L3 subcaches 0 and 1 of AMD Family 15h CPUs can have a size of 2MB.
Update the calculation routine for the number of L3 indices to
reflect that.
Signed-off-by: Frank Arnold <frank.arnold@amd.com>
Cc: Rosenfeld Hans <Hans.Rosenfeld@amd.com>
Cc: Herrmann3 Andreas <Andreas.Herrmann3@amd.com>
Cc: Mike Travis <travis@sgi.com>
Cc: Frank Arnold <Frank.Arnold@amd.com>
Link: http://lkml.kernel.org/r/20110726170449.GB32536@aftab
It's not a good reason to allocate memory in the smp function call
just because someone thought it's the most conveniant place.
The AMD L3 data is coupled to the northbridge info by a pointer to the
corresponding north bridge data. So allocating it with the northbridge
data and referencing the northbridge in the cache_info code instead
uses less memory and gets rid of that atomic allocation hack in the
smp function call.
Tested-by: Borislav Petkov <borislav.petkov@amd.com>
Cc: Hans Rosenfeld <hans.rosenfeld@amd.com>
Cc: Andreas Herrmann <andreas.herrmann3@amd.com>
Link: http://lkml.kernel.org/r/20110723212626.688229918@linutronix.de
Commit f9b90566c ("x86: reduce stack usage in init_intel_cacheinfo")
introduced a shadow structure to reduce the stack usage on large
machines instead of making the smaller structure embedded into the
large one. That's definitely a candidate for the bad taste award.
Move the small struct into the large one and get rid of the ugly type
casts.
Cc: Borislav Petkov <borislav.petkov@amd.com>
Link: http://lkml.kernel.org/r/20110723212626.625651773@linutronix.de
free_cache_attributes() kfree's:
per_cpu(ici_cpuid4_info, cpu)->l3
which is a pointer to memory which was allocated as a block in
amd_init_l3_cache(). l3 of a particular cpu points to a part of this
memory blob. The part and the rest of the blob are still referenced by
other cpus.
As far as I can tell from the git history this is a leftover from the
conversion from per cpu to node data with commit ba06edb63(x86,
cacheinfo: Make L3 cache info per node) and the following commit
f658bcfb2(x86, cacheinfo: Cleanup L3 cache index disable support)
Link: http://lkml.kernel.org/r/20110723212626.550539989@linutronix.de
We provide two slots to disable cache indices, and have a check to
prevent both slots to be used for the same index.
If the user disables the same index on different subcaches, both slots
will hold the same index, e.g.
$ echo 2047 > /sys/devices/system/cpu/cpu0/cache/index3/cache_disable_0
$ cat /sys/devices/system/cpu/cpu0/cache/index3/cache_disable_0
2047
$ echo 1050623 > /sys/devices/system/cpu/cpu0/cache/index3/cache_disable_1
$ cat /sys/devices/system/cpu/cpu0/cache/index3/cache_disable_1
2047
due to the fact that the check was looking only at index bits [11:0]
and was ignoring writes to bits outside that range. The more correct
fix is to simply check whether the index is within the bounds of
[0..l3->indices].
While at it, cleanup comments and drop now-unused local macros.
Link: http://lkml.kernel.org/r/1305553188-21061-3-git-send-email-bp@amd64.org
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
732eacc0542d0aa48797f675888b85d6065af837 converted code around the
kernel using nested max() macros to use the new max3 macro but forgot to
remove the old line in intel_cacheinfo.c. Fix it.
