commit dc76803e57cc86589c4efcb5362918f9b0c0436f upstream.
The consolidation of the start_thread() functions removed the export
unintentionally. This breaks binfmt handlers built as a module.
Add it back.
Fixes: e634d8fc792c ("x86-64: merge the standard and compat start_thread() functions")
Signed-off-by: Rian Hunter <rian@alum.mit.edu>
Cc: Borislav Petkov <bpetkov@suse.de>
Cc: Vitaly Kuznetsov <vkuznets@redhat.com>
Cc: Joerg Roedel <jroedel@suse.de>
Cc: Dmitry Safonov <dima@arista.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: stable@vger.kernel.org
Link: https://lkml.kernel.org/r/20180819230854.7275-1-rian@alum.mit.edu
(cherry picked from commit 37a8f7c38339b22b69876d6f5a0ab851565284e3)
The TS_COMPAT bit is very hot and is accessed from code paths that mostly
also touch thread_info::flags. Move it into struct thread_info to improve
cache locality.
The only reason it was in thread_struct is that there was a brief period
during which arch-specific fields were not allowed in struct thread_info.
Linus suggested further changing:
ti->status &= ~(TS_COMPAT|TS_I386_REGS_POKED);
to:
if (unlikely(ti->status & (TS_COMPAT|TS_I386_REGS_POKED)))
on the theory that frequently dirtying the cacheline even in pure 64-bit
code that never needs to modify status hurts performance. That could be a
reasonable followup patch, but I suspect it matters less on top of this
patch.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Reviewed-by: Ingo Molnar <mingo@kernel.org>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Kernel Hardening <kernel-hardening@lists.openwall.com>
Link: https://lkml.kernel.org/r/03148bcc1b217100e6e8ecf6a5468c45cf4304b6.1517164461.git.luto@kernel.org
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
commit e137a4d8f4dd2e277e355495b6b2cb241a8693c3 upstream.
Switching FS and GS is a mess, and the current code is still subtly
wrong: it assumes that "Loading a nonzero value into FS sets the
index and base", which is false on AMD CPUs if the value being
loaded is 1, 2, or 3.
(The current code came from commit 3e2b68d752c9 ("x86/asm,
sched/x86: Rewrite the FS and GS context switch code"), which made
it better but didn't fully fix it.)
Rewrite it to be much simpler and more obviously correct. This
should fix it fully on AMD CPUs and shouldn't adversely affect
performance.
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Chang Seok <chang.seok.bae@intel.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
commit 767d035d838f4fd6b5a5bbd7a3f6d293b7f65a49 upstream.
execve used to leak FSBASE and GSBASE on AMD CPUs. Fix it.
The security impact of this bug is small but not quite zero -- it
could weaken ASLR when a privileged task execs a less privileged
program, but only if program changed bitness across the exec, or the
child binary was highly unusual or actively malicious. A child
program that was compromised after the exec would not have access to
the leaked base.
Pull protection keys syscall interface from Thomas Gleixner:
"This is the final step of Protection Keys support which adds the
syscalls so user space can actually allocate keys and protect memory
areas with them. Details and usage examples can be found in the
documentation.
