commit 6690e86be83ac75832e461c141055b5d601c0a6d upstream.
Effectively reverts commit:
2c7577a75837 ("sched/x86_64: Don't save flags on context switch")
Specifically because SMAP uses FLAGS.AC which invalidates the claim
that the kernel has clean flags.
In particular; while preemption from interrupt return is fine (the
IRET frame on the exception stack contains FLAGS) it breaks any code
that does synchonous scheduling, including preempt_enable().
This has become a significant issue ever since commit:
5b24a7a2aa20 ("Add 'unsafe' user access functions for batched accesses")
provided for means of having 'normal' C code between STAC / CLAC,
exposing the FLAGS.AC state. So far this hasn't led to trouble,
however fix it before it comes apart.
Reported-by: Julien Thierry <julien.thierry@arm.com>
Acked-by: Andy Lutomirski <luto@amacapital.net>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: stable@kernel.org
Fixes: 5b24a7a2aa20 ("Add 'unsafe' user access functions for batched accesses")
commit ff16701a29cba3aafa0bd1656d766813b2d0a811 upstream
Move the conditional invocation of __switch_to_xtra() into an inline
function so the logic can be shared between 32 and 64 bit.
Remove the handthrough of the TSS pointer and retrieve the pointer directly
in the bitmap handling function. Use this_cpu_ptr() instead of the
per_cpu() indirection.
This is a preparatory change so integration of conditional indirect branch
speculation optimization happens only in one place.
Reviewed-by: Ingo Molnar <mingo@kernel.org>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Tom Lendacky <thomas.lendacky@amd.com>
Cc: David Woodhouse <dwmw@amazon.co.uk>
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Cc: Casey Schaufler <casey.schaufler@intel.com>
Cc: Asit Mallick <asit.k.mallick@intel.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Jon Masters <jcm@redhat.com>
Cc: Waiman Long <longman9394@gmail.com>
Cc: Greg KH <gregkh@linuxfoundation.org>
Cc: Dave Stewart <david.c.stewart@intel.com>
Cc: stable@vger.kernel.org
Link: https://lkml.kernel.org/r/20181125185005.280855518@linutronix.de
commit c482feefe1aeb150156248ba0fd3e029bc886605 upstream.
The TSS is a fairly juicy target for exploits, and, now that the TSS
is in the cpu_entry_area, it's no longer protected by kASLR. Make it
read-only on x86_64.
On x86_32, it can't be RO because it's written by the CPU during task
switches, and we use a task gate for double faults. I'd also be
nervous about errata if we tried to make it RO even on configurations
without double fault handling.
[ tglx: AMD confirmed that there is no problem on 64-bit with TSS RO. So
it's probably safe to assume that it's a non issue, though Intel
might have been creative in that area. Still waiting for
confirmation. ]
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Reviewed-by: Borislav Petkov <bpetkov@suse.de>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: David Laight <David.Laight@aculab.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Eduardo Valentin <eduval@amazon.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: aliguori@amazon.com
Cc: daniel.gruss@iaik.tugraz.at
Cc: hughd@google.com
Cc: keescook@google.com
Link: https://lkml.kernel.org/r/20171204150606.733700132@linutronix.de
commit 46f5a10a721ce8dce8cc8fe55279b49e1c6b3288 upstream.
The only remaining readers in context switch code or vm86(), and
they all just want to update TSS.sp0 to match the current task.
Replace them all with a new helper update_sp0().
Reviewed-by: Borislav Petkov <bp@suse.de>
Cc: Borislav Petkov <bpetkov@suse.de>
Link: http://lkml.kernel.org/r/2d231687f4ff288c9d9e98d7861b7df374246ac3.1509609304.git.luto@kernel.org
commit da51da189a24bb9b7e2d5a123be096e51a4695a5 upstream.
load_sp0() had an odd signature:
void load_sp0(struct tss_struct *tss, struct thread_struct *thread);
Simplify it to:
void load_sp0(unsigned long sp0);
Also simplify a few get_cpu()/put_cpu() sequences to
preempt_disable()/preempt_enable().
Link: http://lkml.kernel.org/r/2655d8b42ed940aa384fe18ee1129bbbcf730a08.1509609304.git.luto@kernel.org
commit bd7dc5a6afac719d8ce4092391eef2c7e83c2a75 upstream.
This causes the MSR_IA32_SYSENTER_CS write to move out of the
paravirt callback. This shouldn't affect Xen PV: Xen already ignores
MSR_IA32_SYSENTER_ESP writes. In any event, Xen doesn't support
vm86() in a useful way.
Note to any potential backporters: This patch won't break lguest, as
lguest didn't have any SYSENTER support at all.
Link: http://lkml.kernel.org/r/75cf09fe03ae778532d0ca6c65aa58e66bc2f90c.1509609304.git.luto@kernel.org
Pull x86 cache quality monitoring update from Thomas Gleixner:
"This update provides a complete rewrite of the Cache Quality
Monitoring (CQM) facility.
