path: root/arch/x86/kernel/reboot.c
2018-01-02x86/mm/64: Fix reboot interaction with CR4.PCIDEAndy Lutomirski
commit 924c6b900cfdf376b07bccfd80e62b21914f8a5a upstream. Trying to reboot via real mode fails with PCID on: long mode cannot be exited while CR4.PCIDE is set. (No, I have no idea why, but the SDM and actual CPUs are in agreement here.) The result is a GPF and a hang instead of a reboot. I didn't catch this in testing because neither my computer nor my VM reboots this way. I can trigger it with reboot=bios, though. Fixes: 660da7c9228f ("x86/mm: Enable CR4.PCIDE on supported systems") Reported-and-tested-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Andy Lutomirski <luto@kernel.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Borislav Petkov <bp@alien8.de> Link: https://lkml.kernel.org/r/f1e7d965998018450a7a70c2823873686a8b21c0.1507524746.git.luto@kernel.org Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-01-31x86/reboot/quirks: Add iMac10,1 to pci_reboot_dmi_table[]Mario Kleiner
commit 2f0c0b2d96b1205efb14347009748d786c2d9ba5 upstream. Without the reboot=pci method, the iMac 10,1 simply hangs after printing "Restarting system" at the point when it should reboot. This fixes it. Signed-off-by: Mario Kleiner <mario.kleiner.de@gmail.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1450466646-26663-1-git-send-email-mario.kleiner.de@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-10kexec: split kexec_load syscall from kexec core codeDave Young
There are two kexec load syscalls, kexec_load another and kexec_file_load. kexec_file_load has been splited as kernel/kexec_file.c. In this patch I split kexec_load syscall code to kernel/kexec.c. And add a new kconfig option KEXEC_CORE, so we can disable kexec_load and use kexec_file_load only, or vice verse. The original requirement is from Ted Ts'o, he want kexec kernel signature being checked with CONFIG_KEXEC_VERIFY_SIG enabled. But kexec-tools use kexec_load syscall can bypass the checking. Vivek Goyal proposed to create a common kconfig option so user can compile in only one syscall for loading kexec kernel. KEXEC/KEXEC_FILE selects KEXEC_CORE so that old config files still work. Because there's general code need CONFIG_KEXEC_CORE, so I updated all the architecture Kconfig with a new option KEXEC_CORE, and let KEXEC selects KEXEC_CORE in arch Kconfig. Also updated general kernel code with to kexec_load syscall. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Dave Young <dyoung@redhat.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Petr Tesarik <ptesarik@suse.cz> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Josh Boyer <jwboyer@fedoraproject.org> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-01x86/reboot: Add ASRock Q1900DC-ITX mainboard reboot quirkStefan Lippers-Hollmann
The ASRock Q1900DC-ITX mainboard (Baytrail-D) hangs randomly in both BIOS and UEFI mode while rebooting unless reboot=pci is used. Add a quirk to reboot via the pci method. The problem is very intermittent and hard to debug, it might succeed rebooting just fine 40 times in a row - but fails half a dozen times the next day. It seems to be slightly less common in BIOS CSM mode than native UEFI (with the CSM disabled), but it does happen in either mode. Since I've started testing this patch in late january, rebooting has been 100% reliable. Most of the time it already hangs during POST, but occasionally it might even make it through the bootloader and the kernel might even start booting, but then hangs before the mode switch. The same symptoms occur with grub-efi, gummiboot and grub-pc, just as well as (at least) kernel 3.16-3.19 and 4.0-rc6 (I haven't tried older kernels than 3.16). Upgrading to the most current mainboard firmware of the ASRock Q1900DC-ITX, version 1.20, does not improve the situation. ( Searching the web seems to suggest that other Bay Trail-D mainboards might be affected as well. ) -- Signed-off-by: Stefan Lippers-Hollmann <s.l-h@gmx.de> Cc: <stable@vger.kernel.org> Cc: Matt Fleming <matt.fleming@intel.com> Link: http://lkml.kernel.org/r/20150330224427.0fb58e42@mir Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-12-16x86, irq: Move IOAPIC related declarations from hw_irq.h into io_apic.hJiang Liu