The mm side of this has been acked by Mel"
* 'mm-pkeys-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/pkeys: Update documentation
x86/mm/pkeys: Do not skip PKRU register if debug registers are not used
x86/pkeys: Fix pkeys build breakage for some non-x86 arches
x86/pkeys: Add self-tests
x86/pkeys: Allow configuration of init_pkru
x86/pkeys: Default to a restrictive init PKRU
pkeys: Add details of system call use to Documentation/
generic syscalls: Wire up memory protection keys syscalls
x86: Wire up protection keys system calls
x86/pkeys: Allocation/free syscalls
x86/pkeys: Make mprotect_key() mask off additional vm_flags
mm: Implement new pkey_mprotect() system call
x86/pkeys: Add fault handling for PF_PK page fault bit
Pull x86 vdso updates from Ingo Molnar:
"The main changes in this cycle centered around adding support for
32-bit compatible C/R of the vDSO on 64-bit kernels, by Dmitry
Safonov"
* 'x86-vdso-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/vdso: Use CONFIG_X86_X32_ABI to enable vdso prctl
x86/vdso: Only define map_vdso_randomized() if CONFIG_X86_64
x86/vdso: Only define prctl_map_vdso() if CONFIG_CHECKPOINT_RESTORE
x86/signal: Add SA_{X32,IA32}_ABI sa_flags
x86/ptrace: Down with test_thread_flag(TIF_IA32)
x86/coredump: Use pr_reg size, rather that TIF_IA32 flag
x86/arch_prctl/vdso: Add ARCH_MAP_VDSO_*
x86/vdso: Replace calculate_addr in map_vdso() with addr
x86/vdso: Unmap vdso blob on vvar mapping failure
The prctl code which references vdso_image_x32 is built when CONFIG_X86_X32
is set. This results in the following build failure:
LD init/built-in.o
arch/x86/built-in.o: In function `do_arch_prctl':
(.text+0x27466): undefined reference to `vdso_image_x32'
vdso_image_x32 depends on CONFIG_X86_X32_ABI. So we need to make the prctl
depend on that as well.
[ tglx: Massaged changelog ]
Fixes: 2eefd8789698 ("x86/arch_prctl/vdso: Add ARCH_MAP_VDSO_*")
Signed-off-by: Vinson Lee <vlee@freedesktop.org>
Reviewed-by: Dmitry Safonov <dsafonov@virtuozzo.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Dmitry Vyukov <dvyukov@google.com>
Link: http://lkml.kernel.org/r/1474073513-6656-1-git-send-email-vlee@freedesktop.org
... otherwise the compiler complains:
arch/x86/kernel/process_64.c:528:13: warning: ‘prctl_map_vdso’ defined but not used [-Wunused-function]
Cc: Dmitry Safonov <dsafonov@virtuozzo.com>
Cc: gorcunov@openvz.org
Cc: linux-mm@kvack.org
Cc: oleg@redhat.com
Cc: xemul@virtuozzo.com
Because sched.h and thread_info.h are a tangled mess, I turned
in_compat_syscall() into a macro. If we had current_thread_struct()
or similar and we could use it from thread_info.h, then this would
be a bit cleaner.
Cc: Jann Horn <jann@thejh.net>
Link: http://lkml.kernel.org/r/ccc8a1b2f41f9c264a41f771bb4a6539a642ad72.1473801993.git.luto@kernel.org
Add API to change vdso blob type with arch_prctl.
As this is usefull only by needs of CRIU, expose
this interface under CONFIG_CHECKPOINT_RESTORE.
Signed-off-by: Dmitry Safonov <dsafonov@virtuozzo.com>
Acked-by: Andy Lutomirski <luto@kernel.org>
Cc: 0x7f454c46@gmail.com
Cc: oleg@redhat.com
Link: http://lkml.kernel.org/r/20160905133308.28234-4-dsafonov@virtuozzo.com
__show_regs() fails to dump the PKRU state when the debug registers are in
their default state because there is a return statement on the debug
register state.
Change the logic to report PKRU value even when debug registers are in
their default state.
Fixes:c0b17b5bd4b7 ("x86/mm/pkeys: Dump PKRU with other kernel registers")
Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org>
Acked-by: Dave Hansen <dave.hansen@linux.intel.com>
Link: http://lkml.kernel.org/r/20160910183045.4618-1-nicolas.iooss_linux@m4x.org
Instead of setting up a fake pt_regs context, put the kernel thread
function pointer and arg into the unused callee-restored registers
of 'struct fork_frame'.
