The bad syscall nr paths are their own incomprehensible route
through the entry control flow. Rearrange them to work just like
syscalls that return -ENOSYS.
This fixes an OOPS in the audit code when fast-path auditing is
enabled and sysenter gets a bad syscall nr (CVE-2014-4508).
This has probably been broken since Linux 2.6.27:
af0575bba0 i386 syscall audit fast-path
Cc: stable@vger.kernel.org
Cc: Roland McGrath <roland@redhat.com>
Reported-by: Toralf Förster <toralf.foerster@gmx.de>
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Link: http://lkml.kernel.org/r/e09c499eade6fc321266dd6b54da7beb28d6991c.1403558229.git.luto@amacapital.net
Pull more perf updates from Ingo Molnar:
"A second round of perf updates:
- wide reaching kprobes sanitization and robustization, with the hope
of fixing all 'probe this function crashes the kernel' bugs, by
Masami Hiramatsu.
- uprobes updates from Oleg Nesterov: tmpfs support, corner case
fixes and robustization work.
- perf tooling updates and fixes from Jiri Olsa, Namhyung Ki, Arnaldo
et al:
* Add support to accumulate hist periods (Namhyung Kim)
* various fixes, refactorings and enhancements"
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (101 commits)
perf: Differentiate exec() and non-exec() comm events
perf: Fix perf_event_comm() vs. exec() assumption
uprobes/x86: Rename arch_uprobe->def to ->defparam, minor comment updates
perf/documentation: Add description for conditional branch filter
perf/x86: Add conditional branch filtering support
perf/tool: Add conditional branch filter 'cond' to perf record
perf: Add new conditional branch filter 'PERF_SAMPLE_BRANCH_COND'
uprobes: Teach copy_insn() to support tmpfs
uprobes: Shift ->readpage check from __copy_insn() to uprobe_register()
perf/x86: Use common PMU interrupt disabled code
perf/ARM: Use common PMU interrupt disabled code
perf: Disable sampled events if no PMU interrupt
perf: Fix use after free in perf_remove_from_context()
perf tools: Fix 'make help' message error
perf record: Fix poll return value propagation
perf tools: Move elide bool into perf_hpp_fmt struct
perf tools: Remove elide setup for SORT_MODE__MEMORY mode
perf tools: Fix "==" into "=" in ui_browser__warning assignment
perf tools: Allow overriding sysfs and proc finding with env var
perf tools: Consider header files outside perf directory in tags target
Embedded systems, which may be very memory-size-sensitive, are
extremely unlikely to ever encounter any 16-bit software, so make it
a CONFIG_EXPERT option to turn off support for any 16-bit software
whatsoever.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Link: http://lkml.kernel.org/r/1398816946-3351-1-git-send-email-hpa@linux.intel.com
It is not safe to use LAR to filter when to go down the espfix path,
because the LDT is per-process (rather than per-thread) and another
thread might change the descriptors behind our back. Fortunately it
is always *safe* (if a bit slow) to go down the espfix path, and a
32-bit LDT stack segment is extremely rare.
Cc: <stable@vger.kernel.org> # consider after upstream merge
.entry.text is a code area which is used for interrupt/syscall
entries, which includes many sensitive code.
Thus, it is better to prohibit probing on all of such code
instead of a part of that.
Since some symbols are already registered on kprobe blacklist,
this also removes them from the blacklist.
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Jan Kiszka <jan.kiszka@siemens.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Jonathan Lebon <jlebon@redhat.com>
Cc: Seiji Aguchi <seiji.aguchi@hds.com>
Link: http://lkml.kernel.org/r/20140417081658.26341.57354.stgit@ltc230.yrl.intra.hitachi.co.jp
Function tracing callbacks expect to have the ftrace_ops that registered it
passed to them, not the address of the variable that holds the ftrace_ops
that registered it.
Use a mov instead of a lea to store the ftrace_ops into the parameter
of the function tracing callback.
Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Link: http://lkml.kernel.org/r/20131113152004.459787f9@gandalf.local.home
Cc: <stable@vger.kernel.org> # v3.8+
Pull x86/trace changes from Ingo Molnar:
"This adds page fault tracepoints which have zero runtime cost in the
disabled case via IDT trickery (no NOPs in the page fault hotpath)"
* 'x86-trace-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, trace: Change user|kernel_page_fault to page_fault_user|kernel
x86, trace: Add page fault tracepoints
x86, trace: Delete __trace_alloc_intr_gate()
x86, trace: Register exception handler to trace IDT
x86, trace: Remove __alloc_intr_gate()
This patch registers exception handlers for tracing to a trace IDT.