Clean up code by moving IOAPIC related declarations from hw_irq.h into io_apic.h. Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: H. Peter Anvin <hpa@linux.intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Rafael J. Wysocki <rjw@rjwysocki.net> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Grant Likely <grant.likely@linaro.org> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Baoquan He <bhe@redhat.com> Cc: Matt Fleming <matt.fleming@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Aubrey <aubrey.li@linux.intel.com> Cc: Ryan Desfosses <ryan@desfo.org> Cc: Quentin Lambert <lambert.quentin@gmail.com> Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Link: http://lkml.kernel.org/r/1414397531-28254-14-git-send-email-jiang.liu@linux.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-07-18x86/reboot: Add EFI reboot quirk for ACPI Hardware Reduced flagMatt Fleming
It appears that the BayTrail-T class of hardware requires EFI in order to powerdown and reboot and no other reliable method exists. This quirk is generally applicable to all hardware that has the ACPI Hardware Reduced bit set, since usually ACPI would be the preferred method. Cc: Len Brown <len.brown@intel.com> Cc: Mark Salter <msalter@redhat.com> Cc: "Rafael J. Wysocki" <rafael.j.wysocki@intel.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2014-07-18efi/reboot: Add generic wrapper around EfiResetSystem()Matt Fleming
Implement efi_reboot(), which is really just a wrapper around the EfiResetSystem() EFI runtime service, but it does at least allow us to funnel all callers through a single location. It also simplifies the callsites since users no longer need to check to see whether EFI_RUNTIME_SERVICES are enabled. Cc: Tony Luck <tony.luck@intel.com> Tested-by: Mark Salter <msalter@redhat.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2014-05-07x86/reboot: Add reboot quirk for Certec BPC600Christian Gmeiner
Certec BPC600 needs reboot=pci to actually reboot. Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Li Aubrey <aubrey.li@linux.intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Dave Jones <davej@redhat.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1399446114-2147-1-git-send-email-christian.gmeiner@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-04-16x86: Remove the PCI reboot method from the default chainIngo Molnar
Steve reported a reboot hang and bisected it back to this commit: a4f1987e4c54 x86, reboot: Add EFI and CF9 reboot methods into the default list He heroically tested all reboot methods and found the following: reboot=t # triple fault ok reboot=k # keyboard ctrl FAIL reboot=b # BIOS ok reboot=a # ACPI FAIL reboot=e # EFI FAIL [system has no EFI] reboot=p # PCI 0xcf9 FAIL And I think it's pretty obvious that we should only try PCI 0xcf9 as a last resort - if at all. The other observation is that (on this box) we should never try the PCI reboot method, but close with either the 'triple fault' or the 'BIOS' (terminal!) reboot methods. Thirdly, CF9_COND is a total misnomer - it should be something like CF9_SAFE or CF9_CAREFUL, and 'CF9' should be 'CF9_FORCE' ... So this patch fixes the worst problems: - it orders the actual reboot logic to follow the reboot ordering pattern - it was in a pretty random order before for no good reason. - it fixes the CF9 misnomers and uses BOOT_CF9_FORCE and BOOT_CF9_SAFE flags to make the code more obvious. - it tries the BIOS reboot method before the PCI reboot method. (Since 'BIOS' is a terminal reboot method resulting in a hang if it does not work, this is essentially equivalent to removing the PCI reboot method from the default reboot chain.) - just for the miraculous possibility of terminal (resulting in hang) reboot methods of triple fault or BIOS returning without having done their job, there's an ordering between them as well. Reported-and-bisected-and-tested-by: Steven Rostedt <rostedt@goodmis.org> Cc: Li Aubrey <aubrey.li@linux.intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Link: http://lkml.kernel.org/r/20140404064120.GB11877@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-03-05x86, reboot: Only use CF9_COND automatically, not CF9H. Peter Anvin
Only CF9_COND is appropriate for inclusion in the default chain, not CF9; the latter will poke that register unconditionally, whereas CF9_COND will at least look for PCI configuration method #1 or #2 first (a weak check, but better than nothing.) CF9 should be used for explicit system configuration (command line or DMI) only. Cc: Aubrey Li <aubrey.li@intel.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Link: http://lkml.kernel.org/r/53130A46.1010801@linux.intel.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-03-05x86, reboot: Add EFI and CF9 reboot methods into the default listLi, Aubrey