Signed-off-by: Brian Gerst <brgerst@gmail.com>
Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com>
Link: http://lkml.kernel.org/r/1471106302-10159-6-git-send-email-brgerst@gmail.com
Move the low-level context switch code to an out-of-line asm stub instead of
using complex inline asm. This allows constructing a new stack frame for the
child process to make it seamlessly flow to ret_from_fork without an extra
test and branch in __switch_to(). It also improves code generation for
__schedule() by using the C calling convention instead of clobbering all
registers.
Link: http://lkml.kernel.org/r/1471106302-10159-5-git-send-email-brgerst@gmail.com
Historically a lot of these existed because we did not have
a distinction between what was modular code and what was providing
support to modules via EXPORT_SYMBOL and friends. That changed
when we forked out support for the latter into the export.h file.
This means we should be able to reduce the usage of module.h
in code that is obj-y Makefile or bool Kconfig. The advantage
in doing so is that module.h itself sources about 15 other headers;
adding significantly to what we feed cpp, and it can obscure what
headers we are effectively using.
Since module.h was the source for init.h (for __init) and for
export.h (for EXPORT_SYMBOL) we consider each obj-y/bool instance
for the presence of either and replace as needed. Build testing
revealed some implicit header usage that was fixed up accordingly.
Note that some bool/obj-y instances remain since module.h is
the header for some exception table entry stuff, and for things
like __init_or_module (code that is tossed when MODULES=n).
Link: http://lkml.kernel.org/r/20160714001901.31603-4-paul.gortmaker@windriver.com
The GSBASE upper limit exists to prevent user code from confusing
the paranoid idtentry path. The FSBASE upper limit is just for
consistency. There's no need to enforce a smaller limit for 32-bit
tasks.
Just use TASK_SIZE_MAX. This simplifies the logic and will save a
few bytes of code.
Link: http://lkml.kernel.org/r/5357f2fe0f103eabf005773b70722451eab09a89.1462897104.git.luto@kernel.org
This fixes an oversight in:
731e33e39a5b95 ("Remove FSBASE/GSBASE < 4G optimization")
Signed-off-by: Mateusz Guzik <mguzik@redhat.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Link: http://lkml.kernel.org/r/1462913803-29634-1-git-send-email-mguzik@redhat.com
Unlike ds and es, these are base addresses, not selectors. Rename
them so their meaning is more obvious.
On x86_32, the field is still called fs. Fixing that could make sense
as a future cleanup.
Link: http://lkml.kernel.org/r/69a18a51c4cba0ce29a241e570fc618ad721d908.1461698311.git.luto@kernel.org
As far as I know, the optimization doesn't work on any modern distro
because modern distros use high addresses for ASLR. Remove it.
The ptrace code was either wrong or very strange, but the behavior
with this patch should be essentially identical to the behavior
without this patch unless user code goes out of its way to mislead
ptrace.
On newer CPUs, once the FSGSBASE instructions are enabled, we won't
want to use the optimized variant anyway.
This isn't actually much of a performance regression, it has no effect
on normal dynamically linked programs, and it's a considerably
simplification. It also removes some nasty special cases from code
that is already way too full of special cases for comfort.
Link: http://lkml.kernel.org/r/dd1599b08866961dba9d2458faa6bbd7fba471d7.1461698311.git.luto@kernel.org
The is_ia32_task()/is_x32_task() function names are a big misnomer: they
suggests that the compat-ness of a system call is a task property, which
is not true, the compatness of a system call purely depends on how it
was invoked through the system call layer.
A task may call 32-bit and 64-bit and x32 system calls without changing
any of its kernel visible state.
This specific minomer is also actively dangerous, as it might cause kernel
developers to use the wrong kind of security checks within system calls.
So rename it to in_{ia32,x32}_syscall().
Suggested-by: Andy Lutomirski <luto@amacapital.net>
Suggested-by: Ingo Molnar <mingo@kernel.org>
[ Expanded the changelog. ]
Cc: akpm@linux-foundation.org
Link: http://lkml.kernel.org/r/1460987025-30360-1-git-send-email-dsafonov@virtuozzo.com
The old code was incomprehensible and was buggy on AMD CPUs.
