commit 4fe2d8b11a370af286287a2661de9d4e6c9a145a upstream.
If the kernel oopses while on the trampoline stack, it will print
"<SYSENTER>" even if SYSENTER is not involved. That is rather confusing.
The "SYSENTER" stack is used for a lot more than SYSENTER now. Give it a
better string to display in stack dumps, and rename the kernel code to
match.
Also move the 32-bit code over to the new naming even though it still uses
the entry stack only for SYSENTER.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Juergen Gross <jgross@suse.com>
commit 33a2f1a6c4d7c0a02d1c006fb0379cc5ca3b96bb upstream.
get_stack_info() doesn't currently know about the SYSENTER stack, so
unwinding will fail if we entered the kernel on the SYSENTER stack
and haven't fully switched off. Teach get_stack_info() about the
SYSENTER stack.
With future patches applied that run part of the entry code on the
SYSENTER stack and introduce an intentional BUG(), I would get:
PANIC: double fault, error_code: 0x0
RIP: 0010:do_error_trap+0x33/0x1c0
Call Trace:
Code: ...
With this patch, I get:
Call Trace:
<SYSENTER>
? async_page_fault+0x36/0x60
? invalid_op+0x22/0x40
? sync_regs+0x3c/0x40
? sync_regs+0x2e/0x40
? error_entry+0x6c/0xd0
</SYSENTER>
Code: ...
which is a lot more informative.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Reviewed-by: Borislav Petkov <bp@suse.de>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Borislav Petkov <bpetkov@suse.de>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: David Laight <David.Laight@aculab.com>
Cc: Eduardo Valentin <eduval@amazon.com>
Cc: Greg KH <gregkh@linuxfoundation.org>
Cc: aliguori@amazon.com
Cc: daniel.gruss@iaik.tugraz.at
Cc: hughd@google.com
Cc: keescook@google.com
Link: https://lkml.kernel.org/r/20171204150605.392711508@linutronix.de
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
On x86_64, the double fault exception stack is located immediately after
the interrupt stack in memory. This causes confusion in the unwinder
when it tries to unwind through an empty interrupt stack, where the
stack pointer points to the address bordering the two stacks. The
unwinder incorrectly thinks it's running on the double fault stack.
Fix this kind of stack border confusion by never considering the
beginning address of an exception or interrupt stack to be part of the
stack.
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Jiri Slaby <jslaby@suse.cz>
Cc: live-patching@vger.kernel.org
Fixes: 5fe599e02e41 ("x86/dumpstack: Add support for unwinding empty IRQ stacks")
Link: http://lkml.kernel.org/r/bcc142160a5104de5c354c21c394c93a0173943f.1499786555.git.jpoimboe@redhat.com
By using "UD0" for WARN()s we remove the function call and its possible
__FILE__ and __LINE__ immediate arguments from the instruction stream.
Total image size will not change much, what we win in the instruction
stream we'll lose because of the __bug_table entries. Still, saves on
I$ footprint and the total image size does go down a bit.
text data filename
10702123 4530992 defconfig-build/vmlinux.orig
10682460 4530992 defconfig-build/vmlinux.patched
(UML didn't seem to use GENERIC_BUG at all, so remove it)
Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Richard Weinberger <richard.weinberger@gmail.com>
<linux/sched/debug.h>
We are going to split <linux/sched/debug.h> out of <linux/sched.h>, which
will have to be picked up from other headers and a couple of .c files.
Create a trivial placeholder <linux/sched/debug.h> file that just
maps to <linux/sched.h> to make this patch obviously correct and
bisectable.
Include the new header in the files that are going to need it.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
NMI stack dumps are bracketed by the following tags:
<NMI>
<EOE>
The ending tag is kind of confusing if you don't already know what "EOE"
means (end of exception). The same ending tag is also used to mark the
end of all other exceptions' stacks. For example:
<#DF>
<EOE>
And similarly, "EOI" is used as the ending tag for interrupts:
<IRQ>
<EOI>
Change the tags to be more comprehensible by making them symmetrical and
more XML-esque:
<NMI>
</NMI>
<#DF>
</#DF>
<IRQ>
</IRQ>
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Link: http://lkml.kernel.org/r/180196e3754572540b595bc56b947d43658979a7.1479491159.git.jpoimboe@redhat.com
Print a warning if stack recursion is detected.
Use printk_deferred_once() because the unwinder can be called with the
console lock by lockdep via save_stack_trace().
