path: root/arch/x86/kernel/pci-gart_64.c
2011-05-10x86, gart: Rename pci-gart_64.c to amd_gart_64.cJoerg Roedel
This file only contains code relevant for the northbridge gart in AMD processors. This patch renames the file to represent this fact in the filename. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2011-04-18x86, gart: Make sure GART does not map physmem above 1TBJoerg Roedel
The GART can only map physical memory below 1TB. Make sure the gart driver in the kernel does not try to map memory above 1TB. Cc: <stable@kernel.org> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Link: http://lkml.kernel.org/r/1303134346-5805-5-git-send-email-joerg.roedel@amd.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2011-03-23x86: Use syscore_ops instead of sysdev classes and sysdevsRafael J. Wysocki
Some subsystems in the x86 tree need to carry out suspend/resume and shutdown operations with one CPU on-line and interrupts disabled and they define sysdev classes and sysdevs or sysdev drivers for this purpose. This leads to unnecessarily complicated code and excessive memory usage, so switch them to using struct syscore_ops objects for this purpose instead. Generally, there are three categories of subsystems that use sysdevs for implementing PM operations: (1) subsystems whose suspend/resume callbacks ignore their arguments entirely (the majority), (2) subsystems whose suspend/resume callbacks use their struct sys_device argument, but don't really need to do that, because they can be implemented differently in an arguably simpler way (io_apic.c), and (3) subsystems whose suspend/resume callbacks use their struct sys_device argument, but the value of that argument is always the same and could be ignored (microcode_core.c). In all of these cases the subsystems in question may be readily converted to using struct syscore_ops objects for power management and shutdown. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu>
2010-11-18x86, amd-nb: Cleanup AMD northbridge caching codeHans Rosenfeld
Support more than just the "Misc Control" part of the northbridges. Support more flags by turning "gart_supported" into a single bit flag that is stored in a flags member. Clean up related code by using a set of functions (amd_nb_num(), amd_nb_has_feature() and node_to_amd_nb()) instead of accessing the NB data structures directly. Reorder the initialization code and put the GART flush words caching in a separate function. Signed-off-by: Hans Rosenfeld <hans.rosenfeld@amd.com> Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2010-11-18x86, amd-nb: Complete the rename of AMD NB and related codeHans Rosenfeld
Not only the naming of the files was confusing, it was even more so for the function and variable names. Renamed the K8 NB and NUMA stuff that is also used on other AMD platforms. This also renames the CONFIG_K8_NUMA option to CONFIG_AMD_NUMA and the related file k8topology_64.c to amdtopology_64.c. No functional changes intended. Signed-off-by: Hans Rosenfeld <hans.rosenfeld@amd.com> Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2010-10-21Merge branch 'x86-iommu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, iommu: Update header comments with appropriate naming ia64, iommu: Add a dummy iommu_table.h file in IA64. x86, iommu: Fix IOMMU_INIT alignment rules x86, doc: Adding comments about .iommu_table and its neighbors. x86, iommu: Utilize the IOMMU_INIT macros functionality. x86, VT-d: Make Intel VT-d IOMMU use IOMMU_INIT_* macros. x86, GART/AMD-VI: Make AMD GART and IOMMU use IOMMU_INIT_* macros. x86, calgary: Make Calgary IOMMU use IOMMU_INIT_* macros. x86, xen-swiotlb: Make Xen-SWIOTLB use IOMMU_INIT_* macros. x86, swiotlb: Make SWIOTLB use IOMMU_INIT_* macros. x86, swiotlb: Simplify SWIOTLB pci_swiotlb_detect routine. x86, iommu: Add proper dependency sort routine (and sanity check). x86, iommu: Make all IOMMU's detection routines return a value. x86, iommu: Add IOMMU_INIT macros, .iommu_table section, and iommu_table_entry structure