Reviewed-by: Borislav Petkov <bp@suse.de>
Cc: Rudolf Marek <r.marek@assembler.cz>
Link: http://lkml.kernel.org/r/5f6bde874c6fe6831c6711b5b1522a238ba035b4.1460075211.git.luto@kernel.org
ARCH_GET_FS and ARCH_GET_GS attempted to figure out the fsbase and
gsbase respectively from saved thread state. This was wrong: fsbase
and gsbase live in registers while a thread is running, not in
memory.
For reasons I can't fathom, the fsbase and gsbase code were
different. Since neither was correct, I didn't try to figure out
what the point of the difference was.
Change it to simply read the MSRs.
The code for reading the base for a remote thread is also completely
wrong if the target thread uses its own descriptors (which is the case
for all 32-bit threaded programs), but fixing that is a different
story.
Link: http://lkml.kernel.org/r/c6e7b507c72ca3bdbf6c7a8a3ceaa0334e873bd9.1460075211.git.luto@kernel.org
Pull x86 fixes from Ingo Molnar:
"Misc fixes:
- fix hotplug bugs
- fix irq live lock
- fix various topology handling bugs
- fix APIC ACK ordering
- fix PV iopl handling
- fix speling
- fix/tweak memcpy_mcsafe() return value
- fix fbcon bug
- remove stray prototypes"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/msr: Remove unused native_read_tscp()
x86/apic: Remove declaration of unused hw_nmi_is_cpu_stuck
x86/oprofile/nmi: Add missing hotplug FROZEN handling
x86/hpet: Use proper mask to modify hotplug action
x86/apic/uv: Fix the hotplug notifier
x86/apb/timer: Use proper mask to modify hotplug action
x86/topology: Use total_cpus not nr_cpu_ids for logical packages
x86/topology: Fix Intel HT disable
x86/topology: Fix logical package mapping
x86/irq: Cure live lock in fixup_irqs()
x86/tsc: Prevent NULL pointer deref in calibrate_delay_is_known()
x86/apic: Fix suspicious RCU usage in smp_trace_call_function_interrupt()
x86/iopl: Fix iopl capability check on Xen PV
x86/iopl/64: Properly context-switch IOPL on Xen PV
selftests/x86: Add an iopl test
x86/mm, x86/mce: Fix return type/value for memcpy_mcsafe()
x86/video: Don't assume all FB devices are PCI devices
arch/x86/irq: Purge useless handler declarations from hw_irq.h
x86: Fix misspellings in comments
x86's is_compat_task always checked the current syscall type, not the
task type. It has no non-arch users any more, so just remove it to
avoid confusion.
On x86, nothing should really be checking the task ABI. There are
legitimate users for the syscall ABI and for the mm ABI.
On Xen PV, regs->flags doesn't reliably reflect IOPL and the
exit-to-userspace code doesn't change IOPL. We need to context
switch it manually.
I'm doing this without going through paravirt because this is
specific to Xen PV. After the dust settles, we can merge this with
the 32-bit code, tidy up the iopl syscall implementation, and remove
the set_iopl pvop entirely.
Fixes XSA-171.
Reviewewd-by: Jan Beulich <JBeulich@suse.com>
Cc: Andrew Cooper <andrew.cooper3@citrix.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: Jan Beulich <JBeulich@suse.com>
Link: http://lkml.kernel.org/r/693c3bd7aeb4d3c27c92c622b7d0f554a458173c.1458162709.git.luto@kernel.org
Protection Keys never affect kernel mappings. But, they can
affect whether the kernel will fault when it touches a user
mapping. The kernel doesn't touch user mappings without some
careful choreography and these accesses don't generally result in
oopses. But, if one does, we definitely want to have PKRU
available so we can figure out if protection keys played a role.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Dave Hansen <dave@sr71.net>
Link: http://lkml.kernel.org/r/20160212210225.BF0D4482@viggo.jf.intel.com
This was meant to print base address and entry count; make it do so
again.
