commit 086e8ced65d9bcc4a8e8f1cd39b09640f2883f90 upstream.
In x2apic mode, we need to set the upper address register of the fault
handling interrupt register of the vt-d hardware. Without this
irq migration of the vt-d fault handling interrupt is broken.
Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
LKML-Reference: <1291225233.2648.39.camel@sbsiddha-MOBL3>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Acked-by: Chris Wright <chrisw@sous-sol.org>
Tested-by: Takao Indoh <indou.takao@jp.fujitsu.com>
commit 75e3cfbed6f71a8f151dc6e413b6ce3c390030cb upstream.
Currently the redirection hint in the interrupt-remapping table entry
is set to 0, which means the remapped interrupt is directed to the
processors listed in the destination. So in logical flat mode
in the presence of intr-remapping, this results in a single
interrupt multi-casted to multiple cpu's as specified by the destination
bit mask. But what we really want is to send that interrupt to one of the cpus
based on the lowest priority delivery mode.
Set the redirection hint in the IRTE to '1' to indicate that we want
the remapped interrupt to be directed to only one of the processors
This fixes the issue of same interrupt getting delivered to multiple cpu's
in the logical flat mode in the presence of interrupt-remapping. While
there is no functional issue observed with this behavior, this will
impact performance of such configurations (<=8 cpu's using logical flat
mode in the presence of interrupt-remapping)
LKML-Reference: <20100827181049.013051492@sbsiddha-MOBL3.sc.intel.com>
Cc: Weidong Han <weidong.han@intel.com>
free_irq_cfg() is not freeing the cpumask_vars in irq_cfg. Fixing this
triggers a use after free caused by the fact that copying struct
irq_cfg is done with memcpy, which copies the pointer not the cpumask.
Fix both places.
Cc: Yinghai Lu <yhlu.kernel@gmail.com>
LKML-Reference: <alpine.LFD.2.00.1009282052570.2416@localhost6.localdomain6>
Cc: stable@kernel.org
Fix a boot crash when apic=debug is used and the APIC is
not properly initialized.
This issue appears during Xen Dom0 kernel boot but the
fix is generic and the crash could occur on real hardware
as well.
Signed-off-by: Daniel Kiper <dkiper@net-space.pl>
Cc: xen-devel@lists.xensource.com
Cc: konrad.wilk@oracle.com
Cc: jeremy@goop.org
Cc: <stable@kernel.org> # .35.x, .34.x, .33.x, .32.x
LKML-Reference: <20100819224616.GB9967@router-fw-old.local.net-space.pl>
commit 2ca1af9aa3285c6a5f103ed31ad09f7399fc65d7 "PCI: MSI: Remove
unsafe and unnecessary hardware access" changed read_msi_msg_desc() to
return the last MSI message written instead of reading it from the
device, since it may be called while the device is in a reduced
power state.
However, the pSeries platform code really does need to read messages
from the device, since they are initially written by firmware.
Therefore:
- Restore the previous behaviour of read_msi_msg_desc()
- Add new functions get_cached_msi_msg{,_desc}() which return the
- Use the new functions where appropriate
Acked-by: Michael Ellerman <michael@ellerman.id.au>
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
When I introduced the global variable gsi_end I thought gsi_end on
io_apics was one past the end of the gsi range for the io_apic. After
it was pointed out the the range on io_apics was inclusive I changed
my global variable to match. That was a big mistake. Inclusive
semantics without a range start cannot describe the case when no gsi's
are allocated. Describing the case where no gsi's are allocated is
important in sfi.c and mpparse.c so that we can assign gsi numbers
instead of blindly copying the gsi assignments the BIOS has done as we
do in the acpi case.
To keep from getting the global variable confused with the gsi range
end rename it gsi_top.
To allow describing the case where no gsi's are allocated have gsi_top
be one place the highest gsi number seen in the system.
