path: root/arch/x86/kernel/apic/x2apic_uv_x.c
2011-11-11x86: uv2: Workaround for UV2 Hub bug (system global address format)Jack Steiner
commit 6a469e4665bc158599de55d64388861d0a9f10f4 upstream. This is a workaround for a UV2 hub bug that affects the format of system global addresses. The GRU API for UV2 was inadvertently broken by a hardware change. The format of the physical address used for TLB dropins and for addresses used with instructions running in unmapped mode has changed. This change was not documented and became apparent only when diags failed running on system simulators. For UV1, TLB and GRU instruction physical addresses are identical to socket physical addresses (although high NASID bits must be OR'ed into the address). For UV2, socket physical addresses need to be converted. The NODE portion of the physical address needs to be shifted so that the low bit is in bit 39 or bit 40, depending on an MMR value. It is not yet clear if this bug will be fixed in a silicon respin. If it is fixed, the hub revision will be incremented & the workaround disabled. Signed-off-by: Jack Steiner <steiner@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-05x86, UV: Remove UV delay in starting slave cpusJack Steiner
Delete the 10 msec delay between the INIT and SIPI when starting slave cpus. I can find no requirement for this delay. BIOS also has similar code sequences without the delay. Removing the delay reduces boot time by 40 sec. Every bit helps. Signed-off-by: Jack Steiner <steiner@sgi.com> Cc: <stable@kernel.org> Link: http://lkml.kernel.org/r/20110805140900.GA6774@sgi.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-14x86/uv/x2apic: update for change in pci bridge handling.Dave Airlie
When I added 3448a19da479b6bd1e28e2a2be9fa16c6a6feb39 I forgot about the special uv handling code for this, so this patch fixes it up. Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Acked-by: Ingo Molnar Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-05-25x86, UV: Add support for SGI UV2 hub chipJack Steiner
This patch adds support for a new version of the SGI UV hub chip. The hub chip is the node controller that connects multiple blades into a larger coherent SSI. For the most part, UV2 is compatible with UV1. The majority of the changes are in the addresses of MMRs and in a few cases, the contents of MMRs. These changes are the result in changes in the system topology such as node configuration, processor types, maximum nodes, physical address sizes, etc. Signed-off-by: Jack Steiner <steiner@sgi.com> Link: http://lkml.kernel.org/r/20110511175028.GA18006@sgi.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-22x86, apic: Make apic drivers staticSuresh Siddha
Apic probe now looks at the apic drivers listed in the .apicdrivers section. Remove apic_probe[] and make each apic driver static. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Tested-by: Cyrill Gorcunov <gorcunov@openvz.org> Cc: steiner@sgi.com Cc: gorcunov@openvz.org Cc: yinghai@kernel.org Link: http://lkml.kernel.org/r/20110521005526.341718626@sbsiddha-MOBL3.sc.intel.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-22x86, apic: Introduce .apicdrivers section to find the list of apic driversSuresh Siddha
This will pave the way for each apic driver to be self-contained and eliminate the need for apic_probe[]. Order in which apic drivers are listed in the .apicdrivers section is important, as this determines the apic probe order. And this is enforced by the ordering of apic driver files in the Makefile and the macros apic_driver()/apic_drivers(). Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Tested-by: Cyrill Gorcunov <gorcunov@openvz.org> Cc: steiner@sgi.com Cc: gorcunov@openvz.org Cc: yinghai@kernel.org Link: http://lkml.kernel.org/r/20110521005526.068775085@sbsiddha-MOBL3.sc.intel.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-20x86, apic: Use probe routines to simplify apic selectionSuresh Siddha