Link: http://lkml.kernel.org/r/def18247aafaab480844484398e793f552b79bda.1477496147.git.jpoimboe@redhat.com
[ Unbroke the lines. ]
For mostly historical reasons, the x86 oops dump shows the raw stack
values:
[registers]
Stack:
ffff880079af7350 ffff880079905400 0000000000000000 ffffc900008f3ae0
ffffffffa0196610 0000000000000001 00010000ffffffff 0000000087654321
0000000000000002 0000000000000000 0000000000000000 0000000000000000
Call Trace:
This seems to be an artifact from long ago, and probably isn't needed
anymore. It generally just adds noise to the dump, and it can be
actively harmful because it leaks kernel addresses.
Linus says:
"The stack dump actually goes back to forever, and it used to be
useful back in 1992 or so. But it used to be useful mainly because
stacks were simpler and we didn't have very good call traces anyway. I
definitely remember having used them - I just do not remember having
used them in the last ten+ years.
Of course, it's still true that if you can trigger an oops, you've
likely already lost the security game, but since the stack dump is so
useless, let's aim to just remove it and make games like the above
harder."
This also removes the related 'kstack=' cmdline option and the
'kstack_depth_to_print' sysctl.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Link: http://lkml.kernel.org/r/e83bd50df52d8fe88e94d2566426ae40d813bf8f.1477405374.git.jpoimboe@redhat.com
All previous users of dump_trace() have been converted to use the new
unwind interfaces, so we can remove it and the related
print_context_stack() and print_context_stack_bp() callback functions.
Cc: Byungchul Park <byungchul.park@lge.com>
Cc: Nilay Vaish <nilayvaish@gmail.com>
Link: http://lkml.kernel.org/r/5b97da3572b40b5a4d8e185cf2429308d0987a13.1474045023.git.jpoimboe@redhat.com
Convert show_trace_log_lvl() to use the new unwinder. dump_trace() has
been deprecated.
show_trace_log_lvl() is special compared to other users of the unwinder.
It's the only place where both reliable *and* unreliable addresses are
needed. With frame pointers enabled, most callers of the unwinder don't
want to know about unreliable addresses. But in this case, when we're
dumping the stack to the console because something presumably went
wrong, the unreliable addresses are useful:
- They show stale data on the stack which can provide useful clues.
- If something goes wrong with the unwinder, or if frame pointers are
corrupt or missing, all the stack addresses still get shown.
So in order to show all addresses on the stack, and at the same time
figure out which addresses are reliable, we have to do the scanning and
the unwinding in parallel.
The scanning is done with the help of get_stack_info() to traverse the
stacks. The unwinding is done separately by the new unwinder.
In theory we could simplify show_trace_log_lvl() by instead pushing some
of this logic into the unwind code. But then we would need some kind of
"fake" frame logic in the unwinder which would add a lot of complexity
and wouldn't be worth it in order to support only one user.
Another benefit of this approach is that once we have a DWARF unwinder,
we should be able to just plug it in with minimal impact to this code.
Another change here is that callers of show_trace_log_lvl() don't need
to provide the 'bp' argument. The unwinder already finds the relevant
frame pointer by unwinding until it reaches the first frame after the
provided stack pointer.
Link: http://lkml.kernel.org/r/703b5998604c712a1f801874b43f35d6dac52ede.1474045023.git.jpoimboe@redhat.com
show_stack_log_lvl() and friends allow a NULL pointer for the
task_struct to indicate the current task. This creates confusion and
can cause sneaky bugs.
Instead require the caller to pass 'current' directly.
This only changes the internal workings of the dumpstack code. The
dump_trace() and show_stack() interfaces still allow a NULL task
pointer. Those interfaces should also probably be fixed as well.
Specifically, pin the stack in save_stack_trace_tsk() and
show_trace_log_lvl().
This will prevent a crash if the target task dies before or while
dumping its stack once we start freeing task stacks early.
Cc: Jann Horn <jann@thejh.net>
Link: http://lkml.kernel.org/r/cf0082cde65d1941a996d026f2b2cdbfaca17bfa.1474003868.git.luto@kernel.org
in_exception_stack() has some recursion checking which makes sure the
stack trace code never traverses a given exception stack more than once.
This prevents an infinite loop if corruption somehow causes a stack's
"next stack" pointer to point to itself (directly or indirectly).
The recursion checking can be useful for other stacks in addition to the
exception stack, so extend it to work for all stacks.