This fixes an off by one bug in sfi.c:
Reported-by: jacob pan <jacob.jun.pan@linux.intel.com>
This fixes the same off by one bug in mpparse.c:
This fixes an off unreachable by one bug in acpi/boot.c:irq_to_gsi
Reported-by: Yinghai <yinghai.lu@oracle.com>
LKML-Reference: <m17hm9jre7.fsf_-_@fess.ebiederm.org>
* 'x86-irq-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, acpi/irq: Define gsi_end when X86_IO_APIC is undefined
x86, irq: Kill io_apic_renumber_irq
x86, acpi/irq: Handle isa irqs that are not identity mapped to gsi's.
x86, ioapic: Simplify probe_nr_irqs_gsi.
x86, ioapic: Optimize pin_2_irq
x86, ioapic: Move nr_ioapic_registers calculation to mp_register_ioapic.
x86, ioapic: In mpparse use mp_register_ioapic
x86, ioapic: Teach mp_register_ioapic to compute a global gsi_end
x86, ioapic: Fix the types of gsi values
x86, ioapic: Fix io_apic_redir_entries to return the number of entries.
x86, ioapic: Only export mp_find_ioapic and mp_find_ioapic_pin in io_apic.h
x86, acpi/irq: Generalize mp_config_acpi_legacy_irqs
x86, acpi/irq: Fix acpi_sci_ioapic_setup so it has both bus_irq and gsi
x86, acpi/irq: pci device dev->irq is an isa irq not a gsi
x86, acpi/irq: Teach acpi_get_override_irq to take a gsi not an isa_irq
x86, acpi/irq: Introduce apci_isa_irq_to_gsi
Now that the generic irq layer is performing the exact same remapping as
io_apic_renumber_irq we can kill this weird es7000 specific function.
LKML-Reference: <1269936436-7039-15-git-send-email-ebiederm@xmission.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
ACPI irq source overrides are allowed for the 16 isa irqs and are
allowed to map any gsi to any isa irq. A few motherboards have been
seen to take advantage of this and put the isa irqs on the 2nd or
3rd ioapic. This causes some problems, most notably the fact
that we can not use any gsi < 16.
To correct this move the gsis that are not isa irqs and have
a gsi number < 16 into the linux irq space just past gsi_end.
This is what the es7000 platform is doing today. Moving only the
low 16 gsis above the rest of the gsi's only penalizes weird
platforms, leaving sane acpi implementations with a 1-1 mapping
of gsis and irqs.
LKML-Reference: <1269936436-7039-14-git-send-email-ebiederm@xmission.com>
Use the global gsi_end value now that all ioapics have
valid gsi numbers instead of a combination of acpi_probe_gsi
and walking all of the ioapics and couting their number of
entries by hand if acpi_probe_gsi gave us an answer we did
not like.
LKML-Reference: <1269936436-7039-13-git-send-email-ebiederm@xmission.com>
Now that all ioapics have valid gsi_base values use this to
accellerate pin_2_irq. In the case of acpi this also ensures
that pin_2_irq will compute the same irq value for an ioapic
pin as acpi will.
LKML-Reference: <1269936436-7039-12-git-send-email-ebiederm@xmission.com>
Now that all ioapic registration happens in mp_register_ioapic we can
move the calculation of nr_ioapic_registers there from enable_IO_APIC.
The number of ioapic registers is already calucated in mp_register_ioapic
so all that really needs to be done is to save the caluclated value
in nr_ioapic_registers.
LKML-Reference: <1269936436-7039-11-git-send-email-ebiederm@xmission.com>
Add the global variable gsi_end and teach mp_register_ioapic
to keep it uptodate as we add more ioapics into the system.
ioapics can only be added early in boot so the code that
runs later can treat gsi_end as a constant.
Remove the have hacks in sfi.c to second guess mp_register_ioapic
by keeping t's own running total of how many gsi's have been seen,
and instead use the gsi_end.
LKML-Reference: <1269936436-7039-9-git-send-email-ebiederm@xmission.com>
This patches fixes the types of gsi_base and gsi_end values in
struct mp_ioapic_gsi, and the gsi parameter of mp_find_ioapic
A gsi is cannonically a u32, not an int.
LKML-Reference: <1269936436-7039-8-git-send-email-ebiederm@xmission.com>
io_apic_redir_entries has a huge conceptual bug. It returns the maximum
redirection entry not the number of redirection entries. Which simply
does not match what the name of the function. This just caught me
and it caught Feng Tang, and Len Brown when they wrote sfi_parse_ioapic.