Use the unused probe routine in the apic driver to finalize the apic model selection. This cleans up the default_setup_apic_routing() and this probe routine in future can also be used for doing any apic model specific initialisation. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Acked-by: Cyrill Gorcunov <gorcunov@openvz.org> Cc: steiner@sgi.com Cc: yinghai@kernel.org Link: http://lkml.kernel.org/r/20110519234637.247458931@sbsiddha-MOBL3.sc.intel.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-10x86, UV: Fix NMI handler for UV platformsJack Steiner
This fixes problems seen on UV systems handling NMIs from the node controller. I isolated the "dazed..." messages that I saw earlier to a bug in the BMC on our platform. It was sending NMIs w/o properly setting a register that indicated the source of NMI. So rather than _assuming_ any unhandled NMI came from the UV system maintenance console (SMC), add a check to verify that the SMC actually sent the NMI. Signed-off-by: Jack Steiner <steiner@sgi.com> Cc: gorcunov@gmail.com Cc: dzickus@redhat.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-31x86, UV: Fix kdump rebootCliff Wickman
After a crash dump on an SGI Altix UV system the crash kernel fails to cause a reboot. EFI mode is disabled in the kdump kernel, so only the reboot_type of BOOT_ACPI works. Signed-off-by: Cliff Wickman <cpw@sgi.com> Cc: rja@sgi.com LKML-Reference: <E1Q5Iuo-00013b-UK@eag09.americas.sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-29x86: Stop including <linux/delay.h> in two asm header filesJean Delvare
Stop including <linux/delay.h> in x86 header files which don't need it. This will let the compiler complain when this header is not included by source files when it should, so that contributors can fix the problem before building on other architectures starts to fail. Credits go to Geert for the idea. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: James E.J. Bottomley <James.Bottomley@suse.de> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> LKML-Reference: <20110325152014.297890ec@endymion.delvare> [ this also fixes an upstream build bug in drivers/media/rc/ite-cir.c ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-28x86: Replace apic->apicid_to_node() with ->x86_32_numa_cpu_node()Tejun Heo
apic->apicid_to_node() is 32bit specific apic operation which determines NUMA node for a CPU. Depending on the APIC implementation, it can be easier to determine NUMA node from either physical or logical apicid. Currently, ->apicid_to_node() takes @logical_apicid and calls hard_smp_processor_id() if the physical apicid is needed. This prevents NUMA mapping from being queried from a different CPU, which in turn makes it impossible to initialize NUMA mapping before SMP bringup. This patch replaces apic->apicid_to_node() with ->x86_32_numa_cpu_node() which takes @cpu, from which both logical and physical apicids can easily be determined. While at it, drop duplicate implementations from bigsmp_32 and summit_32, and use the default one. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Pekka Enberg <penberg@kernel.org> Cc: eric.dumazet@gmail.com Cc: yinghai@kernel.org Cc: brgerst@gmail.com Cc: gorcunov@gmail.com Cc: shaohui.zheng@intel.com Cc: rientjes@google.com LKML-Reference: <1295789862-25482-13-git-send-email-tj@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-28x86: Kill apic->cpu_to_logical_apicid()Tejun Heo