Link: http://lkml.kernel.org/r/95de5db4cfe111754845a5cef04e20630d01423f.1473905218.git.jpoimboe@redhat.com
When an interrupt happens in entry code while running on a software IRQ
stack, and the IRQ stack was empty, regs->sp will contain the stack end
address (e.g., irq_stack_ptr). If the regs are passed to dump_trace(),
get_stack_info() will report STACK_TYPE_UNKNOWN, causing dump_trace() to
return prematurely without trying to go to the next stack.
Update the bounds checking for software interrupt stacks so that the
ending address is now considered part of the stack.
This means that it's now possible for the 'walk_stack' callbacks --
print_context_stack() and print_context_stack_bp() -- to be called with
an empty stack. But that's fine; they're already prepared to deal with
that due to their on_stack() checks.
Link: http://lkml.kernel.org/r/5a5e5de92dcf11e8dc6b6e8e50ad7639d067830b.1473905218.git.jpoimboe@redhat.com
valid_stack_ptr() is buggy: it assumes that all stacks are of size
THREAD_SIZE, which is not true for exception stacks. So the
walk_stack() callbacks will need to know the location of the beginning
of the stack as well as the end.
Another issue is that in general the various features of a stack (type,
size, next stack pointer, description string) are scattered around in
various places throughout the stack dump code.
Encapsulate all that information in a single place with a new stack_info
struct and a get_stack_info() interface.
Link: http://lkml.kernel.org/r/8164dd0db96b7e6a279fa17ae5e6dc375eecb4a9.1473905218.git.jpoimboe@redhat.com
show_stack_log_lvl() and dump_trace() are already preemption safe:
- If they're running in irq or exception context, preemption is already
disabled and the percpu stack pointers can be trusted.
- If they're running with preemption enabled, they must be running on
the task stack anyway, so it doesn't matter if they're comparing the
stack pointer against a percpu stack pointer from this CPU or another
one: either way it won't match.
Link: http://lkml.kernel.org/r/a0ca0b1044eca97d4f0ec7c1619cf80b3b65560d.1473371307.git.jpoimboe@redhat.com
When calling show_stack_log_lvl() or dump_trace() with a regs argument,
providing a stack pointer or frame pointer is redundant.
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>d
Reviewed-by: Andy Lutomirski <luto@kernel.org>
Link: http://lkml.kernel.org/r/1694e2e955e3b9a73a3c3d5ba2634344014dd550.1472057064.git.jpoimboe@redhat.com
The various functions involved in dumping the stack all do similar
things with regard to getting the stack pointer and the frame pointer
based on the regs and task arguments. Create helper functions to
do that instead.
Link: http://lkml.kernel.org/r/f448914885a35f333fe04da1b97a6c2cc1f80974.1472057064.git.jpoimboe@redhat.com
Pull x86 header cleanups from Ingo Molnar:
"This tree is a cleanup of the x86 tree reducing spurious uses of
module.h - which should improve build performance a bit"
* 'x86-headers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, crypto: Restore MODULE_LICENSE() to glue_helper.c so it loads
x86/apic: Remove duplicated include from probe_64.c
x86/ce4100: Remove duplicated include from ce4100.c
x86/headers: Include spinlock_types.h in x8664_ksyms_64.c for missing spinlock_t
x86/platform: Delete extraneous MODULE_* tags fromm ts5500
x86: Audit and remove any remaining unnecessary uses of module.h
x86/kvm: Audit and remove any unnecessary uses of module.h
x86/xen: Audit and remove any unnecessary uses of module.h
x86/platform: Audit and remove any unnecessary uses of module.h
x86/lib: Audit and remove any unnecessary uses of module.h
x86/kernel: Audit and remove any unnecessary uses of module.h
x86/mm: Audit and remove any unnecessary uses of module.h
x86: Don't use module.h just for AUTHOR / LICENSE tags
Historically a lot of these existed because we did not have
a distinction between what was modular code and what was providing
support to modules via EXPORT_SYMBOL and friends. That changed
when we forked out support for the latter into the export.h file.
This means we should be able to reduce the usage of module.h
in code that is obj-y Makefile or bool Kconfig. The advantage
in doing so is that module.h itself sources about 15 other headers;
adding significantly to what we feed cpp, and it can obscure what
headers we are effectively using.
Since module.h was the source for init.h (for __init) and for
export.h (for EXPORT_SYMBOL) we consider each obj-y/bool instance
for the presence of either and replace as needed. Build testing
revealed some implicit header usage that was fixed up accordingly.