Reboot is the last service linux OS provides to the end user. We are supposed to make this function more robust than today. This patch adds all of the known reboot methods into the default attempt list. The machines requiring reboot=efi or reboot=p or reboot=bios get a chance to reboot automatically now. If there is a new reboot method emerged, we are supposed to add it to the default list as well, instead of adding the endless dmidecode entry. If one method required is in the default list in this patch but the machine reboot still hangs, that means some methods ahead of the required method cause the system hangs, then reboot the machine by passing reboot= arguments and submit the reboot dmidecode table quirk. We are supposed to remove the reboot dmidecode table from the kernel, but to be safe, we keep it. This patch prevents us from adding more. If you happened to have a machine listed in the reboot dmidecode table and this patch makes reboot work on your machine, please submit a patch to remove the quirk. The default reboot order with this patch is now: ACPI > KBD > ACPI > KBD > EFI > CF9_COND > BIOS Because BIOS and TRIPLE are mutually exclusive (either will either work or hang the machine) that method is not included. [ hpa: as with any changes to the reboot order, this patch will have to be monitored carefully for regressions. ] Signed-off-by: Aubrey Li <aubrey.li@intel.com> Acked-by: Matthew Garrett <mjg59@srcf.ucam.org> Link: http://lkml.kernel.org/r/53130A46.1010801@linux.intel.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-12-04x86/apic, doc: Justification for disabling IO APIC before Local APICFenghua Yu
Since erratum AVR31 in "Intel Atom Processor C2000 Product Family Specification Update" is now published, I added a justification comment for disabling IO APIC before Local APIC, as changed in commit: 522e66464467 x86/apic: Disable I/O APIC before shutdown of the local APIC Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Link: http://lkml.kernel.org/r/1386202069-51515-1-git-send-email-fenghua.yu@intel.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-11-12Merge branch 'x86-reboot-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 reboot changes from Ingo Molnar: "Misc changes - the only one with functional impact should be commit 16c21ae5ca63 ("reboot: Allow specifying warm/cold reset for CF9 boot type") which extends cold/warm reboot handling to the 0xCF9 reboot method" * 'x86-reboot-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/reboot: Correct pr_info() log message in the set_bios/pci/kbd_reboot() x86/reboot: Sort reboot DMI quirks by vendor x86/reboot: Remove the duplicate C6100 entry in the reboot quirks list reboot: Allow specifying warm/cold reset for CF9 boot type
2013-11-07x86/apic: Disable I/O APIC before shutdown of the local APICFenghua Yu
In reboot and crash path, when we shut down the local APIC, the I/O APIC is still active. This may cause issues because external interrupts can still come in and disturb the local APIC during shutdown process. To quiet external interrupts, disable I/O APIC before shutdown local APIC. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Link: http://lkml.kernel.org/r/1382578212-4677-1-git-send-email-fenghua.yu@intel.com Cc: <stable@kernel.org> [ I suppose the 'issue' is a hang during shutdown. It's a fine change nevertheless. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-25x86/reboot: Correct pr_info() log message in the set_bios/pci/kbd_reboot()Lan Tianyu
commit: c767a54ba065 x86/debug: Add KERN_<LEVEL> to bare printks, convert printks to pr_<level> broke the log messages in the set_bios/pci/kbd_reboot() functions, by putting the reboot method string and quirk entry's ident string in the wrong order. This patch fixes it. Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Cc: holt@sgi.com Cc: davej@fedoraproject.org Cc: lenb@kernel.org Cc: rjw@rjwysocki.net Cc: awilliam@redhat.com Link: http://lkml.kernel.org/r/1382598693-29334-1-git-send-email-tianyu.lan@intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-06x86/reboot: Add reboot quirk for Dell Latitude E5410Ville Syrjälä
Dell Latitude E5410 needs reboot=pci to actually reboot. Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: http://lkml.kernel.org/r/1380888964-14517-1-git-send-email-ville.syrjala@linux.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-02x86/reboot: Sort reboot DMI quirks by vendorDave Jones
Grouping them by vendor should make it easier to spot duplicates. Signed-off-by: Dave Jones <davej@fedoraproject.org> Link: http://lkml.kernel.org/r/20131001203655.GA10719@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-26x86/reboot: Remove the duplicate C6100 entry in the reboot quirks listMasoud Sharbiani
Two entries for the same system type were added, with two different vendor names: 'Dell' and 'Dell, Inc.'. Since a prefix match is being used by the DMI parsing code, we can eliminate the latter as redundant. Reported-by: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Masoud Sharbiani <msharbiani@twitter.com> Cc: holt@sgi.com Link: http://lkml.kernel.org/r/1380216643-4683-1-git-send-email-masoud.sharbiani@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-26Merge branch 'linus'Ingo Molnar
