commit b01d4e68933ec23e43b1046fa35d593cefcf37d1 upstream.
It's an enum, not a #define, you can't use it in asm files.
Introduced in commit 5fa10196bdb5 ("x86: Ignore NMIs that come in during
early boot"), and sadly I didn't compile-test things like I should have
before pushing out.
My weak excuse is that the x86 tree generally doesn't introduce stupid
things like this (and the ARM pull afterwards doesn't cause me to do a
compile-test either, since I don't cross-compile).
Cc: Don Zickus <dzickus@redhat.com>
Cc: H. Peter Anvin <hpa@linux.intel.com>
commit 5fa10196bdb5f190f595ebd048490ee52dddea0f upstream.
Don Zickus reports:
A customer generated an external NMI using their iLO to test kdump
worked. Unfortunately, the machine hung. Disabling the nmi_watchdog
made things work.
I speculated the external NMI fired, caused the machine to panic (as
expected) and the perf NMI from the watchdog came in and was latched.
My guess was this somehow caused the hang.
It appears that the latched NMI stays latched until the early page
table generation on 64 bits, which causes exceptions to happen which
end in IRET, which re-enable NMI. Therefore, ignore NMIs that come in
during early execution, until we have proper exception handling.
Reported-and-tested-by: Don Zickus <dzickus@redhat.com>
Link: http://lkml.kernel.org/r/1394221143-29713-1-git-send-email-dzickus@redhat.com
Pull x86 microcode loading update from Peter Anvin:
"This patchset lets us update the CPU microcode very, very early in
initialization if the BIOS fails to do so (never happens, right?)
This is handy for dealing with things like the Atom erratum where we
have to run without PSE because microcode loading happens too late.
As I mentioned in the x86/mm push request it depends on that
infrastructure but it is otherwise a standalone feature."
* 'x86/microcode' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/Kconfig: Make early microcode loading a configuration feature
x86/mm/init.c: Copy ucode from initrd image to kernel memory
x86/head64.c: Early update ucode in 64-bit
x86/head_32.S: Early update ucode in 32-bit
x86/microcode_intel_early.c: Early update ucode on Intel's CPU
x86/tlbflush.h: Define __native_flush_tlb_global_irq_disabled()
x86/microcode_intel_lib.c: Early update ucode on Intel's CPU
x86/microcode_core_early.c: Define interfaces for early loading ucode
x86/common.c: load ucode in 64 bit or show loading ucode info in 32 bit on AP
x86/common.c: Make have_cpuid_p() a global function
x86/microcode_intel.h: Define functions and macros for early loading ucode
x86, doc: Documentation for early microcode loading
Jumping here we are about to enable paging so rename the label
accordingly.
Link: http://lkml.kernel.org/r/1360592538-10643-5-git-send-email-bp@alien8.de
We do that once earlier now and cache it into new_cpu_data.cpuid_level
so no need for the EFLAGS.ID toggling dance anymore.
Link: http://lkml.kernel.org/r/1360592538-10643-4-git-send-email-bp@alien8.de
We detect CPUID function support on each CPU and save it for later use,
obviating the need to play the toggle EFLAGS.ID game every time. C code
is looking at ->cpuid_level anyway.
Link: http://lkml.kernel.org/r/1360592538-10643-3-git-send-email-bp@alien8.de
Remove code fragments detecting a 386 CPU since we don't support those
anymore. Also, do not do alignment checks because they're done only at
CPL3. Also, no need to preserve EFLAGS.
Link: http://lkml.kernel.org/r/1360592538-10643-2-git-send-email-bp@alien8.de
This updates ucode in 32-bit kernel on BSP and AP. At this point, there is no
paging and no virtual address yet.
Signed-off-by: Fenghua Yu <fenghua.yu@intel.com>
Link: http://lkml.kernel.org/r/1356075872-3054-10-git-send-email-fenghua.yu@intel.com
Patch
5a5a51db78e x86-32: Start out eflags and cr4 clean
... made x86-32 match x86-64 in that we initialize %eflags and %cr4
from scratch. This broke OLPC XO-1.5, because the XO enters the
kernel with paging enabled, which the kernel doesn't expect.
Since we no longer support 386 (the source of most of the variability
in %cr0 configuration), we can simply match further x86-64 and
initialize %cr0 to a fixed value -- the one variable part remaining in
%cr0 is for FPU control, but all that is handled later on in
initialization; in particular, configuring %cr0 as if the FPU is
present until proven otherwise is correct and necessary for the probe
to work.