Note that some bool/obj-y instances remain since module.h is
the header for some exception table entry stuff, and for things
like __init_or_module (code that is tossed when MODULES=n).
Link: http://lkml.kernel.org/r/20160714001901.31603-4-paul.gortmaker@windriver.com
The comment suggests that show_stack(NULL, NULL) should backtrace the
current context, but the code doesn't match the comment. If regs are
given, start the "Stack:" hexdump at regs->sp.
Link: http://lkml.kernel.org/r/1467671487-10344-2-git-send-email-bp@alien8.de
Link: http://lkml.kernel.org/r/efcd79bf4106d61f1cd258c2caa87f3a0618eeac.1466036668.git.luto@kernel.org
None of the code actually wants a thread_info, it all wants a
task_struct, and it's just converting to a thread_info pointer much too
early.
No semantic change.
Pull x86 debug changes from Ingo Molnar:
"Stack printing fixlets"
* 'x86-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/kernel: Use kstack_end() in dumpstack_64.c
x86/kernel: Fix output of show_stack_log_lvl()
user_mode_vm() and user_mode() are now the same. Change all callers
of user_mode_vm() to user_mode().
The next patch will remove the definition of user_mode_vm.
Cc: Brad Spengler <spender@grsecurity.net>
Link: http://lkml.kernel.org/r/43b1f57f3df70df5a08b0925897c660725015554.1426728647.git.luto@kernel.org
[ Merged to a more recent kernel. ]
show_stack_log_lvl() does not set the log level after a new line, the
following messages printed with pr_cont() are thus assigned to the
default log level.
This patch prepends the log level to the next message following a new
line.
print_trace_address() uses printk(log_lvl). Using printk() with just
a log level is ignored and thus has no effect on the next pr_cont().
We need to prepend the log level directly into the message.
Signed-off-by: Adrien Schildknecht <adrien+dev@schischi.me>
Acked-by: Ingo Molnar <mingo@kernel.org>
Link: http://lkml.kernel.org/r/1424399661-20327-1-git-send-email-adrien+dev@schischi.me
Pull x86 threadinfo changes from Ingo Molnar:
"The main change here is the consolidation/unification of 32 and 64 bit
thread_info handling methods, from Steve Rostedt"
* 'x86-threadinfo-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, threadinfo: Redo "x86: Use inline assembler to get sp"
x86: Clean up dumpstack_64.c code
x86: Keep thread_info on thread stack in x86_32
x86: Prepare removal of previous_esp from i386 thread_info structure
x86: Nuke GET_THREAD_INFO_WITH_ESP() macro for i386
x86: Nuke the supervisor_stack field in i386 thread_info
Commit 028a690a1ebc8b "i386: Remove unneeded test of 'task' in
dump_trace()" correctly removed the unneeded 'task != NULL'
check because it would be set to current if it was NULL.
Commit 2bc5f927d489 "i386: split out dumpstack code from
traps_32.c" moved the code from traps_32.c to its own file
dump_stack.c for preparation of the i386 / x86_64 merge.
Commit 8a541665b906 "dumpstack: x86: various small unification
steps" worked to make i386 and x86_64 dump_stack logic similar.
But this actually reverted the correct change from
028a690a1ebc8b.
Commit d0caf292505d "x86/dumpstack: Remove unneeded check in
dump_trace()" removed the unneeded "task != NULL" check for
x86_64 but left that same unneeded check for i386, that was
added because x86_64 had it!
This chain of events ironically had i386 add back the unneeded
task != NULL check because x86_64 did it, and then the fix for
x86_64 was fixed by Dan. And even more ironically, it was Dan's
smatch bot that told me that a change to dump_stack_32 I made
may be wrong if current can be NULL (it can't), as there was a
check for it by assigning task to current, and then checking if
task is NULL.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Acked-by: Alexander van Heukelum <heukelum@fastmail.fm>
Cc: Jesper Juhl <jesper.juhl@gmail.com>
Link: http://lkml.kernel.org/r/20140307105242.79a0befd@gandalf.local.home
x86_64 uses a per_cpu variable kernel_stack to always point to
the thread stack of current. This is where the thread_info is stored
and is accessed from this location even when the irq or exception stack
is in use. This removes the complexity of having to maintain the
thread info on the stack when interrupts are running and having to
copy the preempt_count and other fields to the interrupt stack.
x86_32 uses the old method of copying the thread_info from the thread
stack to the exception stack just before executing the exception.
Having the two different requires #ifdefs and also the x86_32 way
is a bit of a pain to maintain. By converting x86_32 to the same
method of x86_64, we can remove #ifdefs, clean up the x86_32 code
a little, and remove the overhead of the copy.