To implemented it in set_intr_gate(), this patch does followings.
- Register the exception handlers to
the trace IDT by prepending "trace_" to the handler's names.
- Also, newly introduce trace_page_fault() to add tracepoints
in a subsequent patch.
Signed-off-by: Seiji Aguchi <seiji.aguchi@hds.com>
Link: http://lkml.kernel.org/r/52716DEC.5050204@hds.com
Convert x86 to use a per-cpu preemption count. The reason for doing so
is that accessing per-cpu variables is a lot cheaper than accessing
thread_info variables.
We still need to save/restore the actual preemption count due to
PREEMPT_ACTIVE so we place the per-cpu __preempt_count variable in the
same cache-line as the other hot __switch_to() variables such as
current_task.
NOTE: this save/restore is required even for !PREEMPT kernels as
cond_resched() also relies on preempt_count's PREEMPT_ACTIVE to ignore
task_struct::state.
Also rename thread_info::preempt_count to ensure nobody is
'accidentally' still poking at it.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/n/tip-gzn5rfsf8trgjoqx8hyayy3q@git.kernel.org
Early microcode loading runs C code before paging is enabled on 32
bits. Since ftrace puts a hook into every function, that hook needs
to be safe to execute in the pre-paging environment. This is
currently true for dynamic ftrace but not for static ftrace.
Static ftrace is obsolescent and assumed to not be
performance-critical, so we can simply test that the stack pointer
falls within the valid range of kernel addresses.
Reported-by: Jan Kiszka <jan.kiszka@siemens.com>
Tested-by: Jan Kiszka <jan.kiszka@siemens.com>
[Purpose of this patch]
As Vaibhav explained in the thread below, tracepoints for irq vectors
are useful.
http://www.spinics.net/lists/mm-commits/msg85707.html
<snip>
The current interrupt traces from irq_handler_entry and irq_handler_exit
provide when an interrupt is handled. They provide good data about when
the system has switched to kernel space and how it affects the currently
running processes.
There are some IRQ vectors which trigger the system into kernel space,
which are not handled in generic IRQ handlers. Tracing such events gives
us the information about IRQ interaction with other system events.
The trace also tells where the system is spending its time. We want to
know which cores are handling interrupts and how they are affecting other
processes in the system. Also, the trace provides information about when
the cores are idle and which interrupts are changing that state.
<snip>
On the other hand, my usecase is tracing just local timer event and
getting a value of instruction pointer.
I suggested to add an argument local timer event to get instruction pointer before.
But there is another way to get it with external module like systemtap.
So, I don't need to add any argument to irq vector tracepoints now.
[Patch Description]
Vaibhav's patch shared a trace point ,irq_vector_entry/irq_vector_exit, in all events.
But there is an above use case to trace specific irq_vector rather than tracing all events.
In this case, we are concerned about overhead due to unwanted events.
So, add following tracepoints instead of introducing irq_vector_entry/exit.
so that we can enable them independently.
- local_timer_vector
- reschedule_vector
- call_function_vector
- call_function_single_vector
- irq_work_entry_vector
- error_apic_vector
- thermal_apic_vector
- threshold_apic_vector
- spurious_apic_vector
- x86_platform_ipi_vector
Also, introduce a logic switching IDT at enabling/disabling time so that a time penalty
makes a zero when tracepoints are disabled. Detailed explanations are as follows.
- Create trace irq handlers with entering_irq()/exiting_irq().
- Create a new IDT, trace_idt_table, at boot time by adding a logic to
_set_gate(). It is just a copy of original idt table.
- Register the new handlers for tracpoints to the new IDT by introducing
macros to alloc_intr_gate() called at registering time of irq_vector handlers.
- Add checking, whether irq vector tracing is on/off, into load_current_idt().
This has to be done below debug checking for these reasons.
- Switching to debug IDT may be kicked while tracing is enabled.
- On the other hands, switching to trace IDT is kicked only when debugging
is disabled.
In addition, the new IDT is created only when CONFIG_TRACING is enabled to avoid being
used for other purposes.
Link: http://lkml.kernel.org/r/51C323ED.5050708@hds.com
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull signal handling cleanups from Al Viro:
"This is the first pile; another one will come a bit later and will
contain SYSCALL_DEFINE-related patches.
- a bunch of signal-related syscalls (both native and compat)
unified.
- a bunch of compat syscalls switched to COMPAT_SYSCALL_DEFINE
(fixing several potential problems with missing argument
validation, while we are at it)
- a lot of now-pointless wrappers killed
- a couple of architectures (cris and hexagon) forgot to save
altstack settings into sigframe, even though they used the
(uninitialized) values in sigreturn; fixed.