Modify io_apic_redir_entries to actually return the number of redirection
entries, and fix the callers so that they properly handle receiving the
number of the number of redirection table entries, instead of the
number of redirection table entries less one.
While the usage in sfi.c does not show up in this patch it is fixed
by virtue of the fact that io_apic_redir_entries now has the semantics
sfi_parse_ioapic most reasonably expects.
LKML-Reference: <1269936436-7039-7-git-send-email-ebiederm@xmission.com>
In perverse acpi implementations the isa irqs are not identity mapped
to the first 16 gsi. Furthermore at least the extended interrupt
resource capability may return gsi's and not isa irqs. So since
what we get from acpi is a gsi teach acpi_get_overrride_irq to
operate on a gsi instead of an isa_irq.
LKML-Reference: <1269936436-7039-2-git-send-email-ebiederm@xmission.com>
Upstream PV guests fail to boot because of a NULL pointer in
irq_force_complete_move(). It is possible that xen guests have
irq_desc->chip_data = NULL.
Test for NULL chip_data pointer before attempting to complete an irq move.
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
LKML-Reference: <20100427152434.16193.49104.sendpatchset@prarit.bos.redhat.com>
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: <stable@kernel.org> [2.6.33]
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Ingo Molnar reported that with the recent changes of not
statically blocking IRQ0_VECTOR..IRQ15_VECTOR's on all the
cpu's, broke an AMD platform (with Nvidia chipset) boot when
"noapic" boot option is used.
On this platform, legacy PIC interrupts are getting delivered to
all the cpu's instead of just the boot cpu. Thus not
initializing the vector to irq mapping for the legacy irq's
resulted in not handling certain interrupts causing boot hang.
Fix this by initializing the vector to irq mapping on all the
logical cpu's, if the legacy IRQ is handled by the legacy PIC.
Reported-by: Ingo Molnar <mingo@elte.hu>
[ -v2: io-apic-enabled improvement ]
Acked-by: Yinghai Lu <yinghai@kernel.org>
Cc: Eric W. Biederman <ebiederm@xmission.com>
LKML-Reference: <1268692386.3296.43.camel@sbs-t61.sc.intel.com>
* 'x86-mrst-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (30 commits)
x86, mrst: Fix whitespace breakage in apb_timer.c
x86, mrst: Fix APB timer per cpu clockevent
x86, mrst: Remove X86_MRST dependency on PCI_IOAPIC
x86, olpc: Use pci subarch init for OLPC
x86, pci: Add arch_init to x86_init abstraction
x86, mrst: Add Kconfig dependencies for Moorestown
x86, pci: Exclude Moorestown PCI code if CONFIG_X86_MRST=n
x86, numaq: Make CONFIG_X86_NUMAQ depend on CONFIG_PCI
x86, pci: Add sanity check for PCI fixed bar probing
x86, legacy_irq: Remove duplicate vector assigment
x86, legacy_irq: Remove left over nr_legacy_irqs
x86, mrst: Platform clock setup code
x86, apbt: Moorestown APB system timer driver
x86, mrst: Add vrtc platform data setup code
x86, mrst: Add platform timer info parsing code
x86, mrst: Fill in PCI functions in x86_init layer
x86, mrst: Add dummy legacy pic to platform setup
x86/PCI: Moorestown PCI support
x86, ioapic: Add dummy ioapic functions
x86, ioapic: Early enable ioapic for timer irq
Fixed up semantic conflict of new clocksources due to commit
17622339af25 ("clocksource: add argument to resume callback").
