path: root/arch/x86/kernel/early-quirks.c
2008-01-30x86: fix section mismatch warning in early-quirks.cSam Ravnborg
Fix following warnings: WARNING: arch/x86/kernel/built-in.o(.text+0x139e1): Section mismatch: reference to .init.data:early_qrk in 'check_dev_quirk' WARNING: arch/x86/kernel/built-in.o(.text+0x139f5): Section mismatch: reference to .init.data:early_qrk in 'check_dev_quirk' WARNING: arch/x86/kernel/built-in.o(.text+0x13a0c): Section mismatch: reference to .init.data:early_qrk in 'check_dev_quirk' WARNING: arch/x86/kernel/built-in.o(.text+0x13a12): Section mismatch: reference to .init.data:early_qrk in 'check_dev_quirk' WARNING: arch/x86/kernel/built-in.o(.text+0x13a1a): Section mismatch: reference to .init.data:early_qrk in 'check_dev_quirk' WARNING: arch/x86/kernel/built-in.o(.text+0x13a36): Section mismatch: reference to .init.data:early_qrk in 'check_dev_quirk' WARNING: arch/x86/kernel/built-in.o(.text+0x13a42): Section mismatch: reference to .init.data: Warning was caused by access to the __initdata annotated variable from the non-annotated static function check_dev_quirk(). check_dev_quirk() were only used from a function annotated __init so add __init annotation to check_dev_quirk() to fix it. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: clean up arch/x86/kernel/early-quirks.cNeil Horman
clean up checkpatch errors. No code changed. text data bss dec hex filename 705 120 0 825 339 early-quirks.o.before 705 120 0 825 339 early-quirks.o.after Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86, kexec: force x86 arches to boot kdump kernels on boot cpuNeil Horman
Recently a kdump bug was discovered in which a system would hang inside calibrate_delay during the booting of the kdump kernel. This was caused by the fact that the jiffies counter was not being incremented during timer calibration. The root cause of this problem was found to be a bios misconfiguration of the hypertransport bus. On system affected by this hang, the bios had assigned APIC ids which used extended apic bits (more than the nominal 4 bit ids's), but failed to configure bit 17 of the hypertransport transaction config register, which indicated that the mask for the destination field of interrupt packets accross the ht bus (see section 3.3.9 of http://www.amd.com/us-en/assets/content_type/white_papers_and_tech_docs/26094.PDF). If a crash occurs on a cpu with an APIC id that extends beyond 4 bits, it will not recieve interrupts during the kdump kernel boot, and this hang will be the result. The fix is to add this patch, whcih add an early pci quirk check, to forcibly enable this bit in the httcfg register. This enables all cpus on a system to receive interrupts, and allows kdump kernel bootup to procede normally. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-30x86 gart: rename symbols only used for the GART implementationJoerg Roedel
This patch renames the 4 symbols iommu_hole_init(), iommu_aperture, iommu_aperture_allowed, iommu_aperture_disabled. All these symbols are only used for the GART implementation of IOMMUs. It adds and additional gart_ prefix to them. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-30x86 gart: rename CONFIG_IOMMU to CONFIG_GART_IOMMUJoerg Roedel
This patch renames the IOMMU config option to GART_IOMMU because in fact it means the GART and not general support for an IOMMU on x86. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Acked-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-30x86 gart: rename iommu.h to gart.hJoerg Roedel
This patch renames the include file asm-x86/iommu.h to asm-x86/gart.h to make clear to which IOMMU implementation it belongs. The patch also adds "GART" to the Kconfig line. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Acked-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-27x86: fix compiler warnings in arch/x86/kernel/early-quirks.cJeff Garzik
fix this warning: arch/x86/kernel/early-quirks.c:40: warning: nvidia_hpet_check defined but not used Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-19x86: Unify i386 and x86-64 early quirksAndi Kleen
They were already very similar; just use the same file now. [ tglx: arch/x86 adaptation ] Cc: lenb@kernel.org Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