Merge in the relevant upstream merge point to queue up dependent patch. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-25reboot: Allow specifying warm/cold reset for CF9 boot typeLi Fei
In current implementation for reboot type CF9 and CF9_COND, warm and cold reset are not differentiated, and both are performed by writing 0x06 to port 0xCF9. This commit will differentiate warm and cold reset: For warm reset, write 0x06 to port 0xCF9; For cold reset, write 0x0E to port 0xCF9. [ hpa: This meaning of "cold" and "warm" reset is different from other reboot types use, where "warm" means "bypass BIOS POST". It is also not entirely clear that it actually solves any actual problem. However, it would seem fairly harmless to offer this additional option. Also note that we do not mask bit 3 in the "warm reset" case. This preserves the behavior on existing systems, including ones quirked to use CF9. It seems reasonable that on any system where the warm/cold distinction actually matters that bit 3 would be read as zero. ] From: Liu Chuansheng <chuansheng.liu@intel.com> Signed-off-by: Li Fei <fei.li@intel.com> Link: http://lkml.kernel.org/r/1377072837.24556.2.camel@fli24-HP-Compaq-8100-Elite-CMT-PC Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-25x86/reboot: Fix apparent cut-n-paste mistake in Dell reboot workaroundDave Jones
This seems to have been copied from the Optiplex 990 entry above, but somoene forgot to change the ident text. Signed-off-by: Dave Jones <davej@fedoraproject.org> Link: http://lkml.kernel.org/r/20130925001344.GA13554@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-23x86/reboot: Add quirk to make Dell C6100 use reboot=pci automaticallyMasoud Sharbiani
Dell PowerEdge C6100 machines fail to completely reboot about 20% of the time. Signed-off-by: Masoud Sharbiani <msharbiani@twitter.com> Signed-off-by: Vinson Lee <vlee@twitter.com> Cc: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: <stable@vger.kernel.org> Link: http://lkml.kernel.org/r/1379717947-18042-1-git-send-email-vlee@freedesktop.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-07-09reboot: move arch/x86 reboot= handling to generic kernelRobin Holt
Merge together the unicore32, arm, and x86 reboot= command line parameter handling. Signed-off-by: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Acked-by: Ingo Molnar <mingo@kernel.org> Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09reboot: x86: prepare reboot_mode for moving to generic kernel codeRobin Holt
Prepare for the moving the parsing of reboot= to the generic kernel code by making reboot_mode into a more generic form. Signed-off-by: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Miguel Boton <mboton.lkml@gmail.com> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-30efi: Make 'efi_enabled' a function to query EFI facilitiesMatt Fleming
Originally 'efi_enabled' indicated whether a kernel was booted from EFI firmware. Over time its semantics have changed, and it now indicates whether or not we are booted on an EFI machine with bit-native firmware, e.g. 64-bit kernel with 64-bit firmware. The immediate motivation for this patch is the bug report at, https://bugs.launchpad.net/ubuntu-cdimage/+bug/1040557 which details how running a platform driver on an EFI machine that is designed to run under BIOS can cause the machine to become bricked. Also, the following report, https://bugzilla.kernel.org/show_bug.cgi?id=47121 details how running said driver can also cause Machine Check Exceptions. Drivers need a new means of detecting whether they're running on an EFI machine, as sadly the expression, if (!efi_enabled) hasn't been a sufficient condition for quite some time. Users actually want to query 'efi_enabled' for different reasons - what they really want access to is the list of available EFI facilities. For instance, the x86 reboot code needs to know whether it can invoke the ResetSystem() function provided by the EFI runtime services, while the ACPI OSL code wants to know whether the EFI config tables were mapped successfully. There are also checks in some of the platform driver code to simply see if they're running on an EFI machine (which would make it a bad idea to do BIOS-y things). This patch is a prereq for the samsung-laptop fix patch. Cc: David Airlie <airlied@linux.ie> Cc: Corentin Chary <corentincj@iksaif.net> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Dave Jiang <dave.jiang@intel.com> Cc: Olof Johansson <olof@lixom.net> Cc: Peter Jones <pjones@redhat.com> Cc: Colin Ian King <colin.king@canonical.com> Cc: Steve Langasek <steve.langasek@canonical.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Konrad Rzeszutek Wilk <konrad@kernel.org> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: <stable@vger.kernel.org> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2012-10-04x86/reboot: Remove quirk entry for SBC FITPCDavid Hooper