After the previous patch, apic->cpu_to_logical_apicid() is no longer used. Kill it. For apic types with custom cpu_to_logical_apicid() which is also used for other purposes, remove the function and modify its users to do the mapping directly. #ifdef's on CONFIG_SMP in es7000_32 and summit_32 are ignored during conversion as they are not used for UP kernels. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: eric.dumazet@gmail.com Cc: yinghai@kernel.org Cc: brgerst@gmail.com Cc: gorcunov@gmail.com Cc: penberg@kernel.org Cc: shaohui.zheng@intel.com Cc: rientjes@google.com LKML-Reference: <1295789862-25482-7-git-send-email-tj@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-11Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Fix Moorestown VRTC fixmap placement x86/gpio: Implement x86 gpio_to_irq convert function x86, UV: Fix APICID shift for Westmere processors x86: Use PCI method for enabling AMD extended config space before MSR method x86: tsc: Prevent delayed init if initial tsc calibration failed x86, lapic-timer: Increase the max_delta to 31 bits x86: Fix sparse non-ANSI function warnings in smpboot.c x86, numa: Fix CONFIG_DEBUG_PER_CPU_MAPS without NUMA emulation x86, AMD, PCI: Add AMD northbridge PCI device id for CPU families 12h and 14h x86, numa: Fix cpu to node mapping for sparse node ids x86, numa: Fake node-to-cpumask for NUMA emulation x86, numa: Fake apicid and pxm mappings for NUMA emulation x86, numa: Avoid compiling NUMA emulation functions without CONFIG_NUMA_EMU x86, numa: Reduce minimum fake node size to 32M Fix up trivial conflict in arch/x86/kernel/apic/x2apic_uv_x.c
2011-01-11Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (28 commits) perf session: Fix infinite loop in __perf_session__process_events perf evsel: Support perf_evsel__open(cpus > 1 && threads > 1) perf sched: Use PTHREAD_STACK_MIN to avoid pthread_attr_setstacksize() fail perf tools: Emit clearer message for sys_perf_event_open ENOENT return perf stat: better error message for unsupported events perf sched: Fix allocation result check perf, x86: P4 PMU - Fix unflagged overflows handling dynamic debug: Fix build issue with older gcc tracing: Fix TRACE_EVENT power tracepoint creation tracing: Fix preempt count leak tracepoint: Add __rcu annotation tracing: remove duplicate null-pointer check in skb tracepoint tracing/trivial: Add missing comma in TRACE_EVENT comment tracing: Include module.h in define_trace.h x86: Save rbp in pt_regs on irq entry x86, dumpstack: Fix unused variable warning x86, NMI: Clean-up default_do_nmi() x86, NMI: Allow NMI reason io port (0x61) to be processed on any CPU x86, NMI: Remove DIE_NMI_IPI x86, NMI: Add priorities to handlers ...
2011-01-11x86, UV: Fix APICID shift for Westmere processorsJack Steiner
Westmere processors use a different algorithm for assigning APICIDs on SGI UV systems. The location of the node number within the apicid is now a function of the processor type. Signed-off-by: Jack Steiner <steiner@sgi.com> LKML-Reference: <20110110195210.GA18737@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-09Merge branch 'tip/perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/urgent
2011-01-07Merge branch 'for-2.6.38' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (30 commits) gameport: use this_cpu_read instead of lookup x86: udelay: Use this_cpu_read to avoid address calculation x86: Use this_cpu_inc_return for nmi counter x86: Replace uses of current_cpu_data with this_cpu ops x86: Use this_cpu_ops to optimize code vmstat: User per cpu atomics to avoid interrupt disable / enable irq_work: Use per cpu atomics instead of regular atomics cpuops: Use cmpxchg for xchg to avoid lock semantics x86: this_cpu_cmpxchg and this_cpu_xchg operations percpu: Generic this_cpu_cmpxchg() and this_cpu_xchg support percpu,x86: relocate this_cpu_add_return() and friends connector: Use this_cpu operations xen: Use this_cpu_inc_return taskstats: Use this_cpu_ops random: Use this_cpu_inc_return fs: Use this_cpu_inc_return in buffer.c highmem: Use this_cpu_xx_return() operations vmstat: Use this_cpu_inc_return for vm statistics x86: Support for this_cpu_add, sub, dec, inc_return percpu: Generic support for this_cpu_add, sub, dec, inc_return ... Fixed up conflicts: in arch/x86/kernel/{apic/nmi.c, apic/x2apic_uv_x.c, process.c} as per Tejun.