The existing CQM support was duct taped into perf with a lot of issues
and the attempts to fix those turned out to be incomplete and
horrible.
After lengthy discussions it was decided to integrate the CQM support
into the Resource Director Technology (RDT) facility, which is the
obvious choise as in hardware CQM is part of RDT. This allowed to add
Memory Bandwidth Monitoring support on top.
As a result the mechanisms for allocating cache/memory bandwidth and
the corresponding monitoring mechanisms are integrated into a single
management facility with a consistent user interface"
* 'x86-cache-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (37 commits)
x86/intel_rdt: Turn off most RDT features on Skylake
x86/intel_rdt: Add command line options for resource director technology
x86/intel_rdt: Move special case code for Haswell to a quirk function
x86/intel_rdt: Remove redundant ternary operator on return
x86/intel_rdt/cqm: Improve limbo list processing
x86/intel_rdt/mbm: Fix MBM overflow handler during CPU hotplug
x86/intel_rdt: Modify the intel_pqr_state for better performance
x86/intel_rdt/cqm: Clear the default RMID during hotcpu
x86/intel_rdt: Show bitmask of shareable resource with other executing units
x86/intel_rdt/mbm: Handle counter overflow
x86/intel_rdt/mbm: Add mbm counter initialization
x86/intel_rdt/mbm: Basic counting of MBM events (total and local)
x86/intel_rdt/cqm: Add CPU hotplug support
x86/intel_rdt/cqm: Add sched_in support
x86/intel_rdt: Introduce rdt_enable_key for scheduling
x86/intel_rdt/cqm: Add mount,umount support
x86/intel_rdt/cqm: Add rmdir support
x86/intel_rdt: Separate the ctrl bits from rmdir
x86/intel_rdt/cqm: Add mon_data
x86/intel_rdt: Prepare for RDT monitor data support
Because the "perf cqm" and resctrl code were separately added and
indivdually configurable, there seem to be separate context switch code
and also things on global .h which are not really needed.
Move only the scheduling specific code and definitions to
<asm/intel_rdt_sched.h> and the put all the other declarations to a
local intel_rdt.h.
h/t to Reinette Chatre for pointing out that we should separate the
public interfaces used by other parts of the kernel from private
objects shared between the various files comprising RDT.
No functional change.
Signed-off-by: Vikas Shivappa <vikas.shivappa@linux.intel.com>
Cc: ravi.v.shankar@intel.com
Cc: tony.luck@intel.com
Cc: fenghua.yu@intel.com
Cc: peterz@infradead.org
Cc: eranian@google.com
Cc: vikas.shivappa@intel.com
Cc: ak@linux.intel.com
Cc: davidcc@google.com
Cc: reinette.chatre@intel.com
Link: http://lkml.kernel.org/r/1501017287-28083-5-git-send-email-vikas.shivappa@linux.intel.com
Now that pt_regs properly defines segment fields as 16-bit on 32-bit
CPUs, there's no need to mask off the high word.
The kernel has several code paths that read CR3. Most of them assume that
CR3 contains the PGD's physical address, whereas some of them awkwardly
use PHYSICAL_PAGE_MASK to mask off low bits.
Add explicit mask macros for CR3 and convert all of the CR3 readers.
This will keep them from breaking when PCID is enabled.
Cc: xen-devel <xen-devel@lists.xen.org>
Link: http://lkml.kernel.org/r/883f8fb121f4616c1c1427ad87350bb2f5ffeca1.1497288170.git.luto@kernel.org
DEBUG_PREEMPT warning
... to raw_smp_processor_id() to not trip the
BUG: using smp_processor_id() in preemptible [00000000] code: swapper/0/1
check. The reasoning behind it is that __warn() already uses the raw_
variants but the show_regs() path on 32-bit doesn't.
Link: http://lkml.kernel.org/r/20170528092212.fiod7kygpjm23m3o@pd.tnic
Hook up arch_prctl to call do_arch_prctl() on x86-32, and in 32 bit compat
mode on x86-64. This allows to have arch_prctls that are not specific to 64
bits.
On UML, simply stub out this syscall.
Signed-off-by: Kyle Huey <khuey@kylehuey.com>
Cc: Grzegorz Andrejczuk <grzegorz.andrejczuk@intel.com>
Cc: kvm@vger.kernel.org
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: linux-kselftest@vger.kernel.org
Cc: Nadav Amit <nadav.amit@gmail.com>
Cc: Robert O'Callahan <robert@ocallahan.org>
Cc: Richard Weinberger <richard@nod.at>
Cc: "Rafael J. Wysocki" <rafael.j.wysocki@intel.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Len Brown <len.brown@intel.com>
Cc: Shuah Khan <shuah@kernel.org>
Cc: user-mode-linux-devel@lists.sourceforge.net
Cc: Jeff Dike <jdike@addtoit.com>
Cc: user-mode-linux-user@lists.sourceforge.net
Cc: David Matlack <dmatlack@google.com>
Cc: Dmitry Safonov <dsafonov@virtuozzo.com>
Cc: linux-fsdevel@vger.kernel.org
Link: http://lkml.kernel.org/r/20170320081628.18952-7-khuey@kylehuey.com
<linux/sched/task_stack.h>
We are going to split <linux/sched/task_stack.h> out of <linux/sched.h>, which
will have to be picked up from other headers and a couple of .c files.