Link: http://lkml.kernel.org/r/20110806012354.263834829@goodmis.org
Link: http://lkml.kernel.org/r/20140206144321.852942014@goodmis.org
The i386 thread_info contains a previous_esp field that is used
to daisy chain the different stacks for dump_stack()
(ie. irq, softirq, thread stacks).
The goal is to eventual make i386 handling of thread_info the same
as x86_64, which means that the thread_info will not be in the stack
but as a per_cpu variable. We will no longer depend on thread_info
being able to daisy chain different stacks as it will only exist
in one location (the thread stack).
By moving previous_esp to the end of thread_info and referencing
it as an offset instead of using a thread_info field, this becomes
a stepping stone to moving the thread_info.
The offset to get to the previous stack is rather ugly in this
patch, but this is only temporary and the prev_esp will be changed
in the next commit. This commit is more for sanity checks of the
change.
Cc: Robert Richter <rric@kernel.org>
Link: http://lkml.kernel.org/r/20110806012353.891757693@goodmis.org
Link: http://lkml.kernel.org/r/20140206144321.608754481@goodmis.org
show_regs() is inherently arch-dependent but it does make sense to print
generic debug information and some archs already do albeit in slightly
different forms. This patch introduces a generic function to print debug
information from show_regs() so that different archs print out the same
information and it's much easier to modify what's printed.
show_regs_print_info() prints out the same debug info as dump_stack()
does plus task and thread_info pointers.
* Archs which didn't print debug info now do.
alpha, arc, blackfin, c6x, cris, frv, h8300, hexagon, ia64, m32r,
metag, microblaze, mn10300, openrisc, parisc, score, sh64, sparc,
um, xtensa
* Already prints debug info. Replaced with show_regs_print_info().
The printed information is superset of what used to be there.
arm, arm64, avr32, mips, powerpc, sh32, tile, unicore32, x86
* s390 is special in that it used to print arch-specific information
along with generic debug info. Heiko and Martin think that the
arch-specific extra isn't worth keeping s390 specfic implementation.
Converted to use the generic version.
Note that now all archs print the debug info before actual register
dumps.
An example BUG() dump follows.
kernel BUG at /work/os/work/kernel/workqueue.c:4841!
invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #7
Hardware name: empty empty/S3992, BIOS 080011 10/26/2007
task: ffff88007c85e040 ti: ffff88007c860000 task.ti: ffff88007c860000
RIP: 0010:[<ffffffff8234a07e>] [<ffffffff8234a07e>] init_workqueues+0x4/0x6
RSP: 0000:ffff88007c861ec8 EFLAGS: 00010246
RAX: ffff88007c861fd8 RBX: ffffffff824466a8 RCX: 0000000000000001
RDX: 0000000000000046 RSI: 0000000000000001 RDI: ffffffff8234a07a
RBP: ffff88007c861ec8 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000000 R12: ffffffff8234a07a
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffff88007dc00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: ffff88015f7ff000 CR3: 00000000021f1000 CR4: 00000000000007f0
Stack:
ffff88007c861ef8 ffffffff81000312 ffffffff824466a8 ffff88007c85e650
0000000000000003 0000000000000000 ffff88007c861f38 ffffffff82335e5d
ffff88007c862080 ffffffff8223d8c0 ffff88007c862080 ffffffff81c47760
Call Trace:
[<ffffffff81000312>] do_one_initcall+0x122/0x170
[<ffffffff82335e5d>] kernel_init_freeable+0x9b/0x1c8
[<ffffffff81c47760>] ? rest_init+0x140/0x140
[<ffffffff81c4776e>] kernel_init+0xe/0xf0
[<ffffffff81c6be9c>] ret_from_fork+0x7c/0xb0
v2: Typo fix in x86-32.
v3: CPU number dropped from show_regs_print_info() as
dump_stack_print_info() has been updated to print it. s390
specific implementation dropped as requested by s390 maintainers.
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Chris Metcalf <cmetcalf@tilera.com> [tile bits]
Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits]
Printing the list of loaded modules is really unrelated to what
this function is about, and is particularly unnecessary in the
context of the SysRQ key handling (gets printed so far over and
over).
It should really be the caller of the function to decide whether
this piece of information is useful (and to avoid redundantly
printing it).
