commit 8dca15e40889e5d5e9655b03ba79c26200f760ce upstream.
"[CPUFREQ] cpumask: avoid playing with cpus_allowed in speedstep-ich.c"
changed the code to mistakenly pass the current cpu as the "processor"
argument of speedstep_get_frequency(), whereas it should be the type of
the processor.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=14340
Based on a patch by Dave Mueller.
Acked-by: Dominik Brodowski <linux@brodo.de>
Reported-by: Dave Mueller <dave.mueller@gmx.ch>
Signed-off-by: Dave Jones <davej@redhat.com>
commit f0adb134d8dc9993a9998dc50845ec4f6ff4fadc upstream.
Fixes bugzilla #13780
Commit 5fd29d6ccbc98884569d6f3105aeca70858b3e0f ("printk: clean up
handling of log-levels and newlines") changed printk semantics. printk
lines with multiple KERN_<level> prefixes are no longer emitted as
before the patch.
<level> is now included in the output on each additional use.
Remove all uses of multiple KERN_<level>s in formats.
Provide support for family 0xf processors with 2 P-states
below the elevator voltage. Remove the checks that prevent
this configuration from being supported and increase the
transition voltage to prevent errors during the transition.
Signed-off-by: Mark Langsdorf <mark.langsdorf@amd.com>
arch/x86/kernel/cpu/cpufreq/powernow-k8.c
Remove all old-style cpumask operators, and cpumask_t.
Also: get rid of the unused define_siblings function.
Acked-by: Mark Langsdorf <mark.langsdorf@amd.com>
Tested-by: Mark Langsdorf <mark.langsdorf@amd.com>
cpumask: avoid playing with cpus_allowed in powernow-k8.c
It's generally a very bad idea to mug some process's cpumask: it could
legitimately and reasonably be changed by root, which could break us
(if done before our code) or them (if we restore the wrong value).
I did not replace powernowk8_target; it needs fixing, but it grabs a
mutex (so no smp_call_function_single here) but Mark points out it can
be called multiple times per second, so work_on_cpu is too heavy.
To: cpufreq@vger.kernel.org
arch/x86/kernel/cpu/cpufreq/speedstep-centrino.c
Impact: don't play with current's cpumask
Use rdmsr_on_cpu and wrmsr_on_cpu instead.
We use smp_call_function_single: this had the advantage of being more
efficient, too.
Cc: Dominik Brodowski <linux@brodo.de>
Make powernowk8_get() similar to powernowk8_target() and powernowk8_verify()
in the way it obtains "powernow_data" for a given CPU.
Cc: Andreas Herrmann <andreas.herrmann3@amd.com>
Cc: Langsdorf, Mark <mark.langsdorf@amd.com>
Cc: Thomas Renninger <trenn@suse.de>
Signed-off-by: Naga Chumbalkar <nagananda.chumbalkar@hp.com>
Reviewed-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Tested-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Acked-by: Langsdorf, Mark <mark.langsdorf@amd.com>
Signed-off-by: Thomas Renninger <trenn@suse.de>
By definition, "cpuinfo_cur_freq" should report the value from HW. So, don't
depend on the cached value. Instead read P-state directly from HW, while
taking into account the erratum 311 workaround for Fam 11h processors.
This symbol doesn't need file-global scope.
Cc: "Zhang, Rui" <rui.zhang@intel.com>
Cc: Dave Jones <davej@codemonkey.org.uk>
Cc: Leo Milano <lmilano@gmx.net>
Mess cleanup in powernow_k8_acpi_pst_values() function.
Signed-off-by: Luis Henriques <henrix@sapo.pt>
This doesn't fix anything, but it's expected that a transition latency of 0
could cause trouble in the future.
The e_powersaver driver for VIA's C7 CPU's needs to be marked as
DANGEROUS as it configures the CPU to power states that are out
of specification.
According to Centaur, all systems with C7 and Nano CPU's support
the ACPI p-state method. Thus, the acpi-cpufreq driver should
be used instead.
Signed-off-by: Harald Welte <HaraldWelte@viatech.com>
The VIA/Centaur C7, C7-M and Nano CPU's all support ACPI based cpu p-states
using a MSR interface. The Linux driver just never made use of it, since in
addition to the check for the EST flag it also checked if the vendor is Intel.