Create a trivial placeholder <linux/sched/task_stack.h> file that just
maps to <linux/sched.h> to make this patch obviously correct and
bisectable.
Include the new header in the files that are going to need it.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
<linux/sched/task.h>
We are going to split <linux/sched/task.h> out of <linux/sched.h>, which
Create a trivial placeholder <linux/sched/task.h> file that just
bisectable.
Pull x86 cache allocation interface from Thomas Gleixner:
"This provides support for Intel's Cache Allocation Technology, a cache
partitioning mechanism.
The interface is odd, but the hardware interface of that CAT stuff is
odd as well.
We tried hard to come up with an abstraction, but that only allows
rather simple partitioning, but no way of sharing and dealing with the
per package nature of this mechanism.
In the end we decided to expose the allocation bitmaps directly so all
combinations of the hardware can be utilized.
There are two ways of associating a cache partition:
- Task
A task can be added to a resource group. It uses the cache
partition associated to the group.
- CPU
All tasks which are not member of a resource group use the group to
which the CPU they are running on is associated with.
That allows for simple CPU based partitioning schemes.
The main expected user sare:
- Virtualization so a VM can only trash only the associated part of
the cash w/o disturbing others
- Real-Time systems to seperate RT and general workloads.
- Latency sensitive enterprise workloads
- In theory this also can be used to protect against cache side
channel attacks"
[ Intel RDT is "Resource Director Technology". The interface really is
rather odd and very specific, which delayed this pull request while I
was thinking about it. The pull request itself came in early during
the merge window, I just delayed it until things had calmed down and I
had more time.
But people tell me they'll use this, and the good news is that it is
_so_ specific that it's rather independent of anything else, and no
user is going to depend on the interface since it's pretty rare. So if
push comes to shove, we can just remove the interface and nothing will
break ]
* 'x86-cache-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (31 commits)
x86/intel_rdt: Implement show_options() for resctrlfs
x86/intel_rdt: Call intel_rdt_sched_in() with preemption disabled
x86/intel_rdt: Update task closid immediately on CPU in rmdir and unmount
x86/intel_rdt: Fix setting of closid when adding CPUs to a group
x86/intel_rdt: Update percpu closid immeditately on CPUs affected by changee
x86/intel_rdt: Reset per cpu closids on unmount
x86/intel_rdt: Select KERNFS when enabling INTEL_RDT_A
x86/intel_rdt: Prevent deadlock against hotplug lock
x86/intel_rdt: Protect info directory from removal
x86/intel_rdt: Add info files to Documentation
x86/intel_rdt: Export the minimum number of set mask bits in sysfs
x86/intel_rdt: Propagate error in rdt_mount() properly
x86/intel_rdt: Add a missing #include
MAINTAINERS: Add maintainer for Intel RDT resource allocation
x86/intel_rdt: Add scheduler hook
x86/intel_rdt: Add schemata file
x86/intel_rdt: Add tasks files
x86/intel_rdt: Add cpus file
x86/intel_rdt: Add mkdir to resctrl file system
x86/intel_rdt: Add "info" files to resctrl file system
Pull x86 idle updates from Ingo Molnar:
"There were two bigger changes in this development cycle:
- remove idle notifiers:
32 files changed, 74 insertions(+), 803 deletions(-)
These notifiers were of questionable value and the main usecase,
the i7300 driver, was essentially unmaintained and can be removed,
plus modern power management concepts don't need the callback - so
use this golden opportunity and get rid of this opaque and fragile
callback from a latency sensitive code path.