To deal with the XO case sanely, explicitly disable paging in %cr0
before we muck with %cr3, %cr4 or EFER -- those operations are
inherently unsafe with paging enabled.
NOTE: There is still a lot of 386-related junk in head_32.S which we
can and should get rid of, however, this is intended as a minimal fix
whereas the cleanup can be deferred to the next merge window.
Reported-by: Andres Salomon <dilinger@queued.net>
Tested-by: Daniel Drake <dsd@laptop.org>
Link: http://lkml.kernel.org/r/50FA0661.2060400@linux.intel.com
Pull x86 BSP hotplug changes from Ingo Molnar:
"This tree enables CPU#0 (the boot processor) to be onlined/offlined on
x86, just like any other CPU. Enabled on Intel CPUs for now.
Allowing this required the identification and fixing of latent CPU#0
assumptions (such as CPU#0 initializations, etc.) in the x86
architecture code, plus the identification of barriers to
BSP-offlining, such as active PIC interrupts which can only be
serviced on the BSP.
It's behind a default-off option, and there's a debug option that
allows the automatic testing of this feature.
The motivation of this feature is to allow and prepare for true
CPU-hotplug hardware support: recent changes to MCE support enable us
to detect a deteriorating but not yet hard-failing L1/L2 cache on a
CPU that could be soft-unplugged - or a failing L3 cache on a
multi-socket system.
Note that true hardware hot-plug is not yet fully enabled by this,
because that requires a special platform wakeup sequence to be sent to
the freshly powered up CPU#0. Future patches for this are planned,
once such a platform exists. Chicken and egg"
* 'x86-bsp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, topology: Debug CPU0 hotplug
x86/i387.c: Initialize thread xstate only on CPU0 only once
x86, hotplug: Handle retrigger irq by the first available CPU
x86, hotplug: The first online processor saves the MTRR state
x86, hotplug: During CPU0 online, enable x2apic, set_numa_node.
x86, hotplug: Wake up CPU0 via NMI instead of INIT, SIPI, SIPI
x86-32, hotplug: Add start_cpu0() entry point to head_32.S
x86-64, hotplug: Add start_cpu0() entry point to head_64.S
kernel/cpu.c: Add comment for priority in cpu_hotplug_pm_callback
x86, hotplug, suspend: Online CPU0 for suspend or hibernate
x86, hotplug: Support functions for CPU0 online/offline
x86, topology: Don't offline CPU0 if any PIC irq can not be migrated out of it
x86, Kconfig: Add config switch for CPU0 hotplug
doc: Add x86 CPU0 online/offline feature
There appear to have been some 486 clones, including the "enhanced"
version of Am486, which have CPUID but not CR4. These 486 clones had
only the FPU flag, if any, unlike the Intel 486s with CPUID, which
also had VME and therefore needed CR4.
Therefore, look at the basic CPUID flags and require at least one bit
other than bit 0 before we modify CR4.
Thanks to Christian Ludloff of sandpile.org for confirming this as a
problem.
start_cpu0() is defined in head_32.S for 32-bit. The function sets up stack and
jumps to start_secondary() for CPU0 wake up.
Link: http://lkml.kernel.org/r/1352835171-3958-9-git-send-email-fenghua.yu@intel.com
%cr4 is supposed to reflect a set of features into which the operating
system is opting in. If the BIOS or bootloader leaks bits here, this
is not desirable. Consider a bootloader passing in %cr4.pae set to a
legacy paging kernel, for example -- it will not have any immediate
effect, but the kernel would crash when turning paging on.
A similar argument applies to %eflags, and since we have to look for
%eflags.id being settable we can use a sequence which clears %eflags
as a side effect.
Note that we already do this for x86-64.
Link: http://lkml.kernel.org/r/1348529239-17943-1-git-send-email-hpa@linux.intel.com
Pull x86 trampoline rework from H. Peter Anvin:
"This code reworks all the "trampoline"/"realmode" code (various bits
that need to live in the first megabyte of memory, most but not all of
which runs in real mode at some point) in the kernel into a single
object. The main reason for doing this is that it eliminates the last
place in the kernel where we needed pages to be mapped RWX. This code
separates all that code into proper R/RW/RX pages."