Cc: Hagen Paul Pfeifer <hagen@jauu.net>
Cc: Frank Arnold <farnold@amd64.org>
Link: http://lkml.kernel.org/r/1305553188-21061-2-git-send-email-bp@amd64.org
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (93 commits)
x86, tlb, UV: Do small micro-optimization for native_flush_tlb_others()
x86-64, NUMA: Don't call numa_set_distanc() for all possible node combinations during emulation
x86-64, NUMA: Don't assume phys node 0 is always online in numa_emulation()
x86-64, NUMA: Clean up initmem_init()
x86-64, NUMA: Fix numa_emulation code with node0 without RAM
x86-64, NUMA: Revert NUMA affine page table allocation
x86: Work around old gas bug
x86-64, NUMA: Better explain numa_distance handling
x86-64, NUMA: Fix distance table handling
mm: Move early_node_map[] reverse scan helpers under HAVE_MEMBLOCK
x86-64, NUMA: Fix size of numa_distance array
x86: Rename e820_table_* to pgt_buf_*
bootmem: Move __alloc_memory_core_early() to nobootmem.c
bootmem: Move contig_page_data definition to bootmem.c/nobootmem.c
bootmem: Separate out CONFIG_NO_BOOTMEM code into nobootmem.c
x86-64, NUMA: Seperate out numa_alloc_distance() from numa_set_distance()
x86-64, NUMA: Add proper function comments to global functions
x86-64, NUMA: Move NUMA emulation into numa_emulation.c
x86-64, NUMA: Prepare numa_emulation() for moving NUMA emulation into a separate file
x86-64, NUMA: Do not scan two times for setup_node_bootmem()
Fix up conflicts in arch/x86/kernel/smpboot.c
L3 Cache Partitioning allows selecting which of the 4 L3 subcaches can be used
for evictions by the L2 cache of each compute unit. By writing a 4-bit
hexadecimal mask into the the sysfs file
/sys/devices/system/cpu/cpuX/cache/index3/subcaches, the user can set the
enabled subcaches for a CPU.
The settings are directly read from and written to the hardware, so there is no
way to have contradicting settings for two CPUs belonging to the same compute
unit. Writing will always overwrite any previous setting for a compute unit.
Signed-off-by: Hans Rosenfeld <hans.rosenfeld@amd.com>
Cc: <Andreas.Herrmann3@amd.com>
LKML-Reference: <1297098639-431383-1-git-send-email-hans.rosenfeld@amd.com>
[ -v3: minor style fixes ]
cpu_info is already with per_cpu, We can take llc_shared_map out
of cpu_info, and declare it as per_cpu variable directly.
So later referencing could be simple and directly instead of
diving to find cpu_info at first.
Also could make smp_store_cpu_info() much simple to avoid to do
save and restore trick.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: Alok N Kataria <akataria@vmware.com>
Cc: Stephen Hemminger <shemminger@vyatta.com>
Cc: Hans J. Koch <hjk@linutronix.de>
Cc: Tejun Heo <tj@kernel.org>
Cc: Robert Richter <robert.richter@amd.com>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
LKML-Reference: <4D3A16E8.5020608@kernel.org>
Update to latest definitions in:
http://www.intel.com/Assets/PDF/appnote/241618.pdf
[ Note, this update of the doc has removed some old values which
we have listed. I think until we have clarification that they
were never used in production, they should be left there. ]
Signed-off-by: Dave Jones <davej@redhat.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
LKML-Reference: <20110120012055.GA15985@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (30 commits)
gameport: use this_cpu_read instead of lookup
x86: udelay: Use this_cpu_read to avoid address calculation
x86: Use this_cpu_inc_return for nmi counter
x86: Replace uses of current_cpu_data with this_cpu ops
x86: Use this_cpu_ops to optimize code
vmstat: User per cpu atomics to avoid interrupt disable / enable
irq_work: Use per cpu atomics instead of regular atomics
cpuops: Use cmpxchg for xchg to avoid lock semantics
x86: this_cpu_cmpxchg and this_cpu_xchg operations
percpu: Generic this_cpu_cmpxchg() and this_cpu_xchg support
percpu,x86: relocate this_cpu_add_return() and friends
connector: Use this_cpu operations
xen: Use this_cpu_inc_return
taskstats: Use this_cpu_ops
random: Use this_cpu_inc_return
fs: Use this_cpu_inc_return in buffer.c
highmem: Use this_cpu_xx_return() operations
vmstat: Use this_cpu_inc_return for vm statistics
x86: Support for this_cpu_add, sub, dec, inc_return
percpu: Generic support for this_cpu_add, sub, dec, inc_return
Fixed up conflicts: in arch/x86/kernel/{apic/nmi.c, apic/x2apic_uv_x.c, process.c}
as per Tejun.