- microblaze fixes for delivery of multiple signals arriving at once
- saner set of helpers for signal delivery introduced, several
architectures switched to using those."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (143 commits)
x86: convert to ksignal
sparc: convert to ksignal
arm: switch to struct ksignal * passing
alpha: pass k_sigaction and siginfo_t using ksignal pointer
burying unused conditionals
make do_sigaltstack() static
arm64: switch to generic old sigaction() (compat-only)
arm64: switch to generic compat rt_sigaction()
arm64: switch compat to generic old sigsuspend
arm64: switch to generic compat rt_sigqueueinfo()
arm64: switch to generic compat rt_sigpending()
arm64: switch to generic compat rt_sigprocmask()
arm64: switch to generic sigaltstack
sparc: switch to generic old sigsuspend
sparc: COMPAT_SYSCALL_DEFINE does all sign-extension as well as SYSCALL_DEFINE
sparc: kill sign-extending wrappers for native syscalls
kill sparc32_open()
sparc: switch to use of generic old sigaction
sparc: switch sys_compat_rt_sigaction() to COMPAT_SYSCALL_DEFINE
mips: switch to generic sys_fork() and sys_clone()
Starting with win8, vmbus interrupts can be delivered on any VCPU in the guest
and furthermore can be concurrently active on multiple VCPUs. Support this
interrupt delivery model by setting up a separate IDT entry for Hyper-V vmbus.
interrupts. I would like to thank Jan Beulich <JBeulich@suse.com> and
Thomas Gleixner <tglx@linutronix.de>, for their help.
In this version of the patch, based on the feedback, I have merged the IDT
vector for Xen and Hyper-V and made the necessary adjustments. Furhermore,
based on Jan's feedback I have added the necessary compilation switches.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
Link: http://lkml.kernel.org/r/1359940959-32168-3-git-send-email-kys@microsoft.com
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
Pull Xen fixes from Konrad Rzeszutek Wilk:
- CVE-2013-0190/XSA-40 (or stack corruption for 32-bit PV kernels)
- Fix racy vma access spotted by Al Viro
- Fix mmap batch ioctl potentially resulting in large O(n) page allcations.
- Fix vcpu online/offline BUG:scheduling while atomic..
- Fix unbound buffer scanning for more than 32 vCPUs.
- Fix grant table being incorrectly initialized
- Fix incorrect check in pciback
- Allow privcmd in backend domains.
Fix up whitespace conflict due to ugly merge resolution in Xen tree in
arch/arm/xen/enlighten.c
* tag 'stable/for-linus-3.8-rc3-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen: Fix stack corruption in xen_failsafe_callback for 32bit PVOPS guests.
Revert "xen/smp: Fix CPU online/offline bug triggering a BUG: scheduling while atomic."
xen/gntdev: remove erronous use of copy_to_user
xen/gntdev: correctly unmap unlinked maps in mmu notifier
xen/gntdev: fix unsafe vma access
xen/privcmd: Fix mmap batch ioctl.
Xen: properly bound buffer access when parsing cpu/*/availability
xen/grant-table: correctly initialize grant table version 1
x86/xen : Fix the wrong check in pciback
xen/privcmd: Relax access control in privcmd_ioctl_mmap
This fixes CVE-2013-0190 / XSA-40
There has been an error on the xen_failsafe_callback path for failed
iret, which causes the stack pointer to be wrong when entering the
iret_exc error path. This can result in the kernel crashing.
In the classic kernel case, the relevant code looked a little like:
popl %eax # Error code from hypervisor
jz 5f
addl $16,%esp
jmp iret_exc # Hypervisor said iret fault
5: addl $16,%esp
# Hypervisor said segment selector fault
Here, there are two identical addls on either option of a branch which
appears to have been optimised by hoisting it above the jz, and
converting it to an lea, which leaves the flags register unaffected.
In the PVOPS case, the code looks like:
popl_cfi %eax # Error from the hypervisor
lea 16(%esp),%esp # Add $16 before choosing fault path
CFI_ADJUST_CFA_OFFSET -16
jz 5f
addl $16,%esp # Incorrectly adjust %esp again
jmp iret_exc
It is possible unprivileged userspace applications to cause this
behaviour, for example by loading an LDT code selector, then changing
the code selector to be not-present. At this point, there is a race
condition where it is possible for the hypervisor to return back to
userspace from an interrupt, fault on its own iret, and inject a
failsafe_callback into the kernel.
This bug has been present since the introduction of Xen PVOPS support
in commit 5ead97c84 (xen: Core Xen implementation), in 2.6.23.