(Len Brown, Thomas Gleixner)
- improve the AMD Erratum 400 workaround that used high overhead MSR
polling in the idle loop (Borisla Petkov, Thomas Gleixner)"
* 'x86-idle-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86: Remove empty idle.h header
x86/amd: Simplify AMD E400 aware idle routine
x86/amd: Check for the C1E bug post ACPI subsystem init
x86/bugs: Separate AMD E400 erratum and C1E bug
x86/cpufeature: Provide helper to set bugs bits
x86/idle: Remove enter_idle(), exit_idle()
x86: Remove x86_test_and_clear_bit_percpu()
x86/idle: Remove is_idle flag
x86/idle: Remove idle_notifier
i7300_idle: Remove this driver
Pull x86 FPU updates from Ingo Molnar:
"The main changes in this cycle were:
- do a large round of simplifications after all CPUs do 'eager' FPU
context switching in v4.9: remove CR0 twiddling, remove leftover
eager/lazy bts, etc (Andy Lutomirski)
- more FPU code simplifications: remove struct fpu::counter, clarify
nomenclature, remove unnecessary arguments/functions and better
structure the code (Rik van Riel)"
* 'x86-fpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/fpu: Remove clts()
x86/fpu: Remove stts()
x86/fpu: Handle #NM without FPU emulation as an error
x86/fpu, lguest: Remove CR0.TS support
x86/fpu, kvm: Remove host CR0.TS manipulation
x86/fpu: Remove irq_ts_save() and irq_ts_restore()
x86/fpu: Stop saving and restoring CR0.TS in fpu__init_check_bugs()
x86/fpu: Get rid of two redundant clts() calls
x86/fpu: Finish excising 'eagerfpu'
x86/fpu: Split old_fpu & new_fpu handling into separate functions
x86/fpu: Remove 'cpu' argument from __cpu_invalidate_fpregs_state()
x86/fpu: Split old & new FPU code paths
x86/fpu: Remove __fpregs_(de)activate()
x86/fpu: Rename lazy restore functions to "register state valid"
x86/fpu, kvm: Remove KVM vcpu->fpu_counter
x86/fpu: Remove struct fpu::counter
x86/fpu: Remove use_eager_fpu()
x86/fpu: Remove the XFEATURE_MASK_EAGER/LAZY distinction
x86/fpu: Hard-disable lazy FPU mode
x86/crypto, x86/fpu: Remove X86_FEATURE_EAGER_FPU #ifdef from the crc32c code
One include less is always a good thing(tm). Good riddance.
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/20161209182912.2726-6-bp@alien8.de
Hook the x86 scheduler code to update closid based on whether the current
task is assigned to a specific closid or running on a CPU assigned to a
specific closid.
Signed-off-by: Fenghua Yu <fenghua.yu@intel.com>
Cc: "Ravi V Shankar" <ravi.v.shankar@intel.com>
Cc: "Tony Luck" <tony.luck@intel.com>
Cc: "Shaohua Li" <shli@fb.com>
Cc: "Sai Prakhya" <sai.praneeth.prakhya@intel.com>
Cc: "Peter Zijlstra" <peterz@infradead.org>
Cc: "Stephane Eranian" <eranian@google.com>
Cc: "Dave Hansen" <dave.hansen@intel.com>
Cc: "David Carrillo-Cisneros" <davidcc@google.com>
Cc: "Nilay Vaish" <nilayvaish@gmail.com>
Cc: "Vikas Shivappa" <vikas.shivappa@linux.intel.com>
Cc: "Ingo Molnar" <mingo@elte.hu>
Cc: "Borislav Petkov" <bp@suse.de>
Cc: "H. Peter Anvin" <h.peter.anvin@intel.com>
Link: http://lkml.kernel.org/r/1477692289-37412-10-git-send-email-fenghua.yu@intel.com
Printing kernel text addresses in stack dumps is of questionable value,
especially now that address randomization is becoming common.
It can be a security issue because it leaks kernel addresses. It also
affects the usefulness of the stack dump. Linus says:
"I actually spend time cleaning up commit messages in logs, because
useless data that isn't actually information (random hex numbers) is
actively detrimental.
It makes commit logs less legible.
It also makes it harder to parse dumps.
It's not useful. That makes it actively bad.
I probably look at more oops reports than most people. I have not
found the hex numbers useful for the last five years, because they are
just randomized crap.
The stack content thing just makes code scroll off the screen etc, for
example."
The only real downside to removing these addresses is that they can be
used to disambiguate duplicate symbol names. However such cases are
rare, and the context of the stack dump should be enough to be able to
figure it out.
There's now a 'faddr2line' script which can be used to convert a
function address to a file name and line:
$ ./scripts/faddr2line ~/k/vmlinux write_sysrq_trigger+0x51/0x60
write_sysrq_trigger+0x51/0x60:
write_sysrq_trigger at drivers/tty/sysrq.c:1098
Or gdb can be used:
$ echo "list *write_sysrq_trigger+0x51" |gdb ~/k/vmlinux |grep "is in"
(gdb) 0xffffffff815b5d83 is in driver_probe_device (/home/jpoimboe/git/linux/drivers/base/dd.c:378).
(But note that when there are duplicate symbol names, gdb will only show
the first symbol it finds. faddr2line is recommended over gdb because
it handles duplicates and it also does function size checking.)
Here's an example of what a stack dump looks like after this change:
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: sysrq_handle_crash+0x45/0x80
PGD 36bfa067 [ 29.650644] PUD 7aca3067
Oops: 0002 [#1] PREEMPT SMP
Modules linked in: ...
