commit 7cc23cd6c0c7d7f4bee057607e7ce01568925717 upstream.
We should always have proper privileges when requesting kernel
data.
Cc: eranian@google.com
Link: http://lkml.kernel.org/r/20130503121256.230745028@chello.nl
[ Fix build error reported by fengguang.wu@intel.com, propagate error code back. ]
Link: http://lkml.kernel.org/n/tip-v0x9ky3ahzr6nm3c6ilwrili@git.kernel.org
commit 6e15eb3ba6c0249c9e8c783517d131b47db995ca upstream.
The LBR 'from' adddress is under full userspace control; ensure
we validate it before reading from it.
Note: is_module_text_address() can potentially be quite
expensive; for those running into that with high overhead
in modules optimize it using an RCU backed rb-tree.
Reported-by: Andi Kleen <ak@linux.intel.com>
Link: http://lkml.kernel.org/r/20130503121256.158211806@chello.nl
Link: http://lkml.kernel.org/n/tip-mk8i82ffzax01cnqo829iy1q@git.kernel.org
This patch adds an internal sofware filter to complement
the (optional) LBR hardware filter.
The software filter is necessary:
- as a substitute when there is no HW LBR filter (e.g., Atom, Core)
- to complement HW LBR filter in case of errata (e.g., Nehalem/Westmere)
- to provide finer grain filtering (e.g., all processors)
Sometimes the LBR HW filter cannot distinguish between two types
of branches. For instance, to capture syscall as CALLS, it is necessary
to enable the LBR_FAR filter which will also capture JMP instructions.
Thus, a second pass is necessary to filter those out, this is what the
SW filter can do.
The SW filter is built on top of the internal x86 disassembler. It
is a best effort filter especially for user level code. It is subject
to the availability of the text page of the program.
The SW filter is enabled on all Intel processors. It is bypassed
when the user is capturing all branches at all priv levels.
Signed-off-by: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/1328826068-11713-9-git-send-email-eranian@google.com
This patch implements PERF_SAMPLE_BRANCH support for Intel
x86processors. It connects PERF_SAMPLE_BRANCH to the actual LBR.
The patch adds the hooks in the PMU irq handler to save the LBR
on counter overflow for both regular and PEBS modes.
Link: http://lkml.kernel.org/r/1328826068-11713-8-git-send-email-eranian@google.com
The patch adds a restriction for Intel Atom LBR support. Only
steppings 10 (PineView) and more recent are supported. Older models
do not have a functional LBR. Their LBR does not freeze on PMU
interrupt which makes LBR unusable in the context of perf_events.
Link: http://lkml.kernel.org/r/1328826068-11713-7-git-send-email-eranian@google.com
This patch adds the mappings from the generic PERF_SAMPLE_BRANCH_*
filters to the actual Intel x86LBR filters, whenever they exist.
Link: http://lkml.kernel.org/r/1328826068-11713-6-git-send-email-eranian@google.com
This patch adds the LBR definitions for NHM/WSM/SNB and Core.
It also adds the definitions for the architected LBR MSR:
LBR_SELECT, LBRT_TOS.
Link: http://lkml.kernel.org/r/1328826068-11713-3-git-send-email-eranian@google.com
This patch adds the ability to sample taken branches to the
perf_event interface.
The ability to capture taken branches is very useful for all
sorts of analysis. For instance, basic block profiling, call
counts, statistical call graph.
This new capability requires hardware assist and as such may
not be available on all HW platforms. On Intel x86 it is
implemented on top of the Last Branch Record (LBR) facility.
To enable taken branches sampling, the PERF_SAMPLE_BRANCH_STACK
bit must be set in attr->sample_type.
Sampled taken branches may be filtered by type and/or priv
levels.
The patch adds a new field, called branch_sample_type, to the
perf_event_attr structure. It contains a bitmask of filters
to apply to the sampled taken branches.
Filters may be implemented in HW. If the HW filter does not exist
or is not good enough, some arch may also implement a SW filter.