Signed-off-by: Frediano Ziglio <frediano.ziglio@citrix.com>
Signed-off-by: Andrew Cooper <andrew.cooper3@citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Conditional on CONFIG_GENERIC_SIGALTSTACK; architectures that do not
select it are completely unaffected
* commit 'v3.7-rc1': (10892 commits)
Linux 3.7-rc1
x86, boot: Explicitly include autoconf.h for hostprogs
perf: Fix UAPI fallout
ARM: config: make sure that platforms are ordered by option string
ARM: config: sort select statements alphanumerically
UAPI: (Scripted) Disintegrate include/linux/byteorder
UAPI: Unexport linux/blk_types.h
UAPI: Unexport part of linux/ppp-comp.h
perf: Handle new rbtree implementation
procfs: don't need a PATH_MAX allocation to hold a string representation of an int
vfs: embed struct filename inside of names_cache allocation if possible
audit: make audit_inode take struct filename
vfs: make path_openat take a struct filename pointer
vfs: turn do_path_lookup into wrapper around struct filename variant
audit: allow audit code to satisfy getname requests from its names_list
vfs: define struct filename and have getname() return it
btrfs: Fix compilation with user namespace support enabled
userns: Fix posix_acl_file_xattr_userns gid conversion
userns: Properly print bluetooth socket uids
In 32 bit guests, if a userspace process has %eax == -ERESTARTSYS
(-512) or -ERESTARTNOINTR (-513) when it is interrupted by an event
/and/ the process has a pending signal then %eip (and %eax) are
corrupted when returning to the main process after handling the
signal. The application may then crash with SIGSEGV or a SIGILL or it
may have subtly incorrect behaviour (depending on what instruction it
returned to).
The occurs because handle_signal() is incorrectly thinking that there
is a system call that needs to restarted so it adjusts %eip and %eax
to re-execute the system call instruction (even though user space had
not done a system call).
If %eax == -514 (-ERESTARTNOHAND (-514) or -ERESTART_RESTARTBLOCK
(-516) then handle_signal() only corrupted %eax (by setting it to
-EINTR). This may cause the application to crash or have incorrect
behaviour.
handle_signal() assumes that regs->orig_ax >= 0 means a system call so
any kernel entry point that is not for a system call must push a
negative value for orig_ax. For example, for physical interrupts on
bare metal the inverse of the vector is pushed and page_fault() sets
regs->orig_ax to -1, overwriting the hardware provided error code.
xen_hypervisor_callback() was incorrectly pushing 0 for orig_ax
instead of -1.
Classic Xen kernels pushed %eax which works as %eax cannot be both
non-negative and -RESTARTSYS (etc.), but using -1 is consistent with
other non-system call entry points and avoids some of the tests in
handle_signal().
There were similar bugs in xen_failsafe_callback() of both 32 and
64-bit guests. If the fault was corrected and the normal return path
was used then 0 was incorrectly pushed as the value for orig_ax.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Acked-by: Jan Beulich <JBeulich@suse.com>
Acked-by: Ian Campbell <ian.campbell@citrix.com>
Pull third pile of kernel_execve() patches from Al Viro:
"The last bits of infrastructure for kernel_thread() et.al., with
alpha/arm/x86 use of those. Plus sanitizing the asm glue and
do_notify_resume() on alpha, fixing the "disabled irq while running
task_work stuff" breakage there.
At that point the rest of kernel_thread/kernel_execve/sys_execve work
can be done independently for different architectures. The only
pending bits that do depend on having all architectures converted are
restrictred to fs/* and kernel/* - that'll obviously have to wait for
the next cycle.
I thought we'd have to wait for all of them done before we start
eliminating the longjump-style insanity in kernel_execve(), but it
turned out there's a very simple way to do that without flagday-style
changes."
alpha: switch to saner kernel_execve() semantics
arm: switch to saner kernel_execve() semantics
x86, um: convert to saner kernel_execve() semantics
infrastructure for saner ret_from_kernel_thread semantics
make sure that kernel_thread() callbacks call do_exit() themselves
make sure that we always have a return path from kernel_execve()
ppc: eeh_event should just use kthread_run()
don't bother with kernel_thread/kernel_execve for launching linuxrc
alpha: get rid of switch_stack argument of do_work_pending()
alpha: don't bother passing switch_stack separately from regs
alpha: take SIGPENDING/NOTIFY_RESUME loop into signal.c
alpha: simplify TIF_NEED_RESCHED handling
Pull pile 2 of execve and kernel_thread unification work from Al Viro:
"Stuff in there: kernel_thread/kernel_execve/sys_execve conversions for
several more architectures plus assorted signal fixes and cleanups.