CPU: 1 PID: 786 Comm: bash Tainted: G E 4.9.0-rc1+ #1
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.9.1-1.fc24 04/01/2014
task: ffff880078582a40 task.stack: ffffc90000ba8000
RIP: 0010:sysrq_handle_crash+0x45/0x80
RSP: 0018:ffffc90000babdc8 EFLAGS: 00010296
RAX: ffff880078582a40 RBX: 0000000000000063 RCX: 0000000000000001
RDX: 0000000000000001 RSI: 0000000000000000 RDI: 0000000000000292
RBP: ffffc90000babdc8 R08: 0000000b31866061 R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000000 R12: 0000000000000000
R13: 0000000000000007 R14: ffffffff81ee8680 R15: 0000000000000000
FS: 00007ffb43869700(0000) GS:ffff88007d400000(0000) knlGS:0000000000000000
CR2: 0000000000000000 CR3: 000000007a3e9000 CR4: 00000000001406e0
Stack:
ffffc90000babe00 ffffffff81572d08 ffffffff81572bd5 0000000000000002
0000000000000000 ffff880079606600 00007ffb4386e000 ffffc90000babe20
ffffffff81573201 ffff880036a3fd00 fffffffffffffffb ffffc90000babe40
Call Trace:
__handle_sysrq+0x138/0x220
? __handle_sysrq+0x5/0x220
proc_reg_write+0x42/0x70
__vfs_write+0x37/0x140
? preempt_count_sub+0xa1/0x100
? __sb_start_write+0xf5/0x210
? vfs_write+0x183/0x1a0
vfs_write+0xb8/0x1a0
SyS_write+0x58/0xc0
entry_SYSCALL_64_fastpath+0x1f/0xc2
RIP: 0033:0x7ffb42f55940
RSP: 002b:00007ffd33bb6b18 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: 0000000000000046 RCX: 00007ffb42f55940
RDX: 0000000000000002 RSI: 00007ffb4386e000 RDI: 0000000000000001
RBP: 0000000000000011 R08: 00007ffb4321ea40 R09: 00007ffb43869700
R10: 00007ffb43869700 R11: 0000000000000246 R12: 0000000000778a10
R13: 00007ffd33bb5c00 R14: 0000000000000007 R15: 0000000000000010
Code: 34 e8 d0 34 bc ff 48 c7 c2 3b 2b 57 81 be 01 00 00 00 48 c7 c7 e0 dd e5 81 e8 a8 55 ba ff c7 05 0e 3f de 00 01 00 00 00 0f ae f8 <c6> 04 25 00 00 00 00 01 5d c3 e8 4c 49 bc ff 84 c0 75 c3 48 c7
RIP: sysrq_handle_crash+0x45/0x80 RSP: ffffc90000babdc8
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Link: http://lkml.kernel.org/r/69329cb29b8f324bb5fcea14d61d224807fb6488.1477405374.git.jpoimboe@redhat.com
By moving all of the new_fpu state handling into switch_fpu_finish(),
the code can be simplified some more.
This gets rid of the prefetch, but given the size of the FPU register
state on modern CPUs, and the amount of work done by __switch_to()
inbetween both functions, the value of a single cache line prefetch
seems somewhat dubious anyway.
Signed-off-by: Rik van Riel <riel@redhat.com>
Acked-by: Dave Hansen <dave.hansen@intel.com>
Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Link: http://lkml.kernel.org/r/1476447331-21566-3-git-send-email-riel@redhat.com
We use __read_cr4() vs __read_cr4_safe() inconsistently. On
CR4-less CPUs, all CR4 bits are effectively clear, so we can make
the code simpler and more robust by making __read_cr4() always fix
up faults on 32-bit kernels.
This may fix some bugs on old 486-like CPUs, but I don't have any
easy way to test that.
Cc: david@saggiorato.net
Link: http://lkml.kernel.org/r/ea647033d357d9ce2ad2bbde5a631045f5052fb6.1475178370.git.luto@kernel.org
thread_saved_pc() was using a completely bogus method to get the return
address. Since switch_to() was previously inlined, there was no sane way
to know where on the stack the return address was stored. Now with the
frame of a sleeping thread well defined, this can be implemented correctly.
Signed-off-by: Brian Gerst <brgerst@gmail.com>
Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com>
Link: http://lkml.kernel.org/r/1471106302-10159-7-git-send-email-brgerst@gmail.com
Instead of setting up a fake pt_regs context, put the kernel thread
function pointer and arg into the unused callee-restored registers
of 'struct fork_frame'.
Link: http://lkml.kernel.org/r/1471106302-10159-6-git-send-email-brgerst@gmail.com
Move the low-level context switch code to an out-of-line asm stub instead of
using complex inline asm. This allows constructing a new stack frame for the
child process to make it seamlessly flow to ret_from_fork without an extra
test and branch in __switch_to(). It also improves code generation for
__schedule() by using the C calling convention instead of clobbering all
registers.
Link: http://lkml.kernel.org/r/1471106302-10159-5-git-send-email-brgerst@gmail.com
Historically a lot of these existed because we did not have
a distinction between what was modular code and what was providing
support to modules via EXPORT_SYMBOL and friends. That changed
when we forked out support for the latter into the export.h file.
This means we should be able to reduce the usage of module.h
in code that is obj-y Makefile or bool Kconfig. The advantage
in doing so is that module.h itself sources about 15 other headers;
adding significantly to what we feed cpp, and it can obscure what
headers we are effectively using.
Since module.h was the source for init.h (for __init) and for
export.h (for EXPORT_SYMBOL) we consider each obj-y/bool instance
for the presence of either and replace as needed. Build testing
revealed some implicit header usage that was fixed up accordingly.