The following generic filters are currently defined:
- PERF_SAMPLE_USER
only branches whose targets are at the user level
- PERF_SAMPLE_KERNEL
only branches whose targets are at the kernel level
- PERF_SAMPLE_HV
only branches whose targets are at the hypervisor level
- PERF_SAMPLE_ANY
any type of branches (subject to priv levels filters)
- PERF_SAMPLE_ANY_CALL
any call branches (may incl. syscall on some arch)
- PERF_SAMPLE_ANY_RET
any return branches (may incl. syscall returns on some arch)
- PERF_SAMPLE_IND_CALL
indirect call branches
Obviously filter may be combined. The priv level bits are optional.
If not provided, the priv level of the associated event are used. It
is possible to collect branches at a priv level different from the
associated event. Use of kernel, hv priv levels is subject to permissions
and availability (hv).
The number of taken branch records present in each sample may vary based
on HW, the type of sampled branches, the executed code. Therefore
each sample contains the number of taken branches it contains.
Link: http://lkml.kernel.org/r/1328826068-11713-2-git-send-email-eranian@google.com
With the new throttling/unthrottling code introduced with
commit:
e050e3f0a71b ("perf: Fix broken interrupt rate throttling")
we occasionally hit two WARN_ON_ONCE() checks in:
- intel_pmu_pebs_enable()
- intel_pmu_lbr_enable()
- x86_pmu_start()
The assertions are no longer problematic. There is a valid
path where they can trigger but it is harmless.
The assertion can be triggered with:
$ perf record -e instructions:pp ....
Leading to paths:
intel_pmu_enable_event
x86_perf_event_set_period
x86_pmu_start
perf_adjust_freq_unthr_context
perf_event_task_tick
scheduler_tick
And:
x86_pmu_start
perf_adjust_freq_unthr_context.
scheduler_tick
cpuc->enabled is always on because when we get to
perf_adjust_freq_unthr_context() the PMU is not totally
disabled. Furthermore when we need to adjust a period,
we only stop the event we need to change and not the
entire PMU. Thus, when we re-enable, cpuc->enabled is
already set. Note that when we stop the event, both
pebs and lbr are stopped if necessary (and possible).
Cc: peterz@infradead.org
Link: http://lkml.kernel.org/r/20120202110401.GA30911@quad
The CPU support for perf events on x86 was implemented via included C files
with #ifdefs. Clean this up by creating a new header file and compiling
the vendor-specific files as needed.
Signed-off-by: Kevin Winchester <kjwinchester@gmail.com>
Link: http://lkml.kernel.org/r/1314747665-2090-1-git-send-email-kjwinchester@gmail.com
Move all debugctlmsr thingies into msr-index.h
LKML-Reference: <20100325135413.861425293@chello.nl>
Don't decrement the TOS twice...
Cc: Arnaldo Carvalho de Melo <acme@infradead.org>
Cc: paulus@samba.org
Cc: robert.richter@amd.com
Cc: fweisbec@gmail.com
LKML-Reference: <new-submission>
If we reset the LBR on each first counter, simple counter rotation which
first deschedules all counters and then reschedules the new ones will
lead to LBR reset, even though we're still in the same task context.
Reduce this by not flushing on the first counter but only flushing on
different task contexts.
We should never call ->enable with the pmu enabled, and we _can_ have
->disable called with the pmu enabled.
Some CPUs have errata where the LBR is not cleared on Power-On. So always
clear the LBRs before use.
LKML-Reference: <20100305154128.966563424@chello.nl>
Saner PERF_CAPABILITIES support, which also exposes pebs_trap. Use that
latter to make PEBS's use of LBR conditional since a fault-like pebs
should already report the correct IP.
( As of this writing there is no known hardware that implements
!pebs_trap )
LKML-Reference: <20100304140100.770650663@chello.nl>
Implement simple suport Intel Last-Branch-Record, it supports all
hardware that implements FREEZE_LBRS_ON_PMI, but does not (yet) implement
the LBR config register.
The Intel LBR is a FIFO of From,To addresses describing the last few
branches the hardware took.
This patch does not add perf interface to the LBR, but merely provides an
interface for internal use.
LKML-Reference: <20100304140100.544191154@chello.nl>