[ Removed the vendor checks entirely - Linus ]
These are defined as static cpumask_var_t so if MAXSMP is not used,
they are cleared already. Avoid surprises when MAXSMP is enabled.
Signed-off-by: Yinghai Lu <yinghai.lu@kernel.org>
The powernow-k8 driver checks to see that the Performance Control/Status
Registers are declared as FFH (functional fixed hardware) by the BIOS.
However, this check got broken in the commit:
0e64a0c982c06a6b8f5e2a7f29eb108fdf257b2f
[CPUFREQ] checkpatch cleanups for powernow-k8
Fix based on an original patch from Naga Chumbalkar.
Cc: Mark Langsdorf <mark.langsdorf@amd.com>
Signed-off-by: Len Brown <len.brown@intel.com>
Slightly modified by trenn@suse.de -> only do this on fam 10h and fam 11h.
Currently powernow-k8 determines CPU frequency from ACPI PSS objects, but
according to AMD family 11h BKDG this frequency is just a rounded value:
"CoreFreq (MHz) = The CPU COF specified by MSRC001_00[6B:64][CpuFid]
rounded to the nearest 100 Mhz."
As a consequnce powernow-k8 reports wrong CPU frequency on some systems,
e.g. on Turion X2 Ultra:
powernow-k8: Found 1 AMD Turion(tm)X2 Ultra DualCore Mobile ZM-82
processors (2 cpu cores) (version 2.20.00)
powernow-k8: 0 : pstate 0 (2200 MHz)
powernow-k8: 1 : pstate 1 (1100 MHz)
powernow-k8: 2 : pstate 2 (600 MHz)
But this is wrong as frequency for Pstate2 is 550 MHz. x86info reports it
correctly:
#x86info -a |grep Pstate
Pstate-0: fid=e, did=0, vid=24 (2200MHz)
Pstate-1: fid=e, did=1, vid=30 (1100MHz)
Pstate-2: fid=e, did=2, vid=3c (550MHz) (current)
Solution is to determine the frequency directly from Pstate MSRs instead
of using rounded values from ACPI table.
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
- Make the message shorter and easier to grep for
- Use printk_once instead of WARN_ONCE (functionality of these was mixed)
arch/x86/kernel/cpu/cpufreq/powernow-k7.c:172: warning: 'invalidate_entry' defined but not used
Reported-by: Toralf Förster <toralf.foerster@gmx.de>
Some atom procs don't do freq scaling (such as the atom 330 on my own
littlefalls2 board). By adding the atom family here, we at least get
the benefit of passive cooling in a thermal emergency. Not sure how
to see that its actually helping any, but the driver does bind and
claim its functioning on my atom 330.
Signed-off-by: Jarod Wilson <jarod@redhat.com>
Take already available policy->cpuinfo.max_freq and get rid of acpi-cpufreq
specific max_freq variable.
This implies that P0 is always the highest frequency which should always
be true as ACPI spec says:
As a result, the zeroth entry describes the highest performance state
Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Fix for a regression that was introduced by earlier commit
18b2646fe3babeb40b34a0c1751e0bf5adfdc64c on Mon Apr 6 11:26:08 2009
Regression resulted in the below error happened on systems with
software coordination where per_cpu acpi data will not be initiated for
secondary CPUs in a P-state domain.
On Tue, 2009-04-14 at 23:01 -0700, Zhang, Yanmin wrote:
My machine hanged with kernel 2.6.30-rc2 when script read
> /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor.
> opps happens in get_measured_perf:
> cur.aperf.whole = readin.aperf.whole -
> per_cpu(drv_data, cpu)->saved_aperf;
> Because per_cpu(drv_data, cpu)=NULL.
> So function get_measured_perf should check if (per_cpu(drv_data,
> cpu)==NULL)
> and return 0 if it's NULL.