* 'x86-apic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (25 commits)
x86: Fix out of order of gsi
x86: apic: Fix mismerge, add arch_probe_nr_irqs() again
x86, irq: Keep chip_data in create_irq_nr and destroy_irq
xen: Remove unnecessary arch specific xen irq functions.
smp: Use nr_cpus= to set nr_cpu_ids early
x86, irq: Remove arch_probe_nr_irqs
sparseirq: Use radix_tree instead of ptrs array
sparseirq: Change irq_desc_ptrs to static
init: Move radix_tree_init() early
irq: Remove unnecessary bootmem code
x86: Add iMac9,1 to pci_reboot_dmi_table
x86: Convert i8259_lock to raw_spinlock
x86: Convert nmi_lock to raw_spinlock
x86: Convert ioapic_lock and vector_lock to raw_spinlock
x86: Avoid race condition in pci_enable_msix()
x86: Fix SCI on IOAPIC != 0
x86, ia32_aout: do not kill argument mapping
x86, irq: Move __setup_vector_irq() before the first irq enable in cpu online path
x86, irq: Update the vector domain for legacy irqs handled by io-apic
x86, irq: Don't block IRQ0_VECTOR..IRQ15_VECTOR's on all cpu's
Iranna D Ankad reported that IBM x3950 systems have boot
problems after this commit:
| commit b9c61b70075c87a8612624736faf4a2de5b1ed30
| x86/pci: update pirq_enable_irq() to setup io apic routing
The problem is that with the patch, the machine freezes when
console=ttyS0,... kernel serial parameter is passed.
It seem to freeze at DVD initialization and the whole problem
seem to be DVD/pata related, but somehow exposed through the
serial parameter.
Such apic problems can expose really weird behavior:
ACPI: IOAPIC (id[0x10] address[0xfecff000] gsi_base[0])
IOAPIC[0]: apic_id 16, version 0, address 0xfecff000, GSI 0-2
ACPI: IOAPIC (id[0x0f] address[0xfec00000] gsi_base[3])
IOAPIC[1]: apic_id 15, version 0, address 0xfec00000, GSI 3-38
ACPI: IOAPIC (id[0x0e] address[0xfec01000] gsi_base[39])
IOAPIC[2]: apic_id 14, version 0, address 0xfec01000, GSI 39-74
ACPI: INT_SRC_OVR (bus 0 bus_irq 1 global_irq 4 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 5 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 3 global_irq 6 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 4 global_irq 7 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 6 global_irq 9 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 7 global_irq 10 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 8 global_irq 11 low edge)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 12 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 12 global_irq 15 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 13 global_irq 16 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 17 low edge)
ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 18 dfl dfl)
It turns out that the system has three io apic controllers, but
boot ioapic routing is in the second one, and that gsi_base is
not 0 - it is using a bunch of INT_SRC_OVR...
So these recent changes:
1. one set routing for first io apic controller
2. assume irq = gsi
... will break that system.
So try to remap those gsis, need to seperate boot_ioapic_idx
detection out of enable_IO_APIC() and call them early.
So introduce boot_ioapic_idx, and remap_ioapic_gsi()...
-v2: shift gsi with delta instead of gsi_base of boot_ioapic_idx
-v3: double check with find_isa_irq_apic(0, mp_INT) to get right
boot_ioapic_idx
-v4: nr_legacy_irqs
-v5: add print out for boot_ioapic_idx, and also make it could be
applied for current kernel and previous kernel
-v6: add bus_irq, in acpi_sci_ioapic_setup, so can get overwride
for sci right mapping...
-v7: looks like pnpacpi get irq instead of gsi, so need to revert
them back...
-v8: split into two patches
-v9: according to Eric, use fixed 16 for shifting instead of remap
-v10: still need to touch rsparser.c
-v11: just revert back to way Eric suggest...
anyway the ioapic in first ioapic is blocked by second...
-v12: two patches, this one will add more loop but check apic_id and irq > 16
Reported-by: Iranna D Ankad <iranna.ankad@in.ibm.com>
Bisected-by: Iranna D Ankad <iranna.ankad@in.ibm.com>
Tested-by: Gary Hade <garyhade@us.ibm.com>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: Thomas Renninger <trenn@suse.de>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: len.brown@intel.com
LKML-Reference: <4B8A321A.1000008@kernel.org>
Merge commit aef55d4922 mis-merged io_apic.c so we lost the
arch_probe_nr_irqs() method.
This caused subtle boot breakages (udev confusion likely
due to missing drivers) with certain configs.