There'll be more (in particular, real fixes for the alpha
do_notify_resume() irq mess)..."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (43 commits)
alpha: don't open-code trace_report_syscall_{enter,exit}
Uninclude linux/freezer.h
m32r: trim masks
avr32: trim masks
tile: don't bother with SIGTRAP in setup_frame
microblaze: don't bother with SIGTRAP in setup_rt_frame()
mn10300: don't bother with SIGTRAP in setup_frame()
frv: no need to raise SIGTRAP in setup_frame()
x86: get rid of duplicate code in case of CONFIG_VM86
unicore32: remove pointless test
h8300: trim _TIF_WORK_MASK
parisc: decide whether to go to slow path (tracesys) based on thread flags
parisc: don't bother looping in do_signal()
parisc: fix double restarts
bury the rest of TIF_IRET
sanitize tsk_is_polling()
bury _TIF_RESTORE_SIGMASK
unicore32: unobfuscate _TIF_WORK_MASK
mips: NOTIFY_RESUME is not needed in TIF masks
mips: merge the identical "return from syscall" per-ABI code
arch/arm/include/asm/thread_info.h
Pull generic execve() changes from Al Viro:
"This introduces the generic kernel_thread() and kernel_execve()
functions, and switches x86, arm, alpha, um and s390 over to them."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (26 commits)
s390: convert to generic kernel_execve()
s390: switch to generic kernel_thread()
s390: fold kernel_thread_helper() into ret_from_fork()
s390: fold execve_tail() into start_thread(), convert to generic sys_execve()
um: switch to generic kernel_thread()
x86, um/x86: switch to generic sys_execve and kernel_execve
x86: split ret_from_fork
alpha: introduce ret_from_kernel_execve(), switch to generic kernel_execve()
alpha: switch to generic kernel_thread()
alpha: switch to generic sys_execve()
arm: get rid of execve wrapper, switch to generic execve() implementation
arm: optimized current_pt_regs()
arm: introduce ret_from_kernel_execve(), switch to generic kernel_execve()
arm: split ret_from_fork, simplify kernel_thread() [based on patch by rmk]
new helper: current_pt_regs()
preparation for generic kernel_thread()
um: kill thread->forking
um: let signal_delivered() do SIGTRAP on singlestepping into handler
Pull x86/smap support from Ingo Molnar:
"This adds support for the SMAP (Supervisor Mode Access Prevention) CPU
feature on Intel CPUs: a hardware feature that prevents unintended
user-space data access from kernel privileged code.
It's turned on automatically when possible.
This, in combination with SMEP, makes it even harder to exploit kernel
bugs such as NULL pointer dereferences."
Fix up trivial conflict in arch/x86/kernel/entry_64.S due to newly added
includes right next to each other.
* 'x86-smap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, smep, smap: Make the switching functions one-way
x86, suspend: On wakeup always initialize cr4 and EFER
x86-32: Start out eflags and cr4 clean
x86, smap: Do not abuse the [f][x]rstor_checking() functions for user space
x86-32, smap: Add STAC/CLAC instructions to 32-bit kernel entry
x86, smap: Reduce the SMAP overhead for signal handling
x86, smap: A page fault due to SMAP is an oops
x86, smap: Turn on Supervisor Mode Access Prevention
x86, smap: Add STAC and CLAC instructions to control user space access
x86, uaccess: Merge prototypes for clear_user/__clear_user
x86, smap: Add a header file with macros for STAC/CLAC
x86, alternative: Add header guards to <asm/alternative-asm.h>
x86, alternative: Use .pushsection/.popsection
x86, smap: Add CR4 bit for SMAP
x86-32, mm: The WP test should be done on a kernel page
no need to have the call of do_notify_resume() + checks around it
duplicated for vm86 case - a bit of rearranging of ifdefs and we'll
have a perfectly fine copy to jump back to.
32bit wrapper is lost on that; 64bit one is *not*, since
we need to arrange for full pt_regs on stack when we call
sys_execve() and we need to load callee-saved ones from
there afterwards.
The changes to entry_32.S got missed in checkin:
63bcff2a x86, smap: Add STAC and CLAC instructions to control user space access
The resulting kernel was largely functional but SMAP protection could
have been bypassed.
Link: http://lkml.kernel.org/r/1348256595-29119-9-git-send-email-hpa@linux.intel.com
Adjust x86 regs.ip to ip + MCOUNT_INSN_SIZE as like as
on x86-64. This helps us to consolidate codes which use
regs->ip on both of x86/x86-64.