Remove the quirk for the SBC FITPC. It seems ot have been required when the default was kbd reboot, but no longer required now that the default is acpi reboot. Furthermore, BIOS reboot no longer works for this board as of 2.6.39 or any of the 3.x kernels. Signed-off-by: David Hooper <dave@beermex.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Link: http://lkml.kernel.org/r/20121002142635.17403.59959.stgit@localhost.localdomain Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-07-22Merge branch 'x86-reboot-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86/reboot changes from Ingo Molnar: "Now that the revampted x86 real-mode trampoline code is upstream and seems to be working well, we can extend the 64-bit reboot code to be as capable as the 32-bit one." * 'x86-reboot-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86-64, reboot: Be more paranoid in 64-bit reboot=bios x86, reboot: Drop redundant write of reboot_mode x86-64, reboot: Allow reboot=bios and reboot-cpu override on x86-64
2012-07-22Merge branch 'x86-debug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull debug-for-linus git tree from Ingo Molnar. Fix up trivial conflict in arch/x86/kernel/cpu/perf_event_intel.c due to a printk() having changed to a pr_info() differently in the two branches. * 'x86-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Move call to print_modules() out of show_regs() x86/mm: Mark free_initrd_mem() as __init x86/microcode: Mark microcode_id[] as __initconst x86/nmi: Clean up register_nmi_handler() usage x86: Save cr2 in NMI in case NMIs take a page fault (for i386) x86: Remove cmpxchg from i386 NMI nesting code x86: Save cr2 in NMI in case NMIs take a page fault x86/debug: Add KERN_<LEVEL> to bare printks, convert printks to pr_<level>
2012-06-30Merge branches 'acpi_pad-bugzilla-42981', 'apei-bugzilla-43282', ↵Len Brown
'video-bugzilla-43168', 'bugzilla-40002' and 'bugfix-misc' into release bug fixes
2012-06-20x86, reboot: Drop redundant write of reboot_modeH. Peter Anvin
We write reboot_mode to BIOS location 0x472 in native_machine_emergency_restart() (reboot.c:542) already, there is no need to then write it again in machine_real_restart(). This means nothing gets written there for MRR_APM, but the APM call is a poweroff call and doesn't use this memory location. Link: http://lkml.kernel.org/n/tip-3i0pfh44c1e3jv5lab0cf7sc@git.kernel.org Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2012-06-20Merge commit 'v3.5-rc3' into x86/debugIngo Molnar
Merge it in to pick up a fix that we are going to clean up in this branch. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-06-17x86-64, reboot: Allow reboot=bios and reboot-cpu override on x86-64H. Peter Anvin
With the revamped realmode trampoline code, it is trivial to extend support for reboot=bios to x86-64. Furthermore, while we are at it, remove the restriction that only we can only override the reboot CPU on 32 bits. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Link: http://lkml.kernel.org/n/tip-jopx7y6g6dbcx4tpal8q0jlr@git.kernel.org
2012-06-06x86/reboot: Fix a warning message triggered by stop_other_cpus()Feng Tang
When rebooting our 24 CPU Westmere servers with 3.4-rc6, we always see this warning msg: Restarting system. machine restart ------------[ cut here ]------------ WARNING: at arch/x86/kernel/smp.c:125 native_smp_send_reschedule+0x74/0xa7() Hardware name: X8DTN Modules linked in: igb [last unloaded: scsi_wait_scan] Pid: 1, comm: systemd-shutdow Not tainted 3.4.0-rc6+ #22 Call Trace: <IRQ> [<ffffffff8102a41f>] warn_slowpath_common+0x7e/0x96 [<ffffffff8102a44c>] warn_slowpath_null+0x15/0x17 [<ffffffff81018cf7>] native_smp_send_reschedule+0x74/0xa7 [<ffffffff810561c1>] trigger_load_balance+0x279/0x2a6 [<ffffffff81050112>] scheduler_tick+0xe0/0xe9 [<ffffffff81036768>] update_process_times+0x60/0x70 [<ffffffff81062f2f>] tick_sched_timer+0x68/0x92 [<ffffffff81046e33>] __run_hrtimer+0xb3/0x13c [<ffffffff81062ec7>] ? tick_nohz_handler+0xd0/0xd0 [<ffffffff810474f2>] hrtimer_interrupt+0xdb/0x198 [<ffffffff81019a35>] smp_apic_timer_interrupt+0x81/0x94 [<ffffffff81655187>] apic_timer_interrupt+0x67/0x70 <EOI> [<ffffffff8101a3c4>] ? default_send_IPI_mask_allbutself_phys+0xb4/0xc4 [<ffffffff8101c680>] physflat_send_IPI_allbutself+0x12/0x14 [<ffffffff81018db4>] native_nmi_stop_other_cpus+0x8a/0xd6 [<ffffffff810188ba>] native_machine_shutdown+0x50/0x67 [<ffffffff81018926>] machine_shutdown+0xa/0xc [<ffffffff8101897e>] native_machine_restart+0x20/0x32 [<ffffffff810189b0>] machine_restart+0xa/0xc [<ffffffff8103b196>] kernel_restart+0x47/0x4c [<ffffffff8103b2e6>] sys_reboot+0x13e/0x17c [<ffffffff8164e436>] ? _raw_spin_unlock_bh+0x10/0x12 [<ffffffff810fcac9>] ? bdi_queue_work+0xcf/0xd8 [<ffffffff810fe82f>] ? __bdi_start_writeback+0xae/0xb7 [<ffffffff810e0d64>] ? iterate_supers+0xa3/0xb7 [<ffffffff816547a2>] system_call_fastpath+0x16/0x1b ---[ end trace 320af5cb1cb60c5b ]--- The root cause seems to be the default_send_IPI_mask_allbutself_phys() takes quite some time (I measured it could be several ms) to complete sending NMIs to all the other 23 CPUs, and for HZ=250/1000 system, the time is long enough for a timer interrupt to happen, which will in turn trigger to kick load balance to a stopped CPU and cause this warning in native_smp_send_reschedule(). So disabling the local irq before stop_other_cpu() can fix this problem (tested 25 times reboot ok), and it is fine as there should be nobody caring the timer interrupt in such reboot stage. The latest 3.4 kernel slightly changes this behavior by sending REBOOT_VECTOR first and only send NMI_VECTOR if the REBOOT_VCTOR fails, and this patch is still needed to prevent the problem. Signed-off-by: Feng Tang <feng.tang@intel.com> Acked-by: Don Zickus <dzickus@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20120530231541.4c13433a@feng-i7 Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-06-06x86/debug: Add KERN_<LEVEL> to bare printks, convert printks to pr_<level>Joe Perches
Use a more current logging style: - Bare printks should have a KERN_<LEVEL> for consistency's sake - Add pr_fmt where appropriate - Neaten some macro definitions - Convert some Ok output to OK - Use "%s: ", __func__ in pr_fmt for summit - Convert some printks to pr_<level> Message output is not identical in all cases. Signed-off-by: Joe Perches <joe@perches.com> Cc: levinsasha928@gmail.com Link: http://lkml.kernel.org/r/1337655007.24226.10.camel@joe2Laptop [ merged two similar patches, tidied up the changelog ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-06-05ACPI, x86: fix Dell M6600 ACPI reboot regression via DMIZhang Rui
Dell Precision M6600 is known to require PCI reboot, so add it to the reboot blacklist in pci_reboot_dmi_table[]. https://bugzilla.kernel.org/show_bug.cgi?id=42749 cc: x86@kernel.org Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-05-29Merge branch 'x86-trampoline-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 trampoline rework from H. Peter Anvin: "This code reworks all the "trampoline"/"realmode" code (various bits that need to live in the first megabyte of memory, most but not all of which runs in real mode at some point) in the kernel into a single object. The main reason for doing this is that it eliminates the last place in the kernel where we needed pages to be mapped RWX. This code separates all that code into proper R/RW/RX pages." Fix up conflicts in arch/x86/kernel/Makefile (mca removed next to reboot code), and arch/x86/kernel/reboot.c (reboot code moved around in one branch, modified in this one), and arch/x86/tools/relocs.c (mostly same code came in earlier due to working around the ld bugs just before the 3.4 release). Also remove stale x86-relocs entry from scripts/.gitignore as per Peter Anvin. * commit '61f5446169046c217a5479517edac3a890c3bee7': (36 commits) x86, realmode: Move end signature into header.S x86, relocs: When printing an error, say relative or absolute x86, relocs: More relocations which may end up as absolute x86, relocs: Workaround for binutils 2.22.52.0.1 section bug xen-acpi-processor: Add missing #include <xen/xen.h> acpi, bgrd: Add missing <linux/io.h> to drivers/acpi/bgrt.c x86, realmode: Change EFER to a single u64 field x86, realmode: Move kernel/realmode.c to realmode/init.c x86, realmode: Move not-common bits out of trampoline_common.S x86, realmode: Mask out EFER.LMA when saving trampoline EFER x86, realmode: Fix no cache bits test in reboot_32.S x86, realmode: Make sure all generated files are listed in targets x86, realmode: build fix: remove duplicate build x86, realmode: read cr4 and EFER from kernel for 64-bit trampoline x86, realmode: fixes compilation issue in tboot.c x86, realmode: move relocs from scripts/ to arch/x86/tools x86, realmode: header for trampoline code x86, realmode: flattened rm hierachy x86, realmode: don't copy real_mode_header x86, realmode: fix 64-bit wakeup sequence ...