Fix up conflicts in arch/x86/kernel/Makefile (mca removed next to reboot
code), and arch/x86/kernel/reboot.c (reboot code moved around in one
branch, modified in this one), and arch/x86/tools/relocs.c (mostly same
code came in earlier due to working around the ld bugs just before the
3.4 release).
Also remove stale x86-relocs entry from scripts/.gitignore as per Peter
Anvin.
* commit '61f5446169046c217a5479517edac3a890c3bee7': (36 commits)
x86, realmode: Move end signature into header.S
x86, relocs: When printing an error, say relative or absolute
x86, relocs: More relocations which may end up as absolute
x86, relocs: Workaround for binutils 2.22.52.0.1 section bug
xen-acpi-processor: Add missing #include <xen/xen.h>
acpi, bgrd: Add missing <linux/io.h> to drivers/acpi/bgrt.c
x86, realmode: Change EFER to a single u64 field
x86, realmode: Move kernel/realmode.c to realmode/init.c
x86, realmode: Move not-common bits out of trampoline_common.S
x86, realmode: Mask out EFER.LMA when saving trampoline EFER
x86, realmode: Fix no cache bits test in reboot_32.S
x86, realmode: Make sure all generated files are listed in targets
x86, realmode: build fix: remove duplicate build
x86, realmode: read cr4 and EFER from kernel for 64-bit trampoline
x86, realmode: fixes compilation issue in tboot.c
x86, realmode: move relocs from scripts/ to arch/x86/tools
x86, realmode: header for trampoline code
x86, realmode: flattened rm hierachy
x86, realmode: don't copy real_mode_header
x86, realmode: fix 64-bit wakeup sequence
Migrated SMP trampoline code to the real mode blob.
SMP trampoline code is not yet removed from
.x86_trampoline because it is needed by the wakeup
code.
[ hpa: always enable compiling startup_32_smp in head_32.S... it is
only a few instructions which go into .init on UP builds, and it makes
the rest of the code less #ifdef ugly. ]
Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@intel.com>
Link: http://lkml.kernel.org/r/1336501366-28617-6-git-send-email-jarkko.sakkinen@intel.com
If we get an exception during early boot, walk the exception table to
see if we should intercept it. The main use case for this is to allow
rdmsr_safe()/wrmsr_safe() during CPU initialization.
Since the exception table is currently sorted at runtime, and fairly
late in startup, this code walks the exception table linearly. We
obviously don't need to worry about modules, however: none have been
loaded at this point.
This patch changes the early IDT setup to look a lot more like x86-64:
we now install handlers for all 32 exception vectors. The output of
the early exception handler has changed somewhat as it directly
reflects the stack frame of the exception handler, and the stack frame
has been somewhat restructured.
Finally, centralize the code that can and should be run only once.
[ v2: Use early_fixup_exception() instead of linear search ]
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Link: http://lkml.kernel.org/r/1334794610-5546-6-git-send-email-hpa@zytor.com
* 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (27 commits)
x86: Clean up apic.c and apic.h
x86: Remove superflous goal definition of tsc_sync
x86: dt: Correct local apic documentation in device tree bindings
x86: dt: Cleanup local apic setup
x86: dt: Fix OLPC=y/INTEL_CE=n build
rtc: cmos: Add OF bindings
x86: ce4100: Use OF to setup devices
x86: ioapic: Add OF bindings for IO_APIC
x86: dtb: Add generic bus probe
x86: dtb: Add support for PCI devices backed by dtb nodes
x86: dtb: Add device tree support for HPET
x86: dtb: Add early parsing of IO_APIC
x86: dtb: Add irq domain abstraction
x86: dtb: Add a device tree for CE4100
x86: Add device tree support
x86: e820: Remove conditional early mapping in parse_e820_ext
x86: OLPC: Make OLPC=n build again
x86: OLPC: Remove extra OLPC_OPENFIRMWARE_DT indirection
x86: OLPC: Cleanup config maze completely
x86: OLPC: Hide OLPC_OPENFIRMWARE config switch
Fix up conflicts in arch/x86/platform/ce4100/ce4100.c
PAGE_SIZE_asm, PAGE_SHIFT_asm, THREAD_SIZE_asm can be safely removed from
asm-offsets.c, and be replaced by their non-'_asm' counterparts in the code
that uses them, since the _AC macro defined in include/linux/const.h makes
PAGE_SIZE/PAGE_SHIFT/THREAD_SIZE work with as.