2010-10-21Merge branch 'x86-amd-nb-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-amd-nb-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, amd_nb: Enable GART support for AMD family 0x15 CPUs x86, amd: Use compute unit information to determine thread siblings x86, amd: Extract compute unit information for AMD CPUs x86, amd: Add support for CPUID topology extension of AMD CPUs x86, nmi: Support NMI watchdog on newer AMD CPU families x86, mtrr: Assume SYS_CFG[Tom2ForceMemTypeWB] exists on all future AMD CPUs x86, k8: Rename k8.[ch] to amd_nb.[ch] and CONFIG_K8_NB to CONFIG_AMD_NB x86, k8-gart: Decouple handling of garts and northbridges x86, cacheinfo: Fix dependency of AMD L3 CID x86, kvm: add new AMD SVM feature bits x86, cpu: Fix allowed CPUID bits for KVM guests x86, cpu: Update AMD CPUID feature bits x86, cpu: Fix renamed, not-yet-shipping AMD CPUID feature bit x86, AMD: Remove needless CPU family check (for L3 cache info) x86, tsc: Remove CPU frequency calibration on AMD
2010-09-20x86, k8: Rename k8.[ch] to amd_nb.[ch] and CONFIG_K8_NB to CONFIG_AMD_NBAndreas Herrmann
The file names are somehow misleading as the code is not specific to AMD K8 CPUs anymore. The files accomodate code for other AMD CPU northbridges as well. Same is true for the config option which is valid for AMD CPU northbridges in general and not specific to K8. Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> LKML-Reference: <20100917160343.GD4958@loge.amd.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-09-17x86, k8-gart: Decouple handling of garts and northbridgesAndreas Herrmann
So far we only provide num_k8_northbridges. This is required in different areas (e.g. L3 cache index disable, GART). But not all AMD CPUs provide a GART. Thus it is useful to split off the GART handling from the generic caching of AMD northbridge misc devices. Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> LKML-Reference: <20100917160254.GC4958@loge.amd.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-09-05x86, GART: Disable GART table walk probesBorislav Petkov
Current code tramples over bit F3x90[6] which can be used to disable GART table walk probes. However, this bit should be set for performance reasons (speed up GART table walks). We are allowed to do that since we put GART tables in UC memory later anyway. Make it so. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Cc: Dave Airlie <airlied@redhat.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> LKML-Reference: <1283531981-7495-3-git-send-email-bp@amd64.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-08-26x86, GART/AMD-VI: Make AMD GART and IOMMU use IOMMU_INIT_* macros.Konrad Rzeszutek Wilk
We utilize the IOMMU_INIT macros to create this dependency: [null] | [pci_xen_swiotlb_detect] | [pci_swiotlb_detect_override] | [pci_swiotlb_detect_4gb] | +-------+--------+ / \ [detect_calgary] [gart_iommu_hole_init] | [amd_iommu_detect] Meaning that 'amd_iommu_detect' will be called after 'gart_iommu_hole_init'. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> LKML-Reference: <1282845485-8991-9-git-send-email-konrad.wilk@oracle.com> CC: Fujita Tomonori <fujita.tomonori@lab.ntt.co.jp> CC: Joerg Roedel <joerg.roedel@amd.com> CC: Thomas Gleixner <tglx@linutronix.de> CC: Ingo Molnar <mingo@redhat.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-04-13Merge branch 'iommu/fixes' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/joro/linux-2.6-iommu into x86/urgent
2010-04-07x86/gart: Disable GART explicitly before initializationJoerg Roedel
If we boot into a crash-kernel the gart might still be enabled and its caches might be dirty. This can result in undefined behavior later. Fix it by explicitly disabling the gart hardware before initialization and flushing the caches after enablement. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-13x86, k8 nb: Fix boot crash: enable k8_northbridges unconditionally on AMD ↵Borislav Petkov
systems de957628ce7c84764ff41331111036b3ae5bad0f changed setting of the x86_init.iommu.iommu_init function ptr only when GART IOMMU is found. One side effect of it is that num_k8_northbridges is not initialized anymore if not explicitly called. This resulted in uninitialized pointers in <arch/x86/kernel/cpu/intel_cacheinfo.c:amd_calc_l3_indices()>, for example, which uses the num_k8_northbridges thing through node_to_k8_nb_misc(). Fix that through an initcall that runs right after the PCI subsystem and does all the scanning. Then, remove initialization in gart_iommu_init() which is a rootfs_initcall and we're running before that. What is more, since num_k8_northbridges is being used in other places beside GART IOMMU, include it whenever we add AMD CPU support. The previous dependency chain in kconfig contained K8_NB depends on AGP_AMD64|GART_IOMMU which was clearly incorrect. The more natural way in terms of hardware dependency should be AGP_AMD64|GART_IOMMU depends on K8_NB depends on CPU_SUP_AMD && PCI. Make it so Number One! Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Joerg Roedel <joerg.roedel@amd.com> LKML-Reference: <20100312144303.GA29262@aftab> Signed-off-by: Ingo Molnar <mingo@elte.hu> Tested-by: Joerg Roedel <joerg.roedel@amd.com>