2011-01-07x86: Convert some devices to use DIE_NMIUNKNOWNDon Zickus
They are a handful of places in the code that register a die_notifier as a catch all in case no claims the NMI. Unfortunately, they trigger on events like DIE_NMI and DIE_NMI_IPI, which depending on when they registered may collide with other handlers that have the ability to determine if the NMI is theirs or not. The function unknown_nmi_error() makes one last effort to walk the die_chain when no one else has claimed the NMI before spitting out messages that the NMI is unknown. This is a better spot for these devices to execute any code without colliding with the other handlers. The two drivers modified are only compiled on x86 arches I believe, so they shouldn't be affected by other arches that may not have DIE_NMIUNKNOWN defined. Signed-off-by: Don Zickus <dzickus@redhat.com> Cc: Russ Anderson <rja@sgi.com> Cc: Corey Minyard <minyard@acm.org> Cc: openipmi-developer@lists.sourceforge.net Cc: dann frazier <dannf@hp.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1294348732-15030-3-git-send-email-dzickus@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-30x86: Use this_cpu_ops to optimize codeTejun Heo
Go through x86 code and replace __get_cpu_var and get_cpu_var instances that refer to a scalar and are not used for address determinations. Cc: Yinghai Lu <yinghai@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-12-22x86, UV: Fix the effect of extra bits in the hub nodeid registerJack Steiner
UV systems can be partitioned into multiple independent SSIs. Large partitioned systems may have extra bits in the node_id register. These bits are used when the total memory on all SSIs exceeds 16TB. These extra bits need to be ignored when calculating x2apic_extra_bits. Signed-off-by: Jack Steiner <steiner@sgi.com> LKML-Reference: <20101130195926.972776133@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-22x86, UV: Add common uv_early_read_mmr() function for reading MMRsJack Steiner
Early in boot, reading MMRs from the UV hub controller require calls to early_ioremap()/early_iounmap(). Rather than duplicating code, add a common function to do the map/read/unmap. Signed-off-by: Jack Steiner <steiner@sgi.com> LKML-Reference: <20101130195926.834804371@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-18x86: UV: Address interrupt/IO port operation conflictDimitri Sivanich
This patch for SGI UV systems addresses a problem whereby interrupt transactions being looped back from a local IOH, through the hub to a local CPU can (erroneously) conflict with IO port operations and other transactions. To workaound this we set a high bit in the APIC IDs used for interrupts. This bit appears to be ignored by the sockets, but it avoids the conflict in the hub. Signed-off-by: Dimitri Sivanich <sivanich@sgi.com> LKML-Reference: <20101116222352.GA8155@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> ___ arch/x86/include/asm/uv/uv_hub.h | 4 ++++ arch/x86/include/asm/uv/uv_mmrs.h | 19 ++++++++++++++++++- arch/x86/kernel/apic/x2apic_uv_x.c | 25 +++++++++++++++++++++++-- arch/x86/platform/uv/tlb_uv.c | 2 +- arch/x86/platform/uv/uv_time.c | 4 +++- 5 files changed, 49 insertions(+), 5 deletions(-)
2010-11-10x86, UV: Update node controller MMRsJack Steiner
A new version of the SGI UV hub node controller is being developed. A few of the MMRs (control registers) that exist on the current hub no longer exist on the new hub. Fortunately, there are alternate MMRs that are are functionally equivalent and that exist on both hubs. This patch changes the UV code to use MMRs that exist in BOTH versions of the hub node controller. Signed-off-by: Jack Steiner <steiner@sgi.com> LKML-Reference: <20101106204056.GA27584@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-28x86, uv: More Westmere support on SGI UVRuss Anderson
Enable Westmere support for all APIC modes on SGI UV. Signed-off-by: Russ Anderson <rja@sgi.com> LKML-Reference: <20101028224132.GB15804@sgi.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-10-26x86, uv: Enable Westmere support on SGI UVRuss Anderson
Enable Westmere support on SGI UV. The UV initialization code is dependent on the APICID bits. Westmere-EX uses different APIC bit mapping than Nehalem-EX. This code reads the apic shift value from a UV MMR to do the proper bit decoding to determint the pnode. Signed-off-by: Russ Anderson <rja@sgi.com> LKML-Reference: <20101026212728.GB15071@sgi.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-09-10x86, UV: Fix initialization of max_pnodeJack Steiner
Fix calculation of "max_pnode" for systems where the the highest blade has neither cpus or memory. (And, yes, although rare this does occur). Signed-off-by: Jack Steiner <steiner@sgi.com> LKML-Reference: <20100910150808.GA19802@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-07-21x86, UV: Make kdump avoid stack dumpsCliff Wickman