Replace all uses of current_cpu_data with this_cpu operations on the
per cpu structure cpu_info. The scala accesses are replaced with the
matching this_cpu ops which results in smaller and more efficient
code.
In the long run, it might be a good idea to remove cpu_data() macro
too and use per_cpu macro directly.
tj: updated description
Cc: Yinghai Lu <yinghai@kernel.org>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Acked-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Christoph Lameter <cl@linux.com>
Adaptions to the changes of the AMD northbridge caching code: instead
of a bool in each l3 struct, use a flag in amd_northbridges.flags to
indicate L3 cache index disable support; use a pointer to the whole
northbridge instead of the misc device in the l3 struct; simplify the
initialisation; dynamically generate sysfs attribute array.
Support more than just the "Misc Control" part of the northbridges.
Support more flags by turning "gart_supported" into a single bit flag
that is stored in a flags member. Clean up related code by using a set
of functions (amd_nb_num(), amd_nb_has_feature() and node_to_amd_nb())
instead of accessing the NB data structures directly. Reorder the
initialization code and put the GART flush words caching in a separate
function.
Not only the naming of the files was confusing, it was even more so for
the function and variable names.
Renamed the K8 NB and NUMA stuff that is also used on other AMD
platforms. This also renames the CONFIG_K8_NUMA option to
CONFIG_AMD_NUMA and the related file k8topology_64.c to
amdtopology_64.c. No functional changes intended.
Use the new {max,min}3 macros to save some cycles and bytes on the stack.
This patch substitutes trivial nested macros with their counterpart.
Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net>
Cc: Joe Perches <joe@perches.com>
Cc: Hartley Sweeten <hsweeten@visionengravers.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: Sean Hefty <sean.hefty@intel.com>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
The file names are somehow misleading as the code is not specific to
AMD K8 CPUs anymore. The files accomodate code for other AMD CPU
northbridges as well.
Same is true for the config option which is valid for AMD CPU
northbridges in general and not specific to K8.
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
LKML-Reference: <20100917160343.GD4958@loge.amd.com>
So far we only provide num_k8_northbridges. This is required in
different areas (e.g. L3 cache index disable, GART). But not all AMD
CPUs provide a GART. Thus it is useful to split off the GART handling
from the generic caching of AMD northbridge misc devices.
LKML-Reference: <20100917160254.GC4958@loge.amd.com>
L3 cache index disable code uses PCI accesses to AMD northbridge functions.
Currently the code is #ifdef CONFIG_CPU_SUP_AMD.
But it should be #if (defined(CONFIG_CPU_SUP_AMD) && defined(CONFIG_PCI))
which in the end is a dependency to K8_NB.
LKML-Reference: <20100917160744.GF4958@loge.amd.com>
This is in preparation for disabling L3 cache indices after having
received correctable ECCs in the L3 cache. Now we allow for initial
setting of a disabled index slot (write once) and deny writing new
indices to it after it has been disabled. Also, we deny using both slots
to disable one and the same index.
Userspace can restore the previously disabled indices by rewriting those
sysfs entries when booting.
Cleanup and reorganize code while at it.
LKML-Reference: <20100602161840.GI18327@aftab>
When disabling an L3 cache index, make sure we disable that index in
all four subcaches of the L3. Clarify nomenclature while at it, wrt to
disable slots versus disable index and rename accordingly.
LKML-Reference: <1271945222-5283-6-git-send-email-bp@amd64.org>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Currently, we're allocating L3 cache info and calculating indices for
each online cpu which is clearly superfluous. Instead, we need to do
this per-node as is each L3 cache.
No functional change, only per-cpu memory savings.
-v2: Allocate L3 cache descriptors array dynamically.
LKML-Reference: <1271945222-5283-5-git-send-email-bp@amd64.org>
Add a struct representing L3 cache attributes (subcache sizes and
indices count) and move the respective members out of _cpuid4_info.
Also, stash the struct pci_dev ptr into the struct simplifying the code
even more.
There should be no functionality change resulting from this patch except
slightly slimming the _cpuid4_info per-cpu vars.