Link: http://lkml.kernel.org/r/20120905143100.10329.60109.stgit@localhost.localdomain
The graph caller is called by the mcount callers, which already does
the check against the function_trace_stop variable. No reason to
check it again.
Link: http://lkml.kernel.org/r/20120711195745.588538769@goodmis.org
The final position of the stack after saving regs and setting up
the parameters for ftrace_regs_call, is the position of the pt_regs
needed for the 4th parameter. Instead of saving it into a temporary
reg and pushing the reg, simply push the stack pointer.
Link: http://lkml.kernel.org/r/1342702344.12353.16.camel@gandalf.stny.rr.com
Signed-off-by: Uros Bizjak <ubizjak@gmail.com>
Add saving full regs for function tracing on i386.
The saving of regs was influenced by patches sent out by
Masami Hiramatsu.
Link: Link: http://lkml.kernel.org/r/20120711195745.379060003@goodmis.org
Add a way to have different functions calling different trampolines.
If a ftrace_ops wants regs saved on the return, then have only the
functions with ops registered to save regs. Functions registered by
other ops would not be affected, unless the functions overlap.
If one ftrace_ops registered functions A, B and C and another ops
registered fucntions to save regs on A, and D, then only functions
A and D would be saving regs. Function B and C would work as normal.
Although A is registered by both ops: normal and saves regs; this is fine
as saving the regs is needed to satisfy one of the ops that calls it
but the regs are ignored by the other ops function.
x86_64 implements the full regs saving, and i386 just passes a NULL
for regs to satisfy the ftrace_ops passing. Where an arch must supply
both regs and ftrace_ops parameters, even if regs is just NULL.
It is OK for an arch to pass NULL regs. All function trace users that
require regs passing must add the flag FTRACE_OPS_FL_SAVE_REGS when
registering the ftrace_ops. If the arch does not support saving regs
then the ftrace_ops will fail to register. The flag
FTRACE_OPS_FL_SAVE_REGS_IF_SUPPORTED may be set that will prevent the
ftrace_ops from failing to register. In this case, the handler may
either check if regs is not NULL or check if ARCH_SUPPORTS_FTRACE_SAVE_REGS.
If the arch supports passing regs it will set this macro and pass regs
for ops that request them. All other archs will just pass NULL.
Link: Link: http://lkml.kernel.org/r/20120711195745.107705970@goodmis.org
Cc: Alexander van Heukelum <heukelum@fastmail.fm>
Add support of passing the current ftrace_ops into the 3rd parameter
of the callback to the function tracer.
Link: http://lkml.kernel.org/r/20120612225424.942411318@goodmis.org
If we end up calling do_notify_resume() with !user_mode(refs), it
does nothing (do_signal() explicitly bails out and we can't get there
with TIF_NOTIFY_RESUME in such situations). Then we jump to
resume_userspace_sig, which rechecks the same thing and bails out
to resume_kernel, thus breaking the loop.
It's easier and cheaper to check *before* calling do_notify_resume()
and bail out to resume_kernel immediately. And kill the check in
do_signal()...
Note that on amd64 we can't get there with !user_mode() at all - asm
glue takes care of that.
Acked-and-reviewed-by: Thomas Gleixner <tglx@linutronix.de>
arch/x86/kernel/entry_32.S
Remove open-coded exception table entries in arch/x86/kernel/entry_32.S,
and replace them with _ASM_EXTABLE() macros; this will allow us to
change the format and type of the exception table entries.
Cc: David Daney <david.daney@cavium.com>
Link: http://lkml.kernel.org/r/CA%2B55aFyijf43qSu3N9nWHEBwaGbb7T2Oq9A=9EyR=Jtyqfq_cQ@mail.gmail.com
The problem occurs on !CONFIG_VM86 kernels [1] when a kernel-mode task
returns from a system call with a pending signal.
A real-life scenario is a child of 'khelper' returning from a failed
kernel_execve() in ____call_usermodehelper() [ kernel/kmod.c ].
kernel_execve() fails due to a pending SIGKILL, which is the result of
"kill -9 -1" (at least, busybox's init does it upon reboot).
The loop is as follows:
* syscall_exit_work:
- work_pending: // start_of_the_loop
- work_notify_sig:
- do_notify_resume()
- do_signal()
- if (!user_mode(regs)) return;
- resume_userspace // TIF_SIGPENDING is still set
- work_pending // so we call work_pending => goto
More information can be found in another LKML thread:
http://www.serverphorums.com/read.php?12,457826
[1] the problem was also seen on MIPS.