--------------sys log------------------
BUG: unable to handle kernel NULL pointer dereference at
0000000000000020
IP: [<ffffffff8021af75>] get_measured_perf+0x4a/0xf9
PGD a7dd88067 PUD a7ccf5067 PMD 0
Oops: 0000 [#1] SMP
last sysfs file: /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
CPU 0
Modules linked in: video output
Pid: 2091, comm: kondemand/0 Not tainted 2.6.30-rc2 #1 MP Server
RIP: 0010:[<ffffffff8021af75>] [<ffffffff8021af75>]
RSP: 0018:ffff880a7d56de20 EFLAGS: 00010246
RAX: 0000000000000000 RBX: 00000046241a42b6 RCX: ffff88004d219000
RDX: 000000000000b660 RSI: 0000000000000020 RDI: 0000000000000001
RBP: ffff880a7f052000 R08: 00000046241a42b6 R09: ffffffff807639f0
R10: 00000000ffffffea R11: ffffffff802207f4 R12: ffff880a7f052000
R13: ffff88004d20e460 R14: 0000000000ddd5a6 R15: 0000000000000001
FS: 0000000000000000(0000) GS:ffff88004d200000(0000)
knlGS:0000000000000000
CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
CR2: 0000000000000020 CR3: 0000000a7f1bf000 CR4: 00000000000006e0
Process kondemand/0 (pid: 2091, threadinfo ffff880a7d56c000, task
ffff880a7d4d18c0)
Stack:
ffff880a7f052078 ffffffff803efd54 00000046241a42b6 000000462ffa9e95
0000000000000001 0000000000000001 00000000ffffffea ffffffff8064f41a
0000000000000012 0000000000000012 ffff880a7f052000 ffffffff80650547
Call Trace:
[<ffffffff803efd54>] ? kobject_get+0x12/0x17
[<ffffffff8064f41a>] ? __cpufreq_driver_getavg+0x42/0x57
[<ffffffff80650547>] ? do_dbs_timer+0x147/0x272
[<ffffffff80650400>] ? do_dbs_timer+0x0/0x272
[<ffffffff802474ca>] ? worker_thread+0x15b/0x1f5
[<ffffffff8024a02c>] ? autoremove_wake_function+0x0/0x2e
[<ffffffff8024736f>] ? worker_thread+0x0/0x1f5
[<ffffffff80249f0d>] ? kthread+0x54/0x83
[<ffffffff8020c87a>] ? child_rip+0xa/0x20
[<ffffffff80249eb9>] ? kthread+0x0/0x83
[<ffffffff8020c870>] ? child_rip+0x0/0x20
Code: 99 a6 03 00 31 c9 85 c0 0f 85 c3 00 00 00 89 df 4c 8b 44 24 10 48
c7 c2 60 b6 00 00 48 8b 0c fd e0 30 a5 80 4c 89 c3 48 8b 04 0a <48> 2b
58 20 48 8b 44 24 18 48 89 1c 24 48 8b 34 0a 48 2b 46 28
RIP [<ffffffff8021af75>] get_measured_perf+0x4a/0xf9
RSP <ffff880a7d56de20>
---[ end trace 2b8fac9a49e19ad4 ]---
Tested-by: "Zhang, Yanmin" <yanmin_zhang@linux.intel.com>
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
It turns out that 'smp_call_function_many()' doesn't work at all like
'smp_call_function_single()', and my change to Andrew's patch to use it
rather than a loop over all CPU's acpi-cpufreq doesn't work.
My bad.
'smp_call_function_many()' has two "features" (aka "documented bugs"):
(a) it needs to be called with preemption disabled, because it uses
smp_processor_id() without guarding the CPU lookup with 'get_cpu()'
and 'put_cpu()' like the 'single' variant does.
(b) even if the current CPU is part of the CPU mask, it won't do the
call on that CPU.
Still, we're better off trying to use 'smp_call_function_many()' than
looping over CPU's, since it at least in theory allows us to use a
broadcast IPI and do it all in parallel. So let's just work around the
silly semantic bugs in that function.
Reported-and-tested-by: Ali Gholami Rudi <ali@rudi.ir>
Cc: Andrew Morton <akpm@linux-foundation.org>,
Cc: Dave Jones <davej@redhat.com>
We ended up incorrectly using '&cur' instead of '&readin' in the
work_on_cpu() -> smp_call_function_single() transformation in commit
01599fca6758d2cd133e78f87426fc851c9ea725 ("cpufreq: use
smp_call_function_[single|many]() in acpi-cpufreq.c").