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Link: http://lkml.kernel.org/r/4FDF21A4020000780008A67F@nat28.tlf.novell.com
Use a more current logging style:
- Bare printks should have a KERN_<LEVEL> for consistency's sake
- Add pr_fmt where appropriate
- Neaten some macro definitions
- Convert some Ok output to OK
- Use "%s: ", __func__ in pr_fmt for summit
- Convert some printks to pr_<level>
Message output is not identical in all cases.
Cc: levinsasha928@gmail.com
Link: http://lkml.kernel.org/r/1337655007.24226.10.camel@joe2Laptop
[ merged two similar patches, tidied up the changelog ]
What was called show_registers() so far already showed a stack
trace for kernel faults, and kernel_stack_pointer() isn't even
valid to be used for faults from user mode, hence it was
pointless for show_regs() to call show_trace() after
show_registers().
Simply rename show_registers() to show_regs() and eliminate
the old definition.
Link: http://lkml.kernel.org/r/4FAA3D3902000078000826E1@nat28.tlf.novell.com
While for a user mode register dump it may be reasonable to skip
those (albeit x86-64 doesn't do so), for kernel mode dumps these
should be printed to make sure all information possibly
necessary for analysis is available.
Link: http://lkml.kernel.org/r/4F58889202000078000770E7@nat28.tlf.novell.com
When printing the code bytes in show_registers(), the markers around the
byte at the fault address could make the printk() format string look
like a valid log level and facility code. This would prevent this byte
from being printed and result in a spurious newline:
[ 7555.765589] Code: 8b 32 e9 94 00 00 00 81 7d 00 ff 00 00 00 0f 87 96 00 00 00 48 8b 83 c0 00 00 00 44 89 e2 44 89 e6 48 89 df 48 8b 80 d8 02 00 00
[ 7555.765683] 8b 48 28 48 89 d0 81 e2 ff 0f 00 00 48 c1 e8 0c 48 c1 e0 04
Add KERN_CONT where needed, and elsewhere in show_registers() for
consistency.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Link: http://lkml.kernel.org/r/4EEFA7AE.9020407@ladisch.de
Current stack dump code scans entire stack and check each entry
contains a pointer to kernel code. If CONFIG_FRAME_POINTER=y it
could mark whether the pointer is valid or not based on value of
the frame pointer. Invalid entries could be preceded by '?' sign.
However this was not going to happen because scan start point
was always higher than the frame pointer so that they could not
meet.
Commit 9c0729dc8062 ("x86: Eliminate bp argument from the stack
tracing routines") delayed bp acquisition point, so the bp was
read in lower frame, thus all of the entries were marked
invalid.
This patch fixes this by reverting above commit while retaining
stack_frame() helper as suggested by Frederic Weisbecker.
End result looks like below:
before:
[ 3.508329] Call Trace:
[ 3.508551] [<ffffffff814f35c9>] ? panic+0x91/0x199
[ 3.508662] [<ffffffff814f3739>] ? printk+0x68/0x6a
[ 3.508770] [<ffffffff81a981b2>] ? mount_block_root+0x257/0x26e
[ 3.508876] [<ffffffff81a9821f>] ? mount_root+0x56/0x5a
[ 3.508975] [<ffffffff81a98393>] ? prepare_namespace+0x170/0x1a9
[ 3.509216] [<ffffffff81a9772b>] ? kernel_init+0x1d2/0x1e2
[ 3.509335] [<ffffffff81003894>] ? kernel_thread_helper+0x4/0x10
[ 3.509442] [<ffffffff814f6880>] ? restore_args+0x0/0x30
[ 3.509542] [<ffffffff81a97559>] ? kernel_init+0x0/0x1e2
[ 3.509641] [<ffffffff81003890>] ? kernel_thread_helper+0x0/0x10
after:
[ 3.522991] Call Trace:
[ 3.523351] [<ffffffff814f35b9>] panic+0x91/0x199
[ 3.523468] [<ffffffff814f3729>] ? printk+0x68/0x6a
[ 3.523576] [<ffffffff81a981b2>] mount_block_root+0x257/0x26e
[ 3.523681] [<ffffffff81a9821f>] mount_root+0x56/0x5a
[ 3.523780] [<ffffffff81a98393>] prepare_namespace+0x170/0x1a9
[ 3.523885] [<ffffffff81a9772b>] kernel_init+0x1d2/0x1e2
[ 3.523987] [<ffffffff81003894>] kernel_thread_helper+0x4/0x10
[ 3.524228] [<ffffffff814f6880>] ? restore_args+0x0/0x30
[ 3.524345] [<ffffffff81a97559>] ? kernel_init+0x0/0x1e2
[ 3.524445] [<ffffffff81003890>] ? kernel_thread_helper+0x0/0x10
-v5:
* fix build breakage with oprofile
-v4:
* use 0 instead of regs->bp
* separate out printk changes
-v3:
* apply comment from Frederic
* add a couple of printk fixes
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: Soren Sandmann <ssp@redhat.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Robert Richter <robert.richter@amd.com>
LKML-Reference: <1300416006-3163-1-git-send-email-namhyung@gmail.com>
The various stack tracing routines take a 'bp' argument in which the
caller is supposed to provide the base pointer to use, or 0 if doesn't
have one. Since bp is garbage whenever CONFIG_FRAME_POINTER is not
defined, this means all callers in principle should either always pass
0, or be conditional on CONFIG_FRAME_POINTER.