Signed-off-by: Dmitry Adamushko <dmitry.adamushko@gmail.com>
Link: http://lkml.kernel.org/r/1332448765.2299.68.camel@dimm
Cc: Roland McGrath <roland@hack.frob.com>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit: (29 commits)
audit: no leading space in audit_log_d_path prefix
audit: treat s_id as an untrusted string
audit: fix signedness bug in audit_log_execve_info()
audit: comparison on interprocess fields
audit: implement all object interfield comparisons
audit: allow interfield comparison between gid and ogid
audit: complex interfield comparison helper
audit: allow interfield comparison in audit rules
Kernel: Audit Support For The ARM Platform
audit: do not call audit_getname on error
audit: only allow tasks to set their loginuid if it is -1
audit: remove task argument to audit_set_loginuid
audit: allow audit matching on inode gid
audit: allow matching on obj_uid
audit: remove audit_finish_fork as it can't be called
audit: reject entry,always rules
audit: inline audit_free to simplify the look of generic code
audit: drop audit_set_macxattr as it doesn't do anything
audit: inline checks for not needing to collect aux records
audit: drop some potentially inadvisable likely notations
Use evil merge to fix up grammar mistakes in Kconfig file.
Bad speling and horrible grammar (and copious swearing) is to be
expected, but let's keep it to commit messages and comments, rather than
expose it to users in config help texts or printouts.
Every arch calls:
if (unlikely(current->audit_context))
audit_syscall_entry()
which requires knowledge about audit (the existance of audit_context) in
the arch code. Just do it all in static inline in audit.h so that arch's
can remain blissfully ignorant.
Signed-off-by: Eric Paris <eparis@redhat.com>
The audit system previously expected arches calling to audit_syscall_exit to
supply as arguments if the syscall was a success and what the return code was.
Audit also provides a helper AUDITSC_RESULT which was supposed to simplify things
by converting from negative retcodes to an audit internal magic value stating
success or failure. This helper was wrong and could indicate that a valid
pointer returned to userspace was a failed syscall. The fix is to fix the
layering foolishness. We now pass audit_syscall_exit a struct pt_reg and it
in turns calls back into arch code to collect the return value and to
determine if the syscall was a success or failure. We also define a generic
is_syscall_success() macro which determines success/failure based on if the
value is < -MAX_ERRNO. This works for arches like x86 which do not use a
separate mechanism to indicate syscall failure.
We make both the is_syscall_success() and regs_return_value() static inlines
instead of macros. The reason is because the audit function must take a void*
for the regs. (uml calls theirs struct uml_pt_regs instead of just struct
pt_regs so audit_syscall_exit can't take a struct pt_regs). Since the audit
function takes a void* we need to use static inlines to cast it back to the
arch correct structure to dereference it.
The other major change is that on some arches, like ia64, MIPS and ppc, we
change regs_return_value() to give us the negative value on syscall failure.
THE only other user of this macro, kretprobe_example.c, won't notice and it
makes the value signed consistently for the audit functions across all archs.
In arch/sh/kernel/ptrace_64.c I see that we were using regs[9] in the old
audit code as the return value. But the ptrace_64.h code defined the macro
regs_return_value() as regs[3]. I have no idea which one is correct, but this
patch now uses the regs_return_value() function, so it now uses regs[3].
For powerpc we previously used regs->result but now use the
regs_return_value() function which uses regs->gprs[3]. regs->gprs[3] is
always positive so the regs_return_value(), much like ia64 makes it negative
before calling the audit code when appropriate.
Acked-by: H. Peter Anvin <hpa@zytor.com> [for x86 portion]
Acked-by: Tony Luck <tony.luck@intel.com> [for ia64]
Acked-by: Richard Weinberger <richard@nod.at> [for uml]
Acked-by: David S. Miller <davem@davemloft.net> [for sparc]
Acked-by: Ralf Baechle <ralf@linux-mips.org> [for mips]
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> [for ppc]
* 'x86-syscall-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86: Move <asm/asm-offsets.h> from trace_syscalls.c to asm/syscall.h
x86, um: Fix typo in 32-bit system call modifications
um: Use $(srctree) not $(KBUILD_SRC)
x86, um: Mark system call tables readonly
x86, um: Use the same style generated syscall tables as native
um: Generate headers before generating user-offsets.s
um: Run host archheaders, allow use of host generated headers
kbuild, headers.sh: Don't make archheaders explicitly
x86, syscall: Allow syscall offset to be symbolic
x86, syscall: Re-fix typo in comment
x86: Simplify syscallhdr.sh
x86: Generate system call tables and unistd_*.h from tables
checksyscalls: Use arch/x86/syscalls/syscall_32.tbl as source
x86: Machine-readable syscall tables and scripts to process them
trace: Include <asm/asm-offsets.h> in trace_syscalls.c
x86-64, ia32: Move compat_ni_syscall into C and its own file
x86-64, syscall: Adjust comment spacing and remove typo
kbuild: Add support for an "archheaders" target
kbuild: Add support for installing generated asm headers
do_notify_resume() gets called with interrupts disabled on x86_32. This
is different from the x86_64 behavior, where interrupts are enabled at
the time.