UV NMI callback's should not write stack dumps when a kdump is to be written. When invoking the crash kernel to write a dump, kdump_nmi_shootdown_cpus() uses NMI's to get all the cpu's to save their register context and halt. But the NMI interrupt handler runs a callback list. This patch sets a flag to prevent any of those callbacks from interfering with the halt of the cpu. For UV, which currently has the only callback to which this is relevant, the uv_handle_nmi() callback should not do dumping of stacks. The 'in_crash_kexec' flag is defined as an extern in kdebug.h firstly because x2apic_uv_x.c includes it. Secondly because some future callback might need the flag to know that it should not enter the debugger. (Such a scenario was in fact present in the 2.6.32 kernel, SuSE distribution, where a call to kdb needed to be avoided.) Signed-off-by: Cliff Wickman <cpw@sgi.com> LKML-Reference: <E1ObLvt-0005UZ-Va@eag09.americas.sgi.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-05-18Merge branch 'x86-uv-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-uv-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, UV: uv_irq.c: Fix all sparse warnings x86, UV: Improve BAU performance and error recovery x86, UV: Delete unneeded boot messages x86, UV: Clean up UV headers for MMR definitions
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-17x86, UV: Delete unneeded boot messagesJack Steiner
SGI:UV: Delete extra boot messages that describe the system topology. These messages are no longer useful. Signed-off-by: Jack Steiner <steiner@sgi.com> LKML-Reference: <20100317154038.GA29346@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-13Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, k8 nb: Fix boot crash: enable k8_northbridges unconditionally on AMD systems x86, UV: Fix target_cpus() in x2apic_uv_x.c x86: Reduce per cpu warning boot up messages x86: Reduce per cpu MCA boot up messages x86_64, cpa: Don't work hard in preserving kernel 2M mappings when using 4K already
2010-03-12x86, UV: Fix target_cpus() in x2apic_uv_x.cJack Steiner
target_cpu() should initially target all cpus, not just cpu 0. Otherwise systems with lots of disks can exhaust the interrupt vectors on cpu 0 if a large number of disks are discovered before the irq balancer is running. Note: UV code only... Signed-off-by: Jack Steiner <steiner@sgi.com> LKML-Reference: <20100311184328.GA21433@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-28Merge branch 'x86-uv-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-uv-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, uv: Remove recursion in uv_heartbeat_enable() x86, uv: uv_global_gru_mmr_address() macro fix x86, uv: Add serial number parameter to uv_bios_get_sn_info()
2010-02-27x86: Enable NMI on all cpus on UVRuss Anderson
Enable NMI on all cpus in UV system and add an NMI handler to dump_stack on each cpu. By default on x86 all the cpus except the boot cpu have NMI masked off. This patch enables NMI on all cpus in UV system and adds an NMI handler to dump_stack on each cpu. This way if a system hangs we can NMI the machine and get a backtrace from all the cpus. Version 2: Use x86_platform driver mechanism for nmi init, per Ingo's suggestion. Version 3: Clean up Ingo's nits. Signed-off-by: Russ Anderson <rja@sgi.com> LKML-Reference: <20100226164912.GA24439@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-05x86, uv: Update UV arch to target Legacy VGA I/O correctly.Mike Travis
Add function to direct Legacy VGA I/O traffic to correct I/O Hub. Signed-off-by: Mike Travis <travis@sgi.com> LKML-Reference: <201002022238.o12McEbi018727@imap1.linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Robin Holt <holt@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: David Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-01-15x86, uv: Ensure hub revision set for all ACPI modes.Russ Anderson
Ensure that UV hub revision is set for all ACPI modes. Signed-off-by: Russ Anderson <rja@sgi.com> LKML-Reference: <20100115180908.GB7757@sgi.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-01-15x86, uv: Add function retrieving node controller revision numberJack Steiner
Add function for determining the revision id of the SGI UV node controller chip (HUB). This function is needed in a subsequent patch. Signed-off-by: Jack Steiner <steiner@sgi.com> LKML-Reference: <20100112210904.GA24546@sgi.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-01-13x86: SGI UV: Fix mapping of MMIO registersMike Travis
This fixes the problem of the initialization code not correctly mapping the entire MMIO space on a UV system. A side effect is the map_high() interface needed to be changed to accommodate different address and size shifts. Signed-off-by: Mike Travis <travis@sgi.com> Reviewed-by: Mike Habeck <habeck@sgi.com> Cc: <stable@kernel.org> Cc: Jack Steiner <steiner@sgi.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <4B479202.7080705@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-07x86, uv: Remove recursion in uv_heartbeat_enable()Roel Kluin
The recursion is not needed and does not improve readability. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> LKML-Reference: <4B45F13E.3040202@gmail.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-12-29x86: SGI UV: Fix writes to led registers on remote uv hubsMike Travis