Cc: Yinghai Lu <yinghai@kernel.org>
LKML-Reference: <20100207210250.GB8256@jenkins.home.ifup.org>
Remove duplicated cfg[i].vector assignment.
LKML-Reference: <4B8493A0.6080501@kernel.org>
nr_legacy_irqs and its ilk have moved to legacy_pic.
-v2: there is one in ioapic_.c
Singed-off-by: Yinghai Lu <yinghai@kernel.org>
LKML-Reference: <4B84AAC4.2020204@kernel.org>
Moorestown platform needs apic ready early for the system timer irq
which is delievered via ioapic. Should not impact other platforms.
In the longer term, once ioapic setup is moved before late time init,
we will not need this patch to do early apic enabling.
Signed-off-by: Jacob Pan <jacob.jun.pan@intel.com>
LKML-Reference: <43F901BD926A4E43B106BF17856F07559FB80D07@orsmsx508.amr.corp.intel.com>
arch/x86/kernel/apic/io_apic.c
Merge reason:
Conflicts in arch/x86/kernel/apic/io_apic.c
Resolved Conflicts:
Merge reason: conflict in arch/x86/kernel/apic/io_apic.c
Resolved Conflicts:
The ioapic_disable_legacy() call is no longer needed for platforms do
not have legacy pic. the legacy pic abstraction has taken care it
automatically.
This patch also initialize irq-related static variables based on
information obtained from legacy_pic.
LKML-Reference: <43F901BD926A4E43B106BF17856F0755A30A7660@orsmsx508.amr.corp.intel.com>
This patch replaces legacy PIC-related global variable and functions
with the new legacy_pic abstraction.
LKML-Reference: <43F901BD926A4E43B106BF17856F07559FB80D04@orsmsx508.amr.corp.intel.com>
Since we already track the number of legacy vectors by nr_legacy_irqs, we
can avoid use static vector allocations -- we can use dynamic one.
Signed-off-by: Alek Du <alek.du@intel.com>
LKML-Reference: <43F901BD926A4E43B106BF17856F07559FB80D01@orsmsx508.amr.corp.intel.com>
Version 4: use get_irq_chip_data() in destroy_irq() to get rid of some
local vars.
When two drivers are setting up MSI-X at the same time via
pci_enable_msix() there is a race. See this dmesg excerpt:
[ 85.170610] ixgbe 0000:02:00.1: irq 97 for MSI/MSI-X
[ 85.170611] alloc irq_desc for 99 on node -1
[ 85.170613] igb 0000:08:00.1: irq 98 for MSI/MSI-X
[ 85.170614] alloc kstat_irqs on node -1
[ 85.170616] alloc irq_2_iommu on node -1
[ 85.170617] alloc irq_desc for 100 on node -1
[ 85.170619] alloc kstat_irqs on node -1
[ 85.170621] alloc irq_2_iommu on node -1
[ 85.170625] ixgbe 0000:02:00.1: irq 99 for MSI/MSI-X
[ 85.170626] alloc irq_desc for 101 on node -1
[ 85.170628] igb 0000:08:00.1: irq 100 for MSI/MSI-X
[ 85.170630] alloc kstat_irqs on node -1
[ 85.170631] alloc irq_2_iommu on node -1
[ 85.170635] alloc irq_desc for 102 on node -1
[ 85.170636] alloc kstat_irqs on node -1
[ 85.170639] alloc irq_2_iommu on node -1
[ 85.170646] BUG: unable to handle kernel NULL pointer dereference
at 0000000000000088
As you can see igb and ixgbe are both alternating on create_irq_nr()
via pci_enable_msix() in their probe function.
ixgbe: While looping through irq_desc_ptrs[] via create_irq_nr() ixgbe
choses irq_desc_ptrs[102] and exits the loop, drops vector_lock and
calls dynamic_irq_init. Then it sets irq_desc_ptrs[102]->chip_data =
NULL via dynamic_irq_init().
igb: Grabs the vector_lock now and starts looping over irq_desc_ptrs[]
via create_irq_nr(). It gets to irq_desc_ptrs[102] and does this:
cfg_new = irq_desc_ptrs[102]->chip_data;
if (cfg_new->vector != 0)
continue;
This hits the NULL deref.