2009-12-16iommu-helper: use bitmap libraryAkinobu Mita
Use bitmap library and kill some unused iommu helper functions. 1. s/iommu_area_free/bitmap_clear/ 2. s/iommu_area_reserve/bitmap_set/ 3. Use bitmap_find_next_zero_area instead of find_next_zero_area This cannot be simple substitution because find_next_zero_area doesn't check the last bit of the limit in bitmap 4. Remove iommu_area_free, iommu_area_reserve, and find_next_zero_area Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-14x86: Gart: fix breakage due to IOMMU initialization cleanupYinghai Lu
This fixes the following breakage of the commit 75f1cdf1dda92cae037ec848ae63690d91913eac: - GART systems that don't AGP with broken BIOS and more than 4GB memory are forced to use swiotlb. They can allocate aperture by hand and use GART. - GART systems without GAP must disable GART on shutdown. - swiotlb usage is forced by the boot option, gart_iommu_hole_init() is not called, so we disable GART early_gart_iommu_check(). Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> LKML-Reference: <1260759135-6450-3-git-send-email-fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-17x86: gart: Clean up the code a bitIngo Molnar
Clean up various small stylistic details in the GART code. No functionality changed. Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: muli@il.ibm.com Cc: joerg.roedel@amd.com LKML-Reference: <1258287594-8777-2-git-send-email-fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-17x86: gart: Add own dma_mapping_error functionFUJITA Tomonori
GART IOMMU is the only user of bad_dma_address variable. This patch converts GART to use the newer mechanism, fill in ->mapping_error() in struct dma_map_ops, to make dma_mapping_error() work in IOMMU specific way. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: muli@il.ibm.com Cc: joerg.roedel@amd.com LKML-Reference: <1258287594-8777-2-git-send-email-fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-10x86: Handle HW IOMMU initialization failure gracefullyFUJITA Tomonori
If HW IOMMU initialization fails (Intel VT-d often does this, typically due to BIOS bugs), we fall back to nommu. It doesn't work for the majority since nowadays we have more than 4GB memory so we must use swiotlb instead of nommu. The problem is that it's too late to initialize swiotlb when HW IOMMU initialization fails. We need to allocate swiotlb memory earlier from bootmem allocator. Chris explained the issue in detail: http://marc.info/?l=linux-kernel&m=125657444317079&w=2 The current x86 IOMMU initialization sequence is too complicated and handling the above issue makes it more hacky. This patch changes x86 IOMMU initialization sequence to handle the above issue cleanly. The new x86 IOMMU initialization sequence are: 1. we initialize the swiotlb (and setting swiotlb to 1) in the case of (max_pfn > MAX_DMA32_PFN && !no_iommu). dma_ops is set to swiotlb_dma_ops or nommu_dma_ops. if swiotlb usage is forced by the boot option, we finish here. 2. we call the detection functions of all the IOMMUs 3. the detection function sets x86_init.iommu.iommu_init to the IOMMU initialization function (so we can avoid calling the initialization functions of all the IOMMUs needlessly). 4. if the IOMMU initialization function doesn't need to swiotlb then sets swiotlb to zero (e.g. the initialization is sucessful). 5. if we find that swiotlb is set to zero, we free swiotlb resource. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: chrisw@sous-sol.org Cc: dwmw2@infradead.org Cc: joerg.roedel@amd.com Cc: muli@il.ibm.com LKML-Reference: <1257849980-22640-10-git-send-email-fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-10x86: GART: Convert gart_iommu_hole_init() to use iommu_init hookFUJITA Tomonori