Signed-off-by: Stratos Psomadakis <psomas@cslab.ece.ntua.gr>
LKML-Reference: <1298666774-17646-2-git-send-email-psomas@cslab.ece.ntua.gr>
Neither CONFIG_OLPC_OPENFIRMWARE nor CONFIG_OLPC_OPENFIRMWARE_DT are
really necessary.
OLPC selects OLPC_OPENFIRMWARE unconditionally, so move the "select
OF" part under OLPC config option and fixup the dependencies in
Makefiles and code.
Cc: Andres Salomon <dilinger@queued.net>
Since checkin ebba638ae723d8a8fc2f7abce5ec18b688b791d7 we call
verify_cpu even in 32-bit mode. Unfortunately, calling a function
means using the stack, and the stack pointer was not initialized in
the 32-bit setup code! This code initializes the stack pointer, and
simplifies the interface slightly since it is easier to rely on just a
pointer value rather than a descriptor; we need to have different
values for the segment register anyway.
This retains start_stack as a virtual address, even though a physical
address would be more convenient for 32 bits; the 64-bit code wants
the other way around...
Reported-by: Matthieu Castet <castet.matthieu@free.fr>
LKML-Reference: <4D41E86D.8060205@free.fr>
Tested-by: Kees Cook <kees.cook@canonical.com>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
Documentation/trace/events.txt: Remove obsolete sched_signal_send.
writeback: fix global_dirty_limits comment runtime -> real-time
ppc: fix comment typo singal -> signal
drivers: fix comment typo diable -> disable.
m68k: fix comment typo diable -> disable.
wireless: comment typo fix diable -> disable.
media: comment typo fix diable -> disable.
remove doc for obsolete dynamic-printk kernel-parameter
remove extraneous 'is' from Documentation/iostats.txt
Fix spelling milisec -> ms in snd_ps3 module parameter description
Fix spelling mistakes in comments
Revert conflicting V4L changes
i7core_edac: fix typos in comments
mm/rmap.c: fix comment
sound, ca0106: Fix assignment to 'channel'.
hrtimer: fix a typo in comment
init/Kconfig: fix typo
anon_inodes: fix wrong function name in comment
fix comment typos concerning "consistent"
poll: fix a typo in comment
Fix up trivial conflicts in:
- drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c)
- fs/ext4/ext4.h
Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, mm: Initialize initial_page_table before paravirt jumps
* 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Fix included-by file reference comments
x86, cpu: Only CPU features determine NX capabilities
x86, cpu: Call verify_cpu during 32bit CPU startup
x86, cpu: Clear XD_DISABLED flag on Intel to regain NX
x86, cpu: Rename verify_cpu_64.S to verify_cpu.S
v2.6.36-rc8-54-gb40827f (x86-32, mm: Add an initial page table
for core bootstrapping) made x86 boot using initial_page_table
and broke lguest.
For 2.6.37 we simply cut & paste the initialization code into
lguest (da32dac10126 "lguest: populate initial_page_table"), now
we fix it properly by doing that initialization before the
paravirt jump.
Acked-by: Jeremy Fitzhardinge <jeremy@goop.org>
Cc: lguest <lguest@ozlabs.org>
LKML-Reference: <201101041720.54535.rusty@rustcorp.com.au>
MAINTAINERS
arch/arm/mach-omap2/pm24xx.c
drivers/scsi/bfa/bfa_fcpim.c
Needed to update to apply fixes for which the old branch was too
outdated.
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86-32: Make sure we can map all of lowmem if we need to
x86, vt-d: Handle previous faults after enabling fault handling
x86: Enable the intr-remap fault handling after local APIC setup
x86, vt-d: Fix the vt-d fault handling irq migration in the x2apic mode
x86, vt-d: Quirk for masking vtd spec errors to platform error handling logic
x86, xsave: Use alloc_bootmem_align() instead of alloc_bootmem()
bootmem: Add alloc_bootmem_align()
x86, gcc-4.6: Use gcc -m options when building vdso
x86: HPET: Chose a paranoid safe value for the ETIME check
x86: io_apic: Avoid unused variable warning when CONFIG_GENERIC_PENDING_IRQ=n
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf: Fix off by one in perf_swevent_init()
perf: Fix duplicate events with multiple-pmu vs software events
ftrace: Have recordmcount honor endianness in fn_ELF_R_INFO
scripts/tags.sh: Add magic for trace-events
tracing: Fix panic when lseek() called on "trace" opened for writing
A relocatable kernel can be anywhere in lowmem -- and in the case of a
kdump kernel, is likely to be fairly high. Since the early page
tables map everything from address zero up we need to make sure we
allocate enough brk that we can map all of lowmem if we need to.