Fixes: 37868fe113ff "x86/ldt: Make modify_ldt synchronous"
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Link: http://lkml.kernel.org/r/56797D8402000078000C24F0@prv-mh.provo.novell.com
Fix obvious mistake: FS/GS should be DS/ES.
Signed-off-by: Chuck Ebbert <cebbert.lkml@gmail.com>
Link: http://lkml.kernel.org/r/20151014143119.78858eeb@r5
With the introduction of the context switch preempt_count invariant,
and the demise of PREEMPT_ACTIVE, its pointless to save/restore the
per-cpu preemption count, it must always be 2.
Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com>
The stack layout and the functionality is identical. Use the 64bit
version for all of x86.
Reviewed-by: Borislav Petkov <bp@alien8.de>
Reviewed-by: Dmitry Vyukov <dvyukov@google.com>
Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com>
Cc: Andrey Konovalov <andreyknvl@google.com>
Cc: Kostya Serebryany <kcc@google.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: kasan-dev <kasan-dev@googlegroups.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: Wolfram Gloger <wmglo@dent.med.uni-muenchen.de>
Link: http://lkml.kernel.org/r/20150930083302.779694618@linutronix.de
Dmitry Vyukov reported the following using trinity and the memory
error detector AddressSanitizer
(https://code.google.com/p/address-sanitizer/wiki/AddressSanitizerForKernel).
[ 124.575597] ERROR: AddressSanitizer: heap-buffer-overflow on
address ffff88002e280000
[ 124.576801] ffff88002e280000 is located 131938492886538 bytes to
the left of 28857600-byte region [ffffffff81282e0a, ffffffff82e0830a)
[ 124.578633] Accessed by thread T10915:
[ 124.579295] inlined in describe_heap_address
./arch/x86/mm/asan/report.c:164
[ 124.579295] #0 ffffffff810dd277 in asan_report_error
./arch/x86/mm/asan/report.c:278
[ 124.580137] #1 ffffffff810dc6a0 in asan_check_region
./arch/x86/mm/asan/asan.c:37
[ 124.581050] #2 ffffffff810dd423 in __tsan_read8 ??:0
[ 124.581893] #3 ffffffff8107c093 in get_wchan
./arch/x86/kernel/process_64.c:444
The address checks in the 64bit implementation of get_wchan() are
wrong in several ways:
- The lower bound of the stack is not the start of the stack
page. It's the start of the stack page plus sizeof (struct
thread_info)
- The upper bound must be:
top_of_stack - TOP_OF_KERNEL_STACK_PADDING - 2 * sizeof(unsigned long).
The 2 * sizeof(unsigned long) is required because the stack pointer
points at the frame pointer. The layout on the stack is: ... IP FP
... IP FP. So we need to make sure that both IP and FP are in the
bounds.
Fix the bound checks and get rid of the mix of numeric constants, u64
and unsigned long. Making all unsigned long allows us to use the same
function for 32bit as well.
Use READ_ONCE() when accessing the stack. This does not prevent a
concurrent wakeup of the task and the stack changing, but at least it
avoids TOCTOU.
Also check task state at the end of the loop. Again that does not
prevent concurrent changes, but it avoids walking for nothing.
Add proper comments while at it.
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Based-on-patch-from: Wolfram Gloger <wmglo@dent.med.uni-muenchen.de>
Link: http://lkml.kernel.org/r/20150930083302.694788319@linutronix.de
The modify_ldt syscall exposes a large attack surface and is
unnecessary for modern userspace. Make it optional.