LKML-Reference: <1271945222-5283-4-git-send-email-bp@amd64.org>
environments
When running a quest kernel on xen we get:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000038
IP: [<ffffffff8142f2fb>] cpuid4_cache_lookup_regs+0x2ca/0x3df
PGD 0
Oops: 0000 [#1] SMP
last sysfs file:
CPU 0
Modules linked in:
Pid: 0, comm: swapper Tainted: G W 2.6.34-rc3 #1 /HVM domU
RIP: 0010:[<ffffffff8142f2fb>] [<ffffffff8142f2fb>] cpuid4_cache_lookup_regs+0x
2ca/0x3df
RSP: 0018:ffff880002203e08 EFLAGS: 00010046
RAX: 0000000000000000 RBX: 0000000000000003 RCX: 0000000000000060
RDX: 0000000000000000 RSI: 0000000000000040 RDI: 0000000000000000
RBP: ffff880002203ed8 R08: 00000000000017c0 R09: ffff880002203e38
R10: ffff8800023d5d40 R11: ffffffff81a01e28 R12: ffff880187e6f5c0
R13: ffff880002203e34 R14: ffff880002203e58 R15: ffff880002203e68
FS: 0000000000000000(0000) GS:ffff880002200000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000038 CR3: 0000000001a3c000 CR4: 00000000000006f0
Process swapper (pid: 0, threadinfo ffffffff81a00000, task ffffffff81a44020)
Stack:
ffffffff810d7ecb ffff880002203e20 ffffffff81059140 ffff880002203e30
<0> ffffffff810d7ec9 0000000002203e40 000000000050d140 ffff880002203e70
<0> 0000000002008140 0000000000000086 ffff880040020140 ffffffff81068b8b
Call Trace:
<IRQ>
[<ffffffff810d7ecb>] ? sync_supers_timer_fn+0x0/0x1c
[<ffffffff81059140>] ? mod_timer+0x23/0x25
[<ffffffff810d7ec9>] ? arm_supers_timer+0x34/0x36
[<ffffffff81068b8b>] ? hrtimer_get_next_event+0xa7/0xc3
[<ffffffff81058e85>] ? get_next_timer_interrupt+0x19a/0x20d
[<ffffffff8142fa23>] get_cpu_leaves+0x5c/0x232
[<ffffffff8106a7b1>] ? sched_clock_local+0x1c/0x82
[<ffffffff8106a9a0>] ? sched_clock_tick+0x75/0x7a
[<ffffffff8107748c>] generic_smp_call_function_single_interrupt+0xae/0xd0
[<ffffffff8101f6ef>] smp_call_function_single_interrupt+0x18/0x27
[<ffffffff8100a773>] call_function_single_interrupt+0x13/0x20
<EOI>
[<ffffffff8143c468>] ? notifier_call_chain+0x14/0x63
[<ffffffff810295c6>] ? native_safe_halt+0xc/0xd
[<ffffffff810114eb>] ? default_idle+0x36/0x53
[<ffffffff81008c22>] cpu_idle+0xaa/0xe4
[<ffffffff81423a9a>] rest_init+0x7e/0x80
[<ffffffff81b10dd2>] start_kernel+0x40e/0x419
[<ffffffff81b102c8>] x86_64_start_reservations+0xb3/0xb7
[<ffffffff81b103c4>] x86_64_start_kernel+0xf8/0x107
Code: 14 d5 40 ff ae 81 8b 14 02 31 c0 3b 15 47 1c 8b 00 7d 0e 48 8b 05 36 1c 8b
00 48 63 d2 48 8b 04 d0 c7 85 5c ff ff ff 00 00 00 00 <8b> 70 38 48 8d 8d 5c ff
ff ff 48 8b 78 10 ba c4 01 00 00 e8 eb
RIP [<ffffffff8142f2fb>] cpuid4_cache_lookup_regs+0x2ca/0x3df
RSP <ffff880002203e08>
---[ end trace a7919e7f17c0a726 ]---
The L3 cache index disable feature of AMD CPUs has to be disabled if the
kernel is running as guest on top of a hypervisor because northbridge
devices are not available to the guest. Currently, this fixes a boot
crash on top of Xen. In the future this will become an issue on KVM as
well.