Reported-by: Stanislaw Gruszka <sgruszka@redhat.com>
Tested-by: Yinghai Lu <yinghai@kernel.org>
LKML-Reference: <4D0AD3ED.8070607@kernel.org>
Two x86 patches broke lguest:
1) v2.6.35-492-g72d7c3b, which changed x86 to use the memblock allocator.
In lguest, the host places linear page tables at the top of mem, which
used to be enough to get us up to the swapper_pg_dir page tables. With
the first patch, the direct mapping tables used that memory:
Before: kernel direct mapping tables up to 4000000 @ 7000-1a000
After: kernel direct mapping tables up to 4000000 @ 3fed000-4000000
I initially fixed this by lying about the amount of memory we had, so
the kernel wouldn't blatt the lguest boot pagetables (yuk!), but then...
2) v2.6.36-rc8-54-gb40827f, which made x86 boot use initial_page_table.
This was initialized in a part of head_32.S which isn't executed by
lguest; it is then copied into swapper_pg_dir. So we have to initialize
it; and anyway we switch to it before we blatt the old tables, so that
fixes the previous damage as well.
For the moment, I cut & pasted the code into lguest's boot code, but
next merge window I will merge them.
Cc: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
To: x86@kernel.org
The XD_DISABLE-clearing side-effect needs to happen for both 32bit
and 64bit, but the 32bit init routines were not calling verify_cpu()
yet. This adds that call to gain the side-effect.
The longmode/SSE tests being performed in verify_cpu() need to happen very
early for 64bit but not for 32bit. Instead of including it in two places
for 32bit, we can just include it once in arch/x86/kernel/head_32.S.
Signed-off-by: Kees Cook <kees.cook@canonical.com>
LKML-Reference: <1289414154-7829-4-git-send-email-kees.cook@canonical.com>
Acked-by: Pekka Enberg <penberg@kernel.org>
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
"gadget", "through", "command", "maintain", "maintain", "controller", "address",
"between", "initiali[zs]e", "instead", "function", "select", "already",
"equal", "access", "management", "hierarchy", "registration", "interest",
"relative", "memory", "offset", "already",
This patch adds an initial page table with low mappings used exclusively
for booting APs/resuming after ACPI suspend/machine restart. After this,
there's no need to add low mappings to swapper_pg_dir and zap them later
or create own swsusp PGD page solely for ACPI sleep needs - we have
initial_page_table for that.
Signed-off-by: Borislav Petkov <bp@alien8.de>
LKML-Reference: <20101020070526.GA9588@liondog.tnic>
This patch fixes machine crashes which occur when heavily exercising the
CPU hotplug codepaths on a 32-bit kernel. These crashes are caused by
AMD Erratum 383 and result in a fatal machine check exception. Here's
the scenario:
1. On 32-bit, the swapper_pg_dir page table is used as the initial page
table for booting a secondary CPU.
2. To make this work, swapper_pg_dir needs a direct mapping of physical
memory in it (the low mappings). By adding those low, large page (2M)
mappings (PAE kernel), we create the necessary conditions for Erratum
383 to occur.
3. Other CPUs which do not participate in the off- and onlining game may
use swapper_pg_dir while the low mappings are present (when leave_mm is
called). For all steps below, the CPU referred to is a CPU that is using
swapper_pg_dir, and not the CPU which is being onlined.
4. The presence of the low mappings in swapper_pg_dir can result
in TLB entries for addresses below __PAGE_OFFSET to be established
speculatively. These TLB entries are marked global and large.
5. When the CPU with such TLB entry switches to another page table, this
TLB entry remains because it is global.
6. The process then generates an access to an address covered by the
above TLB entry but there is a permission mismatch - the TLB entry
covers a large global page not accessible to userspace.
7. Due to this permission mismatch a new 4kb, user TLB entry gets
established. Further, Erratum 383 provides for a small window of time
where both TLB entries are present. This results in an uncorrectable
machine check exception signalling a TLB multimatch which panics the
machine.