Cc: Jan Beulich <jbeulich@suse.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: security@kernel.org <security@kernel.org>
Cc: xen-devel <xen-devel@lists.xen.org>
Link: http://lkml.kernel.org/r/a605166a771c343fd64802dece77a903507333bd.1438291540.git.luto@kernel.org
[ Made MATH_EMULATION dependent on MODIFY_LDT_SYSCALL. ]
modify_ldt() has questionable locking and does not synchronize
threads. Improve it: redesign the locking and synchronize all
threads' LDTs using an IPI on all modifications.
This will dramatically slow down modify_ldt in multithreaded
programs, but there shouldn't be any multithreaded programs that
care about modify_ldt's performance in the first place.
This fixes some fallout from the CVE-2015-5157 fixes.
Cc: <stable@vger.kernel.org>
Link: http://lkml.kernel.org/r/4c6978476782160600471bd865b318db34c7b628.1438291540.git.luto@kernel.org
This function is shared between the 32-bit compat and x32 ABIs.
Link: http://lkml.kernel.org/r/1434974121-32575-5-git-send-email-brgerst@gmail.com
For 32-bit userspace on a 64-bit kernel, this requires modifying
stub32_clone to actually swap the appropriate arguments to match
CONFIG_CLONE_BACKWARDS, rather than just leaving the C argument for tls
broken.
Patch co-authored by Josh Triplett and Thiago Macieira.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
Cc: Thiago Macieira <thiago.macieira@intel.com>
Pull x86 core updates from Ingo Molnar:
"There were so many changes in the x86/asm, x86/apic and x86/mm topics
in this cycle that the topical separation of -tip broke down somewhat -
so the result is a more traditional architecture pull request,
collected into the 'x86/core' topic.
The topics were still maintained separately as far as possible, so
bisectability and conceptual separation should still be pretty good -
but there were a handful of merge points to avoid excessive
dependencies (and conflicts) that would have been poorly tested in the
end.
The next cycle will hopefully be much more quiet (or at least will
have fewer dependencies).
The main changes in this cycle were:
* x86/apic changes, with related IRQ core changes: (Jiang Liu, Thomas
Gleixner)
- This is the second and most intrusive part of changes to the x86
interrupt handling - full conversion to hierarchical interrupt
domains:
[IOAPIC domain] -----
[MSI domain] --------[Remapping domain] ----- [ Vector domain ]
| (optional) |
[HPET MSI domain] ----- |
[DMAR domain] -----------------------------
[Legacy domain] -----------------------------
This now reflects the actual hardware and allowed us to distangle
the domain specific code from the underlying parent domain, which
can be optional in the case of interrupt remapping. It's a clear
separation of functionality and removes quite some duct tape
constructs which plugged the remap code between ioapic/msi/hpet
and the vector management.
- Intel IOMMU IRQ remapping enhancements, to allow direct interrupt
injection into guests (Feng Wu)
* x86/asm changes:
- Tons of cleanups and small speedups, micro-optimizations. This
is in preparation to move a good chunk of the low level entry
code from assembly to C code (Denys Vlasenko, Andy Lutomirski,
Brian Gerst)
- Moved all system entry related code to a new home under
arch/x86/entry/ (Ingo Molnar)
- Removal of the fragile and ugly CFI dwarf debuginfo annotations.
Conversion to C will reintroduce many of them - but meanwhile
they are only getting in the way, and the upstream kernel does
not rely on them (Ingo Molnar)
- NOP handling refinements. (Borislav Petkov)
* x86/mm changes:
- Big PAT and MTRR rework: making the code more robust and
preparing to phase out exposing direct MTRR interfaces to drivers -
in favor of using PAT driven interfaces (Toshi Kani, Luis R
Rodriguez, Borislav Petkov)
- New ioremap_wt()/set_memory_wt() interfaces to support
Write-Through cached memory mappings. This is especially
important for good performance on NVDIMM hardware (Toshi Kani)
* x86/ras changes:
- Add support for deferred errors on AMD (Aravind Gopalakrishnan)
This is an important RAS feature which adds hardware support for
poisoned data. That means roughly that the hardware marks data
which it has detected as corrupted but wasn't able to correct, as
poisoned data and raises an APIC interrupt to signal that in the
form of a deferred error. It is the OS's responsibility then to
take proper recovery action and thus prolonge system lifetime as
far as possible.