Note that some bool/obj-y instances remain since module.h is
the header for some exception table entry stuff, and for things
like __init_or_module (code that is tossed when MODULES=n).
Link: http://lkml.kernel.org/r/20160714001901.31603-4-paul.gortmaker@windriver.com
With the introduction of the context switch preempt_count invariant,
and the demise of PREEMPT_ACTIVE, its pointless to save/restore the
per-cpu preemption count, it must always be 2.
Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com>
The stack layout and the functionality is identical. Use the 64bit
version for all of x86.
Reviewed-by: Borislav Petkov <bp@alien8.de>
Reviewed-by: Dmitry Vyukov <dvyukov@google.com>
Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com>
Cc: Andrey Konovalov <andreyknvl@google.com>
Cc: Kostya Serebryany <kcc@google.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: kasan-dev <kasan-dev@googlegroups.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: Wolfram Gloger <wmglo@dent.med.uni-muenchen.de>
Link: http://lkml.kernel.org/r/20150930083302.779694618@linutronix.de
vm86.h was being implicitly included in alot of places via
processor.h, which in turn got it from math_emu.h. Break that
chain and explicitly include vm86.h in all files that need it.
Also remove unused vm86 field from math_emu_info.
Link: http://lkml.kernel.org/r/1438148483-11932-7-git-send-email-brgerst@gmail.com
[ Fixed build failure. ]
For 32-bit userspace on a 64-bit kernel, this requires modifying
stub32_clone to actually swap the appropriate arguments to match
CONFIG_CLONE_BACKWARDS, rather than just leaving the C argument for tls
broken.
Patch co-authored by Josh Triplett and Thiago Macieira.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
Acked-by: Andy Lutomirski <luto@kernel.org>
Cc: Thiago Macieira <thiago.macieira@intel.com>
Pull x86 core updates from Ingo Molnar:
"There were so many changes in the x86/asm, x86/apic and x86/mm topics
in this cycle that the topical separation of -tip broke down somewhat -
so the result is a more traditional architecture pull request,
collected into the 'x86/core' topic.
The topics were still maintained separately as far as possible, so
bisectability and conceptual separation should still be pretty good -
but there were a handful of merge points to avoid excessive
dependencies (and conflicts) that would have been poorly tested in the
end.
The next cycle will hopefully be much more quiet (or at least will
have fewer dependencies).
* x86/apic changes, with related IRQ core changes: (Jiang Liu, Thomas
Gleixner)
- This is the second and most intrusive part of changes to the x86
interrupt handling - full conversion to hierarchical interrupt
domains:
[IOAPIC domain] -----
[MSI domain] --------[Remapping domain] ----- [ Vector domain ]
| (optional) |
[HPET MSI domain] ----- |
[DMAR domain] -----------------------------
[Legacy domain] -----------------------------
This now reflects the actual hardware and allowed us to distangle
the domain specific code from the underlying parent domain, which
can be optional in the case of interrupt remapping. It's a clear
separation of functionality and removes quite some duct tape
constructs which plugged the remap code between ioapic/msi/hpet
and the vector management.
- Intel IOMMU IRQ remapping enhancements, to allow direct interrupt
injection into guests (Feng Wu)
* x86/asm changes:
- Tons of cleanups and small speedups, micro-optimizations. This
is in preparation to move a good chunk of the low level entry
code from assembly to C code (Denys Vlasenko, Andy Lutomirski,
Brian Gerst)
- Moved all system entry related code to a new home under
arch/x86/entry/ (Ingo Molnar)
- Removal of the fragile and ugly CFI dwarf debuginfo annotations.
Conversion to C will reintroduce many of them - but meanwhile
they are only getting in the way, and the upstream kernel does
not rely on them (Ingo Molnar)
- NOP handling refinements. (Borislav Petkov)
* x86/mm changes:
- Big PAT and MTRR rework: making the code more robust and
preparing to phase out exposing direct MTRR interfaces to drivers -
in favor of using PAT driven interfaces (Toshi Kani, Luis R
Rodriguez, Borislav Petkov)
- New ioremap_wt()/set_memory_wt() interfaces to support
Write-Through cached memory mappings. This is especially
important for good performance on NVDIMM hardware (Toshi Kani)
* x86/ras changes:
- Add support for deferred errors on AMD (Aravind Gopalakrishnan)
This is an important RAS feature which adds hardware support for
poisoned data. That means roughly that the hardware marks data
which it has detected as corrupted but wasn't able to correct, as
poisoned data and raises an APIC interrupt to signal that in the
form of a deferred error. It is the OS's responsibility then to
take proper recovery action and thus prolonge system lifetime as
far as possible.
