path: root/arch/x86/kernel/amd_gart_64.c
2014-06-04x86: enable DMA CMA with swiotlbAkinobu Mita
The DMA Contiguous Memory Allocator support on x86 is disabled when swiotlb config option is enabled. So DMA CMA is always disabled on x86_64 because swiotlb is always enabled. This attempts to support for DMA CMA with enabling swiotlb config option. The contiguous memory allocator on x86 is integrated in the function dma_generic_alloc_coherent() which is .alloc callback in nommu_dma_ops for dma_alloc_coherent(). x86_swiotlb_alloc_coherent() which is .alloc callback in swiotlb_dma_ops tries to allocate with dma_generic_alloc_coherent() firstly and then swiotlb_alloc_coherent() is called as a fallback. The main part of supporting DMA CMA with swiotlb is that changing x86_swiotlb_free_coherent() which is .free callback in swiotlb_dma_ops for dma_free_coherent() so that it can distinguish memory allocated by dma_generic_alloc_coherent() from one allocated by swiotlb_alloc_coherent() and release it with dma_generic_free_coherent() which can handle contiguous memory. This change requires making is_swiotlb_buffer() global function. This also needs to change .free callback in the dma_map_ops for amd_gart and sta2x11, because these dma_ops are also using dma_generic_alloc_coherent(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Don Dutile <ddutile@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-17x86, mm: use pfn_range_is_mapped() with gartYinghai Lu
We are going to map ram only, so under max_low_pfn_mapped, between 4g and max_pfn_mapped does not mean mapped at all. Use pfn_range_is_mapped() directly. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Link: http://lkml.kernel.org/r/1353123563-3103-14-git-send-email-yinghai@kernel.org Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2012-03-28X86 & IA64: adapt for dma_map_ops changesAndrzej Pietrasiewicz
Adapt core x86 and IA64 architecture code for dma_map_ops changes: replace alloc/free_coherent with generic alloc/free methods. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> [removed swiotlb related changes and replaced it with wrappers, merged with IA64 patch to avoid inter-patch dependences in intel-iommu code] Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Tony Luck <tony.luck@intel.com>
2011-09-27doc: fix broken referencesPaul Bolle
There are numerous broken references to Documentation files (in other Documentation files, in comments, etc.). These broken references are caused by typo's in the references, and by renames or removals of the Documentation files. Some broken references are simply odd. Fix these broken references, sometimes by dropping the irrelevant text they were part of. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-10x86, gart: Rename pci-gart_64.c to amd_gart_64.cJoerg Roedel
This file only contains code relevant for the northbridge gart in AMD processors. This patch renames the file to represent this fact in the filename. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