- Add support for Intel "Local MCE"s: upcoming CPUs will support
CPU-local MCE interrupts, as opposed to the traditional system-
wide broadcasted MCE interrupts (Ashok Raj)
- Misc cleanups (Borislav Petkov)
* x86/platform changes:
- Intel Atom SoC updates
... and lots of other cleanups, fixlets and other changes - see the
shortlog and the Git log for details"
* 'x86-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (222 commits)
x86/hpet: Use proper hpet device number for MSI allocation
x86/hpet: Check for irq==0 when allocating hpet MSI interrupts
x86/mm/pat, drivers/infiniband/ipath: Use arch_phys_wc_add() and require PAT disabled
x86/mm/pat, drivers/media/ivtv: Use arch_phys_wc_add() and require PAT disabled
x86/platform/intel/baytrail: Add comments about why we disabled HPET on Baytrail
genirq: Prevent crash in irq_move_irq()
genirq: Enhance irq_data_to_desc() to support hierarchy irqdomain
iommu, x86: Properly handle posted interrupts for IOMMU hotplug
iommu, x86: Provide irq_remapping_cap() interface
iommu, x86: Setup Posted-Interrupts capability for Intel iommu
iommu, x86: Add cap_pi_support() to detect VT-d PI capability
iommu, x86: Avoid migrating VT-d posted interrupts
iommu, x86: Save the mode (posted or remapped) of an IRTE
iommu, x86: Implement irq_set_vcpu_affinity for intel_ir_chip
iommu: dmar: Provide helper to copy shared irte fields
iommu: dmar: Extend struct irte for VT-d Posted-Interrupts
iommu: Add new member capability to struct irq_remap_ops
x86/asm/entry/64: Disentangle error_entry/exit gsbase/ebx/usermode code
x86/asm/entry/32: Shorten __audit_syscall_entry() args preparation
x86/asm/entry/32: Explain reloading of registers after __audit_syscall_entry()
This unifies all the FPU related header files under a unified, hiearchical
naming scheme:
- asm/fpu/types.h: FPU related data types, needed for 'struct task_struct',
widely included in almost all kernel code, and hence kept
as small as possible.
- asm/fpu/api.h: FPU related 'public' methods exported to other subsystems.
- asm/fpu/internal.h: FPU subsystem internal methods
- asm/fpu/xsave.h: XSAVE support internal methods
(Also standardize the header guard in asm/fpu/internal.h.)
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Migrate this function to pure 'struct fpu' usage.
Move to the new fpu__*() namespace.
Fix a minor header file dependency bug in asm/fpu-internal.h: it
relies on i387.h but does not include it. All users of fpu-internal.h
included it explicitly.
Also remove unnecessary includes, to reduce compilation time.
This also makes it easier to use it as a standalone header file
for FPU internals, such as an upcoming C module in arch/x86/kernel/fpu/.
Signed-off-by: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Alexei Starovoitov <ast@plumgrid.com>
Cc: Will Drewry <wad@chromium.org>
Link: http://lkml.kernel.org/r/1429889495-27850-2-git-send-email-dvlasenk@redhat.com
AMD CPUs don't reinitialize the SS descriptor on SYSRET, so SYSRET with
SS == 0 results in an invalid usermode state in which SS is apparently
equal to __USER_DS but causes #SS if used.
Work around the issue by setting SS to __KERNEL_DS __switch_to, thus
ensuring that SYSRET never happens with SS set to NULL.
This was exposed by a recent vDSO cleanup.