The wrong address was being used to write the SCIR led regs on remote hubs. Also, there was an inconsistency between how BIOS and the kernel indexed these regs. Standardize on using the lower 6 bits of the APIC ID as the index. This patch fixes the problem of writing to an errant address to a cpu # >= 64. Signed-off-by: Mike Travis <travis@sgi.com> Reviewed-by: Jack Steiner <steiner@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: stable@kernel.org LKML-Reference: <4B3922F9.3060905@sgi.com> [ v2: fix a number of annoying checkpatch artifacts and whitespace noise ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-17x86, irq: Allow 0xff for /proc/irq/[n]/smp_affinity on an 8-cpu systemSuresh Siddha
John Blackwood reported: > on an older Dell PowerEdge 6650 system with 8 cpus (4 are hyper-threaded), > and 32 bit (x86) kernel, once you change the irq smp_affinity of an irq > to be less than all cpus in the system, you can never change really the > irq smp_affinity back to be all cpus in the system (0xff) again, > even though no error status is returned on the "/bin/echo ff > > /proc/irq/[n]/smp_affinity" operation. > > This is due to that fact that BAD_APICID has the same value as > all cpus (0xff) on 32bit kernels, and thus the value returned from > set_desc_affinity() via the cpu_mask_to_apicid_and() function is treated > as a failure in set_ioapic_affinity_irq_desc(), and no affinity changes > are made. set_desc_affinity() is already checking if the incoming cpu mask intersects with the cpu online mask or not. So there is no need for the apic op cpu_mask_to_apicid_and() to check again and return BAD_APICID. Remove the BAD_APICID return value from cpu_mask_to_apicid_and() and also fix set_desc_affinity() to return -1 instead of using BAD_APICID to represent error conditions (as cpu_mask_to_apicid_and() can return logical or physical apicid values and BAD_APICID is really to represent bad physical apic id). Reported-by: John Blackwood <john.blackwood@ccur.com> Root-caused-by: John Blackwood <john.blackwood@ccur.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <1261103386.2535.409.camel@sbs-t61> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-12-17x86, uv: Add serial number parameter to uv_bios_get_sn_info()Russ Anderson
Add system_serial_number to the information returned by uv_bios_get_sn_info() UV BIOS call. Signed-off-by: Russ Anderson <rja@sgi.com> LKML-Reference: <20091217165323.GA30774@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-12-08Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (36 commits) x86, mm: Correct the implementation of is_untracked_pat_range() x86/pat: Trivial: don't create debugfs for memtype if pat is disabled x86, mtrr: Fix sorting of mtrr after subtracting x86: Move find_smp_config() earlier and avoid bootmem usage x86, platform: Change is_untracked_pat_range() to bool; cleanup init x86: Change is_ISA_range() into an inline function x86, mm: is_untracked_pat_range() takes a normal semiclosed range x86, mm: Call is_untracked_pat_range() rather than is_ISA_range() x86: UV SGI: Don't track GRU space in PAT x86: SGI UV: Fix BAU initialization x86, numa: Use near(er) online node instead of roundrobin for NUMA x86, numa, bootmem: Only free bootmem on NUMA failure path x86: Change crash kernel to reserve via reserve_early() x86: Eliminate redundant/contradicting cache line size config options x86: When cleaning MTRRs, do not fold WP into UC x86: remove "extern" from function prototypes in <asm/proto.h> x86, mm: Report state of NX protections during boot x86, mm: Clean up and simplify NX enablement x86, pageattr: Make set_memory_(x|nx) aware of NX support x86, sleep: Always save the value of EFER ... Fix up conflicts (added both iommu_shutdown and is_untracked_pat_range) to 'struct x86_platform_ops') in arch/x86/include/asm/x86_init.h arch/x86/kernel/x86_init.c
2009-12-05Merge branch 'x86-apic-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-apic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (30 commits) x86, apic: Enable lapic nmi watchdog on AMD Family 11h x86: Remove unnecessary mdelay() from cpu_disable_common() x86, ioapic: Document another case when level irq is seen as an edge x86, ioapic: Fix the EOI register detection mechanism x86, io-apic: Move the effort of clearing remoteIRR explicitly before migrating the irq x86: SGI UV: Map low MMR ranges x86: apic: Print out SRAT table APIC id in hex x86: Re-get cfg_new in case reuse/move irq_desc x86: apic: Remove not needed #ifdef x86: io-apic: IO-APIC MMIO should not fail on resource insertion x86: Remove asm/apicnum.h x86: apic: Do not use stacked physid_mask_t x86, apic: Get rid of apicid_to_cpu_present assign on 64-bit x86, ioapic: Use snrpintf while set names for IO-APIC resourses x86, apic: Use PAGE_SIZE instead of numbers x86: Remove local_irq_enable()/local_irq_disable() in fixup_irqs() x86: Use EOI register in io-apic on intel platforms x86: Force irq complete move during cpu offline x86: Remove move_cleanup_count from irq_cfg x86, intr-remap: Avoid irq_chip mask/unmask in fixup_irqs() for intr-remapping ...