Andrew explains:
"OK, the acpi tree went and had conflicting changes merged into it after
I'd written the patch and it appears that I incorrectly reverted part
of 18b2646fe3babeb40b34a0c1751e0bf5adfdc64c while fixing the resulting
rejects.
Switching it to `readin' looks correct."
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Atttempting to rid us of the problematic work_on_cpu(). Just use
smp_call_fuction_single() here.
This repairs a 10% sysbench(oltp)+mysql regression which Mike reported,
due to
commit 6b44003e5ca66a3fffeb5bc90f40ada2c4340896
Author: Andrew Morton <akpm@linux-foundation.org>
Date: Thu Apr 9 09:50:37 2009 -0600
work_on_cpu(): rewrite it to create a kernel thread on demand
It seems that the kernel calls these acpi-cpufreq functions at a quite
high frequency.
Valdis Kletnieks also reports that this causes 70-90 forks per second on
his hardware.
Cc: Valdis.Kletnieks@vt.edu
Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Cc: Len Brown <len.brown@intel.com>
Cc: Zhao Yakui <yakui.zhao@intel.com>
Acked-by: Dave Jones <davej@redhat.com>
Tested-by: Mike Galbraith <efault@gmx.de>
Cc: "Zhang, Yanmin" <yanmin_zhang@linux.intel.com>
[ Made it use smp_call_function_many() instead of looping over cpu's
with smp_call_function_single() - Linus ]
and 'bjorn.notify' into release
Do not write zeroes to APERF and MPERF by ondemand governor. With this
change, other users can share these MSRs for reads.
Change structure name to make the code cleaner and simpler. No
functionality change in this patch.
Remove dupilicated #include in arch/x86/kernel/cpu/cpufreq/longhaul.c.
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (140 commits)
ACPI: processor: use .notify method instead of installing handler directly
ACPI: button: use .notify method instead of installing handler directly
ACPI: support acpi_device_ops .notify methods
toshiba-acpi: remove MAINTAINERS entry
ACPI: battery: asynchronous init
acer-wmi: Update copyright notice & documentation
acer-wmi: Cleanup the failure cleanup handling
acer-wmi: Blacklist Acer Aspire One
video: build fix
thinkpad-acpi: rework brightness support
thinkpad-acpi: enhanced debugging messages for the fan subdriver
thinkpad-acpi: enhanced debugging messages for the hotkey subdriver
thinkpad-acpi: enhanced debugging messages for rfkill subdrivers
thinkpad-acpi: restrict access to some firmware LEDs
thinkpad-acpi: remove HKEY disable functionality
thinkpad-acpi: add new debug helpers and warn of deprecated atts
thinkpad-acpi: add missing log levels
thinkpad-acpi: cleanup debug helpers
thinkpad-acpi: documentation cleanup
thinkpad-acpi: drop ibm-acpi alias
* 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (413 commits)
tracing, net: fix net tree and tracing tree merge interaction
tracing, powerpc: fix powerpc tree and tracing tree interaction
ring-buffer: do not remove reader page from list on ring buffer free
function-graph: allow unregistering twice
trace: make argument 'mem' of trace_seq_putmem() const
tracing: add missing 'extern' keywords to trace_output.h
tracing: provide trace_seq_reserve()
blktrace: print out BLK_TN_MESSAGE properly
blktrace: extract duplidate code
blktrace: fix memory leak when freeing struct blk_io_trace
blktrace: fix blk_probes_ref chaos
blktrace: make classic output more classic
blktrace: fix off-by-one bug
blktrace: fix the original blktrace
blktrace: fix a race when creating blk_tree_root in debugfs
blktrace: fix timestamp in binary output
tracing, Text Edit Lock: cleanup
tracing: filter fix for TRACE_EVENT_FORMAT events
ftrace: Using FTRACE_WARN_ON() to check "freed record" in ftrace_release()
x86: kretprobe-booster interrupt emulation code fix
Fix up trivial conflicts in
arch/parisc/include/asm/ftrace.h
include/linux/memory.h
kernel/extable.c
kernel/module.c
include/linux/slub_def.h
lib/Kconfig.debug
mm/slob.c
mm/slub.c
arch/x86/kernel/cpu/common.c
Some BIOSes report very high frequency transition latency which are plainly
wrong on CPus that can change frequency using native MSR interface.