Check if northbridge devices are present and do not enable the feature
if there are none.
LKML-Reference: <1271945222-5283-3-git-send-email-bp@amd64.org>
Acked-by: Borislav Petkov <borislav.petkov@amd.com>
All F10h CPUs starting with model 8 resp. 9, stepping 1, support L3
cache index disable. Concentrate the family, model, stepping checking at
one place and enable the feature implicitly on upcoming Fam10h models.
LKML-Reference: <1271945222-5283-2-git-send-email-bp@amd64.org>
Constify struct sysfs_ops.
This is part of the ops structure constification
effort started by Arjan van de Ven et al.
Benefits of this constification:
* prevents modification of data that is shared
(referenced) by many other structure instances
at runtime
* detects/prevents accidental (but not intentional)
modification attempts on archs that enforce
read-only kernel data at runtime
* potentially better optimized code as the compiler
can assume that the const data cannot be changed
* the compiler/linker move const data into .rodata
and therefore exclude them from false sharing
Signed-off-by: Emese Revfy <re.emese@gmail.com>
Acked-by: David Teigland <teigland@redhat.com>
Acked-by: Matt Domsch <Matt_Domsch@dell.com>
Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com>
Acked-by: Hans J. Koch <hjk@linutronix.de>
Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
Acked-by: Jens Axboe <jens.axboe@oracle.com>
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
* 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, cacheinfo: Enable L3 CID only on AMD
x86, cacheinfo: Remove NUMA dependency, fix for AMD Fam10h rev D1
x86, cpu: Print AMD virtualization features in /proc/cpuinfo
x86, cacheinfo: Calculate L3 indices
x86, cacheinfo: Add cache index disable sysfs attrs only to L3 caches
x86, cacheinfo: Fix disabling of L3 cache indices
intel-agp: Switch to wbinvd_on_all_cpus
x86, lib: Add wbinvd smp helpers
Final stage linking can fail with
arch/x86/built-in.o: In function `store_cache_disable':
intel_cacheinfo.c:(.text+0xc509): undefined reference to `amd_get_nb_id'
arch/x86/built-in.o: In function `show_cache_disable':
intel_cacheinfo.c:(.text+0xc7d3): undefined reference to `amd_get_nb_id'
when CONFIG_CPU_SUP_AMD is not enabled because the amd_get_nb_id
helper is defined in AMD-specific code but also used in generic code
(intel_cacheinfo.c). Reorganize the L3 cache index disable code under
CONFIG_CPU_SUP_AMD since it is AMD-only anyway.
LKML-Reference: <20100218184210.GF20473@aftab>
The show/store_cache_disable routines depend unnecessarily on NUMA's
cpu_to_node and the disabling of cache indices broke when !CONFIG_NUMA.
Remove that dependency by using a helper which is always correct.
While at it, enable L3 Cache Index disable on rev D1 Istanbuls which
sport the feature too.
LKML-Reference: <20100218184339.GG20473@aftab>
We need to know the valid L3 indices interval when disabling them over
/sysfs. Do that when the core is brought online and add boundary checks
to the sysfs .store attribute.
LKML-Reference: <1264172467-25155-6-git-send-email-bp@amd64.org>
The cache_disable_[01] attribute in
/sys/devices/system/cpu/cpu?/cache/index[0-3]/
is enabled on all cache levels although only L3 supports it. Add it only
to the cache level that actually supports it.
LKML-Reference: <1264172467-25155-5-git-send-email-bp@amd64.org>
* Correct the masks used for writing the cache index disable indices.
* Do not turn off L3 scrubber - it is not necessary.
* Make sure wbinvd is executed on the same node where the L3 is.
* Check for out-of-bounds values written to the registers.
* Make show_cache_disable hex values unambiguous
* Check for Erratum #388
LKML-Reference: <1264172467-25155-4-git-send-email-bp@amd64.org>
Use a macro to define the cache sizes when cachesize > 1 MB.
This is less typing, and less prone to introducing bugs like we
saw in e02e0e1a130b9ca37c5186d38ad4b3aaf58bb149, and means we
don't have to do maths when adding new non-power-of-2 updates
like those seen recently.