Another possible race exists via pci_disable_msix() in a driver or in
the number of error paths that call free_msi_irqs():
destroy_irq()
dynamic_irq_cleanup() which sets desc->chip_data = NULL
...race window...
desc->chip_data = cfg;
Remove the save and restore code for cfg in create_irq_nr() and
destroy_irq() and take the desc->lock when checking the irq_cfg.
Reported-and-analyzed-by: Brandon Philips <bphilips@suse.de>
Signed-off-by: Brandon Phiilps <bphilips@suse.de>
So keep nr_irqs == NR_IRQS. With radix trees is matters less.
LKML-Reference: <1265793639-15071-33-git-send-email-yinghai@kernel.org>
Keep chip_data in create_irq_nr and destroy_irq.
at 0000000000000088
continue;
destroy_irq()
...race window...
LKML-Reference: <1265793639-15071-3-git-send-email-yinghai@kernel.org>
Signed-off-by: Brandon Phililps <bphilips@suse.de>
Thomas Renninger <trenn@suse.de> reported on IBM x3330
booting a latest kernel on this machine results in:
PCI: PCI BIOS revision 2.10 entry at 0xfd61c, last bus=1
PCI: Using configuration type 1 for base access bio: create slab <bio-0> at 0
ACPI: SCI (IRQ30) allocation failed
ACPI Exception: AE_NOT_ACQUIRED, Unable to install System Control Interrupt handler (20090903/evevent-161)
ACPI: Unable to start the ACPI Interpreter
Later all kind of devices fail...
and bisect it down to this commit:
it turns out we need to set irq routing for the sci on ioapic1 early.
-v2: make it work without sparseirq too.
-v3: fix checkpatch.pl warning, and cc to stable
Reported-by: Thomas Renninger <trenn@suse.de>
Bisected-by: Thomas Renninger <trenn@suse.de>
Tested-by: Thomas Renninger <trenn@suse.de>
LKML-Reference: <1265793639-15071-2-git-send-email-yinghai@kernel.org>
Signed-off-by: Frans Pop <elendil@planet.nl>
Cc: Avi Kivity <avi@redhat.com>
Cc: x86@kernel.org
LKML-Reference: <1265478443-31072-10-git-send-email-elendil@planet.nl>
[ Left out the KVM bits. ]
online path
Lowest priority delivery of logical flat mode is broken on some systems,
such that even when IO-APIC RTE says deliver the interrupt to a particular CPU,
interrupt subsystem delivers the interrupt to totally different CPU.
For example, this behavior was observed on a P4 based system with SiS chipset
which was reported by Li Zefan. We have been handling this kind of behavior by
making sure that in logical flat mode, we assign the same vector to irq
mappings on all the 8 possible logical cpu's.
But we have been doing this initial assignment (__setup_vector_irq()) a little
late (before which interrupts were already enabled for a short duration).
Move the __setup_vector_irq() before the first irq enable point in the
cpu online path to avoid the issue of not handling some interrupts that
wrongly hit the cpu which is still coming online.
LKML-Reference: <20100129194330.283696385@sbs-t61.sc.intel.com>
Tested-by: Li Zefan <lizf@cn.fujitsu.com>
In the recent change of not reserving IRQ0_VECTOR..IRQ15_VECTOR's on all
cpu's, we start with irq 0..15 getting directed to (and handled on) cpu-0.
In the logical flat mode, once the AP's are online (and before irqbalance
comes into picture), kernel intends to handle these IRQ's on any cpu (as the
logical flat mode allows to specify multiple cpu's for the irq destination and
the chipset based routing can deliver to the interrupt to any one of
the specified cpu's). This was broken with our recent change, which was ending
up using only cpu 0 as the destination, even when the kernel was specifying to
use all online cpu's for the logical flat mode case.
Fix this by updating vector allocation domain (cfg->domain) for legacy irqs,
when the IO-APIC handles them.
LKML-Reference: <20100129194330.207790269@sbs-t61.sc.intel.com>
Currently IRQ0..IRQ15 are assigned to IRQ0_VECTOR..IRQ15_VECTOR's on
all the cpu's.