One such system is IBM T42 (2327-8ZU) as reported by Owen Taylor and
Rik van Riel.
cpufreq_ondemand driver uses this transition latency to come up with a
reasonable sampling interval to sample CPU usage and with such high
latency value, ondemand sampling interval ends up being very high
(0.5 sec, in this particular case), resulting in performance impact due to
slow response to increasing frequency.
Fix it by capping-off the transition latency to 20uS for native MSR based
frequency transitions.
mjg: We've confirmed that this also helps on the X31
Acked-by: Matthew Garrett <mjg@redhat.com>
> arch/x86/kernel/cpu/cpufreq/longhaul.c: In function 'longhaul_setstate':
> arch/x86/kernel/cpu/cpufreq/longhaul.c:308: error: implicit declaration of function 'acpi_set_register'
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Compile-tested-by: Stephen Rothwell <sfr@canb.auug.org.au>
arch/parisc/kernel/irq.c
arch/x86/include/asm/fixmap_64.h
arch/x86/include/asm/setup.h
kernel/irq/handle.c
Semantic merge:
arch/x86/include/asm/fixmap.h
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: (35 commits)
[CPUFREQ] Prevent p4-clockmod from auto-binding to the ondemand governor.
[CPUFREQ] Make cpufreq-nforce2 less obnoxious
[CPUFREQ] p4-clockmod reports wrong frequency.
[CPUFREQ] powernow-k8: Use a common exit path.
[CPUFREQ] Change link order of x86 cpufreq modules
[CPUFREQ] conservative: remove 10x from def_sampling_rate
[CPUFREQ] conservative: fixup governor to function more like ondemand logic
[CPUFREQ] conservative: fix dbs_cpufreq_notifier so freq is not locked
[CPUFREQ] conservative: amend author's email address
[CPUFREQ] Use swap() in longhaul.c
[CPUFREQ] checkpatch cleanups for acpi-cpufreq
[CPUFREQ] powernow-k8: Only print error message once, not per core.
[CPUFREQ] ondemand/conservative: sanitize sampling_rate restrictions
[CPUFREQ] ondemand/conservative: deprecate sampling_rate{min,max}
[CPUFREQ] powernow-k8: Always compile powernow-k8 driver with ACPI support
[CPUFREQ] Introduce /sys/devices/system/cpu/cpu*/cpufreq/cpuinfo_transition_latency
[CPUFREQ] checkpatch cleanups for ondemand governor.
[CPUFREQ] checkpatch cleanups for powernow-k7
[CPUFREQ] checkpatch cleanups for speedstep related drivers.
Impact: reduce per-cpu size for CONFIG_CPUMASK_OFFSTACK=y
In most places it's cleaner to use the accessors cpu_sibling_mask()
and cpu_core_mask() wrappers which already exist.
I couldn't avoid cleaning up the access in oprofile, either.
tracing/core
This reverts commit e088e4c9cdb618675874becb91b2fd581ee707e6.
Removing the sysfs interface for p4-clockmod was flagged as a
regression in bug 12826.
Course of action:
- Find out the remaining causes of overheating, and fix them
if possible. ACPI should be doing the right thing automatically.
If it isn't, we need to fix that.
- mark p4-clockmod ui as deprecated
- try again with the removal in six months.
It's not really feasible to printk about the deprecation, because
it needs to happen at all the sysfs entry points, which means adding
a lot of strcmp("p4-clockmod".. calls to the core, which.. bleuch.
arch/x86/Kconfig
block/blktrace.c
kernel/irq/handle.c
Semantic conflict:
kernel/trace/blktrace.c
The latency of p4-clockmod sucks so hard that scaling on a regular
basis with ondemand is a really bad idea.
Signed-off-by: Matthew Garrett <mjg59@srcf.ucam.org>
Not owning an nforce2 is a sign of good taste, not an error.