2012-05-08x86, realmode: don't copy real_mode_headerJarkko Sakkinen
Replaced copying of real_mode_header with a pointer to beginning of RM memory. Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@intel.com> Link: http://lkml.kernel.org/r/1336501366-28617-19-git-send-email-jarkko.sakkinen@intel.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2012-05-08x86, realmode: Move reboot_32.S to unified realmode codeJarkko Sakkinen
Migrated reboot_32.S from x86_trampoline to the real-mode blob. Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@intel.com> Link: http://lkml.kernel.org/r/1336501366-28617-5-git-send-email-jarkko.sakkinen@intel.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2012-02-07x86/reboot: Clean up coding styleMichael D Labriola
This commit simply cleans up the style used in this file to fall in line with what's specified in CodingStyle. Mostly comment changes, with a single removal of unneeded braces. Note that the comments for all the DMI quirks in reboot_dmi_table now all line up consistently using tabs instead of spaces. Signed-off-by: Michael D Labriola <michael.d.labriola@gmail.com> Link: http://lkml.kernel.org/n/tip-lde9yy7qsomh0sdqevn7xp56@git.kernel.org [ Fixed a few small details. ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-02-07x86/reboot: Reduce to a single DMI table for reboot quirksMichael D Labriola
This commit reduces the X86_32 reboot_dmi_table and the X86_64 pci_reboot_dmi_table into a single table with a single set of functions (e.g., only 1 call to core_initcall). The table entries that use set_bios_reboot are grouped together inside a #define CONFIG_X86_32 block. Note that there's a single entry that uses set_kbd_reboot, which used to be available only on X86_32. This commit moves that entry outside the X86_32 block because it seems it never should have been in there. There's multiple places in reboot.c that assume KBD is valid regardless of X86_32/X86_64. Signed-off-by: Michael D Labriola <michael.d.labriola@gmail.com> Cc: Matthew Garrett <mjg@redhat.com> Link: http://lkml.kernel.org/n/tip-lv3aliubas2l3aenq8v3uklk@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-01-30x86/reboot: Remove VersaLogic Menlow reboot quirkMichael D Labriola
This commit removes the reboot quirk originally added by commit e19e074 ("x86: Fix reboot problem on VersaLogic Menlow boards"). Testing with a VersaLogic Ocelot (VL-EPMs-21a rev 1.00 w/ BIOS 6.5.102) revealed the following regarding the reboot hang problem: - v2.6.37 reboot=bios was needed. - v2.6.38-rc1: behavior changed, reboot=acpi is needed, reboot=kbd and reboot=bios results in system hang. - v2.6.38: VersaLogic patch (e19e074 "x86: Fix reboot problem on VersaLogic Menlow boards") was applied prior to v2.6.38-rc7. This patch sets a quirk for VersaLogic Menlow boards that forces the use of reboot=bios, which doesn't work anymore. - v3.2: It seems that commit 660e34c ("x86: Reorder reboot method preferences") changed the default reboot method to acpi prior to v3.0-rc1, which means the default behavior is appropriate for the Ocelot. No VersaLogic quirk is required. The Ocelot board used for testing can successfully reboot w/out having to pass any reboot= arguments for all 3 current versions of the BIOS. Signed-off-by: Michael D Labriola <michael.d.labriola@gmail.com> Cc: Matthew Garrett <mjg@redhat.com> Cc: Michael D Labriola <mlabriol@gdeb.com> Cc: Kushal Koolwal <kushalkoolwal@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/87vcnub9hu.fsf@gmail.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-01-30x86/reboot: Skip DMI checks if reboot set by userMichael D Labriola
Skip DMI checks for vendor specific reboot quirks if the user passed in a reboot= arg on the command line - we should never override user choices. Signed-off-by: Michael D Labriola <michael.d.labriola@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Michael D Labriola <mlabriol@gdeb.com> Cc: Matthew Garrett <mjg@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/87wr8ab9od.fsf@gmail.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-05x86: Fix "Acer Aspire 1" reboot hangPeter Chubb
Looks like on some Acer Aspire 1s with older bioses, reboot via bios fails. It works on my machine, (with BIOS version 0.3310) but not on some others (BIOS version 0.3309). There's a log of problems at: https://bbs.archlinux.org/viewtopic.php?id=124136 This patch adds a different callback to the reboot quirk table, to allow rebooting via keybaord controller. Reported-by: Uroš Vampl <mobile.leecher@gmail.com> Tested-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Peter Chubb <peter.chubb@nicta.com.au> Cc: Don Zickus <dzickus@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: stable@kernel.org Link: http://lkml.kernel.org/r/1323093233-9481-1-git-send-email-anarsoul@gmail.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-05x86/reboot: Blacklist Dell OptiPlex 990 known to require PCI rebootRafael J. Wysocki
Dell OptiPlex 990 is known to require PCI reboot, so add it to the reboot blacklist in pci_reboot_dmi_table[]. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Link: http://lkml.kernel.org/r/201111160019.51303.rjw@sisk.pl Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-10-10x86, nmi: Wire up NMI handlers to new routinesDon Zickus