Queries on lkml on this issue hasn't yielded any clear answer. Lets make
x86_32 behave the same as x86_64, unless there is a real reason to
maintain status quo.
Please refer https://lkml.org/lkml/2011/9/27/130 for more
details.
A similar change was suggested in ARM:
https://lkml.org/lkml/2011/8/25/231
My 32-bit machine works fine (tm) with this patch.
Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Link: http://lkml.kernel.org/r/20111025141812.GA21225@linux.vnet.ibm.com
Generate system call tables and unistd_*.h automatically from the
tables in arch/x86/syscalls. All other information, like NR_syscalls,
is auto-generated, some of which is in asm-offsets_*.c.
This allows us to keep all the system call information in one place,
and allows for kernel space and user space to see different
information; this is currently used for the ia32 system call numbers
when building the 64-bit kernel, but will be used by the x32 ABI in
the near future.
This also removes some gratuitious differences between i386, x86-64
and ia32; in particular, now all system call tables are generated with
the same mechanism.
Cc: H. J. Lu <hjl.tools@gmail.com>
Cc: Michal Marek <mmarek@suse.cz>
entry_32.S contained a hardcoded alternative instruction entry, and the
format changed in commit 59e97e4d6fbc ("x86: Make alternative
instruction pointers relative").
Replace the hardcoded entry with the altinstruction_entry macro. This
fixes the 32-bit boot with CONFIG_X86_INVD_BUG=y.
Reported-and-tested-by: Arnaud Lacombe <lacombar@gmail.com>
Signed-off-by: Andy Lutomirski <luto@mit.edu>
Cc: Peter Anvin <hpa@zytor.com>
* 'x86-trampoline-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Fix binutils-2.21 symbol related build failures
x86-64, trampoline: Remove unused variable
x86, reboot: Fix the use of passed arguments in 32-bit BIOS reboot
x86, reboot: Move the real-mode reboot code to an assembly file
x86: Make the GDT_ENTRY() macro in <asm/segment.h> safe for assembly
x86, trampoline: Use the unified trampoline setup for ACPI wakeup
x86, trampoline: Common infrastructure for low memory trampolines
Fix up trivial conflicts in arch/x86/kernel/Makefile
* 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, binutils, xen: Fix another wrong size directive
x86: Remove dead config option X86_CPU
x86: Really print supported CPUs if PROCESSOR_SELECT=y
x86: Fix a bogus unwind annotation in lib/semaphore_32.S
um, x86-64: Fix UML build after adding CFI annotations to lib/rwsem_64.S
x86: Remove unused bits from lib/thunk_*.S
x86: Use {push,pop}_cfi in more places
x86-64: Add CFI annotations to lib/rwsem_64.S
x86, asm: Cleanup unnecssary macros in asm-offsets.c
x86, system.h: Drop unused __SAVE/__RESTORE macros
x86: Use bitmap library functions
x86: Partly unify asm-offsets_{32,64}.c
x86: Reduce back the alignment of the per-CPU data section
New binutils version 2.21.0.20110302-1 started checking that the symbol
parameter to the .size directive matches the entry name's
symbol parameter, unearthing two mismatches:
AS arch/x86/kernel/acpi/wakeup_rm.o
arch/x86/kernel/acpi/wakeup_rm.S: Assembler messages:
arch/x86/kernel/acpi/wakeup_rm.S:12: Error: .size expression with symbol `wakeup_code_start' does not evaluate to a constant
arch/x86/kernel/entry_32.S: Assembler messages:
arch/x86/kernel/entry_32.S:1421: Error: .size expression with
symbol `apf_page_fault' does not evaluate to a constant
The problem was discovered while using Debian's binutils
(2.21.0.20110302-1) and experimenting with binutils from
upstream.
Thanks Alexander and H.J. for the vital help.
Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com>
Cc: H.J. Lu <hjl.tools@gmail.com>
Cc: Len Brown <len.brown@intel.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
LKML-Reference: <1299620364-21644-1-git-send-email-sedat.dilek@gmail.com>
