using trampoline code. Stack setup was fixed to clear high 16bits
of %esp, maybe that fixes some machines.
.c code sharing and morse code was done H. Peter Anvin, Sam Ravnborg
reviewed kbuild related stuff, and it seems okay to him. Rafael did
some cleanups.
[rjw:
* Made the patch stop breaking compilation on x86-32
* Added arch/x86/kernel/acpi/sleep.h
* Got rid of compiler warnings in arch/x86/kernel/acpi/sleep.c
* Fixed 32-bit compilation on x86-64 systems
* Added include/asm-x86/trampoline.h and fixed the non-SMP
compilation on 64-bit x86
* Removed arch/x86/kernel/acpi/sleep_32.c which was not used
* Fixed some breakage caused by the integration of smpboot.c done
under us in the meantime]
Signed-off-by: Pavel Machek <pavel@suse.cz>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Reviewed-by: Sam Ravnborg <sam@ravnborg.org>