2009-11-30x86, mm: Correct the implementation of is_untracked_pat_range()H. Peter Anvin
The semantics the PAT code expect of is_untracked_pat_range() is "is this range completely contained inside the untracked region." This means that checkin 8a27138924f64d2f30c1022f909f74480046bc3f was technically wrong, because the implementation needlessly confusing. The sane interface is for it to take a semiclosed range like just about everything else (as evidenced by the sheer number of "- 1"'s removed by that patch) so change the actual implementation to match. Reported-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jack Steiner <steiner@sgi.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com> LKML-Reference: <20091119202341.GA4420@sgi.com>
2009-11-26x86: SGI UV: Map low MMR rangesJack Steiner
Explicitly mmap the UV chipset MMR address ranges used to access blade-local registers. Although these same MMRs are also mmaped at higher addresses, the low range is more convenient when accessing blade-local registers. The low range addresses always alias to the local blade regardless of the blade id. Signed-off-by: Jack Steiner <steiner@sgi.com> LKML-Reference: <20091125162018.GA25445@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-23x86, platform: Change is_untracked_pat_range() to bool; cleanup initH. Peter Anvin
- Change is_untracked_pat_range() to return bool. - Clean up the initialization of is_untracked_pat_range() -- by default, we simply point it at is_ISA_range() directly. - Move is_untracked_pat_range to the end of struct x86_platform, since it is the newest field. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Jack Steiner <steiner@sgi.com> LKML-Reference: <20091119202341.GA4420@sgi.com>
2009-11-23x86: UV SGI: Don't track GRU space in PATJack Steiner
GRU space is always mapped as WB in the page table. There is no need to track the mappings in the PAT. This also eliminates the "freeing invalid memtype" messages when the GRU space is unmapped. Signed-off-by: Jack Steiner <steiner@sgi.com> LKML-Reference: <20091119202341.GA4420@sgi.com> [ v2: fix build failure ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-16x86, UV: Fix information in __uv_hub_info structureRobin Holt
A few parts of the uv_hub_info structure are initialized incorrectly. - n_val is being loaded with m_val. - gpa_mask is initialized with a bytes instead of an unsigned long. - Handle the case where none of the alias registers are used. Lastly I converted the bau over to using the uv_hub_info->m_val which is the correct value. Without this patch, booting a large configuration hits a problem where the upper bits of the gnode affect the pnode and the bau will not operate. Signed-off-by: Robin Holt <holt@sgi.com> Acked-by: Jack Steiner <steiner@sgi.com> Cc: Cliff Whickman <cpw@sgi.com> Cc: stable@kernel.org LKML-Reference: <20091015224946.396355000@alcatraz.americas.sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-18x86: SGI UV: Map MMIO-High memory rangeJack Steiner
UV depends on the MMRHI space being identity mapped. The patch: x86: Make 64-bit efi_ioremap use ioremap on MMIO regions changed this to make efi regions at a different address using ioremap. Add the identity mapping to uv_system_init. ( Note this code was previously present but was deleted when BIOS added the ranges to the EFI map - previous efi code identify mapped the ranges. ) Signed-off-by: Jack Steiner <steiner@sgi.com> LKML-Reference: <20090909154339.GA7946@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