There are two ways to fix this issue:
1. Always do a global TLB flush when a new cr3 is loaded and the
old page table was swapper_pg_dir. I consider this a hack hard
to understand and with performance implications
2. Do not use swapper_pg_dir to boot secondary CPUs like 64-bit
does.
This patch implements solution 2. It introduces a trampoline_pg_dir
which has the same layout as swapper_pg_dir with low_mappings. This page
table is used as the initial page table of the booting CPU. Later in the
bringup process, it switches to swapper_pg_dir and does a global TLB
flush. This fixes the crashes in our test cases.
-v2: switch to swapper_pg_dir right after entering start_secondary() so
that we are able to access percpu data which might not be mapped in the
trampoline page table.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
LKML-Reference: <20100816123833.GB28147@aftab>
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
Add support for saving OFW's cif, and later calling into it to run OFW
commands. OFW remains resident in memory, living within virtual range
0xff800000 - 0xffc00000. A single page directory entry points to the
pgdir that OFW actually uses, so rather than saving the entire page
table, we grab and install that one entry permanently in the kernel's
page table.
This is currently only used by the OLPC XO. Note that this particular
calling convention breaks PAE and PAT, and so cannot be used on newer
x86 hardware.
Signed-off-by: Andres Salomon <dilinger@queued.net>
LKML-Reference: <20100618174653.7755a39a@dev.queued.net>
arch/powerpc/platforms/pseries/hvCall.S
include/linux/percpu.h
Use symbolic constants rather than hard-coded values when setting
EFER.NX in head_32.S, and do a more rigorous test for the validity of
the response when probing for the extended CPUID range.
LKML-Reference: <1258154897-6770-2-git-send-email-hpa@zytor.com>
Acked-by: Kees Cook <kees.cook@canonical.com>
Now that the return from alloc_percpu is compatible with the address
of per-cpu vars, it makes sense to hand around the address of per-cpu
variables. To make this sane, we remove the per_cpu__ prefix we used
created to stop people accidentally using these vars directly.
Now we have sparse, we can use that (next patch).
tj: * Updated to convert stuff which were missed by or added after the
original patch.
* Kill per_cpu_var() macro.
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
x86: Remove redundant non-NUMA topology functions
x86: early_printk: Protect against using the same device twice
x86: Reduce verbosity of "PAT enabled" kernel message
x86: Reduce verbosity of "TSC is reliable" message
x86: mce: Use safer ways to access MCE registers
x86: mce, inject: Use real inject-msg in raise_local
x86: mce: Fix thermal throttling message storm
x86: mce: Clean up thermal throttling state tracking code
x86: split NX setup into separate file to limit unstack-protected code
xen: check EFER for NX before setting up GDT mapping
x86: Cleanup linker script using new linker script macros.
x86: Use section .data.page_aligned for the idt_table.
x86: convert to use __HEAD and HEAD_TEXT macros.
x86: convert compressed loader to use __HEAD and HEAD_TEXT macros.
x86: fix fragile computation of vsyscall address
Merge reason: The linker script cleanups are ready for upstream.
This patch changes the remaining direct references to
.data.page_aligned in C and assembly code to use the macros in
include/linux/linkage.h.
Signed-off-by: Tim Abbott <tabbott@ksplice.com>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
.bss.page_aligned in C and assembly code to use the macros in
Acked-by: Paul Mundt <lethal@linux-sh.org>
Cc: Chris Zankel <chris@zankel.net>
* 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (38 commits)
x86: Move get/set_wallclock to x86_platform_ops
x86: platform: Fix section annotations
x86: apic namespace cleanup
x86: Distangle ioapic and i8259
x86: Add Moorestown early detection
x86: Add hardware_subarch ID for Moorestown
x86: Add early platform detection
x86: Move tsc_init to late_time_init
x86: Move tsc_calibration to x86_init_ops
x86: Replace the now identical time_32/64.c by time.c
x86: time_32/64.c unify profile_pc
x86: Move calibrate_cpu to tsc.c
x86: Make timer setup and global variables the same in time_32/64.c
x86: Remove mca bus ifdef from timer interrupt
x86: Simplify timer_ack magic in time_32.c
x86: Prepare unification of time_32/64.c
x86: Remove do_timer hook
x86: Add timer_init to x86_init_ops
x86: Move percpu clockevents setup to x86_init_ops
x86: Move xen_post_allocator_init into xen_pagetable_setup_done
Fix up conflicts in arch/x86/include/asm/io_apic.h
This has the consequence of changing the section name use for head
code from ".text.head" to ".head.text". It also eliminates the
".text.head" output section (instead placing head code at the start of
the .text output section), which should be harmless.