LKML-Reference: <20100104144735.GA18390@redhat.com>
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, mce: Clean up thermal init by introducing intel_thermal_supported()
x86, mce: Thermal monitoring depends on APIC being enabled
x86: Gart: fix breakage due to IOMMU initialization cleanup
x86: Move swiotlb initialization before dma32_free_bootmem
x86: Fix build warning in arch/x86/mm/mmio-mod.c
x86: Remove usedac in feature-removal-schedule.txt
x86: Fix duplicated UV BAU interrupt vector
nvram: Fix write beyond end condition; prove to gcc copy is safe
mm: Adjust do_pages_stat() so gcc can see copy_from_user() is safe
x86: Limit the number of processor bootup messages
x86: Remove enabling x2apic message for every CPU
doc: Add documentation for bootloader_{type,version}
x86, msr: Add support for non-contiguous cpumasks
x86: Use find_e820() instead of hard coded trampoline address
x86, AMD: Fix stale cpuid4_info shared_map data in shared_cpu_map cpumasks
Trivial percpu-naming-introduced conflicts in arch/x86/kernel/cpu/intel_cacheinfo.c
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (34 commits)
m68k: rename global variable vmalloc_end to m68k_vmalloc_end
percpu: add missing per_cpu_ptr_to_phys() definition for UP
percpu: Fix kdump failure if booted with percpu_alloc=page
percpu: make misc percpu symbols unique
percpu: make percpu symbols in ia64 unique
percpu: make percpu symbols in powerpc unique
percpu: make percpu symbols in x86 unique
percpu: make percpu symbols in xen unique
percpu: make percpu symbols in cpufreq unique
percpu: make percpu symbols in oprofile unique
percpu: make percpu symbols in tracer unique
percpu: make percpu symbols under kernel/ and mm/ unique
percpu: remove some sparse warnings
percpu: make alloc_percpu() handle array types
vmalloc: fix use of non-existent percpu variable in put_cpu_var()
this_cpu: Use this_cpu_xx in trace_functions_graph.c
this_cpu: Use this_cpu_xx for ftrace
this_cpu: Use this_cpu_xx in nmi handling
this_cpu: Use this_cpu operations in RCU
this_cpu: Use this_cpu ops for VM statistics
Fix up trivial (famous last words) global per-cpu naming conflicts in
arch/x86/kvm/svm.c
mm/slab.c
The per_cpu cpuid4_info shared_map can contain stale data when CPUs are added
and removed.
The stale data can lead to a NULL pointer derefernce panic on a remove of a
CPU that has had siblings previously removed.
This patch resolves the panic by verifying a cpu is actually online before
adding it to the shared_cpu_map, only examining cpus that are part of
the same lower level cache, and by updating other siblings lowest level cache
maps when a cpu is added.
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
LKML-Reference: <20091209183336.17855.98708.sendpatchset@prarit.bos.redhat.com>
x86, mce: don't restart timer if disabled
x86: Use -maccumulate-outgoing-args for sane mcount prologues
x86: Prevent GCC 4.4.x (pentium-mmx et al) function prologue wreckage
x86: AMD Northbridge: Verify NB's node is online
x86 VSDO: Fix Kconfig help
x86: Fix typo in Intel CPU cache size descriptor
x86: Add new Intel CPU cache size descriptors
Merge reason: we want to queue up a dependent fix.
They aren't really useful, and they pollute the dmesg output a lot
(especially on machines with many cores).
Also the same information can be trivially found out from
userspace.
Reported-by: Mike Travis <travis@sgi.com>
Cc: Roland Dreier <rdreier@cisco.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Cc: Jack Steiner <steiner@sgi.com>
LKML-Reference: <20091112231542.GA7129@redhat.com>
I double-checked the datasheet. One of the existing
descriptors has a typo: it should be 2MB not 2038 KB.
Cc: <stable@kernel.org> # .3x.x: 85160b9: x86: Add new Intel CPU cache size descriptors
LKML-Reference: <20091110200120.GA27090@redhat.com>
The latest rev of Intel doc AP-485 details new cache descriptors
that we don't yet support. 12MB, 18MB and 24MB 24-way assoc L3
caches.