However, there are only really three use cases for stack tracing:
(a) Trace the current task, including IRQ stack if any
(b) Trace the current task, but skip IRQ stack
(c) Trace some other task
In all cases, if CONFIG_FRAME_POINTER is not defined, bp should just
be 0. If it _is_ defined, then
- in case (a) bp should be gotten directly from the CPU's register, so
the caller should pass NULL for regs,
- in case (b) the caller should should pass the IRQ registers to
dump_trace(),
- in case (c) bp should be gotten from the top of the task's stack, so
the caller should pass NULL for regs.
Hence, the bp argument is not necessary because the combination of
task and regs is sufficient to determine an appropriate value for bp.
This patch introduces a new inline function stack_frame(task, regs)
that computes the desired bp. This function is then called from the
two versions of dump_stack().
Signed-off-by: Soren Sandmann <ssp@redhat.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Arjan van de Ven <arjan@infradead.org>,
Cc: Frederic Weisbecker <fweisbec@gmail.com>,
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>,
LKML-Reference: <m3oc9rop28.fsf@dhcp-100-3-82.bos.redhat.com>>
The stack output currently looks like this:
7fffffffffffffff 0000000a00000000 ffffffff81093341 0000000000000046
<0> ffff88003a545fd8 0000000000000000 0000000000000000 00007fffa39769c0
<0> ffff88003e403f58 ffffffff8102fc4c ffff88003e403f58 ffff88003e403f78
The superfluous <0> are caused by recent printk KERN_CONT
change. <*> is now ignored in printk unless some text follows
the level and even then it still has to be the first in the
format message.
Note that the log_lvl parameter is now completely ignored in
show_stack_log_lvl and the stack is dumped with the default
level (like for quite some time already). It behaves the same as
the rest of the dump, function traces are dumped in the very
same manner. Only Code and maybe some lines are printed with
EMERG level.
Unfortunately I see no way how to fix this conceptually to have
the whole oops/BUG/panic output with the same level, so this
removed only the superfluous characters for the time being.
Just for illustration:
<4>Process kworker/0:0 (pid: 0, threadinfo ffff88003c8a6000, task ffff88003c85c100)
<0>Stack:
<4> ffffffff818022c0 0000000a00000001 0000000000000001 0000000000000046
<4> ffff88003c8a7fd8 0000000000000001 ffff88003c8a7e58 0000000000000000
<4> ffff88003e503f48 ffffffff8102fc4c ffff88003e503f48 ffff88003e503f68
<0>Call Trace:
<0> <IRQ>
<4> [<ffffffff8102fc4c>] ? call_softirq+0x1c/0x30 ...
<0>Code: 00 01 00 00 65 8b 04 25 80 c5 00 00 c7 45 ...
Cc: jirislaby@gmail.com
LKML-Reference: <1287586131-16222-1-git-send-email-jslaby@suse.cz>
arch/x86/include/asm/stacktrace.h and arch/x86/kernel/dumpstack.h
declare headers of objects that deal with the same topic.
Actually most of the files that include stacktrace.h also include
dumpstack.h
Although dumpstack.h seems more reserved for internals of stack
traces, those are quite often needed to define specialized stack
trace operations. And perf event arch headers are going to need
access to such low level operations anyway. So don't continue to
bother with dumpstack.h as it's not anymore about isolated deep
internals.
v2: fix struct stack_frame definition conflict in sysprof
Cc: Soeren Sandmann <sandmann@daimi.au.dk>
The check that ignores the debug and nmi stack frames is useless
now that we have a frame pointer that makes us start at the
right place. We don't anymore have to deal with these.