This changes gart_iommu_hole_init() to set gart_iommu_init() to iommu_init hook if gart_iommu_hole_init() finds the GART IOMMU. We can kill the code to check if we found the IOMMU in gart_iommu_init() since gart_iommu_hole_init() sets gart_iommu_init() only when it found the IOMMU. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: chrisw@sous-sol.org Cc: dwmw2@infradead.org Cc: joerg.roedel@amd.com Cc: muli@il.ibm.com LKML-Reference: <1257849980-22640-4-git-send-email-fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-10x86: GART: pci-gart_64.c: Use correct length in strncmpJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Cc: <stable@kernel.org> # .3x.x LKML-Reference: <1257818330.12852.72.camel@Joe-Laptop.home> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-08x86: Use x86_platform for iommu_shutdownFUJITA Tomonori
This patch cleans up pci_iommu_shutdown() a bit to use x86_platform (similar to how IA64 initializes an IOMMU driver). This adds iommu_shutdown() to x86_platform to avoid calling every IOMMUs' shutdown functions in pci_iommu_shutdown() in order. The IOMMU shutdown functions are platform specific (we don't have multiple different IOMMU hardware) so the current way is pointless. An IOMMU driver sets x86_platform.iommu_shutdown to the shutdown function if necessary. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: joerg.roedel@amd.com LKML-Reference: <20091027163358F.fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-07-28x86: replace is_buffer_dma_capable() with dma_capableFUJITA Tomonori
2009-07-08Remove multiple KERN_ prefixes from printk formatsJoe Perches
Commit 5fd29d6ccbc98884569d6f3105aeca70858b3e0f ("printk: clean up handling of log-levels and newlines") changed printk semantics. printk lines with multiple KERN_<level> prefixes are no longer emitted as before the patch. <level> is now included in the output on each additional use. Remove all uses of multiple KERN_<level>s in formats. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-06x86: enable GART-IOMMU only after setting up protection methodsMark Langsdorf
The current code to set up the GART as an IOMMU enables GART translations before it removes the aperture from the kernel memory map, sets the GART PTEs to UC, sets up the guard and scratch pages, or does a wbinvd(). This leaves the possibility of cache aliasing open and can cause system crashes. Re-order the code so as to enable the GART translations only after all safeguards are in place and the tlb has been flushed. AMD has tested this patch on both Istanbul systems and 1st generation Opteron systems with APG enabled and seen no adverse effects. Istanbul systems with HT Assist enabled sometimes see MCE errors due to cache artifacts with the unmodified code. Signed-off-by: Mark Langsdorf <mark.langsdorf@amd.com> Cc: <stable@kernel.org> Cc: Joerg Roedel <joerg.roedel@amd.com> Cc: akpm@linux-foundation.org Cc: jbarnes@virtuousgeek.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-15x86 gart: reimplement IOMMU_LEAK feature by using DMA_API_DEBUGFUJITA Tomonori
IOMMU_LEAK, GART's own feature, dumps the used IOMMU entries when IOMMU entries is full, which might be useful to find a bad driver that eats IOMMU entries. DMA_API_DEBUG provides the similar feature, debug_dma_dump_mappings, and it's better than GART's IOMMU_LEAK feature. GART's IOMMU_LEAK feature doesn't say who uses IOMMU entries so it's hard to find a bad driver. This patch reimplements the GART's IOMMU_LEAK feature by using DMA_API_DEBUG. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Joerg Roedel <joerg.roedel@amd.com> Cc: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <1239669799-23579-2-git-send-email-fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-05Merge branch 'linus' into core/iommuIngo Molnar
2009-01-29Documentation: move DMA-mapping.txt to Doc/PCI/Randy Dunlap
Move DMA-mapping.txt to Documentation/PCI/. DMA-mapping.txt was supposed to be moved from Documentation/ to Documentation/PCI/. The 00-INDEX files in those two directories were updated, along with a few other text files, but the file itself somehow escaped being moved, so move it and update more text files and source files with its new location. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06x86, ia64: convert to use generic dma_map_ops structFUJITA Tomonori