Fixes: e7d6eefaaa44 x86/vdso32/syscall.S: Do not load __USER32_DS to %ss
Cc: Peter Anvin <hpa@zytor.com>
Cc: Denys Vlasenko <vda.linux@googlemail.com>
PER_CPU_VAR(kernel_stack) was set up in a way where it points
five stack slots below the top of stack.
Presumably, it was done to avoid one "sub $5*8,%rsp"
in syscall/sysenter code paths, where iret frame needs to be
created by hand.
Ironically, none of them benefits from this optimization,
since all of them need to allocate additional data on stack
(struct pt_regs), so they still have to perform subtraction.
This patch eliminates KERNEL_STACK_OFFSET.
PER_CPU_VAR(kernel_stack) now points directly to top of stack.
pt_regs allocations are adjusted to allocate iret frame as well.
Hopefully we can merge it later with 32-bit specific
PER_CPU_VAR(cpu_current_top_of_stack) variable...
Net result in generated code is that constants in several insns
are changed.
This change is necessary for changing struct pt_regs creation
in SYSCALL64 code path from MOV to PUSH instructions.
Acked-by: Borislav Petkov <bp@suse.de>
Link: http://lkml.kernel.org/r/1426785469-15125-2-git-send-email-dvlasenk@redhat.com
Both the execve() and sigreturn() family of syscalls have the
ability to change registers in ways that may not be compatabile
with the syscall path they were called from.
In particular, SYSRET and SYSEXIT can't handle non-default %cs and %ss,
and some bits in eflags.
These syscalls have stubs that are hardcoded to jump to the IRET path,
and not return to the original syscall path.
The following commit:
76f5df43cab5e76 ("Always allocate a complete "struct pt_regs" on the kernel stack")
recently changed this for some 32-bit compat syscalls, but introduced a bug where
execve from a 32-bit program to a 64-bit program would fail because it still returned
via SYSRETL. This caused Wine to fail when built for both 32-bit and 64-bit.
This patch sets TIF_NOTIFY_RESUME for execve() and sigreturn() so
that the IRET path is always taken on exit to userspace.
Link: http://lkml.kernel.org/r/1426978461-32089-1-git-send-email-brgerst@gmail.com
[ Improved the changelog and comments. ]
Make clear that the usage of PER_CPU(old_rsp) is purely temporary,
by renaming it to 'rsp_scratch'.
Nothing uses thread_struct::usersp anymore, so remove it.
Originally-from: Denys Vlasenko <dvlasenk@redhat.com>
Tested-by: Borislav Petkov <bp@alien8.de>
Acked-by: Borislav Petkov <bp@alien8.de>
Remove all manipulations of PER_CPU(old_rsp) in C code:
- it is not used on SYSRET return anymore, and system entries
are atomic, so updating it from the fork and context switch
paths is pointless.
- Tweak a few related comments as well: we no longer have a
"partial stack frame" on entry, ever.
Based on (split out of) patch from Denys Vlasenko.
Link: http://lkml.kernel.org/r/1426599779-8010-2-git-send-email-dvlasenk@redhat.com
Prepare for the removal of 'usersp', by simplifying PER_CPU(old_rsp) usage:
- use it only as temp storage
- store the userspace stack pointer immediately in pt_regs->sp
on syscall entry, instead of using it later, on syscall exit.
- change C code to use pt_regs->sp only, instead of PER_CPU(old_rsp)
and task->thread.usersp.
FIXUP/RESTORE_TOP_OF_STACK are simplified as well.
Link: http://lkml.kernel.org/r/1425926364-9526-4-git-send-email-dvlasenk@redhat.com
The change:
75182b1632a8 ("x86/asm/entry: Switch all C consumers of kernel_stack to this_cpu_sp0()")
had the unintended side effect of changing the return value of
current_thread_info() during part of the context switch process.
Change it back.
This has no effect as far as I can tell -- it's just for
consistency.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Link: http://lkml.kernel.org/r/9fcaa47dd8487db59eed7a3911b6ae409476763e.1425692936.git.luto@amacapital.net