LKML-Reference: <1262235183-5320-2-git-send-regression-fweisbec@gmail.com>
The current print_context_stack helper that does the stack
walking job is good for usual stacktraces as it walks through
all the stack and reports even addresses that look unreliable,
which is nice when we don't have frame pointers for example.
But we have users like perf that only require reliable
stacktraces, and those may want a more adapted stack walker, so
lets make this function a callback in stacktrace_ops that users
can tune for their needs.
LKML-Reference: <1261024834-5336-1-git-send-regression-fweisbec@gmail.com>
Make the initialization more readable, plus tidy up a few small
visual details as well.
No change in functionality.
LKML-Reference: <new-submission>
* remove asm/atomic.h inclusion from linux/utsname.h --
not needed after kref conversion
* remove linux/utsname.h inclusion from files which do not need it
NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however
due to some personality stuff it _is_ needed -- cowardly leave ELF-related
headers and files alone.
About every callchains recorded with perf record are filled up
including the internal perfcounter nmi frame:
perf_callchain
perf_counter_overflow
intel_pmu_handle_irq
perf_counter_nmi_handler
notifier_call_chain
atomic_notifier_call_chain
notify_die
do_nmi
nmi
We want ignore this frame as it's not interesting for
instrumentation. To solve this, we simply ignore every frames
from nmi context.
New example of "perf report -s sym -c" after this patch:
9.59% [k] search_by_key
4.88%
search_by_key
reiserfs_read_locked_inode
reiserfs_iget
reiserfs_lookup
do_lookup
__link_path_walk
path_walk
do_path_lookup
user_path_at
vfs_fstatat
vfs_lstat
sys_newlstat
system_call_fastpath
__lxstat
0x406fb1
3.19%
search_by_key
search_by_entry_key
reiserfs_find_entry
reiserfs_lookup
do_lookup
__link_path_walk
path_walk
do_path_lookup
user_path_at
vfs_fstatat
vfs_lstat
sys_newlstat
__lxstat
0x406fb1
For now this patch only solves the problem in x86-64.
LKML-Reference: <1246474930-6088-1-git-send-email-fweisbec@gmail.com>
Impact: better dumpstack output
I noticed in my crash dumps and even in the stack tracer that a
lot of functions listed in the stack trace are simply
return_to_handler which is ftrace graphs way to insert its own
call into the return of a function.
But we lose out where the actually function was called from.
This patch adds in hooks to the dumpstack mechanism that detects
this and finds the real function to print. Both are printed to
let the user know that a hook is still in place.
This does give a funny side effect in the stack tracer output:
Depth Size Location (80 entries)
0) 4144 48 save_stack_trace+0x2f/0x4d
1) 4096 128 ftrace_call+0x5/0x2b
2) 3968 16 mempool_alloc_slab+0x16/0x18
3) 3952 384 return_to_handler+0x0/0x73
4) 3568 -240 stack_trace_call+0x11d/0x209
5) 3808 144 return_to_handler+0x0/0x73
6) 3664 -128 mempool_alloc+0x4d/0xfe
7) 3792 128 return_to_handler+0x0/0x73
8) 3664 -32 scsi_sg_alloc+0x48/0x4a [scsi_mod]
As you can see, the real functions are now negative. This is due
to them not being found inside the stack.
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
Impact: cleanup
As promised, now that dumpstack_32 and dumpstack_64 have so many bits
in common, we should merge the in-sync bits into a common file, to
prevent them from diverging again.
This patch removes bits which are common between dumpstack_32.c and
dumpstack_64.c and places them in a common dumpstack.c which is built
for both 32 and 64 bit arches.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Makefile | 2
arch/x86/kernel/Makefile | 2
arch/x86/kernel/dumpstack.c | 319 +++++++++++++++++++++++++++++++++++++++++
arch/x86/kernel/dumpstack.h | 39 +++++
arch/x86/kernel/dumpstack_32.c | 294 -------------------------------------
arch/x86/kernel/dumpstack_64.c | 285 ------------------------------------
5 files changed, 363 insertions(+), 576 deletions(-)
Make i386's die() equal to x86_64's version.
Whitespace-only changes on x86_64, to make it equal to i386's
version. (user_mode and user_mode_vm are equal on x86_64.)
Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm>
Use oops_begin and oops_end in die_nmi.
version.
oops_begin/oops_end should always be used in pairs. On x86_64
oops_begin increments die_nest_count, and oops_end decrements
die_nest_count. Doing this makes oops_begin and oops_end equal
to the x86_64 versions.