If these IRQ's are handled by legacy pic controller, then the kernel
handles them only on cpu 0. So there is no need to block this vector
space on all cpu's.
Similarly if these IRQ's are handled by IO-APIC, then the IRQ affinity
will determine on which cpu's we need allocate the vector resource for
that particular IRQ. This can be done dynamically and here also there
is no need to block 16 vectors for IRQ0..IRQ15 on all cpu's.
Fix this by initially assigning IRQ0..IRQ15 to IRQ0_VECTOR..IRQ15_VECTOR's only
on cpu 0. If the legacy controllers like pic handles these irq's, then
this configuration will be fixed. If more modern controllers like IO-APIC
handle these IRQ's, then we start with this configuration and as IRQ's
migrate, vectors (/and cpu's) associated with these IRQ's change dynamically.
This will freeup the block of 16 vectors on other cpu's which don't handle
IRQ0..IRQ15, which can now be used for other IRQ's that the particular cpu
handle.
[ hpa: this also an architectural cleanup for future legacy-PIC-free
configurations. ]
[ hpa: fixed typo NR_LEGACY_IRQS -> NR_IRQS_LEGACY ]
LKML-Reference: <1263932453.2814.52.camel@sbs-t61.sc.intel.com>
After talking to some more folks inside intel (Peter Anvin, Asit Mallick),
the safest option (for future compatibility etc) seen was to use vector 0x20
for IRQ_MOVE_CLEANUP_VECTOR instead of using vector 0x1f (which is documented as
reserved vector in the Intel IA32 manuals).
Also we don't need to reserve the entire privilege level (all 16 vectors in
the priority bucket that IRQ_MOVE_CLEANUP_VECTOR falls into), as the
x86 architecture (section 10.9.3 in SDM Vol3a) specifies that with in the
priority level, the higher the vector number the higher the priority.
And hence we don't need to reserve the complete priority level 0x20-0x2f for
the IRQ migration cleanup logic.
So change the IRQ_MOVE_CLEANUP_VECTOR to 0x20 and allow 0x21-0x2f to be used
for device interrupts. 0x30-0x3f will be used for ISA interrupts (these
also can be migrated in the context of IOAPIC and hence need to be at a higher
priority level than IRQ_MOVE_CLEANUP_VECTOR).
LKML-Reference: <20100114002118.521826763@sbs-t61.sc.intel.com>
Cc: Maciej W. Rozycki <macro@linux-mips.org>
With the recent irq migration fixes (post 2.6.32), Gary Hade has noticed
"No IRQ handler for vector" messages during the 2.6.33-rc1 kernel boot on IBM
AMD platforms and root caused the issue to this commit:
> commit 23359a88e7eca3c4f402562b102f23014db3c2aa
> Author: Suresh Siddha <suresh.b.siddha@intel.com>
> Date: Mon Oct 26 14:24:33 2009 -0800
> x86: Remove move_cleanup_count from irq_cfg
As part of this patch, we have removed the move_cleanup_count check
in smp_irq_move_cleanup_interrupt(). With this change, we can run into a
situation where an irq cleanup interrupt on a cpu can cleanup the vector
mappings associated with multiple irqs, of which one of the irq's migration
might be still in progress. As such when that irq hits the old cpu, we get
the "No IRQ handler" messages.
Fix this by checking for the irq_cfg's move_in_progress and if the move
is still in progress delay the vector cleanup to another irq cleanup
interrupt request (which will happen when the irq starts arriving at the
new cpu destination).
Reported-and-tested-by: Gary Hade <garyhade@us.ibm.com>
LKML-Reference: <1262804191.2732.7.camel@sbs-t61.sc.intel.com>
We want to use a vector-assignment sequence that avoids stumbling onto
0x80 earlier in the sequence, in order to improve the spread of
vectors across priority levels on machines with a small number of
interrupt sources. Right now, this is done by simply making the first
vector (0x31 or 0x41) completely unusable. This is unnecessary; all
we need is to start assignment at a +1 offset, we don't actually need
to prohibit the usage of this vector once we have wrapped around.