LKML-Reference: <20091110184924.GA20337@redhat.com>
This patch updates percpu related symbols in x86 such that percpu
symbols are unique and don't clash with local symbols. This serves
two purposes of decreasing the possibility of global percpu symbol
collision and allowing dropping per_cpu__ prefix from percpu symbols.
* arch/x86/kernel/cpu/common.c: rename local variable to avoid collision
* arch/x86/kvm/svm.c: s/svm_data/sd/ for local variables to avoid collision
* arch/x86/kernel/cpu/cpu_debug.c: s/cpu_arr/cpud_arr/
s/priv_arr/cpud_priv_arr/
s/cpu_priv_count/cpud_priv_count/
* arch/x86/kernel/cpu/intel_cacheinfo.c: s/cpuid4_info/ici_cpuid4_info/
s/cache_kobject/ici_cache_kobject/
s/index_kobject/ici_index_kobject/
* arch/x86/kernel/ds.c: s/cpu_context/cpu_ds_context/
Partly based on Rusty Russell's "alloc_percpu: rename percpu vars
which cause name clashes" patch.
Acked-by: (kvm) Avi Kivity <avi@redhat.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: x86@kernel.org
* 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (22 commits)
x86: Fix code patching for paravirt-alternatives on 486
x86, msr: change msr-reg.o to obj-y, and export its symbols
x86: Use hard_smp_processor_id() to get apic id for AMD K8 cpus
x86, sched: Workaround broken sched domain creation for AMD Magny-Cours
x86, mcheck: Use correct cpumask for shared bank4
x86, cacheinfo: Fixup L3 cache information for AMD multi-node processors
x86: Fix CPU llc_shared_map information for AMD Magny-Cours
x86, msr: Fix msr-reg.S compilation with gas 2.16.1, on 32-bit too
x86: Move kernel_fpu_using to irq_fpu_usable in asm/i387.h
x86, msr: fix msr-reg.S compilation with gas 2.16.1
x86, msr: Export the register-setting MSR functions via /dev/*/msr
x86, msr: Create _on_cpu helpers for {rw,wr}msr_safe_regs()
x86, msr: Have the _safe MSR functions return -EIO, not -EFAULT
x86, msr: CFI annotations, cleanups for msr-reg.S
x86, asm: Make _ASM_EXTABLE() usable from assembly code
x86, asm: Add 32-bit versions of the combined CFI macros
x86, AMD: Disable wrongly set X86_FEATURE_LAHF_LM CPUID bit
x86, msr: Rewrite AMD rd/wrmsr variants
x86, msr: Add rd/wrmsr interfaces with preset registers
x86: add specific support for Intel Atom architecture
L3 cache size, associativity and shared_cpu information need to be
adapted to show information for an internal node instead of the
entire physical package.
No code changes except printk levels (although some of the K6
mtrr code might be clearer if there were a few as would
splitting out some of the intel cache code).
Signed-off-by: Alan Cox <alan@linux.intel.com>
LKML-Reference: <new-submission>
See "CPUID Specification" (AMD Publication #: 25481, Rev. 2.28, April 2008)
Cc: Mark Langsdorf <mark.langsdorf@amd.com>
LKML-Reference: <20090409134710.GA8026@alberich.amd.com>
(Use correct mask to zero out bits 24-28 by Andreas)
Signed-off-by: Mark Langsdorf <mark.langsdorf@amd.com>
LKML-Reference: <20090409132406.GK31527@alberich.amd.com>
Impact: replace sysfs attribute
Current interface violates against "one-value-per-sysfs-attribute
rule". This patch replaces current attribute with two attributes --
one for each L3 Cache Index Disable register.
LKML-Reference: <20090409131849.GJ31527@alberich.amd.com>
Impact: avoid code duplication
LKML-Reference: <20090409131617.GI31527@alberich.amd.com>
Impact: bug fix
If user writes to "cache_disable" attribute on a CPU that does not support
this feature, the process hangs due to an invalid return value in
store_cache_disable().
LKML-Reference: <20090409130729.GH31527@alberich.amd.com>