Just convert all the files that have an nmi handler to the new routines. Most of it is straight forward conversion. A couple of places needed some tweaking like kgdb which separates the debug notifier from the nmi handler and mce removes a call to notify_die. [Thanks to Ying for finding out the history behind that mce call https://lkml.org/lkml/2010/5/27/114 And Boris responding that he would like to remove that call because of it https://lkml.org/lkml/2011/9/21/163] The things that get converted are the registeration/unregistration routines and the nmi handler itself has its args changed along with code removal to check which list it is on (most are on one NMI list except for kgdb which has both an NMI routine and an NMI Unknown routine). Signed-off-by: Don Zickus <dzickus@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Corey Minyard <minyard@acm.org> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Robert Richter <robert.richter@amd.com> Cc: Huang Ying <ying.huang@intel.com> Cc: Corey Minyard <minyard@acm.org> Cc: Jack Steiner <steiner@sgi.com> Link: http://lkml.kernel.org/r/1317409584-23662-4-git-send-email-dzickus@redhat.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-21x86: Make Dell Latitude E6420 use reboot=pciH. Peter Anvin
Yet another variant of the Dell Latitude series which requires reboot=pci. From the E5420 bug report by Daniel J Blueman: > The E6420 is affected also (same platform, different casing and > features), which provides an external confirmation of the issue; I can > submit a patch for that later or include it if you prefer: > http://linux.koolsolutions.com/2009/08/04/howto-fix-linux-hangfreeze-during-reboots-and-restarts/ Reported-by: Daniel J Blueman <daniel.blueman@gmail.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: <stable@kernel.org>
2011-07-21x86: Make Dell Latitude E5420 use reboot=pciDaniel J Blueman
Rebooting on the Dell E5420 often hangs with the keyboard or ACPI methods, but is reliable via the PCI method. [ hpa: this was deferred because we believed for a long time that the recent reshuffling of the boot priorities in commit 660e34cebf0a11d54f2d5dd8838607452355f321 fixed this platform. Unfortunately that turned out to be incorrect. ] Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com> Link: http://lkml.kernel.org/r/1305248699-2347-1-git-send-email-daniel.blueman@gmail.com Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: <stable@kernel.org>
2011-07-12x86. reboot: Make Dell Latitude E6320 use reboot=pciMaxime Ripard
The Dell Latitude E6320 doesn't reboot unless reboot=pci is set. Force it thanks to DMI. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Link: http://lkml.kernel.org/r/1309269451-4966-1-git-send-email-maxime.ripard@free-electrons.com Cc: Matthew Garrett <mjg@redhat.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2011-07-05x86, reboot: Acer Aspire One A110 reboot quirkPeter Chubb
Since git commit 660e34cebf0a11d54f2d5dd8838607452355f321 x86: reorder reboot method preferences, my Acer Aspire One hangs on reboot. It appears that its ACPI method for rebooting is broken. The attached patch adds a quirk so that the machine will reboot via the BIOS. [ hpa: verified that the ACPI control on this machine is just plain broken. ] Signed-off-by: Peter Chubb <peter.chubb@nicta.com.au> Link: http://lkml.kernel.org/r/w439iki5vl.wl%25peter@chubb.wattle.id.au Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2011-04-06x86: Reorder reboot method preferencesMatthew Garrett
We have a never ending stream of 'reboot quirks' for new boxes that will not reboot properly under Linux (they will hang on reboot). The reason is widespread 'Windows compatible' assumption of modern x86 hardware, which expects the following reboot sequence: - hitting the ACPI reboot vector (if available) - trying the keyboard controller - hitting the ACPI reboot vector again - then giving the keyboard controller one last go This sequence expectation gets more and more embedded in modern hardware, which often lacks a keyboard controller and may even lock up if the legacy io ports are hit - and which hardware is often not tested with Linux during development. The end result is that reboot works under Windows-alike OSs but not under Linux. Rework our reboot process to meet this hardware externality a little better and match this assumption of newer x86 hardware. In addition to the ACPI,kbd,ACPI,kbd sequence we'll still fall through to attempting a legacy triple fault if nothing else works - and keep trying that and the kbd reset. Signed-off-by: Matthew Garrett <mjg@redhat.com> [ this commit will also save special casing Oaktrail boards ] Acked-by: Alan Cox <alan@linux.intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Leann Ogasawara <leann.ogasawara@canonical.com> Cc: Dave Jones <davej@redhat.com> Cc: Len Brown <len.brown@intel.com> LKML-Reference: <1301939705-2404-1-git-send-email-mjg@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