LKML-Reference: <4B426550.6000209@kernel.org>
I have a system with lots of igb and ixgbe, when iov/vf are
enabled for them, we hit the limit of 3064.
when system has 20 pcie installed, and one card has 2
functions, and one function needs 64 msi-x,
may need 20 * 2 * 64 = 2560 for msi-x
but if iov and vf are enabled
may need 20 * 2 * 64 * 3 = 7680 for msi-x
assume system with 5 ioapic, nr_irqs_gsi will be 120.
NR_CPUS = 512, and nr_cpu_ids = 128
will have NR_IRQS = 256 + 512 * 64 = 33024
will have nr_irqs = 120 + 8 * 128 + 120 * 64 = 8824
When SPARSE_IRQ is not set, there is no increase with kernel data
size.
when NR_CPUS=128, and SPARSE_IRQ is set:
21837444 4216564 12480736 38534744 24bfe58 vmlinux.before
21837442 4216580 12480736 38534758 24bfe66 vmlinux.after
when NR_CPUS=4096, and SPARSE_IRQ is set
21878619 5610244 13415392 40904255 270263f vmlinux.before
21878617 5610244 13415392 40904253 270263d vmlinux.after
LKML-Reference: <4B398ECD.1080506@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/joro/linux-2.6-iommu into x86/urgent
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, irq: Allow 0xff for /proc/irq/[n]/smp_affinity on an 8-cpu system
Makefile: Unexport LC_ALL instead of clearing it
x86: Fix objdump version check in arch/x86/tools/chkobjdump.awk
x86: Reenable TSC sync check at boot, even with NONSTOP_TSC
x86: Don't use POSIX character classes in gen-insn-attr-x86.awk
Makefile: set LC_CTYPE, LC_COLLATE, LC_NUMERIC to C
x86: Increase MAX_EARLY_RES; insufficient on 32-bit NUMA
x86: Fix checking of SRAT when node 0 ram is not from 0
x86, cpuid: Add "volatile" to asm in native_cpuid()
x86, msr: msrs_alloc/free for CONFIG_SMP=n
x86, amd: Get multi-node CPU info from NodeId MSR instead of PCI config space
x86: Add IA32_TSC_AUX MSR and use it
x86, msr/cpuid: Register enough minors for the MSR and CPUID drivers
initramfs: add missing decompressor error check
bzip2: Add missing checks for malloc returning NULL
bzip2/lzma/gzip: pre-boot malloc doesn't return NULL on failure
John Blackwood reported:
> on an older Dell PowerEdge 6650 system with 8 cpus (4 are hyper-threaded),
> and 32 bit (x86) kernel, once you change the irq smp_affinity of an irq
> to be less than all cpus in the system, you can never change really the
> irq smp_affinity back to be all cpus in the system (0xff) again,
> even though no error status is returned on the "/bin/echo ff >
> /proc/irq/[n]/smp_affinity" operation.
> This is due to that fact that BAD_APICID has the same value as
> all cpus (0xff) on 32bit kernels, and thus the value returned from
> set_desc_affinity() via the cpu_mask_to_apicid_and() function is treated
> as a failure in set_ioapic_affinity_irq_desc(), and no affinity changes
> are made.
set_desc_affinity() is already checking if the incoming cpu mask
intersects with the cpu online mask or not. So there is no need
for the apic op cpu_mask_to_apicid_and() to check again
and return BAD_APICID.
Remove the BAD_APICID return value from cpu_mask_to_apicid_and()
and also fix set_desc_affinity() to return -1 instead of using BAD_APICID
to represent error conditions (as cpu_mask_to_apicid_and() can return
logical or physical apicid values and BAD_APICID is really to represent
bad physical apic id).
Reported-by: John Blackwood <john.blackwood@ccur.com>
Root-caused-by: John Blackwood <john.blackwood@ccur.com>
LKML-Reference: <1261103386.2535.409.camel@sbs-t61>
Convert locks which cannot be sleeping locks in preempt-rt to
raw_spinlocks.
Acked-by: Peter Zijlstra <peterz@infradead.org>