This patch only changes the sections in the actual kernel, not those
in the compressed boot loader.
The Intel Optimization Reference Guide says:
In Intel Atom microarchitecture, the address generation unit
assumes that the segment base will be 0 by default. Non-zero
segment base will cause load and store operations to experience
a delay.
- If the segment base isn't aligned to a cache line
boundary, the max throughput of memory operations is
reduced to one [e]very 9 cycles.
Assembly/Compiler Coding Rule 15. (H impact, ML generality)
For Intel Atom processors, use segments with base set to 0
whenever possible; avoid non-zero segment base address that is
not aligned to cache line boundary at all cost.
We can't avoid having a non-zero base for the stack-protector
segment, but we can make it cache-aligned.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Cc: <stable@kernel.org>
LKML-Reference: <4AA01893.6000507@goop.org>
x86 bootprotocol 2.07 has introduced hardware_subarch ID in the boot
parameters provided by FW. We use it to identify Moorestown platforms.
[ tglx: Cleanup and paravirt fix ]
Signed-off-by: Jacob Pan <jacob.jun.pan@intel.com>
Commit 0e83815be719d3391bf5ea24b7fe696c07dbd417 changed the
section the initial_code variable gets allocated in, in an
attempt to address a section conflict warning. This, however
created a new section conflict when building without
HOTPLUG_CPU. The apparently only (reasonable) way to address
this is to always use __REFDATA.
Once at it, also fix a second section mismatch when not using
HOTPLUG_CPU.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Cc: Robert Richter <robert.richter@amd.com>
LKML-Reference: <4A8AE7CD020000780001054B@vpn.id2.novell.com>
Startup code for i386 in arch/x86/kernel/head_32.S is using the
reference variable initial_code that is located in the .cpuinit.data
section. If CONFIG_HOTPLUG_CPU is enabled, startup code is not in an
init section and can be called later too. In this case the reference
initial_code must be kept too. This patch fixes this. See below for
the section mismatch warning.
WARNING: vmlinux.o(.cpuinit.data+0x0): Section mismatch in reference
from the variable initial_code to the function
.init.text:i386_start_kernel()
The variable __cpuinitdata initial_code references
a function __init i386_start_kernel().
If i386_start_kernel is only used by initial_code then
annotate i386_start_kernel with a matching annotation.
Signed-off-by: Robert Richter <robert.richter@amd.com>
LKML-Reference: <1248716632-26844-1-git-send-email-robert.richter@amd.com>
asm/desc.h is included in three assembly files, but the only macro
it defines, GET_DESC_BASE, is never used. This patch removes the
includes, removes the macro GET_DESC_BASE and the ASSEMBLY guard
from asm/desc.h.
Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm>
32 bit x86 had a dedicated .text.head output section,
whereas 64 bit had it all in a single output section.
In the unified version the dedicated .text.head output section
was kept to have full control over the head code.
32 bit:
- Moved definition of _stext to the linker script.
The definition is located _after_ .text.page_aligned as this
is what 32 bit did before.
The ALIGN(8) was introduced so we hit the exact same address
(on the tested config) before and after the move.
I assume that it is a bug that _stext did not cover the
.text.page_aligned section - if this is true it can be fixed
in a follow-up patch (and the ugly ALIGN() can be dropped).
[ Impact: 64-bit: cleanup, 32-bit: use the 64-bit linker script ]
Cc: Tim Abbott <tabbott@MIT.EDU>
LKML-Reference: <1240991249-27117-5-git-send-email-sam@ravnborg.org>
Impact: Tighten bound to avoid masking errors
The definition of MAPPING_BEYOND_END was excessive; this has a nasty
tendency to mask bugs. We have learned over time that this kind of
bug hiding can cause some very strange errors. Therefore, tighten the
bound to only need to map the actual kernel area.
Cc: Yinghai Lu <yinghai@kernel.org>
Impact: cleanup
ALLOCATOR_SLOP is a vestigial remain from when we used the
bootmem allocator to allocate the kernel's linear memory mapping.
Now we directly reserve pages from the e820 mapping, and no
longer require secondary structures to keep track of allocated
pages.