This converts X86 and IA64 to use include/linux/dma-mapping.h. It's a bit large but pretty boring. The major change for X86 is converting 'int dir' to 'enum dma_data_direction dir' in DMA mapping operations. The major changes for IA64 is using map_page and unmap_page instead of map_single and unmap_single. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-06x86: remove map_single and unmap_single in struct dma_mapping_opsFUJITA Tomonori
This patch converts dma_map_single and dma_unmap_single to use map_page and unmap_page respectively and removes unnecessary map_single and unmap_single in struct dma_mapping_ops. This leaves intel-iommu's dma_map_single and dma_unmap_single since IA64 uses them. They will be removed after the unification. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-06x86, gart: add map_page and unmap_pageFUJITA Tomonori
This is a preparation of struct dma_mapping_ops unification. We use map_page and unmap_page instead of map_single and unmap_single. We will remove map_single and unmap_single hooks in the last patch in this patchset. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-29x86_64: pci-gart_64.c iommu_fullflush should be staticJaswinder Singh Rajput
Impact: cleanup, reduce kernel size a bit, avoid sparse warning Fixes sparse warning: arch/x86/kernel/pci-gart_64.c:55:5: warning: symbol 'iommu_fullflush' was not declared. Should it be static? Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-18x86 gart: don't complain if no AMD GART foundBjorn Helgaas
Impact: remove annoying bootup printk It's perfectly normal for no AMD GART to be present, e.g., if you have Intel CPUs. None of the other iommu_init() functions makes noise when it finds nothing. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-03x86: fix broken flushing in GART nofullflush pathJoerg Roedel
Impact: remove stale IOTLB entries In the non-default nofullflush case the GART is only flushed when next_bit wraps around. But it can happen that an unmap operation unmaps memory which is behind the current next_bit location. If these addresses are reused it may result in stale GART IO/TLB entries. Fix this by setting the GART next_bit always behind an unmapped location. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-28x86, gart: fix gart detection for Fam11h CPUsJoerg Roedel
Impact: fix AMD Family 11h boot hangs / USB device problems The AMD Fam11h CPUs have a K8 northbridge. This northbridge is different from other family's because it lacks GART support (as I just learned). But the kernel implicitly expects a GART if it finds an AMD northbridge. Fix this by removing the Fam11h northbridge id from the scan list of K8 northbridges. This patch also changes the message in the GART driver about missing K8 northbridges to tell that the GART is missing which is the correct information in this case. Reported-by: Jouni Malinen <jkmalinen@gmail.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-16x86: convert GART driver to generic iommu_num_pages functionJoerg Roedel
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16x86: rename iommu_num_pages function to iommu_nr_pagesJoerg Roedel
This series of patches re-introduces the iommu_num_pages function so that it can be used by each architecture specific IOMMU implementations. The series also changes IOMMU implementations for X86, Alpha, PowerPC and UltraSparc. The other implementations are not yet changed because the modifications required are not obvious and I can't test them on real hardware. This patch: This is a preparation patch for introducing a generic iommu_num_pages function. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-10Merge branches 'core/iommu', 'x86/amd-iommu' and 'x86/iommu' into ↵Ingo Molnar
x86-v28-for-linus-phase3-B Conflicts: arch/x86/kernel/pci-gart_64.c include/asm-x86/dma-mapping.h
2008-10-06Merge branches 'x86/alternatives', 'x86/cleanups', 'x86/commandline', ↵Ingo Molnar
'x86/crashdump', 'x86/debug', 'x86/defconfig', 'x86/doc', 'x86/exports', 'x86/fpu', 'x86/gart', 'x86/idle', 'x86/mm', 'x86/mtrr', 'x86/nmi-watchdog', 'x86/oprofile', 'x86/paravirt', 'x86/reboot', 'x86/sparse-fixes', 'x86/tsc', 'x86/urgent' and 'x86/vmalloc' into x86-v28-for-linus-phase1