- Add support for Intel "Local MCE"s: upcoming CPUs will support
CPU-local MCE interrupts, as opposed to the traditional system-
wide broadcasted MCE interrupts (Ashok Raj)
- Misc cleanups (Borislav Petkov)
* x86/platform changes:
- Intel Atom SoC updates
... and lots of other cleanups, fixlets and other changes - see the
shortlog and the Git log for details"
* 'x86-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (222 commits)
x86/hpet: Use proper hpet device number for MSI allocation
x86/hpet: Check for irq==0 when allocating hpet MSI interrupts
x86/mm/pat, drivers/infiniband/ipath: Use arch_phys_wc_add() and require PAT disabled
x86/mm/pat, drivers/media/ivtv: Use arch_phys_wc_add() and require PAT disabled
x86/platform/intel/baytrail: Add comments about why we disabled HPET on Baytrail
genirq: Prevent crash in irq_move_irq()
genirq: Enhance irq_data_to_desc() to support hierarchy irqdomain
iommu, x86: Properly handle posted interrupts for IOMMU hotplug
iommu, x86: Provide irq_remapping_cap() interface
iommu, x86: Setup Posted-Interrupts capability for Intel iommu
iommu, x86: Add cap_pi_support() to detect VT-d PI capability
iommu, x86: Avoid migrating VT-d posted interrupts
iommu, x86: Save the mode (posted or remapped) of an IRTE
iommu, x86: Implement irq_set_vcpu_affinity for intel_ir_chip
iommu: dmar: Provide helper to copy shared irte fields
iommu: dmar: Extend struct irte for VT-d Posted-Interrupts
iommu: Add new member capability to struct irq_remap_ops
x86/asm/entry/64: Disentangle error_entry/exit gsbase/ebx/usermode code
x86/asm/entry/32: Shorten __audit_syscall_entry() args preparation
x86/asm/entry/32: Explain reloading of registers after __audit_syscall_entry()
This unifies all the FPU related header files under a unified, hiearchical
naming scheme:
- asm/fpu/types.h: FPU related data types, needed for 'struct task_struct',
widely included in almost all kernel code, and hence kept
as small as possible.
- asm/fpu/api.h: FPU related 'public' methods exported to other subsystems.
- asm/fpu/internal.h: FPU subsystem internal methods
- asm/fpu/xsave.h: XSAVE support internal methods
(Also standardize the header guard in asm/fpu/internal.h.)
Migrate this function to pure 'struct fpu' usage.
Move to the new fpu__*() namespace.
Fix a minor header file dependency bug in asm/fpu-internal.h: it
relies on i387.h but does not include it. All users of fpu-internal.h
included it explicitly.
Also remove unnecessary includes, to reduce compilation time.
This also makes it easier to use it as a standalone header file
for FPU internals, such as an upcoming C module in arch/x86/kernel/fpu/.
Signed-off-by: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Alexei Starovoitov <ast@plumgrid.com>
Cc: Will Drewry <wad@chromium.org>
Link: http://lkml.kernel.org/r/1429889495-27850-2-git-send-email-dvlasenk@redhat.com
PER_CPU_VAR(kernel_stack) was set up in a way where it points
five stack slots below the top of stack.
Presumably, it was done to avoid one "sub $5*8,%rsp"
in syscall/sysenter code paths, where iret frame needs to be
created by hand.
Ironically, none of them benefits from this optimization,
since all of them need to allocate additional data on stack
(struct pt_regs), so they still have to perform subtraction.
This patch eliminates KERNEL_STACK_OFFSET.
PER_CPU_VAR(kernel_stack) now points directly to top of stack.
pt_regs allocations are adjusted to allocate iret frame as well.
Hopefully we can merge it later with 32-bit specific
PER_CPU_VAR(cpu_current_top_of_stack) variable...
Net result in generated code is that constants in several insns
are changed.
This change is necessary for changing struct pt_regs creation
in SYSCALL64 code path from MOV to PUSH instructions.
Acked-by: Borislav Petkov <bp@suse.de>
Link: http://lkml.kernel.org/r/1426785469-15125-2-git-send-email-dvlasenk@redhat.com
user_mode_vm() and user_mode() are now the same. Change all callers
of user_mode_vm() to user_mode().
The next patch will remove the definition of user_mode_vm.
Cc: Brad Spengler <spender@grsecurity.net>
Link: http://lkml.kernel.org/r/43b1f57f3df70df5a08b0925897c660725015554.1426728647.git.luto@kernel.org
[ Merged to a more recent kernel. ]
Both the execve() and sigreturn() family of syscalls have the
ability to change registers in ways that may not be compatabile
with the syscall path they were called from.
In particular, SYSRET and SYSEXIT can't handle non-default %cs and %ss,
and some bits in eflags.
These syscalls have stubs that are hardcoded to jump to the IRET path,
and not return to the original syscall path.
The following commit:
76f5df43cab5e76 ("Always allocate a complete "struct pt_regs" on the kernel stack")
recently changed this for some 32-bit compat syscalls, but introduced a bug where
execve from a 32-bit program to a 64-bit program would fail because it still returned
via SYSRETL. This caused Wine to fail when built for both 32-bit and 64-bit.
This patch sets TIF_NOTIFY_RESUME for execve() and sigreturn() so
that the IRET path is always taken on exit to userspace.