2008-10-05x86: gart iommu have direct mapping when agp is present tooYinghai Lu
move init_memory_mapping() out of init_k8_gatt. for: http://bugzilla.kernel.org/show_bug.cgi?id=11676 2.6.27-rc2 to rc8, apgart fails, iommu=soft works, regression This is needed because we need to map the GART aperture even if the GATT is not initialized. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-27x86/iommu: use __GFP_ZERO instead of memset for GARTJoerg Roedel
2008-09-27x86/iommu: convert GART need_flush to boolJoerg Roedel
2008-09-27x86/iommu: make GART driver checkpatch cleanJoerg Roedel
2008-09-25x86 gart: remove unnecessary initializationFUJITA Tomonori
There is no point to have such initialization in struct dma_mapping_ops. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-25x86: restore old GART alloc_coherent behaviorFUJITA Tomonori
Currently, GART alloc_coherent tries to allocate pages with GFP_DMA32 for a device having dma_masks > 24bit < 32bits. If GART gets an address that a device can't access to, GART try to map the address to a virtual I/O address that the device can access to. But Andi pointed out, "The GART is somewhere in the 4GB range so you cannot use it to map anything < 4GB. Also GART is pretty small." http://lkml.org/lkml/2008/9/12/43 That is, it's possible that GART doesn't have virtual I/O address space that a device can access to. The above behavior doesn't work for a device having dma_masks > 24bit < 32bits. This patch restores old GART alloc_coherent behavior (before the alloc_coherent rewrite). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-25revert "x86: make GART to respect device's dma_mask about virtual mappings"FUJITA Tomonori
This reverts: commit bee44f294efd8417f5e68553778a6cc957af1547 Author: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Date: Fri Sep 12 19:42:35 2008 +0900 x86: make GART to respect device's dma_mask about virtual mappings I wrote the above commit to fix a GART alloc_coherent regression, that can't handle a device having dma_masks > 24bit < 32bits, introduced by the alloc_coherent rewrite: http://lkml.org/lkml/2008/8/12/200 After the alloc_coherent rewrite, GART alloc_coherent tried to allocate pages with GFP_DMA32. If GART got an address that a device can't access to, GART mapped the address to a virtual I/O address. But GART mapping mechanism didn't take account of dma mask, so GART could use a virtual I/O address that the device can't access to again. Alan pointed out: " This is indeed a specific problem found with things like older AACRAID where control blocks must be below 31bits and the GART is above 0x80000000. " The above commit modified GART mapping mechanism to take care of dma mask. But Andi pointed out, "The GART is somewhere in the 4GB range so you cannot use it to map anything < 4GB. Also GART is pretty small." http://lkml.org/lkml/2008/9/12/43 That means it's possible that GART doesn't have virtual I/O address space that a device can access to. The above commit (to modify GART mapping mechanism to take care of dma mask) can't fix the regression reliably so let's avoid making GART more complicated. We need a solution that always works for dma_masks > 24bit < 32bits. That's how GART worked before the alloc_coherent rewrite. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Joerg Roedel <joerg.roedel@amd.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-22iommu: remove fullflush and nofullflush in IOMMU generic optionFUJITA Tomonori
This patch against tip/x86/iommu virtually reverts 2842e5bf3115193f05dc9dac20f940e7abf44c1a. But just reverting the commit breaks AMD IOMMU so this patch also includes some fixes. The above commit adds new two options to x86 IOMMU generic kernel boot options, fullflush and nofullflush. But such change that affects all the IOMMUs needs more discussion (all IOMMU parties need the chance to discuss it): http://lkml.org/lkml/2008/9/19/106 Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-22iommu: export iommu_area_reserve helper functionFUJITA Tomonori
x86 has set_bit_string() that does the exact same thing that set_bit_area() in lib/iommu-helper.c does. This patch exports set_bit_area() in lib/iommu-helper.c as iommu_area_reserve(), converts GART, Calgary, and AMD IOMMU to use it. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