Link: http://lkml.kernel.org/r/1426978461-32089-1-git-send-email-brgerst@gmail.com
[ Improved the changelog and comments. ]
on x86_32
I broke 32-bit kernels. The implementation of sp0 was correct
as far as I can tell, but sp0 was much weirder on x86_32 than I
realized. It has the following issues:
- Init's sp0 is inconsistent with everything else's: non-init tasks
are offset by 8 bytes. (I have no idea why, and the comment is unhelpful.)
- vm86 does crazy things to sp0.
Fix it up by replacing this_cpu_sp0() with
current_top_of_stack() and using a new percpu variable to track
the top of the stack on x86_32.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Fixes: 75182b1632a8 ("x86/asm/entry: Switch all C consumers of kernel_stack to this_cpu_sp0()")
Link: http://lkml.kernel.org/r/d09dbe270883433776e0cbee3c7079433349e96d.1425692936.git.luto@amacapital.net
The change:
had the unintended side effect of changing the return value of
current_thread_info() during part of the context switch process.
Change it back.
This has no effect as far as I can tell -- it's just for
consistency.
Link: http://lkml.kernel.org/r/9fcaa47dd8487db59eed7a3911b6ae409476763e.1425692936.git.luto@amacapital.net
It has nothing to do with init -- there's only one TSS per cpu.
Other names considered include:
- current_tss: Confusing because we never switch the tss.
- singleton_tss: Too long.
This patch was generated with 's/init_tss/cpu_tss/g'. Followup
patches will fix INIT_TSS and INIT_TSS_IST by hand.
Link: http://lkml.kernel.org/r/da29fb2a793e4f649d93ce2d1ed320ebe8516262.1425611534.git.luto@amacapital.net
Context switches and TLB flushes can change individual bits of CR4.
CR4 reads take several cycles, so store a shadow copy of CR4 in a
per-cpu variable.
To avoid wasting a cache line, I added the CR4 shadow to
cpu_tlbstate, which is already touched in switch_mm. The heaviest
users of the cr4 shadow will be switch_mm and __switch_to_xtra, and
__switch_to_xtra is called shortly after switch_mm during context
switch, so the cacheline is likely to be hot.
Cc: Vince Weaver <vince@deater.net>
Cc: "hillf.zj" <hillf.zj@alibaba-inc.com>
Cc: Valdis Kletnieks <Valdis.Kletnieks@vt.edu>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Link: http://lkml.kernel.org/r/3a54dd3353fffbf84804398e00dfdc5b7c1afd7d.1414190806.git.luto@amacapital.net
Both 32bit and 64bit versions of copy_thread() do memset(ptrace_bps)
twice for no reason, kill the 2nd memset().
Link: http://lkml.kernel.org/r/20140902175733.GA21676@redhat.com
Cosmetic, but I think thread.fpu_counter should be initialized in
arch_dup_task_struct() too, along with other "fpu" variables. And
probably it make sense to turn it into thread.fpu->counter.
Link: http://lkml.kernel.org/r/20140902175730.GA21669@redhat.com
Reviewed-by: Suresh Siddha <sbsiddha@gmail.com>
x86_64 uses a per_cpu variable kernel_stack to always point to
the thread stack of current. This is where the thread_info is stored
and is accessed from this location even when the irq or exception stack
is in use. This removes the complexity of having to maintain the
thread info on the stack when interrupts are running and having to
copy the preempt_count and other fields to the interrupt stack.
x86_32 uses the old method of copying the thread_info from the thread
stack to the exception stack just before executing the exception.
Having the two different requires #ifdefs and also the x86_32 way
is a bit of a pain to maintain. By converting x86_32 to the same
method of x86_64, we can remove #ifdefs, clean up the x86_32 code
a little, and remove the overhead of the copy.
Link: http://lkml.kernel.org/r/20110806012354.263834829@goodmis.org
Link: http://lkml.kernel.org/r/20140206144321.852942014@goodmis.org
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
[ hpa: undid incorrect removal from arch/x86/kernel/head_32.S ]
Link: http://lkml.kernel.org/r/1389054026-12947-1-git-send-email-paul.gortmaker@windriver.com
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Only a couple of arches (sh/x86) use fpu_counter in task_struct so it can
be moved out into ARCH specific thread_struct, reducing the size of
task_struct for other arches.
Compile tested i386_defconfig + gcc 4.7.3
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Paul Mundt <paul.mundt@gmail.com>
Convert x86 to use a per-cpu preemption count. The reason for doing so
is that accessing per-cpu variables is a lot cheaper than accessing
thread_info variables.
We still need to save/restore the actual preemption count due to
PREEMPT_ACTIVE so we place the per-cpu __preempt_count variable in the
same cache-line as the other hot __switch_to() variables such as
current_task.
NOTE: this save/restore is required even for !PREEMPT kernels as
cond_resched() also relies on preempt_count's PREEMPT_ACTIVE to ignore
task_struct::state.
Also rename thread_info::preempt_count to ensure nobody is
'accidentally' still poking at it.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/n/tip-gzn5rfsf8trgjoqx8hyayy3q@git.kernel.org
